RTEMS 6.1
Modules | Typedefs | Enumerations | Enumerator | Variables
 Device Peripheral Access Layer
 Edma_request
 Macros for use with bit field definitions (xxx_SHIFT, xxx_MASK).
 SDK Compatibility
typedef enum _iomuxc_sw_mux_ctl_pad iomuxc_sw_mux_ctl_pad_t
 Enumeration for the IOMUXC SW_MUX_CTL_PAD.
typedef enum _iomuxc_sw_pad_ctl_pad iomuxc_sw_pad_ctl_pad_t
 Enumeration for the IOMUXC SW_PAD_CTL_PAD.
typedef enum _iomuxc_select_input iomuxc_select_input_t
 Enumeration for the IOMUXC select input.
typedef enum _xbar_input_signal xbar_input_signal_t
typedef enum _xbar_output_signal xbar_output_signal_t
enum  _iomuxc_sw_mux_ctl_pad {
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_00 = 0U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_01 = 1U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_02 = 2U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_03 = 3U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_04 = 4U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_05 = 5U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_06 = 6U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_07 = 7U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_08 = 8U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_09 = 9U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_10 = 10U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_11 = 11U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_12 = 12U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_13 = 13U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_14 = 14U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_15 = 15U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_16 = 16U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_17 = 17U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_18 = 18U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_19 = 19U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_20 = 20U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_21 = 21U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_22 = 22U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_23 = 23U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_24 = 24U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_25 = 25U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_26 = 26U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_27 = 27U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_28 = 28U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_29 = 29U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_30 = 30U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_31 = 31U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_32 = 32U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_33 = 33U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_34 = 34U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_35 = 35U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_36 = 36U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_37 = 37U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_38 = 38U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_39 = 39U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_40 = 40U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_41 = 41U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_00 = 42U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_01 = 43U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_02 = 44U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_03 = 45U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_04 = 46U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_05 = 47U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_06 = 48U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_07 = 49U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_08 = 50U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_09 = 51U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_10 = 52U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_11 = 53U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_12 = 54U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_13 = 55U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_14 = 56U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_15 = 57U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_00 = 58U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_01 = 59U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_02 = 60U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_03 = 61U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_04 = 62U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_05 = 63U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_06 = 64U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_07 = 65U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_08 = 66U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_09 = 67U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_10 = 68U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_11 = 69U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_12 = 70U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_13 = 71U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_14 = 72U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_15 = 73U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_00 = 74U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_01 = 75U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_02 = 76U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_03 = 77U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_04 = 78U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_05 = 79U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_06 = 80U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_07 = 81U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_08 = 82U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_09 = 83U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_10 = 84U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_11 = 85U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_12 = 86U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_13 = 87U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_14 = 88U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_15 = 89U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_00 = 90U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_01 = 91U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_02 = 92U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_03 = 93U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_04 = 94U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_05 = 95U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_06 = 96U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_07 = 97U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_08 = 98U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_09 = 99U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_10 = 100U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_11 = 101U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_12 = 102U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_13 = 103U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_14 = 104U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_15 = 105U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_00 = 106U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_01 = 107U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_02 = 108U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_03 = 109U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_04 = 110U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_05 = 111U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_00 = 112U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_01 = 113U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_02 = 114U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_03 = 115U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_04 = 116U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_05 = 117U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_06 = 118U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_07 = 119U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_08 = 120U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_09 = 121U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_10 = 122U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_11 = 123U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_00 = 0U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_01 = 1U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_02 = 2U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_03 = 3U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_04 = 4U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_05 = 5U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_06 = 6U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_07 = 7U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_08 = 8U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_09 = 9U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_10 = 10U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_11 = 11U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_12 = 12U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_13 = 13U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_14 = 14U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_15 = 15U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_16 = 16U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_17 = 17U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_18 = 18U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_19 = 19U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_20 = 20U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_21 = 21U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_22 = 22U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_23 = 23U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_24 = 24U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_25 = 25U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_26 = 26U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_27 = 27U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_28 = 28U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_29 = 29U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_30 = 30U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_31 = 31U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_32 = 32U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_33 = 33U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_34 = 34U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_35 = 35U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_36 = 36U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_37 = 37U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_38 = 38U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_39 = 39U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_40 = 40U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_41 = 41U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_00 = 42U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_01 = 43U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_02 = 44U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_03 = 45U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_04 = 46U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_05 = 47U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_06 = 48U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_07 = 49U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_08 = 50U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_09 = 51U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_10 = 52U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_11 = 53U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_12 = 54U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_13 = 55U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_14 = 56U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_15 = 57U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_16 = 58U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_17 = 59U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_18 = 60U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_19 = 61U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_20 = 62U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_00 = 63U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_01 = 64U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_02 = 65U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_03 = 66U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_04 = 67U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_05 = 68U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_06 = 69U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_07 = 70U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_08 = 71U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_09 = 72U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_10 = 73U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_11 = 74U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_12 = 75U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_13 = 76U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_14 = 77U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_15 = 78U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_16 = 79U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_17 = 80U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_18 = 81U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_19 = 82U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_20 = 83U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_21 = 84U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_22 = 85U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_23 = 86U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_24 = 87U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_25 = 88U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_26 = 89U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_27 = 90U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_28 = 91U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_29 = 92U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_30 = 93U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_31 = 94U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_32 = 95U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_33 = 96U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_34 = 97U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_35 = 98U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_00 = 99U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_01 = 100U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_02 = 101U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_03 = 102U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_04 = 103U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_05 = 104U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_00 = 105U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_01 = 106U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_02 = 107U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_03 = 108U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_04 = 109U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_05 = 110U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_06 = 111U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_07 = 112U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_08 = 113U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_09 = 114U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_10 = 115U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_11 = 116U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_00 = 117U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_01 = 118U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_02 = 119U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_03 = 120U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_04 = 121U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_05 = 122U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_06 = 123U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_07 = 124U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_08 = 125U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_09 = 126U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_10 = 127U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_11 = 128U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_00 = 129U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_01 = 130U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_02 = 131U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_03 = 132U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_04 = 133U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_05 = 134U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_06 = 135U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_07 = 136U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_08 = 137U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_09 = 138U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_10 = 139U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_11 = 140U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_12 = 141U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_13 = 142U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_14 = 143U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_15 = 144U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_00 = 0U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_01 = 1U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_02 = 2U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_03 = 3U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_04 = 4U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_05 = 5U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_06 = 6U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_07 = 7U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_08 = 8U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_09 = 9U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_10 = 10U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_11 = 11U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_12 = 12U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_13 = 13U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_14 = 14U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_15 = 15U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_16 = 16U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_17 = 17U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_18 = 18U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_19 = 19U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_20 = 20U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_21 = 21U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_22 = 22U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_23 = 23U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_24 = 24U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_25 = 25U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_26 = 26U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_27 = 27U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_28 = 28U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_29 = 29U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_30 = 30U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_31 = 31U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_32 = 32U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_33 = 33U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_34 = 34U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_35 = 35U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_36 = 36U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_37 = 37U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_38 = 38U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_39 = 39U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_40 = 40U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_41 = 41U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_00 = 42U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_01 = 43U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_02 = 44U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_03 = 45U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_04 = 46U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_05 = 47U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_06 = 48U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_07 = 49U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_08 = 50U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_09 = 51U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_10 = 52U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_11 = 53U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_12 = 54U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_13 = 55U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_14 = 56U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_15 = 57U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_16 = 58U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_17 = 59U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_18 = 60U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_19 = 61U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_20 = 62U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_00 = 63U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_01 = 64U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_02 = 65U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_03 = 66U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_04 = 67U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_05 = 68U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_06 = 69U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_07 = 70U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_08 = 71U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_09 = 72U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_10 = 73U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_11 = 74U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_12 = 75U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_13 = 76U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_14 = 77U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_15 = 78U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_16 = 79U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_17 = 80U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_18 = 81U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_19 = 82U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_20 = 83U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_21 = 84U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_22 = 85U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_23 = 86U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_24 = 87U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_25 = 88U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_26 = 89U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_27 = 90U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_28 = 91U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_29 = 92U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_30 = 93U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_31 = 94U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_32 = 95U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_33 = 96U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_34 = 97U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_35 = 98U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_00 = 99U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_01 = 100U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_02 = 101U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_03 = 102U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_04 = 103U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_05 = 104U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_00 = 105U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_01 = 106U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_02 = 107U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_03 = 108U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_04 = 109U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_05 = 110U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_06 = 111U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_07 = 112U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_08 = 113U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_09 = 114U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_10 = 115U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_11 = 116U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_00 = 117U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_01 = 118U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_02 = 119U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_03 = 120U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_04 = 121U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_05 = 122U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_06 = 123U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_07 = 124U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_08 = 125U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_09 = 126U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_10 = 127U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_11 = 128U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_00 = 129U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_01 = 130U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_02 = 131U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_03 = 132U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_04 = 133U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_05 = 134U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_06 = 135U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_07 = 136U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_08 = 137U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_09 = 138U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_10 = 139U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_11 = 140U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_12 = 141U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_13 = 142U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_14 = 143U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_15 = 144U
 Enumeration for the IOMUXC SW_MUX_CTL_PAD. More...
enum  _iomuxc_sw_pad_ctl_pad {
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_00 = 0U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_01 = 1U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_02 = 2U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_03 = 3U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_04 = 4U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_05 = 5U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_06 = 6U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_07 = 7U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_08 = 8U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_09 = 9U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_10 = 10U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_11 = 11U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_12 = 12U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_13 = 13U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_14 = 14U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_15 = 15U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_16 = 16U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_17 = 17U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_18 = 18U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_19 = 19U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_20 = 20U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_21 = 21U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_22 = 22U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_23 = 23U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_24 = 24U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_25 = 25U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_26 = 26U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_27 = 27U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_28 = 28U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_29 = 29U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_30 = 30U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_31 = 31U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_32 = 32U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_33 = 33U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_34 = 34U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_35 = 35U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_36 = 36U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_37 = 37U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_38 = 38U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_39 = 39U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_40 = 40U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_41 = 41U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_00 = 42U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_01 = 43U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_02 = 44U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_03 = 45U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_04 = 46U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_05 = 47U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_06 = 48U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_07 = 49U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_08 = 50U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_09 = 51U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_10 = 52U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_11 = 53U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_12 = 54U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_13 = 55U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_14 = 56U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_15 = 57U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_00 = 58U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_01 = 59U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_02 = 60U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_03 = 61U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_04 = 62U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_05 = 63U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_06 = 64U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_07 = 65U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_08 = 66U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_09 = 67U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_10 = 68U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_11 = 69U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_12 = 70U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_13 = 71U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_14 = 72U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_15 = 73U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_00 = 74U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_01 = 75U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_02 = 76U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_03 = 77U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_04 = 78U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_05 = 79U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_06 = 80U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_07 = 81U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_08 = 82U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_09 = 83U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_10 = 84U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_11 = 85U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_12 = 86U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_13 = 87U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_14 = 88U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_15 = 89U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_00 = 90U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_01 = 91U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_02 = 92U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_03 = 93U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_04 = 94U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_05 = 95U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_06 = 96U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_07 = 97U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_08 = 98U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_09 = 99U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_10 = 100U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_11 = 101U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_12 = 102U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_13 = 103U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_14 = 104U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_15 = 105U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_00 = 106U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_01 = 107U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_02 = 108U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_03 = 109U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_04 = 110U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_05 = 111U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_00 = 112U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_01 = 113U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_02 = 114U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_03 = 115U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_04 = 116U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_05 = 117U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_06 = 118U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_07 = 119U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_08 = 120U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_09 = 121U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_10 = 122U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_11 = 123U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_00 = 0U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_01 = 1U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_02 = 2U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_03 = 3U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_04 = 4U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_05 = 5U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_06 = 6U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_07 = 7U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_08 = 8U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_09 = 9U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_10 = 10U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_11 = 11U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_12 = 12U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_13 = 13U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_14 = 14U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_15 = 15U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_16 = 16U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_17 = 17U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_18 = 18U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_19 = 19U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_20 = 20U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_21 = 21U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_22 = 22U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_23 = 23U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_24 = 24U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_25 = 25U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_26 = 26U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_27 = 27U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_28 = 28U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_29 = 29U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_30 = 30U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_31 = 31U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_32 = 32U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_33 = 33U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_34 = 34U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_35 = 35U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_36 = 36U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_37 = 37U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_38 = 38U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_39 = 39U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_40 = 40U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_41 = 41U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_00 = 42U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_01 = 43U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_02 = 44U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_03 = 45U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_04 = 46U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_05 = 47U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_06 = 48U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_07 = 49U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_08 = 50U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_09 = 51U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_10 = 52U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_11 = 53U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_12 = 54U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_13 = 55U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_14 = 56U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_15 = 57U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_16 = 58U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_17 = 59U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_18 = 60U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_19 = 61U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_20 = 62U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_00 = 63U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_01 = 64U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_02 = 65U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_03 = 66U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_04 = 67U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_05 = 68U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_06 = 69U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_07 = 70U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_08 = 71U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_09 = 72U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_10 = 73U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_11 = 74U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_12 = 75U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_13 = 76U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_14 = 77U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_15 = 78U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_16 = 79U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_17 = 80U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_18 = 81U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_19 = 82U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_20 = 83U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_21 = 84U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_22 = 85U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_23 = 86U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_24 = 87U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_25 = 88U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_26 = 89U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_27 = 90U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_28 = 91U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_29 = 92U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_30 = 93U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_31 = 94U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_32 = 95U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_33 = 96U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_34 = 97U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_35 = 98U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_00 = 99U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_01 = 100U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_02 = 101U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_03 = 102U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_04 = 103U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_05 = 104U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_00 = 105U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_01 = 106U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_02 = 107U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_03 = 108U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_04 = 109U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_05 = 110U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_06 = 111U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_07 = 112U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_08 = 113U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_09 = 114U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_10 = 115U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_11 = 116U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_00 = 117U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_01 = 118U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_02 = 119U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_03 = 120U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_04 = 121U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_05 = 122U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_06 = 123U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_07 = 124U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_08 = 125U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_09 = 126U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_10 = 127U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_11 = 128U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_00 = 129U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_01 = 130U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_02 = 131U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_03 = 132U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_04 = 133U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_05 = 134U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_06 = 135U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_07 = 136U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_08 = 137U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_09 = 138U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_10 = 139U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_11 = 140U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_12 = 141U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_13 = 142U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_14 = 143U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_15 = 144U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_00 = 0U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_01 = 1U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_02 = 2U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_03 = 3U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_04 = 4U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_05 = 5U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_06 = 6U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_07 = 7U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_08 = 8U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_09 = 9U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_10 = 10U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_11 = 11U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_12 = 12U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_13 = 13U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_14 = 14U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_15 = 15U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_16 = 16U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_17 = 17U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_18 = 18U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_19 = 19U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_20 = 20U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_21 = 21U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_22 = 22U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_23 = 23U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_24 = 24U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_25 = 25U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_26 = 26U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_27 = 27U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_28 = 28U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_29 = 29U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_30 = 30U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_31 = 31U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_32 = 32U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_33 = 33U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_34 = 34U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_35 = 35U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_36 = 36U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_37 = 37U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_38 = 38U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_39 = 39U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_40 = 40U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_41 = 41U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_00 = 42U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_01 = 43U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_02 = 44U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_03 = 45U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_04 = 46U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_05 = 47U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_06 = 48U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_07 = 49U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_08 = 50U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_09 = 51U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_10 = 52U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_11 = 53U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_12 = 54U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_13 = 55U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_14 = 56U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_15 = 57U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_16 = 58U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_17 = 59U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_18 = 60U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_19 = 61U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_20 = 62U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_00 = 63U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_01 = 64U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_02 = 65U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_03 = 66U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_04 = 67U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_05 = 68U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_06 = 69U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_07 = 70U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_08 = 71U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_09 = 72U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_10 = 73U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_11 = 74U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_12 = 75U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_13 = 76U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_14 = 77U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_15 = 78U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_16 = 79U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_17 = 80U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_18 = 81U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_19 = 82U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_20 = 83U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_21 = 84U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_22 = 85U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_23 = 86U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_24 = 87U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_25 = 88U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_26 = 89U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_27 = 90U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_28 = 91U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_29 = 92U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_30 = 93U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_31 = 94U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_32 = 95U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_33 = 96U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_34 = 97U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_35 = 98U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_00 = 99U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_01 = 100U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_02 = 101U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_03 = 102U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_04 = 103U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_05 = 104U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_00 = 105U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_01 = 106U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_02 = 107U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_03 = 108U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_04 = 109U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_05 = 110U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_06 = 111U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_07 = 112U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_08 = 113U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_09 = 114U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_10 = 115U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_11 = 116U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_00 = 117U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_01 = 118U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_02 = 119U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_03 = 120U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_04 = 121U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_05 = 122U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_06 = 123U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_07 = 124U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_08 = 125U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_09 = 126U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_10 = 127U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_11 = 128U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_00 = 129U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_01 = 130U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_02 = 131U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_03 = 132U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_04 = 133U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_05 = 134U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_06 = 135U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_07 = 136U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_08 = 137U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_09 = 138U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_10 = 139U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_11 = 140U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_12 = 141U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_13 = 142U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_14 = 143U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_15 = 144U
 Enumeration for the IOMUXC SW_PAD_CTL_PAD. More...
enum  _iomuxc_select_input {
  kIOMUXC_ANATOP_USB_OTG1_ID_SELECT_INPUT = 0U , kIOMUXC_ANATOP_USB_OTG2_ID_SELECT_INPUT = 1U , kIOMUXC_CCM_PMIC_READY_SELECT_INPUT = 2U , kIOMUXC_CSI_DATA02_SELECT_INPUT = 3U ,
  kIOMUXC_CSI_DATA03_SELECT_INPUT = 4U , kIOMUXC_CSI_DATA04_SELECT_INPUT = 5U , kIOMUXC_CSI_DATA05_SELECT_INPUT = 6U , kIOMUXC_CSI_DATA06_SELECT_INPUT = 7U ,
  kIOMUXC_CSI_DATA07_SELECT_INPUT = 8U , kIOMUXC_CSI_DATA08_SELECT_INPUT = 9U , kIOMUXC_CSI_DATA09_SELECT_INPUT = 10U , kIOMUXC_CSI_HSYNC_SELECT_INPUT = 11U ,
  kIOMUXC_CSI_PIXCLK_SELECT_INPUT = 12U , kIOMUXC_CSI_VSYNC_SELECT_INPUT = 13U , kIOMUXC_ENET_IPG_CLK_RMII_SELECT_INPUT = 14U , kIOMUXC_ENET_MDIO_SELECT_INPUT = 15U ,
  kIOMUXC_ENET0_RXDATA_SELECT_INPUT = 16U , kIOMUXC_ENET1_RXDATA_SELECT_INPUT = 17U , kIOMUXC_ENET_RXEN_SELECT_INPUT = 18U , kIOMUXC_ENET_RXERR_SELECT_INPUT = 19U ,
  kIOMUXC_ENET0_TIMER_SELECT_INPUT = 20U , kIOMUXC_ENET_TXCLK_SELECT_INPUT = 21U , kIOMUXC_FLEXCAN1_RX_SELECT_INPUT = 22U , kIOMUXC_FLEXCAN2_RX_SELECT_INPUT = 23U ,
  kIOMUXC_FLEXPWM1_PWMA3_SELECT_INPUT = 24U , kIOMUXC_FLEXPWM1_PWMA0_SELECT_INPUT = 25U , kIOMUXC_FLEXPWM1_PWMA1_SELECT_INPUT = 26U , kIOMUXC_FLEXPWM1_PWMA2_SELECT_INPUT = 27U ,
  kIOMUXC_FLEXPWM1_PWMB3_SELECT_INPUT = 28U , kIOMUXC_FLEXPWM1_PWMB0_SELECT_INPUT = 29U , kIOMUXC_FLEXPWM1_PWMB1_SELECT_INPUT = 30U , kIOMUXC_FLEXPWM1_PWMB2_SELECT_INPUT = 31U ,
  kIOMUXC_FLEXPWM2_PWMA3_SELECT_INPUT = 32U , kIOMUXC_FLEXPWM2_PWMA0_SELECT_INPUT = 33U , kIOMUXC_FLEXPWM2_PWMA1_SELECT_INPUT = 34U , kIOMUXC_FLEXPWM2_PWMA2_SELECT_INPUT = 35U ,
  kIOMUXC_FLEXPWM2_PWMB3_SELECT_INPUT = 36U , kIOMUXC_FLEXPWM2_PWMB0_SELECT_INPUT = 37U , kIOMUXC_FLEXPWM2_PWMB1_SELECT_INPUT = 38U , kIOMUXC_FLEXPWM2_PWMB2_SELECT_INPUT = 39U ,
  kIOMUXC_FLEXPWM4_PWMA0_SELECT_INPUT = 40U , kIOMUXC_FLEXPWM4_PWMA1_SELECT_INPUT = 41U , kIOMUXC_FLEXPWM4_PWMA2_SELECT_INPUT = 42U , kIOMUXC_FLEXPWM4_PWMA3_SELECT_INPUT = 43U ,
  kIOMUXC_FLEXSPI_A_DQS_SELECT_INPUT = 44U , kIOMUXC_FLEXSPI_A_DATA0_SELECT_INPUT = 45U , kIOMUXC_FLEXSPI_A_DATA1_SELECT_INPUT = 46U , kIOMUXC_FLEXSPI_A_DATA2_SELECT_INPUT = 47U ,
  kIOMUXC_FLEXSPI_A_DATA3_SELECT_INPUT = 48U , kIOMUXC_FLEXSPI_B_DATA0_SELECT_INPUT = 49U , kIOMUXC_FLEXSPI_B_DATA1_SELECT_INPUT = 50U , kIOMUXC_FLEXSPI_B_DATA2_SELECT_INPUT = 51U ,
  kIOMUXC_FLEXSPI_B_DATA3_SELECT_INPUT = 52U , kIOMUXC_FLEXSPI_A_SCK_SELECT_INPUT = 53U , kIOMUXC_LPI2C1_SCL_SELECT_INPUT = 54U , kIOMUXC_LPI2C1_SDA_SELECT_INPUT = 55U ,
  kIOMUXC_LPI2C2_SCL_SELECT_INPUT = 56U , kIOMUXC_LPI2C2_SDA_SELECT_INPUT = 57U , kIOMUXC_LPI2C3_SCL_SELECT_INPUT = 58U , kIOMUXC_LPI2C3_SDA_SELECT_INPUT = 59U ,
  kIOMUXC_LPI2C4_SCL_SELECT_INPUT = 60U , kIOMUXC_LPI2C4_SDA_SELECT_INPUT = 61U , kIOMUXC_LPSPI1_PCS0_SELECT_INPUT = 62U , kIOMUXC_LPSPI1_SCK_SELECT_INPUT = 63U ,
  kIOMUXC_LPSPI1_SDI_SELECT_INPUT = 64U , kIOMUXC_LPSPI1_SDO_SELECT_INPUT = 65U , kIOMUXC_LPSPI2_PCS0_SELECT_INPUT = 66U , kIOMUXC_LPSPI2_SCK_SELECT_INPUT = 67U ,
  kIOMUXC_LPSPI2_SDI_SELECT_INPUT = 68U , kIOMUXC_LPSPI2_SDO_SELECT_INPUT = 69U , kIOMUXC_LPSPI3_PCS0_SELECT_INPUT = 70U , kIOMUXC_LPSPI3_SCK_SELECT_INPUT = 71U ,
  kIOMUXC_LPSPI3_SDI_SELECT_INPUT = 72U , kIOMUXC_LPSPI3_SDO_SELECT_INPUT = 73U , kIOMUXC_LPSPI4_PCS0_SELECT_INPUT = 74U , kIOMUXC_LPSPI4_SCK_SELECT_INPUT = 75U ,
  kIOMUXC_LPSPI4_SDI_SELECT_INPUT = 76U , kIOMUXC_LPSPI4_SDO_SELECT_INPUT = 77U , kIOMUXC_LPUART2_RX_SELECT_INPUT = 78U , kIOMUXC_LPUART2_TX_SELECT_INPUT = 79U ,
  kIOMUXC_LPUART3_CTS_B_SELECT_INPUT = 80U , kIOMUXC_LPUART3_RX_SELECT_INPUT = 81U , kIOMUXC_LPUART3_TX_SELECT_INPUT = 82U , kIOMUXC_LPUART4_RX_SELECT_INPUT = 83U ,
  kIOMUXC_LPUART4_TX_SELECT_INPUT = 84U , kIOMUXC_LPUART5_RX_SELECT_INPUT = 85U , kIOMUXC_LPUART5_TX_SELECT_INPUT = 86U , kIOMUXC_LPUART6_RX_SELECT_INPUT = 87U ,
  kIOMUXC_LPUART6_TX_SELECT_INPUT = 88U , kIOMUXC_LPUART7_RX_SELECT_INPUT = 89U , kIOMUXC_LPUART7_TX_SELECT_INPUT = 90U , kIOMUXC_LPUART8_RX_SELECT_INPUT = 91U ,
  kIOMUXC_LPUART8_TX_SELECT_INPUT = 92U , kIOMUXC_NMI_SELECT_INPUT = 93U , kIOMUXC_QTIMER2_TIMER0_SELECT_INPUT = 94U , kIOMUXC_QTIMER2_TIMER1_SELECT_INPUT = 95U ,
  kIOMUXC_QTIMER2_TIMER2_SELECT_INPUT = 96U , kIOMUXC_QTIMER2_TIMER3_SELECT_INPUT = 97U , kIOMUXC_QTIMER3_TIMER0_SELECT_INPUT = 98U , kIOMUXC_QTIMER3_TIMER1_SELECT_INPUT = 99U ,
  kIOMUXC_QTIMER3_TIMER2_SELECT_INPUT = 100U , kIOMUXC_QTIMER3_TIMER3_SELECT_INPUT = 101U , kIOMUXC_SAI1_MCLK2_SELECT_INPUT = 102U , kIOMUXC_SAI1_RX_BCLK_SELECT_INPUT = 103U ,
  kIOMUXC_SAI1_RX_DATA0_SELECT_INPUT = 104U , kIOMUXC_SAI1_RX_DATA1_SELECT_INPUT = 105U , kIOMUXC_SAI1_RX_DATA2_SELECT_INPUT = 106U , kIOMUXC_SAI1_RX_DATA3_SELECT_INPUT = 107U ,
  kIOMUXC_SAI1_RX_SYNC_SELECT_INPUT = 108U , kIOMUXC_SAI1_TX_BCLK_SELECT_INPUT = 109U , kIOMUXC_SAI1_TX_SYNC_SELECT_INPUT = 110U , kIOMUXC_SAI2_MCLK2_SELECT_INPUT = 111U ,
  kIOMUXC_SAI2_RX_BCLK_SELECT_INPUT = 112U , kIOMUXC_SAI2_RX_DATA0_SELECT_INPUT = 113U , kIOMUXC_SAI2_RX_SYNC_SELECT_INPUT = 114U , kIOMUXC_SAI2_TX_BCLK_SELECT_INPUT = 115U ,
  kIOMUXC_SAI2_TX_SYNC_SELECT_INPUT = 116U , kIOMUXC_SPDIF_IN_SELECT_INPUT = 117U , kIOMUXC_USB_OTG2_OC_SELECT_INPUT = 118U , kIOMUXC_USB_OTG1_OC_SELECT_INPUT = 119U ,
  kIOMUXC_USDHC1_CD_B_SELECT_INPUT = 120U , kIOMUXC_USDHC1_WP_SELECT_INPUT = 121U , kIOMUXC_USDHC2_CLK_SELECT_INPUT = 122U , kIOMUXC_USDHC2_CD_B_SELECT_INPUT = 123U ,
  kIOMUXC_USDHC2_CMD_SELECT_INPUT = 124U , kIOMUXC_USDHC2_DATA0_SELECT_INPUT = 125U , kIOMUXC_USDHC2_DATA1_SELECT_INPUT = 126U , kIOMUXC_USDHC2_DATA2_SELECT_INPUT = 127U ,
  kIOMUXC_USDHC2_DATA3_SELECT_INPUT = 128U , kIOMUXC_USDHC2_DATA4_SELECT_INPUT = 129U , kIOMUXC_USDHC2_DATA5_SELECT_INPUT = 130U , kIOMUXC_USDHC2_DATA6_SELECT_INPUT = 131U ,
  kIOMUXC_USDHC2_DATA7_SELECT_INPUT = 132U , kIOMUXC_USDHC2_WP_SELECT_INPUT = 133U , kIOMUXC_XBAR_INOUT02_SELECT_INPUT = 134U , kIOMUXC_XBAR_INOUT03_SELECT_INPUT = 135U ,
  kIOMUXC_XBAR_INOUT04_SELECT_INPUT = 136U , kIOMUXC_XBAR_INOUT05_SELECT_INPUT = 137U , kIOMUXC_XBAR_INOUT06_SELECT_INPUT = 138U , kIOMUXC_XBAR_INOUT07_SELECT_INPUT = 139U ,
  kIOMUXC_XBAR_INOUT08_SELECT_INPUT = 140U , kIOMUXC_XBAR_INOUT09_SELECT_INPUT = 141U , kIOMUXC_XBAR_INOUT17_SELECT_INPUT = 142U , kIOMUXC_XBAR_INOUT18_SELECT_INPUT = 143U ,
  kIOMUXC_XBAR_INOUT20_SELECT_INPUT = 144U , kIOMUXC_XBAR_INOUT22_SELECT_INPUT = 145U , kIOMUXC_XBAR_INOUT23_SELECT_INPUT = 146U , kIOMUXC_XBAR_INOUT24_SELECT_INPUT = 147U ,
  kIOMUXC_XBAR_INOUT14_SELECT_INPUT = 148U , kIOMUXC_XBAR_INOUT15_SELECT_INPUT = 149U , kIOMUXC_XBAR_INOUT16_SELECT_INPUT = 150U , kIOMUXC_XBAR_INOUT25_SELECT_INPUT = 151U ,
  kIOMUXC_XBAR_INOUT19_SELECT_INPUT = 152U , kIOMUXC_XBAR_INOUT21_SELECT_INPUT = 153U , kIOMUXC_FLEXCAN1_RX_SELECT_INPUT = 0U , kIOMUXC_FLEXCAN2_RX_SELECT_INPUT = 1U ,
  kIOMUXC_ENET_IPG_CLK_RMII_SELECT_INPUT = 4U , kIOMUXC_ENET_MAC0_MDIO_SELECT_INPUT = 5U , kIOMUXC_ENET_MAC0_RXDATA_SELECT_INPUT_0 = 6U , kIOMUXC_ENET_MAC0_RXDATA_SELECT_INPUT_1 = 7U ,
  kIOMUXC_ENET_MAC0_RXEN_SELECT_INPUT = 8U , kIOMUXC_ENET_MAC0_RXERR_SELECT_INPUT = 9U , kIOMUXC_ENET_MAC0_TXCLK_SELECT_INPUT = 10U , kIOMUXC_ENET_1G_IPG_CLK_RMII_SELECT_INPUT = 11U ,
  kIOMUXC_ENET_1G_MAC0_MDIO_SELECT_INPUT = 12U , kIOMUXC_ENET_1G_MAC0_RXCLK_SELECT_INPUT = 13U , kIOMUXC_ENET_1G_MAC0_RXDATA_0_SELECT_INPUT = 14U , kIOMUXC_ENET_1G_MAC0_RXDATA_1_SELECT_INPUT = 15U ,
  kIOMUXC_ENET_1G_MAC0_RXDATA_2_SELECT_INPUT = 16U , kIOMUXC_ENET_1G_MAC0_RXDATA_3_SELECT_INPUT = 17U , kIOMUXC_ENET_1G_MAC0_RXEN_SELECT_INPUT = 18U , kIOMUXC_ENET_1G_MAC0_RXERR_SELECT_INPUT = 19U ,
  kIOMUXC_ENET_1G_MAC0_TXCLK_SELECT_INPUT = 20U , kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_0 = 26U , kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_1 = 27U , kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_2 = 28U ,
  kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_0 = 29U , kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_1 = 30U , kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_2 = 31U , kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_0 = 32U ,
  kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_1 = 33U , kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_2 = 34U , kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_0 = 35U , kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_1 = 36U ,
  kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_2 = 37U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_0 = 38U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_1 = 39U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_2 = 40U ,
  kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_3 = 41U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_0 = 42U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_1 = 43U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_2 = 44U ,
  kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_3 = 45U , kIOMUXC_FLEXSPI1_I_DQS_FA_SELECT_INPUT = 46U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_0 = 47U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_1 = 48U ,
  kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_2 = 49U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_3 = 50U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_0 = 51U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_1 = 52U ,
  kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_2 = 53U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_3 = 54U , kIOMUXC_FLEXSPI1_I_SCK_FA_SELECT_INPUT = 55U , kIOMUXC_FLEXSPI1_I_SCK_FB_SELECT_INPUT = 56U ,
  kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_0 = 57U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_1 = 58U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_2 = 59U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_3 = 60U ,
  kIOMUXC_FLEXSPI2_I_SCK_FA_SELECT_INPUT = 61U , kIOMUXC_GPT3_CAPIN1_SELECT_INPUT = 62U , kIOMUXC_GPT3_CAPIN2_SELECT_INPUT = 63U , kIOMUXC_GPT3_CLKIN_SELECT_INPUT = 64U ,
  kIOMUXC_KPP_COL_SELECT_INPUT_6 = 65U , kIOMUXC_KPP_COL_SELECT_INPUT_7 = 66U , kIOMUXC_KPP_ROW_SELECT_INPUT_6 = 67U , kIOMUXC_KPP_ROW_SELECT_INPUT_7 = 68U ,
  kIOMUXC_LPI2C1_LPI2C_SCL_SELECT_INPUT = 69U , kIOMUXC_LPI2C1_LPI2C_SDA_SELECT_INPUT = 70U , kIOMUXC_LPI2C2_LPI2C_SCL_SELECT_INPUT = 71U , kIOMUXC_LPI2C2_LPI2C_SDA_SELECT_INPUT = 72U ,
  kIOMUXC_LPI2C3_LPI2C_SCL_SELECT_INPUT = 73U , kIOMUXC_LPI2C3_LPI2C_SDA_SELECT_INPUT = 74U , kIOMUXC_LPI2C4_LPI2C_SCL_SELECT_INPUT = 75U , kIOMUXC_LPI2C4_LPI2C_SDA_SELECT_INPUT = 76U ,
  kIOMUXC_LPSPI1_LPSPI_PCS_SELECT_INPUT_0 = 77U , kIOMUXC_LPSPI1_LPSPI_SCK_SELECT_INPUT = 78U , kIOMUXC_LPSPI1_LPSPI_SDI_SELECT_INPUT = 79U , kIOMUXC_LPSPI1_LPSPI_SDO_SELECT_INPUT = 80U ,
  kIOMUXC_LPSPI2_LPSPI_PCS_SELECT_INPUT_0 = 81U , kIOMUXC_LPSPI2_LPSPI_PCS_SELECT_INPUT_1 = 82U , kIOMUXC_LPSPI2_LPSPI_SCK_SELECT_INPUT = 83U , kIOMUXC_LPSPI2_LPSPI_SDI_SELECT_INPUT = 84U ,
  kIOMUXC_LPSPI2_LPSPI_SDO_SELECT_INPUT = 85U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_0 = 86U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_1 = 87U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_2 = 88U ,
  kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_3 = 89U , kIOMUXC_LPSPI3_LPSPI_SCK_SELECT_INPUT = 90U , kIOMUXC_LPSPI3_LPSPI_SDI_SELECT_INPUT = 91U , kIOMUXC_LPSPI3_LPSPI_SDO_SELECT_INPUT = 92U ,
  kIOMUXC_LPSPI4_LPSPI_PCS_SELECT_INPUT_0 = 93U , kIOMUXC_LPSPI4_LPSPI_SCK_SELECT_INPUT = 94U , kIOMUXC_LPSPI4_LPSPI_SDI_SELECT_INPUT = 95U , kIOMUXC_LPSPI4_LPSPI_SDO_SELECT_INPUT = 96U ,
  kIOMUXC_LPUART1_LPUART_RXD_SELECT_INPUT = 97U , kIOMUXC_LPUART1_LPUART_TXD_SELECT_INPUT = 98U , kIOMUXC_LPUART10_LPUART_RXD_SELECT_INPUT = 99U , kIOMUXC_LPUART10_LPUART_TXD_SELECT_INPUT = 100U ,
  kIOMUXC_LPUART7_LPUART_RXD_SELECT_INPUT = 101U , kIOMUXC_LPUART7_LPUART_TXD_SELECT_INPUT = 102U , kIOMUXC_LPUART8_LPUART_RXD_SELECT_INPUT = 103U , kIOMUXC_LPUART8_LPUART_TXD_SELECT_INPUT = 104U ,
  kIOMUXC_QTIMER1_TMR0_INPUT_SELECT_INPUT = 105U , kIOMUXC_QTIMER1_TMR1_INPUT_SELECT_INPUT = 106U , kIOMUXC_QTIMER1_TMR2_INPUT_SELECT_INPUT = 107U , kIOMUXC_QTIMER2_TMR0_INPUT_SELECT_INPUT = 108U ,
  kIOMUXC_QTIMER2_TMR1_INPUT_SELECT_INPUT = 109U , kIOMUXC_QTIMER2_TMR2_INPUT_SELECT_INPUT = 110U , kIOMUXC_QTIMER3_TMR0_INPUT_SELECT_INPUT = 111U , kIOMUXC_QTIMER3_TMR1_INPUT_SELECT_INPUT = 112U ,
  kIOMUXC_QTIMER3_TMR2_INPUT_SELECT_INPUT = 113U , kIOMUXC_QTIMER4_TMR0_INPUT_SELECT_INPUT = 114U , kIOMUXC_QTIMER4_TMR1_INPUT_SELECT_INPUT = 115U , kIOMUXC_QTIMER4_TMR2_INPUT_SELECT_INPUT = 116U ,
  kIOMUXC_SAI1_IPG_CLK_SAI_MCLK_SELECT_INPUT = 117U , kIOMUXC_SAI1_SAI_RXBCLK_SELECT_INPUT = 118U , kIOMUXC_SAI1_SAI_RXDATA_SELECT_INPUT_0 = 119U , kIOMUXC_SAI1_SAI_RXSYNC_SELECT_INPUT = 120U ,
  kIOMUXC_SAI1_SAI_TXBCLK_SELECT_INPUT = 121U , kIOMUXC_SAI1_SAI_TXSYNC_SELECT_INPUT = 122U , kIOMUXC_EMVSIM1_SIO_SELECT_INPUT = 129U , kIOMUXC_EMVSIM1_IPP_SIMPD_SELECT_INPUT = 130U ,
  kIOMUXC_EMVSIM1_POWER_FAIL_SELECT_INPUT = 131U , kIOMUXC_EMVSIM2_SIO_SELECT_INPUT = 132U , kIOMUXC_EMVSIM2_IPP_SIMPD_SELECT_INPUT = 133U , kIOMUXC_EMVSIM2_POWER_FAIL_SELECT_INPUT = 134U ,
  kIOMUXC_SPDIF_SPDIF_IN1_SELECT_INPUT = 135U , kIOMUXC_USB_OTG2_OC_SELECT_INPUT = 136U , kIOMUXC_USB_OTG_OC_SELECT_INPUT = 137U , kIOMUXC_USBPHY1_USB_ID_SELECT_INPUT = 138U ,
  kIOMUXC_USBPHY2_USB_ID_SELECT_INPUT = 139U , kIOMUXC_USDHC1_IPP_CARD_DET_SELECT_INPUT = 140U , kIOMUXC_USDHC1_IPP_WP_ON_SELECT_INPUT = 141U , kIOMUXC_USDHC2_IPP_CARD_DET_SELECT_INPUT = 142U ,
  kIOMUXC_USDHC2_IPP_WP_ON_SELECT_INPUT = 143U , kIOMUXC_XBAR1_IN_SELECT_INPUT_20 = 144U , kIOMUXC_XBAR1_IN_SELECT_INPUT_21 = 145U , kIOMUXC_XBAR1_IN_SELECT_INPUT_22 = 146U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_23 = 147U , kIOMUXC_XBAR1_IN_SELECT_INPUT_24 = 148U , kIOMUXC_XBAR1_IN_SELECT_INPUT_25 = 149U , kIOMUXC_XBAR1_IN_SELECT_INPUT_26 = 150U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_27 = 151U , kIOMUXC_XBAR1_IN_SELECT_INPUT_28 = 152U , kIOMUXC_XBAR1_IN_SELECT_INPUT_29 = 153U , kIOMUXC_XBAR1_IN_SELECT_INPUT_30 = 154U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_31 = 155U , kIOMUXC_XBAR1_IN_SELECT_INPUT_32 = 156U , kIOMUXC_XBAR1_IN_SELECT_INPUT_33 = 157U , kIOMUXC_XBAR1_IN_SELECT_INPUT_34 = 158U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_35 = 159U , kIOMUXC_FLEXCAN1_RX_SELECT_INPUT = 0U , kIOMUXC_FLEXCAN2_RX_SELECT_INPUT = 1U , kIOMUXC_ENET_IPG_CLK_RMII_SELECT_INPUT = 4U ,
  kIOMUXC_ENET_MAC0_MDIO_SELECT_INPUT = 5U , kIOMUXC_ENET_MAC0_RXDATA_SELECT_INPUT_0 = 6U , kIOMUXC_ENET_MAC0_RXDATA_SELECT_INPUT_1 = 7U , kIOMUXC_ENET_MAC0_RXEN_SELECT_INPUT = 8U ,
  kIOMUXC_ENET_MAC0_RXERR_SELECT_INPUT = 9U , kIOMUXC_ENET_MAC0_TXCLK_SELECT_INPUT = 10U , kIOMUXC_ENET_1G_IPG_CLK_RMII_SELECT_INPUT = 11U , kIOMUXC_ENET_1G_MAC0_MDIO_SELECT_INPUT = 12U ,
  kIOMUXC_ENET_1G_MAC0_RXCLK_SELECT_INPUT = 13U , kIOMUXC_ENET_1G_MAC0_RXDATA_0_SELECT_INPUT = 14U , kIOMUXC_ENET_1G_MAC0_RXDATA_1_SELECT_INPUT = 15U , kIOMUXC_ENET_1G_MAC0_RXDATA_2_SELECT_INPUT = 16U ,
  kIOMUXC_ENET_1G_MAC0_RXDATA_3_SELECT_INPUT = 17U , kIOMUXC_ENET_1G_MAC0_RXEN_SELECT_INPUT = 18U , kIOMUXC_ENET_1G_MAC0_RXERR_SELECT_INPUT = 19U , kIOMUXC_ENET_1G_MAC0_TXCLK_SELECT_INPUT = 20U ,
  kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_0 = 26U , kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_1 = 27U , kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_2 = 28U , kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_0 = 29U ,
  kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_1 = 30U , kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_2 = 31U , kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_0 = 32U , kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_1 = 33U ,
  kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_2 = 34U , kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_0 = 35U , kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_1 = 36U , kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_2 = 37U ,
  kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_0 = 38U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_1 = 39U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_2 = 40U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_3 = 41U ,
  kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_0 = 42U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_1 = 43U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_2 = 44U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_3 = 45U ,
  kIOMUXC_FLEXSPI1_I_DQS_FA_SELECT_INPUT = 46U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_0 = 47U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_1 = 48U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_2 = 49U ,
  kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_3 = 50U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_0 = 51U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_1 = 52U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_2 = 53U ,
  kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_3 = 54U , kIOMUXC_FLEXSPI1_I_SCK_FA_SELECT_INPUT = 55U , kIOMUXC_FLEXSPI1_I_SCK_FB_SELECT_INPUT = 56U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_0 = 57U ,
  kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_1 = 58U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_2 = 59U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_3 = 60U , kIOMUXC_FLEXSPI2_I_SCK_FA_SELECT_INPUT = 61U ,
  kIOMUXC_GPT3_CAPIN1_SELECT_INPUT = 62U , kIOMUXC_GPT3_CAPIN2_SELECT_INPUT = 63U , kIOMUXC_GPT3_CLKIN_SELECT_INPUT = 64U , kIOMUXC_KPP_COL_SELECT_INPUT_6 = 65U ,
  kIOMUXC_KPP_COL_SELECT_INPUT_7 = 66U , kIOMUXC_KPP_ROW_SELECT_INPUT_6 = 67U , kIOMUXC_KPP_ROW_SELECT_INPUT_7 = 68U , kIOMUXC_LPI2C1_LPI2C_SCL_SELECT_INPUT = 69U ,
  kIOMUXC_LPI2C1_LPI2C_SDA_SELECT_INPUT = 70U , kIOMUXC_LPI2C2_LPI2C_SCL_SELECT_INPUT = 71U , kIOMUXC_LPI2C2_LPI2C_SDA_SELECT_INPUT = 72U , kIOMUXC_LPI2C3_LPI2C_SCL_SELECT_INPUT = 73U ,
  kIOMUXC_LPI2C3_LPI2C_SDA_SELECT_INPUT = 74U , kIOMUXC_LPI2C4_LPI2C_SCL_SELECT_INPUT = 75U , kIOMUXC_LPI2C4_LPI2C_SDA_SELECT_INPUT = 76U , kIOMUXC_LPSPI1_LPSPI_PCS_SELECT_INPUT_0 = 77U ,
  kIOMUXC_LPSPI1_LPSPI_SCK_SELECT_INPUT = 78U , kIOMUXC_LPSPI1_LPSPI_SDI_SELECT_INPUT = 79U , kIOMUXC_LPSPI1_LPSPI_SDO_SELECT_INPUT = 80U , kIOMUXC_LPSPI2_LPSPI_PCS_SELECT_INPUT_0 = 81U ,
  kIOMUXC_LPSPI2_LPSPI_PCS_SELECT_INPUT_1 = 82U , kIOMUXC_LPSPI2_LPSPI_SCK_SELECT_INPUT = 83U , kIOMUXC_LPSPI2_LPSPI_SDI_SELECT_INPUT = 84U , kIOMUXC_LPSPI2_LPSPI_SDO_SELECT_INPUT = 85U ,
  kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_0 = 86U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_1 = 87U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_2 = 88U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_3 = 89U ,
  kIOMUXC_LPSPI3_LPSPI_SCK_SELECT_INPUT = 90U , kIOMUXC_LPSPI3_LPSPI_SDI_SELECT_INPUT = 91U , kIOMUXC_LPSPI3_LPSPI_SDO_SELECT_INPUT = 92U , kIOMUXC_LPSPI4_LPSPI_PCS_SELECT_INPUT_0 = 93U ,
  kIOMUXC_LPSPI4_LPSPI_SCK_SELECT_INPUT = 94U , kIOMUXC_LPSPI4_LPSPI_SDI_SELECT_INPUT = 95U , kIOMUXC_LPSPI4_LPSPI_SDO_SELECT_INPUT = 96U , kIOMUXC_LPUART1_LPUART_RXD_SELECT_INPUT = 97U ,
  kIOMUXC_LPUART1_LPUART_TXD_SELECT_INPUT = 98U , kIOMUXC_LPUART10_LPUART_RXD_SELECT_INPUT = 99U , kIOMUXC_LPUART10_LPUART_TXD_SELECT_INPUT = 100U , kIOMUXC_LPUART7_LPUART_RXD_SELECT_INPUT = 101U ,
  kIOMUXC_LPUART7_LPUART_TXD_SELECT_INPUT = 102U , kIOMUXC_LPUART8_LPUART_RXD_SELECT_INPUT = 103U , kIOMUXC_LPUART8_LPUART_TXD_SELECT_INPUT = 104U , kIOMUXC_QTIMER1_TMR0_INPUT_SELECT_INPUT = 105U ,
  kIOMUXC_QTIMER1_TMR1_INPUT_SELECT_INPUT = 106U , kIOMUXC_QTIMER1_TMR2_INPUT_SELECT_INPUT = 107U , kIOMUXC_QTIMER2_TMR0_INPUT_SELECT_INPUT = 108U , kIOMUXC_QTIMER2_TMR1_INPUT_SELECT_INPUT = 109U ,
  kIOMUXC_QTIMER2_TMR2_INPUT_SELECT_INPUT = 110U , kIOMUXC_QTIMER3_TMR0_INPUT_SELECT_INPUT = 111U , kIOMUXC_QTIMER3_TMR1_INPUT_SELECT_INPUT = 112U , kIOMUXC_QTIMER3_TMR2_INPUT_SELECT_INPUT = 113U ,
  kIOMUXC_QTIMER4_TMR0_INPUT_SELECT_INPUT = 114U , kIOMUXC_QTIMER4_TMR1_INPUT_SELECT_INPUT = 115U , kIOMUXC_QTIMER4_TMR2_INPUT_SELECT_INPUT = 116U , kIOMUXC_SAI1_IPG_CLK_SAI_MCLK_SELECT_INPUT = 117U ,
  kIOMUXC_SAI1_SAI_RXBCLK_SELECT_INPUT = 118U , kIOMUXC_SAI1_SAI_RXDATA_SELECT_INPUT_0 = 119U , kIOMUXC_SAI1_SAI_RXSYNC_SELECT_INPUT = 120U , kIOMUXC_SAI1_SAI_TXBCLK_SELECT_INPUT = 121U ,
  kIOMUXC_SAI1_SAI_TXSYNC_SELECT_INPUT = 122U , kIOMUXC_EMVSIM1_SIO_SELECT_INPUT = 129U , kIOMUXC_EMVSIM1_IPP_SIMPD_SELECT_INPUT = 130U , kIOMUXC_EMVSIM1_POWER_FAIL_SELECT_INPUT = 131U ,
  kIOMUXC_EMVSIM2_SIO_SELECT_INPUT = 132U , kIOMUXC_EMVSIM2_IPP_SIMPD_SELECT_INPUT = 133U , kIOMUXC_EMVSIM2_POWER_FAIL_SELECT_INPUT = 134U , kIOMUXC_SPDIF_SPDIF_IN1_SELECT_INPUT = 135U ,
  kIOMUXC_USB_OTG2_OC_SELECT_INPUT = 136U , kIOMUXC_USB_OTG_OC_SELECT_INPUT = 137U , kIOMUXC_USBPHY1_USB_ID_SELECT_INPUT = 138U , kIOMUXC_USBPHY2_USB_ID_SELECT_INPUT = 139U ,
  kIOMUXC_USDHC1_IPP_CARD_DET_SELECT_INPUT = 140U , kIOMUXC_USDHC1_IPP_WP_ON_SELECT_INPUT = 141U , kIOMUXC_USDHC2_IPP_CARD_DET_SELECT_INPUT = 142U , kIOMUXC_USDHC2_IPP_WP_ON_SELECT_INPUT = 143U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_20 = 144U , kIOMUXC_XBAR1_IN_SELECT_INPUT_21 = 145U , kIOMUXC_XBAR1_IN_SELECT_INPUT_22 = 146U , kIOMUXC_XBAR1_IN_SELECT_INPUT_23 = 147U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_24 = 148U , kIOMUXC_XBAR1_IN_SELECT_INPUT_25 = 149U , kIOMUXC_XBAR1_IN_SELECT_INPUT_26 = 150U , kIOMUXC_XBAR1_IN_SELECT_INPUT_27 = 151U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_28 = 152U , kIOMUXC_XBAR1_IN_SELECT_INPUT_29 = 153U , kIOMUXC_XBAR1_IN_SELECT_INPUT_30 = 154U , kIOMUXC_XBAR1_IN_SELECT_INPUT_31 = 155U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_32 = 156U , kIOMUXC_XBAR1_IN_SELECT_INPUT_33 = 157U , kIOMUXC_XBAR1_IN_SELECT_INPUT_34 = 158U , kIOMUXC_XBAR1_IN_SELECT_INPUT_35 = 159U
 Enumeration for the IOMUXC select input. More...
enum  _xbar_input_signal {
  kXBARA1_InputLogicLow = 0|0x100U , kXBARA1_InputLogicHigh = 1|0x100U , kXBARA1_InputIomuxXbarIn02 = 2|0x100U , kXBARA1_InputIomuxXbarIn03 = 3|0x100U ,
  kXBARA1_InputIomuxXbarInout04 = 4|0x100U , kXBARA1_InputIomuxXbarInout05 = 5|0x100U , kXBARA1_InputIomuxXbarInout06 = 6|0x100U , kXBARA1_InputIomuxXbarInout07 = 7|0x100U ,
  kXBARA1_InputIomuxXbarInout08 = 8|0x100U , kXBARA1_InputIomuxXbarInout09 = 9|0x100U , kXBARA1_InputIomuxXbarInout10 = 10|0x100U , kXBARA1_InputIomuxXbarInout11 = 11|0x100U ,
  kXBARA1_InputIomuxXbarInout12 = 12|0x100U , kXBARA1_InputIomuxXbarInout13 = 13|0x100U , kXBARA1_InputIomuxXbarInout14 = 14|0x100U , kXBARA1_InputIomuxXbarInout15 = 15|0x100U ,
  kXBARA1_InputIomuxXbarInout16 = 16|0x100U , kXBARA1_InputIomuxXbarInout17 = 17|0x100U , kXBARA1_InputIomuxXbarInout18 = 18|0x100U , kXBARA1_InputIomuxXbarInout19 = 19|0x100U ,
  kXBARA1_InputIomuxXbarIn20 = 20|0x100U , kXBARA1_InputIomuxXbarIn21 = 21|0x100U , kXBARA1_InputIomuxXbarIn22 = 22|0x100U , kXBARA1_InputIomuxXbarIn23 = 23|0x100U ,
  kXBARA1_InputIomuxXbarIn24 = 24|0x100U , kXBARA1_InputIomuxXbarIn25 = 25|0x100U , kXBARA1_InputAcmp1Out = 26|0x100U , kXBARA1_InputAcmp2Out = 27|0x100U ,
  kXBARA1_InputAcmp3Out = 28|0x100U , kXBARA1_InputAcmp4Out = 29|0x100U , kXBARA1_InputRESERVED30 = 30|0x100U , kXBARA1_InputRESERVED31 = 31|0x100U ,
  kXBARA1_InputQtimer3Tmr0Output = 32|0x100U , kXBARA1_InputQtimer3Tmr1Output = 33|0x100U , kXBARA1_InputQtimer3Tmr2Output = 34|0x100U , kXBARA1_InputQtimer3Tmr3Output = 35|0x100U ,
  kXBARA1_InputQtimer4Tmr0Output = 36|0x100U , kXBARA1_InputQtimer4Tmr1Output = 37|0x100U , kXBARA1_InputQtimer4Tmr2Output = 38|0x100U , kXBARA1_InputQtimer4Tmr3Output = 39|0x100U ,
  kXBARA1_InputFlexpwm1Pwm1OutTrig01 = 40|0x100U , kXBARA1_InputFlexpwm1Pwm2OutTrig01 = 41|0x100U , kXBARA1_InputFlexpwm1Pwm3OutTrig01 = 42|0x100U , kXBARA1_InputFlexpwm1Pwm4OutTrig01 = 43|0x100U ,
  kXBARA1_InputFlexpwm2Pwm1OutTrig01 = 44|0x100U , kXBARA1_InputFlexpwm2Pwm2OutTrig01 = 45|0x100U , kXBARA1_InputFlexpwm2Pwm3OutTrig01 = 46|0x100U , kXBARA1_InputFlexpwm2Pwm4OutTrig01 = 47|0x100U ,
  kXBARA1_InputFlexpwm3Pwm1OutTrig01 = 48|0x100U , kXBARA1_InputFlexpwm3Pwm2OutTrig01 = 49|0x100U , kXBARA1_InputFlexpwm3Pwm3OutTrig01 = 50|0x100U , kXBARA1_InputFlexpwm3Pwm4OutTrig01 = 51|0x100U ,
  kXBARA1_InputFlexpwm4Pwm1OutTrig01 = 52|0x100U , kXBARA1_InputFlexpwm4Pwm2OutTrig01 = 53|0x100U , kXBARA1_InputFlexpwm4Pwm3OutTrig01 = 54|0x100U , kXBARA1_InputFlexpwm4Pwm4OutTrig01 = 55|0x100U ,
  kXBARA1_InputPitTrigger0 = 56|0x100U , kXBARA1_InputPitTrigger1 = 57|0x100U , kXBARA1_InputPitTrigger2 = 58|0x100U , kXBARA1_InputPitTrigger3 = 59|0x100U ,
  kXBARA1_InputEnc1PosMatch = 60|0x100U , kXBARA1_InputEnc2PosMatch = 61|0x100U , kXBARA1_InputEnc3PosMatch = 62|0x100U , kXBARA1_InputEnc4PosMatch = 63|0x100U ,
  kXBARA1_InputDmaDone0 = 64|0x100U , kXBARA1_InputDmaDone1 = 65|0x100U , kXBARA1_InputDmaDone2 = 66|0x100U , kXBARA1_InputDmaDone3 = 67|0x100U ,
  kXBARA1_InputDmaDone4 = 68|0x100U , kXBARA1_InputDmaDone5 = 69|0x100U , kXBARA1_InputDmaDone6 = 70|0x100U , kXBARA1_InputDmaDone7 = 71|0x100U ,
  kXBARA1_InputAoi1Out0 = 72|0x100U , kXBARA1_InputAoi1Out1 = 73|0x100U , kXBARA1_InputAoi1Out2 = 74|0x100U , kXBARA1_InputAoi1Out3 = 75|0x100U ,
  kXBARA1_InputAoi2Out0 = 76|0x100U , kXBARA1_InputAoi2Out1 = 77|0x100U , kXBARA1_InputAoi2Out2 = 78|0x100U , kXBARA1_InputAoi2Out3 = 79|0x100U ,
  kXBARA1_InputAdcEtcXbar0Coco0 = 80|0x100U , kXBARA1_InputAdcEtcXbar0Coco1 = 81|0x100U , kXBARA1_InputAdcEtcXbar0Coco2 = 82|0x100U , kXBARA1_InputAdcEtcXbar0Coco3 = 83|0x100U ,
  kXBARA1_InputAdcEtcXbar1Coco0 = 84|0x100U , kXBARA1_InputAdcEtcXbar1Coco1 = 85|0x100U , kXBARA1_InputAdcEtcXbar1Coco2 = 86|0x100U , kXBARA1_InputAdcEtcXbar1Coco3 = 87|0x100U ,
  kXBARB2_InputLogicLow = 0|0x200U , kXBARB2_InputLogicHigh = 1|0x200U , kXBARB2_InputRESERVED2 = 2|0x200U , kXBARB2_InputRESERVED3 = 3|0x200U ,
  kXBARB2_InputRESERVED4 = 4|0x200U , kXBARB2_InputRESERVED5 = 5|0x200U , kXBARB2_InputAcmp1Out = 6|0x200U , kXBARB2_InputAcmp2Out = 7|0x200U ,
  kXBARB2_InputAcmp3Out = 8|0x200U , kXBARB2_InputAcmp4Out = 9|0x200U , kXBARB2_InputRESERVED10 = 10|0x200U , kXBARB2_InputRESERVED11 = 11|0x200U ,
  kXBARB2_InputQtimer3Tmr0Output = 12|0x200U , kXBARB2_InputQtimer3Tmr1Output = 13|0x200U , kXBARB2_InputQtimer3Tmr2Output = 14|0x200U , kXBARB2_InputQtimer3Tmr3Output = 15|0x200U ,
  kXBARB2_InputQtimer4Tmr0Output = 16|0x200U , kXBARB2_InputQtimer4Tmr1Output = 17|0x200U , kXBARB2_InputQtimer4Tmr2Output = 18|0x200U , kXBARB2_InputQtimer4Tmr3Output = 19|0x200U ,
  kXBARB2_InputFlexpwm1Pwm1OutTrig01 = 20|0x200U , kXBARB2_InputFlexpwm1Pwm2OutTrig01 = 21|0x200U , kXBARB2_InputFlexpwm1Pwm3OutTrig01 = 22|0x200U , kXBARB2_InputFlexpwm1Pwm4OutTrig01 = 23|0x200U ,
  kXBARB2_InputFlexpwm2Pwm1OutTrig01 = 24|0x200U , kXBARB2_InputFlexpwm2Pwm2OutTrig01 = 25|0x200U , kXBARB2_InputFlexpwm2Pwm3OutTrig01 = 26|0x200U , kXBARB2_InputFlexpwm2Pwm4OutTrig01 = 27|0x200U ,
  kXBARB2_InputFlexpwm3Pwm1OutTrig01 = 28|0x200U , kXBARB2_InputFlexpwm3Pwm2OutTrig01 = 29|0x200U , kXBARB2_InputFlexpwm3Pwm3OutTrig01 = 30|0x200U , kXBARB2_InputFlexpwm3Pwm4OutTrig01 = 31|0x200U ,
  kXBARB2_InputFlexpwm4Pwm1OutTrig01 = 32|0x200U , kXBARB2_InputFlexpwm4Pwm2OutTrig01 = 33|0x200U , kXBARB2_InputFlexpwm4Pwm3OutTrig01 = 34|0x200U , kXBARB2_InputFlexpwm4Pwm4OutTrig01 = 35|0x200U ,
  kXBARB2_InputPitTrigger0 = 36|0x200U , kXBARB2_InputPitTrigger1 = 37|0x200U , kXBARB2_InputAdcEtcXbar0Coco0 = 38|0x200U , kXBARB2_InputAdcEtcXbar0Coco1 = 39|0x200U ,
  kXBARB2_InputAdcEtcXbar0Coco2 = 40|0x200U , kXBARB2_InputAdcEtcXbar0Coco3 = 41|0x200U , kXBARB2_InputAdcEtcXbar1Coco0 = 42|0x200U , kXBARB2_InputAdcEtcXbar1Coco1 = 43|0x200U ,
  kXBARB2_InputAdcEtcXbar1Coco2 = 44|0x200U , kXBARB2_InputAdcEtcXbar1Coco3 = 45|0x200U , kXBARB2_InputEnc1PosMatch = 46|0x200U , kXBARB2_InputEnc2PosMatch = 47|0x200U ,
  kXBARB2_InputEnc3PosMatch = 48|0x200U , kXBARB2_InputEnc4PosMatch = 49|0x200U , kXBARB2_InputDmaDone0 = 50|0x200U , kXBARB2_InputDmaDone1 = 51|0x200U ,
  kXBARB2_InputDmaDone2 = 52|0x200U , kXBARB2_InputDmaDone3 = 53|0x200U , kXBARB2_InputDmaDone4 = 54|0x200U , kXBARB2_InputDmaDone5 = 55|0x200U ,
  kXBARB2_InputDmaDone6 = 56|0x200U , kXBARB2_InputDmaDone7 = 57|0x200U , kXBARB3_InputLogicLow = 0|0x300U , kXBARB3_InputLogicHigh = 1|0x300U ,
  kXBARB3_InputRESERVED2 = 2|0x300U , kXBARB3_InputRESERVED3 = 3|0x300U , kXBARB3_InputRESERVED4 = 4|0x300U , kXBARB3_InputRESERVED5 = 5|0x300U ,
  kXBARB3_InputAcmp1Out = 6|0x300U , kXBARB3_InputAcmp2Out = 7|0x300U , kXBARB3_InputAcmp3Out = 8|0x300U , kXBARB3_InputAcmp4Out = 9|0x300U ,
  kXBARB3_InputRESERVED10 = 10|0x300U , kXBARB3_InputRESERVED11 = 11|0x300U , kXBARB3_InputQtimer3Tmr0Output = 12|0x300U , kXBARB3_InputQtimer3Tmr1Output = 13|0x300U ,
  kXBARB3_InputQtimer3Tmr2Output = 14|0x300U , kXBARB3_InputQtimer3Tmr3Output = 15|0x300U , kXBARB3_InputQtimer4Tmr0Output = 16|0x300U , kXBARB3_InputQtimer4Tmr1Output = 17|0x300U ,
  kXBARB3_InputQtimer4Tmr2Output = 18|0x300U , kXBARB3_InputQtimer4Tmr3Output = 19|0x300U , kXBARB3_InputFlexpwm1Pwm1OutTrig01 = 20|0x300U , kXBARB3_InputFlexpwm1Pwm2OutTrig01 = 21|0x300U ,
  kXBARB3_InputFlexpwm1Pwm3OutTrig01 = 22|0x300U , kXBARB3_InputFlexpwm1Pwm4OutTrig01 = 23|0x300U , kXBARB3_InputFlexpwm2Pwm1OutTrig01 = 24|0x300U , kXBARB3_InputFlexpwm2Pwm2OutTrig01 = 25|0x300U ,
  kXBARB3_InputFlexpwm2Pwm3OutTrig01 = 26|0x300U , kXBARB3_InputFlexpwm2Pwm4OutTrig01 = 27|0x300U , kXBARB3_InputFlexpwm3Pwm1OutTrig01 = 28|0x300U , kXBARB3_InputFlexpwm3Pwm2OutTrig01 = 29|0x300U ,
  kXBARB3_InputFlexpwm3Pwm3OutTrig01 = 30|0x300U , kXBARB3_InputFlexpwm3Pwm4OutTrig01 = 31|0x300U , kXBARB3_InputFlexpwm4Pwm1OutTrig01 = 32|0x300U , kXBARB3_InputFlexpwm4Pwm2OutTrig01 = 33|0x300U ,
  kXBARB3_InputFlexpwm4Pwm3OutTrig01 = 34|0x300U , kXBARB3_InputFlexpwm4Pwm4OutTrig01 = 35|0x300U , kXBARB3_InputPitTrigger0 = 36|0x300U , kXBARB3_InputPitTrigger1 = 37|0x300U ,
  kXBARB3_InputAdcEtcXbar0Coco0 = 38|0x300U , kXBARB3_InputAdcEtcXbar0Coco1 = 39|0x300U , kXBARB3_InputAdcEtcXbar0Coco2 = 40|0x300U , kXBARB3_InputAdcEtcXbar0Coco3 = 41|0x300U ,
  kXBARB3_InputAdcEtcXbar1Coco0 = 42|0x300U , kXBARB3_InputAdcEtcXbar1Coco1 = 43|0x300U , kXBARB3_InputAdcEtcXbar1Coco2 = 44|0x300U , kXBARB3_InputAdcEtcXbar1Coco3 = 45|0x300U ,
  kXBARB3_InputEnc1PosMatch = 46|0x300U , kXBARB3_InputEnc2PosMatch = 47|0x300U , kXBARB3_InputEnc3PosMatch = 48|0x300U , kXBARB3_InputEnc4PosMatch = 49|0x300U ,
  kXBARB3_InputDmaDone0 = 50|0x300U , kXBARB3_InputDmaDone1 = 51|0x300U , kXBARB3_InputDmaDone2 = 52|0x300U , kXBARB3_InputDmaDone3 = 53|0x300U ,
  kXBARB3_InputDmaDone4 = 54|0x300U , kXBARB3_InputDmaDone5 = 55|0x300U , kXBARB3_InputDmaDone6 = 56|0x300U , kXBARB3_InputDmaDone7 = 57|0x300U ,
  kXBARA1_InputLogicLow = 0|0x100U , kXBARA1_InputLogicHigh = 1|0x100U , kXBARA1_InputRESERVED2 = 2|0x100U , kXBARA1_InputRESERVED3 = 3|0x100U ,
  kXBARA1_InputIomuxXbarInout20 = 20|0x100U , kXBARA1_InputIomuxXbarInout21 = 21|0x100U , kXBARA1_InputIomuxXbarInout22 = 22|0x100U , kXBARA1_InputIomuxXbarInout23 = 23|0x100U ,
  kXBARA1_InputIomuxXbarInout24 = 24|0x100U , kXBARA1_InputIomuxXbarInout25 = 25|0x100U , kXBARA1_InputIomuxXbarInout26 = 26|0x100U , kXBARA1_InputIomuxXbarInout27 = 27|0x100U ,
  kXBARA1_InputIomuxXbarInout28 = 28|0x100U , kXBARA1_InputIomuxXbarInout29 = 29|0x100U , kXBARA1_InputIomuxXbarInout30 = 30|0x100U , kXBARA1_InputIomuxXbarInout31 = 31|0x100U ,
  kXBARA1_InputIomuxXbarInout32 = 32|0x100U , kXBARA1_InputIomuxXbarInout33 = 33|0x100U , kXBARA1_InputIomuxXbarInout34 = 34|0x100U , kXBARA1_InputIomuxXbarInout35 = 35|0x100U ,
  kXBARA1_InputIomuxXbarInout36 = 36|0x100U , kXBARA1_InputIomuxXbarInout37 = 37|0x100U , kXBARA1_InputIomuxXbarInout38 = 38|0x100U , kXBARA1_InputIomuxXbarInout39 = 39|0x100U ,
  kXBARA1_InputIomuxXbarInout40 = 40|0x100U , kXBARA1_InputRESERVED41 = 41|0x100U , kXBARA1_InputAcmp1Out = 42|0x100U , kXBARA1_InputAcmp2Out = 43|0x100U ,
  kXBARA1_InputAcmp3Out = 44|0x100U , kXBARA1_InputAcmp4Out = 45|0x100U , kXBARA1_InputRESERVED46 = 46|0x100U , kXBARA1_InputRESERVED47 = 47|0x100U ,
  kXBARA1_InputRESERVED48 = 48|0x100U , kXBARA1_InputRESERVED49 = 49|0x100U , kXBARA1_InputQtimer1Timer0 = 50|0x100U , kXBARA1_InputQtimer1Timer1 = 51|0x100U ,
  kXBARA1_InputQtimer1Timer2 = 52|0x100U , kXBARA1_InputQtimer1Timer3 = 53|0x100U , kXBARA1_InputQtimer2Timer0 = 54|0x100U , kXBARA1_InputQtimer2Timer1 = 55|0x100U ,
  kXBARA1_InputQtimer2Timer2 = 56|0x100U , kXBARA1_InputQtimer2Timer3 = 57|0x100U , kXBARA1_InputQtimer3Timer0 = 58|0x100U , kXBARA1_InputQtimer3Timer1 = 59|0x100U ,
  kXBARA1_InputQtimer3Timer2 = 60|0x100U , kXBARA1_InputQtimer3Timer3 = 61|0x100U , kXBARA1_InputQtimer4Timer0 = 62|0x100U , kXBARA1_InputQtimer4Timer1 = 63|0x100U ,
  kXBARA1_InputQtimer4Timer2 = 64|0x100U , kXBARA1_InputQtimer4Timer3 = 65|0x100U , kXBARA1_InputRESERVED66 = 66|0x100U , kXBARA1_InputRESERVED67 = 67|0x100U ,
  kXBARA1_InputRESERVED68 = 68|0x100U , kXBARA1_InputRESERVED69 = 69|0x100U , kXBARA1_InputRESERVED70 = 70|0x100U , kXBARA1_InputRESERVED71 = 71|0x100U ,
  kXBARA1_InputRESERVED72 = 72|0x100U , kXBARA1_InputRESERVED73 = 73|0x100U , kXBARA1_InputFlexpwm1Pwm0OutTrig0 = 74|0x100U , kXBARA1_InputFlexpwm1Pwm0OutTrig1 = 75|0x100U ,
  kXBARA1_InputFlexpwm1Pwm1OutTrig0 = 76|0x100U , kXBARA1_InputFlexpwm1Pwm1OutTrig1 = 77|0x100U , kXBARA1_InputFlexpwm1Pwm2OutTrig0 = 78|0x100U , kXBARA1_InputFlexpwm1Pwm2OutTrig1 = 79|0x100U ,
  kXBARA1_InputFlexpwm1Pwm3OutTrig0 = 80|0x100U , kXBARA1_InputFlexpwm1Pwm3OutTrig1 = 81|0x100U , kXBARA1_InputFlexpwm2Pwm0OutTrig01 = 82|0x100U , kXBARA1_InputFlexpwm2Pwm1OutTrig01 = 83|0x100U ,
  kXBARA1_InputFlexpwm2Pwm2OutTrig01 = 84|0x100U , kXBARA1_InputFlexpwm2Pwm3OutTrig01 = 85|0x100U , kXBARA1_InputFlexpwm3Pwm0OutTrig01 = 86|0x100U , kXBARA1_InputFlexpwm3Pwm1OutTrig01 = 87|0x100U ,
  kXBARA1_InputFlexpwm3Pwm2OutTrig01 = 88|0x100U , kXBARA1_InputFlexpwm3Pwm3OutTrig01 = 89|0x100U , kXBARA1_InputFlexpwm4Pwm0OutTrig01 = 90|0x100U , kXBARA1_InputFlexpwm4Pwm1OutTrig01 = 91|0x100U ,
  kXBARA1_InputFlexpwm4Pwm2OutTrig01 = 92|0x100U , kXBARA1_InputFlexpwm4Pwm3OutTrig01 = 93|0x100U , kXBARA1_InputRESERVED94 = 94|0x100U , kXBARA1_InputRESERVED95 = 95|0x100U ,
  kXBARA1_InputRESERVED96 = 96|0x100U , kXBARA1_InputRESERVED97 = 97|0x100U , kXBARA1_InputRESERVED98 = 98|0x100U , kXBARA1_InputRESERVED99 = 99|0x100U ,
  kXBARA1_InputRESERVED100 = 100|0x100U , kXBARA1_InputRESERVED101 = 101|0x100U , kXBARA1_InputPit1Trigger0 = 102|0x100U , kXBARA1_InputPit1Trigger1 = 103|0x100U ,
  kXBARA1_InputPit1Trigger2 = 104|0x100U , kXBARA1_InputPit1Trigger3 = 105|0x100U , kXBARA1_InputDec1PosMatch = 106|0x100U , kXBARA1_InputDec2PosMatch = 107|0x100U ,
  kXBARA1_InputDec3PosMatch = 108|0x100U , kXBARA1_InputDec4PosMatch = 109|0x100U , kXBARA1_InputRESERVED110 = 110|0x100U , kXBARA1_InputRESERVED111 = 111|0x100U ,
  kXBARA1_InputDmaDone0 = 112|0x100U , kXBARA1_InputDmaDone1 = 113|0x100U , kXBARA1_InputDmaDone2 = 114|0x100U , kXBARA1_InputDmaDone3 = 115|0x100U ,
  kXBARA1_InputDmaDone4 = 116|0x100U , kXBARA1_InputDmaDone5 = 117|0x100U , kXBARA1_InputDmaDone6 = 118|0x100U , kXBARA1_InputDmaDone7 = 119|0x100U ,
  kXBARA1_InputDmaLpsrDone0 = 120|0x100U , kXBARA1_InputDmaLpsrDone1 = 121|0x100U , kXBARA1_InputDmaLpsrDone2 = 122|0x100U , kXBARA1_InputDmaLpsrDone3 = 123|0x100U ,
  kXBARA1_InputDmaLpsrDone4 = 124|0x100U , kXBARA1_InputDmaLpsrDone5 = 125|0x100U , kXBARA1_InputDmaLpsrDone6 = 126|0x100U , kXBARA1_InputDmaLpsrDone7 = 127|0x100U ,
  kXBARA1_InputAoi1Out0 = 128|0x100U , kXBARA1_InputAoi1Out1 = 129|0x100U , kXBARA1_InputAoi1Out2 = 130|0x100U , kXBARA1_InputAoi1Out3 = 131|0x100U ,
  kXBARA1_InputAoi2Out0 = 132|0x100U , kXBARA1_InputAoi2Out1 = 133|0x100U , kXBARA1_InputAoi2Out2 = 134|0x100U , kXBARA1_InputAoi2Out3 = 135|0x100U ,
  kXBARA1_InputAdcEtc0Coco0 = 136|0x100U , kXBARA1_InputAdcEtc0Coco1 = 137|0x100U , kXBARA1_InputAdcEtc0Coco2 = 138|0x100U , kXBARA1_InputAdcEtc0Coco3 = 139|0x100U ,
  kXBARA1_InputAdcEtc1Coco0 = 140|0x100U , kXBARA1_InputAdcEtc1Coco1 = 141|0x100U , kXBARA1_InputAdcEtc1Coco2 = 142|0x100U , kXBARA1_InputAdcEtc1Coco3 = 143|0x100U ,
  kXBARB2_InputLogicLow = 0|0x200U , kXBARB2_InputLogicHigh = 1|0x200U , kXBARB2_InputAcmp1Out = 2|0x200U , kXBARB2_InputAcmp2Out = 3|0x200U ,
  kXBARB2_InputAcmp3Out = 4|0x200U , kXBARB2_InputAcmp4Out = 5|0x200U , kXBARB2_InputRESERVED6 = 6|0x200U , kXBARB2_InputRESERVED7 = 7|0x200U ,
  kXBARB2_InputRESERVED8 = 8|0x200U , kXBARB2_InputRESERVED9 = 9|0x200U , kXBARB2_InputQtimer1Timer0 = 10|0x200U , kXBARB2_InputQtimer1Timer1 = 11|0x200U ,
  kXBARB2_InputQtimer1Timer2 = 12|0x200U , kXBARB2_InputQtimer1Timer3 = 13|0x200U , kXBARB2_InputQtimer2Timer0 = 14|0x200U , kXBARB2_InputQtimer2Timer1 = 15|0x200U ,
  kXBARB2_InputQtimer2Timer2 = 16|0x200U , kXBARB2_InputQtimer2Timer3 = 17|0x200U , kXBARB2_InputQtimer3Timer0 = 18|0x200U , kXBARB2_InputQtimer3Timer1 = 19|0x200U ,
  kXBARB2_InputQtimer3Timer2 = 20|0x200U , kXBARB2_InputQtimer3Timer3 = 21|0x200U , kXBARB2_InputQtimer4Timer0 = 22|0x200U , kXBARB2_InputQtimer4Timer1 = 23|0x200U ,
  kXBARB2_InputQtimer4Timer2 = 24|0x200U , kXBARB2_InputQtimer4Timer3 = 25|0x200U , kXBARB2_InputRESERVED26 = 26|0x200U , kXBARB2_InputRESERVED27 = 27|0x200U ,
  kXBARB2_InputRESERVED28 = 28|0x200U , kXBARB2_InputRESERVED29 = 29|0x200U , kXBARB2_InputRESERVED30 = 30|0x200U , kXBARB2_InputRESERVED31 = 31|0x200U ,
  kXBARB2_InputRESERVED32 = 32|0x200U , kXBARB2_InputRESERVED33 = 33|0x200U , kXBARB2_InputFlexpwm1Pwm0OutTrig01 = 34|0x200U , kXBARB2_InputFlexpwm1Pwm1OutTrig01 = 35|0x200U ,
  kXBARB2_InputFlexpwm1Pwm2OutTrig01 = 36|0x200U , kXBARB2_InputFlexpwm1Pwm3OutTrig01 = 37|0x200U , kXBARB2_InputFlexpwm2Pwm0OutTrig01 = 38|0x200U , kXBARB2_InputFlexpwm2Pwm1OutTrig01 = 39|0x200U ,
  kXBARB2_InputFlexpwm2Pwm2OutTrig01 = 40|0x200U , kXBARB2_InputFlexpwm2Pwm3OutTrig01 = 41|0x200U , kXBARB2_InputFlexpwm3Pwm0OutTrig01 = 42|0x200U , kXBARB2_InputFlexpwm3Pwm1OutTrig01 = 43|0x200U ,
  kXBARB2_InputFlexpwm3Pwm2OutTrig01 = 44|0x200U , kXBARB2_InputFlexpwm3Pwm3OutTrig01 = 45|0x200U , kXBARB2_InputFlexpwm4Pwm0OutTrig01 = 46|0x200U , kXBARB2_InputFlexpwm4Pwm1OutTrig01 = 47|0x200U ,
  kXBARB2_InputFlexpwm4Pwm2OutTrig01 = 48|0x200U , kXBARB2_InputFlexpwm4Pwm3OutTrig01 = 49|0x200U , kXBARB2_InputRESERVED50 = 50|0x200U , kXBARB2_InputRESERVED51 = 51|0x200U ,
  kXBARB2_InputRESERVED52 = 52|0x200U , kXBARB2_InputRESERVED53 = 53|0x200U , kXBARB2_InputRESERVED54 = 54|0x200U , kXBARB2_InputRESERVED55 = 55|0x200U ,
  kXBARB2_InputRESERVED56 = 56|0x200U , kXBARB2_InputRESERVED57 = 57|0x200U , kXBARB2_InputPit1Trigger0 = 58|0x200U , kXBARB2_InputPit1Trigger1 = 59|0x200U ,
  kXBARB2_InputAdcEtc0Coco0 = 60|0x200U , kXBARB2_InputAdcEtc0Coco1 = 61|0x200U , kXBARB2_InputAdcEtc0Coco2 = 62|0x200U , kXBARB2_InputAdcEtc0Coco3 = 63|0x200U ,
  kXBARB2_InputAdcEtc1Coco0 = 64|0x200U , kXBARB2_InputAdcEtc1Coco1 = 65|0x200U , kXBARB2_InputAdcEtc1Coco2 = 66|0x200U , kXBARB2_InputAdcEtc1Coco3 = 67|0x200U ,
  kXBARB2_InputRESERVED68 = 68|0x200U , kXBARB2_InputRESERVED69 = 69|0x200U , kXBARB2_InputRESERVED70 = 70|0x200U , kXBARB2_InputRESERVED71 = 71|0x200U ,
  kXBARB2_InputRESERVED72 = 72|0x200U , kXBARB2_InputRESERVED73 = 73|0x200U , kXBARB2_InputRESERVED74 = 74|0x200U , kXBARB2_InputRESERVED75 = 75|0x200U ,
  kXBARB2_InputDec1PosMatch = 76|0x200U , kXBARB2_InputDec2PosMatch = 77|0x200U , kXBARB2_InputDec3PosMatch = 78|0x200U , kXBARB2_InputDec4PosMatch = 79|0x200U ,
  kXBARB2_InputRESERVED80 = 80|0x200U , kXBARB2_InputRESERVED81 = 81|0x200U , kXBARB2_InputDmaDone0 = 82|0x200U , kXBARB2_InputDmaDone1 = 83|0x200U ,
  kXBARB2_InputDmaDone2 = 84|0x200U , kXBARB2_InputDmaDone3 = 85|0x200U , kXBARB2_InputDmaDone4 = 86|0x200U , kXBARB2_InputDmaDone5 = 87|0x200U ,
  kXBARB2_InputDmaDone6 = 88|0x200U , kXBARB2_InputDmaDone7 = 89|0x200U , kXBARB2_InputDmaLpsrDone0 = 90|0x200U , kXBARB2_InputDmaLpsrDone1 = 91|0x200U ,
  kXBARB2_InputDmaLpsrDone2 = 92|0x200U , kXBARB2_InputDmaLpsrDone3 = 93|0x200U , kXBARB2_InputDmaLpsrDone4 = 94|0x200U , kXBARB2_InputDmaLpsrDone5 = 95|0x200U ,
  kXBARB2_InputDmaLpsrDone6 = 96|0x200U , kXBARB2_InputDmaLpsrDone7 = 97|0x200U , kXBARB3_InputLogicLow = 0|0x300U , kXBARB3_InputLogicHigh = 1|0x300U ,
  kXBARB3_InputAcmp1Out = 2|0x300U , kXBARB3_InputAcmp2Out = 3|0x300U , kXBARB3_InputAcmp3Out = 4|0x300U , kXBARB3_InputAcmp4Out = 5|0x300U ,
  kXBARB3_InputRESERVED6 = 6|0x300U , kXBARB3_InputRESERVED7 = 7|0x300U , kXBARB3_InputRESERVED8 = 8|0x300U , kXBARB3_InputRESERVED9 = 9|0x300U ,
  kXBARB3_InputQtimer1Timer0 = 10|0x300U , kXBARB3_InputQtimer1Timer1 = 11|0x300U , kXBARB3_InputQtimer1Timer2 = 12|0x300U , kXBARB3_InputQtimer1Timer3 = 13|0x300U ,
  kXBARB3_InputQtimer2Timer0 = 14|0x300U , kXBARB3_InputQtimer2Timer1 = 15|0x300U , kXBARB3_InputQtimer2Timer2 = 16|0x300U , kXBARB3_InputQtimer2Timer3 = 17|0x300U ,
  kXBARB3_InputQtimer3Timer0 = 18|0x300U , kXBARB3_InputQtimer3Timer1 = 19|0x300U , kXBARB3_InputQtimer3Timer2 = 20|0x300U , kXBARB3_InputQtimer3Timer3 = 21|0x300U ,
  kXBARB3_InputQtimer4Timer0 = 22|0x300U , kXBARB3_InputQtimer4Timer1 = 23|0x300U , kXBARB3_InputQtimer4Timer2 = 24|0x300U , kXBARB3_InputQtimer4Timer3 = 25|0x300U ,
  kXBARB3_InputRESERVED26 = 26|0x300U , kXBARB3_InputRESERVED27 = 27|0x300U , kXBARB3_InputRESERVED28 = 28|0x300U , kXBARB3_InputRESERVED29 = 29|0x300U ,
  kXBARB3_InputRESERVED30 = 30|0x300U , kXBARB3_InputRESERVED31 = 31|0x300U , kXBARB3_InputRESERVED32 = 32|0x300U , kXBARB3_InputRESERVED33 = 33|0x300U ,
  kXBARB3_InputFlexpwm1Pwm0OutTrig01 = 34|0x300U , kXBARB3_InputFlexpwm1Pwm1OutTrig01 = 35|0x300U , kXBARB3_InputFlexpwm1Pwm2OutTrig01 = 36|0x300U , kXBARB3_InputFlexpwm1Pwm3OutTrig01 = 37|0x300U ,
  kXBARB3_InputFlexpwm2Pwm0OutTrig01 = 38|0x300U , kXBARB3_InputFlexpwm2Pwm1OutTrig01 = 39|0x300U , kXBARB3_InputFlexpwm2Pwm2OutTrig01 = 40|0x300U , kXBARB3_InputFlexpwm2Pwm3OutTrig01 = 41|0x300U ,
  kXBARB3_InputFlexpwm3Pwm0OutTrig01 = 42|0x300U , kXBARB3_InputFlexpwm3Pwm1OutTrig01 = 43|0x300U , kXBARB3_InputFlexpwm3Pwm2OutTrig01 = 44|0x300U , kXBARB3_InputFlexpwm3Pwm3OutTrig01 = 45|0x300U ,
  kXBARB3_InputFlexpwm4Pwm0OutTrig01 = 46|0x300U , kXBARB3_InputFlexpwm4Pwm1OutTrig01 = 47|0x300U , kXBARB3_InputFlexpwm4Pwm2OutTrig01 = 48|0x300U , kXBARB3_InputFlexpwm4Pwm3OutTrig01 = 49|0x300U ,
  kXBARB3_InputRESERVED50 = 50|0x300U , kXBARB3_InputRESERVED51 = 51|0x300U , kXBARB3_InputRESERVED52 = 52|0x300U , kXBARB3_InputRESERVED53 = 53|0x300U ,
  kXBARB3_InputRESERVED54 = 54|0x300U , kXBARB3_InputRESERVED55 = 55|0x300U , kXBARB3_InputRESERVED56 = 56|0x300U , kXBARB3_InputRESERVED57 = 57|0x300U ,
  kXBARB3_InputPit1Trigger0 = 58|0x300U , kXBARB3_InputPit1Trigger1 = 59|0x300U , kXBARB3_InputAdcEtc0Coco0 = 60|0x300U , kXBARB3_InputAdcEtc0Coco1 = 61|0x300U ,
  kXBARB3_InputAdcEtc0Coco2 = 62|0x300U , kXBARB3_InputAdcEtc0Coco3 = 63|0x300U , kXBARB3_InputAdcEtc1Coco0 = 64|0x300U , kXBARB3_InputAdcEtc1Coco1 = 65|0x300U ,
  kXBARB3_InputAdcEtc1Coco2 = 66|0x300U , kXBARB3_InputAdcEtc1Coco3 = 67|0x300U , kXBARB3_InputRESERVED68 = 68|0x300U , kXBARB3_InputRESERVED69 = 69|0x300U ,
  kXBARB3_InputRESERVED70 = 70|0x300U , kXBARB3_InputRESERVED71 = 71|0x300U , kXBARB3_InputRESERVED72 = 72|0x300U , kXBARB3_InputRESERVED73 = 73|0x300U ,
  kXBARB3_InputRESERVED74 = 74|0x300U , kXBARB3_InputRESERVED75 = 75|0x300U , kXBARB3_InputDec1PosMatch = 76|0x300U , kXBARB3_InputDec2PosMatch = 77|0x300U ,
  kXBARB3_InputDec3PosMatch = 78|0x300U , kXBARB3_InputDec4PosMatch = 79|0x300U , kXBARB3_InputRESERVED80 = 80|0x300U , kXBARB3_InputRESERVED81 = 81|0x300U ,
  kXBARB3_InputDmaDone0 = 82|0x300U , kXBARB3_InputDmaDone1 = 83|0x300U , kXBARB3_InputDmaDone2 = 84|0x300U , kXBARB3_InputDmaDone3 = 85|0x300U ,
  kXBARB3_InputDmaDone4 = 86|0x300U , kXBARB3_InputDmaDone5 = 87|0x300U , kXBARB3_InputDmaDone6 = 88|0x300U , kXBARB3_InputDmaDone7 = 89|0x300U ,
  kXBARB3_InputDmaLpsrDone0 = 90|0x300U , kXBARB3_InputDmaLpsrDone1 = 91|0x300U , kXBARB3_InputDmaLpsrDone2 = 92|0x300U , kXBARB3_InputDmaLpsrDone3 = 93|0x300U ,
  kXBARB3_InputDmaLpsrDone4 = 94|0x300U , kXBARB3_InputDmaLpsrDone5 = 95|0x300U , kXBARB3_InputDmaLpsrDone6 = 96|0x300U , kXBARB3_InputDmaLpsrDone7 = 97|0x300U ,
enum  _xbar_output_signal {
  kXBARA1_OutputDmaChMuxReq30 = 0|0x100U , kXBARA1_OutputDmaChMuxReq31 = 1|0x100U , kXBARA1_OutputDmaChMuxReq94 = 2|0x100U , kXBARA1_OutputDmaChMuxReq95 = 3|0x100U ,
  kXBARA1_OutputIomuxXbarInout04 = 4|0x100U , kXBARA1_OutputIomuxXbarInout05 = 5|0x100U , kXBARA1_OutputIomuxXbarInout06 = 6|0x100U , kXBARA1_OutputIomuxXbarInout07 = 7|0x100U ,
  kXBARA1_OutputIomuxXbarInout08 = 8|0x100U , kXBARA1_OutputIomuxXbarInout09 = 9|0x100U , kXBARA1_OutputIomuxXbarInout10 = 10|0x100U , kXBARA1_OutputIomuxXbarInout11 = 11|0x100U ,
  kXBARA1_OutputIomuxXbarInout12 = 12|0x100U , kXBARA1_OutputIomuxXbarInout13 = 13|0x100U , kXBARA1_OutputIomuxXbarInout14 = 14|0x100U , kXBARA1_OutputIomuxXbarInout15 = 15|0x100U ,
  kXBARA1_OutputIomuxXbarInout16 = 16|0x100U , kXBARA1_OutputIomuxXbarInout17 = 17|0x100U , kXBARA1_OutputIomuxXbarInout18 = 18|0x100U , kXBARA1_OutputIomuxXbarInout19 = 19|0x100U ,
  kXBARA1_OutputAcmp1Sample = 20|0x100U , kXBARA1_OutputAcmp2Sample = 21|0x100U , kXBARA1_OutputAcmp3Sample = 22|0x100U , kXBARA1_OutputAcmp4Sample = 23|0x100U ,
  kXBARA1_OutputRESERVED24 = 24|0x100U , kXBARA1_OutputRESERVED25 = 25|0x100U , kXBARA1_OutputFlexpwm1Exta0 = 26|0x100U , kXBARA1_OutputFlexpwm1Exta1 = 27|0x100U ,
  kXBARA1_OutputFlexpwm1Exta2 = 28|0x100U , kXBARA1_OutputFlexpwm1Exta3 = 29|0x100U , kXBARA1_OutputFlexpwm1ExtSync0 = 30|0x100U , kXBARA1_OutputFlexpwm1ExtSync1 = 31|0x100U ,
  kXBARA1_OutputFlexpwm1ExtSync2 = 32|0x100U , kXBARA1_OutputFlexpwm1ExtSync3 = 33|0x100U , kXBARA1_OutputFlexpwm1ExtClk = 34|0x100U , kXBARA1_OutputFlexpwm1Fault0 = 35|0x100U ,
  kXBARA1_OutputFlexpwm1Fault1 = 36|0x100U , kXBARA1_OutputFlexpwm1234Fault2 = 37|0x100U , kXBARA1_OutputFlexpwm1234Fault3 = 38|0x100U , kXBARA1_OutputFlexpwm1ExtForce = 39|0x100U ,
  kXBARA1_OutputFlexpwm234Exta0 = 40|0x100U , kXBARA1_OutputFlexpwm234Exta1 = 41|0x100U , kXBARA1_OutputFlexpwm234Exta2 = 42|0x100U , kXBARA1_OutputFlexpwm234Exta3 = 43|0x100U ,
  kXBARA1_OutputFlexpwm2ExtSync0 = 44|0x100U , kXBARA1_OutputFlexpwm2ExtSync1 = 45|0x100U , kXBARA1_OutputFlexpwm2ExtSync2 = 46|0x100U , kXBARA1_OutputFlexpwm2ExtSync3 = 47|0x100U ,
  kXBARA1_OutputFlexpwm234ExtClk = 48|0x100U , kXBARA1_OutputFlexpwm2Fault0 = 49|0x100U , kXBARA1_OutputFlexpwm2Fault1 = 50|0x100U , kXBARA1_OutputFlexpwm2ExtForce = 51|0x100U ,
  kXBARA1_OutputFlexpwm3ExtSync0 = 52|0x100U , kXBARA1_OutputFlexpwm3ExtSync1 = 53|0x100U , kXBARA1_OutputFlexpwm3ExtSync2 = 54|0x100U , kXBARA1_OutputFlexpwm3ExtSync3 = 55|0x100U ,
  kXBARA1_OutputFlexpwm3Fault0 = 56|0x100U , kXBARA1_OutputFlexpwm3Fault1 = 57|0x100U , kXBARA1_OutputFlexpwm3ExtForce = 58|0x100U , kXBARA1_OutputFlexpwm4ExtSync0 = 59|0x100U ,
  kXBARA1_OutputFlexpwm4ExtSync1 = 60|0x100U , kXBARA1_OutputFlexpwm4ExtSync2 = 61|0x100U , kXBARA1_OutputFlexpwm4ExtSync3 = 62|0x100U , kXBARA1_OutputFlexpwm4Fault0 = 63|0x100U ,
  kXBARA1_OutputFlexpwm4Fault1 = 64|0x100U , kXBARA1_OutputFlexpwm4ExtForce = 65|0x100U , kXBARA1_OutputEnc1PhaseAInput = 66|0x100U , kXBARA1_OutputEnc1PhaseBInput = 67|0x100U ,
  kXBARA1_OutputEnc1Index = 68|0x100U , kXBARA1_OutputEnc1Home = 69|0x100U , kXBARA1_OutputEnc1Trigger = 70|0x100U , kXBARA1_OutputEnc2PhaseAInput = 71|0x100U ,
  kXBARA1_OutputEnc2PhaseBInput = 72|0x100U , kXBARA1_OutputEnc2Index = 73|0x100U , kXBARA1_OutputEnc2Home = 74|0x100U , kXBARA1_OutputEnc2Trigger = 75|0x100U ,
  kXBARA1_OutputEnc3PhaseAInput = 76|0x100U , kXBARA1_OutputEnc3PhaseBInput = 77|0x100U , kXBARA1_OutputEnc3Index = 78|0x100U , kXBARA1_OutputEnc3Home = 79|0x100U ,
  kXBARA1_OutputEnc3Trigger = 80|0x100U , kXBARA1_OutputEnc4PhaseAInput = 81|0x100U , kXBARA1_OutputEnc4PhaseBInput = 82|0x100U , kXBARA1_OutputEnc4Index = 83|0x100U ,
  kXBARA1_OutputEnc4Home = 84|0x100U , kXBARA1_OutputEnc4Trigger = 85|0x100U , kXBARA1_OutputQtimer1Tmr0Input = 86|0x100U , kXBARA1_OutputQtimer1Tmr1Input = 87|0x100U ,
  kXBARA1_OutputQtimer1Tmr2Input = 88|0x100U , kXBARA1_OutputQtimer1Tmr3Input = 89|0x100U , kXBARA1_OutputQtimer2Tmr0Input = 90|0x100U , kXBARA1_OutputQtimer2Tmr1Input = 91|0x100U ,
  kXBARA1_OutputQtimer2Tmr2Input = 92|0x100U , kXBARA1_OutputQtimer2Tmr3Input = 93|0x100U , kXBARA1_OutputQtimer3Tmr0Input = 94|0x100U , kXBARA1_OutputQtimer3Tmr1Input = 95|0x100U ,
  kXBARA1_OutputQtimer3Tmr2Input = 96|0x100U , kXBARA1_OutputQtimer3Tmr3Input = 97|0x100U , kXBARA1_OutputQtimer4Tmr0Input = 98|0x100U , kXBARA1_OutputQtimer4Tmr1Input = 99|0x100U ,
  kXBARA1_OutputQtimer4Tmr2Input = 100|0x100U , kXBARA1_OutputQtimer4Tmr3Input = 101|0x100U , kXBARA1_OutputEwmEwmIn = 102|0x100U , kXBARA1_OutputAdcEtcXbar0Trig0 = 103|0x100U ,
  kXBARA1_OutputAdcEtcXbar0Trig1 = 104|0x100U , kXBARA1_OutputAdcEtcXbar0Trig2 = 105|0x100U , kXBARA1_OutputAdcEtcXbar0Trig3 = 106|0x100U , kXBARA1_OutputAdcEtcXbar1Trig0 = 107|0x100U ,
  kXBARA1_OutputAdcEtcXbar1Trig1 = 108|0x100U , kXBARA1_OutputAdcEtcXbar1Trig2 = 109|0x100U , kXBARA1_OutputAdcEtcXbar1Trig3 = 110|0x100U , kXBARA1_OutputLpi2c1TrgInput = 111|0x100U ,
  kXBARA1_OutputLpi2c2TrgInput = 112|0x100U , kXBARA1_OutputLpi2c3TrgInput = 113|0x100U , kXBARA1_OutputLpi2c4TrgInput = 114|0x100U , kXBARA1_OutputLpspi1TrgInput = 115|0x100U ,
  kXBARA1_OutputLpspi2TrgInput = 116|0x100U , kXBARA1_OutputLpspi3TrgInput = 117|0x100U , kXBARA1_OutputLpspi4TrgInput = 118|0x100U , kXBARA1_OutputLpuart1TrgInput = 119|0x100U ,
  kXBARA1_OutputLpuart2TrgInput = 120|0x100U , kXBARA1_OutputLpuart3TrgInput = 121|0x100U , kXBARA1_OutputLpuart4TrgInput = 122|0x100U , kXBARA1_OutputLpuart5TrgInput = 123|0x100U ,
  kXBARA1_OutputLpuart6TrgInput = 124|0x100U , kXBARA1_OutputLpuart7TrgInput = 125|0x100U , kXBARA1_OutputLpuart8TrgInput = 126|0x100U , kXBARA1_OutputFlexio1TriggerIn0 = 127|0x100U ,
  kXBARA1_OutputFlexio1TriggerIn1 = 128|0x100U , kXBARA1_OutputFlexio2TriggerIn0 = 129|0x100U , kXBARA1_OutputFlexio2TriggerIn1 = 130|0x100U , kXBARB2_OutputAoi1In00 = 0|0x200U ,
  kXBARB2_OutputAoi1In01 = 1|0x200U , kXBARB2_OutputAoi1In02 = 2|0x200U , kXBARB2_OutputAoi1In03 = 3|0x200U , kXBARB2_OutputAoi1In04 = 4|0x200U ,
  kXBARB2_OutputAoi1In05 = 5|0x200U , kXBARB2_OutputAoi1In06 = 6|0x200U , kXBARB2_OutputAoi1In07 = 7|0x200U , kXBARB2_OutputAoi1In08 = 8|0x200U ,
  kXBARB2_OutputAoi1In09 = 9|0x200U , kXBARB2_OutputAoi1In10 = 10|0x200U , kXBARB2_OutputAoi1In11 = 11|0x200U , kXBARB2_OutputAoi1In12 = 12|0x200U ,
  kXBARB2_OutputAoi1In13 = 13|0x200U , kXBARB2_OutputAoi1In14 = 14|0x200U , kXBARB2_OutputAoi1In15 = 15|0x200U , kXBARB3_OutputAoi2In00 = 0|0x300U ,
  kXBARB3_OutputAoi2In01 = 1|0x300U , kXBARB3_OutputAoi2In02 = 2|0x300U , kXBARB3_OutputAoi2In03 = 3|0x300U , kXBARB3_OutputAoi2In04 = 4|0x300U ,
  kXBARB3_OutputAoi2In05 = 5|0x300U , kXBARB3_OutputAoi2In06 = 6|0x300U , kXBARB3_OutputAoi2In07 = 7|0x300U , kXBARB3_OutputAoi2In08 = 8|0x300U ,
  kXBARB3_OutputAoi2In09 = 9|0x300U , kXBARB3_OutputAoi2In10 = 10|0x300U , kXBARB3_OutputAoi2In11 = 11|0x300U , kXBARB3_OutputAoi2In12 = 12|0x300U ,
  kXBARB3_OutputAoi2In13 = 13|0x300U , kXBARB3_OutputAoi2In14 = 14|0x300U , kXBARB3_OutputAoi2In15 = 15|0x300U , kXBARA1_OutputDmaChMuxReq81 = 0|0x100U ,
  kXBARA1_OutputDmaChMuxReq82 = 1|0x100U , kXBARA1_OutputDmaChMuxReq83 = 2|0x100U , kXBARA1_OutputDmaChMuxReq84 = 3|0x100U , kXBARA1_OutputIomuxXbarInout04 = 4|0x100U ,
  kXBARA1_OutputIomuxXbarInout05 = 5|0x100U , kXBARA1_OutputIomuxXbarInout06 = 6|0x100U , kXBARA1_OutputIomuxXbarInout07 = 7|0x100U , kXBARA1_OutputIomuxXbarInout08 = 8|0x100U ,
  kXBARA1_OutputIomuxXbarInout09 = 9|0x100U , kXBARA1_OutputIomuxXbarInout10 = 10|0x100U , kXBARA1_OutputIomuxXbarInout11 = 11|0x100U , kXBARA1_OutputIomuxXbarInout12 = 12|0x100U ,
  kXBARA1_OutputIomuxXbarInout13 = 13|0x100U , kXBARA1_OutputIomuxXbarInout14 = 14|0x100U , kXBARA1_OutputIomuxXbarInout15 = 15|0x100U , kXBARA1_OutputIomuxXbarInout16 = 16|0x100U ,
  kXBARA1_OutputIomuxXbarInout17 = 17|0x100U , kXBARA1_OutputIomuxXbarInout18 = 18|0x100U , kXBARA1_OutputIomuxXbarInout19 = 19|0x100U , kXBARA1_OutputIomuxXbarInout20 = 20|0x100U ,
  kXBARA1_OutputIomuxXbarInout21 = 21|0x100U , kXBARA1_OutputIomuxXbarInout22 = 22|0x100U , kXBARA1_OutputIomuxXbarInout23 = 23|0x100U , kXBARA1_OutputIomuxXbarInout24 = 24|0x100U ,
  kXBARA1_OutputIomuxXbarInout25 = 25|0x100U , kXBARA1_OutputIomuxXbarInout26 = 26|0x100U , kXBARA1_OutputIomuxXbarInout27 = 27|0x100U , kXBARA1_OutputIomuxXbarInout28 = 28|0x100U ,
  kXBARA1_OutputIomuxXbarInout29 = 29|0x100U , kXBARA1_OutputIomuxXbarInout30 = 30|0x100U , kXBARA1_OutputIomuxXbarInout31 = 31|0x100U , kXBARA1_OutputIomuxXbarInout32 = 32|0x100U ,
  kXBARA1_OutputIomuxXbarInout33 = 33|0x100U , kXBARA1_OutputIomuxXbarInout34 = 34|0x100U , kXBARA1_OutputIomuxXbarInout35 = 35|0x100U , kXBARA1_OutputIomuxXbarInout36 = 36|0x100U ,
  kXBARA1_OutputIomuxXbarInout37 = 37|0x100U , kXBARA1_OutputIomuxXbarInout38 = 38|0x100U , kXBARA1_OutputIomuxXbarInout39 = 39|0x100U , kXBARA1_OutputIomuxXbarInout40 = 40|0x100U ,
  kXBARA1_OutputAcmp1Sample = 41|0x100U , kXBARA1_OutputAcmp2Sample = 42|0x100U , kXBARA1_OutputAcmp3Sample = 43|0x100U , kXBARA1_OutputAcmp4Sample = 44|0x100U ,
  kXBARA1_OutputRESERVED45 = 45|0x100U , kXBARA1_OutputRESERVED46 = 46|0x100U , kXBARA1_OutputRESERVED47 = 47|0x100U , kXBARA1_OutputRESERVED48 = 48|0x100U ,
  kXBARA1_OutputFlexpwm1Pwm0Exta = 49|0x100U , kXBARA1_OutputFlexpwm1Pwm1Exta = 50|0x100U , kXBARA1_OutputFlexpwm1Pwm2Exta = 51|0x100U , kXBARA1_OutputFlexpwm1Pwm3Exta = 52|0x100U ,
  kXBARA1_OutputFlexpwm1Pwm0ExtSync = 53|0x100U , kXBARA1_OutputFlexpwm1Pwm1ExtSync = 54|0x100U , kXBARA1_OutputFlexpwm1Pwm2ExtSync = 55|0x100U , kXBARA1_OutputFlexpwm1Pwm3ExtSync = 56|0x100U ,
  kXBARA1_OutputFlexpwm1ExtClk = 57|0x100U , kXBARA1_OutputFlexpwm1Fault0 = 58|0x100U , kXBARA1_OutputFlexpwm1Fault1 = 59|0x100U , kXBARA1_OutputFlexpwm1234Fault2 = 60|0x100U ,
  kXBARA1_OutputFlexpwm1234Fault3 = 61|0x100U , kXBARA1_OutputFlexpwm1ExtForce = 62|0x100U , kXBARA1_OutputFlexpwm2Pwm0Exta = 63|0x100U , kXBARA1_OutputFlexpwm2Pwm1Exta = 64|0x100U ,
  kXBARA1_OutputFlexpwm2Pwm2Exta = 65|0x100U , kXBARA1_OutputFlexpwm2Pwm3Exta = 66|0x100U , kXBARA1_OutputFlexpwm2Pwm0ExtSync = 67|0x100U , kXBARA1_OutputFlexpwm2Pwm1ExtSync = 68|0x100U ,
  kXBARA1_OutputFlexpwm2Pwm2ExtSync = 69|0x100U , kXBARA1_OutputFlexpwm2Pwm3ExtSync = 70|0x100U , kXBARA1_OutputFlexpwm2ExtClk = 71|0x100U , kXBARA1_OutputFlexpwm2Fault0 = 72|0x100U ,
  kXBARA1_OutputFlexpwm2Fault1 = 73|0x100U , kXBARA1_OutputFlexpwm2ExtForce = 74|0x100U , kXBARA1_OutputFlexpwm34Pwm0Exta = 75|0x100U , kXBARA1_OutputFlexpwm34Pwm1Exta = 76|0x100U ,
  kXBARA1_OutputFlexpwm34Pwm2Exta = 77|0x100U , kXBARA1_OutputFlexpwm34Pwm3Exta = 78|0x100U , kXBARA1_OutputFlexpwm34ExtClk = 79|0x100U , kXBARA1_OutputFlexpwm3Pwm0ExtSync = 80|0x100U ,
  kXBARA1_OutputFlexpwm3Pwm1ExtSync = 81|0x100U , kXBARA1_OutputFlexpwm3Pwm2ExtSync = 82|0x100U , kXBARA1_OutputFlexpwm3Pwm3ExtSync = 83|0x100U , kXBARA1_OutputFlexpwm3Fault0 = 84|0x100U ,
  kXBARA1_OutputFlexpwm3Fault1 = 85|0x100U , kXBARA1_OutputFlexpwm3ExtForce = 86|0x100U , kXBARA1_OutputFlexpwm4Pwm0ExtSync = 87|0x100U , kXBARA1_OutputFlexpwm4Pwm1ExtSync = 88|0x100U ,
  kXBARA1_OutputFlexpwm4Pwm2ExtSync = 89|0x100U , kXBARA1_OutputFlexpwm4Pwm3ExtSync = 90|0x100U , kXBARA1_OutputFlexpwm4Fault0 = 91|0x100U , kXBARA1_OutputFlexpwm4Fault1 = 92|0x100U ,
  kXBARA1_OutputFlexpwm4ExtForce = 93|0x100U , kXBARA1_OutputRESERVED94 = 94|0x100U , kXBARA1_OutputRESERVED95 = 95|0x100U , kXBARA1_OutputRESERVED96 = 96|0x100U ,
  kXBARA1_OutputRESERVED97 = 97|0x100U , kXBARA1_OutputRESERVED98 = 98|0x100U , kXBARA1_OutputRESERVED99 = 99|0x100U , kXBARA1_OutputRESERVED100 = 100|0x100U ,
  kXBARA1_OutputRESERVED101 = 101|0x100U , kXBARA1_OutputRESERVED102 = 102|0x100U , kXBARA1_OutputRESERVED103 = 103|0x100U , kXBARA1_OutputRESERVED104 = 104|0x100U ,
  kXBARA1_OutputRESERVED105 = 105|0x100U , kXBARA1_OutputRESERVED106 = 106|0x100U , kXBARA1_OutputRESERVED107 = 107|0x100U , kXBARA1_OutputDec1Phasea = 108|0x100U ,
  kXBARA1_OutputDec1Phaseb = 109|0x100U , kXBARA1_OutputDec1Index = 110|0x100U , kXBARA1_OutputDec1Home = 111|0x100U , kXBARA1_OutputDec1Trigger = 112|0x100U ,
  kXBARA1_OutputDec2Phasea = 113|0x100U , kXBARA1_OutputDec2Phaseb = 114|0x100U , kXBARA1_OutputDec2Index = 115|0x100U , kXBARA1_OutputDec2Home = 116|0x100U ,
  kXBARA1_OutputDec2Trigger = 117|0x100U , kXBARA1_OutputDec3Phasea = 118|0x100U , kXBARA1_OutputDec3Phaseb = 119|0x100U , kXBARA1_OutputDec3Index = 120|0x100U ,
  kXBARA1_OutputDec3Home = 121|0x100U , kXBARA1_OutputDec3Trigger = 122|0x100U , kXBARA1_OutputDec4Phasea = 123|0x100U , kXBARA1_OutputDec4Phaseb = 124|0x100U ,
  kXBARA1_OutputDec4Index = 125|0x100U , kXBARA1_OutputDec4Home = 126|0x100U , kXBARA1_OutputDec4Trigger = 127|0x100U , kXBARA1_OutputRESERVED128 = 128|0x100U ,
  kXBARA1_OutputRESERVED129 = 129|0x100U , kXBARA1_OutputRESERVED130 = 130|0x100U , kXBARA1_OutputRESERVED131 = 131|0x100U , kXBARA1_OutputCan1 = 132|0x100U ,
  kXBARA1_OutputCan2 = 133|0x100U , kXBARA1_OutputRESERVED134 = 134|0x100U , kXBARA1_OutputRESERVED135 = 135|0x100U , kXBARA1_OutputRESERVED136 = 136|0x100U ,
  kXBARA1_OutputRESERVED137 = 137|0x100U , kXBARA1_OutputQtimer1Timer0 = 138|0x100U , kXBARA1_OutputQtimer1Timer1 = 139|0x100U , kXBARA1_OutputQtimer1Timer2 = 140|0x100U ,
  kXBARA1_OutputQtimer1Timer3 = 141|0x100U , kXBARA1_OutputQtimer2Timer0 = 142|0x100U , kXBARA1_OutputQtimer2Timer1 = 143|0x100U , kXBARA1_OutputQtimer2Timer2 = 144|0x100U ,
  kXBARA1_OutputQtimer2Timer3 = 145|0x100U , kXBARA1_OutputQtimer3Timer0 = 146|0x100U , kXBARA1_OutputQtimer3Timer1 = 147|0x100U , kXBARA1_OutputQtimer3Timer2 = 148|0x100U ,
  kXBARA1_OutputQtimer3Timer3 = 149|0x100U , kXBARA1_OutputQtimer4Timer0 = 150|0x100U , kXBARA1_OutputQtimer4Timer1 = 151|0x100U , kXBARA1_OutputQtimer4Timer2 = 152|0x100U ,
  kXBARA1_OutputQtimer4Timer3 = 153|0x100U , kXBARA1_OutputEwmEwmIn = 154|0x100U , kXBARA1_OutputAdcEtc0Coco0 = 155|0x100U , kXBARA1_OutputAdcEtc0Coco1 = 156|0x100U ,
  kXBARA1_OutputAdcEtc0Coco2 = 157|0x100U , kXBARA1_OutputAdcEtc0Coco3 = 158|0x100U , kXBARA1_OutputAdcEtc1Coco0 = 159|0x100U , kXBARA1_OutputAdcEtc1Coco1 = 160|0x100U ,
  kXBARA1_OutputAdcEtc1Coco2 = 161|0x100U , kXBARA1_OutputAdcEtc1Coco3 = 162|0x100U , kXBARA1_OutputRESERVED163 = 163|0x100U , kXBARA1_OutputRESERVED164 = 164|0x100U ,
  kXBARA1_OutputRESERVED165 = 165|0x100U , kXBARA1_OutputRESERVED166 = 166|0x100U , kXBARA1_OutputRESERVED167 = 167|0x100U , kXBARA1_OutputRESERVED168 = 168|0x100U ,
  kXBARA1_OutputRESERVED169 = 169|0x100U , kXBARA1_OutputRESERVED170 = 170|0x100U , kXBARA1_OutputFlexio1TrigIn0 = 171|0x100U , kXBARA1_OutputFlexio1TrigIn1 = 172|0x100U ,
  kXBARA1_OutputFlexio2TrigIn0 = 173|0x100U , kXBARA1_OutputFlexio2TrigIn1 = 174|0x100U , kXBARB2_OutputAoi1In00 = 0|0x200U , kXBARB2_OutputAoi1In01 = 1|0x200U ,
  kXBARB2_OutputAoi1In02 = 2|0x200U , kXBARB2_OutputAoi1In03 = 3|0x200U , kXBARB2_OutputAoi1In04 = 4|0x200U , kXBARB2_OutputAoi1In05 = 5|0x200U ,
  kXBARB2_OutputAoi1In06 = 6|0x200U , kXBARB2_OutputAoi1In07 = 7|0x200U , kXBARB2_OutputAoi1In08 = 8|0x200U , kXBARB2_OutputAoi1In09 = 9|0x200U ,
  kXBARB2_OutputAoi1In10 = 10|0x200U , kXBARB2_OutputAoi1In11 = 11|0x200U , kXBARB2_OutputAoi1In12 = 12|0x200U , kXBARB2_OutputAoi1In13 = 13|0x200U ,
  kXBARB2_OutputAoi1In14 = 14|0x200U , kXBARB2_OutputAoi1In15 = 15|0x200U , kXBARB3_OutputAoi2In00 = 0|0x300U , kXBARB3_OutputAoi2In01 = 1|0x300U ,
  kXBARB3_OutputAoi2In02 = 2|0x300U , kXBARB3_OutputAoi2In03 = 3|0x300U , kXBARB3_OutputAoi2In04 = 4|0x300U , kXBARB3_OutputAoi2In05 = 5|0x300U ,
  kXBARB3_OutputAoi2In06 = 6|0x300U , kXBARB3_OutputAoi2In07 = 7|0x300U , kXBARB3_OutputAoi2In08 = 8|0x300U , kXBARB3_OutputAoi2In09 = 9|0x300U ,
  kXBARB3_OutputAoi2In10 = 10|0x300U , kXBARB3_OutputAoi2In11 = 11|0x300U , kXBARB3_OutputAoi2In12 = 12|0x300U , kXBARB3_OutputAoi2In13 = 13|0x300U ,
  kXBARB3_OutputAoi2In14 = 14|0x300U , kXBARB3_OutputAoi2In15 = 15|0x300U , kXBARA1_OutputDmaChMuxReq81 = 0|0x100U , kXBARA1_OutputDmaChMuxReq82 = 1|0x100U ,
  kXBARA1_OutputDmaChMuxReq83 = 2|0x100U , kXBARA1_OutputDmaChMuxReq84 = 3|0x100U , kXBARA1_OutputIomuxXbarInout04 = 4|0x100U , kXBARA1_OutputIomuxXbarInout05 = 5|0x100U ,
  kXBARA1_OutputIomuxXbarInout06 = 6|0x100U , kXBARA1_OutputIomuxXbarInout07 = 7|0x100U , kXBARA1_OutputIomuxXbarInout08 = 8|0x100U , kXBARA1_OutputIomuxXbarInout09 = 9|0x100U ,
  kXBARA1_OutputIomuxXbarInout10 = 10|0x100U , kXBARA1_OutputIomuxXbarInout11 = 11|0x100U , kXBARA1_OutputIomuxXbarInout12 = 12|0x100U , kXBARA1_OutputIomuxXbarInout13 = 13|0x100U ,
  kXBARA1_OutputIomuxXbarInout14 = 14|0x100U , kXBARA1_OutputIomuxXbarInout15 = 15|0x100U , kXBARA1_OutputIomuxXbarInout16 = 16|0x100U , kXBARA1_OutputIomuxXbarInout17 = 17|0x100U ,
  kXBARA1_OutputIomuxXbarInout18 = 18|0x100U , kXBARA1_OutputIomuxXbarInout19 = 19|0x100U , kXBARA1_OutputIomuxXbarInout20 = 20|0x100U , kXBARA1_OutputIomuxXbarInout21 = 21|0x100U ,
  kXBARA1_OutputIomuxXbarInout22 = 22|0x100U , kXBARA1_OutputIomuxXbarInout23 = 23|0x100U , kXBARA1_OutputIomuxXbarInout24 = 24|0x100U , kXBARA1_OutputIomuxXbarInout25 = 25|0x100U ,
  kXBARA1_OutputIomuxXbarInout26 = 26|0x100U , kXBARA1_OutputIomuxXbarInout27 = 27|0x100U , kXBARA1_OutputIomuxXbarInout28 = 28|0x100U , kXBARA1_OutputIomuxXbarInout29 = 29|0x100U ,
  kXBARA1_OutputIomuxXbarInout30 = 30|0x100U , kXBARA1_OutputIomuxXbarInout31 = 31|0x100U , kXBARA1_OutputIomuxXbarInout32 = 32|0x100U , kXBARA1_OutputIomuxXbarInout33 = 33|0x100U ,
  kXBARA1_OutputIomuxXbarInout34 = 34|0x100U , kXBARA1_OutputIomuxXbarInout35 = 35|0x100U , kXBARA1_OutputIomuxXbarInout36 = 36|0x100U , kXBARA1_OutputIomuxXbarInout37 = 37|0x100U ,
  kXBARA1_OutputIomuxXbarInout38 = 38|0x100U , kXBARA1_OutputIomuxXbarInout39 = 39|0x100U , kXBARA1_OutputIomuxXbarInout40 = 40|0x100U , kXBARA1_OutputAcmp1Sample = 41|0x100U ,
  kXBARA1_OutputAcmp2Sample = 42|0x100U , kXBARA1_OutputAcmp3Sample = 43|0x100U , kXBARA1_OutputAcmp4Sample = 44|0x100U , kXBARA1_OutputRESERVED45 = 45|0x100U ,
  kXBARA1_OutputRESERVED46 = 46|0x100U , kXBARA1_OutputRESERVED47 = 47|0x100U , kXBARA1_OutputRESERVED48 = 48|0x100U , kXBARA1_OutputFlexpwm1Pwm0Exta = 49|0x100U ,
  kXBARA1_OutputFlexpwm1Pwm1Exta = 50|0x100U , kXBARA1_OutputFlexpwm1Pwm2Exta = 51|0x100U , kXBARA1_OutputFlexpwm1Pwm3Exta = 52|0x100U , kXBARA1_OutputFlexpwm1Pwm0ExtSync = 53|0x100U ,
  kXBARA1_OutputFlexpwm1Pwm1ExtSync = 54|0x100U , kXBARA1_OutputFlexpwm1Pwm2ExtSync = 55|0x100U , kXBARA1_OutputFlexpwm1Pwm3ExtSync = 56|0x100U , kXBARA1_OutputFlexpwm1ExtClk = 57|0x100U ,
  kXBARA1_OutputFlexpwm1Fault0 = 58|0x100U , kXBARA1_OutputFlexpwm1Fault1 = 59|0x100U , kXBARA1_OutputFlexpwm1234Fault2 = 60|0x100U , kXBARA1_OutputFlexpwm1234Fault3 = 61|0x100U ,
  kXBARA1_OutputFlexpwm1ExtForce = 62|0x100U , kXBARA1_OutputFlexpwm2Pwm0Exta = 63|0x100U , kXBARA1_OutputFlexpwm2Pwm1Exta = 64|0x100U , kXBARA1_OutputFlexpwm2Pwm2Exta = 65|0x100U ,
  kXBARA1_OutputFlexpwm2Pwm3Exta = 66|0x100U , kXBARA1_OutputFlexpwm2Pwm0ExtSync = 67|0x100U , kXBARA1_OutputFlexpwm2Pwm1ExtSync = 68|0x100U , kXBARA1_OutputFlexpwm2Pwm2ExtSync = 69|0x100U ,
  kXBARA1_OutputFlexpwm2Pwm3ExtSync = 70|0x100U , kXBARA1_OutputFlexpwm2ExtClk = 71|0x100U , kXBARA1_OutputFlexpwm2Fault0 = 72|0x100U , kXBARA1_OutputFlexpwm2Fault1 = 73|0x100U ,
  kXBARA1_OutputFlexpwm2ExtForce = 74|0x100U , kXBARA1_OutputFlexpwm34Pwm0Exta = 75|0x100U , kXBARA1_OutputFlexpwm34Pwm1Exta = 76|0x100U , kXBARA1_OutputFlexpwm34Pwm2Exta = 77|0x100U ,
  kXBARA1_OutputFlexpwm34Pwm3Exta = 78|0x100U , kXBARA1_OutputFlexpwm34ExtClk = 79|0x100U , kXBARA1_OutputFlexpwm3Pwm0ExtSync = 80|0x100U , kXBARA1_OutputFlexpwm3Pwm1ExtSync = 81|0x100U ,
  kXBARA1_OutputFlexpwm3Pwm2ExtSync = 82|0x100U , kXBARA1_OutputFlexpwm3Pwm3ExtSync = 83|0x100U , kXBARA1_OutputFlexpwm3Fault0 = 84|0x100U , kXBARA1_OutputFlexpwm3Fault1 = 85|0x100U ,
  kXBARA1_OutputFlexpwm3ExtForce = 86|0x100U , kXBARA1_OutputFlexpwm4Pwm0ExtSync = 87|0x100U , kXBARA1_OutputFlexpwm4Pwm1ExtSync = 88|0x100U , kXBARA1_OutputFlexpwm4Pwm2ExtSync = 89|0x100U ,
  kXBARA1_OutputFlexpwm4Pwm3ExtSync = 90|0x100U , kXBARA1_OutputFlexpwm4Fault0 = 91|0x100U , kXBARA1_OutputFlexpwm4Fault1 = 92|0x100U , kXBARA1_OutputFlexpwm4ExtForce = 93|0x100U ,
  kXBARA1_OutputRESERVED94 = 94|0x100U , kXBARA1_OutputRESERVED95 = 95|0x100U , kXBARA1_OutputRESERVED96 = 96|0x100U , kXBARA1_OutputRESERVED97 = 97|0x100U ,
  kXBARA1_OutputRESERVED98 = 98|0x100U , kXBARA1_OutputRESERVED99 = 99|0x100U , kXBARA1_OutputRESERVED100 = 100|0x100U , kXBARA1_OutputRESERVED101 = 101|0x100U ,
  kXBARA1_OutputRESERVED102 = 102|0x100U , kXBARA1_OutputRESERVED103 = 103|0x100U , kXBARA1_OutputRESERVED104 = 104|0x100U , kXBARA1_OutputRESERVED105 = 105|0x100U ,
  kXBARA1_OutputRESERVED106 = 106|0x100U , kXBARA1_OutputRESERVED107 = 107|0x100U , kXBARA1_OutputDec1Phasea = 108|0x100U , kXBARA1_OutputDec1Phaseb = 109|0x100U ,
  kXBARA1_OutputDec1Index = 110|0x100U , kXBARA1_OutputDec1Home = 111|0x100U , kXBARA1_OutputDec1Trigger = 112|0x100U , kXBARA1_OutputDec2Phasea = 113|0x100U ,
  kXBARA1_OutputDec2Phaseb = 114|0x100U , kXBARA1_OutputDec2Index = 115|0x100U , kXBARA1_OutputDec2Home = 116|0x100U , kXBARA1_OutputDec2Trigger = 117|0x100U ,
  kXBARA1_OutputDec3Phasea = 118|0x100U , kXBARA1_OutputDec3Phaseb = 119|0x100U , kXBARA1_OutputDec3Index = 120|0x100U , kXBARA1_OutputDec3Home = 121|0x100U ,
  kXBARA1_OutputDec3Trigger = 122|0x100U , kXBARA1_OutputDec4Phasea = 123|0x100U , kXBARA1_OutputDec4Phaseb = 124|0x100U , kXBARA1_OutputDec4Index = 125|0x100U ,
  kXBARA1_OutputDec4Home = 126|0x100U , kXBARA1_OutputDec4Trigger = 127|0x100U , kXBARA1_OutputRESERVED128 = 128|0x100U , kXBARA1_OutputRESERVED129 = 129|0x100U ,
  kXBARA1_OutputRESERVED130 = 130|0x100U , kXBARA1_OutputRESERVED131 = 131|0x100U , kXBARA1_OutputCan1 = 132|0x100U , kXBARA1_OutputCan2 = 133|0x100U ,
  kXBARA1_OutputRESERVED134 = 134|0x100U , kXBARA1_OutputRESERVED135 = 135|0x100U , kXBARA1_OutputRESERVED136 = 136|0x100U , kXBARA1_OutputRESERVED137 = 137|0x100U ,
  kXBARA1_OutputQtimer1Timer0 = 138|0x100U , kXBARA1_OutputQtimer1Timer1 = 139|0x100U , kXBARA1_OutputQtimer1Timer2 = 140|0x100U , kXBARA1_OutputQtimer1Timer3 = 141|0x100U ,
  kXBARA1_OutputQtimer2Timer0 = 142|0x100U , kXBARA1_OutputQtimer2Timer1 = 143|0x100U , kXBARA1_OutputQtimer2Timer2 = 144|0x100U , kXBARA1_OutputQtimer2Timer3 = 145|0x100U ,
  kXBARA1_OutputQtimer3Timer0 = 146|0x100U , kXBARA1_OutputQtimer3Timer1 = 147|0x100U , kXBARA1_OutputQtimer3Timer2 = 148|0x100U , kXBARA1_OutputQtimer3Timer3 = 149|0x100U ,
  kXBARA1_OutputQtimer4Timer0 = 150|0x100U , kXBARA1_OutputQtimer4Timer1 = 151|0x100U , kXBARA1_OutputQtimer4Timer2 = 152|0x100U , kXBARA1_OutputQtimer4Timer3 = 153|0x100U ,
  kXBARA1_OutputEwmEwmIn = 154|0x100U , kXBARA1_OutputAdcEtc0Coco0 = 155|0x100U , kXBARA1_OutputAdcEtc0Coco1 = 156|0x100U , kXBARA1_OutputAdcEtc0Coco2 = 157|0x100U ,
  kXBARA1_OutputAdcEtc0Coco3 = 158|0x100U , kXBARA1_OutputAdcEtc1Coco0 = 159|0x100U , kXBARA1_OutputAdcEtc1Coco1 = 160|0x100U , kXBARA1_OutputAdcEtc1Coco2 = 161|0x100U ,
  kXBARA1_OutputAdcEtc1Coco3 = 162|0x100U , kXBARA1_OutputRESERVED163 = 163|0x100U , kXBARA1_OutputRESERVED164 = 164|0x100U , kXBARA1_OutputRESERVED165 = 165|0x100U ,
  kXBARA1_OutputRESERVED166 = 166|0x100U , kXBARA1_OutputRESERVED167 = 167|0x100U , kXBARA1_OutputRESERVED168 = 168|0x100U , kXBARA1_OutputRESERVED169 = 169|0x100U ,
  kXBARA1_OutputRESERVED170 = 170|0x100U , kXBARA1_OutputFlexio1TrigIn0 = 171|0x100U , kXBARA1_OutputFlexio1TrigIn1 = 172|0x100U , kXBARA1_OutputFlexio2TrigIn0 = 173|0x100U ,
  kXBARA1_OutputFlexio2TrigIn1 = 174|0x100U , kXBARB2_OutputAoi1In00 = 0|0x200U , kXBARB2_OutputAoi1In01 = 1|0x200U , kXBARB2_OutputAoi1In02 = 2|0x200U ,
  kXBARB2_OutputAoi1In03 = 3|0x200U , kXBARB2_OutputAoi1In04 = 4|0x200U , kXBARB2_OutputAoi1In05 = 5|0x200U , kXBARB2_OutputAoi1In06 = 6|0x200U ,
  kXBARB2_OutputAoi1In07 = 7|0x200U , kXBARB2_OutputAoi1In08 = 8|0x200U , kXBARB2_OutputAoi1In09 = 9|0x200U , kXBARB2_OutputAoi1In10 = 10|0x200U ,
  kXBARB2_OutputAoi1In11 = 11|0x200U , kXBARB2_OutputAoi1In12 = 12|0x200U , kXBARB2_OutputAoi1In13 = 13|0x200U , kXBARB2_OutputAoi1In14 = 14|0x200U ,
  kXBARB2_OutputAoi1In15 = 15|0x200U , kXBARB3_OutputAoi2In00 = 0|0x300U , kXBARB3_OutputAoi2In01 = 1|0x300U , kXBARB3_OutputAoi2In02 = 2|0x300U ,
  kXBARB3_OutputAoi2In03 = 3|0x300U , kXBARB3_OutputAoi2In04 = 4|0x300U , kXBARB3_OutputAoi2In05 = 5|0x300U , kXBARB3_OutputAoi2In06 = 6|0x300U ,
  kXBARB3_OutputAoi2In07 = 7|0x300U , kXBARB3_OutputAoi2In08 = 8|0x300U , kXBARB3_OutputAoi2In09 = 9|0x300U , kXBARB3_OutputAoi2In10 = 10|0x300U ,
  kXBARB3_OutputAoi2In11 = 11|0x300U , kXBARB3_OutputAoi2In12 = 12|0x300U , kXBARB3_OutputAoi2In13 = 13|0x300U , kXBARB3_OutputAoi2In14 = 14|0x300U ,
enum  _iomuxc_sw_mux_ctl_pad {
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_00 = 0U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_01 = 1U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_02 = 2U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_03 = 3U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_04 = 4U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_05 = 5U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_06 = 6U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_07 = 7U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_08 = 8U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_09 = 9U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_10 = 10U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_11 = 11U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_12 = 12U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_13 = 13U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_14 = 14U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_15 = 15U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_16 = 16U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_17 = 17U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_18 = 18U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_19 = 19U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_20 = 20U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_21 = 21U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_22 = 22U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_23 = 23U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_24 = 24U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_25 = 25U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_26 = 26U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_27 = 27U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_28 = 28U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_29 = 29U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_30 = 30U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_31 = 31U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_32 = 32U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_33 = 33U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_34 = 34U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_35 = 35U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_36 = 36U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_37 = 37U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_38 = 38U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_39 = 39U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_40 = 40U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_41 = 41U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_00 = 42U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_01 = 43U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_02 = 44U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_03 = 45U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_04 = 46U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_05 = 47U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_06 = 48U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_07 = 49U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_08 = 50U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_09 = 51U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_10 = 52U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_11 = 53U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_12 = 54U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_13 = 55U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_14 = 56U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_15 = 57U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_00 = 58U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_01 = 59U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_02 = 60U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_03 = 61U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_04 = 62U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_05 = 63U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_06 = 64U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_07 = 65U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_08 = 66U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_09 = 67U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_10 = 68U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_11 = 69U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_12 = 70U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_13 = 71U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_14 = 72U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_15 = 73U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_00 = 74U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_01 = 75U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_02 = 76U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_03 = 77U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_04 = 78U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_05 = 79U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_06 = 80U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_07 = 81U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_08 = 82U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_09 = 83U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_10 = 84U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_11 = 85U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_12 = 86U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_13 = 87U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_14 = 88U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_15 = 89U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_00 = 90U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_01 = 91U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_02 = 92U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_03 = 93U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_04 = 94U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_05 = 95U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_06 = 96U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_07 = 97U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_08 = 98U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_09 = 99U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_10 = 100U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_11 = 101U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_12 = 102U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_13 = 103U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_14 = 104U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_15 = 105U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_00 = 106U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_01 = 107U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_02 = 108U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_03 = 109U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_04 = 110U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_05 = 111U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_00 = 112U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_01 = 113U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_02 = 114U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_03 = 115U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_04 = 116U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_05 = 117U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_06 = 118U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_07 = 119U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_08 = 120U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_09 = 121U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_10 = 122U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_11 = 123U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_00 = 0U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_01 = 1U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_02 = 2U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_03 = 3U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_04 = 4U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_05 = 5U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_06 = 6U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_07 = 7U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_08 = 8U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_09 = 9U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_10 = 10U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_11 = 11U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_12 = 12U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_13 = 13U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_14 = 14U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_15 = 15U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_16 = 16U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_17 = 17U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_18 = 18U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_19 = 19U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_20 = 20U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_21 = 21U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_22 = 22U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_23 = 23U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_24 = 24U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_25 = 25U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_26 = 26U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_27 = 27U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_28 = 28U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_29 = 29U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_30 = 30U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_31 = 31U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_32 = 32U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_33 = 33U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_34 = 34U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_35 = 35U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_36 = 36U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_37 = 37U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_38 = 38U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_39 = 39U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_40 = 40U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_41 = 41U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_00 = 42U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_01 = 43U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_02 = 44U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_03 = 45U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_04 = 46U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_05 = 47U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_06 = 48U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_07 = 49U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_08 = 50U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_09 = 51U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_10 = 52U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_11 = 53U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_12 = 54U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_13 = 55U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_14 = 56U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_15 = 57U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_16 = 58U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_17 = 59U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_18 = 60U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_19 = 61U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_20 = 62U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_00 = 63U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_01 = 64U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_02 = 65U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_03 = 66U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_04 = 67U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_05 = 68U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_06 = 69U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_07 = 70U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_08 = 71U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_09 = 72U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_10 = 73U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_11 = 74U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_12 = 75U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_13 = 76U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_14 = 77U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_15 = 78U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_16 = 79U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_17 = 80U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_18 = 81U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_19 = 82U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_20 = 83U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_21 = 84U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_22 = 85U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_23 = 86U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_24 = 87U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_25 = 88U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_26 = 89U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_27 = 90U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_28 = 91U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_29 = 92U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_30 = 93U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_31 = 94U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_32 = 95U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_33 = 96U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_34 = 97U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_35 = 98U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_00 = 99U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_01 = 100U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_02 = 101U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_03 = 102U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_04 = 103U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_05 = 104U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_00 = 105U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_01 = 106U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_02 = 107U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_03 = 108U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_04 = 109U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_05 = 110U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_06 = 111U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_07 = 112U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_08 = 113U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_09 = 114U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_10 = 115U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_11 = 116U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_00 = 117U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_01 = 118U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_02 = 119U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_03 = 120U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_04 = 121U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_05 = 122U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_06 = 123U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_07 = 124U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_08 = 125U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_09 = 126U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_10 = 127U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_11 = 128U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_00 = 129U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_01 = 130U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_02 = 131U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_03 = 132U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_04 = 133U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_05 = 134U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_06 = 135U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_07 = 136U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_08 = 137U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_09 = 138U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_10 = 139U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_11 = 140U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_12 = 141U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_13 = 142U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_14 = 143U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_15 = 144U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_00 = 0U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_01 = 1U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_02 = 2U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_03 = 3U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_04 = 4U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_05 = 5U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_06 = 6U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_07 = 7U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_08 = 8U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_09 = 9U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_10 = 10U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_11 = 11U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_12 = 12U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_13 = 13U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_14 = 14U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_15 = 15U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_16 = 16U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_17 = 17U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_18 = 18U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_19 = 19U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_20 = 20U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_21 = 21U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_22 = 22U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_23 = 23U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_24 = 24U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_25 = 25U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_26 = 26U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_27 = 27U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_28 = 28U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_29 = 29U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_30 = 30U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_31 = 31U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_32 = 32U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_33 = 33U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_34 = 34U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_35 = 35U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_36 = 36U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_37 = 37U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_38 = 38U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_39 = 39U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_40 = 40U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_41 = 41U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_00 = 42U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_01 = 43U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_02 = 44U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_03 = 45U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_04 = 46U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_05 = 47U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_06 = 48U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_07 = 49U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_08 = 50U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_09 = 51U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_10 = 52U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_11 = 53U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_12 = 54U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_13 = 55U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_14 = 56U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_15 = 57U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_16 = 58U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_17 = 59U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_18 = 60U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_19 = 61U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_20 = 62U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_00 = 63U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_01 = 64U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_02 = 65U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_03 = 66U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_04 = 67U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_05 = 68U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_06 = 69U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_07 = 70U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_08 = 71U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_09 = 72U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_10 = 73U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_11 = 74U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_12 = 75U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_13 = 76U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_14 = 77U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_15 = 78U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_16 = 79U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_17 = 80U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_18 = 81U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_19 = 82U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_20 = 83U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_21 = 84U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_22 = 85U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_23 = 86U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_24 = 87U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_25 = 88U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_26 = 89U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_27 = 90U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_28 = 91U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_29 = 92U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_30 = 93U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_31 = 94U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_32 = 95U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_33 = 96U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_34 = 97U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_35 = 98U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_00 = 99U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_01 = 100U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_02 = 101U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_03 = 102U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_04 = 103U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_05 = 104U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_00 = 105U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_01 = 106U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_02 = 107U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_03 = 108U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_04 = 109U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_05 = 110U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_06 = 111U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_07 = 112U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_08 = 113U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_09 = 114U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_10 = 115U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_11 = 116U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_00 = 117U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_01 = 118U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_02 = 119U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_03 = 120U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_04 = 121U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_05 = 122U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_06 = 123U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_07 = 124U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_08 = 125U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_09 = 126U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_10 = 127U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_11 = 128U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_00 = 129U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_01 = 130U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_02 = 131U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_03 = 132U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_04 = 133U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_05 = 134U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_06 = 135U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_07 = 136U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_08 = 137U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_09 = 138U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_10 = 139U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_11 = 140U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_12 = 141U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_13 = 142U ,
  kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_14 = 143U , kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_15 = 144U
 Enumeration for the IOMUXC SW_MUX_CTL_PAD. More...
enum  _iomuxc_sw_pad_ctl_pad {
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_00 = 0U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_01 = 1U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_02 = 2U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_03 = 3U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_04 = 4U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_05 = 5U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_06 = 6U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_07 = 7U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_08 = 8U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_09 = 9U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_10 = 10U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_11 = 11U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_12 = 12U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_13 = 13U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_14 = 14U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_15 = 15U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_16 = 16U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_17 = 17U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_18 = 18U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_19 = 19U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_20 = 20U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_21 = 21U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_22 = 22U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_23 = 23U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_24 = 24U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_25 = 25U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_26 = 26U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_27 = 27U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_28 = 28U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_29 = 29U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_30 = 30U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_31 = 31U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_32 = 32U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_33 = 33U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_34 = 34U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_35 = 35U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_36 = 36U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_37 = 37U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_38 = 38U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_39 = 39U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_40 = 40U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_41 = 41U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_00 = 42U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_01 = 43U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_02 = 44U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_03 = 45U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_04 = 46U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_05 = 47U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_06 = 48U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_07 = 49U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_08 = 50U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_09 = 51U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_10 = 52U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_11 = 53U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_12 = 54U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_13 = 55U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_14 = 56U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_15 = 57U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_00 = 58U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_01 = 59U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_02 = 60U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_03 = 61U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_04 = 62U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_05 = 63U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_06 = 64U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_07 = 65U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_08 = 66U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_09 = 67U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_10 = 68U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_11 = 69U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_12 = 70U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_13 = 71U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_14 = 72U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_15 = 73U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_00 = 74U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_01 = 75U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_02 = 76U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_03 = 77U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_04 = 78U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_05 = 79U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_06 = 80U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_07 = 81U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_08 = 82U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_09 = 83U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_10 = 84U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_11 = 85U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_12 = 86U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_13 = 87U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_14 = 88U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_15 = 89U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_00 = 90U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_01 = 91U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_02 = 92U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_03 = 93U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_04 = 94U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_05 = 95U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_06 = 96U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_07 = 97U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_08 = 98U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_09 = 99U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_10 = 100U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_11 = 101U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_12 = 102U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_13 = 103U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_14 = 104U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_15 = 105U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_00 = 106U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_01 = 107U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_02 = 108U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_03 = 109U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_04 = 110U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_05 = 111U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_00 = 112U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_01 = 113U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_02 = 114U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_03 = 115U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_04 = 116U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_05 = 117U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_06 = 118U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_07 = 119U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_08 = 120U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_09 = 121U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_10 = 122U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_11 = 123U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_00 = 0U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_01 = 1U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_02 = 2U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_03 = 3U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_04 = 4U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_05 = 5U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_06 = 6U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_07 = 7U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_08 = 8U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_09 = 9U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_10 = 10U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_11 = 11U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_12 = 12U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_13 = 13U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_14 = 14U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_15 = 15U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_16 = 16U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_17 = 17U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_18 = 18U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_19 = 19U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_20 = 20U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_21 = 21U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_22 = 22U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_23 = 23U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_24 = 24U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_25 = 25U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_26 = 26U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_27 = 27U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_28 = 28U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_29 = 29U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_30 = 30U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_31 = 31U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_32 = 32U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_33 = 33U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_34 = 34U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_35 = 35U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_36 = 36U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_37 = 37U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_38 = 38U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_39 = 39U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_40 = 40U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_41 = 41U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_00 = 42U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_01 = 43U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_02 = 44U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_03 = 45U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_04 = 46U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_05 = 47U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_06 = 48U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_07 = 49U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_08 = 50U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_09 = 51U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_10 = 52U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_11 = 53U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_12 = 54U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_13 = 55U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_14 = 56U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_15 = 57U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_16 = 58U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_17 = 59U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_18 = 60U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_19 = 61U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_20 = 62U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_00 = 63U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_01 = 64U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_02 = 65U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_03 = 66U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_04 = 67U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_05 = 68U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_06 = 69U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_07 = 70U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_08 = 71U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_09 = 72U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_10 = 73U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_11 = 74U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_12 = 75U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_13 = 76U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_14 = 77U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_15 = 78U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_16 = 79U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_17 = 80U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_18 = 81U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_19 = 82U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_20 = 83U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_21 = 84U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_22 = 85U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_23 = 86U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_24 = 87U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_25 = 88U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_26 = 89U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_27 = 90U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_28 = 91U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_29 = 92U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_30 = 93U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_31 = 94U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_32 = 95U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_33 = 96U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_34 = 97U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_35 = 98U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_00 = 99U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_01 = 100U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_02 = 101U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_03 = 102U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_04 = 103U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_05 = 104U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_00 = 105U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_01 = 106U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_02 = 107U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_03 = 108U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_04 = 109U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_05 = 110U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_06 = 111U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_07 = 112U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_08 = 113U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_09 = 114U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_10 = 115U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_11 = 116U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_00 = 117U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_01 = 118U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_02 = 119U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_03 = 120U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_04 = 121U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_05 = 122U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_06 = 123U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_07 = 124U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_08 = 125U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_09 = 126U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_10 = 127U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_11 = 128U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_00 = 129U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_01 = 130U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_02 = 131U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_03 = 132U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_04 = 133U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_05 = 134U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_06 = 135U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_07 = 136U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_08 = 137U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_09 = 138U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_10 = 139U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_11 = 140U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_12 = 141U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_13 = 142U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_14 = 143U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_15 = 144U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_00 = 0U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_01 = 1U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_02 = 2U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_03 = 3U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_04 = 4U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_05 = 5U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_06 = 6U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_07 = 7U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_08 = 8U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_09 = 9U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_10 = 10U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_11 = 11U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_12 = 12U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_13 = 13U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_14 = 14U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_15 = 15U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_16 = 16U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_17 = 17U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_18 = 18U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_19 = 19U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_20 = 20U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_21 = 21U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_22 = 22U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_23 = 23U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_24 = 24U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_25 = 25U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_26 = 26U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_27 = 27U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_28 = 28U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_29 = 29U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_30 = 30U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_31 = 31U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_32 = 32U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_33 = 33U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_34 = 34U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_35 = 35U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_36 = 36U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_37 = 37U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_38 = 38U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_39 = 39U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_40 = 40U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_41 = 41U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_00 = 42U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_01 = 43U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_02 = 44U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_03 = 45U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_04 = 46U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_05 = 47U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_06 = 48U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_07 = 49U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_08 = 50U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_09 = 51U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_10 = 52U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_11 = 53U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_12 = 54U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_13 = 55U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_14 = 56U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_15 = 57U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_16 = 58U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_17 = 59U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_18 = 60U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_19 = 61U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_20 = 62U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_00 = 63U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_01 = 64U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_02 = 65U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_03 = 66U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_04 = 67U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_05 = 68U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_06 = 69U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_07 = 70U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_08 = 71U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_09 = 72U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_10 = 73U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_11 = 74U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_12 = 75U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_13 = 76U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_14 = 77U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_15 = 78U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_16 = 79U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_17 = 80U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_18 = 81U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_19 = 82U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_20 = 83U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_21 = 84U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_22 = 85U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_23 = 86U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_24 = 87U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_25 = 88U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_26 = 89U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_27 = 90U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_28 = 91U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_29 = 92U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_30 = 93U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_31 = 94U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_32 = 95U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_33 = 96U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_34 = 97U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_35 = 98U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_00 = 99U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_01 = 100U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_02 = 101U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_03 = 102U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_04 = 103U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_05 = 104U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_00 = 105U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_01 = 106U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_02 = 107U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_03 = 108U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_04 = 109U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_05 = 110U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_06 = 111U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_07 = 112U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_08 = 113U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_09 = 114U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_10 = 115U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_11 = 116U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_00 = 117U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_01 = 118U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_02 = 119U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_03 = 120U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_04 = 121U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_05 = 122U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_06 = 123U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_07 = 124U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_08 = 125U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_09 = 126U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_10 = 127U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_11 = 128U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_00 = 129U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_01 = 130U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_02 = 131U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_03 = 132U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_04 = 133U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_05 = 134U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_06 = 135U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_07 = 136U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_08 = 137U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_09 = 138U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_10 = 139U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_11 = 140U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_12 = 141U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_13 = 142U ,
  kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_14 = 143U , kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_15 = 144U
 Enumeration for the IOMUXC SW_PAD_CTL_PAD. More...
