RTEMS 6.1
Structure definition of ADC instance and ADC group regular. More...
#include <stm32h7xx_hal_adc.h>
Data Fields | |
| uint32_t | ClockPrescaler |
| uint32_t | Resolution |
| uint32_t | ScanConvMode |
| uint32_t | EOCSelection |
| FunctionalState | LowPowerAutoWait |
| FunctionalState | ContinuousConvMode |
| uint32_t | NbrOfConversion |
| FunctionalState | DiscontinuousConvMode |
| uint32_t | NbrOfDiscConversion |
| uint32_t | ExternalTrigConv |
| uint32_t | ExternalTrigConvEdge |
| uint32_t | ConversionDataManagement |
| uint32_t | Overrun |
| uint32_t | LeftBitShift |
| FunctionalState | OversamplingMode |
| ADC_OversamplingTypeDef | Oversampling |
| uint32_t ADC_InitTypeDef::ClockPrescaler |
Select ADC clock source (synchronous clock derived from APB clock or asynchronous clock derived from system clock or PLL (Refer to reference manual for list of clocks available)) and clock prescaler. This parameter can be a value of ADC common - Clock source. Note: The ADC clock configuration is common to all ADC instances. Note: In case of usage of channels on injected group, ADC frequency should be lower than AHB clock frequency /4 for resolution 12 or 10 bits, AHB clock frequency /3 for resolution 8 bits, AHB clock frequency /2 for resolution 6 bits. Note: In case of synchronous clock mode based on HCLK/1, the configuration must be enabled only if the system clock has a 50% duty clock cycle (APB prescaler configured inside RCC must be bypassed and PCLK clock must have 50% duty cycle). Refer to reference manual for details. Note: In case of usage of asynchronous clock, the selected clock must be preliminarily enabled at RCC top level. Note: This parameter can be modified only if all ADC instances are disabled.
| FunctionalState ADC_InitTypeDef::ContinuousConvMode |
Specify whether the conversion is performed in single mode (one conversion) or continuous mode for ADC group regular, after the first ADC conversion start trigger occurred (software start or external trigger). This parameter can be set to ENABLE or DISABLE.
| uint32_t ADC_InitTypeDef::ConversionDataManagement |
Specifies whether the Data conversion data is managed: using the DMA (oneshot or circular), or stored in the DR register or transferred to DFSDM register. Note: In continuous mode, DMA must be configured in circular mode. Otherwise an overrun will be triggered when DMA buffer maximum pointer is reached. This parameter can be a value of ADC Conversion Data Management. Note: This parameter must be modified when no conversion is on going on both regular and injected groups (ADC disabled, or ADC enabled without continuous mode or external trigger that could launch a conversion).
| FunctionalState ADC_InitTypeDef::DiscontinuousConvMode |
Specify whether the conversions sequence of ADC group regular is performed in Complete-sequence/Discontinuous-sequence (main sequence subdivided in successive parts). Discontinuous mode is used only if sequencer is enabled (parameter 'ScanConvMode'). If sequencer is disabled, this parameter is discarded. Discontinuous mode can be enabled only if continuous mode is disabled. If continuous mode is enabled, this parameter setting is discarded. This parameter can be set to ENABLE or DISABLE.
| uint32_t ADC_InitTypeDef::EOCSelection |
Specify which EOC (End Of Conversion) flag is used for conversion by polling and interruption: end of unitary conversion or end of sequence conversions. This parameter can be a value of ADC sequencer end of unitary conversion or sequence conversions.
| uint32_t ADC_InitTypeDef::ExternalTrigConv |
Select the external event source used to trigger ADC group regular conversion start. If set to ADC_SOFTWARE_START, external triggers are disabled and software trigger is used instead. This parameter can be a value of ADC group regular trigger source. Caution: external trigger source is common to all ADC instances.
