RTEMS 6.1
CRC Init Structure definition. More...
#include <stm32h7xx_hal_crc.h>
Data Fields | |
| uint8_t | DefaultPolynomialUse |
| uint8_t | DefaultInitValueUse |
| uint32_t | GeneratingPolynomial |
| uint32_t | CRCLength |
| uint32_t | InitValue |
| uint32_t | InputDataInversionMode |
| uint32_t | OutputDataInversionMode |
| uint32_t CRC_InitTypeDef::CRCLength |
This parameter is a value of Polynomial sizes to configure the peripheral and indicates CRC length. Value can be either one of
| uint8_t CRC_InitTypeDef::DefaultInitValueUse |
This parameter is a value of Indicates whether or not default init value is used and indicates if default init value is used. If set to DEFAULT_INIT_VALUE_ENABLE, resort to default 0xFFFFFFFF value. In that case, there is no need to set InitValue field. If otherwise set to DEFAULT_INIT_VALUE_DISABLE, InitValue field must be set.
| uint8_t CRC_InitTypeDef::DefaultPolynomialUse |
This parameter is a value of Indicates whether or not default polynomial is used and indicates if default polynomial is used. If set to DEFAULT_POLYNOMIAL_ENABLE, resort to default X^32 + X^26 + X^23 + X^22 + X^16 + X^12 + X^11 + X^10 +X^8 + X^7 + X^5 + X^4 + X^2+ X +1. In that case, there is no need to set GeneratingPolynomial field. If otherwise set to DEFAULT_POLYNOMIAL_DISABLE, GeneratingPolynomial and CRCLength fields must be set.
| uint32_t CRC_InitTypeDef::GeneratingPolynomial |
Set CRC generating polynomial as a 7, 8, 16 or 32-bit long value for a polynomial degree respectively equal to 7, 8, 16 or 32. This field is written in normal, representation e.g., for a polynomial of degree 7, X^7 + X^6 + X^5 + X^2 + 1 is written 0x65. No need to specify it if DefaultPolynomialUse is set to DEFAULT_POLYNOMIAL_ENABLE.
| uint32_t CRC_InitTypeDef::InitValue |
Init value to initiate CRC computation. No need to specify it if DefaultInitValueUse is set to DEFAULT_INIT_VALUE_ENABLE.
| uint32_t CRC_InitTypeDef::InputDataInversionMode |
This parameter is a value of Input Data Inversion Modes and specifies input data inversion mode. Can be either one of the following values
| uint32_t CRC_InitTypeDef::OutputDataInversionMode |
This parameter is a value of Output Data Inversion Modes and specifies output data (i.e. CRC) inversion mode. Can be either
