RTEMS 6.1
rtems_blkdev_read_ahead Struct Reference
Block device read-ahead control. More...
#include <diskdevs.h>
rtems_chain_node node
 Chain node for the read-ahead request queue of the read-ahead task.
rtems_blkdev_bnum trigger
 Block value to trigger the read-ahead request.
rtems_blkdev_bnum next
 Start block for the next read-ahead request.
uint32_t nr_blocks
 Size of the next read-ahead request in blocks.
Field Documentation
◆ next
rtems_blkdev_bnum rtems_blkdev_read_ahead::next
In case the trigger value is out of range of valid blocks, this value my be arbitrary.
◆ nr_blocks
uint32_t rtems_blkdev_read_ahead::nr_blocks
A value of RTEMS_DISK_READ_AHEAD_SIZE_AUTO will try to read the rest of the disk but at most the configured max_read_ahead_blocks.
◆ trigger
rtems_blkdev_bnum rtems_blkdev_read_ahead::trigger
A value of RTEMS_DISK_READ_AHEAD_NO_TRIGGER will disable further read-ahead requests (except the ones triggered by rtems_bdbuf_peek) since no valid block can have this value.
