RTEMS 6.1
stm32h7xx_ll_cortex.h
1
34/* Define to prevent recursive inclusion -------------------------------------*/
35#ifndef STM32H7xx_LL_CORTEX_H
36#define STM32H7xx_LL_CORTEX_H
37
38#ifdef __cplusplus
39extern "C" {
40#endif
41
42/* Includes ------------------------------------------------------------------*/
43#include "stm32h7xx.h"
44
54/* Private types -------------------------------------------------------------*/
55/* Private variables ---------------------------------------------------------*/
56
57/* Private constants ---------------------------------------------------------*/
58
59/* Private macros ------------------------------------------------------------*/
60
61/* Exported types ------------------------------------------------------------*/
62/* Exported constants --------------------------------------------------------*/
72#define LL_SYSTICK_CLKSOURCE_HCLK_DIV8 0x00000000UL
73#define LL_SYSTICK_CLKSOURCE_HCLK SysTick_CTRL_CLKSOURCE_Msk
82#define LL_HANDLER_FAULT_USG SCB_SHCSR_USGFAULTENA_Msk
83#define LL_HANDLER_FAULT_BUS SCB_SHCSR_BUSFAULTENA_Msk
84#define LL_HANDLER_FAULT_MEM SCB_SHCSR_MEMFAULTENA_Msk
89#if __MPU_PRESENT
90
95#define LL_MPU_CTRL_HFNMI_PRIVDEF_NONE 0x00000000UL
96#define LL_MPU_CTRL_HARDFAULT_NMI MPU_CTRL_HFNMIENA_Msk
97#define LL_MPU_CTRL_PRIVILEGED_DEFAULT MPU_CTRL_PRIVDEFENA_Msk
98#define LL_MPU_CTRL_HFNMI_PRIVDEF (MPU_CTRL_HFNMIENA_Msk | MPU_CTRL_PRIVDEFENA_Msk)
107#define LL_MPU_REGION_NUMBER0 0x00UL
108#define LL_MPU_REGION_NUMBER1 0x01UL
109#define LL_MPU_REGION_NUMBER2 0x02UL
110#define LL_MPU_REGION_NUMBER3 0x03UL
111#define LL_MPU_REGION_NUMBER4 0x04UL
112#define LL_MPU_REGION_NUMBER5 0x05UL
113#define LL_MPU_REGION_NUMBER6 0x06UL
114#define LL_MPU_REGION_NUMBER7 0x07UL
115#if !defined(CORE_CM4)
116#define LL_MPU_REGION_NUMBER8 0x08UL
117#define LL_MPU_REGION_NUMBER9 0x09UL
118#define LL_MPU_REGION_NUMBER10 0x0AUL
119#define LL_MPU_REGION_NUMBER11 0x0BUL
120#define LL_MPU_REGION_NUMBER12 0x0CUL
121#define LL_MPU_REGION_NUMBER13 0x0DUL
122#define LL_MPU_REGION_NUMBER14 0x0EUL
123#define LL_MPU_REGION_NUMBER15 0x0FUL
124#endif /* !defined(CORE_CM4) */
133#define LL_MPU_REGION_SIZE_32B (0x04UL << MPU_RASR_SIZE_Pos)
134#define LL_MPU_REGION_SIZE_64B (0x05UL << MPU_RASR_SIZE_Pos)
135#define LL_MPU_REGION_SIZE_128B (0x06UL << MPU_RASR_SIZE_Pos)
136#define LL_MPU_REGION_SIZE_256B (0x07UL << MPU_RASR_SIZE_Pos)
137#define LL_MPU_REGION_SIZE_512B (0x08UL << MPU_RASR_SIZE_Pos)
138#define LL_MPU_REGION_SIZE_1KB (0x09UL << MPU_RASR_SIZE_Pos)
139#define LL_MPU_REGION_SIZE_2KB (0x0AUL << MPU_RASR_SIZE_Pos)
140#define LL_MPU_REGION_SIZE_4KB (0x0BUL << MPU_RASR_SIZE_Pos)
141#define LL_MPU_REGION_SIZE_8KB (0x0CUL << MPU_RASR_SIZE_Pos)
142#define LL_MPU_REGION_SIZE_16KB (0x0DUL << MPU_RASR_SIZE_Pos)
143#define LL_MPU_REGION_SIZE_32KB (0x0EUL << MPU_RASR_SIZE_Pos)
144#define LL_MPU_REGION_SIZE_64KB (0x0FUL << MPU_RASR_SIZE_Pos)
145#define LL_MPU_REGION_SIZE_128KB (0x10UL << MPU_RASR_SIZE_Pos)
146#define LL_MPU_REGION_SIZE_256KB (0x11UL << MPU_RASR_SIZE_Pos)
147#define LL_MPU_REGION_SIZE_512KB (0x12UL << MPU_RASR_SIZE_Pos)
148#define LL_MPU_REGION_SIZE_1MB (0x13UL << MPU_RASR_SIZE_Pos)
149#define LL_MPU_REGION_SIZE_2MB (0x14UL << MPU_RASR_SIZE_Pos)
150#define LL_MPU_REGION_SIZE_4MB (0x15UL << MPU_RASR_SIZE_Pos)
151#define LL_MPU_REGION_SIZE_8MB (0x16UL << MPU_RASR_SIZE_Pos)
152#define LL_MPU_REGION_SIZE_16MB (0x17UL << MPU_RASR_SIZE_Pos)
153#define LL_MPU_REGION_SIZE_32MB (0x18UL << MPU_RASR_SIZE_Pos)
154#define LL_MPU_REGION_SIZE_64MB (0x19UL << MPU_RASR_SIZE_Pos)
155#define LL_MPU_REGION_SIZE_128MB (0x1AUL << MPU_RASR_SIZE_Pos)
156#define LL_MPU_REGION_SIZE_256MB (0x1BUL << MPU_RASR_SIZE_Pos)
157#define LL_MPU_REGION_SIZE_512MB (0x1CUL << MPU_RASR_SIZE_Pos)
158#define LL_MPU_REGION_SIZE_1GB (0x1DUL << MPU_RASR_SIZE_Pos)
159#define LL_MPU_REGION_SIZE_2GB (0x1EUL << MPU_RASR_SIZE_Pos)
160#define LL_MPU_REGION_SIZE_4GB (0x1FUL << MPU_RASR_SIZE_Pos)
169#define LL_MPU_REGION_NO_ACCESS (0x00UL << MPU_RASR_AP_Pos)
170#define LL_MPU_REGION_PRIV_RW (0x01UL << MPU_RASR_AP_Pos)
171#define LL_MPU_REGION_PRIV_RW_URO (0x02UL << MPU_RASR_AP_Pos)
172#define LL_MPU_REGION_FULL_ACCESS (0x03UL << MPU_RASR_AP_Pos)
173#define LL_MPU_REGION_PRIV_RO (0x05UL << MPU_RASR_AP_Pos)
174#define LL_MPU_REGION_PRIV_RO_URO (0x06UL << MPU_RASR_AP_Pos)
183#define LL_MPU_TEX_LEVEL0 (0x00UL << MPU_RASR_TEX_Pos)
184#define LL_MPU_TEX_LEVEL1 (0x01UL << MPU_RASR_TEX_Pos)
185#define LL_MPU_TEX_LEVEL2 (0x02UL << MPU_RASR_TEX_Pos)
187/* Legacy Define */
188#define LL_MPU_TEX_LEVEL4 (0x04UL << MPU_RASR_TEX_Pos)
197#define LL_MPU_INSTRUCTION_ACCESS_ENABLE 0x00UL
198#define LL_MPU_INSTRUCTION_ACCESS_DISABLE MPU_RASR_XN_Msk
207#define LL_MPU_ACCESS_SHAREABLE MPU_RASR_S_Msk
208#define LL_MPU_ACCESS_NOT_SHAREABLE 0x00UL
217#define LL_MPU_ACCESS_CACHEABLE MPU_RASR_C_Msk
218#define LL_MPU_ACCESS_NOT_CACHEABLE 0x00UL
227#define LL_MPU_ACCESS_BUFFERABLE MPU_RASR_B_Msk
228#define LL_MPU_ACCESS_NOT_BUFFERABLE 0x00UL
232#endif /* __MPU_PRESENT */
237/* Exported macro ------------------------------------------------------------*/
238
239/* Exported functions --------------------------------------------------------*/
256__STATIC_INLINE uint32_t LL_SYSTICK_IsActiveCounterFlag(void)
257{
258 return (((SysTick->CTRL & SysTick_CTRL_COUNTFLAG_Msk) == (SysTick_CTRL_COUNTFLAG_Msk)) ? 1UL : 0UL);
259}
260
269__STATIC_INLINE void LL_SYSTICK_SetClkSource(uint32_t Source)
270{
271 MODIFY_REG(SysTick->CTRL, LL_SYSTICK_CLKSOURCE_HCLK, Source);
272}
273
281__STATIC_INLINE uint32_t LL_SYSTICK_GetClkSource(void)
282{
283 return (uint32_t)(READ_BIT(SysTick->CTRL, LL_SYSTICK_CLKSOURCE_HCLK));
284}
285
291__STATIC_INLINE void LL_SYSTICK_EnableIT(void)
292{
293 SET_BIT(SysTick->CTRL, SysTick_CTRL_TICKINT_Msk);
294}
295
301__STATIC_INLINE void LL_SYSTICK_DisableIT(void)
302{
303 CLEAR_BIT(SysTick->CTRL, SysTick_CTRL_TICKINT_Msk);
304}
305
311__STATIC_INLINE uint32_t LL_SYSTICK_IsEnabledIT(void)
312{
313 return ((READ_BIT(SysTick->CTRL, SysTick_CTRL_TICKINT_Msk) == (SysTick_CTRL_TICKINT_Msk)) ? 1UL : 0UL);
314}
315
330__STATIC_INLINE void LL_LPM_EnableSleep(void)
331{
332 /* Clear SLEEPDEEP bit of Cortex System Control Register */
333 CLEAR_BIT(SCB->SCR, SCB_SCR_SLEEPDEEP_Msk);
334}
335
341__STATIC_INLINE void LL_LPM_EnableDeepSleep(void)
342{
343 /* Set SLEEPDEEP bit of Cortex System Control Register */
344 SET_BIT(SCB->SCR, SCB_SCR_SLEEPDEEP_Msk);
345}
346
354__STATIC_INLINE void LL_LPM_EnableSleepOnExit(void)
355{
356 /* Set SLEEPONEXIT bit of Cortex System Control Register */
357 SET_BIT(SCB->SCR, SCB_SCR_SLEEPONEXIT_Msk);
358}
359
365__STATIC_INLINE void LL_LPM_DisableSleepOnExit(void)
366{
367 /* Clear SLEEPONEXIT bit of Cortex System Control Register */
368 CLEAR_BIT(SCB->SCR, SCB_SCR_SLEEPONEXIT_Msk);
369}
370
377__STATIC_INLINE void LL_LPM_EnableEventOnPend(void)
378{
379 /* Set SEVEONPEND bit of Cortex System Control Register */
380 SET_BIT(SCB->SCR, SCB_SCR_SEVONPEND_Msk);
381}
382
389__STATIC_INLINE void LL_LPM_DisableEventOnPend(void)
390{
391 /* Clear SEVEONPEND bit of Cortex System Control Register */
392 CLEAR_BIT(SCB->SCR, SCB_SCR_SEVONPEND_Msk);
393}
394
413__STATIC_INLINE void LL_HANDLER_EnableFault(uint32_t Fault)
414{
415 /* Enable the system handler fault */
416 SET_BIT(SCB->SHCSR, Fault);
417}
418
428__STATIC_INLINE void LL_HANDLER_DisableFault(uint32_t Fault)
429{
430 /* Disable the system handler fault */
431 CLEAR_BIT(SCB->SHCSR, Fault);
432}
433
448__STATIC_INLINE uint32_t LL_CPUID_GetImplementer(void)
449{
450 return (uint32_t)(READ_BIT(SCB->CPUID, SCB_CPUID_IMPLEMENTER_Msk) >> SCB_CPUID_IMPLEMENTER_Pos);
