RTEMS 6.1
#include <MIMXRT1166_cm4.h>
__IO uint32_t CTRL_1
__IO uint32_t CTRL_2
__IO uint32_t STAT
uint8_t RESERVED_0 [4]
__IO uint32_t FIFO_CTRL
__IO uint32_t FIFO_STAT
uint8_t RESERVED_1 [12]
__I uint32_t DATACH [8]
uint8_t RESERVED_2 [32]
__IO uint32_t DC_CTRL
uint8_t RESERVED_3 [12]
__IO uint32_t RANGE_CTRL
uint8_t RESERVED_4 [4]
__IO uint32_t RANGE_STAT
uint8_t RESERVED_5 [16]
__IO uint32_t VAD0_CTRL_1
__IO uint32_t VAD0_CTRL_2
__IO uint32_t VAD0_STAT
__IO uint32_t VAD0_SCONFIG
__IO uint32_t VAD0_NCONFIG
__I uint32_t VAD0_NDATA
__IO uint32_t VAD0_ZCD
PDM - Register Layout Typedef
The documentation for this struct was generated from the following files:
