RTEMS 6.1
__STATIC_INLINE void LL_HANDLER_EnableFault (uint32_t Fault)
 Enable a fault in System handler control register (SHCSR) @rmtoll SCB_SHCSR MEMFAULTENA LL_HANDLER_EnableFault.
__STATIC_INLINE void LL_HANDLER_DisableFault (uint32_t Fault)
 Disable a fault in System handler control register (SHCSR) @rmtoll SCB_SHCSR MEMFAULTENA LL_HANDLER_DisableFault.
◆ LL_HANDLER_DisableFault()
__STATIC_INLINE void LL_HANDLER_DisableFault ( uint32_t  Fault)
Parameters
FaultThis parameter can be a combination of the following values:
Return values
None
◆ LL_HANDLER_EnableFault()
__STATIC_INLINE void LL_HANDLER_EnableFault ( uint32_t  Fault)
Parameters
Return values
None