enum  _iomuxc_select_input {
  kIOMUXC_ANATOP_USB_OTG1_ID_SELECT_INPUT = 0U , kIOMUXC_ANATOP_USB_OTG2_ID_SELECT_INPUT = 1U , kIOMUXC_CCM_PMIC_READY_SELECT_INPUT = 2U , kIOMUXC_CSI_DATA02_SELECT_INPUT = 3U ,
  kIOMUXC_CSI_DATA03_SELECT_INPUT = 4U , kIOMUXC_CSI_DATA04_SELECT_INPUT = 5U , kIOMUXC_CSI_DATA05_SELECT_INPUT = 6U , kIOMUXC_CSI_DATA06_SELECT_INPUT = 7U ,
  kIOMUXC_CSI_DATA07_SELECT_INPUT = 8U , kIOMUXC_CSI_DATA08_SELECT_INPUT = 9U , kIOMUXC_CSI_DATA09_SELECT_INPUT = 10U , kIOMUXC_CSI_HSYNC_SELECT_INPUT = 11U ,
  kIOMUXC_CSI_PIXCLK_SELECT_INPUT = 12U , kIOMUXC_CSI_VSYNC_SELECT_INPUT = 13U , kIOMUXC_ENET_IPG_CLK_RMII_SELECT_INPUT = 14U , kIOMUXC_ENET_MDIO_SELECT_INPUT = 15U ,
  kIOMUXC_ENET0_RXDATA_SELECT_INPUT = 16U , kIOMUXC_ENET1_RXDATA_SELECT_INPUT = 17U , kIOMUXC_ENET_RXEN_SELECT_INPUT = 18U , kIOMUXC_ENET_RXERR_SELECT_INPUT = 19U ,
  kIOMUXC_ENET0_TIMER_SELECT_INPUT = 20U , kIOMUXC_ENET_TXCLK_SELECT_INPUT = 21U , kIOMUXC_FLEXCAN1_RX_SELECT_INPUT = 22U , kIOMUXC_FLEXCAN2_RX_SELECT_INPUT = 23U ,
  kIOMUXC_FLEXPWM1_PWMA3_SELECT_INPUT = 24U , kIOMUXC_FLEXPWM1_PWMA0_SELECT_INPUT = 25U , kIOMUXC_FLEXPWM1_PWMA1_SELECT_INPUT = 26U , kIOMUXC_FLEXPWM1_PWMA2_SELECT_INPUT = 27U ,
  kIOMUXC_FLEXPWM1_PWMB3_SELECT_INPUT = 28U , kIOMUXC_FLEXPWM1_PWMB0_SELECT_INPUT = 29U , kIOMUXC_FLEXPWM1_PWMB1_SELECT_INPUT = 30U , kIOMUXC_FLEXPWM1_PWMB2_SELECT_INPUT = 31U ,
  kIOMUXC_FLEXPWM2_PWMA3_SELECT_INPUT = 32U , kIOMUXC_FLEXPWM2_PWMA0_SELECT_INPUT = 33U , kIOMUXC_FLEXPWM2_PWMA1_SELECT_INPUT = 34U , kIOMUXC_FLEXPWM2_PWMA2_SELECT_INPUT = 35U ,
  kIOMUXC_FLEXPWM2_PWMB3_SELECT_INPUT = 36U , kIOMUXC_FLEXPWM2_PWMB0_SELECT_INPUT = 37U , kIOMUXC_FLEXPWM2_PWMB1_SELECT_INPUT = 38U , kIOMUXC_FLEXPWM2_PWMB2_SELECT_INPUT = 39U ,
  kIOMUXC_FLEXPWM4_PWMA0_SELECT_INPUT = 40U , kIOMUXC_FLEXPWM4_PWMA1_SELECT_INPUT = 41U , kIOMUXC_FLEXPWM4_PWMA2_SELECT_INPUT = 42U , kIOMUXC_FLEXPWM4_PWMA3_SELECT_INPUT = 43U ,
  kIOMUXC_FLEXSPI_A_DQS_SELECT_INPUT = 44U , kIOMUXC_FLEXSPI_A_DATA0_SELECT_INPUT = 45U , kIOMUXC_FLEXSPI_A_DATA1_SELECT_INPUT = 46U , kIOMUXC_FLEXSPI_A_DATA2_SELECT_INPUT = 47U ,
  kIOMUXC_FLEXSPI_A_DATA3_SELECT_INPUT = 48U , kIOMUXC_FLEXSPI_B_DATA0_SELECT_INPUT = 49U , kIOMUXC_FLEXSPI_B_DATA1_SELECT_INPUT = 50U , kIOMUXC_FLEXSPI_B_DATA2_SELECT_INPUT = 51U ,
  kIOMUXC_FLEXSPI_B_DATA3_SELECT_INPUT = 52U , kIOMUXC_FLEXSPI_A_SCK_SELECT_INPUT = 53U , kIOMUXC_LPI2C1_SCL_SELECT_INPUT = 54U , kIOMUXC_LPI2C1_SDA_SELECT_INPUT = 55U ,
  kIOMUXC_LPI2C2_SCL_SELECT_INPUT = 56U , kIOMUXC_LPI2C2_SDA_SELECT_INPUT = 57U , kIOMUXC_LPI2C3_SCL_SELECT_INPUT = 58U , kIOMUXC_LPI2C3_SDA_SELECT_INPUT = 59U ,
  kIOMUXC_LPI2C4_SCL_SELECT_INPUT = 60U , kIOMUXC_LPI2C4_SDA_SELECT_INPUT = 61U , kIOMUXC_LPSPI1_PCS0_SELECT_INPUT = 62U , kIOMUXC_LPSPI1_SCK_SELECT_INPUT = 63U ,
  kIOMUXC_LPSPI1_SDI_SELECT_INPUT = 64U , kIOMUXC_LPSPI1_SDO_SELECT_INPUT = 65U , kIOMUXC_LPSPI2_PCS0_SELECT_INPUT = 66U , kIOMUXC_LPSPI2_SCK_SELECT_INPUT = 67U ,
  kIOMUXC_LPSPI2_SDI_SELECT_INPUT = 68U , kIOMUXC_LPSPI2_SDO_SELECT_INPUT = 69U , kIOMUXC_LPSPI3_PCS0_SELECT_INPUT = 70U , kIOMUXC_LPSPI3_SCK_SELECT_INPUT = 71U ,
  kIOMUXC_LPSPI3_SDI_SELECT_INPUT = 72U , kIOMUXC_LPSPI3_SDO_SELECT_INPUT = 73U , kIOMUXC_LPSPI4_PCS0_SELECT_INPUT = 74U , kIOMUXC_LPSPI4_SCK_SELECT_INPUT = 75U ,
  kIOMUXC_LPSPI4_SDI_SELECT_INPUT = 76U , kIOMUXC_LPSPI4_SDO_SELECT_INPUT = 77U , kIOMUXC_LPUART2_RX_SELECT_INPUT = 78U , kIOMUXC_LPUART2_TX_SELECT_INPUT = 79U ,
  kIOMUXC_LPUART3_CTS_B_SELECT_INPUT = 80U , kIOMUXC_LPUART3_RX_SELECT_INPUT = 81U , kIOMUXC_LPUART3_TX_SELECT_INPUT = 82U , kIOMUXC_LPUART4_RX_SELECT_INPUT = 83U ,
  kIOMUXC_LPUART4_TX_SELECT_INPUT = 84U , kIOMUXC_LPUART5_RX_SELECT_INPUT = 85U , kIOMUXC_LPUART5_TX_SELECT_INPUT = 86U , kIOMUXC_LPUART6_RX_SELECT_INPUT = 87U ,
  kIOMUXC_LPUART6_TX_SELECT_INPUT = 88U , kIOMUXC_LPUART7_RX_SELECT_INPUT = 89U , kIOMUXC_LPUART7_TX_SELECT_INPUT = 90U , kIOMUXC_LPUART8_RX_SELECT_INPUT = 91U ,
  kIOMUXC_LPUART8_TX_SELECT_INPUT = 92U , kIOMUXC_NMI_SELECT_INPUT = 93U , kIOMUXC_QTIMER2_TIMER0_SELECT_INPUT = 94U , kIOMUXC_QTIMER2_TIMER1_SELECT_INPUT = 95U ,
  kIOMUXC_QTIMER2_TIMER2_SELECT_INPUT = 96U , kIOMUXC_QTIMER2_TIMER3_SELECT_INPUT = 97U , kIOMUXC_QTIMER3_TIMER0_SELECT_INPUT = 98U , kIOMUXC_QTIMER3_TIMER1_SELECT_INPUT = 99U ,
  kIOMUXC_QTIMER3_TIMER2_SELECT_INPUT = 100U , kIOMUXC_QTIMER3_TIMER3_SELECT_INPUT = 101U , kIOMUXC_SAI1_MCLK2_SELECT_INPUT = 102U , kIOMUXC_SAI1_RX_BCLK_SELECT_INPUT = 103U ,
  kIOMUXC_SAI1_RX_DATA0_SELECT_INPUT = 104U , kIOMUXC_SAI1_RX_DATA1_SELECT_INPUT = 105U , kIOMUXC_SAI1_RX_DATA2_SELECT_INPUT = 106U , kIOMUXC_SAI1_RX_DATA3_SELECT_INPUT = 107U ,
  kIOMUXC_SAI1_RX_SYNC_SELECT_INPUT = 108U , kIOMUXC_SAI1_TX_BCLK_SELECT_INPUT = 109U , kIOMUXC_SAI1_TX_SYNC_SELECT_INPUT = 110U , kIOMUXC_SAI2_MCLK2_SELECT_INPUT = 111U ,
  kIOMUXC_SAI2_RX_BCLK_SELECT_INPUT = 112U , kIOMUXC_SAI2_RX_DATA0_SELECT_INPUT = 113U , kIOMUXC_SAI2_RX_SYNC_SELECT_INPUT = 114U , kIOMUXC_SAI2_TX_BCLK_SELECT_INPUT = 115U ,
  kIOMUXC_SAI2_TX_SYNC_SELECT_INPUT = 116U , kIOMUXC_SPDIF_IN_SELECT_INPUT = 117U , kIOMUXC_USB_OTG2_OC_SELECT_INPUT = 118U , kIOMUXC_USB_OTG1_OC_SELECT_INPUT = 119U ,
  kIOMUXC_USDHC1_CD_B_SELECT_INPUT = 120U , kIOMUXC_USDHC1_WP_SELECT_INPUT = 121U , kIOMUXC_USDHC2_CLK_SELECT_INPUT = 122U , kIOMUXC_USDHC2_CD_B_SELECT_INPUT = 123U ,
  kIOMUXC_USDHC2_CMD_SELECT_INPUT = 124U , kIOMUXC_USDHC2_DATA0_SELECT_INPUT = 125U , kIOMUXC_USDHC2_DATA1_SELECT_INPUT = 126U , kIOMUXC_USDHC2_DATA2_SELECT_INPUT = 127U ,
  kIOMUXC_USDHC2_DATA3_SELECT_INPUT = 128U , kIOMUXC_USDHC2_DATA4_SELECT_INPUT = 129U , kIOMUXC_USDHC2_DATA5_SELECT_INPUT = 130U , kIOMUXC_USDHC2_DATA6_SELECT_INPUT = 131U ,
  kIOMUXC_USDHC2_DATA7_SELECT_INPUT = 132U , kIOMUXC_USDHC2_WP_SELECT_INPUT = 133U , kIOMUXC_XBAR_INOUT02_SELECT_INPUT = 134U , kIOMUXC_XBAR_INOUT03_SELECT_INPUT = 135U ,
  kIOMUXC_XBAR_INOUT04_SELECT_INPUT = 136U , kIOMUXC_XBAR_INOUT05_SELECT_INPUT = 137U , kIOMUXC_XBAR_INOUT06_SELECT_INPUT = 138U , kIOMUXC_XBAR_INOUT07_SELECT_INPUT = 139U ,
  kIOMUXC_XBAR_INOUT08_SELECT_INPUT = 140U , kIOMUXC_XBAR_INOUT09_SELECT_INPUT = 141U , kIOMUXC_XBAR_INOUT17_SELECT_INPUT = 142U , kIOMUXC_XBAR_INOUT18_SELECT_INPUT = 143U ,
  kIOMUXC_XBAR_INOUT20_SELECT_INPUT = 144U , kIOMUXC_XBAR_INOUT22_SELECT_INPUT = 145U , kIOMUXC_XBAR_INOUT23_SELECT_INPUT = 146U , kIOMUXC_XBAR_INOUT24_SELECT_INPUT = 147U ,
  kIOMUXC_XBAR_INOUT14_SELECT_INPUT = 148U , kIOMUXC_XBAR_INOUT15_SELECT_INPUT = 149U , kIOMUXC_XBAR_INOUT16_SELECT_INPUT = 150U , kIOMUXC_XBAR_INOUT25_SELECT_INPUT = 151U ,
  kIOMUXC_XBAR_INOUT19_SELECT_INPUT = 152U , kIOMUXC_XBAR_INOUT21_SELECT_INPUT = 153U , kIOMUXC_FLEXCAN1_RX_SELECT_INPUT = 0U , kIOMUXC_FLEXCAN2_RX_SELECT_INPUT = 1U ,
  kIOMUXC_ENET_IPG_CLK_RMII_SELECT_INPUT = 4U , kIOMUXC_ENET_MAC0_MDIO_SELECT_INPUT = 5U , kIOMUXC_ENET_MAC0_RXDATA_SELECT_INPUT_0 = 6U , kIOMUXC_ENET_MAC0_RXDATA_SELECT_INPUT_1 = 7U ,
  kIOMUXC_ENET_MAC0_RXEN_SELECT_INPUT = 8U , kIOMUXC_ENET_MAC0_RXERR_SELECT_INPUT = 9U , kIOMUXC_ENET_MAC0_TXCLK_SELECT_INPUT = 10U , kIOMUXC_ENET_1G_IPG_CLK_RMII_SELECT_INPUT = 11U ,
  kIOMUXC_ENET_1G_MAC0_MDIO_SELECT_INPUT = 12U , kIOMUXC_ENET_1G_MAC0_RXCLK_SELECT_INPUT = 13U , kIOMUXC_ENET_1G_MAC0_RXDATA_0_SELECT_INPUT = 14U , kIOMUXC_ENET_1G_MAC0_RXDATA_1_SELECT_INPUT = 15U ,
  kIOMUXC_ENET_1G_MAC0_RXDATA_2_SELECT_INPUT = 16U , kIOMUXC_ENET_1G_MAC0_RXDATA_3_SELECT_INPUT = 17U , kIOMUXC_ENET_1G_MAC0_RXEN_SELECT_INPUT = 18U , kIOMUXC_ENET_1G_MAC0_RXERR_SELECT_INPUT = 19U ,
  kIOMUXC_ENET_1G_MAC0_TXCLK_SELECT_INPUT = 20U , kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_0 = 26U , kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_1 = 27U , kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_2 = 28U ,
  kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_0 = 29U , kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_1 = 30U , kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_2 = 31U , kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_0 = 32U ,
  kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_1 = 33U , kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_2 = 34U , kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_0 = 35U , kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_1 = 36U ,
  kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_2 = 37U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_0 = 38U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_1 = 39U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_2 = 40U ,
  kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_3 = 41U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_0 = 42U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_1 = 43U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_2 = 44U ,
  kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_3 = 45U , kIOMUXC_FLEXSPI1_I_DQS_FA_SELECT_INPUT = 46U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_0 = 47U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_1 = 48U ,
  kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_2 = 49U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_3 = 50U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_0 = 51U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_1 = 52U ,
  kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_2 = 53U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_3 = 54U , kIOMUXC_FLEXSPI1_I_SCK_FA_SELECT_INPUT = 55U , kIOMUXC_FLEXSPI1_I_SCK_FB_SELECT_INPUT = 56U ,
  kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_0 = 57U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_1 = 58U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_2 = 59U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_3 = 60U ,
  kIOMUXC_FLEXSPI2_I_SCK_FA_SELECT_INPUT = 61U , kIOMUXC_GPT3_CAPIN1_SELECT_INPUT = 62U , kIOMUXC_GPT3_CAPIN2_SELECT_INPUT = 63U , kIOMUXC_GPT3_CLKIN_SELECT_INPUT = 64U ,
  kIOMUXC_KPP_COL_SELECT_INPUT_6 = 65U , kIOMUXC_KPP_COL_SELECT_INPUT_7 = 66U , kIOMUXC_KPP_ROW_SELECT_INPUT_6 = 67U , kIOMUXC_KPP_ROW_SELECT_INPUT_7 = 68U ,
  kIOMUXC_LPI2C1_LPI2C_SCL_SELECT_INPUT = 69U , kIOMUXC_LPI2C1_LPI2C_SDA_SELECT_INPUT = 70U , kIOMUXC_LPI2C2_LPI2C_SCL_SELECT_INPUT = 71U , kIOMUXC_LPI2C2_LPI2C_SDA_SELECT_INPUT = 72U ,
  kIOMUXC_LPI2C3_LPI2C_SCL_SELECT_INPUT = 73U , kIOMUXC_LPI2C3_LPI2C_SDA_SELECT_INPUT = 74U , kIOMUXC_LPI2C4_LPI2C_SCL_SELECT_INPUT = 75U , kIOMUXC_LPI2C4_LPI2C_SDA_SELECT_INPUT = 76U ,
  kIOMUXC_LPSPI1_LPSPI_PCS_SELECT_INPUT_0 = 77U , kIOMUXC_LPSPI1_LPSPI_SCK_SELECT_INPUT = 78U , kIOMUXC_LPSPI1_LPSPI_SDI_SELECT_INPUT = 79U , kIOMUXC_LPSPI1_LPSPI_SDO_SELECT_INPUT = 80U ,
  kIOMUXC_LPSPI2_LPSPI_PCS_SELECT_INPUT_0 = 81U , kIOMUXC_LPSPI2_LPSPI_PCS_SELECT_INPUT_1 = 82U , kIOMUXC_LPSPI2_LPSPI_SCK_SELECT_INPUT = 83U , kIOMUXC_LPSPI2_LPSPI_SDI_SELECT_INPUT = 84U ,
  kIOMUXC_LPSPI2_LPSPI_SDO_SELECT_INPUT = 85U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_0 = 86U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_1 = 87U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_2 = 88U ,
  kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_3 = 89U , kIOMUXC_LPSPI3_LPSPI_SCK_SELECT_INPUT = 90U , kIOMUXC_LPSPI3_LPSPI_SDI_SELECT_INPUT = 91U , kIOMUXC_LPSPI3_LPSPI_SDO_SELECT_INPUT = 92U ,
  kIOMUXC_LPSPI4_LPSPI_PCS_SELECT_INPUT_0 = 93U , kIOMUXC_LPSPI4_LPSPI_SCK_SELECT_INPUT = 94U , kIOMUXC_LPSPI4_LPSPI_SDI_SELECT_INPUT = 95U , kIOMUXC_LPSPI4_LPSPI_SDO_SELECT_INPUT = 96U ,
  kIOMUXC_LPUART1_LPUART_RXD_SELECT_INPUT = 97U , kIOMUXC_LPUART1_LPUART_TXD_SELECT_INPUT = 98U , kIOMUXC_LPUART10_LPUART_RXD_SELECT_INPUT = 99U , kIOMUXC_LPUART10_LPUART_TXD_SELECT_INPUT = 100U ,
  kIOMUXC_LPUART7_LPUART_RXD_SELECT_INPUT = 101U , kIOMUXC_LPUART7_LPUART_TXD_SELECT_INPUT = 102U , kIOMUXC_LPUART8_LPUART_RXD_SELECT_INPUT = 103U , kIOMUXC_LPUART8_LPUART_TXD_SELECT_INPUT = 104U ,
  kIOMUXC_QTIMER1_TMR0_INPUT_SELECT_INPUT = 105U , kIOMUXC_QTIMER1_TMR1_INPUT_SELECT_INPUT = 106U , kIOMUXC_QTIMER1_TMR2_INPUT_SELECT_INPUT = 107U , kIOMUXC_QTIMER2_TMR0_INPUT_SELECT_INPUT = 108U ,
  kIOMUXC_QTIMER2_TMR1_INPUT_SELECT_INPUT = 109U , kIOMUXC_QTIMER2_TMR2_INPUT_SELECT_INPUT = 110U , kIOMUXC_QTIMER3_TMR0_INPUT_SELECT_INPUT = 111U , kIOMUXC_QTIMER3_TMR1_INPUT_SELECT_INPUT = 112U ,
  kIOMUXC_QTIMER3_TMR2_INPUT_SELECT_INPUT = 113U , kIOMUXC_QTIMER4_TMR0_INPUT_SELECT_INPUT = 114U , kIOMUXC_QTIMER4_TMR1_INPUT_SELECT_INPUT = 115U , kIOMUXC_QTIMER4_TMR2_INPUT_SELECT_INPUT = 116U ,
  kIOMUXC_SAI1_IPG_CLK_SAI_MCLK_SELECT_INPUT = 117U , kIOMUXC_SAI1_SAI_RXBCLK_SELECT_INPUT = 118U , kIOMUXC_SAI1_SAI_RXDATA_SELECT_INPUT_0 = 119U , kIOMUXC_SAI1_SAI_RXSYNC_SELECT_INPUT = 120U ,
  kIOMUXC_SAI1_SAI_TXBCLK_SELECT_INPUT = 121U , kIOMUXC_SAI1_SAI_TXSYNC_SELECT_INPUT = 122U , kIOMUXC_EMVSIM1_SIO_SELECT_INPUT = 129U , kIOMUXC_EMVSIM1_IPP_SIMPD_SELECT_INPUT = 130U ,
  kIOMUXC_EMVSIM1_POWER_FAIL_SELECT_INPUT = 131U , kIOMUXC_EMVSIM2_SIO_SELECT_INPUT = 132U , kIOMUXC_EMVSIM2_IPP_SIMPD_SELECT_INPUT = 133U , kIOMUXC_EMVSIM2_POWER_FAIL_SELECT_INPUT = 134U ,
  kIOMUXC_SPDIF_SPDIF_IN1_SELECT_INPUT = 135U , kIOMUXC_USB_OTG2_OC_SELECT_INPUT = 136U , kIOMUXC_USB_OTG_OC_SELECT_INPUT = 137U , kIOMUXC_USBPHY1_USB_ID_SELECT_INPUT = 138U ,
  kIOMUXC_USBPHY2_USB_ID_SELECT_INPUT = 139U , kIOMUXC_USDHC1_IPP_CARD_DET_SELECT_INPUT = 140U , kIOMUXC_USDHC1_IPP_WP_ON_SELECT_INPUT = 141U , kIOMUXC_USDHC2_IPP_CARD_DET_SELECT_INPUT = 142U ,
  kIOMUXC_USDHC2_IPP_WP_ON_SELECT_INPUT = 143U , kIOMUXC_XBAR1_IN_SELECT_INPUT_20 = 144U , kIOMUXC_XBAR1_IN_SELECT_INPUT_21 = 145U , kIOMUXC_XBAR1_IN_SELECT_INPUT_22 = 146U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_23 = 147U , kIOMUXC_XBAR1_IN_SELECT_INPUT_24 = 148U , kIOMUXC_XBAR1_IN_SELECT_INPUT_25 = 149U , kIOMUXC_XBAR1_IN_SELECT_INPUT_26 = 150U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_27 = 151U , kIOMUXC_XBAR1_IN_SELECT_INPUT_28 = 152U , kIOMUXC_XBAR1_IN_SELECT_INPUT_29 = 153U , kIOMUXC_XBAR1_IN_SELECT_INPUT_30 = 154U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_31 = 155U , kIOMUXC_XBAR1_IN_SELECT_INPUT_32 = 156U , kIOMUXC_XBAR1_IN_SELECT_INPUT_33 = 157U , kIOMUXC_XBAR1_IN_SELECT_INPUT_34 = 158U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_35 = 159U , kIOMUXC_FLEXCAN1_RX_SELECT_INPUT = 0U , kIOMUXC_FLEXCAN2_RX_SELECT_INPUT = 1U , kIOMUXC_ENET_IPG_CLK_RMII_SELECT_INPUT = 4U ,
  kIOMUXC_ENET_MAC0_MDIO_SELECT_INPUT = 5U , kIOMUXC_ENET_MAC0_RXDATA_SELECT_INPUT_0 = 6U , kIOMUXC_ENET_MAC0_RXDATA_SELECT_INPUT_1 = 7U , kIOMUXC_ENET_MAC0_RXEN_SELECT_INPUT = 8U ,
  kIOMUXC_ENET_MAC0_RXERR_SELECT_INPUT = 9U , kIOMUXC_ENET_MAC0_TXCLK_SELECT_INPUT = 10U , kIOMUXC_ENET_1G_IPG_CLK_RMII_SELECT_INPUT = 11U , kIOMUXC_ENET_1G_MAC0_MDIO_SELECT_INPUT = 12U ,
  kIOMUXC_ENET_1G_MAC0_RXCLK_SELECT_INPUT = 13U , kIOMUXC_ENET_1G_MAC0_RXDATA_0_SELECT_INPUT = 14U , kIOMUXC_ENET_1G_MAC0_RXDATA_1_SELECT_INPUT = 15U , kIOMUXC_ENET_1G_MAC0_RXDATA_2_SELECT_INPUT = 16U ,
  kIOMUXC_ENET_1G_MAC0_RXDATA_3_SELECT_INPUT = 17U , kIOMUXC_ENET_1G_MAC0_RXEN_SELECT_INPUT = 18U , kIOMUXC_ENET_1G_MAC0_RXERR_SELECT_INPUT = 19U , kIOMUXC_ENET_1G_MAC0_TXCLK_SELECT_INPUT = 20U ,
  kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_0 = 26U , kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_1 = 27U , kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_2 = 28U , kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_0 = 29U ,
  kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_1 = 30U , kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_2 = 31U , kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_0 = 32U , kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_1 = 33U ,
  kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_2 = 34U , kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_0 = 35U , kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_1 = 36U , kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_2 = 37U ,
  kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_0 = 38U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_1 = 39U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_2 = 40U , kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_3 = 41U ,
  kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_0 = 42U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_1 = 43U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_2 = 44U , kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_3 = 45U ,
  kIOMUXC_FLEXSPI1_I_DQS_FA_SELECT_INPUT = 46U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_0 = 47U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_1 = 48U , kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_2 = 49U ,
  kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_3 = 50U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_0 = 51U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_1 = 52U , kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_2 = 53U ,
  kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_3 = 54U , kIOMUXC_FLEXSPI1_I_SCK_FA_SELECT_INPUT = 55U , kIOMUXC_FLEXSPI1_I_SCK_FB_SELECT_INPUT = 56U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_0 = 57U ,
  kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_1 = 58U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_2 = 59U , kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_3 = 60U , kIOMUXC_FLEXSPI2_I_SCK_FA_SELECT_INPUT = 61U ,
  kIOMUXC_GPT3_CAPIN1_SELECT_INPUT = 62U , kIOMUXC_GPT3_CAPIN2_SELECT_INPUT = 63U , kIOMUXC_GPT3_CLKIN_SELECT_INPUT = 64U , kIOMUXC_KPP_COL_SELECT_INPUT_6 = 65U ,
  kIOMUXC_KPP_COL_SELECT_INPUT_7 = 66U , kIOMUXC_KPP_ROW_SELECT_INPUT_6 = 67U , kIOMUXC_KPP_ROW_SELECT_INPUT_7 = 68U , kIOMUXC_LPI2C1_LPI2C_SCL_SELECT_INPUT = 69U ,
  kIOMUXC_LPI2C1_LPI2C_SDA_SELECT_INPUT = 70U , kIOMUXC_LPI2C2_LPI2C_SCL_SELECT_INPUT = 71U , kIOMUXC_LPI2C2_LPI2C_SDA_SELECT_INPUT = 72U , kIOMUXC_LPI2C3_LPI2C_SCL_SELECT_INPUT = 73U ,
  kIOMUXC_LPI2C3_LPI2C_SDA_SELECT_INPUT = 74U , kIOMUXC_LPI2C4_LPI2C_SCL_SELECT_INPUT = 75U , kIOMUXC_LPI2C4_LPI2C_SDA_SELECT_INPUT = 76U , kIOMUXC_LPSPI1_LPSPI_PCS_SELECT_INPUT_0 = 77U ,
  kIOMUXC_LPSPI1_LPSPI_SCK_SELECT_INPUT = 78U , kIOMUXC_LPSPI1_LPSPI_SDI_SELECT_INPUT = 79U , kIOMUXC_LPSPI1_LPSPI_SDO_SELECT_INPUT = 80U , kIOMUXC_LPSPI2_LPSPI_PCS_SELECT_INPUT_0 = 81U ,
  kIOMUXC_LPSPI2_LPSPI_PCS_SELECT_INPUT_1 = 82U , kIOMUXC_LPSPI2_LPSPI_SCK_SELECT_INPUT = 83U , kIOMUXC_LPSPI2_LPSPI_SDI_SELECT_INPUT = 84U , kIOMUXC_LPSPI2_LPSPI_SDO_SELECT_INPUT = 85U ,
  kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_0 = 86U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_1 = 87U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_2 = 88U , kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_3 = 89U ,
  kIOMUXC_LPSPI3_LPSPI_SCK_SELECT_INPUT = 90U , kIOMUXC_LPSPI3_LPSPI_SDI_SELECT_INPUT = 91U , kIOMUXC_LPSPI3_LPSPI_SDO_SELECT_INPUT = 92U , kIOMUXC_LPSPI4_LPSPI_PCS_SELECT_INPUT_0 = 93U ,
  kIOMUXC_LPSPI4_LPSPI_SCK_SELECT_INPUT = 94U , kIOMUXC_LPSPI4_LPSPI_SDI_SELECT_INPUT = 95U , kIOMUXC_LPSPI4_LPSPI_SDO_SELECT_INPUT = 96U , kIOMUXC_LPUART1_LPUART_RXD_SELECT_INPUT = 97U ,
  kIOMUXC_LPUART1_LPUART_TXD_SELECT_INPUT = 98U , kIOMUXC_LPUART10_LPUART_RXD_SELECT_INPUT = 99U , kIOMUXC_LPUART10_LPUART_TXD_SELECT_INPUT = 100U , kIOMUXC_LPUART7_LPUART_RXD_SELECT_INPUT = 101U ,
  kIOMUXC_LPUART7_LPUART_TXD_SELECT_INPUT = 102U , kIOMUXC_LPUART8_LPUART_RXD_SELECT_INPUT = 103U , kIOMUXC_LPUART8_LPUART_TXD_SELECT_INPUT = 104U , kIOMUXC_QTIMER1_TMR0_INPUT_SELECT_INPUT = 105U ,
  kIOMUXC_QTIMER1_TMR1_INPUT_SELECT_INPUT = 106U , kIOMUXC_QTIMER1_TMR2_INPUT_SELECT_INPUT = 107U , kIOMUXC_QTIMER2_TMR0_INPUT_SELECT_INPUT = 108U , kIOMUXC_QTIMER2_TMR1_INPUT_SELECT_INPUT = 109U ,
  kIOMUXC_QTIMER2_TMR2_INPUT_SELECT_INPUT = 110U , kIOMUXC_QTIMER3_TMR0_INPUT_SELECT_INPUT = 111U , kIOMUXC_QTIMER3_TMR1_INPUT_SELECT_INPUT = 112U , kIOMUXC_QTIMER3_TMR2_INPUT_SELECT_INPUT = 113U ,
  kIOMUXC_QTIMER4_TMR0_INPUT_SELECT_INPUT = 114U , kIOMUXC_QTIMER4_TMR1_INPUT_SELECT_INPUT = 115U , kIOMUXC_QTIMER4_TMR2_INPUT_SELECT_INPUT = 116U , kIOMUXC_SAI1_IPG_CLK_SAI_MCLK_SELECT_INPUT = 117U ,
  kIOMUXC_SAI1_SAI_RXBCLK_SELECT_INPUT = 118U , kIOMUXC_SAI1_SAI_RXDATA_SELECT_INPUT_0 = 119U , kIOMUXC_SAI1_SAI_RXSYNC_SELECT_INPUT = 120U , kIOMUXC_SAI1_SAI_TXBCLK_SELECT_INPUT = 121U ,
  kIOMUXC_SAI1_SAI_TXSYNC_SELECT_INPUT = 122U , kIOMUXC_EMVSIM1_SIO_SELECT_INPUT = 129U , kIOMUXC_EMVSIM1_IPP_SIMPD_SELECT_INPUT = 130U , kIOMUXC_EMVSIM1_POWER_FAIL_SELECT_INPUT = 131U ,
  kIOMUXC_EMVSIM2_SIO_SELECT_INPUT = 132U , kIOMUXC_EMVSIM2_IPP_SIMPD_SELECT_INPUT = 133U , kIOMUXC_EMVSIM2_POWER_FAIL_SELECT_INPUT = 134U , kIOMUXC_SPDIF_SPDIF_IN1_SELECT_INPUT = 135U ,
  kIOMUXC_USB_OTG2_OC_SELECT_INPUT = 136U , kIOMUXC_USB_OTG_OC_SELECT_INPUT = 137U , kIOMUXC_USBPHY1_USB_ID_SELECT_INPUT = 138U , kIOMUXC_USBPHY2_USB_ID_SELECT_INPUT = 139U ,
  kIOMUXC_USDHC1_IPP_CARD_DET_SELECT_INPUT = 140U , kIOMUXC_USDHC1_IPP_WP_ON_SELECT_INPUT = 141U , kIOMUXC_USDHC2_IPP_CARD_DET_SELECT_INPUT = 142U , kIOMUXC_USDHC2_IPP_WP_ON_SELECT_INPUT = 143U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_20 = 144U , kIOMUXC_XBAR1_IN_SELECT_INPUT_21 = 145U , kIOMUXC_XBAR1_IN_SELECT_INPUT_22 = 146U , kIOMUXC_XBAR1_IN_SELECT_INPUT_23 = 147U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_24 = 148U , kIOMUXC_XBAR1_IN_SELECT_INPUT_25 = 149U , kIOMUXC_XBAR1_IN_SELECT_INPUT_26 = 150U , kIOMUXC_XBAR1_IN_SELECT_INPUT_27 = 151U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_28 = 152U , kIOMUXC_XBAR1_IN_SELECT_INPUT_29 = 153U , kIOMUXC_XBAR1_IN_SELECT_INPUT_30 = 154U , kIOMUXC_XBAR1_IN_SELECT_INPUT_31 = 155U ,
  kIOMUXC_XBAR1_IN_SELECT_INPUT_32 = 156U , kIOMUXC_XBAR1_IN_SELECT_INPUT_33 = 157U , kIOMUXC_XBAR1_IN_SELECT_INPUT_34 = 158U , kIOMUXC_XBAR1_IN_SELECT_INPUT_35 = 159U
 Enumeration for the IOMUXC select input. More...
__IO uint32_t ADC_Type::HC [8]
__I uint32_t ADC_Type::HS
__I uint32_t ADC_Type::R [8]
__IO uint32_t ADC_Type::CFG
__IO uint32_t ADC_Type::GC
__IO uint32_t ADC_Type::GS
__IO uint32_t ADC_Type::CV
__IO uint32_t ADC_Type::OFS
__IO uint32_t ADC_Type::CAL
__IO uint32_t ADC_ETC_Type::CTRL
__IO uint32_t ADC_ETC_Type::DONE0_1_IRQ
__IO uint32_t ADC_ETC_Type::DONE2_3_ERR_IRQ
__IO uint32_t ADC_ETC_Type::DMA_CTRL
__IO uint32_t   ADC_ETC_Type::TRIGn_CTRL
__IO uint32_t   ADC_ETC_Type::TRIGn_COUNTER
__IO uint32_t   ADC_ETC_Type::TRIGn_CHAIN_1_0
__IO uint32_t   ADC_ETC_Type::TRIGn_CHAIN_3_2
__IO uint32_t   ADC_ETC_Type::TRIGn_CHAIN_5_4
__IO uint32_t   ADC_ETC_Type::TRIGn_CHAIN_7_6
__I uint32_t   ADC_ETC_Type::TRIGn_RESULT_1_0
__I uint32_t   ADC_ETC_Type::TRIGn_RESULT_3_2
__I uint32_t   ADC_ETC_Type::TRIGn_RESULT_5_4
__I uint32_t   ADC_ETC_Type::TRIGn_RESULT_7_6
struct {
ADC_ETC_Type::TRIG [8]
__IO uint32_t AIPSTZ_Type::MPR
uint8_t AIPSTZ_Type::RESERVED_0 [60]
__IO uint32_t AIPSTZ_Type::OPACR
__IO uint32_t AIPSTZ_Type::OPACR1
__IO uint32_t AIPSTZ_Type::OPACR2
__IO uint32_t AIPSTZ_Type::OPACR3
__IO uint32_t AIPSTZ_Type::OPACR4
__IO uint16_t   AOI_Type::BFCRT01
__IO uint16_t   AOI_Type::BFCRT23
struct {
AOI_Type::BFCRT [4]
__IO uint32_t BEE_Type::CTRL
__IO uint32_t BEE_Type::ADDR_OFFSET0
__IO uint32_t BEE_Type::ADDR_OFFSET1
__IO uint32_t BEE_Type::AES_KEY0_W0
__IO uint32_t BEE_Type::AES_KEY0_W1
__IO uint32_t BEE_Type::AES_KEY0_W2
__IO uint32_t BEE_Type::AES_KEY0_W3
__IO uint32_t BEE_Type::STATUS
__O uint32_t BEE_Type::CTR_NONCE0_W0
__O uint32_t BEE_Type::CTR_NONCE0_W1
__O uint32_t BEE_Type::CTR_NONCE0_W2
__O uint32_t BEE_Type::CTR_NONCE0_W3
__O uint32_t BEE_Type::CTR_NONCE1_W0
__O uint32_t BEE_Type::CTR_NONCE1_W1
__O uint32_t BEE_Type::CTR_NONCE1_W2
__O uint32_t BEE_Type::CTR_NONCE1_W3
__IO uint32_t BEE_Type::REGION1_TOP
__IO uint32_t BEE_Type::REGION1_BOT
__IO uint32_t CAN_Type::MCR
__IO uint32_t CAN_Type::CTRL1
__IO uint32_t CAN_Type::TIMER
uint8_t CAN_Type::RESERVED_0 [4]
__IO uint32_t CAN_Type::RXMGMASK
__IO uint32_t CAN_Type::RX14MASK
__IO uint32_t CAN_Type::RX15MASK
__IO uint32_t CAN_Type::ECR
__IO uint32_t CAN_Type::ESR1
__IO uint32_t CAN_Type::IMASK2
__IO uint32_t CAN_Type::IMASK1
__IO uint32_t CAN_Type::IFLAG2
__IO uint32_t CAN_Type::IFLAG1
__IO uint32_t CAN_Type::CTRL2
__I uint32_t CAN_Type::ESR2
uint8_t CAN_Type::RESERVED_1 [8]
__I uint32_t CAN_Type::CRCR
__IO uint32_t CAN_Type::RXFGMASK
__I uint32_t CAN_Type::RXFIR
uint8_t CAN_Type::RESERVED_2 [8]
__I uint32_t CAN_Type::DBG1
__I uint32_t CAN_Type::DBG2
uint8_t CAN_Type::RESERVED_3 [32]
__IO uint32_t   CAN_Type::CS
__IO uint32_t   CAN_Type::ID
__IO uint32_t   CAN_Type::WORD0
__IO uint32_t   CAN_Type::WORD1
struct {
CAN_Type::MB [64]
uint8_t CAN_Type::RESERVED_4 [1024]
__IO uint32_t CAN_Type::RXIMR [64]
uint8_t CAN_Type::RESERVED_5 [96]
__IO uint32_t CAN_Type::GFWR
__IO uint32_t CCM_Type::CCR
uint8_t CCM_Type::RESERVED_0 [4]
__I uint32_t CCM_Type::CSR
__IO uint32_t CCM_Type::CCSR
__IO uint32_t CCM_Type::CACRR
__IO uint32_t CCM_Type::CBCDR
__IO uint32_t CCM_Type::CBCMR
__IO uint32_t CCM_Type::CSCMR1
__IO uint32_t CCM_Type::CSCMR2
__IO uint32_t CCM_Type::CSCDR1
__IO uint32_t CCM_Type::CS1CDR
__IO uint32_t CCM_Type::CS2CDR
__IO uint32_t CCM_Type::CDCDR
uint8_t CCM_Type::RESERVED_1 [4]
__IO uint32_t CCM_Type::CSCDR2
__IO uint32_t CCM_Type::CSCDR3
uint8_t CCM_Type::RESERVED_2 [8]
__I uint32_t CCM_Type::CDHIPR
uint8_t CCM_Type::RESERVED_3 [8]
__IO uint32_t CCM_Type::CLPCR
__IO uint32_t CCM_Type::CISR
__IO uint32_t CCM_Type::CIMR
__IO uint32_t CCM_Type::CCOSR
__IO uint32_t CCM_Type::CGPR
__IO uint32_t CCM_Type::CCGR0
__IO uint32_t CCM_Type::CCGR1
__IO uint32_t CCM_Type::CCGR2
__IO uint32_t CCM_Type::CCGR3
__IO uint32_t CCM_Type::CCGR4
__IO uint32_t CCM_Type::CCGR5
__IO uint32_t CCM_Type::CCGR6
uint8_t CCM_Type::RESERVED_4 [4]
__IO uint32_t CCM_Type::CMEOR
__IO uint32_t CCM_ANALOG_Type::PLL_ARM
__IO uint32_t CCM_ANALOG_Type::PLL_ARM_SET
__IO uint32_t CCM_ANALOG_Type::PLL_ARM_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_ARM_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_USB1
__IO uint32_t CCM_ANALOG_Type::PLL_USB1_SET
__IO uint32_t CCM_ANALOG_Type::PLL_USB1_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_USB1_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_USB2
__IO uint32_t CCM_ANALOG_Type::PLL_USB2_SET
__IO uint32_t CCM_ANALOG_Type::PLL_USB2_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_USB2_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_SYS
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_SET
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_SS
uint8_t CCM_ANALOG_Type::RESERVED_0 [12]
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_NUM
uint8_t CCM_ANALOG_Type::RESERVED_1 [12]
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_DENOM
uint8_t CCM_ANALOG_Type::RESERVED_2 [12]
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO_SET
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO_NUM
uint8_t CCM_ANALOG_Type::RESERVED_3 [12]
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO_DENOM
uint8_t CCM_ANALOG_Type::RESERVED_4 [12]
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO_SET
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO_NUM
uint8_t CCM_ANALOG_Type::RESERVED_5 [12]
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO_DENOM
uint8_t CCM_ANALOG_Type::RESERVED_6 [28]
__IO uint32_t CCM_ANALOG_Type::PLL_ENET
__IO uint32_t CCM_ANALOG_Type::PLL_ENET_SET
__IO uint32_t CCM_ANALOG_Type::PLL_ENET_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_ENET_TOG
__IO uint32_t CCM_ANALOG_Type::PFD_480
__IO uint32_t CCM_ANALOG_Type::PFD_480_SET
__IO uint32_t CCM_ANALOG_Type::PFD_480_CLR
__IO uint32_t CCM_ANALOG_Type::PFD_480_TOG
__IO uint32_t CCM_ANALOG_Type::PFD_528
__IO uint32_t CCM_ANALOG_Type::PFD_528_SET
__IO uint32_t CCM_ANALOG_Type::PFD_528_CLR
__IO uint32_t CCM_ANALOG_Type::PFD_528_TOG
uint8_t CCM_ANALOG_Type::RESERVED_7 [64]
__IO uint32_t CCM_ANALOG_Type::MISC0
__IO uint32_t CCM_ANALOG_Type::MISC0_SET
__IO uint32_t CCM_ANALOG_Type::MISC0_CLR
__IO uint32_t CCM_ANALOG_Type::MISC0_TOG
__IO uint32_t CCM_ANALOG_Type::MISC1
__IO uint32_t CCM_ANALOG_Type::MISC1_SET
__IO uint32_t CCM_ANALOG_Type::MISC1_CLR
__IO uint32_t CCM_ANALOG_Type::MISC1_TOG
__IO uint32_t CCM_ANALOG_Type::MISC2
__IO uint32_t CCM_ANALOG_Type::MISC2_SET
__IO uint32_t CCM_ANALOG_Type::MISC2_CLR
__IO uint32_t CCM_ANALOG_Type::MISC2_TOG
uint8_t CM7_MCM_Type::RESERVED_0 [16]
__IO uint32_t CM7_MCM_Type::ISCR
__IO uint8_t CMP_Type::CR0
__IO uint8_t CMP_Type::CR1
__IO uint8_t CMP_Type::FPR
__IO uint8_t CMP_Type::SCR
__IO uint8_t CMP_Type::DACCR
__IO uint8_t CMP_Type::MUXCR
__IO uint32_t CSI_Type::CR1
__IO uint32_t CSI_Type::CR2
__IO uint32_t CSI_Type::CR3
__I uint32_t CSI_Type::STATFIFO
__I uint32_t CSI_Type::RFIFO
__IO uint32_t CSI_Type::RXCNT
__IO uint32_t CSI_Type::SR
uint8_t CSI_Type::RESERVED_0 [4]
__IO uint32_t CSI_Type::DMASA_STATFIFO
__IO uint32_t CSI_Type::DMATS_STATFIFO
__IO uint32_t CSI_Type::DMASA_FB1
__IO uint32_t CSI_Type::DMASA_FB2
__IO uint32_t CSI_Type::FBUF_PARA
__IO uint32_t CSI_Type::IMAG_PARA
uint8_t CSI_Type::RESERVED_1 [16]
__IO uint32_t CSI_Type::CR18
__IO uint32_t CSI_Type::CR19
__IO uint32_t CSU_Type::CSL [32]
uint8_t CSU_Type::RESERVED_0 [384]
__IO uint32_t CSU_Type::HP0
uint8_t CSU_Type::RESERVED_1 [20]
__IO uint32_t CSU_Type::SA
uint8_t CSU_Type::RESERVED_2 [316]
__IO uint32_t CSU_Type::HPCONTROL0
__IO uint32_t DCDC_Type::REG0
__IO uint32_t DCDC_Type::REG1
__IO uint32_t DCDC_Type::REG2
__IO uint32_t DCDC_Type::REG3
__IO uint32_t DCP_Type::CTRL
__IO uint32_t DCP_Type::CTRL_SET
__IO uint32_t DCP_Type::CTRL_CLR
__IO uint32_t DCP_Type::CTRL_TOG
__IO uint32_t DCP_Type::STAT
__IO uint32_t DCP_Type::STAT_SET
__IO uint32_t DCP_Type::STAT_CLR
__IO uint32_t DCP_Type::STAT_TOG
__IO uint32_t DCP_Type::CHANNELCTRL
__IO uint32_t DCP_Type::CHANNELCTRL_SET
__IO uint32_t DCP_Type::CHANNELCTRL_CLR
__IO uint32_t DCP_Type::CHANNELCTRL_TOG
__IO uint32_t DCP_Type::CAPABILITY0
uint8_t DCP_Type::RESERVED_0 [12]
__I uint32_t DCP_Type::CAPABILITY1
uint8_t DCP_Type::RESERVED_1 [12]
__IO uint32_t DCP_Type::CONTEXT
uint8_t DCP_Type::RESERVED_2 [12]
__IO uint32_t DCP_Type::KEY
uint8_t DCP_Type::RESERVED_3 [12]
__IO uint32_t DCP_Type::KEYDATA
uint8_t DCP_Type::RESERVED_4 [12]
__I uint32_t DCP_Type::PACKET0
uint8_t DCP_Type::RESERVED_5 [12]
__I uint32_t DCP_Type::PACKET1
uint8_t DCP_Type::RESERVED_6 [12]
__I uint32_t DCP_Type::PACKET2
uint8_t DCP_Type::RESERVED_7 [12]
__I uint32_t DCP_Type::PACKET3
uint8_t DCP_Type::RESERVED_8 [12]
__I uint32_t DCP_Type::PACKET4
uint8_t DCP_Type::RESERVED_9 [12]
__I uint32_t DCP_Type::PACKET5
uint8_t DCP_Type::RESERVED_10 [12]
__I uint32_t DCP_Type::PACKET6
uint8_t DCP_Type::RESERVED_11 [28]
__IO uint32_t DCP_Type::CH0CMDPTR
uint8_t DCP_Type::RESERVED_12 [12]
__IO uint32_t DCP_Type::CH0SEMA
uint8_t DCP_Type::RESERVED_13 [12]
__IO uint32_t DCP_Type::CH0STAT
__IO uint32_t DCP_Type::CH0STAT_SET
__IO uint32_t DCP_Type::CH0STAT_CLR
__IO uint32_t DCP_Type::CH0STAT_TOG
__IO uint32_t DCP_Type::CH0OPTS
__IO uint32_t DCP_Type::CH0OPTS_SET
__IO uint32_t DCP_Type::CH0OPTS_CLR
__IO uint32_t DCP_Type::CH0OPTS_TOG
__IO uint32_t DCP_Type::CH1CMDPTR
uint8_t DCP_Type::RESERVED_14 [12]
__IO uint32_t DCP_Type::CH1SEMA
uint8_t DCP_Type::RESERVED_15 [12]
__IO uint32_t DCP_Type::CH1STAT
__IO uint32_t DCP_Type::CH1STAT_SET
__IO uint32_t DCP_Type::CH1STAT_CLR
__IO uint32_t DCP_Type::CH1STAT_TOG
__IO uint32_t DCP_Type::CH1OPTS
__IO uint32_t DCP_Type::CH1OPTS_SET
__IO uint32_t DCP_Type::CH1OPTS_CLR
__IO uint32_t DCP_Type::CH1OPTS_TOG
__IO uint32_t DCP_Type::CH2CMDPTR
uint8_t DCP_Type::RESERVED_16 [12]
__IO uint32_t DCP_Type::CH2SEMA
uint8_t DCP_Type::RESERVED_17 [12]
__IO uint32_t DCP_Type::CH2STAT
__IO uint32_t DCP_Type::CH2STAT_SET
__IO uint32_t DCP_Type::CH2STAT_CLR
__IO uint32_t DCP_Type::CH2STAT_TOG
__IO uint32_t DCP_Type::CH2OPTS
__IO uint32_t DCP_Type::CH2OPTS_SET
__IO uint32_t DCP_Type::CH2OPTS_CLR
__IO uint32_t DCP_Type::CH2OPTS_TOG
__IO uint32_t DCP_Type::CH3CMDPTR
uint8_t DCP_Type::RESERVED_18 [12]
__IO uint32_t DCP_Type::CH3SEMA
uint8_t DCP_Type::RESERVED_19 [12]
__IO uint32_t DCP_Type::CH3STAT
__IO uint32_t DCP_Type::CH3STAT_SET
__IO uint32_t DCP_Type::CH3STAT_CLR
__IO uint32_t DCP_Type::CH3STAT_TOG
__IO uint32_t DCP_Type::CH3OPTS
__IO uint32_t DCP_Type::CH3OPTS_SET
__IO uint32_t DCP_Type::CH3OPTS_CLR
__IO uint32_t DCP_Type::CH3OPTS_TOG
uint8_t DCP_Type::RESERVED_20 [512]
__IO uint32_t DCP_Type::DBGSELECT
uint8_t DCP_Type::RESERVED_21 [12]
__I uint32_t DCP_Type::DBGDATA
uint8_t DCP_Type::RESERVED_22 [12]
__IO uint32_t DCP_Type::PAGETABLE
uint8_t DCP_Type::RESERVED_23 [12]
__I uint32_t DCP_Type::VERSION
__IO uint32_t DMA_Type::CR
__I uint32_t DMA_Type::ES
uint8_t DMA_Type::RESERVED_0 [4]
__IO uint32_t DMA_Type::ERQ
uint8_t DMA_Type::RESERVED_1 [4]
__IO uint32_t DMA_Type::EEI
__O uint8_t DMA_Type::CEEI
__O uint8_t DMA_Type::SEEI
__O uint8_t DMA_Type::CERQ
__O uint8_t DMA_Type::SERQ
__O uint8_t DMA_Type::CDNE
__O uint8_t DMA_Type::SSRT
__O uint8_t DMA_Type::CERR
__O uint8_t DMA_Type::CINT
uint8_t DMA_Type::RESERVED_2 [4]
__IO uint32_t DMA_Type::INT
uint8_t DMA_Type::RESERVED_3 [4]
__IO uint32_t DMA_Type::ERR
uint8_t DMA_Type::RESERVED_4 [4]
__I uint32_t DMA_Type::HRS
uint8_t DMA_Type::RESERVED_5 [12]
__IO uint32_t DMA_Type::EARS
uint8_t DMA_Type::RESERVED_6 [184]
__IO uint8_t DMA_Type::DCHPRI3
__IO uint8_t DMA_Type::DCHPRI2
__IO uint8_t DMA_Type::DCHPRI1
__IO uint8_t DMA_Type::DCHPRI0
__IO uint8_t DMA_Type::DCHPRI7
__IO uint8_t DMA_Type::DCHPRI6
__IO uint8_t DMA_Type::DCHPRI5
__IO uint8_t DMA_Type::DCHPRI4
__IO uint8_t DMA_Type::DCHPRI11
__IO uint8_t DMA_Type::DCHPRI10
__IO uint8_t DMA_Type::DCHPRI9
__IO uint8_t DMA_Type::DCHPRI8
__IO uint8_t DMA_Type::DCHPRI15
__IO uint8_t DMA_Type::DCHPRI14
__IO uint8_t DMA_Type::DCHPRI13
__IO uint8_t DMA_Type::DCHPRI12
__IO uint8_t DMA_Type::DCHPRI19
__IO uint8_t DMA_Type::DCHPRI18
__IO uint8_t DMA_Type::DCHPRI17
__IO uint8_t DMA_Type::DCHPRI16
__IO uint8_t DMA_Type::DCHPRI23
__IO uint8_t DMA_Type::DCHPRI22
__IO uint8_t DMA_Type::DCHPRI21
__IO uint8_t DMA_Type::DCHPRI20
__IO uint8_t DMA_Type::DCHPRI27
__IO uint8_t DMA_Type::DCHPRI26
__IO uint8_t DMA_Type::DCHPRI25
__IO uint8_t DMA_Type::DCHPRI24
__IO uint8_t DMA_Type::DCHPRI31
__IO uint8_t DMA_Type::DCHPRI30
__IO uint8_t DMA_Type::DCHPRI29
__IO uint8_t DMA_Type::DCHPRI28
uint8_t DMA_Type::RESERVED_7 [3808]
__IO uint32_t   DMA_Type::SADDR
__IO uint16_t   DMA_Type::SOFF
__IO uint16_t   DMA_Type::ATTR
__IO uint32_t   DMA_Type::NBYTES_MLNO
__IO uint32_t   DMA_Type::NBYTES_MLOFFNO
__IO uint32_t   DMA_Type::NBYTES_MLOFFYES
union {
__IO int32_t   DMA_Type::SLAST
__IO uint32_t   DMA_Type::DADDR
__IO uint16_t   DMA_Type::DOFF
__IO uint16_t   DMA_Type::CITER_ELINKNO
__IO uint16_t   DMA_Type::CITER_ELINKYES
union {
__IO int32_t   DMA_Type::DLAST_SGA
__IO uint16_t   DMA_Type::CSR
__IO uint16_t   DMA_Type::BITER_ELINKNO
__IO uint16_t   DMA_Type::BITER_ELINKYES
union {
struct {
   union {
   union {
   union {
DMA_Type::TCD [32]
__IO uint32_t DMAMUX_Type::CHCFG [32]
__IO uint16_t ENC_Type::CTRL
__IO uint16_t ENC_Type::FILT
__IO uint16_t ENC_Type::WTR
__IO uint16_t ENC_Type::POSD
__I uint16_t ENC_Type::POSDH
__IO uint16_t ENC_Type::REV
__I uint16_t ENC_Type::REVH
__IO uint16_t ENC_Type::UPOS
__IO uint16_t ENC_Type::LPOS
__I uint16_t ENC_Type::UPOSH
__I uint16_t ENC_Type::LPOSH
__IO uint16_t ENC_Type::UINIT
__IO uint16_t ENC_Type::LINIT
__I uint16_t ENC_Type::IMR
__IO uint16_t ENC_Type::TST
__IO uint16_t ENC_Type::CTRL2
__IO uint16_t ENC_Type::UMOD
__IO uint16_t ENC_Type::LMOD
__IO uint16_t ENC_Type::UCOMP
__IO uint16_t ENC_Type::LCOMP
uint8_t ENET_Type::RESERVED_0 [4]
__IO uint32_t ENET_Type::EIR
__IO uint32_t ENET_Type::EIMR
uint8_t ENET_Type::RESERVED_1 [4]
__IO uint32_t ENET_Type::RDAR
__IO uint32_t ENET_Type::TDAR
uint8_t ENET_Type::RESERVED_2 [12]
__IO uint32_t ENET_Type::ECR
uint8_t ENET_Type::RESERVED_3 [24]
__IO uint32_t ENET_Type::MMFR
__IO uint32_t ENET_Type::MSCR
uint8_t ENET_Type::RESERVED_4 [28]
__IO uint32_t ENET_Type::MIBC
uint8_t ENET_Type::RESERVED_5 [28]
__IO uint32_t ENET_Type::RCR
uint8_t ENET_Type::RESERVED_6 [60]
__IO uint32_t ENET_Type::TCR
uint8_t ENET_Type::RESERVED_7 [28]
__IO uint32_t ENET_Type::PALR
__IO uint32_t ENET_Type::PAUR
__IO uint32_t ENET_Type::OPD
__IO uint32_t ENET_Type::TXIC [1]
uint8_t ENET_Type::RESERVED_8 [12]
__IO uint32_t ENET_Type::RXIC [1]
uint8_t ENET_Type::RESERVED_9 [20]
__IO uint32_t ENET_Type::IAUR
__IO uint32_t ENET_Type::IALR
__IO uint32_t ENET_Type::GAUR
__IO uint32_t ENET_Type::GALR
uint8_t ENET_Type::RESERVED_10 [28]
__IO uint32_t ENET_Type::TFWR
uint8_t ENET_Type::RESERVED_11 [56]
__IO uint32_t ENET_Type::RDSR
__IO uint32_t ENET_Type::TDSR
__IO uint32_t ENET_Type::MRBR
uint8_t ENET_Type::RESERVED_12 [4]
__IO uint32_t ENET_Type::RSFL
__IO uint32_t ENET_Type::RSEM
__IO uint32_t ENET_Type::RAEM
__IO uint32_t ENET_Type::RAFL
__IO uint32_t ENET_Type::TSEM
__IO uint32_t ENET_Type::TAEM
__IO uint32_t ENET_Type::TAFL
__IO uint32_t ENET_Type::TIPG
__IO uint32_t ENET_Type::FTRL
uint8_t ENET_Type::RESERVED_13 [12]
__IO uint32_t ENET_Type::TACC
__IO uint32_t ENET_Type::RACC
uint8_t ENET_Type::RESERVED_14 [60]
__I uint32_t ENET_Type::RMON_T_PACKETS
__I uint32_t ENET_Type::RMON_T_BC_PKT
__I uint32_t ENET_Type::RMON_T_MC_PKT
__I uint32_t ENET_Type::RMON_T_CRC_ALIGN
__I uint32_t ENET_Type::RMON_T_UNDERSIZE
__I uint32_t ENET_Type::RMON_T_OVERSIZE
__I uint32_t ENET_Type::RMON_T_FRAG
__I uint32_t ENET_Type::RMON_T_JAB
__I uint32_t ENET_Type::RMON_T_COL
__I uint32_t ENET_Type::RMON_T_P64
__I uint32_t ENET_Type::RMON_T_P65TO127
__I uint32_t ENET_Type::RMON_T_P128TO255
__I uint32_t ENET_Type::RMON_T_P256TO511
__I uint32_t ENET_Type::RMON_T_P512TO1023
__I uint32_t ENET_Type::RMON_T_P1024TO2047
__I uint32_t ENET_Type::RMON_T_P_GTE2048
__I uint32_t ENET_Type::RMON_T_OCTETS
uint8_t ENET_Type::RESERVED_15 [4]
__I uint32_t ENET_Type::IEEE_T_FRAME_OK
__I uint32_t ENET_Type::IEEE_T_1COL
__I uint32_t ENET_Type::IEEE_T_MCOL
__I uint32_t ENET_Type::IEEE_T_DEF
__I uint32_t ENET_Type::IEEE_T_LCOL
__I uint32_t ENET_Type::IEEE_T_EXCOL
__I uint32_t ENET_Type::IEEE_T_MACERR
__I uint32_t ENET_Type::IEEE_T_CSERR
__I uint32_t ENET_Type::IEEE_T_SQE
__I uint32_t ENET_Type::IEEE_T_FDXFC
__I uint32_t ENET_Type::IEEE_T_OCTETS_OK
uint8_t ENET_Type::RESERVED_16 [12]
__I uint32_t ENET_Type::RMON_R_PACKETS
__I uint32_t ENET_Type::RMON_R_BC_PKT
__I uint32_t ENET_Type::RMON_R_MC_PKT
__I uint32_t ENET_Type::RMON_R_CRC_ALIGN
__I uint32_t ENET_Type::RMON_R_UNDERSIZE
__I uint32_t ENET_Type::RMON_R_OVERSIZE
__I uint32_t ENET_Type::RMON_R_FRAG
__I uint32_t ENET_Type::RMON_R_JAB
uint8_t ENET_Type::RESERVED_17 [4]
__I uint32_t ENET_Type::RMON_R_P64
__I uint32_t ENET_Type::RMON_R_P65TO127
__I uint32_t ENET_Type::RMON_R_P128TO255
__I uint32_t ENET_Type::RMON_R_P256TO511
__I uint32_t ENET_Type::RMON_R_P512TO1023
__I uint32_t ENET_Type::RMON_R_P1024TO2047
__I uint32_t ENET_Type::RMON_R_P_GTE2048
__I uint32_t ENET_Type::RMON_R_OCTETS
__I uint32_t ENET_Type::IEEE_R_DROP
__I uint32_t ENET_Type::IEEE_R_FRAME_OK
__I uint32_t ENET_Type::IEEE_R_CRC
__I uint32_t ENET_Type::IEEE_R_ALIGN
__I uint32_t ENET_Type::IEEE_R_MACERR
__I uint32_t ENET_Type::IEEE_R_FDXFC
__I uint32_t ENET_Type::IEEE_R_OCTETS_OK
uint8_t ENET_Type::RESERVED_18 [284]
__IO uint32_t ENET_Type::ATCR
__IO uint32_t ENET_Type::ATVR
__IO uint32_t ENET_Type::ATOFF
__IO uint32_t ENET_Type::ATPER
__IO uint32_t ENET_Type::ATCOR
__IO uint32_t ENET_Type::ATINC
__I uint32_t ENET_Type::ATSTMP
uint8_t ENET_Type::RESERVED_19 [488]
__IO uint32_t ENET_Type::TGSR
__IO uint32_t   ENET_Type::TCSR
__IO uint32_t   ENET_Type::TCCR
struct {
ENET_Type::CHANNEL [4]
__IO uint8_t EWM_Type::CTRL
__O uint8_t EWM_Type::SERV
__IO uint8_t EWM_Type::CMPL
__IO uint8_t EWM_Type::CMPH
__IO uint8_t EWM_Type::CLKCTRL
__IO uint8_t EWM_Type::CLKPRESCALER
__I uint32_t FLEXIO_Type::VERID
__I uint32_t FLEXIO_Type::PARAM
__IO uint32_t FLEXIO_Type::CTRL
__I uint32_t FLEXIO_Type::PIN
__IO uint32_t FLEXIO_Type::SHIFTSTAT
__IO uint32_t FLEXIO_Type::SHIFTERR
__IO uint32_t FLEXIO_Type::TIMSTAT
uint8_t FLEXIO_Type::RESERVED_0 [4]
__IO uint32_t FLEXIO_Type::SHIFTSIEN
__IO uint32_t FLEXIO_Type::SHIFTEIEN
__IO uint32_t FLEXIO_Type::TIMIEN
uint8_t FLEXIO_Type::RESERVED_1 [4]
__IO uint32_t FLEXIO_Type::SHIFTSDEN
uint8_t FLEXIO_Type::RESERVED_2 [12]
__IO uint32_t FLEXIO_Type::SHIFTSTATE
uint8_t FLEXIO_Type::RESERVED_3 [60]
__IO uint32_t FLEXIO_Type::SHIFTCTL [4]
uint8_t FLEXIO_Type::RESERVED_4 [112]
__IO uint32_t FLEXIO_Type::SHIFTCFG [4]
uint8_t FLEXIO_Type::RESERVED_5 [240]
__IO uint32_t FLEXIO_Type::SHIFTBUF [4]
uint8_t FLEXIO_Type::RESERVED_6 [112]
__IO uint32_t FLEXIO_Type::SHIFTBUFBIS [4]
uint8_t FLEXIO_Type::RESERVED_7 [112]
__IO uint32_t FLEXIO_Type::SHIFTBUFBYS [4]
uint8_t FLEXIO_Type::RESERVED_8 [112]
__IO uint32_t FLEXIO_Type::SHIFTBUFBBS [4]
uint8_t FLEXIO_Type::RESERVED_9 [112]
__IO uint32_t FLEXIO_Type::TIMCTL [4]
uint8_t FLEXIO_Type::RESERVED_10 [112]
__IO uint32_t FLEXIO_Type::TIMCFG [4]
uint8_t FLEXIO_Type::RESERVED_11 [112]
__IO uint32_t FLEXIO_Type::TIMCMP [4]
uint8_t FLEXIO_Type::RESERVED_12 [368]
__IO uint32_t FLEXIO_Type::SHIFTBUFNBS [4]
uint8_t FLEXIO_Type::RESERVED_13 [112]
__IO uint32_t FLEXIO_Type::SHIFTBUFHWS [4]
uint8_t FLEXIO_Type::RESERVED_14 [112]
__IO uint32_t FLEXIO_Type::SHIFTBUFNIS [4]
__IO uint32_t FLEXRAM_Type::TCM_CTRL
uint8_t FLEXRAM_Type::RESERVED_0 [12]
__IO uint32_t FLEXRAM_Type::INT_STATUS
__IO uint32_t FLEXRAM_Type::INT_STAT_EN
__IO uint32_t FLEXRAM_Type::INT_SIG_EN
__IO uint32_t FLEXSPI_Type::MCR0
__IO uint32_t FLEXSPI_Type::MCR1
__IO uint32_t FLEXSPI_Type::MCR2
__IO uint32_t FLEXSPI_Type::AHBCR
__IO uint32_t FLEXSPI_Type::INTEN
__IO uint32_t FLEXSPI_Type::INTR
__IO uint32_t FLEXSPI_Type::LUTKEY
__IO uint32_t FLEXSPI_Type::LUTCR
__IO uint32_t FLEXSPI_Type::AHBRXBUFCR0 [4]
uint8_t FLEXSPI_Type::RESERVED_0 [48]
__IO uint32_t FLEXSPI_Type::FLSHCR0 [4]
__IO uint32_t FLEXSPI_Type::FLSHCR1 [4]
__IO uint32_t FLEXSPI_Type::FLSHCR2 [4]
uint8_t FLEXSPI_Type::RESERVED_1 [4]
__IO uint32_t FLEXSPI_Type::FLSHCR4
uint8_t FLEXSPI_Type::RESERVED_2 [8]
__IO uint32_t FLEXSPI_Type::IPCR0
__IO uint32_t FLEXSPI_Type::IPCR1
uint8_t FLEXSPI_Type::RESERVED_3 [8]
__IO uint32_t FLEXSPI_Type::IPCMD
uint8_t FLEXSPI_Type::RESERVED_4 [4]
__IO uint32_t FLEXSPI_Type::IPRXFCR
__IO uint32_t FLEXSPI_Type::IPTXFCR
__IO uint32_t FLEXSPI_Type::DLLCR [2]
uint8_t FLEXSPI_Type::RESERVED_5 [24]
__I uint32_t FLEXSPI_Type::STS0
__I uint32_t FLEXSPI_Type::STS1
__I uint32_t FLEXSPI_Type::STS2
__I uint32_t FLEXSPI_Type::AHBSPNDSTS
__I uint32_t FLEXSPI_Type::IPRXFSTS
__I uint32_t FLEXSPI_Type::IPTXFSTS
uint8_t FLEXSPI_Type::RESERVED_6 [8]
__I uint32_t FLEXSPI_Type::RFDR [32]
__O uint32_t FLEXSPI_Type::TFDR [32]
__IO uint32_t FLEXSPI_Type::LUT [64]
__IO uint32_t GPC_Type::CNTR
uint8_t GPC_Type::RESERVED_0 [4]
__IO uint32_t GPC_Type::IMR [4]
__I uint32_t GPC_Type::ISR [4]
uint8_t GPC_Type::RESERVED_1 [12]
__IO uint32_t GPC_Type::IMR5
__I uint32_t GPC_Type::ISR5
__IO uint32_t GPIO_Type::DR
__IO uint32_t GPIO_Type::GDIR
__I uint32_t GPIO_Type::PSR
__IO uint32_t GPIO_Type::ICR1
__IO uint32_t GPIO_Type::ICR2
__IO uint32_t GPIO_Type::IMR
__IO uint32_t GPIO_Type::ISR
__IO uint32_t GPIO_Type::EDGE_SEL
uint8_t GPIO_Type::RESERVED_0 [100]
__O uint32_t GPIO_Type::DR_SET
__O uint32_t GPIO_Type::DR_CLEAR
__O uint32_t GPIO_Type::DR_TOGGLE
__IO uint32_t GPT_Type::CR
__IO uint32_t GPT_Type::PR
__IO uint32_t GPT_Type::SR
__IO uint32_t GPT_Type::IR
__IO uint32_t GPT_Type::OCR [3]
__I uint32_t GPT_Type::ICR [2]
__I uint32_t GPT_Type::CNT
__I uint32_t I2S_Type::VERID
__I uint32_t I2S_Type::PARAM
__IO uint32_t I2S_Type::TCSR
__IO uint32_t I2S_Type::TCR1
__IO uint32_t I2S_Type::TCR2
__IO uint32_t I2S_Type::TCR3
__IO uint32_t I2S_Type::TCR4
__IO uint32_t I2S_Type::TCR5
__O uint32_t I2S_Type::TDR [4]
uint8_t I2S_Type::RESERVED_0 [16]
__I uint32_t I2S_Type::TFR [4]
uint8_t I2S_Type::RESERVED_1 [16]
__IO uint32_t I2S_Type::TMR
uint8_t I2S_Type::RESERVED_2 [36]
__IO uint32_t I2S_Type::RCSR
__IO uint32_t I2S_Type::RCR1
__IO uint32_t I2S_Type::RCR2
__IO uint32_t I2S_Type::RCR3
__IO uint32_t I2S_Type::RCR4
__IO uint32_t I2S_Type::RCR5
__I uint32_t I2S_Type::RDR [4]
uint8_t I2S_Type::RESERVED_3 [16]
__I uint32_t I2S_Type::RFR [4]
uint8_t I2S_Type::RESERVED_4 [16]
__IO uint32_t I2S_Type::RMR
uint8_t IOMUXC_Type::RESERVED_0 [20]
__IO uint32_t IOMUXC_Type::SW_MUX_CTL_PAD [124]
__IO uint32_t IOMUXC_Type::SW_PAD_CTL_PAD [124]
__IO uint32_t IOMUXC_Type::SELECT_INPUT [154]
uint32_t IOMUXC_GPR_Type::GPR0
__IO uint32_t IOMUXC_GPR_Type::GPR1
__IO uint32_t IOMUXC_GPR_Type::GPR2
__IO uint32_t IOMUXC_GPR_Type::GPR3
__IO uint32_t IOMUXC_GPR_Type::GPR4
__IO uint32_t IOMUXC_GPR_Type::GPR5
__IO uint32_t IOMUXC_GPR_Type::GPR6
__IO uint32_t IOMUXC_GPR_Type::GPR7
__IO uint32_t IOMUXC_GPR_Type::GPR8
uint32_t IOMUXC_GPR_Type::GPR9
__IO uint32_t IOMUXC_GPR_Type::GPR10
__IO uint32_t IOMUXC_GPR_Type::GPR11
__IO uint32_t IOMUXC_GPR_Type::GPR12
__IO uint32_t IOMUXC_GPR_Type::GPR13
__IO uint32_t IOMUXC_GPR_Type::GPR14
uint32_t IOMUXC_GPR_Type::GPR15
__IO uint32_t IOMUXC_GPR_Type::GPR16
__IO uint32_t IOMUXC_GPR_Type::GPR17
__IO uint32_t IOMUXC_GPR_Type::GPR18
__IO uint32_t IOMUXC_GPR_Type::GPR19
__IO uint32_t IOMUXC_GPR_Type::GPR20
__IO uint32_t IOMUXC_GPR_Type::GPR21
__IO uint32_t IOMUXC_GPR_Type::GPR22
__IO uint32_t IOMUXC_GPR_Type::GPR23
__IO uint32_t IOMUXC_GPR_Type::GPR24
__IO uint32_t IOMUXC_GPR_Type::GPR25
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_WAKEUP
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_PMIC_ON_REQ
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_PMIC_STBY_REQ
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_TEST_MODE
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_POR_B
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_ONOFF
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_WAKEUP
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_PMIC_ON_REQ
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_PMIC_STBY_REQ
uint32_t IOMUXC_SNVS_GPR_Type::GPR0
uint32_t IOMUXC_SNVS_GPR_Type::GPR1
uint32_t IOMUXC_SNVS_GPR_Type::GPR2
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR3
__IO uint16_t KPP_Type::KPCR
__IO uint16_t KPP_Type::KPSR
__IO uint16_t KPP_Type::KDDR
__IO uint16_t KPP_Type::KPDR
__IO uint32_t LCDIF_Type::CTRL
__IO uint32_t LCDIF_Type::CTRL_SET
__IO uint32_t LCDIF_Type::CTRL_CLR
__IO uint32_t LCDIF_Type::CTRL_TOG
__IO uint32_t LCDIF_Type::CTRL1
__IO uint32_t LCDIF_Type::CTRL1_SET
__IO uint32_t LCDIF_Type::CTRL1_CLR
__IO uint32_t LCDIF_Type::CTRL1_TOG
__IO uint32_t LCDIF_Type::CTRL2
__IO uint32_t LCDIF_Type::CTRL2_SET
__IO uint32_t LCDIF_Type::CTRL2_CLR
__IO uint32_t LCDIF_Type::CTRL2_TOG
__IO uint32_t LCDIF_Type::TRANSFER_COUNT
uint8_t LCDIF_Type::RESERVED_0 [12]
__IO uint32_t LCDIF_Type::CUR_BUF
uint8_t LCDIF_Type::RESERVED_1 [12]
__IO uint32_t LCDIF_Type::NEXT_BUF
uint8_t LCDIF_Type::RESERVED_2 [28]
__IO uint32_t LCDIF_Type::VDCTRL0
__IO uint32_t LCDIF_Type::VDCTRL0_SET
__IO uint32_t LCDIF_Type::VDCTRL0_CLR
__IO uint32_t LCDIF_Type::VDCTRL0_TOG
__IO uint32_t LCDIF_Type::VDCTRL1
uint8_t LCDIF_Type::RESERVED_3 [12]
__IO uint32_t LCDIF_Type::VDCTRL2
uint8_t LCDIF_Type::RESERVED_4 [12]
__IO uint32_t LCDIF_Type::VDCTRL3
uint8_t LCDIF_Type::RESERVED_5 [12]
__IO uint32_t LCDIF_Type::VDCTRL4
uint8_t LCDIF_Type::RESERVED_6 [220]
__IO uint32_t LCDIF_Type::BM_ERROR_STAT
uint8_t LCDIF_Type::RESERVED_7 [12]
__IO uint32_t LCDIF_Type::CRC_STAT
uint8_t LCDIF_Type::RESERVED_8 [12]
__I uint32_t LCDIF_Type::STAT
uint8_t LCDIF_Type::RESERVED_9 [236]
__IO uint32_t LCDIF_Type::RGB_ADJUST
__IO uint32_t LCDIF_Type::RGB_ADJUST_SET
__IO uint32_t LCDIF_Type::RGB_ADJUST_CLR
__IO uint32_t LCDIF_Type::RGB_ADJUST_TOG
uint8_t LCDIF_Type::RESERVED_10 [208]
__IO uint32_t LCDIF_Type::PIGEONCTRL0
__IO uint32_t LCDIF_Type::PIGEONCTRL0_SET
__IO uint32_t LCDIF_Type::PIGEONCTRL0_CLR
__IO uint32_t LCDIF_Type::PIGEONCTRL0_TOG
__IO uint32_t LCDIF_Type::PIGEONCTRL1
__IO uint32_t LCDIF_Type::PIGEONCTRL1_SET
__IO uint32_t LCDIF_Type::PIGEONCTRL1_CLR
__IO uint32_t LCDIF_Type::PIGEONCTRL1_TOG
__IO uint32_t LCDIF_Type::PIGEONCTRL2
__IO uint32_t LCDIF_Type::PIGEONCTRL2_SET
__IO uint32_t LCDIF_Type::PIGEONCTRL2_CLR
__IO uint32_t LCDIF_Type::PIGEONCTRL2_TOG
uint8_t LCDIF_Type::RESERVED_11 [1104]
__IO uint32_t   LCDIF_Type::PIGEON_0
__IO uint32_t   LCDIF_Type::PIGEON_1
__IO uint32_t   LCDIF_Type::PIGEON_2
struct {
   uint8_t   RESERVED_0 [12]
   uint8_t   RESERVED_1 [12]
   uint8_t   RESERVED_2 [28]
LCDIF_Type::PIGEON [12]
__IO uint32_t LCDIF_Type::LUT_CTRL
uint8_t LCDIF_Type::RESERVED_12 [12]
__IO uint32_t LCDIF_Type::LUT0_ADDR
uint8_t LCDIF_Type::RESERVED_13 [12]
__IO uint32_t LCDIF_Type::LUT0_DATA
uint8_t LCDIF_Type::RESERVED_14 [12]
__IO uint32_t LCDIF_Type::LUT1_ADDR
uint8_t LCDIF_Type::RESERVED_15 [12]
__IO uint32_t LCDIF_Type::LUT1_DATA
__I uint32_t LPI2C_Type::VERID
__I uint32_t LPI2C_Type::PARAM
uint8_t LPI2C_Type::RESERVED_0 [8]
__IO uint32_t LPI2C_Type::MCR
__IO uint32_t LPI2C_Type::MSR
__IO uint32_t LPI2C_Type::MIER
__IO uint32_t LPI2C_Type::MDER
__IO uint32_t LPI2C_Type::MCFGR0
__IO uint32_t LPI2C_Type::MCFGR1
__IO uint32_t LPI2C_Type::MCFGR2
__IO uint32_t LPI2C_Type::MCFGR3
uint8_t LPI2C_Type::RESERVED_1 [16]
__IO uint32_t LPI2C_Type::MDMR
uint8_t LPI2C_Type::RESERVED_2 [4]
__IO uint32_t LPI2C_Type::MCCR0
uint8_t LPI2C_Type::RESERVED_3 [4]
__IO uint32_t LPI2C_Type::MCCR1
uint8_t LPI2C_Type::RESERVED_4 [4]
__IO uint32_t LPI2C_Type::MFCR
__I uint32_t LPI2C_Type::MFSR
__O uint32_t LPI2C_Type::MTDR
uint8_t LPI2C_Type::RESERVED_5 [12]
__I uint32_t LPI2C_Type::MRDR
uint8_t LPI2C_Type::RESERVED_6 [156]
__IO uint32_t LPI2C_Type::SCR
__IO uint32_t LPI2C_Type::SSR
__IO uint32_t LPI2C_Type::SIER
__IO uint32_t LPI2C_Type::SDER
uint8_t LPI2C_Type::RESERVED_7 [4]
__IO uint32_t LPI2C_Type::SCFGR1
__IO uint32_t LPI2C_Type::SCFGR2
uint8_t LPI2C_Type::RESERVED_8 [20]
__IO uint32_t LPI2C_Type::SAMR
uint8_t LPI2C_Type::RESERVED_9 [12]
__I uint32_t LPI2C_Type::SASR
__IO uint32_t LPI2C_Type::STAR
uint8_t LPI2C_Type::RESERVED_10 [8]
__O uint32_t LPI2C_Type::STDR
uint8_t LPI2C_Type::RESERVED_11 [12]
__I uint32_t LPI2C_Type::SRDR
__I uint32_t LPSPI_Type::VERID
__I uint32_t LPSPI_Type::PARAM
uint8_t LPSPI_Type::RESERVED_0 [8]
__IO uint32_t LPSPI_Type::CR
__IO uint32_t LPSPI_Type::SR
__IO uint32_t LPSPI_Type::IER
__IO uint32_t LPSPI_Type::DER
__IO uint32_t LPSPI_Type::CFGR0
__IO uint32_t LPSPI_Type::CFGR1
uint8_t LPSPI_Type::RESERVED_1 [8]
__IO uint32_t LPSPI_Type::DMR0
__IO uint32_t LPSPI_Type::DMR1
uint8_t LPSPI_Type::RESERVED_2 [8]
__IO uint32_t LPSPI_Type::CCR
uint8_t LPSPI_Type::RESERVED_3 [20]
__IO uint32_t LPSPI_Type::FCR
__I uint32_t LPSPI_Type::FSR
__IO uint32_t LPSPI_Type::TCR
__O uint32_t LPSPI_Type::TDR
uint8_t LPSPI_Type::RESERVED_4 [8]
__I uint32_t LPSPI_Type::RSR
__I uint32_t LPSPI_Type::RDR
__I uint32_t LPUART_Type::VERID
__I uint32_t LPUART_Type::PARAM
__IO uint32_t LPUART_Type::GLOBAL
__IO uint32_t LPUART_Type::PINCFG
__IO uint32_t LPUART_Type::BAUD
__IO uint32_t LPUART_Type::STAT
__IO uint32_t LPUART_Type::CTRL
__IO uint32_t LPUART_Type::DATA
__IO uint32_t LPUART_Type::MATCH
__IO uint32_t LPUART_Type::MODIR
__IO uint32_t LPUART_Type::FIFO
__IO uint32_t LPUART_Type::WATER
__IO uint32_t OCOTP_Type::CTRL
__IO uint32_t OCOTP_Type::CTRL_SET
__IO uint32_t OCOTP_Type::CTRL_CLR
__IO uint32_t OCOTP_Type::CTRL_TOG
__IO uint32_t OCOTP_Type::TIMING
uint8_t OCOTP_Type::RESERVED_0 [12]
__IO uint32_t OCOTP_Type::DATA
uint8_t OCOTP_Type::RESERVED_1 [12]
__IO uint32_t OCOTP_Type::READ_CTRL
uint8_t OCOTP_Type::RESERVED_2 [12]
__IO uint32_t OCOTP_Type::READ_FUSE_DATA
uint8_t OCOTP_Type::RESERVED_3 [12]
__IO uint32_t OCOTP_Type::SW_STICKY
uint8_t OCOTP_Type::RESERVED_4 [12]
__IO uint32_t OCOTP_Type::SCS
__IO uint32_t OCOTP_Type::SCS_SET
__IO uint32_t OCOTP_Type::SCS_CLR
__IO uint32_t OCOTP_Type::SCS_TOG
uint8_t OCOTP_Type::RESERVED_5 [32]
__I uint32_t OCOTP_Type::VERSION
uint8_t OCOTP_Type::RESERVED_6 [108]
__IO uint32_t OCOTP_Type::TIMING2
uint8_t OCOTP_Type::RESERVED_7 [764]
__IO uint32_t OCOTP_Type::LOCK
uint8_t OCOTP_Type::RESERVED_8 [12]
__IO uint32_t OCOTP_Type::CFG0
uint8_t OCOTP_Type::RESERVED_9 [12]
__IO uint32_t OCOTP_Type::CFG1
uint8_t OCOTP_Type::RESERVED_10 [12]
__IO uint32_t OCOTP_Type::CFG2
uint8_t OCOTP_Type::RESERVED_11 [12]
__IO uint32_t OCOTP_Type::CFG3
uint8_t OCOTP_Type::RESERVED_12 [12]
__IO uint32_t OCOTP_Type::CFG4
uint8_t OCOTP_Type::RESERVED_13 [12]
__IO uint32_t OCOTP_Type::CFG5
uint8_t OCOTP_Type::RESERVED_14 [12]
__IO uint32_t OCOTP_Type::CFG6
uint8_t OCOTP_Type::RESERVED_15 [12]
__IO uint32_t OCOTP_Type::MEM0
uint8_t OCOTP_Type::RESERVED_16 [12]
__IO uint32_t OCOTP_Type::MEM1
uint8_t OCOTP_Type::RESERVED_17 [12]
__IO uint32_t OCOTP_Type::MEM2
uint8_t OCOTP_Type::RESERVED_18 [12]
__IO uint32_t OCOTP_Type::MEM3
uint8_t OCOTP_Type::RESERVED_19 [12]
__IO uint32_t OCOTP_Type::MEM4
uint8_t OCOTP_Type::RESERVED_20 [12]
__IO uint32_t OCOTP_Type::ANA0
uint8_t OCOTP_Type::RESERVED_21 [12]
__IO uint32_t OCOTP_Type::ANA1
uint8_t OCOTP_Type::RESERVED_22 [12]
__IO uint32_t OCOTP_Type::ANA2
uint8_t OCOTP_Type::RESERVED_23 [140]
__IO uint32_t OCOTP_Type::SRK0
uint8_t OCOTP_Type::RESERVED_24 [12]
__IO uint32_t OCOTP_Type::SRK1
uint8_t OCOTP_Type::RESERVED_25 [12]
__IO uint32_t OCOTP_Type::SRK2
uint8_t OCOTP_Type::RESERVED_26 [12]
__IO uint32_t OCOTP_Type::SRK3
uint8_t OCOTP_Type::RESERVED_27 [12]
__IO uint32_t OCOTP_Type::SRK4
uint8_t OCOTP_Type::RESERVED_28 [12]
__IO uint32_t OCOTP_Type::SRK5
uint8_t OCOTP_Type::RESERVED_29 [12]
__IO uint32_t OCOTP_Type::SRK6
uint8_t OCOTP_Type::RESERVED_30 [12]
__IO uint32_t OCOTP_Type::SRK7
uint8_t OCOTP_Type::RESERVED_31 [12]
__IO uint32_t OCOTP_Type::SJC_RESP0
uint8_t OCOTP_Type::RESERVED_32 [12]
__IO uint32_t OCOTP_Type::SJC_RESP1
uint8_t OCOTP_Type::RESERVED_33 [12]
__IO uint32_t OCOTP_Type::MAC0
uint8_t OCOTP_Type::RESERVED_34 [12]
__IO uint32_t OCOTP_Type::MAC1
uint8_t OCOTP_Type::RESERVED_35 [12]
__IO uint32_t OCOTP_Type::GP3
uint8_t OCOTP_Type::RESERVED_36 [28]
__IO uint32_t OCOTP_Type::GP1
uint8_t OCOTP_Type::RESERVED_37 [12]
__IO uint32_t OCOTP_Type::GP2
uint8_t OCOTP_Type::RESERVED_38 [12]
__IO uint32_t OCOTP_Type::SW_GP1
uint8_t OCOTP_Type::RESERVED_39 [12]
__IO uint32_t OCOTP_Type::SW_GP20
uint8_t OCOTP_Type::RESERVED_40 [12]
__IO uint32_t OCOTP_Type::SW_GP21
uint8_t OCOTP_Type::RESERVED_41 [12]
__IO uint32_t OCOTP_Type::SW_GP22
uint8_t OCOTP_Type::RESERVED_42 [12]
__IO uint32_t OCOTP_Type::SW_GP23
uint8_t OCOTP_Type::RESERVED_43 [12]
__IO uint32_t OCOTP_Type::MISC_CONF0
uint8_t OCOTP_Type::RESERVED_44 [12]
__IO uint32_t OCOTP_Type::MISC_CONF1
uint8_t OCOTP_Type::RESERVED_45 [12]
__IO uint32_t OCOTP_Type::SRK_REVOKE
uint8_t PGC_Type::RESERVED_0 [544]
__IO uint32_t PGC_Type::MEGA_CTRL
__IO uint32_t PGC_Type::MEGA_PUPSCR
__IO uint32_t PGC_Type::MEGA_PDNSCR
__IO uint32_t PGC_Type::MEGA_SR
uint8_t PGC_Type::RESERVED_1 [112]
__IO uint32_t PGC_Type::CPU_CTRL
__IO uint32_t PGC_Type::CPU_PUPSCR
__IO uint32_t PGC_Type::CPU_PDNSCR
__IO uint32_t PGC_Type::CPU_SR
__IO uint32_t PIT_Type::MCR
uint8_t PIT_Type::RESERVED_0 [220]
__I uint32_t PIT_Type::LTMR64H
__I uint32_t PIT_Type::LTMR64L
uint8_t PIT_Type::RESERVED_1 [24]
__IO uint32_t   PIT_Type::LDVAL
__I uint32_t   PIT_Type::CVAL
__IO uint32_t   PIT_Type::TCTRL
__IO uint32_t   PIT_Type::TFLG
struct {
PIT_Type::CHANNEL [4]
uint8_t PMU_Type::RESERVED_0 [272]
