RTEMS 6.1
assert.h File Reference
This header file provides the interfaces of the Assert Handler. More...
#define _Assert(_e)   ( ( void ) 0 )
 Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG and static analysis runs.
#define _Assert_Unused_variable_equals(_var, _val)
 Assert if unused return value is equal.
#define _Assert_Unused_variable_unequal(_var, _val)
 Assert if unused return value is not equal.
