RTEMS 6.1
Header file of I2C HAL module. More...
| struct | I2C_InitTypeDef |
| struct | __I2C_HandleTypeDef |
| #define | HAL_I2C_ERROR_NONE (0x00000000U) |
| #define | HAL_I2C_ERROR_BERR (0x00000001U) |
| #define | HAL_I2C_ERROR_ARLO (0x00000002U) |
| #define | HAL_I2C_ERROR_AF (0x00000004U) |
| #define | HAL_I2C_ERROR_OVR (0x00000008U) |
| #define | HAL_I2C_ERROR_DMA (0x00000010U) |
| #define | HAL_I2C_ERROR_TIMEOUT (0x00000020U) |
| #define | HAL_I2C_ERROR_SIZE (0x00000040U) |
| #define | HAL_I2C_ERROR_DMA_PARAM (0x00000080U) |
| #define | HAL_I2C_ERROR_INVALID_PARAM (0x00000200U) |
| #define | I2C_FIRST_FRAME ((uint32_t)I2C_SOFTEND_MODE) |
| #define | I2C_FIRST_AND_NEXT_FRAME ((uint32_t)(I2C_RELOAD_MODE | I2C_SOFTEND_MODE)) |
| #define | I2C_NEXT_FRAME ((uint32_t)(I2C_RELOAD_MODE | I2C_SOFTEND_MODE)) |
| #define | I2C_FIRST_AND_LAST_FRAME ((uint32_t)I2C_AUTOEND_MODE) |
| #define | I2C_LAST_FRAME ((uint32_t)I2C_AUTOEND_MODE) |
| #define | I2C_LAST_FRAME_NO_STOP ((uint32_t)I2C_SOFTEND_MODE) |
| #define | I2C_OTHER_FRAME (0x000000AAU) |
| #define | I2C_OTHER_AND_LAST_FRAME (0x0000AA00U) |
| #define | I2C_ADDRESSINGMODE_7BIT (0x00000001U) |
| #define | I2C_ADDRESSINGMODE_10BIT (0x00000002U) |
| #define | I2C_DUALADDRESS_DISABLE (0x00000000U) |
| #define | I2C_DUALADDRESS_ENABLE I2C_OAR2_OA2EN |
| #define | I2C_OA2_NOMASK ((uint8_t)0x00U) |
| #define | I2C_OA2_MASK01 ((uint8_t)0x01U) |
| #define | I2C_OA2_MASK02 ((uint8_t)0x02U) |
| #define | I2C_OA2_MASK03 ((uint8_t)0x03U) |
| #define | I2C_OA2_MASK04 ((uint8_t)0x04U) |
| #define | I2C_OA2_MASK05 ((uint8_t)0x05U) |
| #define | I2C_OA2_MASK06 ((uint8_t)0x06U) |
| #define | I2C_OA2_MASK07 ((uint8_t)0x07U) |
| #define | I2C_GENERALCALL_DISABLE (0x00000000U) |
| #define | I2C_GENERALCALL_ENABLE I2C_CR1_GCEN |
| #define | I2C_NOSTRETCH_DISABLE (0x00000000U) |
| #define | I2C_NOSTRETCH_ENABLE I2C_CR1_NOSTRETCH |
| #define | I2C_MEMADD_SIZE_8BIT (0x00000001U) |
| #define | I2C_MEMADD_SIZE_16BIT (0x00000002U) |
| #define | I2C_DIRECTION_TRANSMIT (0x00000000U) |
| #define | I2C_DIRECTION_RECEIVE (0x00000001U) |
| #define | I2C_RELOAD_MODE I2C_CR2_RELOAD |
| #define | I2C_AUTOEND_MODE I2C_CR2_AUTOEND |
| #define | I2C_SOFTEND_MODE (0x00000000U) |
| #define | I2C_NO_STARTSTOP (0x00000000U) |
| #define | I2C_GENERATE_STOP (uint32_t)(0x80000000U | I2C_CR2_STOP) |
| #define | I2C_GENERATE_START_READ (uint32_t)(0x80000000U | I2C_CR2_START | I2C_CR2_RD_WRN) |
| #define | I2C_GENERATE_START_WRITE (uint32_t)(0x80000000U | I2C_CR2_START) |
| #define | I2C_IT_ERRI I2C_CR1_ERRIE |
| #define | I2C_IT_TCI I2C_CR1_TCIE |
| #define | I2C_IT_STOPI I2C_CR1_STOPIE |
| #define | I2C_IT_NACKI I2C_CR1_NACKIE |
| #define | I2C_IT_ADDRI I2C_CR1_ADDRIE |
| #define | I2C_IT_RXI I2C_CR1_RXIE |
| #define | I2C_IT_TXI I2C_CR1_TXIE |
| #define | I2C_FLAG_TXE I2C_ISR_TXE |
| #define | I2C_FLAG_TXIS I2C_ISR_TXIS |
| #define | I2C_FLAG_RXNE I2C_ISR_RXNE |
| #define | I2C_FLAG_ADDR I2C_ISR_ADDR |
| #define | I2C_FLAG_AF I2C_ISR_NACKF |
| #define | I2C_FLAG_STOPF I2C_ISR_STOPF |
| #define | I2C_FLAG_TC I2C_ISR_TC |
| #define | I2C_FLAG_TCR I2C_ISR_TCR |
| #define | I2C_FLAG_BERR I2C_ISR_BERR |
| #define | I2C_FLAG_ARLO I2C_ISR_ARLO |
| #define | I2C_FLAG_OVR I2C_ISR_OVR |
| #define | I2C_FLAG_PECERR I2C_ISR_PECERR |
| #define | I2C_FLAG_TIMEOUT I2C_ISR_TIMEOUT |
| #define | I2C_FLAG_ALERT I2C_ISR_ALERT |
| #define | I2C_FLAG_BUSY I2C_ISR_BUSY |
| #define | I2C_FLAG_DIR I2C_ISR_DIR |
| #define | __HAL_I2C_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_I2C_STATE_RESET) |
| Reset I2C handle state. | |
| #define | __HAL_I2C_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR1 |= (__INTERRUPT__)) |
| Enable the specified I2C interrupt. | |
| #define | __HAL_I2C_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR1 &= (~(__INTERRUPT__))) |
| Disable the specified I2C interrupt. | |
| #define | __HAL_I2C_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check whether the specified I2C interrupt source is enabled or not. | |
| #define | I2C_FLAG_MASK (0x0001FFFFU) |
| Check whether the specified I2C flag is set or not. | |
| #define | __HAL_I2C_GET_FLAG(__HANDLE__, __FLAG__) |
| #define | __HAL_I2C_CLEAR_FLAG(__HANDLE__, __FLAG__) |
| Clear the I2C pending flags which are cleared by writing 1 in a specific bit. | |
| #define | __HAL_I2C_ENABLE(__HANDLE__) (SET_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE)) |
| Enable the specified I2C peripheral. | |
| #define | __HAL_I2C_DISABLE(__HANDLE__) (CLEAR_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE)) |
| Disable the specified I2C peripheral. | |
| #define | __HAL_I2C_GENERATE_NACK(__HANDLE__) (SET_BIT((__HANDLE__)->Instance->CR2, I2C_CR2_NACK)) |
| Generate a Non-Acknowledge I2C peripheral in Slave mode. | |
| #define | IS_I2C_ADDRESSING_MODE(MODE) |
| #define | IS_I2C_DUAL_ADDRESS(ADDRESS) |
| #define | IS_I2C_OWN_ADDRESS2_MASK(MASK) |
| #define | IS_I2C_GENERAL_CALL(CALL) |
| #define | IS_I2C_NO_STRETCH(STRETCH) |
| #define | IS_I2C_MEMADD_SIZE(SIZE) |
| #define | IS_TRANSFER_MODE(MODE) |
| #define | IS_TRANSFER_REQUEST(REQUEST) |
| #define | IS_I2C_TRANSFER_OPTIONS_REQUEST(REQUEST) |
| #define | IS_I2C_TRANSFER_OTHER_OPTIONS_REQUEST(REQUEST) |
| #define | I2C_RESET_CR2(__HANDLE__) |
| #define | I2C_GET_ADDR_MATCH(__HANDLE__) |
| #define | I2C_GET_DIR(__HANDLE__) |
| #define | I2C_GET_STOP_MODE(__HANDLE__) ((__HANDLE__)->Instance->CR2 & I2C_CR2_AUTOEND) |
| #define | I2C_GET_OWN_ADDRESS1(__HANDLE__) ((uint16_t)((__HANDLE__)->Instance->OAR1 & I2C_OAR1_OA1)) |
| #define | I2C_GET_OWN_ADDRESS2(__HANDLE__) ((uint16_t)((__HANDLE__)->Instance->OAR2 & I2C_OAR2_OA2)) |
| #define | IS_I2C_OWN_ADDRESS1(ADDRESS1) ((ADDRESS1) <= 0x000003FFU) |
| #define | IS_I2C_OWN_ADDRESS2(ADDRESS2) ((ADDRESS2) <= (uint16_t)0x00FFU) |
| #define | I2C_MEM_ADD_MSB(__ADDRESS__) |
| #define | I2C_MEM_ADD_LSB(__ADDRESS__) ((uint8_t)((uint16_t)((__ADDRESS__) & (uint16_t)(0x00FFU)))) |
| #define | I2C_GENERATE_START(__ADDMODE__, __ADDRESS__) |
| #define | I2C_CHECK_FLAG(__ISR__, __FLAG__) |
| #define | I2C_CHECK_IT_SOURCE(__CR1__, __IT__) ((((__CR1__) & (__IT__)) == (__IT__)) ? SET : RESET) |
Typedefs | |
| typedef struct __I2C_HandleTypeDef | I2C_HandleTypeDef |
Enumerations | |
| enum | HAL_I2C_StateTypeDef { HAL_I2C_STATE_RESET = 0x00U , HAL_I2C_STATE_READY = 0x20U , HAL_I2C_STATE_BUSY = 0x24U , HAL_I2C_STATE_BUSY_TX = 0x21U , HAL_I2C_STATE_BUSY_RX = 0x22U , HAL_I2C_STATE_LISTEN = 0x28U , HAL_I2C_STATE_BUSY_TX_LISTEN = 0x29U , HAL_I2C_STATE_BUSY_RX_LISTEN = 0x2AU , HAL_I2C_STATE_ABORT = 0x60U } |
| enum | HAL_I2C_ModeTypeDef { HAL_I2C_MODE_NONE = 0x00U , HAL_I2C_MODE_MASTER = 0x10U , HAL_I2C_MODE_SLAVE = 0x20U , HAL_I2C_MODE_MEM = 0x40U } |
| HAL_StatusTypeDef | HAL_I2C_Init (I2C_HandleTypeDef *hi2c) |
| HAL_StatusTypeDef | HAL_I2C_DeInit (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_MspInit (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_MspDeInit (I2C_HandleTypeDef *hi2c) |
| HAL_StatusTypeDef | HAL_I2C_Master_Transmit (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_I2C_Master_Receive (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_I2C_Slave_Transmit (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_I2C_Slave_Receive (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_I2C_Mem_Write (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_I2C_Mem_Read (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_I2C_IsDeviceReady (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint32_t Trials, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_I2C_Master_Transmit_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Master_Receive_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Slave_Transmit_IT (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Slave_Receive_IT (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Mem_Write_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Mem_Read_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Master_Seq_Transmit_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t XferOptions) |
| HAL_StatusTypeDef | HAL_I2C_Master_Seq_Receive_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t XferOptions) |
| HAL_StatusTypeDef | HAL_I2C_Slave_Seq_Transmit_IT (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t XferOptions) |
| HAL_StatusTypeDef | HAL_I2C_Slave_Seq_Receive_IT (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t XferOptions) |
| HAL_StatusTypeDef | HAL_I2C_EnableListen_IT (I2C_HandleTypeDef *hi2c) |
| HAL_StatusTypeDef | HAL_I2C_DisableListen_IT (I2C_HandleTypeDef *hi2c) |
| HAL_StatusTypeDef | HAL_I2C_Master_Abort_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress) |
| HAL_StatusTypeDef | HAL_I2C_Master_Transmit_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Master_Receive_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Slave_Transmit_DMA (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Slave_Receive_DMA (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Mem_Write_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Mem_Read_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_I2C_Master_Seq_Transmit_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t XferOptions) |
| HAL_StatusTypeDef | HAL_I2C_Master_Seq_Receive_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t XferOptions) |
| HAL_StatusTypeDef | HAL_I2C_Slave_Seq_Transmit_DMA (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t XferOptions) |
| HAL_StatusTypeDef | HAL_I2C_Slave_Seq_Receive_DMA (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t XferOptions) |
| void | HAL_I2C_EV_IRQHandler (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_ER_IRQHandler (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_MasterTxCpltCallback (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_MasterRxCpltCallback (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_SlaveTxCpltCallback (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_SlaveRxCpltCallback (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_AddrCallback (I2C_HandleTypeDef *hi2c, uint8_t TransferDirection, uint16_t AddrMatchCode) |
| void | HAL_I2C_ListenCpltCallback (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_MemTxCpltCallback (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_MemRxCpltCallback (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_ErrorCallback (I2C_HandleTypeDef *hi2c) |
| void | HAL_I2C_AbortCpltCallback (I2C_HandleTypeDef *hi2c) |
| HAL_I2C_StateTypeDef | HAL_I2C_GetState (const I2C_HandleTypeDef *hi2c) |
| HAL_I2C_ModeTypeDef | HAL_I2C_GetMode (const I2C_HandleTypeDef *hi2c) |
| uint32_t | HAL_I2C_GetError (const I2C_HandleTypeDef *hi2c) |