451}
452
458__STATIC_INLINE uint32_t LL_CPUID_GetVariant(void)
459{
460 return (uint32_t)(READ_BIT(SCB->CPUID, SCB_CPUID_VARIANT_Msk) >> SCB_CPUID_VARIANT_Pos);
461}
462
468__STATIC_INLINE uint32_t LL_CPUID_GetConstant(void)
469{
470 return (uint32_t)(READ_BIT(SCB->CPUID, SCB_CPUID_ARCHITECTURE_Msk) >> SCB_CPUID_ARCHITECTURE_Pos);
471}
472
478__STATIC_INLINE uint32_t LL_CPUID_GetParNo(void)
479{
480 return (uint32_t)(READ_BIT(SCB->CPUID, SCB_CPUID_PARTNO_Msk) >> SCB_CPUID_PARTNO_Pos);
481}
482
488__STATIC_INLINE uint32_t LL_CPUID_GetRevision(void)
489{
490 return (uint32_t)(READ_BIT(SCB->CPUID, SCB_CPUID_REVISION_Msk) >> SCB_CPUID_REVISION_Pos);
491}
492
497#if __MPU_PRESENT
513__STATIC_INLINE void LL_MPU_Enable(uint32_t Options)
514{
515 /* Enable the MPU*/
516 WRITE_REG(MPU->CTRL, (MPU_CTRL_ENABLE_Msk | Options));
517 /* Ensure MPU settings take effects */
518 __DSB();
519 /* Sequence instruction fetches using update settings */
520 __ISB();
521}
522
528__STATIC_INLINE void LL_MPU_Disable(void)
529{
530 /* Make sure outstanding transfers are done */
531 __DMB();
532 /* Disable MPU*/
533 WRITE_REG(MPU->CTRL, 0U);
534}
535
541__STATIC_INLINE uint32_t LL_MPU_IsEnabled(void)
542{
543 return ((READ_BIT(MPU->CTRL, MPU_CTRL_ENABLE_Msk) == (MPU_CTRL_ENABLE_Msk)) ? 1UL : 0UL);
544}
545
569__STATIC_INLINE void LL_MPU_EnableRegion(uint32_t Region)
570{
571 /* Set Region number */
572 WRITE_REG(MPU->RNR, Region);
573 /* Enable the MPU region */
574 SET_BIT(MPU->RASR, MPU_RASR_ENABLE_Msk);
575}
576
624__STATIC_INLINE void LL_MPU_ConfigRegion(uint32_t Region, uint32_t SubRegionDisable, uint32_t Address, uint32_t Attributes)
625{
626 /* Set Region number */
627 WRITE_REG(MPU->RNR, Region);
628 /* Set base address */
629 WRITE_REG(MPU->RBAR, (Address & 0xFFFFFFE0U));
630 /* Configure MPU */
631 WRITE_REG(MPU->RASR, (MPU_RASR_ENABLE_Msk | Attributes | (SubRegionDisable << MPU_RASR_SRD_Pos)));
632}
633
658__STATIC_INLINE void LL_MPU_DisableRegion(uint32_t Region)
659{
660 /* Set Region number */
661 WRITE_REG(MPU->RNR, Region);
662 /* Disable the MPU region */
663 CLEAR_BIT(MPU->RASR, MPU_RASR_ENABLE_Msk);
664}
665
670#endif /* __MPU_PRESENT */
683#ifdef __cplusplus
684}
685#endif
686
687#endif /* STM32H7xx_LL_CORTEX_H */
688
__STATIC_FORCEINLINE void __DSB(void)
Data Synchronization Barrier.
Definition: cmsis_gcc.h:286
__STATIC_FORCEINLINE void __DMB(void)
Data Memory Barrier.
Definition: cmsis_gcc.h:297
__STATIC_FORCEINLINE void __ISB(void)
Instruction Synchronization Barrier.
Definition: cmsis_gcc.h:275
#define SCB_CPUID_IMPLEMENTER_Msk
Definition: core_cm4.h:484
#define SCB_CPUID_VARIANT_Pos
Definition: core_cm4.h:486
#define SCB_CPUID_REVISION_Msk
Definition: core_cm4.h:496
#define SCB_CPUID_REVISION_Pos
Definition: core_cm4.h:495
#define SCB_SCR_SLEEPONEXIT_Msk
Definition: core_cm4.h:563
#define SCB_CPUID_IMPLEMENTER_Pos
Definition: core_cm4.h:483
#define SCB_CPUID_PARTNO_Pos
Definition: core_cm4.h:492
#define SCB_SCR_SLEEPDEEP_Msk
Definition: core_cm4.h:560
#define SCB_CPUID_PARTNO_Msk
Definition: core_cm4.h:493
#define SCB_CPUID_VARIANT_Msk
Definition: core_cm4.h:487
#define SCB_CPUID_ARCHITECTURE_Pos
Definition: core_cm4.h:489
#define SCB_CPUID_ARCHITECTURE_Msk
Definition: core_cm4.h:490
#define SCB_SCR_SEVONPEND_Msk
Definition: core_cm4.h:557
#define SysTick_CTRL_COUNTFLAG_Msk
Definition: core_cm4.h:786
#define SysTick_CTRL_TICKINT_Msk
Definition: core_cm4.h:792
#define SCB
Definition: core_cm4.h:1572
#define SysTick
Definition: core_cm4.h:1573
Definition: stm32h7xx_ll_cortex.h:73
Disable a fault in System handler control register (SHCSR) @rmtoll SCB_SHCSR MEMFAULTENA LL_HANDLER_D...
Definition: stm32h7xx_ll_cortex.h:428
Enable a fault in System handler control register (SHCSR) @rmtoll SCB_SHCSR MEMFAULTENA LL_HANDLER_En...
Definition: stm32h7xx_ll_cortex.h:413
Processor uses deep sleep as its low power mode @rmtoll SCB_SCR SLEEPDEEP LL_LPM_EnableDeepSleep.
Definition: stm32h7xx_ll_cortex.h:341
Do not sleep when returning to Thread mode. @rmtoll SCB_SCR SLEEPONEXIT LL_LPM_DisableSleepOnExit.
Definition: stm32h7xx_ll_cortex.h:365
Processor uses sleep as its low power mode @rmtoll SCB_SCR SLEEPDEEP LL_LPM_EnableSleep.
Definition: stm32h7xx_ll_cortex.h:330
Configures sleep-on-exit when returning from Handler mode to Thread mode.
Definition: stm32h7xx_ll_cortex.h:354
Enabled events and all interrupts, including disabled interrupts, can wakeup the processor....
Definition: stm32h7xx_ll_cortex.h:377
Only enabled interrupts or events can wakeup the processor, disabled interrupts are excluded @rmtoll ...
Definition: stm32h7xx_ll_cortex.h:389
Get Variant number (The r value in the rnpn product revision identifier) @rmtoll SCB_CPUID VARIANT LL...
Definition: stm32h7xx_ll_cortex.h:458
Get Implementer code @rmtoll SCB_CPUID IMPLEMENTER LL_CPUID_GetImplementer.
Definition: stm32h7xx_ll_cortex.h:448
Get Revision number (The p value in the rnpn product revision identifier, indicates patch release) @r...
Definition: stm32h7xx_ll_cortex.h:488
Get Constant number @rmtoll SCB_CPUID ARCHITECTURE LL_CPUID_GetConstant.
Definition: stm32h7xx_ll_cortex.h:468
Get Part number @rmtoll SCB_CPUID PARTNO LL_CPUID_GetParNo.
Definition: stm32h7xx_ll_cortex.h:478
Disable SysTick exception request @rmtoll STK_CTRL TICKINT LL_SYSTICK_DisableIT.
Definition: stm32h7xx_ll_cortex.h:301
Get the SysTick clock source @rmtoll STK_CTRL CLKSOURCE LL_SYSTICK_GetClkSource.
Definition: stm32h7xx_ll_cortex.h:281
Enable SysTick exception request @rmtoll STK_CTRL TICKINT LL_SYSTICK_EnableIT.
Definition: stm32h7xx_ll_cortex.h:291
Configures the SysTick clock source @rmtoll STK_CTRL CLKSOURCE LL_SYSTICK_SetClkSource.
Definition: stm32h7xx_ll_cortex.h:269
Checks if the SYSTICK interrupt is enabled or disabled. @rmtoll STK_CTRL TICKINT LL_SYSTICK_IsEnabled...
Definition: stm32h7xx_ll_cortex.h:311
This function checks if the Systick counter flag is active or not.
Definition: stm32h7xx_ll_cortex.h:256
CMSIS STM32H7xx Device Peripheral Access Layer Header File.
