RTEMS 6.1
CRC_HandleTypeDef Struct Reference
CRC Handle Structure definition. More...
#include <stm32h7xx_hal_crc.h>
CRC_TypeDefInstance
CRC_InitTypeDef Init
HAL_LockTypeDef Lock
__IO HAL_CRC_StateTypeDef State
uint32_t InputDataFormat
Field Documentation
◆ Init
CRC_InitTypeDef CRC_HandleTypeDef::Init
CRC configuration parameters
◆ InputDataFormat
uint32_t CRC_HandleTypeDef::InputDataFormat
This parameter is a value of Input Buffer Format and specifies input data format. Can be either
Note that constant CRC_INPUT_FORMAT_UNDEFINED is defined but an initialization error must occur if InputBufferFormat is not one of the three values listed above
◆ Instance
CRC_TypeDef* CRC_HandleTypeDef::Instance
Register base address
◆ Lock
HAL_LockTypeDef CRC_HandleTypeDef::Lock
CRC Locking object
◆ State
__IO HAL_CRC_StateTypeDef CRC_HandleTypeDef::State
CRC communication state