__IO uint32_t PMU_Type::REG_1P1
__IO uint32_t PMU_Type::REG_1P1_SET
__IO uint32_t PMU_Type::REG_1P1_CLR
__IO uint32_t PMU_Type::REG_1P1_TOG
__IO uint32_t PMU_Type::REG_3P0
__IO uint32_t PMU_Type::REG_3P0_SET
__IO uint32_t PMU_Type::REG_3P0_CLR
__IO uint32_t PMU_Type::REG_3P0_TOG
__IO uint32_t PMU_Type::REG_2P5
__IO uint32_t PMU_Type::REG_2P5_SET
__IO uint32_t PMU_Type::REG_2P5_CLR
__IO uint32_t PMU_Type::REG_2P5_TOG
__IO uint32_t PMU_Type::REG_CORE
__IO uint32_t PMU_Type::REG_CORE_SET
__IO uint32_t PMU_Type::REG_CORE_CLR
__IO uint32_t PMU_Type::REG_CORE_TOG
__IO uint32_t PMU_Type::MISC0
__IO uint32_t PMU_Type::MISC0_SET
__IO uint32_t PMU_Type::MISC0_CLR
__IO uint32_t PMU_Type::MISC0_TOG
__IO uint32_t PMU_Type::MISC1
__IO uint32_t PMU_Type::MISC1_SET
__IO uint32_t PMU_Type::MISC1_CLR
__IO uint32_t PMU_Type::MISC1_TOG
__IO uint32_t PMU_Type::MISC2
__IO uint32_t PMU_Type::MISC2_SET
__IO uint32_t PMU_Type::MISC2_CLR
__IO uint32_t PMU_Type::MISC2_TOG
__I uint16_t   PWM_Type::CNT
__IO uint16_t   PWM_Type::INIT
__IO uint16_t   PWM_Type::CTRL2
uint8_t   PWM_Type::RESERVED_0 [2]
__IO uint16_t   PWM_Type::VAL0
__IO uint16_t   PWM_Type::FRACVAL1
__IO uint16_t   PWM_Type::VAL1
__IO uint16_t   PWM_Type::FRACVAL2
__IO uint16_t   PWM_Type::VAL2
__IO uint16_t   PWM_Type::FRACVAL3
__IO uint16_t   PWM_Type::VAL3
__IO uint16_t   PWM_Type::FRACVAL4
__IO uint16_t   PWM_Type::VAL4
__IO uint16_t   PWM_Type::FRACVAL5
__IO uint16_t   PWM_Type::VAL5
__IO uint16_t   PWM_Type::FRCTRL
__IO uint16_t   PWM_Type::OCTRL
__IO uint16_t   PWM_Type::STS
__IO uint16_t   PWM_Type::INTEN
__IO uint16_t   PWM_Type::DMAEN
__IO uint16_t   PWM_Type::TCTRL
__IO uint16_t   PWM_Type::DISMAP [2]
__IO uint16_t   PWM_Type::DTCNT0
__IO uint16_t   PWM_Type::DTCNT1
__IO uint16_t   PWM_Type::CAPTCTRLA
__IO uint16_t   PWM_Type::CAPTCOMPA
__IO uint16_t   PWM_Type::CAPTCTRLB
__IO uint16_t   PWM_Type::CAPTCOMPB
__IO uint16_t   PWM_Type::CAPTCTRLX
__IO uint16_t   PWM_Type::CAPTCOMPX
__I uint16_t   PWM_Type::CVAL0
__I uint16_t   PWM_Type::CVAL0CYC
__I uint16_t   PWM_Type::CVAL1
__I uint16_t   PWM_Type::CVAL1CYC
__I uint16_t   PWM_Type::CVAL2
__I uint16_t   PWM_Type::CVAL2CYC
__I uint16_t   PWM_Type::CVAL3
__I uint16_t   PWM_Type::CVAL3CYC
__I uint16_t   PWM_Type::CVAL4
__I uint16_t   PWM_Type::CVAL4CYC
__I uint16_t   PWM_Type::CVAL5
__I uint16_t   PWM_Type::CVAL5CYC
uint8_t   PWM_Type::RESERVED_1 [8]
struct {
   uint8_t   RESERVED_0 [2]
   uint8_t   RESERVED_1 [8]
PWM_Type::SM [4]
__IO uint16_t PWM_Type::OUTEN
__IO uint16_t PWM_Type::MASK
__IO uint16_t PWM_Type::SWCOUT
__IO uint16_t PWM_Type::DTSRCSEL
__IO uint16_t PWM_Type::MCTRL
__IO uint16_t PWM_Type::MCTRL2
__IO uint16_t PWM_Type::FCTRL
__IO uint16_t PWM_Type::FSTS
__IO uint16_t PWM_Type::FFILT
__IO uint16_t PWM_Type::FTST
__IO uint16_t PWM_Type::FCTRL2
__IO uint32_t PXP_Type::CTRL
__IO uint32_t PXP_Type::CTRL_SET
__IO uint32_t PXP_Type::CTRL_CLR
__IO uint32_t PXP_Type::CTRL_TOG
__IO uint32_t PXP_Type::STAT
__IO uint32_t PXP_Type::STAT_SET
__IO uint32_t PXP_Type::STAT_CLR
__IO uint32_t PXP_Type::STAT_TOG
__IO uint32_t PXP_Type::OUT_CTRL
__IO uint32_t PXP_Type::OUT_CTRL_SET
__IO uint32_t PXP_Type::OUT_CTRL_CLR
__IO uint32_t PXP_Type::OUT_CTRL_TOG
__IO uint32_t PXP_Type::OUT_BUF
uint8_t PXP_Type::RESERVED_0 [12]
__IO uint32_t PXP_Type::OUT_BUF2
uint8_t PXP_Type::RESERVED_1 [12]
__IO uint32_t PXP_Type::OUT_PITCH
uint8_t PXP_Type::RESERVED_2 [12]
__IO uint32_t PXP_Type::OUT_LRC
uint8_t PXP_Type::RESERVED_3 [12]
__IO uint32_t PXP_Type::OUT_PS_ULC
uint8_t PXP_Type::RESERVED_4 [12]
__IO uint32_t PXP_Type::OUT_PS_LRC
uint8_t PXP_Type::RESERVED_5 [12]
__IO uint32_t PXP_Type::OUT_AS_ULC
uint8_t PXP_Type::RESERVED_6 [12]
__IO uint32_t PXP_Type::OUT_AS_LRC
uint8_t PXP_Type::RESERVED_7 [12]
__IO uint32_t PXP_Type::PS_CTRL
__IO uint32_t PXP_Type::PS_CTRL_SET
__IO uint32_t PXP_Type::PS_CTRL_CLR
__IO uint32_t PXP_Type::PS_CTRL_TOG
__IO uint32_t PXP_Type::PS_BUF
uint8_t PXP_Type::RESERVED_8 [12]
__IO uint32_t PXP_Type::PS_UBUF
uint8_t PXP_Type::RESERVED_9 [12]
__IO uint32_t PXP_Type::PS_VBUF
uint8_t PXP_Type::RESERVED_10 [12]
__IO uint32_t PXP_Type::PS_PITCH
uint8_t PXP_Type::RESERVED_11 [12]
__IO uint32_t PXP_Type::PS_BACKGROUND
uint8_t PXP_Type::RESERVED_12 [12]
__IO uint32_t PXP_Type::PS_SCALE
uint8_t PXP_Type::RESERVED_13 [12]
__IO uint32_t PXP_Type::PS_OFFSET
uint8_t PXP_Type::RESERVED_14 [12]
__IO uint32_t PXP_Type::PS_CLRKEYLOW
uint8_t PXP_Type::RESERVED_15 [12]
__IO uint32_t PXP_Type::PS_CLRKEYHIGH
uint8_t PXP_Type::RESERVED_16 [12]
__IO uint32_t PXP_Type::AS_CTRL
uint8_t PXP_Type::RESERVED_17 [12]
__IO uint32_t PXP_Type::AS_BUF
uint8_t PXP_Type::RESERVED_18 [12]
__IO uint32_t PXP_Type::AS_PITCH
uint8_t PXP_Type::RESERVED_19 [12]
__IO uint32_t PXP_Type::AS_CLRKEYLOW
uint8_t PXP_Type::RESERVED_20 [12]
__IO uint32_t PXP_Type::AS_CLRKEYHIGH
uint8_t PXP_Type::RESERVED_21 [12]
__IO uint32_t PXP_Type::CSC1_COEF0
uint8_t PXP_Type::RESERVED_22 [12]
__IO uint32_t PXP_Type::CSC1_COEF1
uint8_t PXP_Type::RESERVED_23 [12]
__IO uint32_t PXP_Type::CSC1_COEF2
uint8_t PXP_Type::RESERVED_24 [348]
__IO uint32_t PXP_Type::POWER
uint8_t PXP_Type::RESERVED_25 [220]
__IO uint32_t PXP_Type::NEXT
uint8_t PXP_Type::RESERVED_26 [60]
__IO uint32_t PXP_Type::PORTER_DUFF_CTRL
uint8_t ROMC_Type::RESERVED_0 [212]
__IO uint32_t ROMC_Type::ROMPATCHD [8]
__IO uint32_t ROMC_Type::ROMPATCHCNTL
uint32_t ROMC_Type::ROMPATCHENH
__IO uint32_t ROMC_Type::ROMPATCHENL
__IO uint32_t ROMC_Type::ROMPATCHA [16]
uint8_t ROMC_Type::RESERVED_1 [200]
__IO uint32_t ROMC_Type::ROMPATCHSR
__IO uint32_t RTWDOG_Type::CS
__IO uint32_t RTWDOG_Type::CNT
__IO uint32_t RTWDOG_Type::TOVAL
__IO uint32_t RTWDOG_Type::WIN
__IO uint32_t SEMC_Type::MCR
__IO uint32_t SEMC_Type::IOCR
__IO uint32_t SEMC_Type::BMCR0
__IO uint32_t SEMC_Type::BMCR1
__IO uint32_t SEMC_Type::BR [9]
uint8_t SEMC_Type::RESERVED_0 [4]
__IO uint32_t SEMC_Type::INTEN
__IO uint32_t SEMC_Type::INTR
__IO uint32_t SEMC_Type::SDRAMCR0
__IO uint32_t SEMC_Type::SDRAMCR1
__IO uint32_t SEMC_Type::SDRAMCR2
__IO uint32_t SEMC_Type::SDRAMCR3
__IO uint32_t SEMC_Type::NANDCR0
__IO uint32_t SEMC_Type::NANDCR1
__IO uint32_t SEMC_Type::NANDCR2
__IO uint32_t SEMC_Type::NANDCR3
__IO uint32_t SEMC_Type::NORCR0
__IO uint32_t SEMC_Type::NORCR1
__IO uint32_t SEMC_Type::NORCR2
uint32_t SEMC_Type::NORCR3
__IO uint32_t SEMC_Type::SRAMCR0
__IO uint32_t SEMC_Type::SRAMCR1
__IO uint32_t SEMC_Type::SRAMCR2
uint32_t SEMC_Type::SRAMCR3
__IO uint32_t SEMC_Type::DBICR0
__IO uint32_t SEMC_Type::DBICR1
uint8_t SEMC_Type::RESERVED_1 [8]
__IO uint32_t SEMC_Type::IPCR0
__IO uint32_t SEMC_Type::IPCR1
__IO uint32_t SEMC_Type::IPCR2
__IO uint32_t SEMC_Type::IPCMD
__IO uint32_t SEMC_Type::IPTXDAT
uint8_t SEMC_Type::RESERVED_2 [12]
__I uint32_t SEMC_Type::IPRXDAT
uint8_t SEMC_Type::RESERVED_3 [12]
__I uint32_t SEMC_Type::STS0
uint32_t SEMC_Type::STS1
__I uint32_t SEMC_Type::STS2
uint32_t SEMC_Type::STS3
uint32_t SEMC_Type::STS4
uint32_t SEMC_Type::STS5
uint32_t SEMC_Type::STS6
uint32_t SEMC_Type::STS7
uint32_t SEMC_Type::STS8
uint32_t SEMC_Type::STS9
uint32_t SEMC_Type::STS10
uint32_t SEMC_Type::STS11
__I uint32_t SEMC_Type::STS12
uint32_t SEMC_Type::STS13
uint32_t SEMC_Type::STS14
uint32_t SEMC_Type::STS15
__IO uint32_t SNVS_Type::HPLR
__IO uint32_t SNVS_Type::HPCOMR
__IO uint32_t SNVS_Type::HPCR
__IO uint32_t SNVS_Type::HPSICR
__IO uint32_t SNVS_Type::HPSVCR
__IO uint32_t SNVS_Type::HPSR
__IO uint32_t SNVS_Type::HPSVSR
__IO uint32_t SNVS_Type::HPHACIVR
__I uint32_t SNVS_Type::HPHACR
__IO uint32_t SNVS_Type::HPRTCMR
__IO uint32_t SNVS_Type::HPRTCLR
__IO uint32_t SNVS_Type::HPTAMR
__IO uint32_t SNVS_Type::HPTALR
__IO uint32_t SNVS_Type::LPLR
__IO uint32_t SNVS_Type::LPCR
__IO uint32_t SNVS_Type::LPMKCR
__IO uint32_t SNVS_Type::LPSVCR
uint8_t SNVS_Type::RESERVED_0 [4]
__IO uint32_t SNVS_Type::LPSECR
__IO uint32_t SNVS_Type::LPSR
__IO uint32_t SNVS_Type::LPSRTCMR
__IO uint32_t SNVS_Type::LPSRTCLR
__IO uint32_t SNVS_Type::LPTAR
__IO uint32_t SNVS_Type::LPSMCMR
__IO uint32_t SNVS_Type::LPSMCLR
__IO uint32_t SNVS_Type::LPLVDR
__IO uint32_t SNVS_Type::LPGPR0_LEGACY_ALIAS
__IO uint32_t SNVS_Type::LPZMKR [8]
uint8_t SNVS_Type::RESERVED_1 [4]
__IO uint32_t SNVS_Type::LPGPR_ALIAS [4]
uint8_t SNVS_Type::RESERVED_2 [96]
__IO uint32_t SNVS_Type::LPGPR [8]
uint8_t SNVS_Type::RESERVED_3 [2776]
__I uint32_t SNVS_Type::HPVIDR1
__I uint32_t SNVS_Type::HPVIDR2
__IO uint32_t SPDIF_Type::SCR
__IO uint32_t SPDIF_Type::SRCD
__IO uint32_t SPDIF_Type::SRPC
__IO uint32_t SPDIF_Type::SIE
__O uint32_t   SPDIF_Type::SIC
__I uint32_t   SPDIF_Type::SIS
union {
__I uint32_t SPDIF_Type::SRL
__I uint32_t SPDIF_Type::SRR
__I uint32_t SPDIF_Type::SRCSH
__I uint32_t SPDIF_Type::SRCSL
__I uint32_t SPDIF_Type::SRU
__I uint32_t SPDIF_Type::SRQ
__O uint32_t SPDIF_Type::STL
__O uint32_t SPDIF_Type::STR
__IO uint32_t SPDIF_Type::STCSCH
__IO uint32_t SPDIF_Type::STCSCL
uint8_t SPDIF_Type::RESERVED_0 [8]
__I uint32_t SPDIF_Type::SRFM
uint8_t SPDIF_Type::RESERVED_1 [8]
__IO uint32_t SRC_Type::SCR
__I uint32_t SRC_Type::SBMR1
__IO uint32_t SRC_Type::SRSR
uint8_t SRC_Type::RESERVED_0 [16]
__I uint32_t SRC_Type::SBMR2
__IO uint32_t SRC_Type::GPR [10]
uint8_t TEMPMON_Type::RESERVED_0 [384]
__IO uint32_t TEMPMON_Type::TEMPSENSE0
__IO uint32_t TEMPMON_Type::TEMPSENSE0_SET
__IO uint32_t TEMPMON_Type::TEMPSENSE0_CLR
__IO uint32_t TEMPMON_Type::TEMPSENSE0_TOG
__IO uint32_t TEMPMON_Type::TEMPSENSE1
__IO uint32_t TEMPMON_Type::TEMPSENSE1_SET
__IO uint32_t TEMPMON_Type::TEMPSENSE1_CLR
__IO uint32_t TEMPMON_Type::TEMPSENSE1_TOG
uint8_t TEMPMON_Type::RESERVED_1 [240]
__IO uint32_t TEMPMON_Type::TEMPSENSE2
__IO uint32_t TEMPMON_Type::TEMPSENSE2_SET
__IO uint32_t TEMPMON_Type::TEMPSENSE2_CLR
__IO uint32_t TEMPMON_Type::TEMPSENSE2_TOG
__IO uint16_t   TMR_Type::COMP1
__IO uint16_t   TMR_Type::COMP2
__IO uint16_t   TMR_Type::CAPT
__IO uint16_t   TMR_Type::LOAD
__IO uint16_t   TMR_Type::HOLD
__IO uint16_t   TMR_Type::CNTR
__IO uint16_t   TMR_Type::CTRL
__IO uint16_t   TMR_Type::SCTRL
__IO uint16_t   TMR_Type::CMPLD1
__IO uint16_t   TMR_Type::CMPLD2
__IO uint16_t   TMR_Type::CSCTRL
__IO uint16_t   TMR_Type::FILT
__IO uint16_t   TMR_Type::DMA
uint8_t   TMR_Type::RESERVED_0 [4]
__IO uint16_t   TMR_Type::ENBL
struct {
   uint8_t   RESERVED_0 [4]
TMR_Type::CHANNEL [4]
__IO uint32_t TRNG_Type::MCTL
__IO uint32_t TRNG_Type::SCMISC
__IO uint32_t TRNG_Type::PKRRNG
__IO uint32_t   TRNG_Type::PKRMAX
__I uint32_t   TRNG_Type::PKRSQ
union {
__IO uint32_t TRNG_Type::SDCTL
__IO uint32_t   TRNG_Type::SBLIM
__I uint32_t   TRNG_Type::TOTSAM
union {
__IO uint32_t TRNG_Type::FRQMIN
__I uint32_t   TRNG_Type::FRQCNT
__IO uint32_t   TRNG_Type::FRQMAX
union {
__I uint32_t   TRNG_Type::SCMC
__IO uint32_t   TRNG_Type::SCML
union {
__I uint32_t   TRNG_Type::SCR1C
__IO uint32_t   TRNG_Type::SCR1L
union {
__I uint32_t   TRNG_Type::SCR2C
__IO uint32_t   TRNG_Type::SCR2L
union {
__I uint32_t   TRNG_Type::SCR3C
__IO uint32_t   TRNG_Type::SCR3L
union {
__I uint32_t   TRNG_Type::SCR4C
__IO uint32_t   TRNG_Type::SCR4L
union {
__I uint32_t   TRNG_Type::SCR5C
__IO uint32_t   TRNG_Type::SCR5L
union {
__I uint32_t   TRNG_Type::SCR6PC
__IO uint32_t   TRNG_Type::SCR6PL
union {
__I uint32_t TRNG_Type::STATUS
__I uint32_t TRNG_Type::ENT [16]
__I uint32_t TRNG_Type::PKRCNT10
__I uint32_t TRNG_Type::PKRCNT32
__I uint32_t TRNG_Type::PKRCNT54
__I uint32_t TRNG_Type::PKRCNT76
__I uint32_t TRNG_Type::PKRCNT98
__I uint32_t TRNG_Type::PKRCNTBA
__I uint32_t TRNG_Type::PKRCNTDC
__I uint32_t TRNG_Type::PKRCNTFE
__IO uint32_t TRNG_Type::SEC_CFG
__IO uint32_t TRNG_Type::INT_CTRL
__IO uint32_t TRNG_Type::INT_MASK
__I uint32_t TRNG_Type::INT_STATUS
uint8_t TRNG_Type::RESERVED_0 [64]
__I uint32_t TRNG_Type::VID1
__I uint32_t TRNG_Type::VID2
__IO uint32_t TSC_Type::BASIC_SETTING
uint8_t TSC_Type::RESERVED_0 [12]
__IO uint32_t TSC_Type::PRE_CHARGE_TIME
uint8_t TSC_Type::RESERVED_1 [12]
__IO uint32_t TSC_Type::FLOW_CONTROL
uint8_t TSC_Type::RESERVED_2 [12]
__I uint32_t TSC_Type::MEASEURE_VALUE
uint8_t TSC_Type::RESERVED_3 [12]
__IO uint32_t TSC_Type::INT_EN
uint8_t TSC_Type::RESERVED_4 [12]
__IO uint32_t TSC_Type::INT_SIG_EN
uint8_t TSC_Type::RESERVED_5 [12]
__IO uint32_t TSC_Type::INT_STATUS
uint8_t TSC_Type::RESERVED_6 [12]
__IO uint32_t TSC_Type::DEBUG_MODE
uint8_t TSC_Type::RESERVED_7 [12]
__IO uint32_t TSC_Type::DEBUG_MODE2
__I uint32_t USB_Type::ID
__I uint32_t USB_Type::HWGENERAL
__I uint32_t USB_Type::HWHOST
__I uint32_t USB_Type::HWDEVICE
__I uint32_t USB_Type::HWTXBUF
__I uint32_t USB_Type::HWRXBUF
uint8_t USB_Type::RESERVED_0 [104]
__IO uint32_t USB_Type::GPTIMER0LD
__IO uint32_t USB_Type::GPTIMER0CTRL
__IO uint32_t USB_Type::GPTIMER1LD
__IO uint32_t USB_Type::GPTIMER1CTRL
__IO uint32_t USB_Type::SBUSCFG
uint8_t USB_Type::RESERVED_1 [108]
__I uint8_t USB_Type::CAPLENGTH
uint8_t USB_Type::RESERVED_2 [1]
__I uint16_t USB_Type::HCIVERSION
__I uint32_t USB_Type::HCSPARAMS
__I uint32_t USB_Type::HCCPARAMS
uint8_t USB_Type::RESERVED_3 [20]
__I uint16_t USB_Type::DCIVERSION
uint8_t USB_Type::RESERVED_4 [2]
__I uint32_t USB_Type::DCCPARAMS
uint8_t USB_Type::RESERVED_5 [24]
__IO uint32_t USB_Type::USBCMD
__IO uint32_t USB_Type::USBSTS
__IO uint32_t USB_Type::USBINTR
__IO uint32_t USB_Type::FRINDEX
uint8_t USB_Type::RESERVED_6 [4]
__IO uint32_t   USB_Type::DEVICEADDR
__IO uint32_t   USB_Type::PERIODICLISTBASE
union {
__IO uint32_t   USB_Type::ASYNCLISTADDR
__IO uint32_t   USB_Type::ENDPTLISTADDR
union {
uint8_t USB_Type::RESERVED_7 [4]
__IO uint32_t USB_Type::BURSTSIZE
__IO uint32_t USB_Type::TXFILLTUNING
uint8_t USB_Type::RESERVED_8 [16]
__IO uint32_t USB_Type::ENDPTNAK
__IO uint32_t USB_Type::ENDPTNAKEN
__I uint32_t USB_Type::CONFIGFLAG
__IO uint32_t USB_Type::PORTSC1
uint8_t USB_Type::RESERVED_9 [28]
__IO uint32_t USB_Type::OTGSC
__IO uint32_t USB_Type::USBMODE
__IO uint32_t USB_Type::ENDPTSETUPSTAT
__IO uint32_t USB_Type::ENDPTPRIME
__IO uint32_t USB_Type::ENDPTFLUSH
__I uint32_t USB_Type::ENDPTSTAT
__IO uint32_t USB_Type::ENDPTCOMPLETE
__IO uint32_t USB_Type::ENDPTCTRL0
__IO uint32_t USB_Type::ENDPTCTRL [7]
uint8_t USBNC_Type::RESERVED_0 [2048]
__IO uint32_t USBNC_Type::USB_OTGn_CTRL
uint8_t USBNC_Type::RESERVED_1 [20]
__IO uint32_t USBNC_Type::USB_OTGn_PHY_CTRL_0
__IO uint32_t USBPHY_Type::PWD
__IO uint32_t USBPHY_Type::PWD_SET
__IO uint32_t USBPHY_Type::PWD_CLR
__IO uint32_t USBPHY_Type::PWD_TOG
__IO uint32_t USBPHY_Type::TX
__IO uint32_t USBPHY_Type::TX_SET
__IO uint32_t USBPHY_Type::TX_CLR
__IO uint32_t USBPHY_Type::TX_TOG
__IO uint32_t USBPHY_Type::RX
__IO uint32_t USBPHY_Type::RX_SET
__IO uint32_t USBPHY_Type::RX_CLR
__IO uint32_t USBPHY_Type::RX_TOG
__IO uint32_t USBPHY_Type::CTRL
__IO uint32_t USBPHY_Type::CTRL_SET
__IO uint32_t USBPHY_Type::CTRL_CLR
__IO uint32_t USBPHY_Type::CTRL_TOG
__IO uint32_t USBPHY_Type::STATUS
uint8_t USBPHY_Type::RESERVED_0 [12]
__IO uint32_t USBPHY_Type::DEBUGr
__IO uint32_t USBPHY_Type::DEBUG_SET
__IO uint32_t USBPHY_Type::DEBUG_CLR
__IO uint32_t USBPHY_Type::DEBUG_TOG
__I uint32_t USBPHY_Type::DEBUG0_STATUS
uint8_t USBPHY_Type::RESERVED_1 [12]
__IO uint32_t USBPHY_Type::DEBUG1
__IO uint32_t USBPHY_Type::DEBUG1_SET
__IO uint32_t USBPHY_Type::DEBUG1_CLR
__IO uint32_t USBPHY_Type::DEBUG1_TOG
__I uint32_t USBPHY_Type::VERSION
uint8_t USB_ANALOG_Type::RESERVED_0 [416]
__IO uint32_t   USB_ANALOG_Type::VBUS_DETECT
__IO uint32_t   USB_ANALOG_Type::VBUS_DETECT_SET
__IO uint32_t   USB_ANALOG_Type::VBUS_DETECT_CLR
__IO uint32_t   USB_ANALOG_Type::VBUS_DETECT_TOG
__IO uint32_t   USB_ANALOG_Type::CHRG_DETECT
__IO uint32_t   USB_ANALOG_Type::CHRG_DETECT_SET
__IO uint32_t   USB_ANALOG_Type::CHRG_DETECT_CLR
__IO uint32_t   USB_ANALOG_Type::CHRG_DETECT_TOG
__I uint32_t   USB_ANALOG_Type::VBUS_DETECT_STAT
uint8_t   USB_ANALOG_Type::RESERVED_0 [12]
__I uint32_t   USB_ANALOG_Type::CHRG_DETECT_STAT
uint8_t   USB_ANALOG_Type::RESERVED_1 [12]
__IO uint32_t   USB_ANALOG_Type::LOOPBACK
__IO uint32_t   USB_ANALOG_Type::LOOPBACK_SET
__IO uint32_t   USB_ANALOG_Type::LOOPBACK_CLR
__IO uint32_t   USB_ANALOG_Type::LOOPBACK_TOG
__IO uint32_t   USB_ANALOG_Type::MISC
__IO uint32_t   USB_ANALOG_Type::MISC_SET
__IO uint32_t   USB_ANALOG_Type::MISC_CLR
__IO uint32_t   USB_ANALOG_Type::MISC_TOG
struct {
USB_ANALOG_Type::INSTANCE [2]
__I uint32_t USB_ANALOG_Type::DIGPROG
__IO uint32_t USDHC_Type::DS_ADDR
__IO uint32_t USDHC_Type::BLK_ATT
__IO uint32_t USDHC_Type::CMD_ARG
__IO uint32_t USDHC_Type::CMD_XFR_TYP
__I uint32_t USDHC_Type::CMD_RSP0
__I uint32_t USDHC_Type::CMD_RSP1
__I uint32_t USDHC_Type::CMD_RSP2
__I uint32_t USDHC_Type::CMD_RSP3
__IO uint32_t USDHC_Type::DATA_BUFF_ACC_PORT
__I uint32_t USDHC_Type::PRES_STATE
__IO uint32_t USDHC_Type::PROT_CTRL
__IO uint32_t USDHC_Type::SYS_CTRL
__IO uint32_t USDHC_Type::INT_STATUS
__IO uint32_t USDHC_Type::INT_STATUS_EN
__IO uint32_t USDHC_Type::INT_SIGNAL_EN
__IO uint32_t USDHC_Type::AUTOCMD12_ERR_STATUS
__IO uint32_t USDHC_Type::HOST_CTRL_CAP
__IO uint32_t USDHC_Type::WTMK_LVL
__IO uint32_t USDHC_Type::MIX_CTRL
uint8_t USDHC_Type::RESERVED_0 [4]
__O uint32_t USDHC_Type::FORCE_EVENT
__I uint32_t USDHC_Type::ADMA_ERR_STATUS
__IO uint32_t USDHC_Type::ADMA_SYS_ADDR
uint8_t USDHC_Type::RESERVED_1 [4]
__IO uint32_t USDHC_Type::DLL_CTRL
__I uint32_t USDHC_Type::DLL_STATUS
__IO uint32_t USDHC_Type::CLK_TUNE_CTRL_STATUS
uint8_t USDHC_Type::RESERVED_2 [84]
__IO uint32_t USDHC_Type::VEND_SPEC
__IO uint32_t USDHC_Type::MMC_BOOT
__IO uint32_t USDHC_Type::VEND_SPEC2
__IO uint32_t USDHC_Type::TUNING_CTRL
__IO uint16_t WDOG_Type::WCR
__IO uint16_t WDOG_Type::WSR
__I uint16_t WDOG_Type::WRSR
__IO uint16_t WDOG_Type::WICR
__IO uint16_t WDOG_Type::WMCR
__IO uint16_t XBARA_Type::SEL0
__IO uint16_t XBARA_Type::SEL1
__IO uint16_t XBARA_Type::SEL2
__IO uint16_t XBARA_Type::SEL3
__IO uint16_t XBARA_Type::SEL4
__IO uint16_t XBARA_Type::SEL5
__IO uint16_t XBARA_Type::SEL6
__IO uint16_t XBARA_Type::SEL7
__IO uint16_t XBARA_Type::SEL8
__IO uint16_t XBARA_Type::SEL9
__IO uint16_t XBARA_Type::SEL10
__IO uint16_t XBARA_Type::SEL11
__IO uint16_t XBARA_Type::SEL12
__IO uint16_t XBARA_Type::SEL13
__IO uint16_t XBARA_Type::SEL14
__IO uint16_t XBARA_Type::SEL15
__IO uint16_t XBARA_Type::SEL16
__IO uint16_t XBARA_Type::SEL17
__IO uint16_t XBARA_Type::SEL18
__IO uint16_t XBARA_Type::SEL19
__IO uint16_t XBARA_Type::SEL20
__IO uint16_t XBARA_Type::SEL21
__IO uint16_t XBARA_Type::SEL22
__IO uint16_t XBARA_Type::SEL23
__IO uint16_t XBARA_Type::SEL24
__IO uint16_t XBARA_Type::SEL25
__IO uint16_t XBARA_Type::SEL26
__IO uint16_t XBARA_Type::SEL27
__IO uint16_t XBARA_Type::SEL28
__IO uint16_t XBARA_Type::SEL29
__IO uint16_t XBARA_Type::SEL30
__IO uint16_t XBARA_Type::SEL31
__IO uint16_t XBARA_Type::SEL32
__IO uint16_t XBARA_Type::SEL33
__IO uint16_t XBARA_Type::SEL34
__IO uint16_t XBARA_Type::SEL35
__IO uint16_t XBARA_Type::SEL36
__IO uint16_t XBARA_Type::SEL37
__IO uint16_t XBARA_Type::SEL38
__IO uint16_t XBARA_Type::SEL39
__IO uint16_t XBARA_Type::SEL40
__IO uint16_t XBARA_Type::SEL41
__IO uint16_t XBARA_Type::SEL42
__IO uint16_t XBARA_Type::SEL43
__IO uint16_t XBARA_Type::SEL44
__IO uint16_t XBARA_Type::SEL45
__IO uint16_t XBARA_Type::SEL46
__IO uint16_t XBARA_Type::SEL47
__IO uint16_t XBARA_Type::SEL48
__IO uint16_t XBARA_Type::SEL49
__IO uint16_t XBARA_Type::SEL50
__IO uint16_t XBARA_Type::SEL51
__IO uint16_t XBARA_Type::SEL52
__IO uint16_t XBARA_Type::SEL53
__IO uint16_t XBARA_Type::SEL54
__IO uint16_t XBARA_Type::SEL55
__IO uint16_t XBARA_Type::SEL56
__IO uint16_t XBARA_Type::SEL57
__IO uint16_t XBARA_Type::SEL58
__IO uint16_t XBARA_Type::SEL59
__IO uint16_t XBARA_Type::SEL60
__IO uint16_t XBARA_Type::SEL61
__IO uint16_t XBARA_Type::SEL62
__IO uint16_t XBARA_Type::SEL63
__IO uint16_t XBARA_Type::SEL64
__IO uint16_t XBARA_Type::SEL65
__IO uint16_t XBARA_Type::CTRL0
__IO uint16_t XBARA_Type::CTRL1
__IO uint16_t XBARB_Type::SEL0
__IO uint16_t XBARB_Type::SEL1
__IO uint16_t XBARB_Type::SEL2
__IO uint16_t XBARB_Type::SEL3
__IO uint16_t XBARB_Type::SEL4
__IO uint16_t XBARB_Type::SEL5
__IO uint16_t XBARB_Type::SEL6
__IO uint16_t XBARB_Type::SEL7
uint8_t XTALOSC24M_Type::RESERVED_0 [336]
__IO uint32_t XTALOSC24M_Type::MISC0
__IO uint32_t XTALOSC24M_Type::MISC0_SET
__IO uint32_t XTALOSC24M_Type::MISC0_CLR
__IO uint32_t XTALOSC24M_Type::MISC0_TOG
uint8_t XTALOSC24M_Type::RESERVED_1 [272]
__IO uint32_t XTALOSC24M_Type::LOWPWR_CTRL
__IO uint32_t XTALOSC24M_Type::LOWPWR_CTRL_SET
__IO uint32_t XTALOSC24M_Type::LOWPWR_CTRL_CLR
__IO uint32_t XTALOSC24M_Type::LOWPWR_CTRL_TOG
uint8_t XTALOSC24M_Type::RESERVED_2 [32]
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG0
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG0_SET
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG0_CLR
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG0_TOG
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG1
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG1_SET
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG1_CLR
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG1_TOG
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG2
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG2_SET
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG2_CLR
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG2_TOG
__I uint32_t ADC_Type::VERID
__I uint32_t ADC_Type::PARAM
uint8_t ADC_Type::RESERVED_0 [8]
__IO uint32_t ADC_Type::CTRL
__IO uint32_t ADC_Type::STAT
__IO uint32_t ADC_Type::IE
__IO uint32_t ADC_Type::DE
__IO uint32_t ADC_Type::PAUSE
uint8_t ADC_Type::RESERVED_1 [8]
__IO uint32_t ADC_Type::FCTRL
__O uint32_t ADC_Type::SWTRIG
uint8_t ADC_Type::RESERVED_2 [136]
__IO uint32_t ADC_Type::TCTRL [8]
uint8_t ADC_Type::RESERVED_3 [32]
__IO uint32_t   ADC_Type::CMDL
__IO uint32_t   ADC_Type::CMDH
struct {
ADC_Type::CMD [15]
uint8_t ADC_Type::RESERVED_4 [136]
uint8_t ADC_Type::RESERVED_5 [240]
__I uint32_t ADC_Type::RESFIFO
struct {
uint8_t ANADIG_LDO_SNVS_Type::RESERVED_0 [1296]
__IO uint32_t ANADIG_LDO_SNVS_Type::PMU_LDO_LPSR_ANA
uint8_t ANADIG_LDO_SNVS_Type::RESERVED_1 [12]
__IO uint32_t ANADIG_LDO_SNVS_Type::PMU_LDO_LPSR_DIG_2
uint8_t ANADIG_LDO_SNVS_Type::RESERVED_2 [12]
uint8_t ANADIG_LDO_SNVS_DIG_Type::RESERVED_0 [1344]
__IO uint32_t ANADIG_LDO_SNVS_DIG_Type::PMU_LDO_SNVS_DIG
uint8_t ANADIG_MISC_Type::RESERVED_0 [2048]
__I uint32_t ANADIG_MISC_Type::MISC_DIFPROG
uint8_t ANADIG_MISC_Type::RESERVED_1 [28]
__IO uint32_t ANADIG_MISC_Type::VDDSOC_AI_CTRL
uint8_t ANADIG_MISC_Type::RESERVED_2 [12]
__IO uint32_t ANADIG_MISC_Type::VDDSOC_AI_WDATA
uint8_t ANADIG_MISC_Type::RESERVED_3 [12]
__I uint32_t ANADIG_MISC_Type::VDDSOC_AI_RDATA
uint8_t ANADIG_MISC_Type::RESERVED_4 [12]
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_CTRL_1G
uint8_t ANADIG_MISC_Type::RESERVED_5 [12]
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_WDATA_1G
uint8_t ANADIG_MISC_Type::RESERVED_6 [12]
__I uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_RDATA_1G
uint8_t ANADIG_MISC_Type::RESERVED_7 [12]
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_CTRL_AUDIO
uint8_t ANADIG_MISC_Type::RESERVED_8 [12]
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_WDATA_AUDIO
uint8_t ANADIG_MISC_Type::RESERVED_9 [12]
__I uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_RDATA_AUDIO
uint8_t ANADIG_MISC_Type::RESERVED_10 [12]
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_CTRL_VIDEO
uint8_t ANADIG_MISC_Type::RESERVED_11 [12]
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_WDATA_VIDEO
uint8_t ANADIG_MISC_Type::RESERVED_12 [12]
__I uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_RDATA_VIDEO
uint8_t ANADIG_MISC_Type::RESERVED_13 [12]
__IO uint32_t ANADIG_MISC_Type::VDDLPSR_AI_CTRL
uint8_t ANADIG_MISC_Type::RESERVED_14 [12]
__IO uint32_t ANADIG_MISC_Type::VDDLPSR_AI_WDATA
uint8_t ANADIG_MISC_Type::RESERVED_15 [12]
__I uint32_t ANADIG_MISC_Type::VDDLPSR_AI_RDATA_REFTOP
uint8_t ANADIG_MISC_Type::RESERVED_16 [12]
__I uint32_t ANADIG_MISC_Type::VDDLPSR_AI_RDATA_TMPSNS
uint8_t ANADIG_MISC_Type::RESERVED_17 [12]
__IO uint32_t ANADIG_MISC_Type::VDDLPSR_AI400M_CTRL
uint8_t ANADIG_MISC_Type::RESERVED_18 [12]
__IO uint32_t ANADIG_MISC_Type::VDDLPSR_AI400M_WDATA
uint8_t ANADIG_MISC_Type::RESERVED_19 [12]
__I uint32_t ANADIG_MISC_Type::VDDLPSR_AI400M_RDATA
uint8_t ANADIG_OSC_Type::RESERVED_0 [16]
__IO uint32_t ANADIG_OSC_Type::OSC_48M_CTRL
uint8_t ANADIG_OSC_Type::RESERVED_1 [12]
__IO uint32_t ANADIG_OSC_Type::OSC_24M_CTRL
uint8_t ANADIG_OSC_Type::RESERVED_2 [28]
__I uint32_t ANADIG_OSC_Type::OSC_400M_CTRL0
uint8_t ANADIG_OSC_Type::RESERVED_3 [12]
__IO uint32_t ANADIG_OSC_Type::OSC_400M_CTRL1
uint8_t ANADIG_OSC_Type::RESERVED_4 [12]
__IO uint32_t ANADIG_OSC_Type::OSC_400M_CTRL2
uint8_t ANADIG_OSC_Type::RESERVED_5 [92]
__IO uint32_t ANADIG_OSC_Type::OSC_16M_CTRL
uint8_t ANADIG_PLL_Type::RESERVED_0 [512]
__IO uint32_t ANADIG_PLL_Type::ARM_PLL_CTRL
uint8_t ANADIG_PLL_Type::RESERVED_1 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL3_CTRL
uint8_t ANADIG_PLL_Type::RESERVED_2 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL3_UPDATE
uint8_t ANADIG_PLL_Type::RESERVED_3 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL3_PFD
uint8_t ANADIG_PLL_Type::RESERVED_4 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL2_CTRL
uint8_t ANADIG_PLL_Type::RESERVED_5 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL2_UPDATE
uint8_t ANADIG_PLL_Type::RESERVED_6 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL2_SS
uint8_t ANADIG_PLL_Type::RESERVED_7 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL2_PFD
uint8_t ANADIG_PLL_Type::RESERVED_8 [44]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL2_MFD
uint8_t ANADIG_PLL_Type::RESERVED_9 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL1_SS
uint8_t ANADIG_PLL_Type::RESERVED_10 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL1_CTRL
uint8_t ANADIG_PLL_Type::RESERVED_11 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL1_DENOMINATOR
uint8_t ANADIG_PLL_Type::RESERVED_12 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL1_NUMERATOR
uint8_t ANADIG_PLL_Type::RESERVED_13 [12]
__IO uint32_t ANADIG_PLL_Type::SYS_PLL1_DIV_SELECT
uint8_t ANADIG_PLL_Type::RESERVED_14 [12]
__IO uint32_t ANADIG_PLL_Type::PLL_AUDIO_CTRL
uint8_t ANADIG_PLL_Type::RESERVED_15 [12]
__IO uint32_t ANADIG_PLL_Type::PLL_AUDIO_SS
uint8_t ANADIG_PLL_Type::RESERVED_16 [12]
__IO uint32_t ANADIG_PLL_Type::PLL_AUDIO_DENOMINATOR
uint8_t ANADIG_PLL_Type::RESERVED_17 [12]
__IO uint32_t ANADIG_PLL_Type::PLL_AUDIO_NUMERATOR
uint8_t ANADIG_PLL_Type::RESERVED_18 [12]
__IO uint32_t ANADIG_PLL_Type::PLL_AUDIO_DIV_SELECT
uint8_t ANADIG_PLL_Type::RESERVED_19 [12]
__IO uint32_t ANADIG_PLL_Type::PLL_VIDEO_CTRL
uint8_t ANADIG_PLL_Type::RESERVED_20 [12]
__IO uint32_t ANADIG_PLL_Type::PLL_VIDEO_SS
uint8_t ANADIG_PLL_Type::RESERVED_21 [12]
__IO uint32_t ANADIG_PLL_Type::PLL_VIDEO_DENOMINATOR
uint8_t ANADIG_PLL_Type::RESERVED_22 [12]
__IO uint32_t ANADIG_PLL_Type::PLL_VIDEO_NUMERATOR
uint8_t ANADIG_PLL_Type::RESERVED_23 [12]
__IO uint32_t ANADIG_PLL_Type::PLL_VIDEO_DIV_SELECT
uint8_t ANADIG_PMU_Type::RESERVED_0 [1280]
__IO uint32_t ANADIG_PMU_Type::PMU_LDO_PLL
uint8_t ANADIG_PMU_Type::RESERVED_1 [76]
__IO uint32_t ANADIG_PMU_Type::PMU_BIAS_CTRL
uint8_t ANADIG_PMU_Type::RESERVED_2 [12]
__IO uint32_t ANADIG_PMU_Type::PMU_BIAS_CTRL2
uint8_t ANADIG_PMU_Type::RESERVED_3 [12]
__IO uint32_t ANADIG_PMU_Type::PMU_REF_CTRL
uint8_t ANADIG_PMU_Type::RESERVED_4 [12]
__IO uint32_t ANADIG_PMU_Type::PMU_POWER_DETECT_CTRL
uint8_t ANADIG_PMU_Type::RESERVED_5 [124]
__IO uint32_t ANADIG_PMU_Type::LDO_PLL_ENABLE_SP
uint8_t ANADIG_PMU_Type::RESERVED_6 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_ANA_ENABLE_SP
uint8_t ANADIG_PMU_Type::RESERVED_7 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_ANA_LP_MODE_SP
uint8_t ANADIG_PMU_Type::RESERVED_8 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_ANA_TRACKING_EN_SP
uint8_t ANADIG_PMU_Type::RESERVED_9 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_ANA_BYPASS_EN_SP
uint8_t ANADIG_PMU_Type::RESERVED_10 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_ANA_STBY_EN_SP
uint8_t ANADIG_PMU_Type::RESERVED_11 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_ENABLE_SP
uint8_t ANADIG_PMU_Type::RESERVED_12 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_TRG_SP0
uint8_t ANADIG_PMU_Type::RESERVED_13 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_TRG_SP1
uint8_t ANADIG_PMU_Type::RESERVED_14 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_TRG_SP2
uint8_t ANADIG_PMU_Type::RESERVED_15 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_TRG_SP3
uint8_t ANADIG_PMU_Type::RESERVED_16 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_LP_MODE_SP
uint8_t ANADIG_PMU_Type::RESERVED_17 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_TRACKING_EN_SP
uint8_t ANADIG_PMU_Type::RESERVED_18 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_BYPASS_EN_SP
uint8_t ANADIG_PMU_Type::RESERVED_19 [12]
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_STBY_EN_SP
uint8_t ANADIG_PMU_Type::RESERVED_20 [12]
__IO uint32_t ANADIG_PMU_Type::BANDGAP_ENABLE_SP
uint8_t ANADIG_PMU_Type::RESERVED_21 [28]
__IO uint32_t ANADIG_PMU_Type::RBB_SOC_ENABLE_SP
uint8_t ANADIG_PMU_Type::RESERVED_22 [12]
__IO uint32_t ANADIG_PMU_Type::RBB_LPSR_ENABLE_SP
uint8_t ANADIG_PMU_Type::RESERVED_23 [12]
__IO uint32_t ANADIG_PMU_Type::BANDGAP_STBY_EN_SP
uint8_t ANADIG_PMU_Type::RESERVED_24 [12]
__IO uint32_t ANADIG_PMU_Type::PLL_LDO_STBY_EN_SP
uint8_t ANADIG_PMU_Type::RESERVED_25 [28]
__IO uint32_t ANADIG_PMU_Type::RBB_SOC_STBY_EN_SP
uint8_t ANADIG_PMU_Type::RESERVED_26 [12]
__IO uint32_t ANADIG_PMU_Type::RBB_LPSR_STBY_EN_SP
uint8_t ANADIG_PMU_Type::RESERVED_27 [28]
__IO uint32_t ANADIG_PMU_Type::RBB_LPSR_CONFIGURE
uint8_t ANADIG_PMU_Type::RESERVED_28 [12]
__IO uint32_t ANADIG_PMU_Type::RBB_SOC_CONFIGURE
uint8_t ANADIG_PMU_Type::RESERVED_29 [12]
__I uint32_t ANADIG_PMU_Type::REFTOP_OTP_TRIM_VALUE
uint8_t ANADIG_PMU_Type::RESERVED_30 [28]
__I uint32_t ANADIG_PMU_Type::LPSR_1P8_LDO_OTP_TRIM_VALUE
uint8_t ANADIG_TEMPSENSOR_Type::RESERVED_0 [1024]
__IO uint32_t ANADIG_TEMPSENSOR_Type::TEMPSENSOR
uint8_t ANADIG_TEMPSENSOR_Type::RESERVED_1 [44]
__I uint32_t ANADIG_TEMPSENSOR_Type::TEMPSNS_OTP_TRIM_VALUE
__IO uint16_t   AOI_Type::BFCRT01
__IO uint16_t   AOI_Type::BFCRT23
struct {
AOI_Type::BFCRT [4]
__IO uint32_t ASRC_Type::ASRCTR
__IO uint32_t ASRC_Type::ASRIER
uint8_t ASRC_Type::RESERVED_0 [4]
__IO uint32_t ASRC_Type::ASRCNCR
__IO uint32_t ASRC_Type::ASRCFG
__IO uint32_t ASRC_Type::ASRCSR
__IO uint32_t ASRC_Type::ASRCDR1
__IO uint32_t ASRC_Type::ASRCDR2
__I uint32_t ASRC_Type::ASRSTR
uint8_t ASRC_Type::RESERVED_1 [28]
__IO uint32_t ASRC_Type::ASRPM [5]
__IO uint32_t ASRC_Type::ASRTFR1
uint8_t ASRC_Type::RESERVED_2 [4]
__IO uint32_t ASRC_Type::ASRCCR
__O uint32_t ASRC_Type::ASRDIA
__I uint32_t ASRC_Type::ASRDOA
__O uint32_t ASRC_Type::ASRDIB
__I uint32_t ASRC_Type::ASRDOB
__O uint32_t ASRC_Type::ASRDIC
__I uint32_t ASRC_Type::ASRDOC
uint8_t ASRC_Type::RESERVED_3 [8]
__IO uint32_t ASRC_Type::ASRIDRHA
__IO uint32_t ASRC_Type::ASRIDRLA
__IO uint32_t ASRC_Type::ASRIDRHB
__IO uint32_t ASRC_Type::ASRIDRLB
__IO uint32_t ASRC_Type::ASRIDRHC
__IO uint32_t ASRC_Type::ASRIDRLC
__IO uint32_t ASRC_Type::ASR76K
__IO uint32_t ASRC_Type::ASR56K
__IO uint32_t ASRC_Type::ASRMCRA
__I uint32_t ASRC_Type::ASRFSTA
__IO uint32_t ASRC_Type::ASRMCRB
__I uint32_t ASRC_Type::ASRFSTB
__IO uint32_t ASRC_Type::ASRMCRC
__I uint32_t ASRC_Type::ASRFSTC
uint8_t ASRC_Type::RESERVED_4 [8]
__IO uint32_t ASRC_Type::ASRMCR1 [3]
__IO uint32_t   AUDIO_PLL_Type::RW
__IO uint32_t   AUDIO_PLL_Type::SET
__IO uint32_t   AUDIO_PLL_Type::CLR
__IO uint32_t   AUDIO_PLL_Type::TOG
struct {
AUDIO_PLL_Type::CTRL0
struct {
AUDIO_PLL_Type::SPREAD_SPECTRUM
struct {
AUDIO_PLL_Type::NUMERATOR
struct {
AUDIO_PLL_Type::DENOMINATOR
uint8_t CAAM_Type::RESERVED_0 [4]
__IO uint32_t CAAM_Type::MCFGR
__IO uint32_t CAAM_Type::PAGE0_SDID
__IO uint32_t CAAM_Type::SCFGR
__IO uint32_t   CAAM_Type::JRDID_MS
__IO uint32_t   CAAM_Type::JRDID_LS
struct {
CAAM_Type::JRADID [4]
uint8_t CAAM_Type::RESERVED_1 [40]
__IO uint32_t CAAM_Type::DEBUGCTL
__IO uint32_t CAAM_Type::JRSTARTR
__IO uint32_t CAAM_Type::RTIC_OWN
__IO uint32_t   CAAM_Type::RTIC_DID
struct {
CAAM_Type::RTICADID [4]
uint8_t CAAM_Type::RESERVED_2 [16]
__IO uint32_t CAAM_Type::DECORSR
uint8_t CAAM_Type::RESERVED_3 [4]
__IO uint32_t CAAM_Type::DECORR
__IO uint32_t   CAAM_Type::DECODID_MS
__IO uint32_t   CAAM_Type::DECODID_LS
struct {
CAAM_Type::DECONDID [1]
uint8_t CAAM_Type::RESERVED_4 [120]
__IO uint32_t CAAM_Type::DAR
__O uint32_t CAAM_Type::DRR
uint8_t CAAM_Type::RESERVED_5 [92]
__IO uint32_t   CAAM_Type::JRSMVBAR
struct {
CAAM_Type::JRNSMVBAR [4]
uint8_t CAAM_Type::RESERVED_6 [124]
__IO uint32_t CAAM_Type::PBSL
uint8_t CAAM_Type::RESERVED_7 [28]
__I uint32_t   CAAM_Type::DMA_AIDL_MAP_MS
__I uint32_t   CAAM_Type::DMA_AIDL_MAP_LS
__I uint32_t   CAAM_Type::DMA_AIDM_MAP_MS
__I uint32_t   CAAM_Type::DMA_AIDM_MAP_LS
struct {
CAAM_Type::AID_CNTS [1]
__I uint32_t CAAM_Type::DMA0_AID_ENB
uint8_t CAAM_Type::RESERVED_8 [12]
__IO uint64_t CAAM_Type::DMA0_ARD_TC
uint8_t CAAM_Type::RESERVED_9 [4]
__IO uint32_t CAAM_Type::DMA0_ARD_LAT
__IO uint64_t CAAM_Type::DMA0_AWR_TC
uint8_t CAAM_Type::RESERVED_10 [4]
__IO uint32_t CAAM_Type::DMA0_AWR_LAT
uint8_t CAAM_Type::RESERVED_11 [128]
__IO uint8_t CAAM_Type::MPPKR [64]
uint8_t CAAM_Type::RESERVED_12 [64]
__IO uint8_t CAAM_Type::MPMR [32]
uint8_t CAAM_Type::RESERVED_13 [32]
__I uint8_t CAAM_Type::MPTESTR [32]
uint8_t CAAM_Type::RESERVED_14 [24]
__I uint32_t CAAM_Type::MPECC
uint8_t CAAM_Type::RESERVED_15 [4]
__IO uint32_t CAAM_Type::JDKEKR [8]
__IO uint32_t CAAM_Type::TDKEKR [8]
__IO uint32_t CAAM_Type::TDSKR [8]
uint8_t CAAM_Type::RESERVED_16 [128]
__IO uint64_t CAAM_Type::SKNR
uint8_t CAAM_Type::RESERVED_17 [36]
__I uint32_t CAAM_Type::DMA_STA
__I uint32_t CAAM_Type::DMA_X_AID_7_4_MAP
__I uint32_t CAAM_Type::DMA_X_AID_3_0_MAP
__I uint32_t CAAM_Type::DMA_X_AID_15_12_MAP
__I uint32_t CAAM_Type::DMA_X_AID_11_8_MAP
uint8_t CAAM_Type::RESERVED_18 [4]
__I uint32_t CAAM_Type::DMA_X_AID_15_0_EN
uint8_t CAAM_Type::RESERVED_19 [8]
__IO uint32_t CAAM_Type::DMA_X_ARTC_CTL
__IO uint32_t CAAM_Type::DMA_X_ARTC_LC
__IO uint32_t CAAM_Type::DMA_X_ARTC_SC
__IO uint32_t CAAM_Type::DMA_X_ARTC_LAT
__IO uint32_t CAAM_Type::DMA_X_AWTC_CTL
__IO uint32_t CAAM_Type::DMA_X_AWTC_LC
__IO uint32_t CAAM_Type::DMA_X_AWTC_SC
__IO uint32_t CAAM_Type::DMA_X_AWTC_LAT
uint8_t CAAM_Type::RESERVED_20 [176]
__IO uint32_t CAAM_Type::RTMCTL
__IO uint32_t CAAM_Type::RTSCMISC
__IO uint32_t CAAM_Type::RTPKRRNG
__IO uint32_t   CAAM_Type::RTPKRMAX
__I uint32_t   CAAM_Type::RTPKRSQ
union {
__IO uint32_t CAAM_Type::RTSDCTL
__IO uint32_t   CAAM_Type::RTSBLIM
__I uint32_t   CAAM_Type::RTTOTSAM
union {
__IO uint32_t CAAM_Type::RTFRQMIN
__I uint32_t   CAAM_Type::RTFRQCNT
__I uint32_t   CAAM_Type::RTSCMC
__I uint32_t   CAAM_Type::RTSCR1C
__I uint32_t   CAAM_Type::RTSCR2C
__I uint32_t   CAAM_Type::RTSCR3C
__I uint32_t   CAAM_Type::RTSCR4C
__I uint32_t   CAAM_Type::RTSCR5C
__I uint32_t   CAAM_Type::RTSCR6PC
struct {
}   CAAM_Type::COUNT
__IO uint32_t   CAAM_Type::RTFRQMAX
__IO uint32_t   CAAM_Type::RTSCML
__IO uint32_t   CAAM_Type::RTSCR1L
__IO uint32_t   CAAM_Type::RTSCR2L
__IO uint32_t   CAAM_Type::RTSCR3L
__IO uint32_t   CAAM_Type::RTSCR4L
__IO uint32_t   CAAM_Type::RTSCR5L
__IO uint32_t   CAAM_Type::RTSCR6PL
struct {
}   CAAM_Type::LIMIT
union {
   struct {
   }   COUNT
   struct {
   }   LIMIT
__I uint32_t CAAM_Type::RTSTATUS
__I uint32_t CAAM_Type::RTENT [16]
__I uint32_t CAAM_Type::RTPKRCNT10
__I uint32_t CAAM_Type::RTPKRCNT32
__I uint32_t CAAM_Type::RTPKRCNT54
__I uint32_t CAAM_Type::RTPKRCNT76
__I uint32_t CAAM_Type::RTPKRCNT98
__I uint32_t CAAM_Type::RTPKRCNTBA
__I uint32_t CAAM_Type::RTPKRCNTDC
__I uint32_t CAAM_Type::RTPKRCNTFE
uint8_t CAAM_Type::RESERVED_21 [32]
__I uint32_t CAAM_Type::RDSTA
uint8_t CAAM_Type::RESERVED_22 [12]
__I uint32_t CAAM_Type::RDINT0
__I uint32_t CAAM_Type::RDINT1
uint8_t CAAM_Type::RESERVED_23 [8]
__IO uint32_t CAAM_Type::RDHCNTL
__I uint32_t CAAM_Type::RDHDIG
__O uint32_t CAAM_Type::RDHBUF
uint8_t CAAM_Type::RESERVED_24 [788]
__I uint32_t   CAAM_Type::PX_SDID_PG0
__IO uint32_t   CAAM_Type::PX_SMAPR_PG0
__IO uint32_t   CAAM_Type::PX_SMAG2_PG0
__IO uint32_t   CAAM_Type::PX_SMAG1_PG0
struct {
CAAM_Type::PX_PG0 [16]
__IO uint32_t CAAM_Type::REIS
__IO uint32_t CAAM_Type::REIE
__I uint32_t CAAM_Type::REIF
__IO uint32_t CAAM_Type::REIH
uint8_t CAAM_Type::RESERVED_25 [192]
__IO uint32_t CAAM_Type::SMWPJRR [4]
uint8_t CAAM_Type::RESERVED_26 [4]
__O uint32_t CAAM_Type::SMCR_PG0
uint8_t CAAM_Type::RESERVED_27 [4]
__I uint32_t CAAM_Type::SMCSR_PG0
uint8_t CAAM_Type::RESERVED_28 [8]
__I uint32_t CAAM_Type::CAAMVID_MS_TRAD
__I uint32_t CAAM_Type::CAAMVID_LS_TRAD
__I uint64_t   CAAM_Type::HT_JD_ADDR
__I uint64_t   CAAM_Type::HT_SD_ADDR
__I uint32_t   CAAM_Type::HT_JQ_CTRL_MS
__I uint32_t   CAAM_Type::HT_JQ_CTRL_LS
__I uint32_t   CAAM_Type::HT_STATUS
struct {
CAAM_Type::HTA [1]
uint8_t CAAM_Type::RESERVED_29 [4]
__IO uint32_t CAAM_Type::JQ_DEBUG_SEL
uint8_t CAAM_Type::RESERVED_30 [404]
__I uint32_t CAAM_Type::JRJIDU_LS
__I uint32_t CAAM_Type::JRJDJIFBC
uint8_t CAAM_Type::RESERVED_31 [28]
__I uint32_t CAAM_Type::JRJDS1
uint8_t CAAM_Type::RESERVED_32 [24]
__I uint64_t CAAM_Type::JRJDDA [1]
uint8_t CAAM_Type::RESERVED_33 [408]
__I uint32_t CAAM_Type::CRNR_MS
__I uint32_t CAAM_Type::CRNR_LS
__I uint32_t CAAM_Type::CTPR_MS
__I uint32_t CAAM_Type::CTPR_LS
uint8_t CAAM_Type::RESERVED_34 [4]
__I uint32_t CAAM_Type::SMSTA
uint8_t CAAM_Type::RESERVED_35 [4]
__I uint32_t CAAM_Type::SMPO
__I uint64_t CAAM_Type::FAR
__I uint32_t CAAM_Type::FADID
__I uint32_t CAAM_Type::FADR
uint8_t CAAM_Type::RESERVED_36 [4]
__I uint32_t CAAM_Type::CSTA
__I uint32_t CAAM_Type::SMVID_MS
__I uint32_t CAAM_Type::SMVID_LS
__I uint32_t CAAM_Type::RVID
__I uint32_t CAAM_Type::CCBVID
__I uint32_t CAAM_Type::CHAVID_MS
__I uint32_t CAAM_Type::CHAVID_LS
__I uint32_t CAAM_Type::CHANUM_MS
__I uint32_t CAAM_Type::CHANUM_LS
uint8_t CAAM_Type::RESERVED_37 [61440]
__IO uint64_t   CAAM_Type::IRBAR_JR
__IO uint32_t   CAAM_Type::IRSR_JR
uint8_t   CAAM_Type::RESERVED_1 [4]
__IO uint32_t   CAAM_Type::IRSAR_JR
uint8_t   CAAM_Type::RESERVED_2 [4]
__IO uint32_t   CAAM_Type::IRJAR_JR
__IO uint64_t   CAAM_Type::ORBAR_JR
__IO uint32_t   CAAM_Type::ORSR_JR
uint8_t   CAAM_Type::RESERVED_4 [4]
__IO uint32_t   CAAM_Type::ORJRR_JR
uint8_t   CAAM_Type::RESERVED_5 [4]
__IO uint32_t   CAAM_Type::ORSFR_JR
uint8_t   CAAM_Type::RESERVED_6 [4]
__I uint32_t   CAAM_Type::JRSTAR_JR
uint8_t   CAAM_Type::RESERVED_7 [4]
__IO uint32_t   CAAM_Type::JRINTR_JR
__IO uint32_t   CAAM_Type::JRCFGR_JR_MS
__IO uint32_t   CAAM_Type::JRCFGR_JR_LS
uint8_t   CAAM_Type::RESERVED_8 [4]
__IO uint32_t   CAAM_Type::IRRIR_JR
__IO uint32_t   CAAM_Type::ORWIR_JR
__O uint32_t   CAAM_Type::JRCR_JR
uint8_t   CAAM_Type::RESERVED_11 [1684]
__I uint32_t   CAAM_Type::JRAAV
uint8_t   CAAM_Type::RESERVED_12 [248]
__I uint64_t   CAAM_Type::JRAAA [4]
uint8_t   CAAM_Type::RESERVED_13 [480]
__I uint32_t   CAAM_Type::PX_SDID_JR
__IO uint32_t   CAAM_Type::PX_SMAPR_JR
__IO uint32_t   CAAM_Type::PX_SMAG2_JR
__IO uint32_t   CAAM_Type::PX_SMAG1_JR
struct {
}   CAAM_Type::PX_JR [16]
uint8_t   CAAM_Type::RESERVED_14 [228]
__O uint32_t   CAAM_Type::SMCR_JR
__I uint32_t   CAAM_Type::SMCSR_JR
uint8_t   CAAM_Type::RESERVED_16 [528]
__I uint32_t   CAAM_Type::REIR0JR
uint8_t   CAAM_Type::RESERVED_17 [4]
__I uint64_t   CAAM_Type::REIR2JR
__I uint32_t   CAAM_Type::REIR4JR
__I uint32_t   CAAM_Type::REIR5JR
uint8_t   CAAM_Type::RESERVED_18 [392]
__I uint32_t   CAAM_Type::CRNR_MS_JR
__I uint32_t   CAAM_Type::CRNR_LS_JR
__I uint32_t   CAAM_Type::CTPR_MS_JR
__I uint32_t   CAAM_Type::CTPR_LS_JR
uint8_t   CAAM_Type::RESERVED_19 [4]
__I uint32_t   CAAM_Type::SMSTA_JR
uint8_t   CAAM_Type::RESERVED_20 [4]
__I uint32_t   CAAM_Type::SMPO_JR
__I uint64_t   CAAM_Type::FAR_JR
__I uint32_t   CAAM_Type::FADID_JR
__I uint32_t   CAAM_Type::FADR_JR
uint8_t   CAAM_Type::RESERVED_21 [4]
__I uint32_t   CAAM_Type::CSTA_JR
__I uint32_t   CAAM_Type::SMVID_MS_JR
__I uint32_t   CAAM_Type::SMVID_LS_JR
__I uint32_t   CAAM_Type::RVID_JR
__I uint32_t   CAAM_Type::CCBVID_JR
__I uint32_t   CAAM_Type::CHAVID_MS_JR
__I uint32_t   CAAM_Type::CHAVID_LS_JR
__I uint32_t   CAAM_Type::CHANUM_MS_JR
__I uint32_t   CAAM_Type::CHANUM_LS_JR
__I uint32_t   CAAM_Type::CAAMVID_MS_JR
__I uint32_t   CAAM_Type::CAAMVID_LS_JR
uint8_t   CAAM_Type::RESERVED_22 [61440]
struct {
   uint8_t   RESERVED_1 [4]
   uint8_t   RESERVED_2 [4]
   uint8_t   RESERVED_3 [4]
   uint8_t   RESERVED_4 [4]
   uint8_t   RESERVED_5 [4]
   uint8_t   RESERVED_6 [4]
   uint8_t   RESERVED_7 [4]
   uint8_t   RESERVED_8 [4]
   uint8_t   RESERVED_9 [4]
   uint8_t   RESERVED_10 [4]
   uint8_t   RESERVED_11 [1684]
   uint8_t   RESERVED_12 [248]
   uint8_t   RESERVED_13 [480]
   struct {
   }   PX_JR [16]
   uint8_t   RESERVED_14 [228]
   uint8_t   RESERVED_15 [4]
   uint8_t   RESERVED_16 [528]
   uint8_t   RESERVED_17 [4]
   uint8_t   RESERVED_18 [392]
   uint8_t   RESERVED_19 [4]
   uint8_t   RESERVED_20 [4]
   uint8_t   RESERVED_21 [4]
   uint8_t   RESERVED_22 [61440]
CAAM_Type::JOBRING [4]
uint8_t CAAM_Type::RESERVED_38 [65540]
__I uint32_t CAAM_Type::RSTA
uint8_t CAAM_Type::RESERVED_39 [4]
__IO uint32_t CAAM_Type::RCMD
uint8_t CAAM_Type::RESERVED_40 [4]
__IO uint32_t CAAM_Type::RCTL
uint8_t CAAM_Type::RESERVED_41 [4]
__IO uint32_t CAAM_Type::RTHR
uint8_t CAAM_Type::RESERVED_42 [8]
__IO uint64_t CAAM_Type::RWDOG
uint8_t CAAM_Type::RESERVED_43 [4]
__IO uint32_t CAAM_Type::REND
uint8_t CAAM_Type::RESERVED_44 [200]
__IO uint64_t   CAAM_Type::RMA
__IO uint32_t   CAAM_Type::RML
struct {
CAAM_Type::RM [4][2]
uint8_t CAAM_Type::RESERVED_45 [128]
__IO uint32_t CAAM_Type::RMD [4][2][32]
uint8_t CAAM_Type::RESERVED_46 [2048]
__I uint32_t CAAM_Type::REIR0RTIC
uint8_t CAAM_Type::RESERVED_47 [4]
__I uint64_t CAAM_Type::REIR2RTIC
__I uint32_t CAAM_Type::REIR4RTIC
__I uint32_t CAAM_Type::REIR5RTIC
uint8_t CAAM_Type::RESERVED_48 [392]
__I uint32_t CAAM_Type::CRNR_MS_RTIC
__I uint32_t CAAM_Type::CRNR_LS_RTIC
__I uint32_t CAAM_Type::CTPR_MS_RTIC
__I uint32_t CAAM_Type::CTPR_LS_RTIC
uint8_t CAAM_Type::RESERVED_49 [4]
__I uint32_t CAAM_Type::SMSTA_RTIC
uint8_t CAAM_Type::RESERVED_50 [8]
__I uint64_t CAAM_Type::FAR_RTIC
__I uint32_t CAAM_Type::FADID_RTIC
__I uint32_t CAAM_Type::FADR_RTIC
uint8_t CAAM_Type::RESERVED_51 [4]
__I uint32_t CAAM_Type::CSTA_RTIC
__I uint32_t CAAM_Type::SMVID_MS_RTIC
__I uint32_t CAAM_Type::SMVID_LS_RTIC
__I uint32_t CAAM_Type::RVID_RTIC
__I uint32_t CAAM_Type::CCBVID_RTIC
__I uint32_t CAAM_Type::CHAVID_MS_RTIC
__I uint32_t CAAM_Type::CHAVID_LS_RTIC
__I uint32_t CAAM_Type::CHANUM_MS_RTIC
__I uint32_t CAAM_Type::CHANUM_LS_RTIC
__I uint32_t CAAM_Type::CAAMVID_MS_RTIC
__I uint32_t CAAM_Type::CAAMVID_LS_RTIC
uint8_t CAAM_Type::RESERVED_52 [126976]
__IO uint32_t   CAAM_Type::CC1MR
__IO uint32_t   CAAM_Type::CC1MR_PK
__IO uint32_t   CAAM_Type::CC1MR_RNG
union {
__IO uint32_t   CAAM_Type::CC1KSR
__IO uint64_t   CAAM_Type::CC1DSR
__IO uint32_t   CAAM_Type::CC1ICVSR
uint8_t   CAAM_Type::RESERVED_3 [20]
__O uint32_t   CAAM_Type::CCCTRL
__IO uint32_t   CAAM_Type::CICTL
__O uint32_t   CAAM_Type::CCWR
__I uint32_t   CAAM_Type::CCSTA_MS
__I uint32_t   CAAM_Type::CCSTA_LS
uint8_t   CAAM_Type::RESERVED_6 [12]
__IO uint32_t   CAAM_Type::CC1AADSZR
__IO uint32_t   CAAM_Type::CC1IVSZR
uint8_t   CAAM_Type::RESERVED_8 [28]
__IO uint32_t   CAAM_Type::CPKASZR
__IO uint32_t   CAAM_Type::CPKBSZR
__IO uint32_t   CAAM_Type::CPKNSZR
uint8_t   CAAM_Type::RESERVED_11 [4]
__IO uint32_t   CAAM_Type::CPKESZR
uint8_t   CAAM_Type::RESERVED_12 [96]
__IO uint32_t   CAAM_Type::CC1CTXR [16]
uint8_t   CAAM_Type::RESERVED_13 [192]
__IO uint32_t   CAAM_Type::CC1KR [8]
uint8_t   CAAM_Type::RESERVED_14 [484]
__IO uint32_t   CAAM_Type::CC2MR
__IO uint32_t   CAAM_Type::CC2KSR
__IO uint64_t   CAAM_Type::CC2DSR
uint8_t   CAAM_Type::RESERVED_16 [4]
__IO uint32_t   CAAM_Type::CC2ICVSZR
uint8_t   CAAM_Type::RESERVED_17 [224]
__IO uint32_t   CAAM_Type::CC2CTXR [18]
uint8_t   CAAM_Type::RESERVED_18 [184]
__IO uint32_t   CAAM_Type::CC2KEYR [32]
uint8_t   CAAM_Type::RESERVED_19 [320]
__I uint32_t   CAAM_Type::CFIFOSTA
uint8_t   CAAM_Type::RESERVED_20 [12]
__O uint32_t   CAAM_Type::CNFIFO
__O uint32_t   CAAM_Type::CNFIFO_2
union {
uint8_t   CAAM_Type::RESERVED_21 [12]
__O uint32_t   CAAM_Type::CIFIFO
__I uint64_t   CAAM_Type::COFIFO
__IO uint32_t   CAAM_Type::DJQCR_MS
__I uint32_t   CAAM_Type::DJQCR_LS
__I uint64_t   CAAM_Type::DDAR
__I uint32_t   CAAM_Type::DOPSTA_MS
__I uint32_t   CAAM_Type::DOPSTA_LS
uint8_t   CAAM_Type::RESERVED_24 [8]
__I uint32_t   CAAM_Type::DPDIDSR
__I uint32_t   CAAM_Type::DODIDSR
uint8_t   CAAM_Type::RESERVED_25 [24]
__IO uint32_t   CAAM_Type::DMTH_MS
__IO uint32_t   CAAM_Type::DMTH_LS
struct {
}   CAAM_Type::DDMTHB [4]
uint8_t   CAAM_Type::RESERVED_26 [32]
__IO uint32_t   CAAM_Type::DGTR_0
__IO uint32_t   CAAM_Type::DGTR_1
__IO uint32_t   CAAM_Type::DGTR_2
__IO uint32_t   CAAM_Type::DGTR_3
struct {
}   CAAM_Type::DDGTR [1]
uint8_t   CAAM_Type::RESERVED_27 [112]
__IO uint32_t   CAAM_Type::DSTR_0
__IO uint32_t   CAAM_Type::DSTR_1
__IO uint32_t   CAAM_Type::DSTR_2
__IO uint32_t   CAAM_Type::DSTR_3
struct {
}   CAAM_Type::DDSTR [1]
uint8_t   CAAM_Type::RESERVED_28 [240]
__IO uint32_t   CAAM_Type::DDESB [64]
uint8_t   CAAM_Type::RESERVED_29 [768]
__I uint32_t   CAAM_Type::DDJR
__I uint32_t   CAAM_Type::DDDR
__I uint64_t   CAAM_Type::DDJP
__I uint64_t   CAAM_Type::DSDP
__I uint32_t   CAAM_Type::DDDR_MS
__I uint32_t   CAAM_Type::DDDR_LS
__IO uint32_t   CAAM_Type::SOL
__IO uint32_t   CAAM_Type::VSOL
__IO uint32_t   CAAM_Type::SIL
__IO uint32_t   CAAM_Type::VSIL
__IO uint32_t   CAAM_Type::DPOVRD
__IO uint32_t   CAAM_Type::UVSOL
__IO uint32_t   CAAM_Type::UVSIL
struct {
   union {
   uint8_t   RESERVED_3 [20]
   uint8_t   RESERVED_6 [12]
   uint8_t   RESERVED_8 [28]
   uint8_t   RESERVED_11 [4]
   uint8_t   RESERVED_12 [96]
   uint8_t   RESERVED_13 [192]
   uint8_t   RESERVED_14 [484]
   uint8_t   RESERVED_16 [4]
   uint8_t   RESERVED_17 [224]
   uint8_t   RESERVED_18 [184]
   uint8_t   RESERVED_19 [320]
   uint8_t   RESERVED_20 [12]
   union {
   uint8_t   RESERVED_21 [12]
   uint8_t   RESERVED_22 [12]
   uint8_t   RESERVED_23 [8]
   uint8_t   RESERVED_24 [8]
   uint8_t   RESERVED_25 [24]
   struct {
   }   DDMTHB [4]
   uint8_t   RESERVED_26 [32]
   struct {
   }   DDGTR [1]
   uint8_t   RESERVED_27 [112]
   struct {
   }   DDSTR [1]
   uint8_t   RESERVED_28 [240]
   uint8_t   RESERVED_29 [768]
CAAM_Type::DC [1]
uint8_t CAAM_Type::RESERVED_53 [356]
__I uint32_t CAAM_Type::CRNR_MS_DC01
__I uint32_t CAAM_Type::CRNR_LS_DC01
__I uint32_t CAAM_Type::CTPR_MS_DC01
__I uint32_t CAAM_Type::CTPR_LS_DC01
uint8_t CAAM_Type::RESERVED_54 [4]
__I uint32_t CAAM_Type::SMSTA_DC01
uint8_t CAAM_Type::RESERVED_55 [8]
__I uint64_t CAAM_Type::FAR_DC01
__I uint32_t CAAM_Type::FADID_DC01
__I uint32_t CAAM_Type::FADR_DC01
uint8_t CAAM_Type::RESERVED_56 [4]
__I uint32_t CAAM_Type::CSTA_DC01
__I uint32_t CAAM_Type::SMVID_MS_DC01
__I uint32_t CAAM_Type::SMVID_LS_DC01
__I uint32_t CAAM_Type::RVID_DC01
__I uint32_t CAAM_Type::CCBVID_DC01
__I uint32_t CAAM_Type::CHAVID_MS_DC01
__I uint32_t CAAM_Type::CHAVID_LS_DC01
__I uint32_t CAAM_Type::CHANUM_MS_DC01
__I uint32_t CAAM_Type::CHANUM_LS_DC01
__I uint32_t CAAM_Type::CAAMVID_MS_DC01
__I uint32_t CAAM_Type::CAAMVID_LS_DC01
__IO uint32_t CAN_Type::CBT
__IO uint32_t   CAN_Type::CS
__IO uint32_t   CAN_Type::ID
__IO uint32_t   CAN_Type::WORD [2]
struct {
}   CAN_Type::MB_8B [64]
__IO uint32_t   CAN_Type::WORD [4]
struct {
}   CAN_Type::MB_16B_L [21]
uint8_t   CAN_Type::RESERVED_0 [8]
struct {
}   CAN_Type::MB_16B_H [21]
struct {
   struct {
   }   MB_16B_L [21]
   uint8_t   RESERVED_0 [8]
   struct {
   }   MB_16B_H [21]
}   CAN_Type::MB_16B
__IO uint32_t   CAN_Type::WORD [8]
struct {
}   CAN_Type::MB_32B_L [12]
uint8_t   CAN_Type::RESERVED_0 [32]
struct {
}   CAN_Type::MB_32B_H [12]
struct {
   struct {
   }   MB_32B_L [12]
   uint8_t   RESERVED_0 [32]
   struct {
   }   MB_32B_H [12]
}   CAN_Type::MB_32B
__IO uint32_t   CAN_Type::WORD [16]
struct {
}   CAN_Type::MB_64B_L [7]
struct {
}   CAN_Type::MB_64B_H [7]
struct {
   struct {
   }   MB_64B_L [7]
   struct {
   }   MB_64B_H [7]
}   CAN_Type::MB_64B
__IO uint32_t   CAN_Type::WORD0
__IO uint32_t   CAN_Type::WORD1
struct {
}   CAN_Type::MB [64]
union {
   struct {
   }   MB_8B [64]
   struct {
      struct {
      }   MB_16B_L [21]
      struct {
      }   MB_16B_H [21]
   }   MB_16B
   struct {
      struct {
      }   MB_32B_L [12]
      struct {
      }   MB_32B_H [12]
   }   MB_32B
   struct {
      struct {
      }   MB_64B_L [7]
      struct {
      }   MB_64B_H [7]
   }   MB_64B
   struct {
   }   MB [64]
__IO uint32_t CAN_Type::MECR
__IO uint32_t CAN_Type::ERRIAR
__IO uint32_t CAN_Type::ERRIDPR
__IO uint32_t CAN_Type::ERRIPPR
__I uint32_t CAN_Type::RERRAR
__I uint32_t CAN_Type::RERRDR
__I uint32_t CAN_Type::RERRSYNR
__IO uint32_t CAN_Type::ERRSR
__IO uint32_t CAN_Type::FDCTRL
__IO uint32_t CAN_Type::FDCBT
__I uint32_t CAN_Type::FDCRC
uint8_t CAN_WRAPPER_Type::RESERVED_0 [2528]
__IO uint32_t CAN_WRAPPER_Type::GFWR
__IO uint32_t   CCM_Type::CONTROL
__IO uint32_t   CCM_Type::CONTROL_SET
__IO uint32_t   CCM_Type::CONTROL_CLR
__IO uint32_t   CCM_Type::CONTROL_TOG
uint8_t   CCM_Type::RESERVED_0 [16]
__I uint32_t   CCM_Type::STATUS0
__I uint32_t   CCM_Type::STATUS1
uint8_t   CCM_Type::RESERVED_1 [4]
__I uint32_t   CCM_Type::CONFIG
__IO uint32_t   CCM_Type::AUTHEN
__IO uint32_t   CCM_Type::AUTHEN_SET
__IO uint32_t   CCM_Type::AUTHEN_CLR
__IO uint32_t   CCM_Type::AUTHEN_TOG
__IO uint32_t   CCM_Type::SETPOINT [16]
struct {
   uint8_t   RESERVED_0 [16]
CCM_Type::CLOCK_ROOT [79]
__IO uint32_t   CCM_Type::STATUS0
struct {
CCM_Type::CLOCK_GROUP [2]
__IO uint32_t   CCM_Type::GPR_SHARED
__IO uint32_t   CCM_Type::CLR
__IO uint32_t   CCM_Type::TOG
struct {
CCM_Type::GPR_SHARED [8]
__IO uint32_t CCM_Type::GPR_PRIVATE1
__IO uint32_t CCM_Type::GPR_PRIVATE1_SET
__IO uint32_t CCM_Type::GPR_PRIVATE1_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE1_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE1_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE1_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE1_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE1_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE2
__IO uint32_t CCM_Type::GPR_PRIVATE2_SET
__IO uint32_t CCM_Type::GPR_PRIVATE2_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE2_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE2_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE2_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE2_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE2_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE3
__IO uint32_t CCM_Type::GPR_PRIVATE3_SET
__IO uint32_t CCM_Type::GPR_PRIVATE3_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE3_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE3_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE3_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE3_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE3_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE4
__IO uint32_t CCM_Type::GPR_PRIVATE4_SET
__IO uint32_t CCM_Type::GPR_PRIVATE4_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE4_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE4_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE4_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE4_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE4_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE5
__IO uint32_t CCM_Type::GPR_PRIVATE5_SET
__IO uint32_t CCM_Type::GPR_PRIVATE5_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE5_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE5_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE5_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE5_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE5_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE6
__IO uint32_t CCM_Type::GPR_PRIVATE6_SET
__IO uint32_t CCM_Type::GPR_PRIVATE6_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE6_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE6_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE6_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE6_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE6_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE7
__IO uint32_t CCM_Type::GPR_PRIVATE7_SET
__IO uint32_t CCM_Type::GPR_PRIVATE7_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE7_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE7_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE7_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE7_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE7_AUTHEN_TOG
__IO uint32_t   CCM_Type::DIRECT
__IO uint32_t   CCM_Type::DOMAINr
uint8_t   CCM_Type::RESERVED_0 [4]
struct {
CCM_Type::OSCPLL [29]
struct {
CCM_Type::LPCG [138]
__IO uint32_t   CCM_OBS_Type::CONTROL
__IO uint32_t   CCM_OBS_Type::CONTROL_SET
__IO uint32_t   CCM_OBS_Type::CONTROL_CLR
__IO uint32_t   CCM_OBS_Type::CONTROL_TOG
uint8_t   CCM_OBS_Type::RESERVED_0 [16]
__I uint32_t   CCM_OBS_Type::STATUS0
uint8_t   CCM_OBS_Type::RESERVED_1 [12]
__IO uint32_t   CCM_OBS_Type::AUTHEN
__IO uint32_t   CCM_OBS_Type::AUTHEN_SET
__IO uint32_t   CCM_OBS_Type::AUTHEN_CLR
__IO uint32_t   CCM_OBS_Type::AUTHEN_TOG
__I uint32_t   CCM_OBS_Type::FREQUENCY_CURRENT
__I uint32_t   CCM_OBS_Type::FREQUENCY_MIN
__I uint32_t   CCM_OBS_Type::FREQUENCY_MAX
uint8_t   CCM_OBS_Type::RESERVED_2 [52]
struct {
   uint8_t   RESERVED_2 [52]
CCM_OBS_Type::OBSERVE [6]
__IO uint32_t CDOG_Type::CONTROL
__IO uint32_t CDOG_Type::RELOAD
__IO uint32_t CDOG_Type::INSTRUCTION_TIMER
__O uint32_t CDOG_Type::SECURE_COUNTER
__I uint32_t CDOG_Type::STATUS
__I uint32_t CDOG_Type::STATUS2
__IO uint32_t CDOG_Type::FLAGS
__IO uint32_t CDOG_Type::PERSISTENT
__O uint32_t CDOG_Type::START
__O uint32_t CDOG_Type::STOP
__O uint32_t CDOG_Type::RESTART
__O uint32_t CDOG_Type::ADD
__O uint32_t CDOG_Type::ADD1
__O uint32_t CDOG_Type::ADD16
__O uint32_t CDOG_Type::ADD256
__O uint32_t CDOG_Type::SUB
__O uint32_t CDOG_Type::SUB1
__O uint32_t CDOG_Type::SUB16
__O uint32_t CDOG_Type::SUB256
__I uint32_t CMP_Type::VERID
__I uint32_t CMP_Type::PARAM
__IO uint32_t CMP_Type::C0
__IO uint32_t CMP_Type::C1
__IO uint32_t CMP_Type::C2
__IO uint32_t CMP_Type::C3
__IO uint32_t CSI_Type::CR20
__IO uint32_t CSI_Type::CR [256]
__I uint32_t DAC_Type::VERID
__I uint32_t DAC_Type::PARAM
__O uint32_t DAC_Type::DATA
__IO uint32_t DAC_Type::CR
__I uint32_t DAC_Type::PTR
__IO uint32_t DAC_Type::CR2
__IO uint32_t DCDC_Type::CTRL0
__IO uint32_t DCDC_Type::CTRL1
__IO uint32_t DCDC_Type::REG4
__IO uint32_t DCDC_Type::REG5
__IO uint32_t DCDC_Type::REG6
__IO uint32_t DCDC_Type::REG7
__IO uint32_t DCDC_Type::REG7P
__IO uint32_t DCDC_Type::REG8
__IO uint32_t DCDC_Type::REG9
__IO uint32_t DCDC_Type::REG10
__IO uint32_t DCDC_Type::REG11
__IO uint32_t DCDC_Type::REG12
__IO uint32_t DCDC_Type::REG13
__IO uint32_t DCDC_Type::REG14
__IO uint32_t DCDC_Type::REG15
__IO uint32_t DCDC_Type::REG16
__IO uint32_t DCDC_Type::REG17
__IO uint32_t DCDC_Type::REG18
__IO uint32_t DCDC_Type::REG19
__IO uint32_t DCDC_Type::REG20
__IO uint32_t DCDC_Type::REG21
__IO uint32_t DCDC_Type::REG22
__IO uint32_t DCDC_Type::REG23
__IO uint32_t DCDC_Type::REG24
__IO uint32_t DCIC_Type::DCICC
__IO uint32_t DCIC_Type::DCICIC
__IO uint32_t DCIC_Type::DCICS
uint8_t DCIC_Type::RESERVED_0 [4]
__IO uint32_t   DCIC_Type::DCICRC
__IO uint32_t   DCIC_Type::DCICRS
__IO uint32_t   DCIC_Type::DCICRRS
__I uint32_t   DCIC_Type::DCICRCS
struct {
DCIC_Type::REGION [16]
__IO uint32_t   DMA_Type::SADDR
__IO uint16_t   DMA_Type::SOFF
__IO uint16_t   DMA_Type::ATTR
__IO uint32_t   DMA_Type::NBYTES_MLNO
__IO uint32_t   DMA_Type::NBYTES_MLOFFNO
__IO uint32_t   DMA_Type::NBYTES_MLOFFYES
union {
