RTEMS 6.1
Files | Macros
Assert Handler
This group contains the Assert Handler implementation. More...
file  assert.h
 This header file provides the interfaces of the Assert Handler.
#define _Assert(_e)   ( ( void ) 0 )
 Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG and static analysis runs.
#define _Assert_Unused_variable_equals(_var, _val)
 Assert if unused return value is equal.
#define _Assert_Unused_variable_unequal(_var, _val)
 Assert if unused return value is not equal.
◆ _Assert_Unused_variable_equals
#define _Assert_Unused_variable_equals (   _var,
  _val
Value:
do { \
_Assert((_var) == (_val)); \
(void) (_var); \
} while (0)
Assert whether _var and _val are equal and ensure _var is marked as used when not building for debug.
Parameters
_varThe return value to be checked.
_valIndicates what _var is supposed to be.
◆ _Assert_Unused_variable_unequal
#define _Assert_Unused_variable_unequal (   _var,
  _val
Value:
do { \
_Assert((_var) != (_val)); \
(void) (_var); \
} while (0)
Assert whether _var and _val are not equal and ensure _var is marked as used when not building for debug.
Parameters
_valIndicates what _var is not supposed to be.
