RTEMS 6.1
Block Device Disk Management API. More...
#include <rtems/libio.h>
#include <rtems/chain.h>
struct  rtems_blkdev_read_ahead
 Block device read-ahead control. More...
struct  rtems_blkdev_stats
 Block device statistics. More...
struct  rtems_disk_device
 Description of a disk device (logical and physical disks). More...
#define RTEMS_DISK_READ_AHEAD_NO_TRIGGER   ((rtems_blkdev_bnum) -1)
 Trigger value to disable further read-ahead requests.
#define RTEMS_DISK_READ_AHEAD_SIZE_AUTO   (0)
 Size value to set number of blocks based on config and disk size.
typedef struct rtems_disk_device rtems_disk_device
typedef uint32_t rtems_blkdev_bnum
 Block device block index type.
typedef int(* rtems_block_device_ioctl) (rtems_disk_device *dd, uint32_t req, void *argp)
 Block device IO control handler type.
RTEMS_DEPRECATED rtems_disk_devicertems_disk_next (dev_t dev)
rtems_status_code rtems_disk_init_phys (rtems_disk_device *dd, uint32_t block_size, rtems_blkdev_bnum block_count, rtems_block_device_ioctl handler, void *driver_data)
rtems_status_code rtems_disk_init_log (rtems_disk_device *dd, rtems_disk_device *phys_dd, rtems_blkdev_bnum block_begin, rtems_blkdev_bnum block_count)
Disk Device Data
Disk Device Maintainance
RTEMS_DEPRECATED rtems_status_code rtems_disk_create_phys (dev_t dev, uint32_t block_size, rtems_blkdev_bnum block_count, rtems_block_device_ioctl handler, void *driver_data, const char *name)
RTEMS_DEPRECATED rtems_status_code rtems_disk_create_log (dev_t dev, dev_t phys, rtems_blkdev_bnum block_begin, rtems_blkdev_bnum block_count, const char *name)
RTEMS_DEPRECATED rtems_status_code rtems_disk_delete (dev_t dev)
RTEMS_DEPRECATED rtems_disk_devicertems_disk_obtain (dev_t dev)
RTEMS_DEPRECATED rtems_status_code rtems_disk_release (rtems_disk_device *dd)
Disk Management
RTEMS_DEPRECATED rtems_status_code rtems_disk_io_initialize (void)
RTEMS_DEPRECATED rtems_status_code rtems_disk_io_done (void)