__IO int32_t   DMA_Type::SLAST
__IO uint32_t   DMA_Type::DADDR
__IO uint16_t   DMA_Type::DOFF
__IO uint16_t   DMA_Type::CITER_ELINKNO
__IO uint16_t   DMA_Type::CITER_ELINKYES
union {
__IO int32_t   DMA_Type::DLAST_SGA
__IO uint16_t   DMA_Type::CSR
__IO uint16_t   DMA_Type::BITER_ELINKNO
__IO uint16_t   DMA_Type::BITER_ELINKYES
union {
struct {
   union {
   union {
   union {
DMA_Type::TCD [32]
__IO uint32_t DSI_HOST_Type::CFG_NUM_LANES
__IO uint32_t DSI_HOST_Type::CFG_NONCONTINUOUS_CLK
__IO uint32_t DSI_HOST_Type::CFG_T_PRE
__IO uint32_t DSI_HOST_Type::CFG_T_POST
__IO uint32_t DSI_HOST_Type::CFG_TX_GAP
__IO uint32_t DSI_HOST_Type::CFG_AUTOINSERT_EOTP
__IO uint32_t DSI_HOST_Type::CFG_EXTRA_CMDS_AFTER_EOTP
__IO uint32_t DSI_HOST_Type::CFG_HTX_TO_COUNT
__IO uint32_t DSI_HOST_Type::CFG_LRX_H_TO_COUNT
__IO uint32_t DSI_HOST_Type::CFG_BTA_H_TO_COUNT
__IO uint32_t DSI_HOST_Type::CFG_TWAKEUP
__I uint32_t DSI_HOST_Type::CFG_STATUS_OUT
__I uint32_t DSI_HOST_Type::RX_ERROR_STATUS
__IO uint32_t DSI_HOST_APB_PKT_IF_Type::TX_PAYLOAD
__IO uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_CONTROL
__IO uint32_t DSI_HOST_APB_PKT_IF_Type::SEND_PACKET
__I uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_STATUS
__I uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_FIFO_WR_LEVEL
__I uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_FIFO_RD_LEVEL
__I uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_RX_PAYLOAD
__I uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_RX_PKT_HEADER
__I uint32_t DSI_HOST_APB_PKT_IF_Type::IRQ_STATUS
__I uint32_t DSI_HOST_APB_PKT_IF_Type::IRQ_STATUS2
__IO uint32_t DSI_HOST_APB_PKT_IF_Type::IRQ_MASK
__IO uint32_t DSI_HOST_APB_PKT_IF_Type::IRQ_MASK2
__IO uint32_t DSI_HOST_DPI_INTFC_Type::PIXEL_PAYLOAD_SIZE
__IO uint32_t DSI_HOST_DPI_INTFC_Type::PIXEL_FIFO_SEND_LEVEL
__IO uint32_t DSI_HOST_DPI_INTFC_Type::INTERFACE_COLOR_CODING
__IO uint32_t DSI_HOST_DPI_INTFC_Type::PIXEL_FORMAT
__IO uint32_t DSI_HOST_DPI_INTFC_Type::VSYNC_POLARITY
__IO uint32_t DSI_HOST_DPI_INTFC_Type::HSYNC_POLARITY
__IO uint32_t DSI_HOST_DPI_INTFC_Type::VIDEO_MODE
__IO uint32_t DSI_HOST_DPI_INTFC_Type::HFP
__IO uint32_t DSI_HOST_DPI_INTFC_Type::HBP
__IO uint32_t DSI_HOST_DPI_INTFC_Type::HSA
__IO uint32_t DSI_HOST_DPI_INTFC_Type::ENABLE_MULT_PKTS
__IO uint32_t DSI_HOST_DPI_INTFC_Type::VBP
__IO uint32_t DSI_HOST_DPI_INTFC_Type::VFP
__IO uint32_t DSI_HOST_DPI_INTFC_Type::BLLP_MODE
__IO uint32_t DSI_HOST_DPI_INTFC_Type::USE_NULL_PKT_BLLP
__IO uint32_t DSI_HOST_DPI_INTFC_Type::VACTIVE
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::PD_TX
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::M_PRG_HS_PREPARE
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::MC_PRG_HS_PREPARE
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::M_PRG_HS_ZERO
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::MC_PRG_HS_ZERO
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::M_PRG_HS_TRAIL
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::MC_PRG_HS_TRAIL
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::PD_PLL
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::TST
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::CN
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::CM
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::CO
__I uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::LOCK
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::LOCK_BYP
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::TX_RCAL
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::AUTO_PD_EN
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::RXLPRP
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::RXCDRP
__I uint32_t EMVSIM_Type::VER_ID
__I uint32_t EMVSIM_Type::PARAM
__IO uint32_t EMVSIM_Type::CLKCFG
__IO uint32_t EMVSIM_Type::DIVISOR
__IO uint32_t EMVSIM_Type::CTRL
__IO uint32_t EMVSIM_Type::INT_MASK
__IO uint32_t EMVSIM_Type::RX_THD
__IO uint32_t EMVSIM_Type::TX_THD
__IO uint32_t EMVSIM_Type::RX_STATUS
__IO uint32_t EMVSIM_Type::TX_STATUS
__IO uint32_t EMVSIM_Type::PCSR
__I uint32_t EMVSIM_Type::RX_BUF
__O uint32_t EMVSIM_Type::TX_BUF
__IO uint32_t EMVSIM_Type::TX_GETU
__IO uint32_t EMVSIM_Type::CWT_VAL
__IO uint32_t EMVSIM_Type::BWT_VAL
__IO uint32_t EMVSIM_Type::BGT_VAL
__IO uint32_t EMVSIM_Type::GPCNT0_VAL
__IO uint32_t EMVSIM_Type::GPCNT1_VAL
__I uint16_t ENC_Type::LASTEDGE
__I uint16_t ENC_Type::LASTEDGEH
__I uint16_t ENC_Type::POSDPER
__I uint16_t ENC_Type::POSDPERBFR
__I uint16_t ENC_Type::POSDPERH
__IO uint16_t ENC_Type::CTRL3
__IO uint32_t ENET_Type::RDSR1
__IO uint32_t ENET_Type::TDSR1
__IO uint32_t ENET_Type::MRBR1
__IO uint32_t ENET_Type::RDSR2
__IO uint32_t ENET_Type::TDSR2
__IO uint32_t ENET_Type::MRBR2
__IO uint32_t ENET_Type::RCMR [2]
__IO uint32_t ENET_Type::DMACFG [2]
__IO uint32_t ENET_Type::RDAR1
__IO uint32_t ENET_Type::TDAR1
__IO uint32_t ENET_Type::RDAR2
__IO uint32_t ENET_Type::TDAR2
__IO uint32_t ENET_Type::QOS
uint32_t ENET_Type::IEEE_T_DROP
uint8_t ENET_Type::RESERVED_20 [488]
__IO uint32_t   ENET_Type::TCSR
__IO uint32_t   ENET_Type::TCCR
struct {
ENET_Type::CHANNEL [4]
__IO uint32_t   ETHERNET_PLL_Type::RW
__IO uint32_t   ETHERNET_PLL_Type::SET
__IO uint32_t   ETHERNET_PLL_Type::CLR
__IO uint32_t   ETHERNET_PLL_Type::TOG
struct {
ETHERNET_PLL_Type::CTRL0
struct {
ETHERNET_PLL_Type::SPREAD_SPECTRUM
struct {
ETHERNET_PLL_Type::NUMERATOR
struct {
ETHERNET_PLL_Type::DENOMINATOR
__IO uint32_t FLEXIO_Type::TIMERSDEN
uint8_t FLEXIO_Type::RESERVED_15 [96]
uint8_t FLEXIO_Type::RESERVED_16 [96]
__IO uint32_t FLEXIO_Type::SHIFTBUFOES [8]
uint8_t FLEXIO_Type::RESERVED_17 [96]
__IO uint32_t FLEXIO_Type::SHIFTBUFEOS [8]
__IO uint32_t FLEXRAM_Type::OCRAM_MAGIC_ADDR
__IO uint32_t FLEXRAM_Type::DTCM_MAGIC_ADDR
__IO uint32_t FLEXRAM_Type::ITCM_MAGIC_ADDR
__I uint32_t FLEXRAM_Type::OCRAM_ECC_SINGLE_ERROR_INFO
__I uint32_t FLEXRAM_Type::OCRAM_ECC_SINGLE_ERROR_ADDR
__I uint32_t FLEXRAM_Type::OCRAM_ECC_SINGLE_ERROR_DATA_LSB
__I uint32_t FLEXRAM_Type::OCRAM_ECC_SINGLE_ERROR_DATA_MSB
__I uint32_t FLEXRAM_Type::OCRAM_ECC_MULTI_ERROR_INFO
__I uint32_t FLEXRAM_Type::OCRAM_ECC_MULTI_ERROR_ADDR
__I uint32_t FLEXRAM_Type::OCRAM_ECC_MULTI_ERROR_DATA_LSB
__I uint32_t FLEXRAM_Type::OCRAM_ECC_MULTI_ERROR_DATA_MSB
__I uint32_t FLEXRAM_Type::ITCM_ECC_SINGLE_ERROR_INFO
__I uint32_t FLEXRAM_Type::ITCM_ECC_SINGLE_ERROR_ADDR
__I uint32_t FLEXRAM_Type::ITCM_ECC_SINGLE_ERROR_DATA_LSB
__I uint32_t FLEXRAM_Type::ITCM_ECC_SINGLE_ERROR_DATA_MSB
__I uint32_t FLEXRAM_Type::ITCM_ECC_MULTI_ERROR_INFO
__I uint32_t FLEXRAM_Type::ITCM_ECC_MULTI_ERROR_ADDR
__I uint32_t FLEXRAM_Type::ITCM_ECC_MULTI_ERROR_DATA_LSB
__I uint32_t FLEXRAM_Type::ITCM_ECC_MULTI_ERROR_DATA_MSB
__I uint32_t FLEXRAM_Type::D0TCM_ECC_SINGLE_ERROR_INFO
__I uint32_t FLEXRAM_Type::D0TCM_ECC_SINGLE_ERROR_ADDR
__I uint32_t FLEXRAM_Type::D0TCM_ECC_SINGLE_ERROR_DATA
__I uint32_t FLEXRAM_Type::D0TCM_ECC_MULTI_ERROR_INFO
__I uint32_t FLEXRAM_Type::D0TCM_ECC_MULTI_ERROR_ADDR
__I uint32_t FLEXRAM_Type::D0TCM_ECC_MULTI_ERROR_DATA
__I uint32_t FLEXRAM_Type::D1TCM_ECC_SINGLE_ERROR_INFO
__I uint32_t FLEXRAM_Type::D1TCM_ECC_SINGLE_ERROR_ADDR
__I uint32_t FLEXRAM_Type::D1TCM_ECC_SINGLE_ERROR_DATA
__I uint32_t FLEXRAM_Type::D1TCM_ECC_MULTI_ERROR_INFO
__I uint32_t FLEXRAM_Type::D1TCM_ECC_MULTI_ERROR_ADDR
__I uint32_t FLEXRAM_Type::D1TCM_ECC_MULTI_ERROR_DATA
__IO uint32_t FLEXRAM_Type::FLEXRAM_CTRL
__I uint32_t FLEXRAM_Type::OCRAM_PIPELINE_STATUS
__I uint32_t FLEXSPI_Type::MISCCR4
__I uint32_t FLEXSPI_Type::MISCCR5
__I uint32_t FLEXSPI_Type::MISCCR6
__I uint32_t FLEXSPI_Type::MISCCR7
uint8_t FLEXSPI_Type::RESERVED_7 [256]
__IO uint32_t FLEXSPI_Type::HMSTRCR [8]
__IO uint32_t FLEXSPI_Type::HADDRSTART
__IO uint32_t FLEXSPI_Type::HADDREND
__IO uint32_t FLEXSPI_Type::HADDROFFSET
uint8_t FLEXSPI_Type::RESERVED_8 [4]
__IO uint32_t FLEXSPI_Type::IPSNSZSTART0
__IO uint32_t FLEXSPI_Type::IPSNSZEND0
__IO uint32_t FLEXSPI_Type::IPSNSZSTART1
__IO uint32_t FLEXSPI_Type::IPSNSZEND1
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONSTART0
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONEND0
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONSTART1
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONEND1
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONSTART2
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONEND2
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONSTART3
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONEND3
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_0 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_AUTHEN_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_INT_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_MISC
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_MODE_CTRL
__I uint32_t GPC_CPU_MODE_CTRL_Type::CM_MODE_STAT
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_1 [232]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_IRQ_WAKEUP_MASK [8]
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_2 [32]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_NON_IRQ_WAKEUP_MASK
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_3 [12]
__I uint32_t GPC_CPU_MODE_CTRL_Type::CM_IRQ_WAKEUP_STAT [8]
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_4 [32]
__I uint32_t GPC_CPU_MODE_CTRL_Type::CM_NON_IRQ_WAKEUP_STAT
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_5 [108]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_SSAR_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_6 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_LPCG_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_7 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_PLL_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_8 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_ISO_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_9 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_RESET_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_10 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_POWER_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_11 [100]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_POWER_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_12 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_RESET_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_13 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_ISO_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_14 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_PLL_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_15 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_LPCG_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_16 [4]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_SSAR_CTRL
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_17 [68]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SP_CTRL
__I uint32_t GPC_CPU_MODE_CTRL_Type::CM_SP_STAT
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_18 [8]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_RUN_MODE_MAPPING
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAIT_MODE_MAPPING
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_STOP_MODE_MAPPING
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SUSPEND_MODE_MAPPING
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SP_MAPPING [16]
uint8_t GPC_CPU_MODE_CTRL_Type::RESERVED_19 [32]
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_STBY_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_0 [4]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_AUTHEN_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_INT_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_1 [4]
__I uint32_t GPC_SET_POINT_CTRL_Type::SP_CPU_REQ
__I uint32_t GPC_SET_POINT_CTRL_Type::SP_SYS_STAT
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_2 [4]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_ROSC_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_3 [32]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_PRIORITY_0_7
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_PRIORITY_8_15
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_4 [184]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_SSAR_SAVE_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_5 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_LPCG_OFF_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_6 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_GROUP_DOWN_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_7 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_ROOT_DOWN_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_8 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_PLL_OFF_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_9 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_ISO_ON_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_10 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_RESET_EARLY_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_11 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_POWER_OFF_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_12 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_BIAS_OFF_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_13 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_BG_PLDO_OFF_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_14 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_LDO_PRE_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_15 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_DCDC_DOWN_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_16 [76]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_DCDC_UP_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_17 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_LDO_POST_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_18 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_BG_PLDO_ON_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_19 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_BIAS_ON_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_20 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_POWER_ON_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_21 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_RESET_LATE_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_22 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_ISO_OFF_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_23 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_PLL_ON_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_24 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_ROOT_UP_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_25 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_GROUP_UP_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_26 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_LPCG_ON_CTRL
uint8_t GPC_SET_POINT_CTRL_Type::RESERVED_27 [12]
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_SSAR_RESTORE_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_0 [4]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_AUTHEN_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_1 [4]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_MISC
uint8_t GPC_STBY_CTRL_Type::RESERVED_2 [224]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_LPCG_IN_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_3 [12]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PLL_IN_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_4 [12]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_BIAS_IN_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_5 [12]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PLDO_IN_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_6 [4]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_BANDGAP_IN_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_7 [4]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_LDO_IN_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_8 [12]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_DCDC_IN_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_9 [12]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PMIC_IN_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_10 [172]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PMIC_OUT_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_11 [12]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_DCDC_OUT_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_12 [12]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_LDO_OUT_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_13 [12]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_BANDGAP_OUT_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_14 [4]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PLDO_OUT_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_15 [4]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_BIAS_OUT_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_16 [12]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PLL_OUT_CTRL
uint8_t GPC_STBY_CTRL_Type::RESERVED_17 [12]
__IO uint32_t GPC_STBY_CTRL_Type::STBY_LPCG_OUT_CTRL
__IO uint32_t IEE_Type::GCFG
__I uint32_t IEE_Type::STA
__IO uint32_t IEE_Type::TSTMD
__O uint32_t IEE_Type::DPAMS
uint8_t IEE_Type::RESERVED_0 [16]
__IO uint32_t IEE_Type::PC_S_LT
__IO uint32_t IEE_Type::PC_M_LT
uint8_t IEE_Type::RESERVED_1 [24]
__IO uint32_t IEE_Type::PC_BLK_ENC
__IO uint32_t IEE_Type::PC_BLK_DEC
uint8_t IEE_Type::RESERVED_2 [8]
__IO uint32_t IEE_Type::PC_SR_TRANS
__IO uint32_t IEE_Type::PC_SW_TRANS
__IO uint32_t IEE_Type::PC_MR_TRANS
__IO uint32_t IEE_Type::PC_MW_TRANS
uint8_t IEE_Type::RESERVED_3 [4]
__IO uint32_t IEE_Type::PC_M_MBR
uint8_t IEE_Type::RESERVED_4 [8]
__IO uint32_t IEE_Type::PC_SR_TBC_U
__IO uint32_t IEE_Type::PC_SR_TBC_L
__IO uint32_t IEE_Type::PC_SW_TBC_U
__IO uint32_t IEE_Type::PC_SW_TBC_L
__IO uint32_t IEE_Type::PC_MR_TBC_U
__IO uint32_t IEE_Type::PC_MR_TBC_L
__IO uint32_t IEE_Type::PC_MW_TBC_U
__IO uint32_t IEE_Type::PC_MW_TBC_L
__IO uint32_t IEE_Type::PC_SR_TLGTT
__IO uint32_t IEE_Type::PC_SW_TLGTT
__IO uint32_t IEE_Type::PC_MR_TLGTT
__IO uint32_t IEE_Type::PC_MW_TLGTT
__IO uint32_t IEE_Type::PC_SR_TLAT_U
__IO uint32_t IEE_Type::PC_SR_TLAT_L
__IO uint32_t IEE_Type::PC_SW_TLAT_U
__IO uint32_t IEE_Type::PC_SW_TLAT_L
__IO uint32_t IEE_Type::PC_MR_TLAT_U
__IO uint32_t IEE_Type::PC_MR_TLAT_L
__IO uint32_t IEE_Type::PC_MW_TLAT_U
__IO uint32_t IEE_Type::PC_MW_TLAT_L
__IO uint32_t IEE_Type::PC_SR_TNRT_U
__IO uint32_t IEE_Type::PC_SR_TNRT_L
__IO uint32_t IEE_Type::PC_SW_TNRT_U
__IO uint32_t IEE_Type::PC_SW_TNRT_L
uint8_t IEE_Type::RESERVED_5 [32]
__I uint32_t IEE_Type::VIDR1
uint8_t IEE_Type::RESERVED_6 [4]
__I uint32_t IEE_Type::AESVID
uint8_t IEE_Type::RESERVED_7 [4]
__IO uint32_t   IEE_Type::REGATTR
uint8_t   IEE_Type::RESERVED_0 [4]
__IO uint32_t   IEE_Type::REGPO
uint8_t   IEE_Type::RESERVED_1 [52]
__O uint32_t   IEE_Type::REGKEY1 [8]
uint8_t   IEE_Type::RESERVED_2 [32]
__O uint32_t   IEE_Type::REGKEY2 [8]
uint8_t   IEE_Type::RESERVED_3 [96]
struct {
   uint8_t   RESERVED_0 [4]
   uint8_t   RESERVED_1 [52]
   uint8_t   RESERVED_2 [32]
   uint8_t   RESERVED_3 [96]
IEE_Type::REGX [8]
uint8_t IEE_Type::RESERVED_8 [1536]
__IO uint32_t IEE_Type::AES_TST_DB [32]
__IO uint32_t IEE_APC_Type::REGION0_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION0_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION0_RDC_D0
__IO uint32_t IEE_APC_Type::REGION0_RDC_D1
__IO uint32_t IEE_APC_Type::REGION1_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION1_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION1_RDC_D0
__IO uint32_t IEE_APC_Type::REGION1_RDC_D1
__IO uint32_t IEE_APC_Type::REGION2_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION2_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION2_RDC_D0
__IO uint32_t IEE_APC_Type::REGION2_RDC_D1
__IO uint32_t IEE_APC_Type::REGION3_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION3_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION3_RDC_D0
__IO uint32_t IEE_APC_Type::REGION3_RDC_D1
__IO uint32_t IEE_APC_Type::REGION4_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION4_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION4_RDC_D0
__IO uint32_t IEE_APC_Type::REGION4_RDC_D1
__IO uint32_t IEE_APC_Type::REGION5_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION5_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION5_RDC_D0
__IO uint32_t IEE_APC_Type::REGION5_RDC_D1
__IO uint32_t IEE_APC_Type::REGION6_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION6_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION6_RDC_D0
__IO uint32_t IEE_APC_Type::REGION6_RDC_D1
__IO uint32_t IEE_APC_Type::REGION7_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION7_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION7_RDC_D0
__IO uint32_t IEE_APC_Type::REGION7_RDC_D1
__IO uint32_t IOMUXC_GPR_Type::GPR0
uint8_t IOMUXC_GPR_Type::RESERVED_0 [4]
__IO uint32_t IOMUXC_GPR_Type::GPR9
__IO uint32_t IOMUXC_GPR_Type::GPR15
uint8_t IOMUXC_GPR_Type::RESERVED_1 [4]
__IO uint32_t IOMUXC_GPR_Type::GPR26
__IO uint32_t IOMUXC_GPR_Type::GPR27
__IO uint32_t IOMUXC_GPR_Type::GPR28
__IO uint32_t IOMUXC_GPR_Type::GPR29
__IO uint32_t IOMUXC_GPR_Type::GPR30
__IO uint32_t IOMUXC_GPR_Type::GPR31
__IO uint32_t IOMUXC_GPR_Type::GPR32
__IO uint32_t IOMUXC_GPR_Type::GPR33
__IO uint32_t IOMUXC_GPR_Type::GPR34
__IO uint32_t IOMUXC_GPR_Type::GPR35
__IO uint32_t IOMUXC_GPR_Type::GPR36
__IO uint32_t IOMUXC_GPR_Type::GPR37
__IO uint32_t IOMUXC_GPR_Type::GPR38
__IO uint32_t IOMUXC_GPR_Type::GPR39
__IO uint32_t IOMUXC_GPR_Type::GPR40
__IO uint32_t IOMUXC_GPR_Type::GPR41
__IO uint32_t IOMUXC_GPR_Type::GPR42
__IO uint32_t IOMUXC_GPR_Type::GPR43
__IO uint32_t IOMUXC_GPR_Type::GPR44
__IO uint32_t IOMUXC_GPR_Type::GPR45
__IO uint32_t IOMUXC_GPR_Type::GPR46
__IO uint32_t IOMUXC_GPR_Type::GPR47
__IO uint32_t IOMUXC_GPR_Type::GPR48
__IO uint32_t IOMUXC_GPR_Type::GPR49
__IO uint32_t IOMUXC_GPR_Type::GPR50
__IO uint32_t IOMUXC_GPR_Type::GPR51
__IO uint32_t IOMUXC_GPR_Type::GPR52
__IO uint32_t IOMUXC_GPR_Type::GPR53
__IO uint32_t IOMUXC_GPR_Type::GPR54
__IO uint32_t IOMUXC_GPR_Type::GPR55
uint8_t IOMUXC_GPR_Type::RESERVED_2 [12]
__IO uint32_t IOMUXC_GPR_Type::GPR59
uint8_t IOMUXC_GPR_Type::RESERVED_3 [8]
__IO uint32_t IOMUXC_GPR_Type::GPR62
__I uint32_t IOMUXC_GPR_Type::GPR63
__IO uint32_t IOMUXC_GPR_Type::GPR64
__IO uint32_t IOMUXC_GPR_Type::GPR65
__IO uint32_t IOMUXC_GPR_Type::GPR66
__IO uint32_t IOMUXC_GPR_Type::GPR67
__IO uint32_t IOMUXC_GPR_Type::GPR68
__IO uint32_t IOMUXC_GPR_Type::GPR69
__IO uint32_t IOMUXC_GPR_Type::GPR70
__IO uint32_t IOMUXC_GPR_Type::GPR71
__IO uint32_t IOMUXC_GPR_Type::GPR72
__IO uint32_t IOMUXC_GPR_Type::GPR73
__IO uint32_t IOMUXC_GPR_Type::GPR74
__I uint32_t IOMUXC_GPR_Type::GPR75
__I uint32_t IOMUXC_GPR_Type::GPR76
__IO uint32_t IOMUXC_LPSR_Type::SW_MUX_CTL_PAD [16]
__IO uint32_t IOMUXC_LPSR_Type::SW_PAD_CTL_PAD [16]
__IO uint32_t IOMUXC_LPSR_Type::SELECT_INPUT [24]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR0
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR1
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR2
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR3
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR4
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR5
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR6
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR7
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR8
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR9
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR10
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR11
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR12
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR13
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR14
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR15
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR16
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR17
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR18
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR19
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR20
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR21
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR22
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR23
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR24
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR25
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR26
uint8_t IOMUXC_LPSR_GPR_Type::RESERVED_0 [24]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR33
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR34
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR35
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR36
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR37
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR38
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR39
__I uint32_t IOMUXC_LPSR_GPR_Type::GPR40
__I uint32_t IOMUXC_LPSR_GPR_Type::GPR41
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_WAKEUP_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_PMIC_ON_REQ_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_PMIC_STBY_REQ_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_00_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_01_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_02_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_03_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_04_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_05_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_06_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_07_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_08_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_09_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_TEST_MODE_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_POR_B_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_ONOFF_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_WAKEUP_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_PMIC_ON_REQ_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_PMIC_STBY_REQ_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_00_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_01_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_02_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_03_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_04_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_05_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_06_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_07_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_08_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_09_DIG
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR [32]
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR32
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR33
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR34
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR35
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR36
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR37
__IO uint32_t   IPS_DOMAIN_Type::SLOT_CTRL
uint8_t   IPS_DOMAIN_Type::RESERVED_0 [12]
struct {
   uint8_t   RESERVED_0 [12]
IPS_DOMAIN_Type::SLOT_CTRL [38]
__IO uint32_t KEY_MANAGER_Type::MASTER_KEY_CTRL
uint8_t KEY_MANAGER_Type::RESERVED_0 [12]
__IO uint32_t KEY_MANAGER_Type::OTFAD1_KEY_CTRL
uint8_t KEY_MANAGER_Type::RESERVED_1 [4]
__IO uint32_t KEY_MANAGER_Type::OTFAD2_KEY_CTRL
uint8_t KEY_MANAGER_Type::RESERVED_2 [4]
__IO uint32_t KEY_MANAGER_Type::IEE_KEY_CTRL
uint8_t KEY_MANAGER_Type::RESERVED_3 [12]
__IO uint32_t KEY_MANAGER_Type::PUF_KEY_CTRL
uint8_t KEY_MANAGER_Type::RESERVED_4 [972]
__IO uint32_t KEY_MANAGER_Type::SLOT0_CTRL
__IO uint32_t KEY_MANAGER_Type::SLOT1_CTRL
__IO uint32_t KEY_MANAGER_Type::SLOT2_CTRL
__IO uint32_t KEY_MANAGER_Type::SLOT3_CTRL
__IO uint32_t KEY_MANAGER_Type::SLOT4_CTRL
__IO uint32_t LCDIF_Type::THRES
__IO uint32_t   LCDIF_Type::PIGEON_0
uint8_t   LCDIF_Type::RESERVED_0 [12]
__IO uint32_t   LCDIF_Type::PIGEON_1
uint8_t   LCDIF_Type::RESERVED_1 [12]
__IO uint32_t   LCDIF_Type::PIGEON_2
uint8_t   LCDIF_Type::RESERVED_2 [28]
struct {
   uint8_t   RESERVED_1 [12]
   uint8_t   RESERVED_2 [28]
LCDIF_Type::PIGEON [12]
__IO uint32_t LCDIFV2_Type::CTRL
__IO uint32_t LCDIFV2_Type::CTRL_SET
__IO uint32_t LCDIFV2_Type::CTRL_CLR
__IO uint32_t LCDIFV2_Type::CTRL_TOG
__IO uint32_t LCDIFV2_Type::DISP_PARA
__IO uint32_t LCDIFV2_Type::DISP_SIZE
__IO uint32_t LCDIFV2_Type::HSYN_PARA
__IO uint32_t LCDIFV2_Type::VSYN_PARA
__IO uint32_t   LCDIFV2_Type::INT_STATUS
__IO uint32_t   LCDIFV2_Type::INT_ENABLE
uint8_t   LCDIFV2_Type::RESERVED_0 [8]
struct {
LCDIFV2_Type::INT [2]
__IO uint32_t LCDIFV2_Type::PDI_PARA
__IO uint32_t   LCDIFV2_Type::CTRLDESCL1
__IO uint32_t   LCDIFV2_Type::CTRLDESCL2
__IO uint32_t   LCDIFV2_Type::CTRLDESCL3
__IO uint32_t   LCDIFV2_Type::CTRLDESCL4
__IO uint32_t   LCDIFV2_Type::CTRLDESCL5
__IO uint32_t   LCDIFV2_Type::CTRLDESCL6
__IO uint32_t   LCDIFV2_Type::CSC_COEF0
__IO uint32_t   LCDIFV2_Type::CSC_COEF1
__IO uint32_t   LCDIFV2_Type::CSC_COEF2
uint8_t   LCDIFV2_Type::RESERVED_0 [28]
struct {
   uint8_t   RESERVED_0 [28]
LCDIFV2_Type::LAYER [8]
__IO uint32_t LCDIFV2_Type::CLUT_LOAD
__IO uint32_t LMEM_Type::PCCCR
__IO uint32_t LMEM_Type::PCCLCR
__IO uint32_t LMEM_Type::PCCSAR
__IO uint32_t LMEM_Type::PCCCVR
uint8_t LMEM_Type::RESERVED_0 [2032]
__IO uint32_t LMEM_Type::PSCCR
__IO uint32_t LMEM_Type::PSCLCR
__IO uint32_t LMEM_Type::PSCSAR
__IO uint32_t LMEM_Type::PSCCVR
__I uint16_t MCM_Type::PLREV
__I uint16_t MCM_Type::PCT
__I uint32_t MCM_Type::MEMCFG
__I uint16_t MCM_Type::PLASC
__I uint16_t MCM_Type::PLAMC
__IO uint32_t MCM_Type::CR
__IO uint32_t MCM_Type::ISCR
uint8_t MCM_Type::RESERVED_0 [12]
__I uint32_t MCM_Type::FADR
__I uint32_t MCM_Type::FATR
__I uint32_t MCM_Type::FDR
uint8_t MCM_Type::RESERVED_1 [980]
__IO uint32_t MCM_Type::LMDR [4]
uint8_t MCM_Type::RESERVED_2 [112]
__IO uint32_t MCM_Type::LMPECR
uint8_t MCM_Type::RESERVED_3 [4]
__IO uint32_t MCM_Type::LMPEIR
uint8_t MCM_Type::RESERVED_4 [4]
__I uint32_t MCM_Type::LMFAR
__IO uint32_t MCM_Type::LMFATR
uint8_t MCM_Type::RESERVED_5 [8]
__I uint32_t MCM_Type::LMFDHR
__I uint32_t MCM_Type::LMFDLR
__IO uint32_t MECC_Type::ERR_STATUS
__IO uint32_t MECC_Type::ERR_STAT_EN
__IO uint32_t MECC_Type::ERR_SIG_EN
__IO uint32_t MECC_Type::ERR_DATA_INJ_LOW0
__IO uint32_t MECC_Type::ERR_DATA_INJ_HIGH0
__IO uint32_t MECC_Type::ERR_ECC_INJ0
__IO uint32_t MECC_Type::ERR_DATA_INJ_LOW1
__IO uint32_t MECC_Type::ERR_DATA_INJ_HIGH1
__IO uint32_t MECC_Type::ERR_ECC_INJ1
__IO uint32_t MECC_Type::ERR_DATA_INJ_LOW2
__IO uint32_t MECC_Type::ERR_DATA_INJ_HIGH2
__IO uint32_t MECC_Type::ERR_ECC_INJ2
__IO uint32_t MECC_Type::ERR_DATA_INJ_LOW3
__IO uint32_t MECC_Type::ERR_DATA_INJ_HIGH3
__IO uint32_t MECC_Type::ERR_ECC_INJ3
__I uint32_t MECC_Type::SINGLE_ERR_ADDR_ECC0
__I uint32_t MECC_Type::SINGLE_ERR_DATA_LOW0
__I uint32_t MECC_Type::SINGLE_ERR_DATA_HIGH0
__I uint32_t MECC_Type::SINGLE_ERR_POS_LOW0
__I uint32_t MECC_Type::SINGLE_ERR_POS_HIGH0
__I uint32_t MECC_Type::SINGLE_ERR_ADDR_ECC1
__I uint32_t MECC_Type::SINGLE_ERR_DATA_LOW1
__I uint32_t MECC_Type::SINGLE_ERR_DATA_HIGH1
__I uint32_t MECC_Type::SINGLE_ERR_POS_LOW1
__I uint32_t MECC_Type::SINGLE_ERR_POS_HIGH1
__I uint32_t MECC_Type::SINGLE_ERR_ADDR_ECC2
__I uint32_t MECC_Type::SINGLE_ERR_DATA_LOW2
__I uint32_t MECC_Type::SINGLE_ERR_DATA_HIGH2
__I uint32_t MECC_Type::SINGLE_ERR_POS_LOW2
__I uint32_t MECC_Type::SINGLE_ERR_POS_HIGH2
__I uint32_t MECC_Type::SINGLE_ERR_ADDR_ECC3
__I uint32_t MECC_Type::SINGLE_ERR_DATA_LOW3
__I uint32_t MECC_Type::SINGLE_ERR_DATA_HIGH3
__I uint32_t MECC_Type::SINGLE_ERR_POS_LOW3
__I uint32_t MECC_Type::SINGLE_ERR_POS_HIGH3
__I uint32_t MECC_Type::MULTI_ERR_ADDR_ECC0
__I uint32_t MECC_Type::MULTI_ERR_DATA_LOW0
__I uint32_t MECC_Type::MULTI_ERR_DATA_HIGH0
__I uint32_t MECC_Type::MULTI_ERR_ADDR_ECC1
__I uint32_t MECC_Type::MULTI_ERR_DATA_LOW1
__I uint32_t MECC_Type::MULTI_ERR_DATA_HIGH1
__I uint32_t MECC_Type::MULTI_ERR_ADDR_ECC2
__I uint32_t MECC_Type::MULTI_ERR_DATA_LOW2
__I uint32_t MECC_Type::MULTI_ERR_DATA_HIGH2
__I uint32_t MECC_Type::MULTI_ERR_ADDR_ECC3
__I uint32_t MECC_Type::MULTI_ERR_DATA_LOW3
__I uint32_t MECC_Type::MULTI_ERR_DATA_HIGH3
uint8_t MECC_Type::RESERVED_0 [68]
__IO uint32_t MECC_Type::PIPE_ECC_EN
__I uint32_t MECC_Type::PENDING_STAT
uint8_t MIPI_CSI2RX_Type::RESERVED_0 [256]
__IO uint32_t MIPI_CSI2RX_Type::CFG_NUM_LANES
__IO uint32_t MIPI_CSI2RX_Type::CFG_DISABLE_DATA_LANES
__I uint32_t MIPI_CSI2RX_Type::BIT_ERR
__I uint32_t MIPI_CSI2RX_Type::IRQ_STATUS
__IO uint32_t MIPI_CSI2RX_Type::IRQ_MASK
__I uint32_t MIPI_CSI2RX_Type::ULPS_STATUS
__I uint32_t MIPI_CSI2RX_Type::PPI_ERRSOT_HS
__I uint32_t MIPI_CSI2RX_Type::PPI_ERRSOTSYNC_HS
__I uint32_t MIPI_CSI2RX_Type::PPI_ERRESC
__I uint32_t MIPI_CSI2RX_Type::PPI_ERRSYNCESC
__I uint32_t MIPI_CSI2RX_Type::PPI_ERRCONTROL
__IO uint32_t MIPI_CSI2RX_Type::CFG_DISABLE_PAYLOAD_0
__IO uint32_t MIPI_CSI2RX_Type::CFG_DISABLE_PAYLOAD_1
uint8_t MIPI_CSI2RX_Type::RESERVED_1 [76]
__IO uint32_t MIPI_CSI2RX_Type::CFG_IGNORE_VC
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_VC
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_P_FIFO_SEND_LEVEL
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_VSYNC
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_HSYNC_FP
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_HSYNC_BP
__IO uint32_t MMCAU_Type::CASR
__IO uint32_t MMCAU_Type::CAA
__IO uint32_t MMCAU_Type::CA [9]
__IO uint32_t MU_Type::TR [4]
__I uint32_t MU_Type::RR [4]
__IO uint32_t MU_Type::SR
__IO uint32_t MU_Type::CR
__IO uint32_t OCOTP_Type::PDN
__IO uint32_t OCOTP_Type::OUT_STATUS
__IO uint32_t OCOTP_Type::OUT_STATUS_SET
__IO uint32_t OCOTP_Type::OUT_STATUS_CLR
__IO uint32_t OCOTP_Type::OUT_STATUS_TOG
__IO uint32_t   OCOTP_Type::READ_FUSE_DATA
uint8_t   OCOTP_Type::RESERVED_0 [12]
struct {
OCOTP_Type::READ_FUSE_DATAS [4]
__IO uint32_t OCOTP_Type::SW_LOCK
__IO uint32_t OCOTP_Type::BIT_LOCK
__I uint32_t OCOTP_Type::LOCKED0
__I uint32_t OCOTP_Type::LOCKED1
__I uint32_t OCOTP_Type::LOCKED2
__I uint32_t OCOTP_Type::LOCKED3
__I uint32_t OCOTP_Type::LOCKED4
__I uint32_t   OCOTP_Type::FUSE
struct {
OCOTP_Type::FUSEN [144]
__IO uint32_t   OSC_RC_400M_Type::RW
__IO uint32_t   OSC_RC_400M_Type::SET
__IO uint32_t   OSC_RC_400M_Type::CLR
__IO uint32_t   OSC_RC_400M_Type::TOG
struct {
OSC_RC_400M_Type::CTRL0
struct {
OSC_RC_400M_Type::CTRL1
struct {
OSC_RC_400M_Type::CTRL2
struct {
OSC_RC_400M_Type::CTRL3
uint8_t OSC_RC_400M_Type::RESERVED_0 [16]
__I uint32_t   OSC_RC_400M_Type::RW
__I uint32_t   OSC_RC_400M_Type::SET
__I uint32_t   OSC_RC_400M_Type::CLR
__I uint32_t   OSC_RC_400M_Type::TOG
struct {
OSC_RC_400M_Type::STAT0
struct {
OSC_RC_400M_Type::STAT1
struct {
OSC_RC_400M_Type::STAT2
uint8_t OTFAD_Type::RESERVED_0 [3072]
__IO uint32_t OTFAD_Type::CR
__IO uint32_t OTFAD_Type::SR
uint8_t OTFAD_Type::RESERVED_1 [248]
__IO uint32_t   OTFAD_Type::KEY [4]
__IO uint32_t   OTFAD_Type::CTR [2]
__IO uint32_t   OTFAD_Type::RGD_W0
__IO uint32_t   OTFAD_Type::RGD_W1
uint8_t   OTFAD_Type::RESERVED_0 [32]
struct {
OTFAD_Type::CTX [4]
__IO uint32_t PDM_Type::CTRL_1
__IO uint32_t PDM_Type::CTRL_2
__IO uint32_t PDM_Type::STAT
uint8_t PDM_Type::RESERVED_0 [4]
__IO uint32_t PDM_Type::FIFO_CTRL
__IO uint32_t PDM_Type::FIFO_STAT
uint8_t PDM_Type::RESERVED_1 [12]
__I uint32_t PDM_Type::DATACH [8]
uint8_t PDM_Type::RESERVED_2 [32]
__IO uint32_t PDM_Type::DC_CTRL
uint8_t PDM_Type::RESERVED_3 [12]
__IO uint32_t PDM_Type::RANGE_CTRL
uint8_t PDM_Type::RESERVED_4 [4]
__IO uint32_t PDM_Type::RANGE_STAT
uint8_t PDM_Type::RESERVED_5 [16]
__IO uint32_t PDM_Type::VAD0_CTRL_1
__IO uint32_t PDM_Type::VAD0_CTRL_2
__IO uint32_t PDM_Type::VAD0_STAT
__IO uint32_t PDM_Type::VAD0_SCONFIG
__IO uint32_t PDM_Type::VAD0_NCONFIG
__I uint32_t PDM_Type::VAD0_NDATA
__IO uint32_t PDM_Type::VAD0_ZCD
uint8_t PGMC_BPC_Type::RESERVED_0 [4]
__IO uint32_t PGMC_BPC_Type::BPC_AUTHEN_CTRL
uint8_t PGMC_BPC_Type::RESERVED_1 [8]
__IO uint32_t PGMC_BPC_Type::BPC_MODE
__IO uint32_t PGMC_BPC_Type::BPC_POWER_CTRL
uint8_t PGMC_BPC_Type::RESERVED_2 [20]
__IO uint32_t PGMC_BPC_Type::BPC_FLAG
uint8_t PGMC_BPC_Type::RESERVED_3 [16]
__IO uint32_t PGMC_BPC_Type::BPC_SSAR_SAVE_CTRL
__IO uint32_t PGMC_BPC_Type::BPC_SSAR_RESTORE_CTRL
uint8_t PGMC_CPC_Type::RESERVED_0 [4]
__IO uint32_t PGMC_CPC_Type::CPC_AUTHEN_CTRL
uint8_t PGMC_CPC_Type::RESERVED_1 [8]
__IO uint32_t PGMC_CPC_Type::CPC_CORE_MODE
__IO uint32_t PGMC_CPC_Type::CPC_CORE_POWER_CTRL
uint8_t PGMC_CPC_Type::RESERVED_2 [20]
__IO uint32_t PGMC_CPC_Type::CPC_FLAG
uint8_t PGMC_CPC_Type::RESERVED_3 [16]
__IO uint32_t PGMC_CPC_Type::CPC_CACHE_MODE
__IO uint32_t PGMC_CPC_Type::CPC_CACHE_CM_CTRL
__IO uint32_t PGMC_CPC_Type::CPC_CACHE_SP_CTRL_0
__IO uint32_t PGMC_CPC_Type::CPC_CACHE_SP_CTRL_1
uint8_t PGMC_CPC_Type::RESERVED_4 [112]
__IO uint32_t PGMC_CPC_Type::CPC_LMEM_MODE
__IO uint32_t PGMC_CPC_Type::CPC_LMEM_CM_CTRL
__IO uint32_t PGMC_CPC_Type::CPC_LMEM_SP_CTRL_0
__IO uint32_t PGMC_CPC_Type::CPC_LMEM_SP_CTRL_1
uint8_t PGMC_MIF_Type::RESERVED_0 [4]
__IO uint32_t PGMC_MIF_Type::MIF_AUTHEN_CTRL
uint8_t PGMC_MIF_Type::RESERVED_1 [8]
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_SLEEP
uint8_t PGMC_MIF_Type::RESERVED_2 [12]
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_IG
uint8_t PGMC_MIF_Type::RESERVED_3 [12]
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_LS
uint8_t PGMC_MIF_Type::RESERVED_4 [12]
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_HS
uint8_t PGMC_MIF_Type::RESERVED_5 [12]
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_STDBY
uint8_t PGMC_MIF_Type::RESERVED_6 [12]
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_ARR_PDN
uint8_t PGMC_MIF_Type::RESERVED_7 [12]
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_PER_PDN
uint8_t PGMC_MIF_Type::RESERVED_8 [12]
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_INITN
uint8_t PGMC_MIF_Type::RESERVED_9 [44]
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_ISO
uint8_t PGMC_PPC_Type::RESERVED_0 [4]
__IO uint32_t PGMC_PPC_Type::PPC_AUTHEN_CTRL
uint8_t PGMC_PPC_Type::RESERVED_1 [8]
__IO uint32_t PGMC_PPC_Type::PPC_MODE
__IO uint32_t PGMC_PPC_Type::PPC_STBY_CM_CTRL
__IO uint32_t PGMC_PPC_Type::PPC_STBY_SP_CTRL
__IO uint32_t   PHY_LDO_Type::RW
__IO uint32_t   PHY_LDO_Type::SET
__IO uint32_t   PHY_LDO_Type::CLR
__IO uint32_t   PHY_LDO_Type::TOG
struct {
PHY_LDO_Type::CTRL0
uint8_t PHY_LDO_Type::RESERVED_0 [64]
__I uint32_t   PHY_LDO_Type::RW
__I uint32_t   PHY_LDO_Type::SET
__I uint32_t   PHY_LDO_Type::CLR
__I uint32_t   PHY_LDO_Type::TOG
struct {
PHY_LDO_Type::STAT0
__IO uint32_t   PIT_Type::LDVAL
__I uint32_t   PIT_Type::CVAL
__IO uint32_t   PIT_Type::TCTRL
__IO uint32_t   PIT_Type::TFLG
struct {
PIT_Type::CHANNEL [4]
__IO uint32_t PUF_Type::CTRL
__IO uint32_t PUF_Type::KEYINDEX
__IO uint32_t PUF_Type::KEYSIZE
uint8_t PUF_Type::RESERVED_0 [20]
__I uint32_t PUF_Type::STAT
uint8_t PUF_Type::RESERVED_1 [4]
__I uint32_t PUF_Type::ALLOW
uint8_t PUF_Type::RESERVED_2 [20]
__O uint32_t PUF_Type::KEYINPUT
__O uint32_t PUF_Type::CODEINPUT
__I uint32_t PUF_Type::CODEOUTPUT
uint8_t PUF_Type::RESERVED_3 [20]
__I uint32_t PUF_Type::KEYOUTINDEX
__I uint32_t PUF_Type::KEYOUTPUT
uint8_t PUF_Type::RESERVED_4 [116]
__IO uint32_t PUF_Type::IFSTAT
uint8_t PUF_Type::RESERVED_5 [28]
__I uint32_t PUF_Type::VERSION
__IO uint32_t PUF_Type::INTEN
__IO uint32_t PUF_Type::INTSTAT
__IO uint32_t PUF_Type::PWRCTRL
__IO uint32_t PUF_Type::CFG
uint8_t PUF_Type::RESERVED_6 [240]
__IO uint32_t PUF_Type::KEYLOCK
__IO uint32_t PUF_Type::KEYENABLE
__IO uint32_t PUF_Type::KEYRESET
__IO uint32_t PUF_Type::IDXBLK
__IO uint32_t PUF_Type::IDXBLK_DP
__IO uint32_t PUF_Type::KEYMASK [2]
uint8_t PUF_Type::RESERVED_7 [56]
__I uint32_t PUF_Type::IDXBLK_STATUS
__I uint32_t PUF_Type::IDXBLK_SHIFT
__I uint16_t   PWM_Type::CNT
__IO uint16_t   PWM_Type::INIT
__IO uint16_t   PWM_Type::CTRL2
uint8_t   PWM_Type::RESERVED_0 [2]
__IO uint16_t   PWM_Type::VAL0
__IO uint16_t   PWM_Type::FRACVAL1
__IO uint16_t   PWM_Type::VAL1
__IO uint16_t   PWM_Type::FRACVAL2
__IO uint16_t   PWM_Type::VAL2
__IO uint16_t   PWM_Type::FRACVAL3
__IO uint16_t   PWM_Type::VAL3
__IO uint16_t   PWM_Type::FRACVAL4
__IO uint16_t   PWM_Type::VAL4
__IO uint16_t   PWM_Type::FRACVAL5
__IO uint16_t   PWM_Type::VAL5
__IO uint16_t   PWM_Type::FRCTRL
__IO uint16_t   PWM_Type::OCTRL
__IO uint16_t   PWM_Type::STS
__IO uint16_t   PWM_Type::INTEN
__IO uint16_t   PWM_Type::DMAEN
__IO uint16_t   PWM_Type::TCTRL
__IO uint16_t   PWM_Type::DISMAP [1]
uint8_t   PWM_Type::RESERVED_1 [2]
__IO uint16_t   PWM_Type::DTCNT0
__IO uint16_t   PWM_Type::DTCNT1
__IO uint16_t   PWM_Type::CAPTCTRLA
__IO uint16_t   PWM_Type::CAPTCOMPA
__IO uint16_t   PWM_Type::CAPTCTRLB
__IO uint16_t   PWM_Type::CAPTCOMPB
__IO uint16_t   PWM_Type::CAPTCTRLX
__IO uint16_t   PWM_Type::CAPTCOMPX
__I uint16_t   PWM_Type::CVAL0
__I uint16_t   PWM_Type::CVAL0CYC
__I uint16_t   PWM_Type::CVAL1
__I uint16_t   PWM_Type::CVAL1CYC
__I uint16_t   PWM_Type::CVAL2
__I uint16_t   PWM_Type::CVAL2CYC
__I uint16_t   PWM_Type::CVAL3
__I uint16_t   PWM_Type::CVAL3CYC
__I uint16_t   PWM_Type::CVAL4
__I uint16_t   PWM_Type::CVAL4CYC
__I uint16_t   PWM_Type::CVAL5
__I uint16_t   PWM_Type::CVAL5CYC
uint8_t   PWM_Type::RESERVED_2 [8]
struct {
   uint8_t   RESERVED_0 [2]
   uint8_t   RESERVED_1 [2]
   uint8_t   RESERVED_2 [8]
PWM_Type::SM [4]
__I uint32_t RDC_Type::VIR
uint8_t RDC_Type::RESERVED_0 [32]
__IO uint32_t RDC_Type::STAT
__IO uint32_t RDC_Type::INTCTRL
__IO uint32_t RDC_Type::INTSTAT
uint8_t RDC_Type::RESERVED_1 [464]
__IO uint32_t RDC_Type::MDA [12]
uint8_t RDC_Type::RESERVED_2 [464]
__IO uint32_t RDC_Type::PDAP [128]
uint8_t RDC_Type::RESERVED_3 [512]
__IO uint32_t   RDC_Type::MRSA
__IO uint32_t   RDC_Type::MREA
__IO uint32_t   RDC_Type::MRC
__IO uint32_t   RDC_Type::MRVS
struct {
RDC_Type::MR [59]
__IO uint8_t RDC_SEMAPHORE_Type::GATE [64]
uint8_t RDC_SEMAPHORE_Type::RESERVED_0 [2]
__IO uint16_t   RDC_SEMAPHORE_Type::RSTGT_R
__IO uint16_t   RDC_SEMAPHORE_Type::RSTGT_W
union {
__IO uint8_t SEMA4_Type::GATE [16]
uint8_t SEMA4_Type::RESERVED_0 [48]
__IO uint16_t   SEMA4_Type::CPINE
uint8_t   SEMA4_Type::RESERVED_0 [6]
struct {
   uint8_t   RESERVED_0 [6]
SEMA4_Type::CPINE [2]
uint8_t SEMA4_Type::RESERVED_1 [48]
__I uint16_t   SEMA4_Type::CPNTF
struct {
SEMA4_Type::CPNTF [2]
uint8_t SEMA4_Type::RESERVED_2 [112]
__IO uint16_t SEMA4_Type::RSTGT
uint8_t SEMA4_Type::RESERVED_3 [2]
__IO uint16_t SEMA4_Type::RSTNTF
__IO uint32_t SEMC_Type::DLLCR
__IO uint32_t SEMC_Type::NORCR3
__IO uint32_t SEMC_Type::DBICR2
__I uint32_t SEMC_Type::STS13
__IO uint32_t SEMC_Type::BR9
__IO uint32_t SEMC_Type::BR10
__IO uint32_t SEMC_Type::BR11
__IO uint32_t SEMC_Type::SRAMCR4
__IO uint32_t SEMC_Type::SRAMCR5
__IO uint32_t SEMC_Type::SRAMCR6
uint8_t SEMC_Type::RESERVED_4 [36]
__IO uint32_t SEMC_Type::DCCR
__IO uint32_t SNVS_Type::LPTGFCR
__IO uint32_t SNVS_Type::LPTDCR
__IO uint32_t SNVS_Type::LPTDC2R
__IO uint32_t SNVS_Type::LPTDSR
__IO uint32_t SNVS_Type::LPTGF1CR
__IO uint32_t SNVS_Type::LPTGF2CR
__O uint32_t SNVS_Type::LPATCR [5]
__IO uint32_t SNVS_Type::LPATCTLR
__IO uint32_t SNVS_Type::LPATCLKR
__IO uint32_t SNVS_Type::LPATRC1R
__IO uint32_t SNVS_Type::LPATRC2R
uint8_t SNVS_Type::RESERVED_4 [2792]
__O uint32_t   SPDIF_Type::SIC
__I uint32_t   SPDIF_Type::SIS
union {
uint8_t SRAM_Type::RESERVED_0 [12288]
__IO uint32_t SRAM_Type::CTRL
__IO uint32_t SRC_Type::SRMR
__IO uint32_t SRC_Type::AUTHEN_MEGA
__IO uint32_t SRC_Type::CTRL_MEGA
__IO uint32_t SRC_Type::SETPOINT_MEGA
__IO uint32_t SRC_Type::DOMAIN_MEGA
__IO uint32_t SRC_Type::STAT_MEGA
uint8_t SRC_Type::RESERVED_1 [12]
__IO uint32_t SRC_Type::AUTHEN_DISPLAY
__IO uint32_t SRC_Type::CTRL_DISPLAY
__IO uint32_t SRC_Type::SETPOINT_DISPLAY
__IO uint32_t SRC_Type::DOMAIN_DISPLAY
__IO uint32_t SRC_Type::STAT_DISPLAY
uint8_t SRC_Type::RESERVED_2 [12]
__IO uint32_t SRC_Type::AUTHEN_WAKEUP
__IO uint32_t SRC_Type::CTRL_WAKEUP
__IO uint32_t SRC_Type::SETPOINT_WAKEUP
__IO uint32_t SRC_Type::DOMAIN_WAKEUP
__IO uint32_t SRC_Type::STAT_WAKEUP
uint8_t SRC_Type::RESERVED_3 [44]
__IO uint32_t SRC_Type::AUTHEN_M4CORE
__IO uint32_t SRC_Type::CTRL_M4CORE
__IO uint32_t SRC_Type::SETPOINT_M4CORE
__IO uint32_t SRC_Type::DOMAIN_M4CORE
__IO uint32_t SRC_Type::STAT_M4CORE
uint8_t SRC_Type::RESERVED_4 [12]
__IO uint32_t SRC_Type::AUTHEN_M7CORE
__IO uint32_t SRC_Type::CTRL_M7CORE
__IO uint32_t SRC_Type::SETPOINT_M7CORE
__IO uint32_t SRC_Type::DOMAIN_M7CORE
__IO uint32_t SRC_Type::STAT_M7CORE
uint8_t SRC_Type::RESERVED_5 [12]
__IO uint32_t SRC_Type::AUTHEN_M4DEBUG
__IO uint32_t SRC_Type::CTRL_M4DEBUG
__IO uint32_t SRC_Type::SETPOINT_M4DEBUG
__IO uint32_t SRC_Type::DOMAIN_M4DEBUG
__IO uint32_t SRC_Type::STAT_M4DEBUG
uint8_t SRC_Type::RESERVED_6 [12]
__IO uint32_t SRC_Type::AUTHEN_M7DEBUG
__IO uint32_t SRC_Type::CTRL_M7DEBUG
__IO uint32_t SRC_Type::SETPOINT_M7DEBUG
__IO uint32_t SRC_Type::DOMAIN_M7DEBUG
__IO uint32_t SRC_Type::STAT_M7DEBUG
uint8_t SRC_Type::RESERVED_7 [12]
__IO uint32_t SRC_Type::AUTHEN_USBPHY1
__IO uint32_t SRC_Type::CTRL_USBPHY1
__IO uint32_t SRC_Type::SETPOINT_USBPHY1
__IO uint32_t SRC_Type::DOMAIN_USBPHY1
__IO uint32_t SRC_Type::STAT_USBPHY1
uint8_t SRC_Type::RESERVED_8 [12]
__IO uint32_t SRC_Type::AUTHEN_USBPHY2
__IO uint32_t SRC_Type::CTRL_USBPHY2
__IO uint32_t SRC_Type::SETPOINT_USBPHY2
__IO uint32_t SRC_Type::DOMAIN_USBPHY2
__IO uint32_t SRC_Type::STAT_USBPHY2
__IO uint32_t   SSARC_HP_Type::SRAM0
__IO uint32_t   SSARC_HP_Type::SRAM1
__IO uint32_t   SSARC_HP_Type::SRAM2
uint8_t   SSARC_HP_Type::RESERVED_0 [4]
struct {
SSARC_HP_Type::DESC [1024]
__IO uint32_t   SSARC_LP_Type::DESC_CTRL0
__IO uint32_t   SSARC_LP_Type::DESC_CTRL1
__IO uint32_t   SSARC_LP_Type::DESC_ADDR_UP
__IO uint32_t   SSARC_LP_Type::DESC_ADDR_DOWN
uint8_t   SSARC_LP_Type::RESERVED_0 [16]
struct {
SSARC_LP_Type::GROUPS [16]
__IO uint32_t SSARC_LP_Type::CTRL
__IO uint32_t SSARC_LP_Type::INT_STATUS
__IO uint32_t SSARC_LP_Type::HP_TIMEOUT
uint8_t SSARC_LP_Type::RESERVED_1 [12]
__I uint32_t SSARC_LP_Type::HW_GROUP_PENDING
__I uint32_t SSARC_LP_Type::SW_GROUP_PENDING
__IO uint32_t TMPSNS_Type::CTRL0
__IO uint32_t TMPSNS_Type::CTRL0_SET
__IO uint32_t TMPSNS_Type::CTRL0_CLR
__IO uint32_t TMPSNS_Type::CTRL0_TOG
__IO uint32_t TMPSNS_Type::CTRL1
__IO uint32_t TMPSNS_Type::CTRL1_SET
__IO uint32_t TMPSNS_Type::CTRL1_CLR
__IO uint32_t TMPSNS_Type::CTRL1_TOG
__IO uint32_t TMPSNS_Type::RANGE0
__IO uint32_t TMPSNS_Type::RANGE0_SET
__IO uint32_t TMPSNS_Type::RANGE0_CLR
__IO uint32_t TMPSNS_Type::RANGE0_TOG
__IO uint32_t TMPSNS_Type::RANGE1
__IO uint32_t TMPSNS_Type::RANGE1_SET
__IO uint32_t TMPSNS_Type::RANGE1_CLR
__IO uint32_t TMPSNS_Type::RANGE1_TOG
uint8_t TMPSNS_Type::RESERVED_0 [16]
__IO uint32_t TMPSNS_Type::STATUS0
__IO uint16_t   TMR_Type::COMP1
__IO uint16_t   TMR_Type::COMP2
__IO uint16_t   TMR_Type::CAPT
__IO uint16_t   TMR_Type::LOAD
__IO uint16_t   TMR_Type::HOLD
__IO uint16_t   TMR_Type::CNTR
__IO uint16_t   TMR_Type::CTRL
__IO uint16_t   TMR_Type::SCTRL
__IO uint16_t   TMR_Type::CMPLD1
__IO uint16_t   TMR_Type::CMPLD2
__IO uint16_t   TMR_Type::CSCTRL
__IO uint16_t   TMR_Type::FILT
__IO uint16_t   TMR_Type::DMA
uint8_t   TMR_Type::RESERVED_0 [4]
__IO uint16_t   TMR_Type::ENBL
struct {
TMR_Type::CHANNEL [4]
__IO uint32_t   USB_Type::DEVICEADDR
__IO uint32_t   USB_Type::PERIODICLISTBASE
union {
__IO uint32_t   USB_Type::ASYNCLISTADDR
__IO uint32_t   USB_Type::ENDPTLISTADDR
union {
__IO uint32_t USBHSDCD_Type::CONTROL
__IO uint32_t USBHSDCD_Type::CLOCK
__I uint32_t USBHSDCD_Type::STATUS
__IO uint32_t USBHSDCD_Type::SIGNAL_OVERRIDE
__IO uint32_t USBHSDCD_Type::TIMER0
__IO uint32_t USBHSDCD_Type::TIMER1
__IO uint32_t   USBHSDCD_Type::TIMER2_BC11
__IO uint32_t   USBHSDCD_Type::TIMER2_BC12
union {
__IO uint32_t USBNC_Type::CTRL1
__IO uint32_t USBNC_Type::CTRL2
__IO uint32_t USBNC_Type::HSIC_CTRL
uint8_t USBPHY_Type::RESERVED_2 [28]
__IO uint32_t USBPHY_Type::PLL_SIC
__IO uint32_t USBPHY_Type::PLL_SIC_SET
__IO uint32_t USBPHY_Type::PLL_SIC_CLR
__IO uint32_t USBPHY_Type::PLL_SIC_TOG
uint8_t USBPHY_Type::RESERVED_3 [16]
__IO uint32_t USBPHY_Type::USB1_VBUS_DETECT
__IO uint32_t USBPHY_Type::USB1_VBUS_DETECT_SET
__IO uint32_t USBPHY_Type::USB1_VBUS_DETECT_CLR
__IO uint32_t USBPHY_Type::USB1_VBUS_DETECT_TOG
__I uint32_t USBPHY_Type::USB1_VBUS_DET_STAT
uint8_t USBPHY_Type::RESERVED_4 [12]
__IO uint32_t USBPHY_Type::USB1_CHRG_DETECT
__IO uint32_t USBPHY_Type::USB1_CHRG_DETECT_SET
__IO uint32_t USBPHY_Type::USB1_CHRG_DETECT_CLR
__IO uint32_t USBPHY_Type::USB1_CHRG_DETECT_TOG
__I uint32_t USBPHY_Type::USB1_CHRG_DET_STAT
uint8_t USBPHY_Type::RESERVED_5 [12]
__IO uint32_t USBPHY_Type::ANACTRL
__IO uint32_t USBPHY_Type::ANACTRL_SET
__IO uint32_t USBPHY_Type::ANACTRL_CLR
__IO uint32_t USBPHY_Type::ANACTRL_TOG
__IO uint32_t USBPHY_Type::USB1_LOOPBACK
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_SET
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_CLR
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_TOG
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_HSFSCNT
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_HSFSCNT_SET
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_HSFSCNT_CLR
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_HSFSCNT_TOG
__IO uint32_t USBPHY_Type::TRIM_OVERRIDE_EN
__IO uint32_t USBPHY_Type::TRIM_OVERRIDE_EN_SET
__IO uint32_t USBPHY_Type::TRIM_OVERRIDE_EN_CLR
__IO uint32_t USBPHY_Type::TRIM_OVERRIDE_EN_TOG
__IO uint32_t USDHC_Type::STROBE_DLL_CTRL
__I uint32_t USDHC_Type::STROBE_DLL_STATUS
uint8_t USDHC_Type::RESERVED_3 [72]
__IO uint32_t   VIDEO_MUX_Type::RW
__IO uint32_t   VIDEO_MUX_Type::SET
__IO uint32_t   VIDEO_MUX_Type::CLR
__IO uint32_t   VIDEO_MUX_Type::TOG
struct {
VIDEO_MUX_Type::VID_MUX_CTRL
uint8_t VIDEO_MUX_Type::RESERVED_0 [16]
struct {
VIDEO_MUX_Type::PLM_CTRL
struct {
VIDEO_MUX_Type::YUV420_CTRL
uint8_t VIDEO_MUX_Type::RESERVED_1 [16]
struct {
VIDEO_MUX_Type::CFG_DT_DISABLE
uint8_t VIDEO_MUX_Type::RESERVED_2 [16]
struct {
VIDEO_MUX_Type::MIPI_DSI_CTRL
__IO uint32_t   VIDEO_PLL_Type::RW
__IO uint32_t   VIDEO_PLL_Type::SET
__IO uint32_t   VIDEO_PLL_Type::CLR
__IO uint32_t   VIDEO_PLL_Type::TOG
struct {
VIDEO_PLL_Type::CTRL0
struct {
VIDEO_PLL_Type::SPREAD_SPECTRUM
struct {
VIDEO_PLL_Type::NUMERATOR
struct {
VIDEO_PLL_Type::DENOMINATOR
__IO uint32_t   VMBANDGAP_Type::RW
__IO uint32_t   VMBANDGAP_Type::SET
__IO uint32_t   VMBANDGAP_Type::CLR
__IO uint32_t   VMBANDGAP_Type::TOG
struct {
VMBANDGAP_Type::CTRL0
uint8_t VMBANDGAP_Type::RESERVED_0 [64]
__I uint32_t   VMBANDGAP_Type::RW
__I uint32_t   VMBANDGAP_Type::SET
__I uint32_t   VMBANDGAP_Type::CLR
__I uint32_t   VMBANDGAP_Type::TOG
struct {
VMBANDGAP_Type::STAT0
__IO uint16_t XBARA_Type::SEL66
__IO uint16_t XBARA_Type::SEL67
__IO uint16_t XBARA_Type::SEL68
__IO uint16_t XBARA_Type::SEL69
__IO uint16_t XBARA_Type::SEL70
__IO uint16_t XBARA_Type::SEL71
__IO uint16_t XBARA_Type::SEL72
__IO uint16_t XBARA_Type::SEL73
__IO uint16_t XBARA_Type::SEL74
__IO uint16_t XBARA_Type::SEL75
__IO uint16_t XBARA_Type::SEL76
__IO uint16_t XBARA_Type::SEL77
__IO uint16_t XBARA_Type::SEL78
__IO uint16_t XBARA_Type::SEL79
__IO uint16_t XBARA_Type::SEL80
__IO uint16_t XBARA_Type::SEL81
__IO uint16_t XBARA_Type::SEL82
__IO uint16_t XBARA_Type::SEL83
__IO uint16_t XBARA_Type::SEL84
__IO uint16_t XBARA_Type::SEL85
__IO uint16_t XBARA_Type::SEL86
__IO uint16_t XBARA_Type::SEL87
__IO uint32_t XECC_Type::ECC_CTRL
__IO uint32_t XECC_Type::ERR_STATUS
__IO uint32_t XECC_Type::ERR_STAT_EN
__IO uint32_t XECC_Type::ERR_SIG_EN
__IO uint32_t XECC_Type::ERR_DATA_INJ
__IO uint32_t XECC_Type::ERR_ECC_INJ
__I uint32_t XECC_Type::SINGLE_ERR_ADDR
__I uint32_t XECC_Type::SINGLE_ERR_DATA
__I uint32_t XECC_Type::SINGLE_ERR_ECC
__I uint32_t XECC_Type::SINGLE_ERR_POS
__I uint32_t XECC_Type::SINGLE_ERR_BIT_FIELD
__I uint32_t XECC_Type::MULTI_ERR_ADDR
__I uint32_t XECC_Type::MULTI_ERR_DATA
__I uint32_t XECC_Type::MULTI_ERR_ECC
__I uint32_t XECC_Type::MULTI_ERR_BIT_FIELD
__IO uint32_t XECC_Type::ECC_BASE_ADDR0
__IO uint32_t XECC_Type::ECC_END_ADDR0
__IO uint32_t XECC_Type::ECC_BASE_ADDR1
__IO uint32_t XECC_Type::ECC_END_ADDR1
__IO uint32_t XECC_Type::ECC_BASE_ADDR2
__IO uint32_t XECC_Type::ECC_END_ADDR2
__IO uint32_t XECC_Type::ECC_BASE_ADDR3
__IO uint32_t XECC_Type::ECC_END_ADDR3
__IO uint32_t XRDC2_Type::MCR
__I uint32_t XRDC2_Type::SR
uint8_t XRDC2_Type::RESERVED_0 [4088]
__IO uint32_t   XRDC2_Type::MSC_MSAC_W0
__IO uint32_t   XRDC2_Type::MSC_MSAC_W1
struct {
XRDC2_Type::MSCI_MSAC_WK [128]
uint8_t XRDC2_Type::RESERVED_1 [3072]
__IO uint32_t   XRDC2_Type::MDAC_MDA_W0
__IO uint32_t   XRDC2_Type::MDAC_MDA_W1
struct {
XRDC2_Type::MDACI_MDAJ [32][32]
__IO uint32_t   XRDC2_Type::PAC_PDAC_W0
__IO uint32_t   XRDC2_Type::PAC_PDAC_W1
struct {
XRDC2_Type::PACI_PDACJ [8][256]
__IO uint32_t   XRDC2_Type::MRC_MRGD_W0
__IO uint32_t   XRDC2_Type::MRC_MRGD_W1
__IO uint32_t   XRDC2_Type::MRC_MRGD_W2
__IO uint32_t   XRDC2_Type::MRC_MRGD_W3
uint8_t   XRDC2_Type::RESERVED_0 [4]
__IO uint32_t   XRDC2_Type::MRC_MRGD_W5
__IO uint32_t   XRDC2_Type::MRC_MRGD_W6
uint8_t   XRDC2_Type::RESERVED_1 [4]
struct {
   uint8_t   RESERVED_1 [4]
XRDC2_Type::MRCI_MRGDJ [32][32]
__IO uint32_t   ADC_Type::CMDL
__IO uint32_t   ADC_Type::CMDH
struct {
ADC_Type::CMD [15]
__IO uint32_t   ADC_ETC_Type::TRIGn_CTRL
__IO uint32_t   ADC_ETC_Type::TRIGn_COUNTER
__IO uint32_t   ADC_ETC_Type::TRIGn_CHAIN_1_0
__IO uint32_t   ADC_ETC_Type::TRIGn_CHAIN_3_2
__IO uint32_t   ADC_ETC_Type::TRIGn_CHAIN_5_4
__IO uint32_t   ADC_ETC_Type::TRIGn_CHAIN_7_6
__I uint32_t   ADC_ETC_Type::TRIGn_RESULT_1_0
__I uint32_t   ADC_ETC_Type::TRIGn_RESULT_3_2
__I uint32_t   ADC_ETC_Type::TRIGn_RESULT_5_4
__I uint32_t   ADC_ETC_Type::TRIGn_RESULT_7_6
struct {
ADC_ETC_Type::TRIG [8]
__IO uint16_t   AOI_Type::BFCRT01
__IO uint16_t   AOI_Type::BFCRT23
struct {
AOI_Type::BFCRT [4]
__IO uint32_t   AUDIO_PLL_Type::RW
__IO uint32_t   AUDIO_PLL_Type::SET
__IO uint32_t   AUDIO_PLL_Type::CLR
__IO uint32_t   AUDIO_PLL_Type::TOG
struct {
AUDIO_PLL_Type::CTRL0
struct {
AUDIO_PLL_Type::SPREAD_SPECTRUM
struct {
AUDIO_PLL_Type::NUMERATOR
struct {
AUDIO_PLL_Type::DENOMINATOR
__IO uint32_t   CAAM_Type::JRDID_MS
__IO uint32_t   CAAM_Type::JRDID_LS
struct {
CAAM_Type::JRADID [4]
__IO uint32_t   CAAM_Type::RTIC_DID
uint8_t   CAAM_Type::RESERVED_0 [4]
struct {
CAAM_Type::RTICADID [4]
__IO uint32_t   CAAM_Type::DECODID_MS
__IO uint32_t   CAAM_Type::DECODID_LS
struct {
CAAM_Type::DECONDID [1]
__IO uint32_t   CAAM_Type::JRSMVBAR
struct {
CAAM_Type::JRNSMVBAR [4]
__I uint32_t   CAAM_Type::DMA_AIDL_MAP_MS
__I uint32_t   CAAM_Type::DMA_AIDL_MAP_LS
__I uint32_t   CAAM_Type::DMA_AIDM_MAP_MS
__I uint32_t   CAAM_Type::DMA_AIDM_MAP_LS
struct {
CAAM_Type::AID_CNTS [1]
__IO uint32_t   CAAM_Type::RTPKRMAX
__I uint32_t   CAAM_Type::RTPKRSQ
union {
__IO uint32_t   CAAM_Type::RTSBLIM
__I uint32_t   CAAM_Type::RTTOTSAM
union {
__I uint32_t   CAAM_Type::RTFRQCNT
__I uint32_t   CAAM_Type::RTSCMC
__I uint32_t   CAAM_Type::RTSCR1C
__I uint32_t   CAAM_Type::RTSCR2C
__I uint32_t   CAAM_Type::RTSCR3C
__I uint32_t   CAAM_Type::RTSCR4C
__I uint32_t   CAAM_Type::RTSCR5C
__I uint32_t   CAAM_Type::RTSCR6PC
struct {
}   CAAM_Type::COUNT
__IO uint32_t   CAAM_Type::RTFRQMAX
__IO uint32_t   CAAM_Type::RTSCML
__IO uint32_t   CAAM_Type::RTSCR1L
__IO uint32_t   CAAM_Type::RTSCR2L
__IO uint32_t   CAAM_Type::RTSCR3L
__IO uint32_t   CAAM_Type::RTSCR4L
__IO uint32_t   CAAM_Type::RTSCR5L
__IO uint32_t   CAAM_Type::RTSCR6PL
struct {
