| int | rtems_blkdev_ioctl (rtems_disk_device *dd, uint32_t req, void *argp) |
| | Common IO control primitive.
| rtems_status_code | rtems_blkdev_create (const char *device, uint32_t media_block_size, rtems_blkdev_bnum media_block_count, rtems_block_device_ioctl handler, void *driver_data) |
| | Creates a block device.
| rtems_status_code | rtems_blkdev_create_partition (const char *partition, const char *parent_block_device, rtems_blkdev_bnum media_block_begin, rtems_blkdev_bnum media_block_count) |
| | Creates a partition within a parent block device.
void | rtems_blkdev_print_stats (const rtems_blkdev_stats *stats, uint32_t media_block_size, uint32_t media_block_count, uint32_t block_size, const rtems_printer *printer) |
| | Prints the block device statistics.
void | rtems_blkstats (const rtems_printer *printer, const char *device, bool reset) |
| | Block device statistics command.
#define | RTEMS_BLKIO_REQUEST _IOWR('B', 1, rtems_blkdev_request) |
#define | RTEMS_BLKIO_GETMEDIABLKSIZE _IOR('B', 2, uint32_t) |
#define | RTEMS_BLKIO_GETBLKSIZE _IOR('B', 3, uint32_t) |
#define | RTEMS_BLKIO_SETBLKSIZE _IOW('B', 4, uint32_t) |
#define | RTEMS_BLKIO_GETSIZE _IOR('B', 5, rtems_blkdev_bnum) |
#define | RTEMS_BLKIO_SYNCDEV _IO('B', 6) |
#define | RTEMS_BLKIO_DELETED _IO('B', 7) |
#define | RTEMS_BLKIO_CAPABILITIES _IO('B', 8) |
#define | RTEMS_BLKIO_GETDISKDEV _IOR('B', 9, rtems_disk_device *) |
#define | RTEMS_BLKIO_PURGEDEV _IO('B', 10) |
#define | RTEMS_BLKIO_GETDEVSTATS _IOR('B', 11, rtems_blkdev_stats *) |
#define | RTEMS_BLKIO_RESETDEVSTATS _IO('B', 12) |
Interface between device drivers and the block device buffer module.
The heart of the block device driver is the RTEMS_BLKIO_REQUEST IO control. This call puts IO requests to the block device for asynchronous processing. When a driver executes a request, it invokes the request done callback function to finish the request.
◆ RTEMS_BLKDEV_CAP_MULTISECTOR_CONT
| #define RTEMS_BLKDEV_CAP_MULTISECTOR_CONT (1 << 0) |
Only consecutive multi-sector buffer requests are supported.
This option means the cache will only supply multiple buffers that are inorder so the ATA multi-sector command for example can be used. This is a hack to work around the current ATA driver.
◆ RTEMS_BLKDEV_CAP_SYNC
| #define RTEMS_BLKDEV_CAP_SYNC (1 << 1) |
The driver will accept a sync call.
A sync call is made to a driver after a bdbuf cache sync has finished.
◆ RTEMS_BLKDEV_START_BLOCK
| #define RTEMS_BLKDEV_START_BLOCK |
req | ) |
(req->bufs[0].block) |
◆ rtems_blkdev_request
The block device transfer request is used to read or write a number of blocks from or to the device.
Transfer requests are issued to the disk device driver with the RTEMS_BLKIO_REQUEST IO control. The transfer request completion status must be signalled with rtems_blkdev_request_done(). This function must be called exactly once per request. The return value of the IO control will be ignored for transfer requests.
- See also
- rtems_blkdev_create().
◆ rtems_blkdev_request_op
Block device request type.
- Warning
- The sync request is an IO one and only used from the cache. Use the Block IO when operating at the device level. We need a sync request to avoid requests looping for ever.
- Warning
| Enumerator |
| RTEMS_BLKDEV_REQ_READ | Read the requested blocks of data.
| RTEMS_BLKDEV_REQ_WRITE | Write the requested blocks of data.
| RTEMS_BLKDEV_REQ_SYNC | Sync any data with the media.
◆ rtems_blkdev_create()
The block size is set to the media block size.
- Parameters
| [in] | device | The path for the new block device. |
| [in] | media_block_size | The media block size in bytes. Must be positive. |
| [in] | media_block_count | The media block count. Must be positive. |
| [in] | handler | The block device IO control handler. Must not be NULL. |
| [in] | driver_data | The block device driver data. |
- Return values
| RTEMS_SUCCESSFUL | Successful operation. |
| RTEMS_INVALID_NUMBER | Media block size or count is not positive. |
| RTEMS_NO_MEMORY | Not enough memory. |
| RTEMS_UNSATISFIED | Cannot create generic device node. |
| RTEMS_INCORRECT_STATE | Cannot initialize bdbuf. |
- See also
- rtems_blkdev_create_partition(), rtems_bdbuf_set_block_size(), and rtems_blkdev_request.
◆ rtems_blkdev_create_partition()
A partition manages a subset of consecutive blocks contained in a parent block device. The blocks must be within the range of blocks managed by the associated parent block device. The media block size and IO control handler are inherited by the parent block device. The block size is set to the media block size.
- Parameters
| [in] | partition | The path for the new partition device. |
| [in] | parent_block_device | The parent block device path. |
| [in] | media_block_begin | The media block begin of the partition within the parent block device. |
| [in] | media_block_count | The media block count of the partition. |
- Return values
| RTEMS_INVALID_ID | Block device node does not exist. |
| RTEMS_INVALID_NODE | File system node is not a block device. |
| RTEMS_NOT_IMPLEMENTED | Block device implementation is incomplete. |
| RTEMS_INVALID_NUMBER | Block begin or block count is invalid. |
- See also
- rtems_blkdev_create() and rtems_bdbuf_set_block_size().
◆ rtems_blkdev_ioctl()
Use this in all block devices to handle the common set of IO control requests.
