RTEMS 6.1
CRC calculation unit. More...
#include <stm32h723xx.h>
__IO uint32_t DR
__IO uint32_t IDR
__IO uint32_t CR
uint32_t RESERVED2
__IO uint32_t INIT
__IO uint32_t POL
Field Documentation
◆ CR
__IO uint32_t CRC_TypeDef::CR
CRC Control register, Address offset: 0x08
◆ DR
__IO uint32_t CRC_TypeDef::DR
CRC Data register, Address offset: 0x00
◆ IDR
__IO uint32_t CRC_TypeDef::IDR
CRC Independent data register, Address offset: 0x04
◆ INIT
__IO uint32_t CRC_TypeDef::INIT
Initial CRC value register, Address offset: 0x10
◆ POL
__IO uint32_t CRC_TypeDef::POL
CRC polynomial register, Address offset: 0x14
◆ RESERVED2
uint32_t CRC_TypeDef::RESERVED2
Reserved, 0x0C
The documentation for this struct was generated from the following files:
