RTEMS 6.1
ata.h
2
3/*
4 * Copyright (C) 2010, 2013 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef GEN5200_ATA_H
29#define GEN5200_ATA_H
30
31#include "bestcomm.h"
32
33#include <assert.h>
34
35#include <rtems.h>
36#include <rtems/diskdevs.h>
37#include <rtems/bdbuf.h>
38
39#include <libchip/ata_internal.h>
40#include <libchip/ide_ctrl_io.h>
41#include <libchip/ide_ctrl_cfg.h>
42
44
45#ifdef __cplusplus
46extern "C" {
47#endif /* __cplusplus */
48
49#define DCTRL_SRST BSP_BBIT8(5)
50#define DCTRL_NIEN BSP_BBIT8(6)
51
52#define DAST_BSY BSP_BBIT8(0)
53#define DAST_DRDY BSP_BBIT8(1)
54#define DAST_DRQ BSP_BBIT8(4)
55#define DAST_ERR BSP_BBIT8(7)
56
57#define DST_BSY BSP_BBIT16(0)
58#define DST_DRDY BSP_BBIT16(1)
59#define DST_DRQ BSP_BBIT16(4)
60#define DST_ERR BSP_BBIT16(7)
61
62#define DDMA_HUT BSP_BBIT8(1)
63#define DDMA_FR BSP_BBIT8(2)
64#define DDMA_FE BSP_BBIT8(3)
65#define DDMA_IE BSP_BBIT8(4)
66#define DDMA_UDMA BSP_BBIT8(5)
67#define DDMA_READ BSP_BBIT8(6)
68#define DDMA_WRITE BSP_BBIT8(7)
69
70#define ATA_SECTOR_SHIFT 9
71
72#define ATA_PER_TRANSFER_SECTOR_COUNT_MAX 256
73
74typedef union {
75 struct {
76 uint8_t alternate_status;
77 uint8_t reserved_0[3];
78 uint16_t data;
79 uint8_t reserved_1[2];
80 uint8_t error;
81 uint8_t reserved_2[3];
82 uint8_t sector_count;
83 uint8_t reserved_3[3];
84 uint8_t sector;
85 uint8_t reserved_4[3];
86 uint8_t cylinder_low;
87 uint8_t reserved_5[3];
88 uint8_t cylinder_high;
89 uint8_t reserved_6[3];
90 uint8_t head;
91 uint8_t reserved_7[3];
92 uint16_t status;
93 uint8_t reserved_8[2];
94 } read;
95
96 struct {
97 uint8_t control;
98 uint8_t reserved_0[3];
99 uint16_t data;
100 uint8_t reserved_1[2];
101 uint8_t feature;
102 uint8_t reserved_2[3];
103 uint8_t sector_count;
104 uint8_t reserved_3[3];
105 uint8_t sector;
106 uint8_t reserved_4[3];
107 uint8_t cylinder_low;
108 uint8_t reserved_5[3];
109 uint8_t cylinder_high;
110 uint8_t reserved_6[3];
111 uint8_t head;
112 uint8_t reserved_7[3];
113 uint8_t command;
114 uint8_t dma_control;
115 uint8_t reserved_8[2];
116 } write;
118
119#define ATA ((volatile ata_drive_registers *) 0xf0003a5c)
120
121static inline bool ata_is_data_request(void)
122{
123 return (ATA->read.alternate_status & DAST_DRQ) != 0;
124}
125
126static inline bool ata_is_drive_ready_for_selection(void)
127{
128 return (ATA->read.alternate_status & (DAST_BSY | DAST_DRQ)) == 0;
129}
130
131static inline void ata_wait_400_nano_seconds(void)
132{
133 ATA->read.alternate_status;
134}
135
136static inline void ata_wait_for_drive_ready(void)
137{
138 while ((ATA->read.alternate_status & (DAST_BSY | DAST_DRQ | DAST_DRDY)) != DAST_DRDY) {
139 /* Wait */
140 }
141}
142
143static inline void ata_wait_for_not_busy(void)
144{
145 ata_wait_400_nano_seconds();
146
147 while ((ATA->read.alternate_status & DAST_BSY) != 0) {
148 /* Wait */
149 }
150}
151
152static inline bool ata_wait_for_data_request(void)
153{
154 ata_wait_400_nano_seconds();
155
156 uint8_t alternate_status;
157 do {
158 alternate_status = ATA->read.alternate_status;
159 } while ((alternate_status & DAST_BSY) == DAST_BSY);
160
161 return (alternate_status & (DAST_ERR | DAST_DRQ)) == DAST_DRQ;
162}
163
164static inline bool ata_check_status(void)
165{
166 return (ATA->read.status & (DST_BSY | DST_ERR)) == 0;
167}
168
169static inline void ata_clear_interrupts(void)
170{
171 ATA->read.status;
172}
173
174static inline uint8_t ata_read_or_write_sectors_command(bool read)
175{
176 return read ? 0x20 : 0x30;
177}
178
179static inline rtems_blkdev_bnum ata_max_transfer_count(rtems_blkdev_bnum sector_count)
180{
181 return sector_count > ATA_PER_TRANSFER_SECTOR_COUNT_MAX ?
182 ATA_PER_TRANSFER_SECTOR_COUNT_MAX
183 : sector_count;
184}
185
186static inline void ata_flush_sector(uint16_t *begin)
187{
188 /* XXX: The dcbi operation does not work properly */
189 rtems_cache_flush_multiple_data_lines(begin, ATA_SECTOR_SIZE);
190}
191
192void ata_reset_device(void);
193
194bool ata_set_transfer_mode(uint8_t mode);
195
196bool ata_execute_io_command(uint8_t command, uint32_t lba, uint32_t sector_count);
197
198static inline bool ata_execute_io_command_with_sg(uint8_t command, const rtems_blkdev_sg_buffer *sg)
199{
200 uint32_t lba = sg->block;
201 uint32_t sector_count = sg->length / ATA_SECTOR_SIZE;
202 return ata_execute_io_command(command, lba, sector_count);
203}
204
205typedef struct {
206 const rtems_blkdev_sg_buffer *sg;
207
208 size_t sg_count;
209
210 rtems_blkdev_bnum sg_buffer_offset_mask;
211
212 int sg_index_shift;
214
215static inline void ata_sg_reset(ata_sg_context *self, const rtems_blkdev_sg_buffer *sg, size_t sg_count)
216{
217 self->sg = sg;
218 self->sg_count = sg_count;
219 uint32_t sectors_per_buffer = self->sg[0].length >> ATA_SECTOR_SHIFT;
220 self->sg_buffer_offset_mask = sectors_per_buffer - 1;
221 self->sg_index_shift = __builtin_ffs((int) sectors_per_buffer) - 1;
222}
223
224static inline void ata_sg_create_default(ata_sg_context *self)
225{
226 ata_sg_reset(self, NULL, 0);
227}
228
229static inline void ata_sg_create(ata_sg_context *self, const rtems_blkdev_sg_buffer *sg, size_t sg_count)
230{
231 ata_sg_reset(self, sg, sg_count);
232}
233
234static inline rtems_blkdev_bnum ata_sg_get_start_sector(const ata_sg_context *self)
235{
236 return self->sg[0].block;
237}
238
239static inline rtems_blkdev_bnum ata_sg_get_sector_count(const ata_sg_context *self)
240{
241 return (self->sg_buffer_offset_mask + 1) * self->sg_count;
242}
243
244static inline uint16_t *ata_sg_get_sector_data_begin(const ata_sg_context *self, rtems_blkdev_bnum relative_sector)
245{
246 uint16_t *begin = (uint16_t *)(self->sg[relative_sector >> self->sg_index_shift].buffer);
247
248 return begin + ((relative_sector & self->sg_buffer_offset_mask) << (ATA_SECTOR_SHIFT - 1));
249}
250
251static inline uint16_t *ata_sg_get_sector_data_end(const ata_sg_context *self, uint16_t *begin)
252{
253 return begin + ATA_SECTOR_SIZE / 2;
254}
255
256typedef struct {
257 rtems_id lock;
258
259 bool card_present;
260} ata_driver;
261
262void ata_driver_create(ata_driver *self, const char *device_file_path, rtems_block_device_ioctl io_control);
263
264void ata_driver_destroy(ata_driver *self);
265
266static inline void ata_driver_lock(const ata_driver *self)
267{
269 assert(sc == RTEMS_SUCCESSFUL);
270 (void) sc;
271}
272
273static inline void ata_driver_unlock(const ata_driver *self)
274{
276 assert(sc == RTEMS_SUCCESSFUL);
277 (void) sc;
278}
279
280static inline bool ata_driver_is_card_present(const ata_driver *self)
281{
282 return self->card_present;
283}
284
285static inline void ata_driver_io_request(
286 ata_driver *self,
287 rtems_blkdev_request *request,
288 bool (*transfer)(ata_driver *, bool, rtems_blkdev_sg_buffer *, size_t)
289)
290{
291 assert(request->req == RTEMS_BLKDEV_REQ_READ || request->req == RTEMS_BLKDEV_REQ_WRITE);
292 bool read = request->req != RTEMS_BLKDEV_REQ_WRITE;
293 rtems_blkdev_sg_buffer *sg = &request->bufs[0];
294 uint32_t sg_count = request->bufnum;
295 ata_driver_lock(self);
296 bool ok = (*transfer)(self, read, sg, sg_count);
297 ata_driver_unlock(self);
299 rtems_blkdev_request_done(request, sc);
300}
301
302static inline int ata_driver_io_control(
304 uint32_t cmd,
305 void *arg,
306 bool (*transfer)(ata_driver *, bool, rtems_blkdev_sg_buffer *, size_t)
307)
308{
309 ata_driver *self = (ata_driver *) rtems_disk_get_driver_data(dd);
310
311 switch (cmd) {
312 case RTEMS_BLKIO_REQUEST:
313 ata_driver_io_request(self, (rtems_blkdev_request *) arg, transfer);
314 return 0;
315 case RTEMS_BLKIO_CAPABILITIES:
316 *(uint32_t *) arg = RTEMS_BLKDEV_CAP_MULTISECTOR_CONT;
317 return 0;
318 default:
319 return rtems_blkdev_ioctl(dd, cmd, arg);
320 }
321}
322
323int ata_driver_io_control_pio_polled(
325 uint32_t cmd,
326 void *arg
327);
328
329typedef struct {
330 ata_driver super;
331
332 bestcomm_task task;
333
334 bool read;
335
336 ata_sg_context sg_context;
337
338 rtems_blkdev_bnum transfer_current;
339
340 rtems_blkdev_bnum transfer_end;
342
343void ata_driver_dma_pio_single_create(
345 const char *device_file_path,
346 TaskId task_index
347);
348
349#ifdef __cplusplus
350}
351#endif /* __cplusplus */
352
353#endif /* GEN5200_ATA_H */
This header file provides the interfaces of the Assert Handler.
Block Device Buffer Management.
Block Device Disk Management API.
void rtems_cache_flush_multiple_data_lines(const void *d_addr, size_t n_bytes)
Flushes the data cache lines covering the memory area.
Definition: cacheimpl.h:146
#define RTEMS_WAIT
This option constant indicates that the task wants to wait on the resource.
Definition: options.h:139
rtems_status_code rtems_semaphore_release(rtems_id id)
Releases the semaphore.
Definition: semrelease.c:45
rtems_status_code rtems_semaphore_obtain(rtems_id id, rtems_option option_set, rtems_interval timeout)
Obtains the semaphore.
Definition: semobtain.c:72
rtems_status_code
Definition: status.h:85
@ RTEMS_SUCCESSFUL
This status code indicates successful completion of a requested operation.
Definition: status.h:90
@ RTEMS_IO_ERROR
This status code indicates a device driver IO error.
Definition: status.h:241
#define RTEMS_NO_TIMEOUT
This clock tick interval constant indicates that the calling task is willing to wait potentially fore...
Definition: types.h:236
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
#define RTEMS_BLKDEV_CAP_MULTISECTOR_CONT
Only consecutive multi-sector buffer requests are supported.
Definition: blkdev.h:264
int rtems_blkdev_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
Common IO control primitive.
Definition: blkdev-ioctl.c:24
@ RTEMS_BLKDEV_REQ_READ
Definition: blkdev.h:50
@ RTEMS_BLKDEV_REQ_WRITE
Definition: blkdev.h:51
uint32_t rtems_blkdev_bnum
Block device block index type.
Definition: diskdevs.h:45
int(* rtems_block_device_ioctl)(rtems_disk_device *dd, uint32_t req, void *argp)
Block device IO control handler type.
Definition: diskdevs.h:50
ssize_t read(int fd, void *buffer, size_t count)
Definition: read.c:46
ssize_t write(int fd, const void *buffer, size_t count)
Definition: write.c:49
General purpose assembler macros, linker command file support and some inline functions for direct re...
Definition: ata.h:329
Definition: ata.h:256
Definition: ata.h:205
Definition: bestcomm.h:140
Definition: intercom.c:87
The block device transfer request is used to read or write a number of blocks from or to the device.
Definition: blkdev.h:102
rtems_blkdev_request_op req
Definition: blkdev.h:106
rtems_blkdev_sg_buffer bufs[RTEMS_ZERO_LENGTH_ARRAY]
Definition: blkdev.h:145
uint32_t bufnum
Definition: blkdev.h:126
Block device scatter or gather buffer structure.
Definition: blkdev.h:68
rtems_blkdev_bnum block
Definition: blkdev.h:72
void * buffer
Definition: blkdev.h:82
uint32_t length
Definition: blkdev.h:77
Description of a disk device (logical and physical disks).
Definition: diskdevs.h:177
Definition: ata.h:74