| uint32_t ADC_InitTypeDef::ExternalTrigConvEdge |
Select the external event edge used to trigger ADC group regular conversion start. If trigger source is set to ADC_SOFTWARE_START, this parameter is discarded. This parameter can be a value of ADC group regular trigger edge (when external trigger is selected)
| uint32_t ADC_InitTypeDef::LeftBitShift |
Configures the left shifting applied to the final result with or without oversampling. This parameter can be a value of ADC Extended Oversampling left Shift
| FunctionalState ADC_InitTypeDef::LowPowerAutoWait |
Select the dynamic low power Auto Delay: new conversion start only when the previous conversion (for ADC group regular) or previous sequence (for ADC group injected) has been retrieved by user software, using function HAL_ADC_GetValue() or HAL_ADCEx_InjectedGetValue(). This feature automatically adapts the frequency of ADC conversions triggers to the speed of the system that reads the data. Moreover, this avoids risk of overrun for low frequency applications. This parameter can be set to ENABLE or DISABLE. Note: It is not recommended to use with interruption or DMA (HAL_ADC_Start_IT(), HAL_ADC_Start_DMA()) since these modes have to clear immediately the EOC flag (by CPU to free the IRQ pending event or by DMA). Auto wait will work but fort a very short time, discarding its intended benefit (except specific case of high load of CPU or DMA transfers which can justify usage of auto wait). Do use with polling: 1. Start conversion with HAL_ADC_Start(), 2. Later on, when ADC conversion data is needed: and use HAL_ADC_GetValue() to retrieve conversion result and trig another conversion (in case of usage of injected group, use the equivalent functions HAL_ADCExInjected_Start(), HAL_ADCEx_InjectedGetValue(), ...).
| uint32_t ADC_InitTypeDef::NbrOfConversion |
Specify the number of ranks that will be converted within the regular group sequencer. To use the regular group sequencer and convert several ranks, parameter 'ScanConvMode' must be enabled. This parameter must be a number between Min_Data = 1 and Max_Data = 16. Note: This parameter must be modified when no conversion is on going on regular group (ADC disabled, or ADC enabled without continuous mode or external trigger that could launch a conversion).
| uint32_t ADC_InitTypeDef::NbrOfDiscConversion |
Specifies the number of discontinuous conversions in which the main sequence of ADC group regular (parameter NbrOfConversion) will be subdivided. If parameter 'DiscontinuousConvMode' is disabled, this parameter is discarded. This parameter must be a number between Min_Data = 1 and Max_Data = 8.
| uint32_t ADC_InitTypeDef::Overrun |
Select the behavior in case of overrun: data overwritten or preserved (default). This parameter applies to ADC group regular only. This parameter can be a value of ADC group regular - Overrun behavior on conversion data. Note: In case of overrun set to data preserved and usage with programming model with interruption (HAL_Start_IT()): ADC IRQ handler has to clear end of conversion flags, this induces the release of the preserved data. If needed, this data can be saved in function HAL_ADC_ConvCpltCallback(), placed in user program code (called before end of conversion flags clear). Note: Error reporting with respect to the conversion mode:
| ADC_OversamplingTypeDef ADC_InitTypeDef::Oversampling |
Specify the Oversampling parameters. Caution: this setting overwrites the previous oversampling configuration if oversampling is already enabled.
| FunctionalState ADC_InitTypeDef::OversamplingMode |
Specify whether the oversampling feature is enabled or disabled. This parameter can be set to ENABLE or DISABLE. Note: This parameter can be modified only if there is no conversion is ongoing on ADC groups regular and injected
| uint32_t ADC_InitTypeDef::Resolution |
Configure the ADC resolution. This parameter can be a value of ADC instance - Resolution
| uint32_t ADC_InitTypeDef::ScanConvMode |
Configure the sequencer of ADC groups regular and injected. This parameter can be associated to parameter 'DiscontinuousConvMode' to have main sequence subdivided in successive parts. If disabled: Conversion is performed in single mode (one channel converted, the one defined in rank 1). Parameters 'NbrOfConversion' and 'InjectedNbrOfConversion' are discarded (equivalent to set to 1). If enabled: Conversions are performed in sequence mode (multiple ranks defined by 'NbrOfConversion' or 'InjectedNbrOfConversion' and rank of each channel in sequencer). Scan direction is upward: from rank 1 to rank 'n'. This parameter can be a value of ADC sequencer scan mode
