RTEMS 6.1
Macros | Functions
stm32h7xx_ll_cortex.h File Reference
Header file of CORTEX LL module. More...
#include "stm32h7xx.h"
#define LL_SYSTICK_CLKSOURCE_HCLK_DIV8   0x00000000UL
#define LL_SYSTICK_CLKSOURCE_HCLK   SysTick_CTRL_CLKSOURCE_Msk
#define LL_HANDLER_FAULT_USG   SCB_SHCSR_USGFAULTENA_Msk
#define LL_HANDLER_FAULT_BUS   SCB_SHCSR_BUSFAULTENA_Msk
#define LL_HANDLER_FAULT_MEM   SCB_SHCSR_MEMFAULTENA_Msk
__STATIC_INLINE uint32_t LL_SYSTICK_IsActiveCounterFlag (void)
 This function checks if the Systick counter flag is active or not.
__STATIC_INLINE void LL_SYSTICK_SetClkSource (uint32_t Source)
 Configures the SysTick clock source @rmtoll STK_CTRL CLKSOURCE LL_SYSTICK_SetClkSource.
__STATIC_INLINE uint32_t LL_SYSTICK_GetClkSource (void)
 Get the SysTick clock source @rmtoll STK_CTRL CLKSOURCE LL_SYSTICK_GetClkSource.
__STATIC_INLINE void LL_SYSTICK_EnableIT (void)
 Enable SysTick exception request @rmtoll STK_CTRL TICKINT LL_SYSTICK_EnableIT.
__STATIC_INLINE void LL_SYSTICK_DisableIT (void)
 Disable SysTick exception request @rmtoll STK_CTRL TICKINT LL_SYSTICK_DisableIT.
__STATIC_INLINE uint32_t LL_SYSTICK_IsEnabledIT (void)
 Checks if the SYSTICK interrupt is enabled or disabled. @rmtoll STK_CTRL TICKINT LL_SYSTICK_IsEnabledIT.
__STATIC_INLINE void LL_LPM_EnableSleep (void)
 Processor uses sleep as its low power mode @rmtoll SCB_SCR SLEEPDEEP LL_LPM_EnableSleep.
__STATIC_INLINE void LL_LPM_EnableDeepSleep (void)
 Processor uses deep sleep as its low power mode @rmtoll SCB_SCR SLEEPDEEP LL_LPM_EnableDeepSleep.
__STATIC_INLINE void LL_LPM_EnableSleepOnExit (void)
 Configures sleep-on-exit when returning from Handler mode to Thread mode.
__STATIC_INLINE void LL_LPM_DisableSleepOnExit (void)
 Do not sleep when returning to Thread mode. @rmtoll SCB_SCR SLEEPONEXIT LL_LPM_DisableSleepOnExit.
__STATIC_INLINE void LL_LPM_EnableEventOnPend (void)
 Enabled events and all interrupts, including disabled interrupts, can wakeup the processor. @rmtoll SCB_SCR SEVEONPEND LL_LPM_EnableEventOnPend.
__STATIC_INLINE void LL_LPM_DisableEventOnPend (void)
 Only enabled interrupts or events can wakeup the processor, disabled interrupts are excluded @rmtoll SCB_SCR SEVEONPEND LL_LPM_DisableEventOnPend.
__STATIC_INLINE void LL_HANDLER_EnableFault (uint32_t Fault)
 Enable a fault in System handler control register (SHCSR) @rmtoll SCB_SHCSR MEMFAULTENA LL_HANDLER_EnableFault.
__STATIC_INLINE void LL_HANDLER_DisableFault (uint32_t Fault)
 Disable a fault in System handler control register (SHCSR) @rmtoll SCB_SHCSR MEMFAULTENA LL_HANDLER_DisableFault.
__STATIC_INLINE uint32_t LL_CPUID_GetImplementer (void)
 Get Implementer code @rmtoll SCB_CPUID IMPLEMENTER LL_CPUID_GetImplementer.
__STATIC_INLINE uint32_t LL_CPUID_GetVariant (void)
 Get Variant number (The r value in the rnpn product revision identifier) @rmtoll SCB_CPUID VARIANT LL_CPUID_GetVariant.
__STATIC_INLINE uint32_t LL_CPUID_GetConstant (void)
 Get Constant number @rmtoll SCB_CPUID ARCHITECTURE LL_CPUID_GetConstant.
__STATIC_INLINE uint32_t LL_CPUID_GetParNo (void)
 Get Part number @rmtoll SCB_CPUID PARTNO LL_CPUID_GetParNo.
__STATIC_INLINE uint32_t LL_CPUID_GetRevision (void)
 Get Revision number (The p value in the rnpn product revision identifier, indicates patch release) @rmtoll SCB_CPUID REVISION LL_CPUID_GetRevision.
Author
MCD Application Team
                   ##### How to use this driver #####
  The LL CORTEX driver contains a set of generic APIs that can be
  used by user:
    (+) SYSTICK configuration used by LL_mDelay and LL_Init1msTick
        functions
    (+) Low power mode configuration (SCB register of Cortex-MCU)
    (+) MPU API to configure and enable regions
    (+) API to access to MCU info (CPUID register)
    (+) API to enable fault handler (SHCSR accesses)
Attention
