RTEMS 6.1
| __STATIC_INLINE uint32_t | LL_SYSTICK_IsActiveCounterFlag (void) |
| This function checks if the Systick counter flag is active or not. | |
| __STATIC_INLINE void | LL_SYSTICK_SetClkSource (uint32_t Source) |
| Configures the SysTick clock source @rmtoll STK_CTRL CLKSOURCE LL_SYSTICK_SetClkSource. | |
| __STATIC_INLINE uint32_t | LL_SYSTICK_GetClkSource (void) |
| Get the SysTick clock source @rmtoll STK_CTRL CLKSOURCE LL_SYSTICK_GetClkSource. | |
| __STATIC_INLINE void | LL_SYSTICK_EnableIT (void) |
| Enable SysTick exception request @rmtoll STK_CTRL TICKINT LL_SYSTICK_EnableIT. | |
| __STATIC_INLINE void | LL_SYSTICK_DisableIT (void) |
| Disable SysTick exception request @rmtoll STK_CTRL TICKINT LL_SYSTICK_DisableIT. | |
| __STATIC_INLINE uint32_t | LL_SYSTICK_IsEnabledIT (void) |
| Checks if the SYSTICK interrupt is enabled or disabled. @rmtoll STK_CTRL TICKINT LL_SYSTICK_IsEnabledIT. | |
| __STATIC_INLINE void LL_SYSTICK_DisableIT | ( | void | ) |
| None |
| __STATIC_INLINE void LL_SYSTICK_EnableIT | ( | void | ) |
| None |
| __STATIC_INLINE uint32_t LL_SYSTICK_GetClkSource | ( | void | ) |
| Returned | value can be one of the following values: |
| __STATIC_INLINE uint32_t LL_SYSTICK_IsActiveCounterFlag | ( | void | ) |
| State | of bit (1 or 0). |
| __STATIC_INLINE uint32_t LL_SYSTICK_IsEnabledIT | ( | void | ) |
| __STATIC_INLINE void LL_SYSTICK_SetClkSource | ( | uint32_t | Source | ) |
| Source | This parameter can be one of the following values: |
| None |