}   CAAM_Type::LIMIT
union {
   struct {
   }   COUNT
   struct {
   }   LIMIT
__I uint32_t   CAAM_Type::PX_SDID_PG0
__IO uint32_t   CAAM_Type::PX_SMAPR_PG0
__IO uint32_t   CAAM_Type::PX_SMAG2_PG0
__IO uint32_t   CAAM_Type::PX_SMAG1_PG0
struct {
CAAM_Type::PX_PG0 [16]
__I uint64_t   CAAM_Type::HT_JD_ADDR
__I uint64_t   CAAM_Type::HT_SD_ADDR
__I uint32_t   CAAM_Type::HT_JQ_CTRL_MS
__I uint32_t   CAAM_Type::HT_JQ_CTRL_LS
__I uint32_t   CAAM_Type::HT_STATUS
struct {
CAAM_Type::HTA [1]
__IO uint64_t   CAAM_Type::IRBAR_JR
__IO uint32_t   CAAM_Type::IRSR_JR
uint8_t   CAAM_Type::RESERVED_1 [4]
__IO uint32_t   CAAM_Type::IRSAR_JR
uint8_t   CAAM_Type::RESERVED_2 [4]
__IO uint32_t   CAAM_Type::IRJAR_JR
__IO uint64_t   CAAM_Type::ORBAR_JR
uint8_t   CAAM_Type::RESERVED_3 [4]
__IO uint32_t   CAAM_Type::ORSR_JR
uint8_t   CAAM_Type::RESERVED_4 [4]
__IO uint32_t   CAAM_Type::ORJRR_JR
uint8_t   CAAM_Type::RESERVED_5 [4]
__IO uint32_t   CAAM_Type::ORSFR_JR
uint8_t   CAAM_Type::RESERVED_6 [4]
__I uint32_t   CAAM_Type::JRSTAR_JR
uint8_t   CAAM_Type::RESERVED_7 [4]
__IO uint32_t   CAAM_Type::JRINTR_JR
__IO uint32_t   CAAM_Type::JRCFGR_JR_MS
__IO uint32_t   CAAM_Type::JRCFGR_JR_LS
uint8_t   CAAM_Type::RESERVED_8 [4]
__IO uint32_t   CAAM_Type::IRRIR_JR
uint8_t   CAAM_Type::RESERVED_9 [4]
__IO uint32_t   CAAM_Type::ORWIR_JR
uint8_t   CAAM_Type::RESERVED_10 [4]
__O uint32_t   CAAM_Type::JRCR_JR
uint8_t   CAAM_Type::RESERVED_11 [1684]
__I uint32_t   CAAM_Type::JRAAV
uint8_t   CAAM_Type::RESERVED_12 [248]
__I uint64_t   CAAM_Type::JRAAA [4]
uint8_t   CAAM_Type::RESERVED_13 [480]
__I uint32_t   CAAM_Type::PX_SDID_JR
__IO uint32_t   CAAM_Type::PX_SMAPR_JR
__IO uint32_t   CAAM_Type::PX_SMAG2_JR
__IO uint32_t   CAAM_Type::PX_SMAG1_JR
struct {
}   CAAM_Type::PX_JR [16]
uint8_t   CAAM_Type::RESERVED_14 [228]
__O uint32_t   CAAM_Type::SMCR_JR
uint8_t   CAAM_Type::RESERVED_15 [4]
__I uint32_t   CAAM_Type::SMCSR_JR
uint8_t   CAAM_Type::RESERVED_16 [528]
__I uint32_t   CAAM_Type::REIR0JR
uint8_t   CAAM_Type::RESERVED_17 [4]
__I uint64_t   CAAM_Type::REIR2JR
__I uint32_t   CAAM_Type::REIR4JR
__I uint32_t   CAAM_Type::REIR5JR
uint8_t   CAAM_Type::RESERVED_18 [392]
__I uint32_t   CAAM_Type::CRNR_MS_JR
__I uint32_t   CAAM_Type::CRNR_LS_JR
__I uint32_t   CAAM_Type::CTPR_MS_JR
__I uint32_t   CAAM_Type::CTPR_LS_JR
uint8_t   CAAM_Type::RESERVED_19 [4]
__I uint32_t   CAAM_Type::SMSTA_JR
uint8_t   CAAM_Type::RESERVED_20 [4]
__I uint32_t   CAAM_Type::SMPO_JR
__I uint64_t   CAAM_Type::FAR_JR
__I uint32_t   CAAM_Type::FADID_JR
__I uint32_t   CAAM_Type::FADR_JR
uint8_t   CAAM_Type::RESERVED_21 [4]
__I uint32_t   CAAM_Type::CSTA_JR
__I uint32_t   CAAM_Type::SMVID_MS_JR
__I uint32_t   CAAM_Type::SMVID_LS_JR
__I uint32_t   CAAM_Type::RVID_JR
__I uint32_t   CAAM_Type::CCBVID_JR
__I uint32_t   CAAM_Type::CHAVID_MS_JR
__I uint32_t   CAAM_Type::CHAVID_LS_JR
__I uint32_t   CAAM_Type::CHANUM_MS_JR
__I uint32_t   CAAM_Type::CHANUM_LS_JR
__I uint32_t   CAAM_Type::CAAMVID_MS_JR
__I uint32_t   CAAM_Type::CAAMVID_LS_JR
uint8_t   CAAM_Type::RESERVED_22 [61440]
struct {
   uint8_t   RESERVED_2 [4]
   uint8_t   RESERVED_3 [4]
   uint8_t   RESERVED_4 [4]
   uint8_t   RESERVED_5 [4]
   uint8_t   RESERVED_6 [4]
   uint8_t   RESERVED_7 [4]
   uint8_t   RESERVED_8 [4]
   uint8_t   RESERVED_9 [4]
   uint8_t   RESERVED_10 [4]
   uint8_t   RESERVED_11 [1684]
   uint8_t   RESERVED_12 [248]
   uint8_t   RESERVED_13 [480]
   struct {
   }   PX_JR [16]
   uint8_t   RESERVED_14 [228]
   uint8_t   RESERVED_15 [4]
   uint8_t   RESERVED_16 [528]
   uint8_t   RESERVED_17 [4]
   uint8_t   RESERVED_18 [392]
   uint8_t   RESERVED_19 [4]
   uint8_t   RESERVED_20 [4]
   uint8_t   RESERVED_21 [4]
   uint8_t   RESERVED_22 [61440]
CAAM_Type::JOBRING [4]
__IO uint64_t   CAAM_Type::RMA
__IO uint32_t   CAAM_Type::RML
struct {
CAAM_Type::RM [4][2]
__IO uint32_t   CAAM_Type::CC1MR
__IO uint32_t   CAAM_Type::CC1MR_PK
__IO uint32_t   CAAM_Type::CC1MR_RNG
union {
__IO uint32_t   CAAM_Type::CC1KSR
__IO uint64_t   CAAM_Type::CC1DSR
__IO uint32_t   CAAM_Type::CC1ICVSR
uint8_t   CAAM_Type::RESERVED_3 [20]
__O uint32_t   CAAM_Type::CCCTRL
__IO uint32_t   CAAM_Type::CICTL
__O uint32_t   CAAM_Type::CCWR
__I uint32_t   CAAM_Type::CCSTA_MS
__I uint32_t   CAAM_Type::CCSTA_LS
uint8_t   CAAM_Type::RESERVED_6 [12]
__IO uint32_t   CAAM_Type::CC1AADSZR
__IO uint32_t   CAAM_Type::CC1IVSZR
uint8_t   CAAM_Type::RESERVED_8 [28]
__IO uint32_t   CAAM_Type::CPKASZR
__IO uint32_t   CAAM_Type::CPKBSZR
__IO uint32_t   CAAM_Type::CPKNSZR
uint8_t   CAAM_Type::RESERVED_11 [4]
__IO uint32_t   CAAM_Type::CPKESZR
uint8_t   CAAM_Type::RESERVED_12 [96]
__IO uint32_t   CAAM_Type::CC1CTXR [16]
uint8_t   CAAM_Type::RESERVED_13 [192]
__IO uint32_t   CAAM_Type::CC1KR [8]
uint8_t   CAAM_Type::RESERVED_14 [484]
__IO uint32_t   CAAM_Type::CC2MR
__IO uint32_t   CAAM_Type::CC2KSR
__IO uint64_t   CAAM_Type::CC2DSR
uint8_t   CAAM_Type::RESERVED_16 [4]
__IO uint32_t   CAAM_Type::CC2ICVSZR
uint8_t   CAAM_Type::RESERVED_17 [224]
__IO uint32_t   CAAM_Type::CC2CTXR [18]
uint8_t   CAAM_Type::RESERVED_18 [184]
__IO uint32_t   CAAM_Type::CC2KEYR [32]
uint8_t   CAAM_Type::RESERVED_19 [320]
__I uint32_t   CAAM_Type::CFIFOSTA
uint8_t   CAAM_Type::RESERVED_20 [12]
__O uint32_t   CAAM_Type::CNFIFO
__O uint32_t   CAAM_Type::CNFIFO_2
union {
uint8_t   CAAM_Type::RESERVED_21 [12]
__O uint32_t   CAAM_Type::CIFIFO
uint8_t   CAAM_Type::RESERVED_22 [12]
__I uint64_t   CAAM_Type::COFIFO
uint8_t   CAAM_Type::RESERVED_23 [8]
__IO uint32_t   CAAM_Type::DJQCR_MS
__I uint32_t   CAAM_Type::DJQCR_LS
__I uint64_t   CAAM_Type::DDAR
__I uint32_t   CAAM_Type::DOPSTA_MS
__I uint32_t   CAAM_Type::DOPSTA_LS
uint8_t   CAAM_Type::RESERVED_24 [8]
__I uint32_t   CAAM_Type::DPDIDSR
__I uint32_t   CAAM_Type::DODIDSR
uint8_t   CAAM_Type::RESERVED_25 [24]
__IO uint32_t   CAAM_Type::DMTH_MS
__IO uint32_t   CAAM_Type::DMTH_LS
struct {
}   CAAM_Type::DDMTHB [4]
uint8_t   CAAM_Type::RESERVED_26 [32]
__IO uint32_t   CAAM_Type::DGTR_0
__IO uint32_t   CAAM_Type::DGTR_1
__IO uint32_t   CAAM_Type::DGTR_2
__IO uint32_t   CAAM_Type::DGTR_3
struct {
}   CAAM_Type::DDGTR [1]
uint8_t   CAAM_Type::RESERVED_27 [112]
__IO uint32_t   CAAM_Type::DSTR_0
__IO uint32_t   CAAM_Type::DSTR_1
__IO uint32_t   CAAM_Type::DSTR_2
__IO uint32_t   CAAM_Type::DSTR_3
struct {
}   CAAM_Type::DDSTR [1]
uint8_t   CAAM_Type::RESERVED_28 [240]
__IO uint32_t   CAAM_Type::DDESB [64]
uint8_t   CAAM_Type::RESERVED_29 [768]
__I uint32_t   CAAM_Type::DDJR
__I uint32_t   CAAM_Type::DDDR
__I uint64_t   CAAM_Type::DDJP
__I uint64_t   CAAM_Type::DSDP
__I uint32_t   CAAM_Type::DDDR_MS
__I uint32_t   CAAM_Type::DDDR_LS
__IO uint32_t   CAAM_Type::SOL
__IO uint32_t   CAAM_Type::VSOL
__IO uint32_t   CAAM_Type::SIL
__IO uint32_t   CAAM_Type::VSIL
__IO uint32_t   CAAM_Type::DPOVRD
__IO uint32_t   CAAM_Type::UVSOL
__IO uint32_t   CAAM_Type::UVSIL
struct {
   union {
   uint8_t   RESERVED_3 [20]
   uint8_t   RESERVED_6 [12]
   uint8_t   RESERVED_8 [28]
   uint8_t   RESERVED_11 [4]
   uint8_t   RESERVED_12 [96]
   uint8_t   RESERVED_13 [192]
   uint8_t   RESERVED_14 [484]
   uint8_t   RESERVED_16 [4]
   uint8_t   RESERVED_17 [224]
   uint8_t   RESERVED_18 [184]
   uint8_t   RESERVED_19 [320]
   uint8_t   RESERVED_20 [12]
   union {
   uint8_t   RESERVED_21 [12]
   uint8_t   RESERVED_22 [12]
   uint8_t   RESERVED_23 [8]
   uint8_t   RESERVED_24 [8]
   uint8_t   RESERVED_25 [24]
   struct {
   }   DDMTHB [4]
   uint8_t   RESERVED_26 [32]
   struct {
   }   DDGTR [1]
   uint8_t   RESERVED_27 [112]
   struct {
   }   DDSTR [1]
   uint8_t   RESERVED_28 [240]
   uint8_t   RESERVED_29 [768]
CAAM_Type::DC [1]
__IO uint32_t   CAN_Type::CS
__IO uint32_t   CAN_Type::ID
__IO uint32_t   CAN_Type::WORD [2]
struct {
}   CAN_Type::MB_8B [64]
__IO uint32_t   CAN_Type::WORD [4]
struct {
}   CAN_Type::MB_16B_L [21]
uint8_t   CAN_Type::RESERVED_0 [8]
struct {
}   CAN_Type::MB_16B_H [21]
struct {
   struct {
   }   MB_16B_L [21]
   uint8_t   RESERVED_0 [8]
   struct {
   }   MB_16B_H [21]
}   CAN_Type::MB_16B
__IO uint32_t   CAN_Type::WORD [8]
struct {
}   CAN_Type::MB_32B_L [12]
uint8_t   CAN_Type::RESERVED_0 [32]
struct {
}   CAN_Type::MB_32B_H [12]
struct {
   struct {
   }   MB_32B_L [12]
   uint8_t   RESERVED_0 [32]
   struct {
   }   MB_32B_H [12]
}   CAN_Type::MB_32B
__IO uint32_t   CAN_Type::WORD [16]
struct {
}   CAN_Type::MB_64B_L [7]
struct {
}   CAN_Type::MB_64B_H [7]
struct {
   struct {
   }   MB_64B_L [7]
   struct {
   }   MB_64B_H [7]
}   CAN_Type::MB_64B
__IO uint32_t   CAN_Type::WORD0
__IO uint32_t   CAN_Type::WORD1
struct {
}   CAN_Type::MB [64]
union {
   struct {
   }   MB_8B [64]
   struct {
      struct {
      }   MB_16B_L [21]
      struct {
      }   MB_16B_H [21]
   }   MB_16B
   struct {
      struct {
      }   MB_32B_L [12]
      struct {
      }   MB_32B_H [12]
   }   MB_32B
   struct {
      struct {
      }   MB_64B_L [7]
      struct {
      }   MB_64B_H [7]
   }   MB_64B
   struct {
   }   MB [64]
__IO uint32_t   CCM_Type::CONTROL
__IO uint32_t   CCM_Type::CONTROL_SET
__IO uint32_t   CCM_Type::CONTROL_CLR
__IO uint32_t   CCM_Type::CONTROL_TOG
uint8_t   CCM_Type::RESERVED_0 [16]
__I uint32_t   CCM_Type::STATUS0
__I uint32_t   CCM_Type::STATUS1
uint8_t   CCM_Type::RESERVED_1 [4]
__I uint32_t   CCM_Type::CONFIG
__IO uint32_t   CCM_Type::AUTHEN
__IO uint32_t   CCM_Type::AUTHEN_SET
__IO uint32_t   CCM_Type::AUTHEN_CLR
__IO uint32_t   CCM_Type::AUTHEN_TOG
__IO uint32_t   CCM_Type::SETPOINT [16]
struct {
   uint8_t   RESERVED_0 [16]
CCM_Type::CLOCK_ROOT [79]
__IO uint32_t   CCM_Type::STATUS0
struct {
CCM_Type::CLOCK_GROUP [2]
__IO uint32_t   CCM_Type::GPR_SHARED
__IO uint32_t   CCM_Type::CLR
__IO uint32_t   CCM_Type::TOG
struct {
CCM_Type::GPR_SHARED [8]
__IO uint32_t   CCM_Type::DIRECT
__IO uint32_t   CCM_Type::DOMAINr
uint8_t   CCM_Type::RESERVED_0 [4]
struct {
CCM_Type::OSCPLL [29]
struct {
CCM_Type::LPCG [138]
__IO uint32_t   CCM_OBS_Type::CONTROL
__IO uint32_t   CCM_OBS_Type::CONTROL_SET
__IO uint32_t   CCM_OBS_Type::CONTROL_CLR
__IO uint32_t   CCM_OBS_Type::CONTROL_TOG
uint8_t   CCM_OBS_Type::RESERVED_0 [16]
__I uint32_t   CCM_OBS_Type::STATUS0
uint8_t   CCM_OBS_Type::RESERVED_1 [12]
__IO uint32_t   CCM_OBS_Type::AUTHEN
__IO uint32_t   CCM_OBS_Type::AUTHEN_SET
__IO uint32_t   CCM_OBS_Type::AUTHEN_CLR
__IO uint32_t   CCM_OBS_Type::AUTHEN_TOG
__I uint32_t   CCM_OBS_Type::FREQUENCY_CURRENT
__I uint32_t   CCM_OBS_Type::FREQUENCY_MIN
__I uint32_t   CCM_OBS_Type::FREQUENCY_MAX
uint8_t   CCM_OBS_Type::RESERVED_2 [52]
struct {
   uint8_t   RESERVED_2 [52]
CCM_OBS_Type::OBSERVE [6]
__IO uint32_t   DCIC_Type::DCICRC
__IO uint32_t   DCIC_Type::DCICRS
__IO uint32_t   DCIC_Type::DCICRRS
__I uint32_t   DCIC_Type::DCICRCS
struct {
DCIC_Type::REGION [16]
__IO uint32_t   DMA_Type::SADDR
__IO uint16_t   DMA_Type::SOFF
__IO uint16_t   DMA_Type::ATTR
__IO uint32_t   DMA_Type::NBYTES_MLNO
__IO uint32_t   DMA_Type::NBYTES_MLOFFNO
__IO uint32_t   DMA_Type::NBYTES_MLOFFYES
union {
__IO int32_t   DMA_Type::SLAST
__IO uint32_t   DMA_Type::DADDR
__IO uint16_t   DMA_Type::DOFF
__IO uint16_t   DMA_Type::CITER_ELINKNO
__IO uint16_t   DMA_Type::CITER_ELINKYES
union {
__IO int32_t   DMA_Type::DLAST_SGA
__IO uint16_t   DMA_Type::CSR
__IO uint16_t   DMA_Type::BITER_ELINKNO
__IO uint16_t   DMA_Type::BITER_ELINKYES
union {
struct {
   union {
   union {
   union {
DMA_Type::TCD [32]
struct {
struct {
struct {
struct {
struct {
struct {
IEE_Type::REGX [8]
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
OTFAD_Type::CTX [4]
struct {
PHY_LDO_Type::CTRL0
struct {
PHY_LDO_Type::STAT0
struct {
struct {
PWM_Type::SM [4]
struct {
RDC_Type::MR [59]
union {
struct {
struct {
union {
struct {
struct {
struct {
union {
union {
union {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
struct {
Mapping Information
Typedef Documentation
◆ iomuxc_select_input_t [1/3]
Enumeration for the IOMUXC select input.
Defines the enumeration for the IOMUXC select input collections.
◆ iomuxc_select_input_t [2/3]
◆ iomuxc_select_input_t [3/3]
◆ iomuxc_sw_mux_ctl_pad_t [1/3]
Enumeration for the IOMUXC SW_MUX_CTL_PAD.
Defines the enumeration for the IOMUXC SW_MUX_CTL_PAD collections.
◆ iomuxc_sw_mux_ctl_pad_t [2/3]
◆ iomuxc_sw_mux_ctl_pad_t [3/3]
◆ iomuxc_sw_pad_ctl_pad_t [1/3]
Enumeration for the IOMUXC SW_PAD_CTL_PAD.
Defines the enumeration for the IOMUXC SW_PAD_CTL_PAD collections.
◆ iomuxc_sw_pad_ctl_pad_t [2/3]
◆ iomuxc_sw_pad_ctl_pad_t [3/3]
◆ _iomuxc_select_input [1/3]
kIOMUXC_ANATOP_USB_OTG1_ID_SELECT_INPUT
IOMUXC select input index
kIOMUXC_ANATOP_USB_OTG2_ID_SELECT_INPUT
kIOMUXC_CCM_PMIC_READY_SELECT_INPUT
kIOMUXC_CSI_DATA02_SELECT_INPUT
kIOMUXC_CSI_DATA03_SELECT_INPUT
kIOMUXC_CSI_DATA04_SELECT_INPUT
kIOMUXC_CSI_DATA05_SELECT_INPUT
kIOMUXC_CSI_DATA06_SELECT_INPUT
kIOMUXC_CSI_DATA07_SELECT_INPUT
kIOMUXC_CSI_DATA08_SELECT_INPUT
kIOMUXC_CSI_DATA09_SELECT_INPUT
kIOMUXC_CSI_HSYNC_SELECT_INPUT
kIOMUXC_CSI_PIXCLK_SELECT_INPUT
kIOMUXC_CSI_VSYNC_SELECT_INPUT
kIOMUXC_ENET_IPG_CLK_RMII_SELECT_INPUT
kIOMUXC_ENET_MDIO_SELECT_INPUT
kIOMUXC_ENET0_RXDATA_SELECT_INPUT
kIOMUXC_ENET1_RXDATA_SELECT_INPUT
kIOMUXC_ENET_RXEN_SELECT_INPUT
kIOMUXC_ENET_RXERR_SELECT_INPUT
kIOMUXC_ENET0_TIMER_SELECT_INPUT
kIOMUXC_ENET_TXCLK_SELECT_INPUT
kIOMUXC_FLEXCAN1_RX_SELECT_INPUT
kIOMUXC_FLEXCAN2_RX_SELECT_INPUT
kIOMUXC_FLEXPWM1_PWMA3_SELECT_INPUT
kIOMUXC_FLEXPWM1_PWMA0_SELECT_INPUT
kIOMUXC_FLEXPWM1_PWMA1_SELECT_INPUT
kIOMUXC_FLEXPWM1_PWMA2_SELECT_INPUT
kIOMUXC_FLEXPWM1_PWMB3_SELECT_INPUT
kIOMUXC_FLEXPWM1_PWMB0_SELECT_INPUT
kIOMUXC_FLEXPWM1_PWMB1_SELECT_INPUT
kIOMUXC_FLEXPWM1_PWMB2_SELECT_INPUT
kIOMUXC_FLEXPWM2_PWMA3_SELECT_INPUT
kIOMUXC_FLEXPWM2_PWMA0_SELECT_INPUT
kIOMUXC_FLEXPWM2_PWMA1_SELECT_INPUT
kIOMUXC_FLEXPWM2_PWMA2_SELECT_INPUT
kIOMUXC_FLEXPWM2_PWMB3_SELECT_INPUT
kIOMUXC_FLEXPWM2_PWMB0_SELECT_INPUT
kIOMUXC_FLEXPWM2_PWMB1_SELECT_INPUT
kIOMUXC_FLEXPWM2_PWMB2_SELECT_INPUT
kIOMUXC_FLEXPWM4_PWMA0_SELECT_INPUT
kIOMUXC_FLEXPWM4_PWMA1_SELECT_INPUT
kIOMUXC_FLEXPWM4_PWMA2_SELECT_INPUT
kIOMUXC_FLEXPWM4_PWMA3_SELECT_INPUT
kIOMUXC_FLEXSPI_A_DQS_SELECT_INPUT
kIOMUXC_FLEXSPI_A_DATA0_SELECT_INPUT
kIOMUXC_FLEXSPI_A_DATA1_SELECT_INPUT
kIOMUXC_FLEXSPI_A_DATA2_SELECT_INPUT
kIOMUXC_FLEXSPI_A_DATA3_SELECT_INPUT
kIOMUXC_FLEXSPI_B_DATA0_SELECT_INPUT
kIOMUXC_FLEXSPI_B_DATA1_SELECT_INPUT
kIOMUXC_FLEXSPI_B_DATA2_SELECT_INPUT
kIOMUXC_FLEXSPI_B_DATA3_SELECT_INPUT
kIOMUXC_FLEXSPI_A_SCK_SELECT_INPUT
kIOMUXC_LPI2C1_SCL_SELECT_INPUT
kIOMUXC_LPI2C1_SDA_SELECT_INPUT
kIOMUXC_LPI2C2_SCL_SELECT_INPUT
kIOMUXC_LPI2C2_SDA_SELECT_INPUT
kIOMUXC_LPI2C3_SCL_SELECT_INPUT
kIOMUXC_LPI2C3_SDA_SELECT_INPUT
kIOMUXC_LPI2C4_SCL_SELECT_INPUT
kIOMUXC_LPI2C4_SDA_SELECT_INPUT
kIOMUXC_LPSPI1_PCS0_SELECT_INPUT
kIOMUXC_LPSPI1_SCK_SELECT_INPUT
kIOMUXC_LPSPI1_SDI_SELECT_INPUT
kIOMUXC_LPSPI1_SDO_SELECT_INPUT
kIOMUXC_LPSPI2_PCS0_SELECT_INPUT
kIOMUXC_LPSPI2_SCK_SELECT_INPUT
kIOMUXC_LPSPI2_SDI_SELECT_INPUT
kIOMUXC_LPSPI2_SDO_SELECT_INPUT
kIOMUXC_LPSPI3_PCS0_SELECT_INPUT
kIOMUXC_LPSPI3_SCK_SELECT_INPUT
kIOMUXC_LPSPI3_SDI_SELECT_INPUT
kIOMUXC_LPSPI3_SDO_SELECT_INPUT
kIOMUXC_LPSPI4_PCS0_SELECT_INPUT
kIOMUXC_LPSPI4_SCK_SELECT_INPUT
kIOMUXC_LPSPI4_SDI_SELECT_INPUT
kIOMUXC_LPSPI4_SDO_SELECT_INPUT
kIOMUXC_LPUART2_RX_SELECT_INPUT
kIOMUXC_LPUART2_TX_SELECT_INPUT
kIOMUXC_LPUART3_CTS_B_SELECT_INPUT
kIOMUXC_LPUART3_RX_SELECT_INPUT
kIOMUXC_LPUART3_TX_SELECT_INPUT
kIOMUXC_LPUART4_RX_SELECT_INPUT
kIOMUXC_LPUART4_TX_SELECT_INPUT
kIOMUXC_LPUART5_RX_SELECT_INPUT
kIOMUXC_LPUART5_TX_SELECT_INPUT
kIOMUXC_LPUART6_RX_SELECT_INPUT
kIOMUXC_LPUART6_TX_SELECT_INPUT
kIOMUXC_LPUART7_RX_SELECT_INPUT
kIOMUXC_LPUART7_TX_SELECT_INPUT
kIOMUXC_LPUART8_RX_SELECT_INPUT
kIOMUXC_LPUART8_TX_SELECT_INPUT
kIOMUXC_NMI_SELECT_INPUT
kIOMUXC_QTIMER2_TIMER0_SELECT_INPUT
kIOMUXC_QTIMER2_TIMER1_SELECT_INPUT
kIOMUXC_QTIMER2_TIMER2_SELECT_INPUT
kIOMUXC_QTIMER2_TIMER3_SELECT_INPUT
kIOMUXC_QTIMER3_TIMER0_SELECT_INPUT
kIOMUXC_QTIMER3_TIMER1_SELECT_INPUT
kIOMUXC_QTIMER3_TIMER2_SELECT_INPUT
kIOMUXC_QTIMER3_TIMER3_SELECT_INPUT
kIOMUXC_SAI1_MCLK2_SELECT_INPUT
kIOMUXC_SAI1_RX_BCLK_SELECT_INPUT
kIOMUXC_SAI1_RX_DATA0_SELECT_INPUT
kIOMUXC_SAI1_RX_DATA1_SELECT_INPUT
kIOMUXC_SAI1_RX_DATA2_SELECT_INPUT
kIOMUXC_SAI1_RX_DATA3_SELECT_INPUT
kIOMUXC_SAI1_RX_SYNC_SELECT_INPUT
kIOMUXC_SAI1_TX_BCLK_SELECT_INPUT
kIOMUXC_SAI1_TX_SYNC_SELECT_INPUT
kIOMUXC_SAI2_MCLK2_SELECT_INPUT
kIOMUXC_SAI2_RX_BCLK_SELECT_INPUT
kIOMUXC_SAI2_RX_DATA0_SELECT_INPUT
kIOMUXC_SAI2_RX_SYNC_SELECT_INPUT
kIOMUXC_SAI2_TX_BCLK_SELECT_INPUT
kIOMUXC_SAI2_TX_SYNC_SELECT_INPUT
kIOMUXC_SPDIF_IN_SELECT_INPUT
kIOMUXC_USB_OTG2_OC_SELECT_INPUT
kIOMUXC_USB_OTG1_OC_SELECT_INPUT
kIOMUXC_USDHC1_CD_B_SELECT_INPUT
kIOMUXC_USDHC1_WP_SELECT_INPUT
kIOMUXC_USDHC2_CLK_SELECT_INPUT
kIOMUXC_USDHC2_CD_B_SELECT_INPUT
kIOMUXC_USDHC2_CMD_SELECT_INPUT
kIOMUXC_USDHC2_DATA0_SELECT_INPUT
kIOMUXC_USDHC2_DATA1_SELECT_INPUT
kIOMUXC_USDHC2_DATA2_SELECT_INPUT
kIOMUXC_USDHC2_DATA3_SELECT_INPUT
kIOMUXC_USDHC2_DATA4_SELECT_INPUT
kIOMUXC_USDHC2_DATA5_SELECT_INPUT
kIOMUXC_USDHC2_DATA6_SELECT_INPUT
kIOMUXC_USDHC2_DATA7_SELECT_INPUT
kIOMUXC_USDHC2_WP_SELECT_INPUT
kIOMUXC_XBAR_INOUT02_SELECT_INPUT
kIOMUXC_XBAR_INOUT03_SELECT_INPUT
kIOMUXC_XBAR_INOUT04_SELECT_INPUT
kIOMUXC_XBAR_INOUT05_SELECT_INPUT
kIOMUXC_XBAR_INOUT06_SELECT_INPUT
kIOMUXC_XBAR_INOUT07_SELECT_INPUT
kIOMUXC_XBAR_INOUT08_SELECT_INPUT
kIOMUXC_XBAR_INOUT09_SELECT_INPUT
kIOMUXC_XBAR_INOUT17_SELECT_INPUT
kIOMUXC_XBAR_INOUT18_SELECT_INPUT
kIOMUXC_XBAR_INOUT20_SELECT_INPUT
kIOMUXC_XBAR_INOUT22_SELECT_INPUT
kIOMUXC_XBAR_INOUT23_SELECT_INPUT
kIOMUXC_XBAR_INOUT24_SELECT_INPUT
kIOMUXC_XBAR_INOUT14_SELECT_INPUT
kIOMUXC_XBAR_INOUT15_SELECT_INPUT
kIOMUXC_XBAR_INOUT16_SELECT_INPUT
kIOMUXC_XBAR_INOUT25_SELECT_INPUT
kIOMUXC_XBAR_INOUT19_SELECT_INPUT
kIOMUXC_XBAR_INOUT21_SELECT_INPUT
kIOMUXC_ENET_MAC0_MDIO_SELECT_INPUT
kIOMUXC_ENET_MAC0_RXDATA_SELECT_INPUT_0
kIOMUXC_ENET_MAC0_RXDATA_SELECT_INPUT_1
kIOMUXC_ENET_MAC0_RXEN_SELECT_INPUT
kIOMUXC_ENET_MAC0_RXERR_SELECT_INPUT
kIOMUXC_ENET_MAC0_TXCLK_SELECT_INPUT
kIOMUXC_ENET_1G_IPG_CLK_RMII_SELECT_INPUT
kIOMUXC_ENET_1G_MAC0_MDIO_SELECT_INPUT
kIOMUXC_ENET_1G_MAC0_RXCLK_SELECT_INPUT
kIOMUXC_ENET_1G_MAC0_RXDATA_0_SELECT_INPUT
kIOMUXC_ENET_1G_MAC0_RXDATA_1_SELECT_INPUT
kIOMUXC_ENET_1G_MAC0_RXDATA_2_SELECT_INPUT
kIOMUXC_ENET_1G_MAC0_RXDATA_3_SELECT_INPUT
kIOMUXC_ENET_1G_MAC0_RXEN_SELECT_INPUT
kIOMUXC_ENET_1G_MAC0_RXERR_SELECT_INPUT
kIOMUXC_ENET_1G_MAC0_TXCLK_SELECT_INPUT
kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_0
kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_1
kIOMUXC_FLEXPWM1_PWMA_SELECT_INPUT_2
kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_0
kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_1
kIOMUXC_FLEXPWM1_PWMB_SELECT_INPUT_2
kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_0
kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_1
kIOMUXC_FLEXPWM2_PWMA_SELECT_INPUT_2
kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_0
kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_1
kIOMUXC_FLEXPWM2_PWMB_SELECT_INPUT_2
kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_0
kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_1
kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_2
kIOMUXC_FLEXPWM3_PWMA_SELECT_INPUT_3
kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_0
kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_1
kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_2
kIOMUXC_FLEXPWM3_PWMB_SELECT_INPUT_3
kIOMUXC_FLEXSPI1_I_DQS_FA_SELECT_INPUT
kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_0
kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_1
kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_2
kIOMUXC_FLEXSPI1_I_IO_FA_SELECT_INPUT_3
kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_0
kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_1
kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_2
kIOMUXC_FLEXSPI1_I_IO_FB_SELECT_INPUT_3
kIOMUXC_FLEXSPI1_I_SCK_FA_SELECT_INPUT
kIOMUXC_FLEXSPI1_I_SCK_FB_SELECT_INPUT
kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_0
kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_1
kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_2
kIOMUXC_FLEXSPI2_I_IO_FA_SELECT_INPUT_3
kIOMUXC_FLEXSPI2_I_SCK_FA_SELECT_INPUT
kIOMUXC_GPT3_CAPIN1_SELECT_INPUT
kIOMUXC_GPT3_CAPIN2_SELECT_INPUT
kIOMUXC_GPT3_CLKIN_SELECT_INPUT
kIOMUXC_KPP_COL_SELECT_INPUT_6
kIOMUXC_KPP_COL_SELECT_INPUT_7
kIOMUXC_KPP_ROW_SELECT_INPUT_6
kIOMUXC_KPP_ROW_SELECT_INPUT_7
kIOMUXC_LPI2C1_LPI2C_SCL_SELECT_INPUT
kIOMUXC_LPI2C1_LPI2C_SDA_SELECT_INPUT
kIOMUXC_LPI2C2_LPI2C_SCL_SELECT_INPUT
kIOMUXC_LPI2C2_LPI2C_SDA_SELECT_INPUT
kIOMUXC_LPI2C3_LPI2C_SCL_SELECT_INPUT
kIOMUXC_LPI2C3_LPI2C_SDA_SELECT_INPUT
kIOMUXC_LPI2C4_LPI2C_SCL_SELECT_INPUT
kIOMUXC_LPI2C4_LPI2C_SDA_SELECT_INPUT
kIOMUXC_LPSPI1_LPSPI_PCS_SELECT_INPUT_0
kIOMUXC_LPSPI1_LPSPI_SCK_SELECT_INPUT
kIOMUXC_LPSPI1_LPSPI_SDI_SELECT_INPUT
kIOMUXC_LPSPI1_LPSPI_SDO_SELECT_INPUT
kIOMUXC_LPSPI2_LPSPI_PCS_SELECT_INPUT_0
kIOMUXC_LPSPI2_LPSPI_PCS_SELECT_INPUT_1
kIOMUXC_LPSPI2_LPSPI_SCK_SELECT_INPUT
kIOMUXC_LPSPI2_LPSPI_SDI_SELECT_INPUT
kIOMUXC_LPSPI2_LPSPI_SDO_SELECT_INPUT
kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_0
kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_1
kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_2
kIOMUXC_LPSPI3_LPSPI_PCS_SELECT_INPUT_3
kIOMUXC_LPSPI3_LPSPI_SCK_SELECT_INPUT
kIOMUXC_LPSPI3_LPSPI_SDI_SELECT_INPUT
kIOMUXC_LPSPI3_LPSPI_SDO_SELECT_INPUT
kIOMUXC_LPSPI4_LPSPI_PCS_SELECT_INPUT_0
kIOMUXC_LPSPI4_LPSPI_SCK_SELECT_INPUT
kIOMUXC_LPSPI4_LPSPI_SDI_SELECT_INPUT
kIOMUXC_LPSPI4_LPSPI_SDO_SELECT_INPUT
kIOMUXC_LPUART1_LPUART_RXD_SELECT_INPUT
kIOMUXC_LPUART1_LPUART_TXD_SELECT_INPUT
kIOMUXC_LPUART10_LPUART_RXD_SELECT_INPUT
kIOMUXC_LPUART10_LPUART_TXD_SELECT_INPUT
kIOMUXC_LPUART7_LPUART_RXD_SELECT_INPUT
kIOMUXC_LPUART7_LPUART_TXD_SELECT_INPUT
kIOMUXC_LPUART8_LPUART_RXD_SELECT_INPUT
kIOMUXC_LPUART8_LPUART_TXD_SELECT_INPUT
kIOMUXC_QTIMER1_TMR0_INPUT_SELECT_INPUT
kIOMUXC_QTIMER1_TMR1_INPUT_SELECT_INPUT
kIOMUXC_QTIMER1_TMR2_INPUT_SELECT_INPUT
kIOMUXC_QTIMER2_TMR0_INPUT_SELECT_INPUT
kIOMUXC_QTIMER2_TMR1_INPUT_SELECT_INPUT
kIOMUXC_QTIMER2_TMR2_INPUT_SELECT_INPUT
kIOMUXC_QTIMER3_TMR0_INPUT_SELECT_INPUT
kIOMUXC_QTIMER3_TMR1_INPUT_SELECT_INPUT
kIOMUXC_QTIMER3_TMR2_INPUT_SELECT_INPUT
kIOMUXC_QTIMER4_TMR0_INPUT_SELECT_INPUT
kIOMUXC_QTIMER4_TMR1_INPUT_SELECT_INPUT
kIOMUXC_QTIMER4_TMR2_INPUT_SELECT_INPUT
kIOMUXC_SAI1_IPG_CLK_SAI_MCLK_SELECT_INPUT
kIOMUXC_SAI1_SAI_RXBCLK_SELECT_INPUT
kIOMUXC_SAI1_SAI_RXDATA_SELECT_INPUT_0
kIOMUXC_SAI1_SAI_RXSYNC_SELECT_INPUT
kIOMUXC_SAI1_SAI_TXBCLK_SELECT_INPUT
kIOMUXC_SAI1_SAI_TXSYNC_SELECT_INPUT
kIOMUXC_EMVSIM1_SIO_SELECT_INPUT
kIOMUXC_EMVSIM1_IPP_SIMPD_SELECT_INPUT
kIOMUXC_EMVSIM1_POWER_FAIL_SELECT_INPUT
kIOMUXC_EMVSIM2_SIO_SELECT_INPUT
kIOMUXC_EMVSIM2_IPP_SIMPD_SELECT_INPUT
kIOMUXC_EMVSIM2_POWER_FAIL_SELECT_INPUT
kIOMUXC_SPDIF_SPDIF_IN1_SELECT_INPUT
kIOMUXC_USB_OTG_OC_SELECT_INPUT
kIOMUXC_USBPHY1_USB_ID_SELECT_INPUT
kIOMUXC_USBPHY2_USB_ID_SELECT_INPUT
kIOMUXC_USDHC1_IPP_CARD_DET_SELECT_INPUT
kIOMUXC_USDHC1_IPP_WP_ON_SELECT_INPUT
kIOMUXC_USDHC2_IPP_CARD_DET_SELECT_INPUT
kIOMUXC_USDHC2_IPP_WP_ON_SELECT_INPUT
kIOMUXC_XBAR1_IN_SELECT_INPUT_20
kIOMUXC_XBAR1_IN_SELECT_INPUT_21
kIOMUXC_XBAR1_IN_SELECT_INPUT_22
kIOMUXC_XBAR1_IN_SELECT_INPUT_23
kIOMUXC_XBAR1_IN_SELECT_INPUT_24
kIOMUXC_XBAR1_IN_SELECT_INPUT_25
kIOMUXC_XBAR1_IN_SELECT_INPUT_26
kIOMUXC_XBAR1_IN_SELECT_INPUT_27
kIOMUXC_XBAR1_IN_SELECT_INPUT_28
kIOMUXC_XBAR1_IN_SELECT_INPUT_29
kIOMUXC_XBAR1_IN_SELECT_INPUT_30
kIOMUXC_XBAR1_IN_SELECT_INPUT_31
kIOMUXC_XBAR1_IN_SELECT_INPUT_32
kIOMUXC_XBAR1_IN_SELECT_INPUT_33
kIOMUXC_XBAR1_IN_SELECT_INPUT_34
kIOMUXC_XBAR1_IN_SELECT_INPUT_35
◆ _iomuxc_select_input [2/3]
◆ _iomuxc_select_input [3/3]
◆ _iomuxc_sw_mux_ctl_pad [1/3]
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_00
IOMUXC SW_MUX_CTL_PAD index
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_12
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_13
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_14
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_15
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_16
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_17
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_18
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_19
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_20
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_21
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_22
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_23
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_24
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_25
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_26
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_27
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_28
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_29
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_30
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_31
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_32
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_33
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_34
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_35
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_36
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_37
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_38
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_39
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_40
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_41
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_12
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_13
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_14
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_15
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_12
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_13
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_14
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_15
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_12
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_13
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_14
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B0_15
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_12
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_13
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_14
kIOMUXC_SW_MUX_CTL_PAD_GPIO_B1_15
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B1_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_12
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_13
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_14
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_15
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_16
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_17
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_18
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_19
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_20
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_21
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_22
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_23
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_24
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_25
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_26
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_27
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_28
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_29
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_30
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_31
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_32
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_33
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_34
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_35
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_36
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_37
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_38
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_39
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_40
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B1_41
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_12
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_13
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_14
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_15
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_16
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_17
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_18
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_19
kIOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_B2_20
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_12
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_13
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_14
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_15
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_16
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_17
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_18
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_19
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_20
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_21
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_22
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_23
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_24
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_25
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_26
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_27
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_28
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_29
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_30
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_31
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_32
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_33
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_34
kIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_35
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B2_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B1_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_00
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_01
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_02
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_03
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_04
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_05
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_06
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_07
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_08
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_09
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_10
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_11
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_12
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_13
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_14
kIOMUXC_SW_MUX_CTL_PAD_GPIO_DISP_B2_15
◆ _iomuxc_sw_mux_ctl_pad [2/3]
◆ _iomuxc_sw_mux_ctl_pad [3/3]
◆ _iomuxc_sw_pad_ctl_pad [1/3]
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_00
IOMUXC SW_PAD_CTL_PAD index
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_12
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_13
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_14
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_15
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_16
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_17
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_18
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_19
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_20
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_21
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_22
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_23
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_24
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_25
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_26
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_27
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_28
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_29
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_30
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_31
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_32
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_33
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_34
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_35
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_36
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_37
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_38
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_39
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_40
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_41
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_12
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_13
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_14
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_15
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_12
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_13
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_14
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_15
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_12
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_13
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_14
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B0_15
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_12
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_13
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_14
kIOMUXC_SW_PAD_CTL_PAD_GPIO_B1_15
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B1_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_12
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_13
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_14
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_15
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_16
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_17
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_18
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_19
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_20
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_21
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_22
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_23
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_24
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_25
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_26
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_27
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_28
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_29
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_30
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_31
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_32
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_33
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_34
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_35
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_36
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_37
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_38
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_39
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_40
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B1_41
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_12
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_13
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_14
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_15
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_16
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_17
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_18
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_19
kIOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_B2_20
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_12
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_13
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_14
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_15
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_16
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_17
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_18
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_19
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_20
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_21
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_22
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_23
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_24
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_25
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_26
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_27
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_28
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_29
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_30
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_31
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_32
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_33
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_34
kIOMUXC_SW_PAD_CTL_PAD_GPIO_AD_35
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B2_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B1_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_00
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_01
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_02
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_03
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_04
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_05
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_06
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_07
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_08
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_09
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_10
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_11
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_12
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_13
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_14
kIOMUXC_SW_PAD_CTL_PAD_GPIO_DISP_B2_15
◆ _iomuxc_sw_pad_ctl_pad [2/3]
◆ _iomuxc_sw_pad_ctl_pad [3/3]
◆ _xbar_input_signal
kXBARA1_InputLogicLow
LOGIC_LOW output assigned to XBARA1_IN0 input.
kXBARA1_InputLogicHigh
LOGIC_HIGH output assigned to XBARA1_IN1 input.
kXBARA1_InputIomuxXbarIn02
IOMUX_XBAR_IN02 output assigned to XBARA1_IN2 input.
kXBARA1_InputIomuxXbarIn03
IOMUX_XBAR_IN03 output assigned to XBARA1_IN3 input.
kXBARA1_InputIomuxXbarInout04
IOMUX_XBAR_INOUT04 output assigned to XBARA1_IN4 input.
kXBARA1_InputIomuxXbarInout05
IOMUX_XBAR_INOUT05 output assigned to XBARA1_IN5 input.
kXBARA1_InputIomuxXbarInout06
IOMUX_XBAR_INOUT06 output assigned to XBARA1_IN6 input.
kXBARA1_InputIomuxXbarInout07
IOMUX_XBAR_INOUT07 output assigned to XBARA1_IN7 input.
kXBARA1_InputIomuxXbarInout08
IOMUX_XBAR_INOUT08 output assigned to XBARA1_IN8 input.
kXBARA1_InputIomuxXbarInout09
IOMUX_XBAR_INOUT09 output assigned to XBARA1_IN9 input.
kXBARA1_InputIomuxXbarInout10
IOMUX_XBAR_INOUT10 output assigned to XBARA1_IN10 input.
kXBARA1_InputIomuxXbarInout11
IOMUX_XBAR_INOUT11 output assigned to XBARA1_IN11 input.
kXBARA1_InputIomuxXbarInout12
IOMUX_XBAR_INOUT12 output assigned to XBARA1_IN12 input.
kXBARA1_InputIomuxXbarInout13
IOMUX_XBAR_INOUT13 output assigned to XBARA1_IN13 input.
kXBARA1_InputIomuxXbarInout14
IOMUX_XBAR_INOUT14 output assigned to XBARA1_IN14 input.
kXBARA1_InputIomuxXbarInout15
IOMUX_XBAR_INOUT15 output assigned to XBARA1_IN15 input.
kXBARA1_InputIomuxXbarInout16
IOMUX_XBAR_INOUT16 output assigned to XBARA1_IN16 input.
kXBARA1_InputIomuxXbarInout17
IOMUX_XBAR_INOUT17 output assigned to XBARA1_IN17 input.
kXBARA1_InputIomuxXbarInout18
IOMUX_XBAR_INOUT18 output assigned to XBARA1_IN18 input.
kXBARA1_InputIomuxXbarInout19
IOMUX_XBAR_INOUT19 output assigned to XBARA1_IN19 input.
kXBARA1_InputIomuxXbarIn20
IOMUX_XBAR_IN20 output assigned to XBARA1_IN20 input.
kXBARA1_InputIomuxXbarIn21
IOMUX_XBAR_IN21 output assigned to XBARA1_IN21 input.
kXBARA1_InputIomuxXbarIn22
IOMUX_XBAR_IN22 output assigned to XBARA1_IN22 input.
kXBARA1_InputIomuxXbarIn23
IOMUX_XBAR_IN23 output assigned to XBARA1_IN23 input.
kXBARA1_InputIomuxXbarIn24
IOMUX_XBAR_IN24 output assigned to XBARA1_IN24 input.
kXBARA1_InputIomuxXbarIn25
IOMUX_XBAR_IN25 output assigned to XBARA1_IN25 input.
kXBARA1_InputAcmp1Out
ACMP1_OUT output assigned to XBARA1_IN26 input.
kXBARA1_InputAcmp2Out
ACMP2_OUT output assigned to XBARA1_IN27 input.
kXBARA1_InputAcmp3Out
ACMP3_OUT output assigned to XBARA1_IN28 input.
kXBARA1_InputAcmp4Out
ACMP4_OUT output assigned to XBARA1_IN29 input.
kXBARA1_InputRESERVED30
XBARA1_IN30 input is reserved.
kXBARA1_InputRESERVED31
XBARA1_IN31 input is reserved.
kXBARA1_InputQtimer3Tmr0Output
QTIMER3_TMR0_OUTPUT output assigned to XBARA1_IN32 input.
kXBARA1_InputQtimer3Tmr1Output
QTIMER3_TMR1_OUTPUT output assigned to XBARA1_IN33 input.
kXBARA1_InputQtimer3Tmr2Output
QTIMER3_TMR2_OUTPUT output assigned to XBARA1_IN34 input.
kXBARA1_InputQtimer3Tmr3Output
QTIMER3_TMR3_OUTPUT output assigned to XBARA1_IN35 input.
kXBARA1_InputQtimer4Tmr0Output
QTIMER4_TMR0_OUTPUT output assigned to XBARA1_IN36 input.
kXBARA1_InputQtimer4Tmr1Output
QTIMER4_TMR1_OUTPUT output assigned to XBARA1_IN37 input.
kXBARA1_InputQtimer4Tmr2Output
QTIMER4_TMR2_OUTPUT output assigned to XBARA1_IN38 input.
kXBARA1_InputQtimer4Tmr3Output
QTIMER4_TMR3_OUTPUT output assigned to XBARA1_IN39 input.
kXBARA1_InputFlexpwm1Pwm1OutTrig01
FLEXPWM1_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN40 input.
kXBARA1_InputFlexpwm1Pwm2OutTrig01
FLEXPWM1_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN41 input.
kXBARA1_InputFlexpwm1Pwm3OutTrig01
FLEXPWM1_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN42 input.
kXBARA1_InputFlexpwm1Pwm4OutTrig01
FLEXPWM1_PWM4_OUT_TRIG0_1 output assigned to XBARA1_IN43 input.
kXBARA1_InputFlexpwm2Pwm1OutTrig01
FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN44 input.
kXBARA1_InputFlexpwm2Pwm2OutTrig01
FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN45 input.
kXBARA1_InputFlexpwm2Pwm3OutTrig01
FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN46 input.
kXBARA1_InputFlexpwm2Pwm4OutTrig01
FLEXPWM2_PWM4_OUT_TRIG0_1 output assigned to XBARA1_IN47 input.
kXBARA1_InputFlexpwm3Pwm1OutTrig01
FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN48 input.
kXBARA1_InputFlexpwm3Pwm2OutTrig01
FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN49 input.
kXBARA1_InputFlexpwm3Pwm3OutTrig01
FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN50 input.
kXBARA1_InputFlexpwm3Pwm4OutTrig01
FLEXPWM3_PWM4_OUT_TRIG0_1 output assigned to XBARA1_IN51 input.
kXBARA1_InputFlexpwm4Pwm1OutTrig01
FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN52 input.
kXBARA1_InputFlexpwm4Pwm2OutTrig01
FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN53 input.
kXBARA1_InputFlexpwm4Pwm3OutTrig01
FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN54 input.
kXBARA1_InputFlexpwm4Pwm4OutTrig01
FLEXPWM4_PWM4_OUT_TRIG0_1 output assigned to XBARA1_IN55 input.
kXBARA1_InputPitTrigger0
PIT_TRIGGER0 output assigned to XBARA1_IN56 input.
kXBARA1_InputPitTrigger1
PIT_TRIGGER1 output assigned to XBARA1_IN57 input.
kXBARA1_InputPitTrigger2
PIT_TRIGGER2 output assigned to XBARA1_IN58 input.
kXBARA1_InputPitTrigger3
PIT_TRIGGER3 output assigned to XBARA1_IN59 input.
kXBARA1_InputEnc1PosMatch
ENC1_POS_MATCH output assigned to XBARA1_IN60 input.
kXBARA1_InputEnc2PosMatch
ENC2_POS_MATCH output assigned to XBARA1_IN61 input.
kXBARA1_InputEnc3PosMatch
ENC3_POS_MATCH output assigned to XBARA1_IN62 input.
kXBARA1_InputEnc4PosMatch
ENC4_POS_MATCH output assigned to XBARA1_IN63 input.
kXBARA1_InputDmaDone0
DMA_DONE0 output assigned to XBARA1_IN64 input.
kXBARA1_InputDmaDone1
DMA_DONE1 output assigned to XBARA1_IN65 input.
kXBARA1_InputDmaDone2
DMA_DONE2 output assigned to XBARA1_IN66 input.
kXBARA1_InputDmaDone3
DMA_DONE3 output assigned to XBARA1_IN67 input.
kXBARA1_InputDmaDone4
DMA_DONE4 output assigned to XBARA1_IN68 input.
kXBARA1_InputDmaDone5
DMA_DONE5 output assigned to XBARA1_IN69 input.
kXBARA1_InputDmaDone6
DMA_DONE6 output assigned to XBARA1_IN70 input.
kXBARA1_InputDmaDone7
DMA_DONE7 output assigned to XBARA1_IN71 input.
kXBARA1_InputAoi1Out0
AOI1_OUT0 output assigned to XBARA1_IN72 input.
kXBARA1_InputAoi1Out1
AOI1_OUT1 output assigned to XBARA1_IN73 input.
kXBARA1_InputAoi1Out2
AOI1_OUT2 output assigned to XBARA1_IN74 input.
kXBARA1_InputAoi1Out3
AOI1_OUT3 output assigned to XBARA1_IN75 input.
kXBARA1_InputAoi2Out0
AOI2_OUT0 output assigned to XBARA1_IN76 input.
kXBARA1_InputAoi2Out1
AOI2_OUT1 output assigned to XBARA1_IN77 input.
kXBARA1_InputAoi2Out2
AOI2_OUT2 output assigned to XBARA1_IN78 input.
kXBARA1_InputAoi2Out3
AOI2_OUT3 output assigned to XBARA1_IN79 input.
kXBARA1_InputAdcEtcXbar0Coco0
ADC_ETC_XBAR0_COCO0 output assigned to XBARA1_IN80 input.
kXBARA1_InputAdcEtcXbar0Coco1
ADC_ETC_XBAR0_COCO1 output assigned to XBARA1_IN81 input.
kXBARA1_InputAdcEtcXbar0Coco2
ADC_ETC_XBAR0_COCO2 output assigned to XBARA1_IN82 input.
kXBARA1_InputAdcEtcXbar0Coco3
ADC_ETC_XBAR0_COCO3 output assigned to XBARA1_IN83 input.
kXBARA1_InputAdcEtcXbar1Coco0
ADC_ETC_XBAR1_COCO0 output assigned to XBARA1_IN84 input.
kXBARA1_InputAdcEtcXbar1Coco1
ADC_ETC_XBAR1_COCO1 output assigned to XBARA1_IN85 input.
kXBARA1_InputAdcEtcXbar1Coco2
ADC_ETC_XBAR1_COCO2 output assigned to XBARA1_IN86 input.
kXBARA1_InputAdcEtcXbar1Coco3
ADC_ETC_XBAR1_COCO3 output assigned to XBARA1_IN87 input.
kXBARB2_InputLogicLow
LOGIC_LOW output assigned to XBARB2_IN0 input.
kXBARB2_InputLogicHigh
LOGIC_HIGH output assigned to XBARB2_IN1 input.
kXBARB2_InputRESERVED2
XBARB2_IN2 input is reserved.
kXBARB2_InputRESERVED3
XBARB2_IN3 input is reserved.
kXBARB2_InputRESERVED4
XBARB2_IN4 input is reserved.
kXBARB2_InputRESERVED5
XBARB2_IN5 input is reserved.
kXBARB2_InputAcmp1Out
ACMP1_OUT output assigned to XBARB2_IN6 input.
kXBARB2_InputAcmp2Out
ACMP2_OUT output assigned to XBARB2_IN7 input.
kXBARB2_InputAcmp3Out
ACMP3_OUT output assigned to XBARB2_IN8 input.
kXBARB2_InputAcmp4Out
ACMP4_OUT output assigned to XBARB2_IN9 input.
kXBARB2_InputRESERVED10
XBARB2_IN10 input is reserved.
kXBARB2_InputRESERVED11
XBARB2_IN11 input is reserved.
kXBARB2_InputQtimer3Tmr0Output
QTIMER3_TMR0_OUTPUT output assigned to XBARB2_IN12 input.
kXBARB2_InputQtimer3Tmr1Output
QTIMER3_TMR1_OUTPUT output assigned to XBARB2_IN13 input.
kXBARB2_InputQtimer3Tmr2Output
QTIMER3_TMR2_OUTPUT output assigned to XBARB2_IN14 input.
kXBARB2_InputQtimer3Tmr3Output
QTIMER3_TMR3_OUTPUT output assigned to XBARB2_IN15 input.
kXBARB2_InputQtimer4Tmr0Output
QTIMER4_TMR0_OUTPUT output assigned to XBARB2_IN16 input.
kXBARB2_InputQtimer4Tmr1Output
QTIMER4_TMR1_OUTPUT output assigned to XBARB2_IN17 input.
kXBARB2_InputQtimer4Tmr2Output
QTIMER4_TMR2_OUTPUT output assigned to XBARB2_IN18 input.
kXBARB2_InputQtimer4Tmr3Output
QTIMER4_TMR3_OUTPUT output assigned to XBARB2_IN19 input.
kXBARB2_InputFlexpwm1Pwm1OutTrig01
FLEXPWM1_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN20 input.
kXBARB2_InputFlexpwm1Pwm2OutTrig01
FLEXPWM1_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN21 input.
kXBARB2_InputFlexpwm1Pwm3OutTrig01
FLEXPWM1_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN22 input.
kXBARB2_InputFlexpwm1Pwm4OutTrig01
FLEXPWM1_PWM4_OUT_TRIG0_1 output assigned to XBARB2_IN23 input.
kXBARB2_InputFlexpwm2Pwm1OutTrig01
FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN24 input.
kXBARB2_InputFlexpwm2Pwm2OutTrig01
FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN25 input.
kXBARB2_InputFlexpwm2Pwm3OutTrig01
FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN26 input.
kXBARB2_InputFlexpwm2Pwm4OutTrig01
FLEXPWM2_PWM4_OUT_TRIG0_1 output assigned to XBARB2_IN27 input.
kXBARB2_InputFlexpwm3Pwm1OutTrig01
FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN28 input.
kXBARB2_InputFlexpwm3Pwm2OutTrig01
FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN29 input.
kXBARB2_InputFlexpwm3Pwm3OutTrig01
FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN30 input.
kXBARB2_InputFlexpwm3Pwm4OutTrig01
FLEXPWM3_PWM4_OUT_TRIG0_1 output assigned to XBARB2_IN31 input.
kXBARB2_InputFlexpwm4Pwm1OutTrig01
FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN32 input.
kXBARB2_InputFlexpwm4Pwm2OutTrig01
FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN33 input.
kXBARB2_InputFlexpwm4Pwm3OutTrig01
FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN34 input.
kXBARB2_InputFlexpwm4Pwm4OutTrig01
FLEXPWM4_PWM4_OUT_TRIG0_1 output assigned to XBARB2_IN35 input.
kXBARB2_InputPitTrigger0
PIT_TRIGGER0 output assigned to XBARB2_IN36 input.
kXBARB2_InputPitTrigger1
PIT_TRIGGER1 output assigned to XBARB2_IN37 input.
kXBARB2_InputAdcEtcXbar0Coco0
ADC_ETC_XBAR0_COCO0 output assigned to XBARB2_IN38 input.
kXBARB2_InputAdcEtcXbar0Coco1
ADC_ETC_XBAR0_COCO1 output assigned to XBARB2_IN39 input.
kXBARB2_InputAdcEtcXbar0Coco2
ADC_ETC_XBAR0_COCO2 output assigned to XBARB2_IN40 input.
kXBARB2_InputAdcEtcXbar0Coco3
ADC_ETC_XBAR0_COCO3 output assigned to XBARB2_IN41 input.
kXBARB2_InputAdcEtcXbar1Coco0
ADC_ETC_XBAR1_COCO0 output assigned to XBARB2_IN42 input.
kXBARB2_InputAdcEtcXbar1Coco1
ADC_ETC_XBAR1_COCO1 output assigned to XBARB2_IN43 input.
kXBARB2_InputAdcEtcXbar1Coco2
ADC_ETC_XBAR1_COCO2 output assigned to XBARB2_IN44 input.
kXBARB2_InputAdcEtcXbar1Coco3
ADC_ETC_XBAR1_COCO3 output assigned to XBARB2_IN45 input.
kXBARB2_InputEnc1PosMatch
ENC1_POS_MATCH output assigned to XBARB2_IN46 input.
kXBARB2_InputEnc2PosMatch
ENC2_POS_MATCH output assigned to XBARB2_IN47 input.
kXBARB2_InputEnc3PosMatch
ENC3_POS_MATCH output assigned to XBARB2_IN48 input.
kXBARB2_InputEnc4PosMatch
ENC4_POS_MATCH output assigned to XBARB2_IN49 input.
kXBARB2_InputDmaDone0
DMA_DONE0 output assigned to XBARB2_IN50 input.
kXBARB2_InputDmaDone1
DMA_DONE1 output assigned to XBARB2_IN51 input.
kXBARB2_InputDmaDone2
DMA_DONE2 output assigned to XBARB2_IN52 input.
kXBARB2_InputDmaDone3
DMA_DONE3 output assigned to XBARB2_IN53 input.
kXBARB2_InputDmaDone4
DMA_DONE4 output assigned to XBARB2_IN54 input.
kXBARB2_InputDmaDone5
DMA_DONE5 output assigned to XBARB2_IN55 input.
kXBARB2_InputDmaDone6
DMA_DONE6 output assigned to XBARB2_IN56 input.
kXBARB2_InputDmaDone7
DMA_DONE7 output assigned to XBARB2_IN57 input.
kXBARB3_InputLogicLow
LOGIC_LOW output assigned to XBARB3_IN0 input.
kXBARB3_InputLogicHigh
LOGIC_HIGH output assigned to XBARB3_IN1 input.
kXBARB3_InputRESERVED2
XBARB3_IN2 input is reserved.
kXBARB3_InputRESERVED3
XBARB3_IN3 input is reserved.
kXBARB3_InputRESERVED4
XBARB3_IN4 input is reserved.
kXBARB3_InputRESERVED5
XBARB3_IN5 input is reserved.
kXBARB3_InputAcmp1Out
ACMP1_OUT output assigned to XBARB3_IN6 input.
kXBARB3_InputAcmp2Out
ACMP2_OUT output assigned to XBARB3_IN7 input.
kXBARB3_InputAcmp3Out
ACMP3_OUT output assigned to XBARB3_IN8 input.
kXBARB3_InputAcmp4Out
ACMP4_OUT output assigned to XBARB3_IN9 input.
kXBARB3_InputRESERVED10
XBARB3_IN10 input is reserved.
kXBARB3_InputRESERVED11
XBARB3_IN11 input is reserved.
kXBARB3_InputQtimer3Tmr0Output
QTIMER3_TMR0_OUTPUT output assigned to XBARB3_IN12 input.
kXBARB3_InputQtimer3Tmr1Output
QTIMER3_TMR1_OUTPUT output assigned to XBARB3_IN13 input.
kXBARB3_InputQtimer3Tmr2Output
QTIMER3_TMR2_OUTPUT output assigned to XBARB3_IN14 input.
kXBARB3_InputQtimer3Tmr3Output
QTIMER3_TMR3_OUTPUT output assigned to XBARB3_IN15 input.
kXBARB3_InputQtimer4Tmr0Output
QTIMER4_TMR0_OUTPUT output assigned to XBARB3_IN16 input.
kXBARB3_InputQtimer4Tmr1Output
QTIMER4_TMR1_OUTPUT output assigned to XBARB3_IN17 input.
kXBARB3_InputQtimer4Tmr2Output
QTIMER4_TMR2_OUTPUT output assigned to XBARB3_IN18 input.
kXBARB3_InputQtimer4Tmr3Output
QTIMER4_TMR3_OUTPUT output assigned to XBARB3_IN19 input.
kXBARB3_InputFlexpwm1Pwm1OutTrig01
FLEXPWM1_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN20 input.
kXBARB3_InputFlexpwm1Pwm2OutTrig01
FLEXPWM1_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN21 input.
kXBARB3_InputFlexpwm1Pwm3OutTrig01
FLEXPWM1_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN22 input.
kXBARB3_InputFlexpwm1Pwm4OutTrig01
FLEXPWM1_PWM4_OUT_TRIG0_1 output assigned to XBARB3_IN23 input.
kXBARB3_InputFlexpwm2Pwm1OutTrig01
FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN24 input.
kXBARB3_InputFlexpwm2Pwm2OutTrig01
FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN25 input.
kXBARB3_InputFlexpwm2Pwm3OutTrig01
FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN26 input.
kXBARB3_InputFlexpwm2Pwm4OutTrig01
FLEXPWM2_PWM4_OUT_TRIG0_1 output assigned to XBARB3_IN27 input.
kXBARB3_InputFlexpwm3Pwm1OutTrig01
FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN28 input.
kXBARB3_InputFlexpwm3Pwm2OutTrig01
FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN29 input.
kXBARB3_InputFlexpwm3Pwm3OutTrig01
FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN30 input.
kXBARB3_InputFlexpwm3Pwm4OutTrig01
FLEXPWM3_PWM4_OUT_TRIG0_1 output assigned to XBARB3_IN31 input.
kXBARB3_InputFlexpwm4Pwm1OutTrig01
FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN32 input.
kXBARB3_InputFlexpwm4Pwm2OutTrig01
FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN33 input.
kXBARB3_InputFlexpwm4Pwm3OutTrig01
FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN34 input.
kXBARB3_InputFlexpwm4Pwm4OutTrig01
FLEXPWM4_PWM4_OUT_TRIG0_1 output assigned to XBARB3_IN35 input.
kXBARB3_InputPitTrigger0
PIT_TRIGGER0 output assigned to XBARB3_IN36 input.
kXBARB3_InputPitTrigger1
PIT_TRIGGER1 output assigned to XBARB3_IN37 input.
kXBARB3_InputAdcEtcXbar0Coco0
ADC_ETC_XBAR0_COCO0 output assigned to XBARB3_IN38 input.
kXBARB3_InputAdcEtcXbar0Coco1
ADC_ETC_XBAR0_COCO1 output assigned to XBARB3_IN39 input.
kXBARB3_InputAdcEtcXbar0Coco2
ADC_ETC_XBAR0_COCO2 output assigned to XBARB3_IN40 input.
kXBARB3_InputAdcEtcXbar0Coco3
ADC_ETC_XBAR0_COCO3 output assigned to XBARB3_IN41 input.
kXBARB3_InputAdcEtcXbar1Coco0
ADC_ETC_XBAR1_COCO0 output assigned to XBARB3_IN42 input.
kXBARB3_InputAdcEtcXbar1Coco1
ADC_ETC_XBAR1_COCO1 output assigned to XBARB3_IN43 input.
kXBARB3_InputAdcEtcXbar1Coco2
ADC_ETC_XBAR1_COCO2 output assigned to XBARB3_IN44 input.
kXBARB3_InputAdcEtcXbar1Coco3
ADC_ETC_XBAR1_COCO3 output assigned to XBARB3_IN45 input.
kXBARB3_InputEnc1PosMatch
ENC1_POS_MATCH output assigned to XBARB3_IN46 input.
kXBARB3_InputEnc2PosMatch
ENC2_POS_MATCH output assigned to XBARB3_IN47 input.
kXBARB3_InputEnc3PosMatch
ENC3_POS_MATCH output assigned to XBARB3_IN48 input.
kXBARB3_InputEnc4PosMatch
ENC4_POS_MATCH output assigned to XBARB3_IN49 input.
kXBARB3_InputDmaDone0
DMA_DONE0 output assigned to XBARB3_IN50 input.
kXBARB3_InputDmaDone1
DMA_DONE1 output assigned to XBARB3_IN51 input.
kXBARB3_InputDmaDone2
DMA_DONE2 output assigned to XBARB3_IN52 input.
kXBARB3_InputDmaDone3
DMA_DONE3 output assigned to XBARB3_IN53 input.
kXBARB3_InputDmaDone4
DMA_DONE4 output assigned to XBARB3_IN54 input.
kXBARB3_InputDmaDone5
DMA_DONE5 output assigned to XBARB3_IN55 input.
kXBARB3_InputDmaDone6
DMA_DONE6 output assigned to XBARB3_IN56 input.
kXBARB3_InputDmaDone7
DMA_DONE7 output assigned to XBARB3_IN57 input.
kXBARA1_InputRESERVED2
XBARA1_IN2 input is reserved.
XBARA1_IN3 input is reserved.
kXBARA1_InputIomuxXbarInout20
IOMUX_XBAR_INOUT20 output assigned to XBARA1_IN20 input.
kXBARA1_InputIomuxXbarInout21
IOMUX_XBAR_INOUT21 output assigned to XBARA1_IN21 input.
kXBARA1_InputIomuxXbarInout22
IOMUX_XBAR_INOUT22 output assigned to XBARA1_IN22 input.
kXBARA1_InputIomuxXbarInout23
IOMUX_XBAR_INOUT23 output assigned to XBARA1_IN23 input.
kXBARA1_InputIomuxXbarInout24
IOMUX_XBAR_INOUT24 output assigned to XBARA1_IN24 input.
kXBARA1_InputIomuxXbarInout25
IOMUX_XBAR_INOUT25 output assigned to XBARA1_IN25 input.
kXBARA1_InputIomuxXbarInout26
IOMUX_XBAR_INOUT26 output assigned to XBARA1_IN26 input.
kXBARA1_InputIomuxXbarInout27
IOMUX_XBAR_INOUT27 output assigned to XBARA1_IN27 input.
kXBARA1_InputIomuxXbarInout28
IOMUX_XBAR_INOUT28 output assigned to XBARA1_IN28 input.
kXBARA1_InputIomuxXbarInout29
IOMUX_XBAR_INOUT29 output assigned to XBARA1_IN29 input.
kXBARA1_InputIomuxXbarInout30
IOMUX_XBAR_INOUT30 output assigned to XBARA1_IN30 input.
kXBARA1_InputIomuxXbarInout31
IOMUX_XBAR_INOUT31 output assigned to XBARA1_IN31 input.
kXBARA1_InputIomuxXbarInout32
IOMUX_XBAR_INOUT32 output assigned to XBARA1_IN32 input.
kXBARA1_InputIomuxXbarInout33
IOMUX_XBAR_INOUT33 output assigned to XBARA1_IN33 input.
kXBARA1_InputIomuxXbarInout34
IOMUX_XBAR_INOUT34 output assigned to XBARA1_IN34 input.
kXBARA1_InputIomuxXbarInout35
IOMUX_XBAR_INOUT35 output assigned to XBARA1_IN35 input.
kXBARA1_InputIomuxXbarInout36
IOMUX_XBAR_INOUT36 output assigned to XBARA1_IN36 input.
kXBARA1_InputIomuxXbarInout37
IOMUX_XBAR_INOUT37 output assigned to XBARA1_IN37 input.
kXBARA1_InputIomuxXbarInout38
IOMUX_XBAR_INOUT38 output assigned to XBARA1_IN38 input.
kXBARA1_InputIomuxXbarInout39
IOMUX_XBAR_INOUT39 output assigned to XBARA1_IN39 input.
kXBARA1_InputIomuxXbarInout40
IOMUX_XBAR_INOUT40 output assigned to XBARA1_IN40 input.
kXBARA1_InputRESERVED41
XBARA1_IN41 input is reserved.
ACMP1_OUT output assigned to XBARA1_IN42 input.
ACMP2_OUT output assigned to XBARA1_IN43 input.
ACMP3_OUT output assigned to XBARA1_IN44 input.
ACMP4_OUT output assigned to XBARA1_IN45 input.
kXBARA1_InputRESERVED46
XBARA1_IN46 input is reserved.
kXBARA1_InputRESERVED47
XBARA1_IN47 input is reserved.
kXBARA1_InputRESERVED48
XBARA1_IN48 input is reserved.
kXBARA1_InputRESERVED49
XBARA1_IN49 input is reserved.
kXBARA1_InputQtimer1Timer0
QTIMER1_TIMER0 output assigned to XBARA1_IN50 input.
kXBARA1_InputQtimer1Timer1
QTIMER1_TIMER1 output assigned to XBARA1_IN51 input.
kXBARA1_InputQtimer1Timer2
QTIMER1_TIMER2 output assigned to XBARA1_IN52 input.
kXBARA1_InputQtimer1Timer3
QTIMER1_TIMER3 output assigned to XBARA1_IN53 input.
kXBARA1_InputQtimer2Timer0
QTIMER2_TIMER0 output assigned to XBARA1_IN54 input.
kXBARA1_InputQtimer2Timer1
QTIMER2_TIMER1 output assigned to XBARA1_IN55 input.
kXBARA1_InputQtimer2Timer2
QTIMER2_TIMER2 output assigned to XBARA1_IN56 input.
kXBARA1_InputQtimer2Timer3
QTIMER2_TIMER3 output assigned to XBARA1_IN57 input.
kXBARA1_InputQtimer3Timer0
QTIMER3_TIMER0 output assigned to XBARA1_IN58 input.
kXBARA1_InputQtimer3Timer1
QTIMER3_TIMER1 output assigned to XBARA1_IN59 input.
kXBARA1_InputQtimer3Timer2
QTIMER3_TIMER2 output assigned to XBARA1_IN60 input.
kXBARA1_InputQtimer3Timer3
QTIMER3_TIMER3 output assigned to XBARA1_IN61 input.
kXBARA1_InputQtimer4Timer0
QTIMER4_TIMER0 output assigned to XBARA1_IN62 input.
kXBARA1_InputQtimer4Timer1
QTIMER4_TIMER1 output assigned to XBARA1_IN63 input.
kXBARA1_InputQtimer4Timer2
QTIMER4_TIMER2 output assigned to XBARA1_IN64 input.
kXBARA1_InputQtimer4Timer3
QTIMER4_TIMER3 output assigned to XBARA1_IN65 input.
kXBARA1_InputRESERVED66
XBARA1_IN66 input is reserved.
kXBARA1_InputRESERVED67
XBARA1_IN67 input is reserved.
kXBARA1_InputRESERVED68
XBARA1_IN68 input is reserved.
kXBARA1_InputRESERVED69
XBARA1_IN69 input is reserved.
kXBARA1_InputRESERVED70
XBARA1_IN70 input is reserved.
kXBARA1_InputRESERVED71
XBARA1_IN71 input is reserved.
kXBARA1_InputRESERVED72
XBARA1_IN72 input is reserved.
kXBARA1_InputRESERVED73
XBARA1_IN73 input is reserved.
kXBARA1_InputFlexpwm1Pwm0OutTrig0
FLEXPWM1_PWM0_OUT_TRIG0 output assigned to XBARA1_IN74 input.
kXBARA1_InputFlexpwm1Pwm0OutTrig1
FLEXPWM1_PWM0_OUT_TRIG1 output assigned to XBARA1_IN75 input.
FLEXPWM1_PWM1_OUT_TRIG0 output assigned to XBARA1_IN76 input.
kXBARA1_InputFlexpwm1Pwm1OutTrig1
FLEXPWM1_PWM1_OUT_TRIG1 output assigned to XBARA1_IN77 input.
FLEXPWM1_PWM2_OUT_TRIG0 output assigned to XBARA1_IN78 input.
kXBARA1_InputFlexpwm1Pwm2OutTrig1
FLEXPWM1_PWM2_OUT_TRIG1 output assigned to XBARA1_IN79 input.
FLEXPWM1_PWM3_OUT_TRIG0 output assigned to XBARA1_IN80 input.
kXBARA1_InputFlexpwm1Pwm3OutTrig1
FLEXPWM1_PWM3_OUT_TRIG1 output assigned to XBARA1_IN81 input.
kXBARA1_InputFlexpwm2Pwm0OutTrig01
FLEXPWM2_PWM0_OUT_TRIG0_1 output assigned to XBARA1_IN82 input.
FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN83 input.
FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN84 input.
FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN85 input.
kXBARA1_InputFlexpwm3Pwm0OutTrig01
FLEXPWM3_PWM0_OUT_TRIG0_1 output assigned to XBARA1_IN86 input.
FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN87 input.
FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN88 input.
FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN89 input.
kXBARA1_InputFlexpwm4Pwm0OutTrig01
FLEXPWM4_PWM0_OUT_TRIG0_1 output assigned to XBARA1_IN90 input.
FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN91 input.
FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN92 input.
FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN93 input.
kXBARA1_InputRESERVED94
XBARA1_IN94 input is reserved.
kXBARA1_InputRESERVED95
XBARA1_IN95 input is reserved.
kXBARA1_InputRESERVED96
XBARA1_IN96 input is reserved.
kXBARA1_InputRESERVED97
XBARA1_IN97 input is reserved.
kXBARA1_InputRESERVED98
XBARA1_IN98 input is reserved.
kXBARA1_InputRESERVED99
XBARA1_IN99 input is reserved.
kXBARA1_InputRESERVED100
XBARA1_IN100 input is reserved.
kXBARA1_InputRESERVED101
XBARA1_IN101 input is reserved.
kXBARA1_InputPit1Trigger0
PIT1_TRIGGER0 output assigned to XBARA1_IN102 input.
kXBARA1_InputPit1Trigger1
PIT1_TRIGGER1 output assigned to XBARA1_IN103 input.
kXBARA1_InputPit1Trigger2
PIT1_TRIGGER2 output assigned to XBARA1_IN104 input.
kXBARA1_InputPit1Trigger3
PIT1_TRIGGER3 output assigned to XBARA1_IN105 input.
kXBARA1_InputDec1PosMatch
DEC1_POS_MATCH output assigned to XBARA1_IN106 input.
kXBARA1_InputDec2PosMatch
DEC2_POS_MATCH output assigned to XBARA1_IN107 input.
kXBARA1_InputDec3PosMatch
DEC3_POS_MATCH output assigned to XBARA1_IN108 input.
kXBARA1_InputDec4PosMatch
DEC4_POS_MATCH output assigned to XBARA1_IN109 input.
kXBARA1_InputRESERVED110
XBARA1_IN110 input is reserved.
kXBARA1_InputRESERVED111
XBARA1_IN111 input is reserved.
DMA_DONE0 output assigned to XBARA1_IN112 input.
DMA_DONE1 output assigned to XBARA1_IN113 input.
DMA_DONE2 output assigned to XBARA1_IN114 input.
DMA_DONE3 output assigned to XBARA1_IN115 input.
DMA_DONE4 output assigned to XBARA1_IN116 input.
DMA_DONE5 output assigned to XBARA1_IN117 input.
DMA_DONE6 output assigned to XBARA1_IN118 input.
DMA_DONE7 output assigned to XBARA1_IN119 input.
kXBARA1_InputDmaLpsrDone0
DMA_LPSR_DONE0 output assigned to XBARA1_IN120 input.
kXBARA1_InputDmaLpsrDone1
DMA_LPSR_DONE1 output assigned to XBARA1_IN121 input.
kXBARA1_InputDmaLpsrDone2
DMA_LPSR_DONE2 output assigned to XBARA1_IN122 input.
kXBARA1_InputDmaLpsrDone3
DMA_LPSR_DONE3 output assigned to XBARA1_IN123 input.
kXBARA1_InputDmaLpsrDone4
DMA_LPSR_DONE4 output assigned to XBARA1_IN124 input.
kXBARA1_InputDmaLpsrDone5
DMA_LPSR_DONE5 output assigned to XBARA1_IN125 input.
kXBARA1_InputDmaLpsrDone6
DMA_LPSR_DONE6 output assigned to XBARA1_IN126 input.
kXBARA1_InputDmaLpsrDone7
DMA_LPSR_DONE7 output assigned to XBARA1_IN127 input.
AOI1_OUT0 output assigned to XBARA1_IN128 input.
AOI1_OUT1 output assigned to XBARA1_IN129 input.
AOI1_OUT2 output assigned to XBARA1_IN130 input.
AOI1_OUT3 output assigned to XBARA1_IN131 input.
AOI2_OUT0 output assigned to XBARA1_IN132 input.
AOI2_OUT1 output assigned to XBARA1_IN133 input.
AOI2_OUT2 output assigned to XBARA1_IN134 input.
AOI2_OUT3 output assigned to XBARA1_IN135 input.
kXBARA1_InputAdcEtc0Coco0
ADC_ETC0_COCO0 output assigned to XBARA1_IN136 input.
kXBARA1_InputAdcEtc0Coco1
ADC_ETC0_COCO1 output assigned to XBARA1_IN137 input.
kXBARA1_InputAdcEtc0Coco2
ADC_ETC0_COCO2 output assigned to XBARA1_IN138 input.
kXBARA1_InputAdcEtc0Coco3
ADC_ETC0_COCO3 output assigned to XBARA1_IN139 input.
kXBARA1_InputAdcEtc1Coco0
ADC_ETC1_COCO0 output assigned to XBARA1_IN140 input.
kXBARA1_InputAdcEtc1Coco1
ADC_ETC1_COCO1 output assigned to XBARA1_IN141 input.
kXBARA1_InputAdcEtc1Coco2
ADC_ETC1_COCO2 output assigned to XBARA1_IN142 input.
kXBARA1_InputAdcEtc1Coco3
ADC_ETC1_COCO3 output assigned to XBARA1_IN143 input.
ACMP1_OUT output assigned to XBARB2_IN2 input.
ACMP2_OUT output assigned to XBARB2_IN3 input.
ACMP3_OUT output assigned to XBARB2_IN4 input.
ACMP4_OUT output assigned to XBARB2_IN5 input.
kXBARB2_InputRESERVED6
XBARB2_IN6 input is reserved.
kXBARB2_InputRESERVED7
XBARB2_IN7 input is reserved.
kXBARB2_InputRESERVED8
XBARB2_IN8 input is reserved.
kXBARB2_InputRESERVED9
XBARB2_IN9 input is reserved.
kXBARB2_InputQtimer1Timer0
QTIMER1_TIMER0 output assigned to XBARB2_IN10 input.
kXBARB2_InputQtimer1Timer1
QTIMER1_TIMER1 output assigned to XBARB2_IN11 input.
kXBARB2_InputQtimer1Timer2
QTIMER1_TIMER2 output assigned to XBARB2_IN12 input.
kXBARB2_InputQtimer1Timer3
QTIMER1_TIMER3 output assigned to XBARB2_IN13 input.
kXBARB2_InputQtimer2Timer0
QTIMER2_TIMER0 output assigned to XBARB2_IN14 input.
kXBARB2_InputQtimer2Timer1
QTIMER2_TIMER1 output assigned to XBARB2_IN15 input.
kXBARB2_InputQtimer2Timer2
QTIMER2_TIMER2 output assigned to XBARB2_IN16 input.
kXBARB2_InputQtimer2Timer3
QTIMER2_TIMER3 output assigned to XBARB2_IN17 input.
kXBARB2_InputQtimer3Timer0
QTIMER3_TIMER0 output assigned to XBARB2_IN18 input.
kXBARB2_InputQtimer3Timer1
QTIMER3_TIMER1 output assigned to XBARB2_IN19 input.
kXBARB2_InputQtimer3Timer2
QTIMER3_TIMER2 output assigned to XBARB2_IN20 input.
kXBARB2_InputQtimer3Timer3
QTIMER3_TIMER3 output assigned to XBARB2_IN21 input.
kXBARB2_InputQtimer4Timer0
QTIMER4_TIMER0 output assigned to XBARB2_IN22 input.
kXBARB2_InputQtimer4Timer1
QTIMER4_TIMER1 output assigned to XBARB2_IN23 input.
kXBARB2_InputQtimer4Timer2
QTIMER4_TIMER2 output assigned to XBARB2_IN24 input.
kXBARB2_InputQtimer4Timer3
QTIMER4_TIMER3 output assigned to XBARB2_IN25 input.
kXBARB2_InputRESERVED26
XBARB2_IN26 input is reserved.
kXBARB2_InputRESERVED27
XBARB2_IN27 input is reserved.
kXBARB2_InputRESERVED28
XBARB2_IN28 input is reserved.
kXBARB2_InputRESERVED29
XBARB2_IN29 input is reserved.
kXBARB2_InputRESERVED30
XBARB2_IN30 input is reserved.
kXBARB2_InputRESERVED31
XBARB2_IN31 input is reserved.
kXBARB2_InputRESERVED32
XBARB2_IN32 input is reserved.
kXBARB2_InputRESERVED33
XBARB2_IN33 input is reserved.
kXBARB2_InputFlexpwm1Pwm0OutTrig01
FLEXPWM1_PWM0_OUT_TRIG0_1 output assigned to XBARB2_IN34 input.
FLEXPWM1_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN35 input.
FLEXPWM1_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN36 input.
FLEXPWM1_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN37 input.
kXBARB2_InputFlexpwm2Pwm0OutTrig01
FLEXPWM2_PWM0_OUT_TRIG0_1 output assigned to XBARB2_IN38 input.
FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN39 input.
FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN40 input.
FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN41 input.
kXBARB2_InputFlexpwm3Pwm0OutTrig01
FLEXPWM3_PWM0_OUT_TRIG0_1 output assigned to XBARB2_IN42 input.
FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN43 input.
FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN44 input.
FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN45 input.
kXBARB2_InputFlexpwm4Pwm0OutTrig01
FLEXPWM4_PWM0_OUT_TRIG0_1 output assigned to XBARB2_IN46 input.
FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN47 input.
FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN48 input.
FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN49 input.
kXBARB2_InputRESERVED50
XBARB2_IN50 input is reserved.
kXBARB2_InputRESERVED51
XBARB2_IN51 input is reserved.
kXBARB2_InputRESERVED52
XBARB2_IN52 input is reserved.
kXBARB2_InputRESERVED53
XBARB2_IN53 input is reserved.
kXBARB2_InputRESERVED54
XBARB2_IN54 input is reserved.
kXBARB2_InputRESERVED55
XBARB2_IN55 input is reserved.
kXBARB2_InputRESERVED56
XBARB2_IN56 input is reserved.
kXBARB2_InputRESERVED57
XBARB2_IN57 input is reserved.
kXBARB2_InputPit1Trigger0
PIT1_TRIGGER0 output assigned to XBARB2_IN58 input.
kXBARB2_InputPit1Trigger1
PIT1_TRIGGER1 output assigned to XBARB2_IN59 input.
kXBARB2_InputAdcEtc0Coco0
ADC_ETC0_COCO0 output assigned to XBARB2_IN60 input.
kXBARB2_InputAdcEtc0Coco1
ADC_ETC0_COCO1 output assigned to XBARB2_IN61 input.
kXBARB2_InputAdcEtc0Coco2
ADC_ETC0_COCO2 output assigned to XBARB2_IN62 input.
kXBARB2_InputAdcEtc0Coco3
ADC_ETC0_COCO3 output assigned to XBARB2_IN63 input.
kXBARB2_InputAdcEtc1Coco0
ADC_ETC1_COCO0 output assigned to XBARB2_IN64 input.
kXBARB2_InputAdcEtc1Coco1
ADC_ETC1_COCO1 output assigned to XBARB2_IN65 input.
kXBARB2_InputAdcEtc1Coco2
ADC_ETC1_COCO2 output assigned to XBARB2_IN66 input.
kXBARB2_InputAdcEtc1Coco3
ADC_ETC1_COCO3 output assigned to XBARB2_IN67 input.
kXBARB2_InputRESERVED68
XBARB2_IN68 input is reserved.
kXBARB2_InputRESERVED69
XBARB2_IN69 input is reserved.
kXBARB2_InputRESERVED70
XBARB2_IN70 input is reserved.
kXBARB2_InputRESERVED71
XBARB2_IN71 input is reserved.
kXBARB2_InputRESERVED72
XBARB2_IN72 input is reserved.
kXBARB2_InputRESERVED73
XBARB2_IN73 input is reserved.
kXBARB2_InputRESERVED74
XBARB2_IN74 input is reserved.
kXBARB2_InputRESERVED75
XBARB2_IN75 input is reserved.
kXBARB2_InputDec1PosMatch
DEC1_POS_MATCH output assigned to XBARB2_IN76 input.
kXBARB2_InputDec2PosMatch
DEC2_POS_MATCH output assigned to XBARB2_IN77 input.
kXBARB2_InputDec3PosMatch
DEC3_POS_MATCH output assigned to XBARB2_IN78 input.
kXBARB2_InputDec4PosMatch
DEC4_POS_MATCH output assigned to XBARB2_IN79 input.
kXBARB2_InputRESERVED80
XBARB2_IN80 input is reserved.
kXBARB2_InputRESERVED81
XBARB2_IN81 input is reserved.
DMA_DONE0 output assigned to XBARB2_IN82 input.
DMA_DONE1 output assigned to XBARB2_IN83 input.
DMA_DONE2 output assigned to XBARB2_IN84 input.
DMA_DONE3 output assigned to XBARB2_IN85 input.
DMA_DONE4 output assigned to XBARB2_IN86 input.
DMA_DONE5 output assigned to XBARB2_IN87 input.
DMA_DONE6 output assigned to XBARB2_IN88 input.
DMA_DONE7 output assigned to XBARB2_IN89 input.
kXBARB2_InputDmaLpsrDone0
DMA_LPSR_DONE0 output assigned to XBARB2_IN90 input.
kXBARB2_InputDmaLpsrDone1
DMA_LPSR_DONE1 output assigned to XBARB2_IN91 input.
kXBARB2_InputDmaLpsrDone2
DMA_LPSR_DONE2 output assigned to XBARB2_IN92 input.
kXBARB2_InputDmaLpsrDone3
DMA_LPSR_DONE3 output assigned to XBARB2_IN93 input.
kXBARB2_InputDmaLpsrDone4
DMA_LPSR_DONE4 output assigned to XBARB2_IN94 input.
kXBARB2_InputDmaLpsrDone5
DMA_LPSR_DONE5 output assigned to XBARB2_IN95 input.
kXBARB2_InputDmaLpsrDone6
DMA_LPSR_DONE6 output assigned to XBARB2_IN96 input.
kXBARB2_InputDmaLpsrDone7
DMA_LPSR_DONE7 output assigned to XBARB2_IN97 input.
ACMP1_OUT output assigned to XBARB3_IN2 input.
ACMP2_OUT output assigned to XBARB3_IN3 input.
ACMP3_OUT output assigned to XBARB3_IN4 input.
ACMP4_OUT output assigned to XBARB3_IN5 input.
kXBARB3_InputRESERVED6
XBARB3_IN6 input is reserved.
kXBARB3_InputRESERVED7
XBARB3_IN7 input is reserved.
kXBARB3_InputRESERVED8
XBARB3_IN8 input is reserved.
kXBARB3_InputRESERVED9
XBARB3_IN9 input is reserved.
kXBARB3_InputQtimer1Timer0
QTIMER1_TIMER0 output assigned to XBARB3_IN10 input.
kXBARB3_InputQtimer1Timer1
QTIMER1_TIMER1 output assigned to XBARB3_IN11 input.
kXBARB3_InputQtimer1Timer2
QTIMER1_TIMER2 output assigned to XBARB3_IN12 input.
kXBARB3_InputQtimer1Timer3
QTIMER1_TIMER3 output assigned to XBARB3_IN13 input.
kXBARB3_InputQtimer2Timer0
QTIMER2_TIMER0 output assigned to XBARB3_IN14 input.
kXBARB3_InputQtimer2Timer1
QTIMER2_TIMER1 output assigned to XBARB3_IN15 input.
kXBARB3_InputQtimer2Timer2
QTIMER2_TIMER2 output assigned to XBARB3_IN16 input.
kXBARB3_InputQtimer2Timer3
QTIMER2_TIMER3 output assigned to XBARB3_IN17 input.
kXBARB3_InputQtimer3Timer0
QTIMER3_TIMER0 output assigned to XBARB3_IN18 input.
kXBARB3_InputQtimer3Timer1
QTIMER3_TIMER1 output assigned to XBARB3_IN19 input.
kXBARB3_InputQtimer3Timer2
QTIMER3_TIMER2 output assigned to XBARB3_IN20 input.
kXBARB3_InputQtimer3Timer3
QTIMER3_TIMER3 output assigned to XBARB3_IN21 input.
kXBARB3_InputQtimer4Timer0
QTIMER4_TIMER0 output assigned to XBARB3_IN22 input.
kXBARB3_InputQtimer4Timer1
QTIMER4_TIMER1 output assigned to XBARB3_IN23 input.
kXBARB3_InputQtimer4Timer2
QTIMER4_TIMER2 output assigned to XBARB3_IN24 input.
kXBARB3_InputQtimer4Timer3
QTIMER4_TIMER3 output assigned to XBARB3_IN25 input.
kXBARB3_InputRESERVED26
XBARB3_IN26 input is reserved.
kXBARB3_InputRESERVED27
XBARB3_IN27 input is reserved.
kXBARB3_InputRESERVED28
XBARB3_IN28 input is reserved.
kXBARB3_InputRESERVED29
XBARB3_IN29 input is reserved.
kXBARB3_InputRESERVED30
XBARB3_IN30 input is reserved.
kXBARB3_InputRESERVED31
XBARB3_IN31 input is reserved.
kXBARB3_InputRESERVED32
XBARB3_IN32 input is reserved.
kXBARB3_InputRESERVED33
XBARB3_IN33 input is reserved.
kXBARB3_InputFlexpwm1Pwm0OutTrig01
FLEXPWM1_PWM0_OUT_TRIG0_1 output assigned to XBARB3_IN34 input.
FLEXPWM1_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN35 input.
FLEXPWM1_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN36 input.
FLEXPWM1_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN37 input.
kXBARB3_InputFlexpwm2Pwm0OutTrig01
FLEXPWM2_PWM0_OUT_TRIG0_1 output assigned to XBARB3_IN38 input.
FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN39 input.
FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN40 input.
FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN41 input.
kXBARB3_InputFlexpwm3Pwm0OutTrig01
FLEXPWM3_PWM0_OUT_TRIG0_1 output assigned to XBARB3_IN42 input.
FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN43 input.
FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN44 input.
FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN45 input.
kXBARB3_InputFlexpwm4Pwm0OutTrig01
FLEXPWM4_PWM0_OUT_TRIG0_1 output assigned to XBARB3_IN46 input.
FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN47 input.
FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN48 input.
FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN49 input.
kXBARB3_InputRESERVED50
XBARB3_IN50 input is reserved.
kXBARB3_InputRESERVED51
XBARB3_IN51 input is reserved.
kXBARB3_InputRESERVED52
XBARB3_IN52 input is reserved.
kXBARB3_InputRESERVED53
XBARB3_IN53 input is reserved.
kXBARB3_InputRESERVED54
XBARB3_IN54 input is reserved.
kXBARB3_InputRESERVED55
XBARB3_IN55 input is reserved.
kXBARB3_InputRESERVED56
XBARB3_IN56 input is reserved.
kXBARB3_InputRESERVED57
XBARB3_IN57 input is reserved.
kXBARB3_InputPit1Trigger0
PIT1_TRIGGER0 output assigned to XBARB3_IN58 input.
kXBARB3_InputPit1Trigger1
PIT1_TRIGGER1 output assigned to XBARB3_IN59 input.
kXBARB3_InputAdcEtc0Coco0
ADC_ETC0_COCO0 output assigned to XBARB3_IN60 input.
kXBARB3_InputAdcEtc0Coco1
ADC_ETC0_COCO1 output assigned to XBARB3_IN61 input.
kXBARB3_InputAdcEtc0Coco2
ADC_ETC0_COCO2 output assigned to XBARB3_IN62 input.
kXBARB3_InputAdcEtc0Coco3
ADC_ETC0_COCO3 output assigned to XBARB3_IN63 input.
kXBARB3_InputAdcEtc1Coco0
ADC_ETC1_COCO0 output assigned to XBARB3_IN64 input.
kXBARB3_InputAdcEtc1Coco1
ADC_ETC1_COCO1 output assigned to XBARB3_IN65 input.
kXBARB3_InputAdcEtc1Coco2
ADC_ETC1_COCO2 output assigned to XBARB3_IN66 input.
kXBARB3_InputAdcEtc1Coco3
ADC_ETC1_COCO3 output assigned to XBARB3_IN67 input.
kXBARB3_InputRESERVED68
XBARB3_IN68 input is reserved.
kXBARB3_InputRESERVED69
XBARB3_IN69 input is reserved.
kXBARB3_InputRESERVED70
XBARB3_IN70 input is reserved.
kXBARB3_InputRESERVED71
XBARB3_IN71 input is reserved.
kXBARB3_InputRESERVED72
XBARB3_IN72 input is reserved.
kXBARB3_InputRESERVED73
XBARB3_IN73 input is reserved.
kXBARB3_InputRESERVED74
XBARB3_IN74 input is reserved.
kXBARB3_InputRESERVED75
XBARB3_IN75 input is reserved.
kXBARB3_InputDec1PosMatch
DEC1_POS_MATCH output assigned to XBARB3_IN76 input.
kXBARB3_InputDec2PosMatch
DEC2_POS_MATCH output assigned to XBARB3_IN77 input.
kXBARB3_InputDec3PosMatch
DEC3_POS_MATCH output assigned to XBARB3_IN78 input.
kXBARB3_InputDec4PosMatch
DEC4_POS_MATCH output assigned to XBARB3_IN79 input.
kXBARB3_InputRESERVED80
XBARB3_IN80 input is reserved.
kXBARB3_InputRESERVED81
XBARB3_IN81 input is reserved.
DMA_DONE0 output assigned to XBARB3_IN82 input.
DMA_DONE1 output assigned to XBARB3_IN83 input.
DMA_DONE2 output assigned to XBARB3_IN84 input.
DMA_DONE3 output assigned to XBARB3_IN85 input.
DMA_DONE4 output assigned to XBARB3_IN86 input.
DMA_DONE5 output assigned to XBARB3_IN87 input.
DMA_DONE6 output assigned to XBARB3_IN88 input.
DMA_DONE7 output assigned to XBARB3_IN89 input.
kXBARB3_InputDmaLpsrDone0
DMA_LPSR_DONE0 output assigned to XBARB3_IN90 input.
kXBARB3_InputDmaLpsrDone1
DMA_LPSR_DONE1 output assigned to XBARB3_IN91 input.
kXBARB3_InputDmaLpsrDone2
DMA_LPSR_DONE2 output assigned to XBARB3_IN92 input.
kXBARB3_InputDmaLpsrDone3
DMA_LPSR_DONE3 output assigned to XBARB3_IN93 input.
kXBARB3_InputDmaLpsrDone4
DMA_LPSR_DONE4 output assigned to XBARB3_IN94 input.
kXBARB3_InputDmaLpsrDone5
DMA_LPSR_DONE5 output assigned to XBARB3_IN95 input.
kXBARB3_InputDmaLpsrDone6
DMA_LPSR_DONE6 output assigned to XBARB3_IN96 input.
kXBARB3_InputDmaLpsrDone7
DMA_LPSR_DONE7 output assigned to XBARB3_IN97 input.
◆ _xbar_output_signal
kXBARA1_OutputDmaChMuxReq30
XBARA1_OUT0 output assigned to DMA_CH_MUX_REQ30
kXBARA1_OutputDmaChMuxReq31
XBARA1_OUT1 output assigned to DMA_CH_MUX_REQ31
kXBARA1_OutputDmaChMuxReq94
XBARA1_OUT2 output assigned to DMA_CH_MUX_REQ94
kXBARA1_OutputDmaChMuxReq95
XBARA1_OUT3 output assigned to DMA_CH_MUX_REQ95
kXBARA1_OutputIomuxXbarInout04
XBARA1_OUT4 output assigned to IOMUX_XBAR_INOUT04
kXBARA1_OutputIomuxXbarInout05
XBARA1_OUT5 output assigned to IOMUX_XBAR_INOUT05
kXBARA1_OutputIomuxXbarInout06
XBARA1_OUT6 output assigned to IOMUX_XBAR_INOUT06
kXBARA1_OutputIomuxXbarInout07
XBARA1_OUT7 output assigned to IOMUX_XBAR_INOUT07
kXBARA1_OutputIomuxXbarInout08
XBARA1_OUT8 output assigned to IOMUX_XBAR_INOUT08
kXBARA1_OutputIomuxXbarInout09
XBARA1_OUT9 output assigned to IOMUX_XBAR_INOUT09
kXBARA1_OutputIomuxXbarInout10
XBARA1_OUT10 output assigned to IOMUX_XBAR_INOUT10
kXBARA1_OutputIomuxXbarInout11
XBARA1_OUT11 output assigned to IOMUX_XBAR_INOUT11
kXBARA1_OutputIomuxXbarInout12
XBARA1_OUT12 output assigned to IOMUX_XBAR_INOUT12
kXBARA1_OutputIomuxXbarInout13
XBARA1_OUT13 output assigned to IOMUX_XBAR_INOUT13
kXBARA1_OutputIomuxXbarInout14
XBARA1_OUT14 output assigned to IOMUX_XBAR_INOUT14
kXBARA1_OutputIomuxXbarInout15
XBARA1_OUT15 output assigned to IOMUX_XBAR_INOUT15
kXBARA1_OutputIomuxXbarInout16
XBARA1_OUT16 output assigned to IOMUX_XBAR_INOUT16
kXBARA1_OutputIomuxXbarInout17
XBARA1_OUT17 output assigned to IOMUX_XBAR_INOUT17
kXBARA1_OutputIomuxXbarInout18
XBARA1_OUT18 output assigned to IOMUX_XBAR_INOUT18
kXBARA1_OutputIomuxXbarInout19
XBARA1_OUT19 output assigned to IOMUX_XBAR_INOUT19
kXBARA1_OutputAcmp1Sample
XBARA1_OUT20 output assigned to ACMP1_SAMPLE
kXBARA1_OutputAcmp2Sample
XBARA1_OUT21 output assigned to ACMP2_SAMPLE
kXBARA1_OutputAcmp3Sample
XBARA1_OUT22 output assigned to ACMP3_SAMPLE
kXBARA1_OutputAcmp4Sample
XBARA1_OUT23 output assigned to ACMP4_SAMPLE
kXBARA1_OutputRESERVED24
XBARA1_OUT24 output is reserved.
kXBARA1_OutputRESERVED25
XBARA1_OUT25 output is reserved.
kXBARA1_OutputFlexpwm1Exta0
XBARA1_OUT26 output assigned to FLEXPWM1_EXTA0
kXBARA1_OutputFlexpwm1Exta1
XBARA1_OUT27 output assigned to FLEXPWM1_EXTA1
kXBARA1_OutputFlexpwm1Exta2
XBARA1_OUT28 output assigned to FLEXPWM1_EXTA2
kXBARA1_OutputFlexpwm1Exta3
XBARA1_OUT29 output assigned to FLEXPWM1_EXTA3
kXBARA1_OutputFlexpwm1ExtSync0
XBARA1_OUT30 output assigned to FLEXPWM1_EXT_SYNC0
kXBARA1_OutputFlexpwm1ExtSync1
XBARA1_OUT31 output assigned to FLEXPWM1_EXT_SYNC1
kXBARA1_OutputFlexpwm1ExtSync2
XBARA1_OUT32 output assigned to FLEXPWM1_EXT_SYNC2
kXBARA1_OutputFlexpwm1ExtSync3
XBARA1_OUT33 output assigned to FLEXPWM1_EXT_SYNC3
kXBARA1_OutputFlexpwm1ExtClk
XBARA1_OUT34 output assigned to FLEXPWM1_EXT_CLK
kXBARA1_OutputFlexpwm1Fault0
XBARA1_OUT35 output assigned to FLEXPWM1_FAULT0
kXBARA1_OutputFlexpwm1Fault1
XBARA1_OUT36 output assigned to FLEXPWM1_FAULT1
kXBARA1_OutputFlexpwm1234Fault2
XBARA1_OUT37 output assigned to FLEXPWM1_2_3_4_FAULT2
kXBARA1_OutputFlexpwm1234Fault3
XBARA1_OUT38 output assigned to FLEXPWM1_2_3_4_FAULT3
kXBARA1_OutputFlexpwm1ExtForce
XBARA1_OUT39 output assigned to FLEXPWM1_EXT_FORCE
kXBARA1_OutputFlexpwm234Exta0
XBARA1_OUT40 output assigned to FLEXPWM2_3_4_EXTA0
kXBARA1_OutputFlexpwm234Exta1
XBARA1_OUT41 output assigned to FLEXPWM2_3_4_EXTA1
kXBARA1_OutputFlexpwm234Exta2
XBARA1_OUT42 output assigned to FLEXPWM2_3_4_EXTA2
kXBARA1_OutputFlexpwm234Exta3
XBARA1_OUT43 output assigned to FLEXPWM2_3_4_EXTA3
kXBARA1_OutputFlexpwm2ExtSync0
XBARA1_OUT44 output assigned to FLEXPWM2_EXT_SYNC0
kXBARA1_OutputFlexpwm2ExtSync1
XBARA1_OUT45 output assigned to FLEXPWM2_EXT_SYNC1
kXBARA1_OutputFlexpwm2ExtSync2
XBARA1_OUT46 output assigned to FLEXPWM2_EXT_SYNC2
kXBARA1_OutputFlexpwm2ExtSync3
XBARA1_OUT47 output assigned to FLEXPWM2_EXT_SYNC3
kXBARA1_OutputFlexpwm234ExtClk
XBARA1_OUT48 output assigned to FLEXPWM2_3_4_EXT_CLK
kXBARA1_OutputFlexpwm2Fault0
XBARA1_OUT49 output assigned to FLEXPWM2_FAULT0
kXBARA1_OutputFlexpwm2Fault1
XBARA1_OUT50 output assigned to FLEXPWM2_FAULT1
kXBARA1_OutputFlexpwm2ExtForce
XBARA1_OUT51 output assigned to FLEXPWM2_EXT_FORCE
kXBARA1_OutputFlexpwm3ExtSync0
XBARA1_OUT52 output assigned to FLEXPWM3_EXT_SYNC0
kXBARA1_OutputFlexpwm3ExtSync1
XBARA1_OUT53 output assigned to FLEXPWM3_EXT_SYNC1
kXBARA1_OutputFlexpwm3ExtSync2
XBARA1_OUT54 output assigned to FLEXPWM3_EXT_SYNC2
kXBARA1_OutputFlexpwm3ExtSync3
XBARA1_OUT55 output assigned to FLEXPWM3_EXT_SYNC3
kXBARA1_OutputFlexpwm3Fault0
XBARA1_OUT56 output assigned to FLEXPWM3_FAULT0
kXBARA1_OutputFlexpwm3Fault1
XBARA1_OUT57 output assigned to FLEXPWM3_FAULT1
kXBARA1_OutputFlexpwm3ExtForce
XBARA1_OUT58 output assigned to FLEXPWM3_EXT_FORCE
kXBARA1_OutputFlexpwm4ExtSync0
XBARA1_OUT59 output assigned to FLEXPWM4_EXT_SYNC0
kXBARA1_OutputFlexpwm4ExtSync1
XBARA1_OUT60 output assigned to FLEXPWM4_EXT_SYNC1
kXBARA1_OutputFlexpwm4ExtSync2
XBARA1_OUT61 output assigned to FLEXPWM4_EXT_SYNC2
kXBARA1_OutputFlexpwm4ExtSync3
XBARA1_OUT62 output assigned to FLEXPWM4_EXT_SYNC3
kXBARA1_OutputFlexpwm4Fault0
XBARA1_OUT63 output assigned to FLEXPWM4_FAULT0
kXBARA1_OutputFlexpwm4Fault1
XBARA1_OUT64 output assigned to FLEXPWM4_FAULT1
kXBARA1_OutputFlexpwm4ExtForce
XBARA1_OUT65 output assigned to FLEXPWM4_EXT_FORCE
kXBARA1_OutputEnc1PhaseAInput
XBARA1_OUT66 output assigned to ENC1_PHASE_A_INPUT
kXBARA1_OutputEnc1PhaseBInput
XBARA1_OUT67 output assigned to ENC1_PHASE_B_INPUT
kXBARA1_OutputEnc1Index
XBARA1_OUT68 output assigned to ENC1_INDEX
kXBARA1_OutputEnc1Home
XBARA1_OUT69 output assigned to ENC1_HOME
kXBARA1_OutputEnc1Trigger
XBARA1_OUT70 output assigned to ENC1_TRIGGER
kXBARA1_OutputEnc2PhaseAInput
XBARA1_OUT71 output assigned to ENC2_PHASE_A_INPUT
kXBARA1_OutputEnc2PhaseBInput
XBARA1_OUT72 output assigned to ENC2_PHASE_B_INPUT
kXBARA1_OutputEnc2Index
XBARA1_OUT73 output assigned to ENC2_INDEX
kXBARA1_OutputEnc2Home
XBARA1_OUT74 output assigned to ENC2_HOME
kXBARA1_OutputEnc2Trigger
XBARA1_OUT75 output assigned to ENC2_TRIGGER
kXBARA1_OutputEnc3PhaseAInput
XBARA1_OUT76 output assigned to ENC3_PHASE_A_INPUT
kXBARA1_OutputEnc3PhaseBInput
XBARA1_OUT77 output assigned to ENC3_PHASE_B_INPUT
kXBARA1_OutputEnc3Index
XBARA1_OUT78 output assigned to ENC3_INDEX
kXBARA1_OutputEnc3Home
XBARA1_OUT79 output assigned to ENC3_HOME
kXBARA1_OutputEnc3Trigger
XBARA1_OUT80 output assigned to ENC3_TRIGGER
kXBARA1_OutputEnc4PhaseAInput
XBARA1_OUT81 output assigned to ENC4_PHASE_A_INPUT
kXBARA1_OutputEnc4PhaseBInput
XBARA1_OUT82 output assigned to ENC4_PHASE_B_INPUT
kXBARA1_OutputEnc4Index
XBARA1_OUT83 output assigned to ENC4_INDEX
kXBARA1_OutputEnc4Home
XBARA1_OUT84 output assigned to ENC4_HOME
kXBARA1_OutputEnc4Trigger
XBARA1_OUT85 output assigned to ENC4_TRIGGER
kXBARA1_OutputQtimer1Tmr0Input
XBARA1_OUT86 output assigned to QTIMER1_TMR0_INPUT
kXBARA1_OutputQtimer1Tmr1Input
XBARA1_OUT87 output assigned to QTIMER1_TMR1_INPUT
kXBARA1_OutputQtimer1Tmr2Input
XBARA1_OUT88 output assigned to QTIMER1_TMR2_INPUT
kXBARA1_OutputQtimer1Tmr3Input
XBARA1_OUT89 output assigned to QTIMER1_TMR3_INPUT
kXBARA1_OutputQtimer2Tmr0Input
XBARA1_OUT90 output assigned to QTIMER2_TMR0_INPUT
kXBARA1_OutputQtimer2Tmr1Input
XBARA1_OUT91 output assigned to QTIMER2_TMR1_INPUT
kXBARA1_OutputQtimer2Tmr2Input
XBARA1_OUT92 output assigned to QTIMER2_TMR2_INPUT
kXBARA1_OutputQtimer2Tmr3Input
XBARA1_OUT93 output assigned to QTIMER2_TMR3_INPUT
kXBARA1_OutputQtimer3Tmr0Input
XBARA1_OUT94 output assigned to QTIMER3_TMR0_INPUT
kXBARA1_OutputQtimer3Tmr1Input
XBARA1_OUT95 output assigned to QTIMER3_TMR1_INPUT
kXBARA1_OutputQtimer3Tmr2Input
XBARA1_OUT96 output assigned to QTIMER3_TMR2_INPUT
kXBARA1_OutputQtimer3Tmr3Input
XBARA1_OUT97 output assigned to QTIMER3_TMR3_INPUT
kXBARA1_OutputQtimer4Tmr0Input
XBARA1_OUT98 output assigned to QTIMER4_TMR0_INPUT
kXBARA1_OutputQtimer4Tmr1Input
XBARA1_OUT99 output assigned to QTIMER4_TMR1_INPUT
kXBARA1_OutputQtimer4Tmr2Input
XBARA1_OUT100 output assigned to QTIMER4_TMR2_INPUT
kXBARA1_OutputQtimer4Tmr3Input
XBARA1_OUT101 output assigned to QTIMER4_TMR3_INPUT
kXBARA1_OutputEwmEwmIn
XBARA1_OUT102 output assigned to EWM_EWM_IN
kXBARA1_OutputAdcEtcXbar0Trig0
XBARA1_OUT103 output assigned to ADC_ETC_XBAR0_TRIG0
kXBARA1_OutputAdcEtcXbar0Trig1
XBARA1_OUT104 output assigned to ADC_ETC_XBAR0_TRIG1
kXBARA1_OutputAdcEtcXbar0Trig2
XBARA1_OUT105 output assigned to ADC_ETC_XBAR0_TRIG2
kXBARA1_OutputAdcEtcXbar0Trig3
XBARA1_OUT106 output assigned to ADC_ETC_XBAR0_TRIG3
kXBARA1_OutputAdcEtcXbar1Trig0
XBARA1_OUT107 output assigned to ADC_ETC_XBAR1_TRIG0
kXBARA1_OutputAdcEtcXbar1Trig1
XBARA1_OUT108 output assigned to ADC_ETC_XBAR1_TRIG1
kXBARA1_OutputAdcEtcXbar1Trig2
XBARA1_OUT109 output assigned to ADC_ETC_XBAR1_TRIG2
kXBARA1_OutputAdcEtcXbar1Trig3
XBARA1_OUT110 output assigned to ADC_ETC_XBAR1_TRIG3
kXBARA1_OutputLpi2c1TrgInput
XBARA1_OUT111 output assigned to LPI2C1_TRG_INPUT
kXBARA1_OutputLpi2c2TrgInput
XBARA1_OUT112 output assigned to LPI2C2_TRG_INPUT
kXBARA1_OutputLpi2c3TrgInput
XBARA1_OUT113 output assigned to LPI2C3_TRG_INPUT
kXBARA1_OutputLpi2c4TrgInput
XBARA1_OUT114 output assigned to LPI2C4_TRG_INPUT
kXBARA1_OutputLpspi1TrgInput
XBARA1_OUT115 output assigned to LPSPI1_TRG_INPUT
kXBARA1_OutputLpspi2TrgInput
XBARA1_OUT116 output assigned to LPSPI2_TRG_INPUT
kXBARA1_OutputLpspi3TrgInput
XBARA1_OUT117 output assigned to LPSPI3_TRG_INPUT
kXBARA1_OutputLpspi4TrgInput
XBARA1_OUT118 output assigned to LPSPI4_TRG_INPUT
kXBARA1_OutputLpuart1TrgInput
XBARA1_OUT119 output assigned to LPUART1_TRG_INPUT
kXBARA1_OutputLpuart2TrgInput
XBARA1_OUT120 output assigned to LPUART2_TRG_INPUT
kXBARA1_OutputLpuart3TrgInput
XBARA1_OUT121 output assigned to LPUART3_TRG_INPUT
kXBARA1_OutputLpuart4TrgInput
XBARA1_OUT122 output assigned to LPUART4_TRG_INPUT
kXBARA1_OutputLpuart5TrgInput
XBARA1_OUT123 output assigned to LPUART5_TRG_INPUT
kXBARA1_OutputLpuart6TrgInput
XBARA1_OUT124 output assigned to LPUART6_TRG_INPUT
kXBARA1_OutputLpuart7TrgInput
XBARA1_OUT125 output assigned to LPUART7_TRG_INPUT
kXBARA1_OutputLpuart8TrgInput
XBARA1_OUT126 output assigned to LPUART8_TRG_INPUT
kXBARA1_OutputFlexio1TriggerIn0
XBARA1_OUT127 output assigned to FLEXIO1_TRIGGER_IN0
kXBARA1_OutputFlexio1TriggerIn1
XBARA1_OUT128 output assigned to FLEXIO1_TRIGGER_IN1
kXBARA1_OutputFlexio2TriggerIn0
XBARA1_OUT129 output assigned to FLEXIO2_TRIGGER_IN0
kXBARA1_OutputFlexio2TriggerIn1
XBARA1_OUT130 output assigned to FLEXIO2_TRIGGER_IN1
kXBARB2_OutputAoi1In00
XBARB2_OUT0 output assigned to AOI1_IN00
kXBARB2_OutputAoi1In01
XBARB2_OUT1 output assigned to AOI1_IN01
kXBARB2_OutputAoi1In02
XBARB2_OUT2 output assigned to AOI1_IN02
kXBARB2_OutputAoi1In03
XBARB2_OUT3 output assigned to AOI1_IN03
kXBARB2_OutputAoi1In04
XBARB2_OUT4 output assigned to AOI1_IN04
kXBARB2_OutputAoi1In05
XBARB2_OUT5 output assigned to AOI1_IN05
kXBARB2_OutputAoi1In06
XBARB2_OUT6 output assigned to AOI1_IN06
kXBARB2_OutputAoi1In07
XBARB2_OUT7 output assigned to AOI1_IN07
kXBARB2_OutputAoi1In08
XBARB2_OUT8 output assigned to AOI1_IN08
kXBARB2_OutputAoi1In09
XBARB2_OUT9 output assigned to AOI1_IN09
kXBARB2_OutputAoi1In10
XBARB2_OUT10 output assigned to AOI1_IN10
kXBARB2_OutputAoi1In11
XBARB2_OUT11 output assigned to AOI1_IN11
kXBARB2_OutputAoi1In12
XBARB2_OUT12 output assigned to AOI1_IN12
kXBARB2_OutputAoi1In13
XBARB2_OUT13 output assigned to AOI1_IN13
kXBARB2_OutputAoi1In14
XBARB2_OUT14 output assigned to AOI1_IN14
kXBARB2_OutputAoi1In15
XBARB2_OUT15 output assigned to AOI1_IN15
kXBARB3_OutputAoi2In00
XBARB3_OUT0 output assigned to AOI2_IN00
kXBARB3_OutputAoi2In01
XBARB3_OUT1 output assigned to AOI2_IN01
kXBARB3_OutputAoi2In02
XBARB3_OUT2 output assigned to AOI2_IN02
kXBARB3_OutputAoi2In03
XBARB3_OUT3 output assigned to AOI2_IN03
kXBARB3_OutputAoi2In04
XBARB3_OUT4 output assigned to AOI2_IN04
kXBARB3_OutputAoi2In05
XBARB3_OUT5 output assigned to AOI2_IN05
kXBARB3_OutputAoi2In06
XBARB3_OUT6 output assigned to AOI2_IN06
kXBARB3_OutputAoi2In07
XBARB3_OUT7 output assigned to AOI2_IN07
kXBARB3_OutputAoi2In08
XBARB3_OUT8 output assigned to AOI2_IN08
kXBARB3_OutputAoi2In09
XBARB3_OUT9 output assigned to AOI2_IN09
kXBARB3_OutputAoi2In10
XBARB3_OUT10 output assigned to AOI2_IN10
kXBARB3_OutputAoi2In11
XBARB3_OUT11 output assigned to AOI2_IN11
kXBARB3_OutputAoi2In12
XBARB3_OUT12 output assigned to AOI2_IN12
kXBARB3_OutputAoi2In13
XBARB3_OUT13 output assigned to AOI2_IN13
kXBARB3_OutputAoi2In14
XBARB3_OUT14 output assigned to AOI2_IN14
kXBARB3_OutputAoi2In15
XBARB3_OUT15 output assigned to AOI2_IN15
kXBARA1_OutputDmaChMuxReq81
XBARA1_OUT0 output assigned to DMA_CH_MUX_REQ81
kXBARA1_OutputDmaChMuxReq82
XBARA1_OUT1 output assigned to DMA_CH_MUX_REQ82
kXBARA1_OutputDmaChMuxReq83
XBARA1_OUT2 output assigned to DMA_CH_MUX_REQ83
kXBARA1_OutputDmaChMuxReq84
XBARA1_OUT3 output assigned to DMA_CH_MUX_REQ84
kXBARA1_OutputIomuxXbarInout20
XBARA1_OUT20 output assigned to IOMUX_XBAR_INOUT20
kXBARA1_OutputIomuxXbarInout21
XBARA1_OUT21 output assigned to IOMUX_XBAR_INOUT21
kXBARA1_OutputIomuxXbarInout22
XBARA1_OUT22 output assigned to IOMUX_XBAR_INOUT22
kXBARA1_OutputIomuxXbarInout23
XBARA1_OUT23 output assigned to IOMUX_XBAR_INOUT23
kXBARA1_OutputIomuxXbarInout24
XBARA1_OUT24 output assigned to IOMUX_XBAR_INOUT24
kXBARA1_OutputIomuxXbarInout25
XBARA1_OUT25 output assigned to IOMUX_XBAR_INOUT25
kXBARA1_OutputIomuxXbarInout26
XBARA1_OUT26 output assigned to IOMUX_XBAR_INOUT26
kXBARA1_OutputIomuxXbarInout27
XBARA1_OUT27 output assigned to IOMUX_XBAR_INOUT27
kXBARA1_OutputIomuxXbarInout28
XBARA1_OUT28 output assigned to IOMUX_XBAR_INOUT28
kXBARA1_OutputIomuxXbarInout29
XBARA1_OUT29 output assigned to IOMUX_XBAR_INOUT29
kXBARA1_OutputIomuxXbarInout30
XBARA1_OUT30 output assigned to IOMUX_XBAR_INOUT30
kXBARA1_OutputIomuxXbarInout31
XBARA1_OUT31 output assigned to IOMUX_XBAR_INOUT31
kXBARA1_OutputIomuxXbarInout32
XBARA1_OUT32 output assigned to IOMUX_XBAR_INOUT32
kXBARA1_OutputIomuxXbarInout33
XBARA1_OUT33 output assigned to IOMUX_XBAR_INOUT33
kXBARA1_OutputIomuxXbarInout34
XBARA1_OUT34 output assigned to IOMUX_XBAR_INOUT34
kXBARA1_OutputIomuxXbarInout35
XBARA1_OUT35 output assigned to IOMUX_XBAR_INOUT35
kXBARA1_OutputIomuxXbarInout36
XBARA1_OUT36 output assigned to IOMUX_XBAR_INOUT36
kXBARA1_OutputIomuxXbarInout37
XBARA1_OUT37 output assigned to IOMUX_XBAR_INOUT37
kXBARA1_OutputIomuxXbarInout38
XBARA1_OUT38 output assigned to IOMUX_XBAR_INOUT38
kXBARA1_OutputIomuxXbarInout39
XBARA1_OUT39 output assigned to IOMUX_XBAR_INOUT39
kXBARA1_OutputIomuxXbarInout40
XBARA1_OUT40 output assigned to IOMUX_XBAR_INOUT40
XBARA1_OUT41 output assigned to ACMP1_SAMPLE
XBARA1_OUT42 output assigned to ACMP2_SAMPLE
XBARA1_OUT43 output assigned to ACMP3_SAMPLE
XBARA1_OUT44 output assigned to ACMP4_SAMPLE
kXBARA1_OutputRESERVED45
XBARA1_OUT45 output is reserved.
kXBARA1_OutputRESERVED46
XBARA1_OUT46 output is reserved.
kXBARA1_OutputRESERVED47
XBARA1_OUT47 output is reserved.
kXBARA1_OutputRESERVED48
XBARA1_OUT48 output is reserved.
kXBARA1_OutputFlexpwm1Pwm0Exta
XBARA1_OUT49 output assigned to FLEXPWM1_PWM0_EXTA
kXBARA1_OutputFlexpwm1Pwm1Exta
XBARA1_OUT50 output assigned to FLEXPWM1_PWM1_EXTA
kXBARA1_OutputFlexpwm1Pwm2Exta
XBARA1_OUT51 output assigned to FLEXPWM1_PWM2_EXTA
kXBARA1_OutputFlexpwm1Pwm3Exta
XBARA1_OUT52 output assigned to FLEXPWM1_PWM3_EXTA
kXBARA1_OutputFlexpwm1Pwm0ExtSync
XBARA1_OUT53 output assigned to FLEXPWM1_PWM0_EXT_SYNC
kXBARA1_OutputFlexpwm1Pwm1ExtSync
XBARA1_OUT54 output assigned to FLEXPWM1_PWM1_EXT_SYNC
kXBARA1_OutputFlexpwm1Pwm2ExtSync
XBARA1_OUT55 output assigned to FLEXPWM1_PWM2_EXT_SYNC
kXBARA1_OutputFlexpwm1Pwm3ExtSync
XBARA1_OUT56 output assigned to FLEXPWM1_PWM3_EXT_SYNC
XBARA1_OUT57 output assigned to FLEXPWM1_EXT_CLK
XBARA1_OUT58 output assigned to FLEXPWM1_FAULT0
XBARA1_OUT59 output assigned to FLEXPWM1_FAULT1
XBARA1_OUT60 output assigned to FLEXPWM1_2_3_4_FAULT2
XBARA1_OUT61 output assigned to FLEXPWM1_2_3_4_FAULT3
XBARA1_OUT62 output assigned to FLEXPWM1_EXT_FORCE
kXBARA1_OutputFlexpwm2Pwm0Exta
XBARA1_OUT63 output assigned to FLEXPWM2_PWM0_EXTA
kXBARA1_OutputFlexpwm2Pwm1Exta
XBARA1_OUT64 output assigned to FLEXPWM2_PWM1_EXTA
kXBARA1_OutputFlexpwm2Pwm2Exta
XBARA1_OUT65 output assigned to FLEXPWM2_PWM2_EXTA
kXBARA1_OutputFlexpwm2Pwm3Exta
XBARA1_OUT66 output assigned to FLEXPWM2_PWM3_EXTA
kXBARA1_OutputFlexpwm2Pwm0ExtSync
XBARA1_OUT67 output assigned to FLEXPWM2_PWM0_EXT_SYNC
kXBARA1_OutputFlexpwm2Pwm1ExtSync
XBARA1_OUT68 output assigned to FLEXPWM2_PWM1_EXT_SYNC
kXBARA1_OutputFlexpwm2Pwm2ExtSync
XBARA1_OUT69 output assigned to FLEXPWM2_PWM2_EXT_SYNC
kXBARA1_OutputFlexpwm2Pwm3ExtSync
XBARA1_OUT70 output assigned to FLEXPWM2_PWM3_EXT_SYNC
kXBARA1_OutputFlexpwm2ExtClk
XBARA1_OUT71 output assigned to FLEXPWM2_EXT_CLK
XBARA1_OUT72 output assigned to FLEXPWM2_FAULT0
XBARA1_OUT73 output assigned to FLEXPWM2_FAULT1
XBARA1_OUT74 output assigned to FLEXPWM2_EXT_FORCE
kXBARA1_OutputFlexpwm34Pwm0Exta
XBARA1_OUT75 output assigned to FLEXPWM3_4_PWM0_EXTA
kXBARA1_OutputFlexpwm34Pwm1Exta
XBARA1_OUT76 output assigned to FLEXPWM3_4_PWM1_EXTA
kXBARA1_OutputFlexpwm34Pwm2Exta
XBARA1_OUT77 output assigned to FLEXPWM3_4_PWM2_EXTA
kXBARA1_OutputFlexpwm34Pwm3Exta
XBARA1_OUT78 output assigned to FLEXPWM3_4_PWM3_EXTA
kXBARA1_OutputFlexpwm34ExtClk
XBARA1_OUT79 output assigned to FLEXPWM3_4_EXT_CLK
kXBARA1_OutputFlexpwm3Pwm0ExtSync
XBARA1_OUT80 output assigned to FLEXPWM3_PWM0_EXT_SYNC
kXBARA1_OutputFlexpwm3Pwm1ExtSync
XBARA1_OUT81 output assigned to FLEXPWM3_PWM1_EXT_SYNC
kXBARA1_OutputFlexpwm3Pwm2ExtSync
XBARA1_OUT82 output assigned to FLEXPWM3_PWM2_EXT_SYNC
kXBARA1_OutputFlexpwm3Pwm3ExtSync
XBARA1_OUT83 output assigned to FLEXPWM3_PWM3_EXT_SYNC
XBARA1_OUT84 output assigned to FLEXPWM3_FAULT0
XBARA1_OUT85 output assigned to FLEXPWM3_FAULT1
XBARA1_OUT86 output assigned to FLEXPWM3_EXT_FORCE
kXBARA1_OutputFlexpwm4Pwm0ExtSync
XBARA1_OUT87 output assigned to FLEXPWM4_PWM0_EXT_SYNC
kXBARA1_OutputFlexpwm4Pwm1ExtSync
XBARA1_OUT88 output assigned to FLEXPWM4_PWM1_EXT_SYNC
kXBARA1_OutputFlexpwm4Pwm2ExtSync
XBARA1_OUT89 output assigned to FLEXPWM4_PWM2_EXT_SYNC
kXBARA1_OutputFlexpwm4Pwm3ExtSync
XBARA1_OUT90 output assigned to FLEXPWM4_PWM3_EXT_SYNC
XBARA1_OUT91 output assigned to FLEXPWM4_FAULT0
XBARA1_OUT92 output assigned to FLEXPWM4_FAULT1
XBARA1_OUT93 output assigned to FLEXPWM4_EXT_FORCE
kXBARA1_OutputRESERVED94
XBARA1_OUT94 output is reserved.
kXBARA1_OutputRESERVED95
XBARA1_OUT95 output is reserved.
kXBARA1_OutputRESERVED96
XBARA1_OUT96 output is reserved.
kXBARA1_OutputRESERVED97
XBARA1_OUT97 output is reserved.
kXBARA1_OutputRESERVED98
XBARA1_OUT98 output is reserved.
kXBARA1_OutputRESERVED99
XBARA1_OUT99 output is reserved.
kXBARA1_OutputRESERVED100
XBARA1_OUT100 output is reserved.
kXBARA1_OutputRESERVED101
XBARA1_OUT101 output is reserved.
kXBARA1_OutputRESERVED102
XBARA1_OUT102 output is reserved.
kXBARA1_OutputRESERVED103
XBARA1_OUT103 output is reserved.
kXBARA1_OutputRESERVED104
XBARA1_OUT104 output is reserved.
kXBARA1_OutputRESERVED105
XBARA1_OUT105 output is reserved.
kXBARA1_OutputRESERVED106
XBARA1_OUT106 output is reserved.
kXBARA1_OutputRESERVED107
XBARA1_OUT107 output is reserved.
kXBARA1_OutputDec1Phasea
XBARA1_OUT108 output assigned to DEC1_PHASEA
kXBARA1_OutputDec1Phaseb
XBARA1_OUT109 output assigned to DEC1_PHASEB
kXBARA1_OutputDec1Index
XBARA1_OUT110 output assigned to DEC1_INDEX
kXBARA1_OutputDec1Home
XBARA1_OUT111 output assigned to DEC1_HOME
kXBARA1_OutputDec1Trigger
XBARA1_OUT112 output assigned to DEC1_TRIGGER
kXBARA1_OutputDec2Phasea
XBARA1_OUT113 output assigned to DEC2_PHASEA
kXBARA1_OutputDec2Phaseb
XBARA1_OUT114 output assigned to DEC2_PHASEB
kXBARA1_OutputDec2Index
XBARA1_OUT115 output assigned to DEC2_INDEX
kXBARA1_OutputDec2Home
XBARA1_OUT116 output assigned to DEC2_HOME
kXBARA1_OutputDec2Trigger
XBARA1_OUT117 output assigned to DEC2_TRIGGER
kXBARA1_OutputDec3Phasea
XBARA1_OUT118 output assigned to DEC3_PHASEA
kXBARA1_OutputDec3Phaseb
XBARA1_OUT119 output assigned to DEC3_PHASEB
kXBARA1_OutputDec3Index
XBARA1_OUT120 output assigned to DEC3_INDEX
kXBARA1_OutputDec3Home
XBARA1_OUT121 output assigned to DEC3_HOME
kXBARA1_OutputDec3Trigger
XBARA1_OUT122 output assigned to DEC3_TRIGGER
kXBARA1_OutputDec4Phasea
XBARA1_OUT123 output assigned to DEC4_PHASEA
kXBARA1_OutputDec4Phaseb
XBARA1_OUT124 output assigned to DEC4_PHASEB
kXBARA1_OutputDec4Index
XBARA1_OUT125 output assigned to DEC4_INDEX
kXBARA1_OutputDec4Home
XBARA1_OUT126 output assigned to DEC4_HOME
kXBARA1_OutputDec4Trigger
XBARA1_OUT127 output assigned to DEC4_TRIGGER
kXBARA1_OutputRESERVED128
XBARA1_OUT128 output is reserved.
kXBARA1_OutputRESERVED129
XBARA1_OUT129 output is reserved.
kXBARA1_OutputRESERVED130
XBARA1_OUT130 output is reserved.
kXBARA1_OutputRESERVED131
XBARA1_OUT131 output is reserved.
kXBARA1_OutputCan1
XBARA1_OUT132 output assigned to CAN1
kXBARA1_OutputCan2
XBARA1_OUT133 output assigned to CAN2
kXBARA1_OutputRESERVED134
XBARA1_OUT134 output is reserved.
kXBARA1_OutputRESERVED135
XBARA1_OUT135 output is reserved.
kXBARA1_OutputRESERVED136
XBARA1_OUT136 output is reserved.
kXBARA1_OutputRESERVED137
XBARA1_OUT137 output is reserved.
kXBARA1_OutputQtimer1Timer0
XBARA1_OUT138 output assigned to QTIMER1_TIMER0
kXBARA1_OutputQtimer1Timer1
XBARA1_OUT139 output assigned to QTIMER1_TIMER1
kXBARA1_OutputQtimer1Timer2
XBARA1_OUT140 output assigned to QTIMER1_TIMER2
kXBARA1_OutputQtimer1Timer3
XBARA1_OUT141 output assigned to QTIMER1_TIMER3
kXBARA1_OutputQtimer2Timer0
XBARA1_OUT142 output assigned to QTIMER2_TIMER0
kXBARA1_OutputQtimer2Timer1
XBARA1_OUT143 output assigned to QTIMER2_TIMER1
kXBARA1_OutputQtimer2Timer2
XBARA1_OUT144 output assigned to QTIMER2_TIMER2
kXBARA1_OutputQtimer2Timer3
XBARA1_OUT145 output assigned to QTIMER2_TIMER3
kXBARA1_OutputQtimer3Timer0
XBARA1_OUT146 output assigned to QTIMER3_TIMER0
kXBARA1_OutputQtimer3Timer1
XBARA1_OUT147 output assigned to QTIMER3_TIMER1
kXBARA1_OutputQtimer3Timer2
XBARA1_OUT148 output assigned to QTIMER3_TIMER2
kXBARA1_OutputQtimer3Timer3
XBARA1_OUT149 output assigned to QTIMER3_TIMER3
kXBARA1_OutputQtimer4Timer0
XBARA1_OUT150 output assigned to QTIMER4_TIMER0
kXBARA1_OutputQtimer4Timer1
XBARA1_OUT151 output assigned to QTIMER4_TIMER1
kXBARA1_OutputQtimer4Timer2
XBARA1_OUT152 output assigned to QTIMER4_TIMER2
kXBARA1_OutputQtimer4Timer3
XBARA1_OUT153 output assigned to QTIMER4_TIMER3
XBARA1_OUT154 output assigned to EWM_EWM_IN
kXBARA1_OutputAdcEtc0Coco0
XBARA1_OUT155 output assigned to ADC_ETC0_COCO0
kXBARA1_OutputAdcEtc0Coco1
XBARA1_OUT156 output assigned to ADC_ETC0_COCO1
kXBARA1_OutputAdcEtc0Coco2
XBARA1_OUT157 output assigned to ADC_ETC0_COCO2
kXBARA1_OutputAdcEtc0Coco3
XBARA1_OUT158 output assigned to ADC_ETC0_COCO3
kXBARA1_OutputAdcEtc1Coco0
XBARA1_OUT159 output assigned to ADC_ETC1_COCO0
kXBARA1_OutputAdcEtc1Coco1
XBARA1_OUT160 output assigned to ADC_ETC1_COCO1
kXBARA1_OutputAdcEtc1Coco2
XBARA1_OUT161 output assigned to ADC_ETC1_COCO2
kXBARA1_OutputAdcEtc1Coco3
XBARA1_OUT162 output assigned to ADC_ETC1_COCO3
kXBARA1_OutputRESERVED163
XBARA1_OUT163 output is reserved.
