RTEMS 6.1
#define ADC_SOFTWARE_START   (LL_ADC_REG_TRIG_SOFTWARE)
#define ADC_EXTERNALTRIG_T1_CC1   (LL_ADC_REG_TRIG_EXT_TIM1_CH1)
#define ADC_EXTERNALTRIG_T1_CC2   (LL_ADC_REG_TRIG_EXT_TIM1_CH2)
#define ADC_EXTERNALTRIG_T1_CC3   (LL_ADC_REG_TRIG_EXT_TIM1_CH3)
#define ADC_EXTERNALTRIG_T2_CC2   (LL_ADC_REG_TRIG_EXT_TIM2_CH2)
#define ADC_EXTERNALTRIG_T3_TRGO   (LL_ADC_REG_TRIG_EXT_TIM3_TRGO)
#define ADC_EXTERNALTRIG_T4_CC4   (LL_ADC_REG_TRIG_EXT_TIM4_CH4)
#define ADC_EXTERNALTRIG_EXT_IT11   (LL_ADC_REG_TRIG_EXT_EXTI_LINE11)
#define ADC_EXTERNALTRIG_T8_TRGO   (LL_ADC_REG_TRIG_EXT_TIM8_TRGO)
#define ADC_EXTERNALTRIG_T8_TRGO2   (LL_ADC_REG_TRIG_EXT_TIM8_TRGO2)
#define ADC_EXTERNALTRIG_T1_TRGO   (LL_ADC_REG_TRIG_EXT_TIM1_TRGO)
#define ADC_EXTERNALTRIG_T1_TRGO2   (LL_ADC_REG_TRIG_EXT_TIM1_TRGO2)
#define ADC_EXTERNALTRIG_T2_TRGO   (LL_ADC_REG_TRIG_EXT_TIM2_TRGO)
#define ADC_EXTERNALTRIG_T4_TRGO   (LL_ADC_REG_TRIG_EXT_TIM4_TRGO)
#define ADC_EXTERNALTRIG_T6_TRGO   (LL_ADC_REG_TRIG_EXT_TIM6_TRGO)
#define ADC_EXTERNALTRIG_T15_TRGO   (LL_ADC_REG_TRIG_EXT_TIM15_TRGO)
#define ADC_EXTERNALTRIG_T3_CC4   (LL_ADC_REG_TRIG_EXT_TIM3_CH4)
#define ADC_EXTERNALTRIG_HR1_ADCTRG1   (LL_ADC_REG_TRIG_EXT_HRTIM_TRG1)
#define ADC_EXTERNALTRIG_HR1_ADCTRG3   (LL_ADC_REG_TRIG_EXT_HRTIM_TRG3)
#define ADC_EXTERNALTRIG_LPTIM1_OUT   (LL_ADC_REG_TRIG_EXT_LPTIM1_OUT)
#define ADC_EXTERNALTRIG_LPTIM2_OUT   (LL_ADC_REG_TRIG_EXT_LPTIM2_OUT)
#define ADC_EXTERNALTRIG_LPTIM3_OUT   (LL_ADC_REG_TRIG_EXT_LPTIM3_OUT)
◆ ADC_EXTERNALTRIG_EXT_IT11
ADC group regular conversion trigger from external peripheral: external interrupt line 11 event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_HR1_ADCTRG1
ADC group regular conversion trigger from external peripheral: HRTIM TRG1 event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_HR1_ADCTRG3
ADC group regular conversion trigger from external peripheral: HRTIM TRG3 event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_LPTIM1_OUT
ADC group regular conversion trigger from external peripheral: LPTIM1 OUT event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_LPTIM2_OUT
ADC group regular conversion trigger from external peripheral: LPTIM2 OUT event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_LPTIM3_OUT
ADC group regular conversion trigger from external peripheral: LPTIM3 event OUT. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T15_TRGO
ADC group regular conversion trigger from external peripheral: TIM15 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T1_CC1
ADC group regular conversion trigger from external peripheral: TIM1 channel 1 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T1_CC2
ADC group regular conversion trigger from external peripheral: TIM1 channel 2 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T1_CC3
ADC group regular conversion trigger from external peripheral: TIM1 channel 3 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T1_TRGO
ADC group regular conversion trigger from external peripheral: TIM1 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T1_TRGO2
ADC group regular conversion trigger from external peripheral: TIM1 TRGO2 event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T2_CC2
ADC group regular conversion trigger from external peripheral: TIM2 channel 2 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T2_TRGO
ADC group regular conversion trigger from external peripheral: TIM2 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T3_CC4
ADC group regular conversion trigger from external peripheral: TIM3 channel 4 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T3_TRGO
ADC group regular conversion trigger from external peripheral: TIM3 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T4_CC4
ADC group regular conversion trigger from external peripheral: TIM4 channel 4 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T4_TRGO
ADC group regular conversion trigger from external peripheral: TIM4 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T6_TRGO
ADC group regular conversion trigger from external peripheral: TIM6 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T8_TRGO
ADC group regular conversion trigger from external peripheral: TIM8 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIG_T8_TRGO2
ADC group regular conversion trigger from external peripheral: TIM8 TRGO2 event. Trigger edge set to rising edge (default setting).
◆ ADC_SOFTWARE_START
ADC group regular conversion trigger internal: SW start.
