RTEMS 6.1
PDM SDMA Driver
struct  _pdm_sdma_handle
 PDM DMA transfer handle, users should not touch the content of the handle. More...
Driver version
typedef struct _pdm_sdma_handle pdm_sdma_handle_t
typedef void(* pdm_sdma_callback_t) (PDM_Type *base, pdm_sdma_handle_t *handle, status_t status, void *userData)
 PDM eDMA transfer callback function for finish and error.
#define FSL_PDM_SDMA_DRIVER_VERSION   (MAKE_VERSION(2, 7, 0))
eDMA Transactional
void PDM_TransferCreateHandleSDMA (PDM_Type *base, pdm_sdma_handle_t *handle, pdm_sdma_callback_t callback, void *userData, sdma_handle_t *dmaHandle, uint32_t eventSource)
 Initializes the PDM eDMA handle.
status_t PDM_TransferReceiveSDMA (PDM_Type *base, pdm_sdma_handle_t *handle, pdm_transfer_t *xfer)
 Performs a non-blocking PDM receive using eDMA.
void PDM_TransferAbortReceiveSDMA (PDM_Type *base, pdm_sdma_handle_t *handle)
 Aborts a PDM receive using eDMA.
void PDM_SetChannelConfigSDMA (PDM_Type *base, pdm_sdma_handle_t *handle, uint32_t channel, const pdm_channel_config_t *config)
 PDM channel configurations.
void PDM_TransferTerminateReceiveSDMA (PDM_Type *base, pdm_sdma_handle_t *handle)
 Terminate all the PDM sdma receive transfer.
◆ FSL_PDM_SDMA_DRIVER_VERSION
Version 2.7.0
◆ PDM_SetChannelConfigSDMA()
void PDM_SetChannelConfigSDMA ( PDM_Type base,
pdm_sdma_handle_t handle,
uint32_t  channel,
const pdm_channel_config_t config
Parameters
basePDM base pointer.
handlePDM eDMA handle pointer.
channelchannel number.
configchannel configurations.
◆ PDM_TransferAbortReceiveSDMA()
void PDM_TransferAbortReceiveSDMA ( PDM_Type base,
Parameters
◆ PDM_TransferCreateHandleSDMA()
void PDM_TransferCreateHandleSDMA ( PDM_Type base,
void *  userData,
sdma_handle_t *  dmaHandle,
This function initializes the PDM DMA handle, which can be used for other PDM master transactional APIs. Usually, for a specified PDM instance, call this API once to get the initialized handle.
Parameters
callbackPointer to user callback function.
userDataUser parameter passed to the callback function.
dmaHandleeDMA handle pointer, this handle shall be static allocated by users.
eventSourcePDM event source number.
◆ PDM_TransferReceiveSDMA()
status_t PDM_TransferReceiveSDMA ( PDM_Type base,
pdm_transfer_t xfer
Note
This interface returns immediately after the transfer initiates. Call the PDM_GetReceiveRemainingBytes to poll the transfer status and check whether the PDM transfer is finished.
Parameters
xferPointer to DMA transfer structure.
Return values
kStatus_SuccessStart a PDM eDMA receive successfully.
kStatus_InvalidArgumentThe input argument is invalid.
kStatus_RxBusyPDM is busy receiving data.
◆ PDM_TransferTerminateReceiveSDMA()
void PDM_TransferTerminateReceiveSDMA ( PDM_Type base,
Parameters
handlePDM SDMA handle pointer.