kXBARA1_OutputRESERVED164
XBARA1_OUT164 output is reserved.
kXBARA1_OutputRESERVED165
XBARA1_OUT165 output is reserved.
kXBARA1_OutputRESERVED166
XBARA1_OUT166 output is reserved.
kXBARA1_OutputRESERVED167
XBARA1_OUT167 output is reserved.
kXBARA1_OutputRESERVED168
XBARA1_OUT168 output is reserved.
kXBARA1_OutputRESERVED169
XBARA1_OUT169 output is reserved.
kXBARA1_OutputRESERVED170
XBARA1_OUT170 output is reserved.
kXBARA1_OutputFlexio1TrigIn0
XBARA1_OUT171 output assigned to FLEXIO1_TRIG_IN0
kXBARA1_OutputFlexio1TrigIn1
XBARA1_OUT172 output assigned to FLEXIO1_TRIG_IN1
kXBARA1_OutputFlexio2TrigIn0
XBARA1_OUT173 output assigned to FLEXIO2_TRIG_IN0
kXBARA1_OutputFlexio2TrigIn1
XBARA1_OUT174 output assigned to FLEXIO2_TRIG_IN1
kXBARA1_OutputCan1
kXBARA1_OutputCan2
Variable Documentation
◆ ADD
__O uint32_t CDOG_Type::ADD
ADD Command, offset: 0x2C
◆ ADD1
__O uint32_t CDOG_Type::ADD1
ADD1 Command, offset: 0x30
◆ ADD16
__O uint32_t CDOG_Type::ADD16
ADD16 Command, offset: 0x34
◆ ADD256
__O uint32_t CDOG_Type::ADD256
ADD256 Command, offset: 0x38
◆ ADDR_OFFSET0
__IO uint32_t BEE_Type::ADDR_OFFSET0
Offset region 0 Register, offset: 0x4
◆ ADDR_OFFSET1
__IO uint32_t BEE_Type::ADDR_OFFSET1
Offset region 1 Register, offset: 0x8
◆ ADMA_ERR_STATUS
__I uint32_t USDHC_Type::ADMA_ERR_STATUS
ADMA Error Status, offset: 0x54
◆ ADMA_SYS_ADDR
__IO uint32_t USDHC_Type::ADMA_SYS_ADDR
ADMA System Address, offset: 0x58
◆ AES_KEY0_W0
__IO uint32_t BEE_Type::AES_KEY0_W0
AES Key 0 Register, offset: 0xC
◆ AES_KEY0_W1
__IO uint32_t BEE_Type::AES_KEY0_W1
AES Key 1 Register, offset: 0x10
◆ AES_KEY0_W2
__IO uint32_t BEE_Type::AES_KEY0_W2
AES Key 2 Register, offset: 0x14
◆ AES_KEY0_W3
__IO uint32_t BEE_Type::AES_KEY0_W3
AES Key 3 Register, offset: 0x18
◆ AES_TST_DB
__IO uint32_t IEE_Type::AES_TST_DB
IEE AES Test Mode Data Buffer, array offset: 0xF00, array step: 0x4
◆ AESVID
__I uint32_t IEE_Type::AESVID
IEE AES Version ID Register, offset: 0xF8
◆ AHBBUFREGIONEND0
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONEND0
RX BUF region End address of region 0, offset: 0x444
◆ AHBBUFREGIONEND1
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONEND1
RX BUF region End address of region 1, offset: 0x44C
◆ AHBBUFREGIONEND2
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONEND2
RX BUF region End address of region 2, offset: 0x454
◆ AHBBUFREGIONEND3
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONEND3
RX BUF region End address of region 3, offset: 0x45C
◆ AHBBUFREGIONSTART0
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONSTART0
RX BUF Start address of region 0, offset: 0x440
◆ AHBBUFREGIONSTART1
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONSTART1
RX BUF Start address of region 1, offset: 0x448
◆ AHBBUFREGIONSTART2
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONSTART2
RX BUF Start address of region 2, offset: 0x450
◆ AHBBUFREGIONSTART3
__IO uint32_t FLEXSPI_Type::AHBBUFREGIONSTART3
RX BUF Start address of region 3, offset: 0x458
◆ AHBCR
__IO uint32_t FLEXSPI_Type::AHBCR
AHB Bus Control Register, offset: 0xC
◆ AHBRXBUFCR0
__IO uint32_t FLEXSPI_Type::AHBRXBUFCR0
AHB RX Buffer 0 Control Register 0..AHB RX Buffer 3 Control Register 0, array offset: 0x20, array step: 0x4
AHB RX Buffer 0 Control Register 0..AHB RX Buffer 7 Control Register 0, array offset: 0x20, array step: 0x4
◆ AHBSPNDSTS
__I uint32_t FLEXSPI_Type::AHBSPNDSTS
AHB Suspend Status Register, offset: 0xEC
◆ ALLOW
__I uint32_t PUF_Type::ALLOW
PUF Allow Register, offset: 0x28
◆ ANA0
__IO uint32_t OCOTP_Type::ANA0
Value of OTP Bank 1 Word 5 (Analog Info.), offset: 0x4D0
◆ ANA1
__IO uint32_t OCOTP_Type::ANA1
Value of OTP Bank 1 Word 6 (Analog Info.), offset: 0x4E0
◆ ANA2
__IO uint32_t OCOTP_Type::ANA2
Value of OTP Bank 1 Word 7 (Analog Info.), offset: 0x4F0
◆ ANACTRL
__IO uint32_t USBPHY_Type::ANACTRL
USB PHY Analog Control Register, offset: 0x100
◆ ANACTRL_CLR
__IO uint32_t USBPHY_Type::ANACTRL_CLR
USB PHY Analog Control Register, offset: 0x108
◆ ANACTRL_SET
__IO uint32_t USBPHY_Type::ANACTRL_SET
USB PHY Analog Control Register, offset: 0x104
◆ ANACTRL_TOG
__IO uint32_t USBPHY_Type::ANACTRL_TOG
USB PHY Analog Control Register, offset: 0x10C
◆ ARM_PLL_CTRL
__IO uint32_t ANADIG_PLL_Type::ARM_PLL_CTRL
ARM_PLL_CTRL_REGISTER, offset: 0x200
◆ AS_BUF
__IO uint32_t PXP_Type::AS_BUF
Alpha Surface Buffer Pointer, offset: 0x160
◆ AS_CLRKEYHIGH
__IO uint32_t PXP_Type::AS_CLRKEYHIGH
Overlay Color Key High, offset: 0x190
◆ AS_CLRKEYLOW
__IO uint32_t PXP_Type::AS_CLRKEYLOW
Overlay Color Key Low, offset: 0x180
◆ AS_CTRL
__IO uint32_t PXP_Type::AS_CTRL
Alpha Surface Control, offset: 0x150
◆ AS_PITCH
__IO uint32_t PXP_Type::AS_PITCH
Alpha Surface Pitch, offset: 0x170
◆ ASR56K
__IO uint32_t ASRC_Type::ASR56K
ASRC 56 kHz Period in terms of ASRC processing clock, offset: 0x9C
◆ ASR76K
__IO uint32_t ASRC_Type::ASR76K
ASRC 76 kHz Period in terms of ASRC processing clock, offset: 0x98
◆ ASRCCR
__IO uint32_t ASRC_Type::ASRCCR
ASRC Channel Counter Register, offset: 0x5C
◆ ASRCDR1
__IO uint32_t ASRC_Type::ASRCDR1
ASRC Clock Divider Register 1, offset: 0x18
◆ ASRCDR2
__IO uint32_t ASRC_Type::ASRCDR2
ASRC Clock Divider Register 2, offset: 0x1C
◆ ASRCFG
__IO uint32_t ASRC_Type::ASRCFG
ASRC Filter Configuration Status Register, offset: 0x10
◆ ASRCNCR
__IO uint32_t ASRC_Type::ASRCNCR
ASRC Channel Number Configuration Register, offset: 0xC
◆ ASRCSR
__IO uint32_t ASRC_Type::ASRCSR
ASRC Clock Source Register, offset: 0x14
◆ ASRCTR
__IO uint32_t ASRC_Type::ASRCTR
ASRC Control Register, offset: 0x0
◆ ASRDIA
__O uint32_t ASRC_Type::ASRDIA
ASRC Data Input Register for Pair x, offset: 0x60
◆ ASRDIB
__O uint32_t ASRC_Type::ASRDIB
ASRC Data Input Register for Pair x, offset: 0x68
◆ ASRDIC
__O uint32_t ASRC_Type::ASRDIC
ASRC Data Input Register for Pair x, offset: 0x70
◆ ASRDOA
__I uint32_t ASRC_Type::ASRDOA
ASRC Data Output Register for Pair x, offset: 0x64
◆ ASRDOB
__I uint32_t ASRC_Type::ASRDOB
ASRC Data Output Register for Pair x, offset: 0x6C
◆ ASRDOC
__I uint32_t ASRC_Type::ASRDOC
ASRC Data Output Register for Pair x, offset: 0x74
◆ ASRFSTA
__I uint32_t ASRC_Type::ASRFSTA
ASRC FIFO Status Register for Pair A, offset: 0xA4
◆ ASRFSTB
__I uint32_t ASRC_Type::ASRFSTB
ASRC FIFO Status Register for Pair B, offset: 0xAC
◆ ASRFSTC
__I uint32_t ASRC_Type::ASRFSTC
ASRC FIFO Status Register for Pair C, offset: 0xB4
◆ ASRIDRHA
__IO uint32_t ASRC_Type::ASRIDRHA
ASRC Ideal Ratio for Pair A-High Part, offset: 0x80
◆ ASRIDRHB
__IO uint32_t ASRC_Type::ASRIDRHB
ASRC Ideal Ratio for Pair B-High Part, offset: 0x88
◆ ASRIDRHC
__IO uint32_t ASRC_Type::ASRIDRHC
ASRC Ideal Ratio for Pair C-High Part, offset: 0x90
◆ ASRIDRLA
__IO uint32_t ASRC_Type::ASRIDRLA
ASRC Ideal Ratio for Pair A -Low Part, offset: 0x84
◆ ASRIDRLB
__IO uint32_t ASRC_Type::ASRIDRLB
ASRC Ideal Ratio for Pair B-Low Part, offset: 0x8C
◆ ASRIDRLC
__IO uint32_t ASRC_Type::ASRIDRLC
ASRC Ideal Ratio for Pair C-Low Part, offset: 0x94
◆ ASRIER
__IO uint32_t ASRC_Type::ASRIER
ASRC Interrupt Enable Register, offset: 0x4
◆ ASRMCR1
__IO uint32_t ASRC_Type::ASRMCR1
ASRC Misc Control Register 1 for Pair X, array offset: 0xC0, array step: 0x4
◆ ASRMCRA
__IO uint32_t ASRC_Type::ASRMCRA
ASRC Misc Control Register for Pair A, offset: 0xA0
◆ ASRMCRB
__IO uint32_t ASRC_Type::ASRMCRB
ASRC Misc Control Register for Pair B, offset: 0xA8
◆ ASRMCRC
__IO uint32_t ASRC_Type::ASRMCRC
ASRC Misc Control Register for Pair C, offset: 0xB0
◆ ASRPM
__IO uint32_t ASRC_Type::ASRPM
ASRC Parameter Register n, array offset: 0x40, array step: 0x4
◆ ASRSTR
__I uint32_t ASRC_Type::ASRSTR
ASRC Status Register, offset: 0x20
◆ ASRTFR1
__IO uint32_t ASRC_Type::ASRTFR1
ASRC Task Queue FIFO Register 1, offset: 0x54
◆ ASYNCLISTADDR [1/4]
__IO uint32_t USB_Type::ASYNCLISTADDR
Next Asynch. Address, offset: 0x158
◆  [2/4]
__IO uint32_t { ... } ::ASYNCLISTADDR
◆  [3/4]
◆  [4/4]
◆ ATCOR
__IO uint32_t ENET_Type::ATCOR
Timer Correction Register, offset: 0x410
◆ ATCR
__IO uint32_t ENET_Type::ATCR
Adjustable Timer Control Register, offset: 0x400
◆ ATINC
__IO uint32_t ENET_Type::ATINC
Time-Stamping Clock Period Register, offset: 0x414
◆ ATOFF
__IO uint32_t ENET_Type::ATOFF
Timer Offset Register, offset: 0x408
◆ ATPER
__IO uint32_t ENET_Type::ATPER
Timer Period Register, offset: 0x40C
◆ ATSTMP
__I uint32_t ENET_Type::ATSTMP
Timestamp of Last Transmitted Frame, offset: 0x418
◆ ATTR [1/4]
__IO uint16_t DMA_Type::ATTR
TCD Transfer Attributes, array offset: 0x1006, array step: 0x20
◆  [2/4]
__IO uint16_t { ... } ::ATTR
◆  [3/4]
◆  [4/4]
◆ ATVR
__IO uint32_t ENET_Type::ATVR
Timer Value Register, offset: 0x404
◆  [1/14]
__IO uint32_t { ... } ::AUTHEN
Clock root access control, array offset: 0x30, array step: 0x80
◆ AUTHEN [2/14]
__IO uint32_t CCM_Type::AUTHEN
Clock group access control, array offset: 0x4030, array step: 0x80
GPR access control, array offset: 0x4810, array step: 0x20
Clock source access control, array offset: 0x501C, array step: 0x20
LPCG access control, array offset: 0x601C, array step: 0x20
◆  [3/14]
◆  [4/14]
◆  [5/14]
◆  [6/14]
◆  [7/14]
Observe access control, array offset: 0x30, array step: 0x80
◆ AUTHEN [8/14]
__IO uint32_t CCM_OBS_Type::AUTHEN
◆  [9/14]
◆  [10/14]
◆  [11/14]
◆  [12/14]
◆  [13/14]
◆  [14/14]
◆  [1/10]
__IO uint32_t { ... } ::AUTHEN_CLR
Clock root access control, array offset: 0x38, array step: 0x80
◆ AUTHEN_CLR [2/10]
__IO uint32_t CCM_Type::AUTHEN_CLR
Clock group access control, array offset: 0x4038, array step: 0x80
GPR access control, array offset: 0x4818, array step: 0x20
◆  [3/10]
◆  [4/10]
◆  [5/10]
Observe access control, array offset: 0x38, array step: 0x80
◆ AUTHEN_CLR [6/10]
__IO uint32_t CCM_OBS_Type::AUTHEN_CLR
◆  [7/10]
◆  [8/10]
◆  [9/10]
◆  [10/10]
◆ AUTHEN_DISPLAY
__IO uint32_t SRC_Type::AUTHEN_DISPLAY
Slice Authentication Register, offset: 0x220
◆ AUTHEN_M4CORE
__IO uint32_t SRC_Type::AUTHEN_M4CORE
Slice Authentication Register, offset: 0x280
◆ AUTHEN_M4DEBUG
__IO uint32_t SRC_Type::AUTHEN_M4DEBUG
Slice Authentication Register, offset: 0x2C0
◆ AUTHEN_M7CORE
__IO uint32_t SRC_Type::AUTHEN_M7CORE
Slice Authentication Register, offset: 0x2A0
◆ AUTHEN_M7DEBUG
__IO uint32_t SRC_Type::AUTHEN_M7DEBUG
Slice Authentication Register, offset: 0x2E0
◆ AUTHEN_MEGA
__IO uint32_t SRC_Type::AUTHEN_MEGA
Slice Authentication Register, offset: 0x200
◆ AUTHEN_SET [1/10]
__IO uint32_t CCM_Type::AUTHEN_SET
Clock root access control, array offset: 0x34, array step: 0x80
Clock group access control, array offset: 0x4034, array step: 0x80
GPR access control, array offset: 0x4814, array step: 0x20
◆  [2/10]
__IO uint32_t { ... } ::AUTHEN_SET
◆  [3/10]
◆  [4/10]
◆ AUTHEN_SET [5/10]
__IO uint32_t CCM_OBS_Type::AUTHEN_SET
Observe access control, array offset: 0x34, array step: 0x80
◆  [6/10]
◆  [7/10]
◆  [8/10]
◆  [9/10]
◆  [10/10]
◆ AUTHEN_TOG [1/10]
__IO uint32_t CCM_Type::AUTHEN_TOG
Clock root access control, array offset: 0x3C, array step: 0x80
Clock group access control, array offset: 0x403C, array step: 0x80
GPR access control, array offset: 0x481C, array step: 0x20
◆  [2/10]
__IO uint32_t { ... } ::AUTHEN_TOG
◆  [3/10]
◆  [4/10]
◆ AUTHEN_TOG [5/10]
__IO uint32_t CCM_OBS_Type::AUTHEN_TOG
Observe access control, array offset: 0x3C, array step: 0x80
◆  [6/10]
◆  [7/10]
◆  [8/10]
◆  [9/10]
◆  [10/10]
◆ AUTHEN_USBPHY1
__IO uint32_t SRC_Type::AUTHEN_USBPHY1
Slice Authentication Register, offset: 0x300
◆ AUTHEN_USBPHY2
__IO uint32_t SRC_Type::AUTHEN_USBPHY2
Slice Authentication Register, offset: 0x320
◆ AUTHEN_WAKEUP
__IO uint32_t SRC_Type::AUTHEN_WAKEUP
Slice Authentication Register, offset: 0x240
◆ AUTO_PD_EN
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::AUTO_PD_EN
AUTO_PD_EN, offset: 0x3C
◆ AUTOCMD12_ERR_STATUS
__IO uint32_t USDHC_Type::AUTOCMD12_ERR_STATUS
Auto CMD12 Error Status, offset: 0x3C
◆ BANDGAP_ENABLE_SP
__IO uint32_t ANADIG_PMU_Type::BANDGAP_ENABLE_SP
BANDGAP_ENABLE_SP_REGISTER, offset: 0x6F0
◆ BANDGAP_STBY_EN_SP
__IO uint32_t ANADIG_PMU_Type::BANDGAP_STBY_EN_SP
BANDGAP_STBY_EN_SP_REGISTER, offset: 0x730
◆ BASIC_SETTING
__IO uint32_t TSC_Type::BASIC_SETTING
Basic Setting, offset: 0x0
◆ BAUD
__IO uint32_t LPUART_Type::BAUD
LPUART Baud Rate Register, offset: 0x10
◆ BFCRT01 [1/4]
__IO uint16_t AOI_Type::BFCRT01
Boolean Function Term 0 and 1 Configuration Register for EVENTn, array offset: 0x0, array step: 0x4
◆  [2/4]
__IO uint16_t { ... } ::BFCRT01
◆  [3/4]
◆  [4/4]
◆ BFCRT23 [1/4]
__IO uint16_t AOI_Type::BFCRT23
Boolean Function Term 2 and 3 Configuration Register for EVENTn, array offset: 0x2, array step: 0x4
◆  [2/4]
__IO uint16_t { ... } ::BFCRT23
◆  [3/4]
◆  [4/4]
◆ BGT_VAL
__IO uint32_t EMVSIM_Type::BGT_VAL
Block Guard Time Value Register, offset: 0x40
◆ BIT_ERR
__I uint32_t MIPI_CSI2RX_Type::BIT_ERR
ECC and CRC Error Status Register, offset: 0x108
◆ BIT_LOCK
__IO uint32_t OCOTP_Type::BIT_LOCK
BIT_LOCK Register, offset: 0x150
◆  [1/4]
__IO uint16_t { ... } ::BITER_ELINKNO
TCD Beginning Minor Loop Link, Major Loop Count (Channel Linking Disabled), array offset: 0x101E, array step: 0x20
◆ BITER_ELINKNO [2/4]
__IO uint16_t DMA_Type::BITER_ELINKNO
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint16_t { ... } ::BITER_ELINKYES
TCD Beginning Minor Loop Link, Major Loop Count (Channel Linking Enabled), array offset: 0x101E, array step: 0x20
◆ BITER_ELINKYES [2/4]
__IO uint16_t DMA_Type::BITER_ELINKYES
◆  [3/4]
◆  [4/4]
◆ BLK_ATT
__IO uint32_t USDHC_Type::BLK_ATT
Block Attributes, offset: 0x4
◆ BLLP_MODE
__IO uint32_t DSI_HOST_DPI_INTFC_Type::BLLP_MODE
BLLP_MODE, offset: 0x34
◆ BM_ERROR_STAT
__IO uint32_t LCDIF_Type::BM_ERROR_STAT
Bus Master Error Status Register, offset: 0x190
◆ BMCR0
__IO uint32_t SEMC_Type::BMCR0
Bus (AXI) Master Control Register 0, offset: 0x8
◆ BMCR1
__IO uint32_t SEMC_Type::BMCR1
Bus (AXI) Master Control Register 1, offset: 0xC
◆ BPC_AUTHEN_CTRL
__IO uint32_t PGMC_BPC_Type::BPC_AUTHEN_CTRL
BPC Authentication Control, offset: 0x4
◆ BPC_FLAG
__IO uint32_t PGMC_BPC_Type::BPC_FLAG
BPC flag, offset: 0x2C
◆ BPC_MODE
__IO uint32_t PGMC_BPC_Type::BPC_MODE
BPC Mode, offset: 0x10
◆ BPC_POWER_CTRL
__IO uint32_t PGMC_BPC_Type::BPC_POWER_CTRL
BPC power control, offset: 0x14
◆ BPC_SSAR_RESTORE_CTRL
__IO uint32_t PGMC_BPC_Type::BPC_SSAR_RESTORE_CTRL
BPC SSAR restore control, offset: 0x44
◆ BPC_SSAR_SAVE_CTRL
__IO uint32_t PGMC_BPC_Type::BPC_SSAR_SAVE_CTRL
BPC SSAR save control, offset: 0x40
◆ BR
__IO uint32_t SEMC_Type::BR
Base Register 0 (For SDRAM CS0 device)..Base Register 8 (For NAND device), array offset: 0x10, array step: 0x4
Base Register 0..Base Register 8, array offset: 0x10, array step: 0x4
◆ BR10
__IO uint32_t SEMC_Type::BR10
Base Register 10, offset: 0x104
◆ BR11
__IO uint32_t SEMC_Type::BR11
Base Register 11, offset: 0x108
◆ BR9
__IO uint32_t SEMC_Type::BR9
Base Register 9, offset: 0x100
◆ BURSTSIZE
__IO uint32_t USB_Type::BURSTSIZE
Programmable Burst Size, offset: 0x160
◆ BWT_VAL
__IO uint32_t EMVSIM_Type::BWT_VAL
Block Wait Time Value Register, offset: 0x3C
◆ C0
__IO uint32_t CMP_Type::C0
CMP Control Register 0, offset: 0x8
◆ C1
__IO uint32_t CMP_Type::C1
CMP Control Register 1, offset: 0xC
◆ C2
__IO uint32_t CMP_Type::C2
CMP Control Register 2, offset: 0x10
◆ C3
__IO uint32_t CMP_Type::C3
CMP Control Register 3, offset: 0x14
◆ CA
__IO uint32_t MMCAU_Type::CA[9]
General Purpose Register, array offset: 0x8, array step: 0x4
◆ CAA
__IO uint32_t MMCAU_Type::CAA
Accumulator, offset: 0x4
◆ CAAMVID_LS
__I uint32_t CAAM_Type::CAAMVID_LS
CAAM Version ID Register, least-significant half, offset: 0xFFC
◆ CAAMVID_LS_DC01
__I uint32_t CAAM_Type::CAAMVID_LS_DC01
CAAM Version ID Register, least-significant half, offset: 0x80FFC
◆ CAAMVID_LS_JR [1/3]
__I uint32_t CAAM_Type::CAAMVID_LS_JR
CAAM Version ID Register, least-significant half, array offset: 0x10FFC, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::CAAMVID_LS_JR
◆  [3/3]
◆ CAAMVID_LS_RTIC
__I uint32_t CAAM_Type::CAAMVID_LS_RTIC
CAAM Version ID Register, least-significant half, offset: 0x60FFC
◆ CAAMVID_LS_TRAD
__I uint32_t CAAM_Type::CAAMVID_LS_TRAD
CAAM Version ID Register, least-significant half, offset: 0xBFC
◆ CAAMVID_MS
__I uint32_t CAAM_Type::CAAMVID_MS
CAAM Version ID Register, most-significant half, offset: 0xFF8
◆ CAAMVID_MS_DC01
__I uint32_t CAAM_Type::CAAMVID_MS_DC01
CAAM Version ID Register, most-significant half, offset: 0x80FF8
◆ CAAMVID_MS_JR [1/3]
__I uint32_t CAAM_Type::CAAMVID_MS_JR
CAAM Version ID Register, most-significant half, array offset: 0x10FF8, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::CAAMVID_MS_JR
◆  [3/3]
◆ CAAMVID_MS_RTIC
__I uint32_t CAAM_Type::CAAMVID_MS_RTIC
CAAM Version ID Register, most-significant half, offset: 0x60FF8
◆ CAAMVID_MS_TRAD
__I uint32_t CAAM_Type::CAAMVID_MS_TRAD
CAAM Version ID Register, most-significant half, offset: 0xBF8
◆ CACRR
__IO uint32_t CCM_Type::CACRR
CCM Arm Clock Root Register, offset: 0x10
◆ CAL
__IO uint32_t ADC_Type::CAL
Calibration value register, offset: 0x58
◆ CAPABILITY0
__IO uint32_t DCP_Type::CAPABILITY0
DCP capability 0 register, offset: 0x30
◆ CAPABILITY1
__I uint32_t DCP_Type::CAPABILITY1
DCP capability 1 register, offset: 0x40
◆ CAPLENGTH
__I uint8_t USB_Type::CAPLENGTH
Capability Registers Length, offset: 0x100
◆ CAPT [1/4]
__IO uint16_t TMR_Type::CAPT
Timer Channel Capture Register, array offset: 0x4, array step: 0x20
◆  [2/4]
__IO uint16_t { ... } ::CAPT
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint16_t { ... } ::CAPTCOMPA
Capture Compare A Register, array offset: 0x36, array step: 0x60
◆ CAPTCOMPA [2/4]
__IO uint16_t PWM_Type::CAPTCOMPA
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint16_t { ... } ::CAPTCOMPB
Capture Compare B Register, array offset: 0x3A, array step: 0x60
◆ CAPTCOMPB [2/4]
__IO uint16_t PWM_Type::CAPTCOMPB
◆  [3/4]
◆  [4/4]
◆ CAPTCOMPX [1/4]
__IO uint16_t PWM_Type::CAPTCOMPX
Capture Compare X Register, array offset: 0x3E, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::CAPTCOMPX
◆  [3/4]
◆  [4/4]
◆ CAPTCTRLA [1/4]
__IO uint16_t PWM_Type::CAPTCTRLA
Capture Control A Register, array offset: 0x34, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::CAPTCTRLA
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint16_t { ... } ::CAPTCTRLB
Capture Control B Register, array offset: 0x38, array step: 0x60
◆ CAPTCTRLB [2/4]
__IO uint16_t PWM_Type::CAPTCTRLB
◆  [3/4]
◆  [4/4]
◆ CAPTCTRLX [1/4]
__IO uint16_t PWM_Type::CAPTCTRLX
Capture Control X Register, array offset: 0x3C, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::CAPTCTRLX
◆  [3/4]
◆  [4/4]
◆ CASR
__IO uint32_t MMCAU_Type::CASR
Status Register, offset: 0x0
◆ CBCDR
__IO uint32_t CCM_Type::CBCDR
CCM Bus Clock Divider Register, offset: 0x14
◆ CBCMR
__IO uint32_t CCM_Type::CBCMR
CCM Bus Clock Multiplexer Register, offset: 0x18
◆ CBT
__IO uint32_t CAN_Type::CBT
CAN Bit Timing register, offset: 0x50
◆ CC1AADSZR [1/3]
__IO uint32_t CAAM_Type::CC1AADSZR
CCB 0 Class 1 AAD Size Register, array offset: 0x8005C, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::CC1AADSZR
◆  [3/3]
◆ CC1CTXR [1/3]
__IO uint32_t CAAM_Type::CC1CTXR[16]
CCB 0 Class 1 Context Register Word 0..CCB 0 Class 1 Context Register Word 15, array offset: 0x80100, array step: index*0xE3C, index2*0x4
◆  [2/3]
__IO uint32_t { ... } ::CC1CTXR[16]
◆  [3/3]
◆  [1/3]
__IO uint64_t { ... } ::CC1DSR
CCB 0 Class 1 Data Size Register, array offset: 0x80010, array step: 0xE3C
◆ CC1DSR [2/3]
__IO uint64_t CAAM_Type::CC1DSR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CC1ICVSR
CCB 0 Class 1 ICV Size Register, array offset: 0x8001C, array step: 0xE3C
◆ CC1ICVSR [2/3]
__IO uint32_t CAAM_Type::CC1ICVSR
◆  [3/3]
◆ CC1IVSZR [1/3]
__IO uint32_t CAAM_Type::CC1IVSZR
CCB 0 Class 1 IV Size Register, array offset: 0x80064, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::CC1IVSZR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CC1KR[8]
CCB 0 Class 1 Key Registers Word 0..CCB 0 Class 1 Key Registers Word 7, array offset: 0x80200, array step: index*0xE3C, index2*0x4
◆ CC1KR [2/3]
__IO uint32_t CAAM_Type::CC1KR[8]
◆  [3/3]
◆ CC1KSR [1/3]
__IO uint32_t CAAM_Type::CC1KSR
CCB 0 Class 1 Key Size Register, array offset: 0x8000C, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::CC1KSR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CC1MR
CCB 0 Class 1 Mode Register Format for Non-Public Key Algorithms, array offset: 0x80004, array step: 0xE3C
◆ CC1MR [2/3]
__IO uint32_t CAAM_Type::CC1MR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CC1MR_PK
CCB 0 Class 1 Mode Register Format for Public Key Algorithms, array offset: 0x80004, array step: 0xE3C
◆ CC1MR_PK [2/3]
__IO uint32_t CAAM_Type::CC1MR_PK
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CC1MR_RNG
CCB 0 Class 1 Mode Register Format for RNG4, array offset: 0x80004, array step: 0xE3C
◆ CC1MR_RNG [2/3]
__IO uint32_t CAAM_Type::CC1MR_RNG
◆  [3/3]
◆ CC2CTXR [1/3]
__IO uint32_t CAAM_Type::CC2CTXR[18]
CCB 0 Class 2 Context Register Word 0..CCB 0 Class 2 Context Register Word 17, array offset: 0x80500, array step: index*0xE3C, index2*0x4
◆  [2/3]
__IO uint32_t { ... } ::CC2CTXR[18]
◆  [3/3]
◆ CC2DSR [1/3]
__IO uint64_t CAAM_Type::CC2DSR
CCB 0 Class 2 Data Size Register, array offset: 0x80410, array step: 0xE3C
◆  [2/3]
__IO uint64_t { ... } ::CC2DSR
◆  [3/3]
◆ CC2ICVSZR [1/3]
__IO uint32_t CAAM_Type::CC2ICVSZR
CCB 0 Class 2 ICV Size Register, array offset: 0x8041C, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::CC2ICVSZR
◆  [3/3]
◆ CC2KEYR [1/3]
__IO uint32_t CAAM_Type::CC2KEYR[32]
CCB 0 Class 2 Key Register Word 0..CCB 0 Class 2 Key Register Word 31, array offset: 0x80600, array step: index*0xE3C, index2*0x4
◆  [2/3]
__IO uint32_t { ... } ::CC2KEYR[32]
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CC2KSR
CCB 0 Class 2 Key Size Register, array offset: 0x8040C, array step: 0xE3C
◆ CC2KSR [2/3]
__IO uint32_t CAAM_Type::CC2KSR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CC2MR
CCB 0 Class 2 Mode Register, array offset: 0x80404, array step: 0xE3C
◆ CC2MR [2/3]
__IO uint32_t CAAM_Type::CC2MR
◆  [3/3]
◆ CCBVID
__I uint32_t CAAM_Type::CCBVID
CHA Cluster Block Version ID Register, offset: 0xFE4
◆ CCBVID_DC01
__I uint32_t CAAM_Type::CCBVID_DC01
CHA Cluster Block Version ID Register, offset: 0x80FE4
◆ CCBVID_JR [1/3]
__I uint32_t CAAM_Type::CCBVID_JR
CHA Cluster Block Version ID Register, array offset: 0x10FE4, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::CCBVID_JR
◆  [3/3]
◆ CCBVID_RTIC
__I uint32_t CAAM_Type::CCBVID_RTIC
CHA Cluster Block Version ID Register, offset: 0x60FE4
◆  [1/3]
__O uint32_t { ... } ::CCCTRL
CCB 0 CHA Control Register, array offset: 0x80034, array step: 0xE3C
◆ CCCTRL [2/3]
__O uint32_t CAAM_Type::CCCTRL
◆  [3/3]
◆ CCGR0
__IO uint32_t CCM_Type::CCGR0
CCM Clock Gating Register 0, offset: 0x68
◆ CCGR1
__IO uint32_t CCM_Type::CCGR1
CCM Clock Gating Register 1, offset: 0x6C
◆ CCGR2
__IO uint32_t CCM_Type::CCGR2
CCM Clock Gating Register 2, offset: 0x70
◆ CCGR3
__IO uint32_t CCM_Type::CCGR3
CCM Clock Gating Register 3, offset: 0x74
◆ CCGR4
__IO uint32_t CCM_Type::CCGR4
CCM Clock Gating Register 4, offset: 0x78
◆ CCGR5
__IO uint32_t CCM_Type::CCGR5
CCM Clock Gating Register 5, offset: 0x7C
◆ CCGR6
__IO uint32_t CCM_Type::CCGR6
CCM Clock Gating Register 6, offset: 0x80
◆ CCOSR
__IO uint32_t CCM_Type::CCOSR
CCM Clock Output Source Register, offset: 0x60
◆ CCR [1/2]
__IO uint32_t CCM_Type::CCR
CCM Control Register, offset: 0x0
◆ CCR [2/2]
__IO uint32_t LPSPI_Type::CCR
Clock Configuration Register, offset: 0x40
Clock Configuration, offset: 0x40
◆ CCSR
__IO uint32_t CCM_Type::CCSR
CCM Clock Switcher Register, offset: 0xC
◆  [1/3]
__I uint32_t { ... } ::CCSTA_LS
CCB 0 Status and Error Register, least-significant half, array offset: 0x8004C, array step: 0xE3C
◆ CCSTA_LS [2/3]
__I uint32_t CAAM_Type::CCSTA_LS
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::CCSTA_MS
CCB 0 Status and Error Register, most-significant half, array offset: 0x80048, array step: 0xE3C
◆ CCSTA_MS [2/3]
__I uint32_t CAAM_Type::CCSTA_MS
◆  [3/3]
◆  [1/3]
__O uint32_t { ... } ::CCWR
CCB 0 Clear Written Register, array offset: 0x80044, array step: 0xE3C
◆ CCWR [2/3]
__O uint32_t CAAM_Type::CCWR
◆  [3/3]
◆ CDCDR
__IO uint32_t CCM_Type::CDCDR
CCM D1 Clock Divider Register, offset: 0x30
◆ CDHIPR
__I uint32_t CCM_Type::CDHIPR
CCM Divider Handshake In-Process Register, offset: 0x48
◆ CDNE
__O uint8_t DMA_Type::CDNE
Clear DONE Status Bit, offset: 0x1C
◆ CEEI
__O uint8_t DMA_Type::CEEI
Clear Enable Error Interrupt, offset: 0x18
◆ CERQ
__O uint8_t DMA_Type::CERQ
Clear Enable Request, offset: 0x1A
◆ CERR
__O uint8_t DMA_Type::CERR
Clear Error, offset: 0x1E
◆ CFG [1/2]
__IO uint32_t ADC_Type::CFG
Configuration register, offset: 0x44
LPADC Configuration Register, offset: 0x20
◆ CFG [2/2]
__IO uint32_t PUF_Type::CFG
PUF Configuration Register, offset: 0x10C
◆ CFG0
__IO uint32_t OCOTP_Type::CFG0
Value of OTP Bank0 Word1 (Configuration and Manufacturing Info.), offset: 0x410
◆ CFG1
__IO uint32_t OCOTP_Type::CFG1
Value of OTP Bank0 Word2 (Configuration and Manufacturing Info.), offset: 0x420
◆ CFG2
__IO uint32_t OCOTP_Type::CFG2
Value of OTP Bank0 Word3 (Configuration and Manufacturing Info.), offset: 0x430
◆ CFG3
__IO uint32_t OCOTP_Type::CFG3
Value of OTP Bank0 Word4 (Configuration and Manufacturing Info.), offset: 0x440
◆ CFG4
__IO uint32_t OCOTP_Type::CFG4
Value of OTP Bank0 Word5 (Configuration and Manufacturing Info.), offset: 0x450
◆ CFG5
__IO uint32_t OCOTP_Type::CFG5
Value of OTP Bank0 Word6 (Configuration and Manufacturing Info.), offset: 0x460
◆ CFG6
__IO uint32_t OCOTP_Type::CFG6
Value of OTP Bank0 Word7 (Configuration and Manufacturing Info.), offset: 0x470
◆ CFG_AUTOINSERT_EOTP
__IO uint32_t DSI_HOST_Type::CFG_AUTOINSERT_EOTP
CFG_AUTOINSERT_ETOP, offset: 0x14
◆ CFG_BTA_H_TO_COUNT
__IO uint32_t DSI_HOST_Type::CFG_BTA_H_TO_COUNT
CFG_BTA_H_TO_COUNT, offset: 0x24
◆ CFG_DISABLE_DATA_LANES
__IO uint32_t MIPI_CSI2RX_Type::CFG_DISABLE_DATA_LANES
Disable Data Lane Register, offset: 0x104
◆ CFG_DISABLE_PAYLOAD_0
__IO uint32_t MIPI_CSI2RX_Type::CFG_DISABLE_PAYLOAD_0
Disable Payload 0 Register, offset: 0x12C
◆ CFG_DISABLE_PAYLOAD_1
__IO uint32_t MIPI_CSI2RX_Type::CFG_DISABLE_PAYLOAD_1
Disable Payload 1 Register, offset: 0x130
◆ CFG_EXTRA_CMDS_AFTER_EOTP
__IO uint32_t DSI_HOST_Type::CFG_EXTRA_CMDS_AFTER_EOTP
CFG_EXTRA_CMDS_AFTER_ETOP, offset: 0x18
◆ CFG_HTX_TO_COUNT
__IO uint32_t DSI_HOST_Type::CFG_HTX_TO_COUNT
CFG_HTX_TO_COUNT, offset: 0x1C
◆ CFG_IGNORE_VC
__IO uint32_t MIPI_CSI2RX_Type::CFG_IGNORE_VC
Ignore Virtual Channel Register, offset: 0x180
◆ CFG_LRX_H_TO_COUNT
__IO uint32_t DSI_HOST_Type::CFG_LRX_H_TO_COUNT
CFG_LRX_H_TO_COUNT, offset: 0x20
◆ CFG_NONCONTINUOUS_CLK
__IO uint32_t DSI_HOST_Type::CFG_NONCONTINUOUS_CLK
CFG_NONCONTINUOUS_CLK, offset: 0x4
◆ CFG_NUM_LANES [1/2]
__IO uint32_t DSI_HOST_Type::CFG_NUM_LANES
CFG_NUM_LANES, offset: 0x0
◆ CFG_NUM_LANES [2/2]
__IO uint32_t MIPI_CSI2RX_Type::CFG_NUM_LANES
Lane Configuration Register, offset: 0x100
◆ CFG_STATUS_OUT
__I uint32_t DSI_HOST_Type::CFG_STATUS_OUT
CFG_STATUS_OUT, offset: 0x2C
◆ CFG_T_POST
__IO uint32_t DSI_HOST_Type::CFG_T_POST
CFG_T_POST, offset: 0xC
◆ CFG_T_PRE
__IO uint32_t DSI_HOST_Type::CFG_T_PRE
CFG_T_PRE, offset: 0x8
◆ CFG_TWAKEUP
__IO uint32_t DSI_HOST_Type::CFG_TWAKEUP
CFG_TWAKEUP, offset: 0x28
◆ CFG_TX_GAP
__IO uint32_t DSI_HOST_Type::CFG_TX_GAP
CFG_TX_GAP, offset: 0x10
◆ CFG_VID_HSYNC
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_HSYNC
HSYNC Configuration Register, offset: 0x194
◆ CFG_VID_HSYNC_BP
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_HSYNC_BP
End of HSYNC Delay Control Register, offset: 0x198
◆ CFG_VID_HSYNC_FP
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_HSYNC_FP
Start of HSYNC Delay control Register, offset: 0x190
◆ CFG_VID_P_FIFO_SEND_LEVEL
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_P_FIFO_SEND_LEVEL
FIFO Send Level Configuration Register, offset: 0x188
◆ CFG_VID_VC
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_VC
Virtual Channel value Register, offset: 0x184
◆ CFG_VID_VSYNC
__IO uint32_t MIPI_CSI2RX_Type::CFG_VID_VSYNC
VSYNC Configuration Register, offset: 0x18C
◆ CFGR0
__IO uint32_t LPSPI_Type::CFGR0
Configuration Register 0, offset: 0x20
Configuration 0, offset: 0x20
◆ CFGR1
__IO uint32_t LPSPI_Type::CFGR1
Configuration Register 1, offset: 0x24
Configuration 1, offset: 0x24
◆ CFIFOSTA [1/3]
__I uint32_t CAAM_Type::CFIFOSTA
CCB 0 FIFO Status Register, array offset: 0x807C0, array step: 0xE3C
◆  [2/3]
__I uint32_t { ... } ::CFIFOSTA
◆  [3/3]
◆ CGPR
__IO uint32_t CCM_Type::CGPR
CCM General Purpose Register, offset: 0x64
◆ CH0CMDPTR
__IO uint32_t DCP_Type::CH0CMDPTR
DCP channel 0 command pointer address register, offset: 0x100
◆ CH0OPTS
__IO uint32_t DCP_Type::CH0OPTS
DCP channel 0 options register, offset: 0x130
◆ CH0OPTS_CLR
__IO uint32_t DCP_Type::CH0OPTS_CLR
DCP channel 0 options register, offset: 0x138
◆ CH0OPTS_SET
__IO uint32_t DCP_Type::CH0OPTS_SET
DCP channel 0 options register, offset: 0x134
◆ CH0OPTS_TOG
__IO uint32_t DCP_Type::CH0OPTS_TOG
DCP channel 0 options register, offset: 0x13C
◆ CH0SEMA
__IO uint32_t DCP_Type::CH0SEMA
DCP channel 0 semaphore register, offset: 0x110
◆ CH0STAT
__IO uint32_t DCP_Type::CH0STAT
DCP channel 0 status register, offset: 0x120
◆ CH0STAT_CLR
__IO uint32_t DCP_Type::CH0STAT_CLR
DCP channel 0 status register, offset: 0x128
◆ CH0STAT_SET
__IO uint32_t DCP_Type::CH0STAT_SET
DCP channel 0 status register, offset: 0x124
◆ CH0STAT_TOG
__IO uint32_t DCP_Type::CH0STAT_TOG
DCP channel 0 status register, offset: 0x12C
◆ CH1CMDPTR
__IO uint32_t DCP_Type::CH1CMDPTR
DCP channel 1 command pointer address register, offset: 0x140
◆ CH1OPTS
__IO uint32_t DCP_Type::CH1OPTS
DCP channel 1 options register, offset: 0x170
◆ CH1OPTS_CLR
__IO uint32_t DCP_Type::CH1OPTS_CLR
DCP channel 1 options register, offset: 0x178
◆ CH1OPTS_SET
__IO uint32_t DCP_Type::CH1OPTS_SET
DCP channel 1 options register, offset: 0x174
◆ CH1OPTS_TOG
__IO uint32_t DCP_Type::CH1OPTS_TOG
DCP channel 1 options register, offset: 0x17C
◆ CH1SEMA
__IO uint32_t DCP_Type::CH1SEMA
DCP channel 1 semaphore register, offset: 0x150
◆ CH1STAT
__IO uint32_t DCP_Type::CH1STAT
DCP channel 1 status register, offset: 0x160
◆ CH1STAT_CLR
__IO uint32_t DCP_Type::CH1STAT_CLR
DCP channel 1 status register, offset: 0x168
◆ CH1STAT_SET
__IO uint32_t DCP_Type::CH1STAT_SET
DCP channel 1 status register, offset: 0x164
◆ CH1STAT_TOG
__IO uint32_t DCP_Type::CH1STAT_TOG
DCP channel 1 status register, offset: 0x16C
◆ CH2CMDPTR
__IO uint32_t DCP_Type::CH2CMDPTR
DCP channel 2 command pointer address register, offset: 0x180
◆ CH2OPTS
__IO uint32_t DCP_Type::CH2OPTS
DCP channel 2 options register, offset: 0x1B0
◆ CH2OPTS_CLR
__IO uint32_t DCP_Type::CH2OPTS_CLR
DCP channel 2 options register, offset: 0x1B8
◆ CH2OPTS_SET
__IO uint32_t DCP_Type::CH2OPTS_SET
DCP channel 2 options register, offset: 0x1B4
◆ CH2OPTS_TOG
__IO uint32_t DCP_Type::CH2OPTS_TOG
DCP channel 2 options register, offset: 0x1BC
◆ CH2SEMA
__IO uint32_t DCP_Type::CH2SEMA
DCP channel 2 semaphore register, offset: 0x190
◆ CH2STAT
__IO uint32_t DCP_Type::CH2STAT
DCP channel 2 status register, offset: 0x1A0
◆ CH2STAT_CLR
__IO uint32_t DCP_Type::CH2STAT_CLR
DCP channel 2 status register, offset: 0x1A8
◆ CH2STAT_SET
__IO uint32_t DCP_Type::CH2STAT_SET
DCP channel 2 status register, offset: 0x1A4
◆ CH2STAT_TOG
__IO uint32_t DCP_Type::CH2STAT_TOG
DCP channel 2 status register, offset: 0x1AC
◆ CH3CMDPTR
__IO uint32_t DCP_Type::CH3CMDPTR
DCP channel 3 command pointer address register, offset: 0x1C0
◆ CH3OPTS
__IO uint32_t DCP_Type::CH3OPTS
DCP channel 3 options register, offset: 0x1F0
◆ CH3OPTS_CLR
__IO uint32_t DCP_Type::CH3OPTS_CLR
DCP channel 3 options register, offset: 0x1F8
◆ CH3OPTS_SET
__IO uint32_t DCP_Type::CH3OPTS_SET
DCP channel 3 options register, offset: 0x1F4
◆ CH3OPTS_TOG
__IO uint32_t DCP_Type::CH3OPTS_TOG
DCP channel 3 options register, offset: 0x1FC
◆ CH3SEMA
__IO uint32_t DCP_Type::CH3SEMA
DCP channel 3 semaphore register, offset: 0x1D0
◆ CH3STAT
__IO uint32_t DCP_Type::CH3STAT
DCP channel 3 status register, offset: 0x1E0
◆ CH3STAT_CLR
__IO uint32_t DCP_Type::CH3STAT_CLR
DCP channel 3 status register, offset: 0x1E8
◆ CH3STAT_SET
__IO uint32_t DCP_Type::CH3STAT_SET
DCP channel 3 status register, offset: 0x1E4
◆ CH3STAT_TOG
__IO uint32_t DCP_Type::CH3STAT_TOG
DCP channel 3 status register, offset: 0x1EC
◆ CHANNELCTRL
__IO uint32_t DCP_Type::CHANNELCTRL
DCP channel control register, offset: 0x20
◆ CHANNELCTRL_CLR
__IO uint32_t DCP_Type::CHANNELCTRL_CLR
DCP channel control register, offset: 0x28
◆ CHANNELCTRL_SET
__IO uint32_t DCP_Type::CHANNELCTRL_SET
DCP channel control register, offset: 0x24
◆ CHANNELCTRL_TOG
__IO uint32_t DCP_Type::CHANNELCTRL_TOG
DCP channel control register, offset: 0x2C
◆ CHANUM_LS
__I uint32_t CAAM_Type::CHANUM_LS
CHA Number Register, least-significant half, offset: 0xFF4
◆ CHANUM_LS_DC01
__I uint32_t CAAM_Type::CHANUM_LS_DC01
CHA Number Register, least-significant half, offset: 0x80FF4
◆  [1/3]
__I uint32_t { ... } ::CHANUM_LS_JR
CHA Number Register, least-significant half, array offset: 0x10FF4, array step: 0x10000
◆ CHANUM_LS_JR [2/3]
__I uint32_t CAAM_Type::CHANUM_LS_JR
◆  [3/3]
◆ CHANUM_LS_RTIC
__I uint32_t CAAM_Type::CHANUM_LS_RTIC
CHA Number Register, least-significant half, offset: 0x60FF4
◆ CHANUM_MS
__I uint32_t CAAM_Type::CHANUM_MS
CHA Number Register, most-significant half, offset: 0xFF0
◆ CHANUM_MS_DC01
__I uint32_t CAAM_Type::CHANUM_MS_DC01
CHA Number Register, most-significant half, offset: 0x80FF0
◆ CHANUM_MS_JR [1/3]
__I uint32_t CAAM_Type::CHANUM_MS_JR
CHA Number Register, most-significant half, array offset: 0x10FF0, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::CHANUM_MS_JR
◆  [3/3]
◆ CHANUM_MS_RTIC
__I uint32_t CAAM_Type::CHANUM_MS_RTIC
CHA Number Register, most-significant half, offset: 0x60FF0
◆ CHAVID_LS
__I uint32_t CAAM_Type::CHAVID_LS
CHA Version ID Register, least-significant half, offset: 0xFEC
◆ CHAVID_LS_DC01
__I uint32_t CAAM_Type::CHAVID_LS_DC01
CHA Version ID Register, least-significant half, offset: 0x80FEC
◆ CHAVID_LS_JR [1/3]
__I uint32_t CAAM_Type::CHAVID_LS_JR
CHA Version ID Register, least-significant half, array offset: 0x10FEC, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::CHAVID_LS_JR
◆  [3/3]
◆ CHAVID_LS_RTIC
__I uint32_t CAAM_Type::CHAVID_LS_RTIC
CHA Version ID Register, least-significant half, offset: 0x60FEC
◆ CHAVID_MS
__I uint32_t CAAM_Type::CHAVID_MS
CHA Version ID Register, most-significant half, offset: 0xFE8
◆ CHAVID_MS_DC01
__I uint32_t CAAM_Type::CHAVID_MS_DC01
CHA Version ID Register, most-significant half, offset: 0x80FE8
◆ CHAVID_MS_JR [1/3]
__I uint32_t CAAM_Type::CHAVID_MS_JR
CHA Version ID Register, most-significant half, array offset: 0x10FE8, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::CHAVID_MS_JR
◆  [3/3]
◆ CHAVID_MS_RTIC
__I uint32_t CAAM_Type::CHAVID_MS_RTIC
CHA Version ID Register, most-significant half, offset: 0x60FE8
◆ CHCFG
__IO uint32_t DMAMUX_Type::CHCFG
Channel 0 Configuration Register..Channel 31 Configuration Register, array offset: 0x0, array step: 0x4
◆  [1/2]
__IO uint32_t { ... } ::CHRG_DETECT
USB Charger Detect Register, array offset: 0x1B0, array step: 0x60
◆ CHRG_DETECT [2/2]
__IO uint32_t USB_ANALOG_Type::CHRG_DETECT
◆  [1/2]
__IO uint32_t { ... } ::CHRG_DETECT_CLR
USB Charger Detect Register, array offset: 0x1B8, array step: 0x60
◆ CHRG_DETECT_CLR [2/2]
__IO uint32_t USB_ANALOG_Type::CHRG_DETECT_CLR
◆  [1/2]
__IO uint32_t { ... } ::CHRG_DETECT_SET
USB Charger Detect Register, array offset: 0x1B4, array step: 0x60
◆ CHRG_DETECT_SET [2/2]
__IO uint32_t USB_ANALOG_Type::CHRG_DETECT_SET
◆  [1/2]
__I uint32_t { ... } ::CHRG_DETECT_STAT
USB Charger Detect Status Register, array offset: 0x1D0, array step: 0x60
◆ CHRG_DETECT_STAT [2/2]
__I uint32_t USB_ANALOG_Type::CHRG_DETECT_STAT
◆  [1/2]
__IO uint32_t { ... } ::CHRG_DETECT_TOG
USB Charger Detect Register, array offset: 0x1BC, array step: 0x60
◆ CHRG_DETECT_TOG [2/2]
__IO uint32_t USB_ANALOG_Type::CHRG_DETECT_TOG
◆  [1/3]
__IO uint32_t { ... } ::CICTL
CCB 0 Interrupt Control Register, array offset: 0x8003C, array step: 0xE3C
◆ CICTL [2/3]
__IO uint32_t CAAM_Type::CICTL
◆  [3/3]
◆ CIFIFO [1/3]
__O uint32_t CAAM_Type::CIFIFO
CCB 0 Input Data FIFO, array offset: 0x807E0, array step: 0xE3C
◆  [2/3]
__O uint32_t { ... } ::CIFIFO
◆  [3/3]
◆ CIMR
__IO uint32_t CCM_Type::CIMR
CCM Interrupt Mask Register, offset: 0x5C
◆ CINT
__O uint8_t DMA_Type::CINT
Clear Interrupt Request, offset: 0x1F
◆ CISR
__IO uint32_t CCM_Type::CISR
CCM Interrupt Status Register, offset: 0x58
◆ CITER_ELINKNO [1/4]
__IO uint16_t DMA_Type::CITER_ELINKNO
TCD Current Minor Loop Link, Major Loop Count (Channel Linking Disabled), array offset: 0x1016, array step: 0x20
◆  [2/4]
__IO uint16_t { ... } ::CITER_ELINKNO
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint16_t { ... } ::CITER_ELINKYES
TCD Current Minor Loop Link, Major Loop Count (Channel Linking Enabled), array offset: 0x1016, array step: 0x20
◆ CITER_ELINKYES [2/4]
__IO uint16_t DMA_Type::CITER_ELINKYES
◆  [3/4]
◆  [4/4]
◆ CLK_TUNE_CTRL_STATUS
__IO uint32_t USDHC_Type::CLK_TUNE_CTRL_STATUS
CLK Tuning Control and Status, offset: 0x68
◆ CLKCFG
__IO uint32_t EMVSIM_Type::CLKCFG
Clock Configuration Register, offset: 0x8
◆ CLKCTRL
__IO uint8_t EWM_Type::CLKCTRL
Clock Control Register, offset: 0x4
◆ CLKPRESCALER
__IO uint8_t EWM_Type::CLKPRESCALER
Clock Prescaler Register, offset: 0x5
◆ CLOCK
__IO uint32_t USBHSDCD_Type::CLOCK
Clock register, offset: 0x4
◆ CLPCR
__IO uint32_t CCM_Type::CLPCR
CCM Low Power Control Register, offset: 0x54
◆ CLR [1/69]
__IO uint32_t AUDIO_PLL_Type::CLR
Fractional PLL Control Register, offset: 0x8
Fractional PLL Spread Spectrum Control Register, offset: 0x18
Fractional PLL Numerator Control Register, offset: 0x28
Fractional PLL Denominator Control Register, offset: 0x38
◆  [2/69]
__IO uint32_t { ... } ::CLR
◆  [3/69]
◆  [4/69]
◆  [5/69]
◆ CLR [6/69]
__IO uint32_t CCM_Type::CLR
General Purpose Register, array offset: 0x4808, array step: 0x20
◆  [7/69]
◆ CLR [8/69]
__IO uint32_t ETHERNET_PLL_Type::CLR
◆  [9/69]
◆  [10/69]
◆  [11/69]
◆  [12/69]
◆ CLR [13/69]
__IO uint32_t OSC_RC_400M_Type::CLR
Control Register 1, offset: 0x18
Control Register 2, offset: 0x28
Control Register 3, offset: 0x38
◆  [14/69]
◆  [15/69]
◆  [16/69]
◆  [17/69]
◆  [18/69]
__I uint32_t { ... } ::CLR
Status Register 0, offset: 0x58
◆ CLR [19/69]
__I uint32_t OSC_RC_400M_Type::CLR
Status Register 1, offset: 0x68
Status Register 2, offset: 0x78
◆  [20/69]
◆  [21/69]
◆  [22/69]
Analog Control Register CTRL0, offset: 0x8
◆ CLR [23/69]
__IO uint32_t PHY_LDO_Type::CLR
◆  [24/69]
Analog Status Register STAT0, offset: 0x58
◆ CLR [25/69]
__I uint32_t PHY_LDO_Type::CLR
◆ CLR [26/69]
__IO uint32_t VIDEO_MUX_Type::CLR
Video mux Control Register, offset: 0x8
Pixel Link Master(PLM) Control Register, offset: 0x28
YUV420 Control Register, offset: 0x38
Data Disable Register, offset: 0x58
MIPI DSI Control Register, offset: 0x78
◆  [27/69]
◆  [28/69]
◆  [29/69]
◆  [30/69]
◆  [31/69]
◆ CLR [32/69]
__IO uint32_t VIDEO_PLL_Type::CLR
◆  [33/69]
◆  [34/69]
◆  [35/69]
◆  [36/69]
◆ CLR [37/69]
__IO uint32_t VMBANDGAP_Type::CLR
◆  [38/69]
◆ CLR [39/69]
__I uint32_t VMBANDGAP_Type::CLR
◆  [40/69]
◆  [41/69]
◆  [42/69]
◆  [43/69]
◆  [44/69]
◆  [45/69]
◆  [46/69]
◆  [47/69]
◆  [48/69]
◆  [49/69]
◆  [50/69]
◆  [51/69]
◆  [52/69]
◆  [53/69]
◆  [54/69]
◆  [55/69]
◆  [56/69]
◆  [57/69]
◆  [58/69]
◆  [59/69]
◆  [60/69]
◆  [61/69]
◆  [62/69]
◆  [63/69]
◆  [64/69]
◆  [65/69]
◆  [66/69]
◆  [67/69]
◆  [68/69]
◆  [69/69]
◆ CLUT_LOAD
__IO uint32_t LCDIFV2_Type::CLUT_LOAD
LCDIFv2 CLUT load Register, offset: 0x400
◆ CM
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::CM
CM, offset: 0x28
◆ CM_AUTHEN_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_AUTHEN_CTRL
CM Authentication Control, offset: 0x4
◆ CM_INT_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_INT_CTRL
CM Interrupt Control, offset: 0x8
◆ CM_IRQ_WAKEUP_MASK
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_IRQ_WAKEUP_MASK
CM IRQ0~31 wakeup mask..CM IRQ224~255 wakeup mask, array offset: 0x100, array step: 0x4
◆ CM_IRQ_WAKEUP_STAT
__I uint32_t GPC_CPU_MODE_CTRL_Type::CM_IRQ_WAKEUP_STAT
CM IRQ0~31 wakeup status..CM IRQ224~255 wakeup status, array offset: 0x150, array step: 0x4
◆ CM_MISC
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_MISC
Miscellaneous, offset: 0xC
◆ CM_MODE_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_MODE_CTRL
CPU mode control, offset: 0x10
◆ CM_MODE_STAT
__I uint32_t GPC_CPU_MODE_CTRL_Type::CM_MODE_STAT
CM CPU mode Status, offset: 0x14
◆ CM_NON_IRQ_WAKEUP_MASK
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_NON_IRQ_WAKEUP_MASK
CM non-irq wakeup mask, offset: 0x140
◆ CM_NON_IRQ_WAKEUP_STAT
__I uint32_t GPC_CPU_MODE_CTRL_Type::CM_NON_IRQ_WAKEUP_STAT
CM non-irq wakeup status, offset: 0x190
◆ CM_RUN_MODE_MAPPING
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_RUN_MODE_MAPPING
CM Run Mode Setpoint Allowed, offset: 0x310
◆ CM_SLEEP_ISO_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_ISO_CTRL
CM sleep isolation control, offset: 0x218
◆ CM_SLEEP_LPCG_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_LPCG_CTRL
CM sleep LPCG control, offset: 0x208
◆ CM_SLEEP_PLL_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_PLL_CTRL
CM sleep PLL control, offset: 0x210
◆ CM_SLEEP_POWER_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_POWER_CTRL
CM sleep power control, offset: 0x228
◆ CM_SLEEP_RESET_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_RESET_CTRL
CM sleep reset control, offset: 0x220
◆ CM_SLEEP_SSAR_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SLEEP_SSAR_CTRL
CM sleep SSAR control, offset: 0x200
◆ CM_SP_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SP_CTRL
CM Setpoint Control, offset: 0x300
◆ CM_SP_MAPPING
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SP_MAPPING
CM Setpoint 0 Mapping..CM Setpoint 15 Mapping, array offset: 0x320, array step: 0x4
◆ CM_SP_STAT
__I uint32_t GPC_CPU_MODE_CTRL_Type::CM_SP_STAT
CM Setpoint Status, offset: 0x304
◆ CM_STBY_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_STBY_CTRL
CM standby control, offset: 0x380
◆ CM_STOP_MODE_MAPPING
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_STOP_MODE_MAPPING
CM Stop Mode Setpoint Allowed, offset: 0x318
◆ CM_SUSPEND_MODE_MAPPING
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_SUSPEND_MODE_MAPPING
CM Suspend Mode Setpoint Allowed, offset: 0x31C
◆ CM_WAIT_MODE_MAPPING
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAIT_MODE_MAPPING
CM Wait Mode Setpoint Allowed, offset: 0x314
◆ CM_WAKEUP_ISO_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_ISO_CTRL
CM wakeup isolation control, offset: 0x2A0
◆ CM_WAKEUP_LPCG_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_LPCG_CTRL
CM wakeup LPCG control, offset: 0x2B0
◆ CM_WAKEUP_PLL_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_PLL_CTRL
CM wakeup PLL control, offset: 0x2A8
◆ CM_WAKEUP_POWER_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_POWER_CTRL
CM wakeup power control, offset: 0x290
◆ CM_WAKEUP_RESET_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_RESET_CTRL
CM wakeup reset control, offset: 0x298
◆ CM_WAKEUP_SSAR_CTRL
__IO uint32_t GPC_CPU_MODE_CTRL_Type::CM_WAKEUP_SSAR_CTRL
CM wakeup SSAR control, offset: 0x2B8
◆ CMD_ARG
__IO uint32_t USDHC_Type::CMD_ARG
Command Argument, offset: 0x8
◆ CMD_RSP0
__I uint32_t USDHC_Type::CMD_RSP0
Command Response0, offset: 0x10
◆ CMD_RSP1
__I uint32_t USDHC_Type::CMD_RSP1
Command Response1, offset: 0x14
◆ CMD_RSP2
__I uint32_t USDHC_Type::CMD_RSP2
Command Response2, offset: 0x18
◆ CMD_RSP3
__I uint32_t USDHC_Type::CMD_RSP3
Command Response3, offset: 0x1C
◆ CMD_XFR_TYP
__IO uint32_t USDHC_Type::CMD_XFR_TYP
Command Transfer Type, offset: 0xC
◆  [1/3]
__IO uint32_t { ... } ::CMDH
LPADC Command High Buffer Register, array offset: 0x104, array step: 0x8
◆ CMDH [2/3]
__IO uint32_t ADC_Type::CMDH
◆  [3/3]
◆ CMDL [1/3]
__IO uint32_t ADC_Type::CMDL
LPADC Command Low Buffer Register, array offset: 0x100, array step: 0x8
◆  [2/3]
__IO uint32_t { ... } ::CMDL
◆  [3/3]
◆ CMEOR
__IO uint32_t CCM_Type::CMEOR
CCM Module Enable Overide Register, offset: 0x88
◆ CMPH
__IO uint8_t EWM_Type::CMPH
Compare High Register, offset: 0x3
◆ CMPL
__IO uint8_t EWM_Type::CMPL
Compare Low Register, offset: 0x2
◆  [1/4]
__IO uint16_t { ... } ::CMPLD1
Timer Channel Comparator Load Register 1, array offset: 0x10, array step: 0x20
◆ CMPLD1 [2/4]
__IO uint16_t TMR_Type::CMPLD1
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint16_t { ... } ::CMPLD2
Timer Channel Comparator Load Register 2, array offset: 0x12, array step: 0x20
◆ CMPLD2 [2/4]
__IO uint16_t TMR_Type::CMPLD2
◆  [3/4]
◆  [4/4]
◆ CN
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::CN
CN, offset: 0x24
◆ CNFIFO [1/3]
__O uint32_t CAAM_Type::CNFIFO
CCB 0 iNformation FIFO When STYPE != 10b, array offset: 0x807D0, array step: 0xE3C
◆  [2/3]
__O uint32_t { ... } ::CNFIFO
◆  [3/3]
◆  [1/3]
__O uint32_t { ... } ::CNFIFO_2
CCB 0 iNformation FIFO When STYPE == 10b, array offset: 0x807D0, array step: 0xE3C
◆ CNFIFO_2 [2/3]
__O uint32_t CAAM_Type::CNFIFO_2
◆  [3/3]
◆ CNT [1/6]
__I uint32_t GPT_Type::CNT
GPT Counter Register, offset: 0x24
◆ CNT [2/6]
__I uint16_t PWM_Type::CNT
Counter Register, array offset: 0x0, array step: 0x60
◆  [3/6]
__I uint16_t { ... } ::CNT
◆ CNT [4/6]
__IO uint32_t RTWDOG_Type::CNT
Watchdog Counter Register, offset: 0x4
◆  [5/6]
◆  [6/6]
◆ CNTR [1/5]
__IO uint32_t GPC_Type::CNTR
GPC Interface control register, offset: 0x0
◆ CNTR [2/5]
__IO uint16_t TMR_Type::CNTR
Timer Channel Counter Register, array offset: 0xA, array step: 0x20
◆  [3/5]
__IO uint16_t { ... } ::CNTR
◆  [4/5]
◆  [5/5]
◆ CO
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::CO
CO, offset: 0x2C
◆ CODEINPUT
__O uint32_t PUF_Type::CODEINPUT
PUF Code Input Register, offset: 0x44
◆ CODEOUTPUT
__I uint32_t PUF_Type::CODEOUTPUT
PUF Code Output Register, offset: 0x48
◆  [1/3]
__I uint64_t { ... } ::COFIFO
CCB 0 Output Data FIFO, array offset: 0x807F0, array step: 0xE3C
◆ COFIFO [2/3]
__I uint64_t CAAM_Type::COFIFO
◆  [3/3]
◆  [1/4]
__IO uint16_t { ... } ::COMP1
Timer Channel Compare Register 1, array offset: 0x0, array step: 0x20
◆ COMP1 [2/4]
__IO uint16_t TMR_Type::COMP1
◆  [3/4]
◆  [4/4]
◆ COMP2 [1/4]
__IO uint16_t TMR_Type::COMP2
Timer Channel Compare Register 2, array offset: 0x2, array step: 0x20
◆  [2/4]
__IO uint16_t { ... } ::COMP2
◆  [3/4]
◆  [4/4]
◆ CONFIG [1/9]
__I uint32_t CCM_Type::CONFIG
Clock root configuration, array offset: 0x2C, array step: 0x80
Clock group configuration, array offset: 0x402C, array step: 0x80
Clock source configuration, array offset: 0x5018, array step: 0x20
LPCG configuration, array offset: 0x6018, array step: 0x20
◆  [2/9]
__I uint32_t { ... } ::CONFIG
◆  [3/9]
◆  [4/9]
◆  [5/9]
◆  [6/9]
◆  [7/9]
◆  [8/9]
◆  [9/9]
◆ CONFIGFLAG
__I uint32_t USB_Type::CONFIGFLAG
Configure Flag Register, offset: 0x180
◆ CONTEXT
__IO uint32_t DCP_Type::CONTEXT
DCP context buffer pointer, offset: 0x50
◆  [1/10]
__IO uint32_t { ... } ::CONTROL
Clock root control, array offset: 0x0, array step: 0x80
◆ CONTROL [2/10]
__IO uint32_t CCM_Type::CONTROL
Clock group control, array offset: 0x4000, array step: 0x80
◆  [3/10]
◆  [4/10]
Observe control, array offset: 0x0, array step: 0x80
◆ CONTROL [5/10]
__IO uint32_t CCM_OBS_Type::CONTROL
◆ CONTROL [6/10]
__IO uint32_t CDOG_Type::CONTROL
Control, offset: 0x0
◆ CONTROL [7/10]
__IO uint32_t USBHSDCD_Type::CONTROL
Control register, offset: 0x0
◆  [8/10]
◆  [9/10]
◆  [10/10]
◆ CONTROL_CLR [1/8]
__IO uint32_t CCM_Type::CONTROL_CLR
Clock root control, array offset: 0x8, array step: 0x80
Clock group control, array offset: 0x4008, array step: 0x80
◆  [2/8]
__IO uint32_t { ... } ::CONTROL_CLR
◆  [3/8]
◆ CONTROL_CLR [4/8]
__IO uint32_t CCM_OBS_Type::CONTROL_CLR
Observe control, array offset: 0x8, array step: 0x80
◆  [5/8]
◆  [6/8]
◆  [7/8]
◆  [8/8]
◆ CONTROL_SET [1/8]
__IO uint32_t CCM_Type::CONTROL_SET
Clock root control, array offset: 0x4, array step: 0x80
Clock group control, array offset: 0x4004, array step: 0x80
◆  [2/8]
__IO uint32_t { ... } ::CONTROL_SET
◆  [3/8]
◆ CONTROL_SET [4/8]
__IO uint32_t CCM_OBS_Type::CONTROL_SET
Observe control, array offset: 0x4, array step: 0x80
◆  [5/8]
◆  [6/8]
◆  [7/8]
◆  [8/8]
◆ CONTROL_TOG [1/8]
__IO uint32_t CCM_Type::CONTROL_TOG
Clock root control, array offset: 0xC, array step: 0x80
Clock group control, array offset: 0x400C, array step: 0x80
◆  [2/8]
__IO uint32_t { ... } ::CONTROL_TOG
◆  [3/8]
◆ CONTROL_TOG [4/8]
__IO uint32_t CCM_OBS_Type::CONTROL_TOG
Observe control, array offset: 0xC, array step: 0x80
◆  [5/8]
◆  [6/8]
◆  [7/8]
◆  [8/8]
◆ CPC_AUTHEN_CTRL
__IO uint32_t PGMC_CPC_Type::CPC_AUTHEN_CTRL
CPC Authentication Control, offset: 0x4
◆ CPC_CACHE_CM_CTRL
__IO uint32_t PGMC_CPC_Type::CPC_CACHE_CM_CTRL
CPC cache CPU mode control, offset: 0x44
◆ CPC_CACHE_MODE
__IO uint32_t PGMC_CPC_Type::CPC_CACHE_MODE
CPC Cache Mode, offset: 0x40
◆ CPC_CACHE_SP_CTRL_0
__IO uint32_t PGMC_CPC_Type::CPC_CACHE_SP_CTRL_0
CPC cache Setpoint control 0, offset: 0x48
◆ CPC_CACHE_SP_CTRL_1
__IO uint32_t PGMC_CPC_Type::CPC_CACHE_SP_CTRL_1
CPC cache Setpoint control 1, offset: 0x4C
◆ CPC_CORE_MODE
__IO uint32_t PGMC_CPC_Type::CPC_CORE_MODE
CPC Core Mode, offset: 0x10
◆ CPC_CORE_POWER_CTRL
__IO uint32_t PGMC_CPC_Type::CPC_CORE_POWER_CTRL
CPC core power control, offset: 0x14
◆ CPC_FLAG
__IO uint32_t PGMC_CPC_Type::CPC_FLAG
CPC flag, offset: 0x2C
◆ CPC_LMEM_CM_CTRL
__IO uint32_t PGMC_CPC_Type::CPC_LMEM_CM_CTRL
CPC local memory CPU mode control, offset: 0xC4
◆ CPC_LMEM_MODE
__IO uint32_t PGMC_CPC_Type::CPC_LMEM_MODE
CPC local memory Mode, offset: 0xC0
◆ CPC_LMEM_SP_CTRL_0
__IO uint32_t PGMC_CPC_Type::CPC_LMEM_SP_CTRL_0
CPC local memory Setpoint control 0, offset: 0xC8
◆ CPC_LMEM_SP_CTRL_1
__IO uint32_t PGMC_CPC_Type::CPC_LMEM_SP_CTRL_1
CPC local memory Setpoint control 1, offset: 0xCC
◆ CPINE [1/3]
__IO uint16_t SEMA4_Type::CPINE
Semaphores Processor n IRQ Notification Enable, array offset: 0x40, array step: 0x8
◆  [2/3]
__IO uint16_t { ... } ::CPINE
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CPKASZR
PKHA A Size Register, array offset: 0x80084, array step: 0xE3C
◆ CPKASZR [2/3]
__IO uint32_t CAAM_Type::CPKASZR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CPKBSZR
PKHA B Size Register, array offset: 0x8008C, array step: 0xE3C
◆ CPKBSZR [2/3]
__IO uint32_t CAAM_Type::CPKBSZR
◆  [3/3]
◆ CPKESZR [1/3]
__IO uint32_t CAAM_Type::CPKESZR
PKHA E Size Register, array offset: 0x8009C, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::CPKESZR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CPKNSZR
PKHA N Size Register, array offset: 0x80094, array step: 0xE3C
◆ CPKNSZR [2/3]
__IO uint32_t CAAM_Type::CPKNSZR
◆  [3/3]
◆  [1/3]
__I uint16_t { ... } ::CPNTF
Semaphores Processor n IRQ Notification, array offset: 0x80, array step: 0x8
◆ CPNTF [2/3]
__I uint16_t SEMA4_Type::CPNTF
◆  [3/3]
◆ CPU_CTRL
__IO uint32_t PGC_Type::CPU_CTRL
PGC CPU Control Register, offset: 0x2A0
◆ CPU_PDNSCR
__IO uint32_t PGC_Type::CPU_PDNSCR
PGC CPU Pull Down Sequence Control Register, offset: 0x2A8
◆ CPU_PUPSCR
__IO uint32_t PGC_Type::CPU_PUPSCR
PGC CPU Power Up Sequence Control Register, offset: 0x2A4
◆ CPU_SR
__IO uint32_t PGC_Type::CPU_SR
PGC CPU Power Gating Controller Status Register, offset: 0x2AC
◆ CR [1/8]
__IO uint32_t DMA_Type::CR
◆ CR [2/8]
__IO uint32_t GPT_Type::CR
GPT Control Register, offset: 0x0
◆ CR [3/8]
__IO uint32_t LPSPI_Type::CR
Control, offset: 0x10
◆ CR [4/8]
__IO uint32_t CSI_Type::CR
CSI Control Register, array offset: 0x54, array step: 0x4
◆ CR [5/8]
__IO uint32_t DAC_Type::CR
DAC Status and Control Register, offset: 0xC
◆ CR [6/8]
__IO uint32_t MCM_Type::CR
◆ CR [7/8]
__IO uint32_t MU_Type::CR
Processor B Control Register, offset: 0x24
Processor A Control Register, offset: 0x24
◆ CR [8/8]
__IO uint32_t OTFAD_Type::CR
Control Register, offset: 0xC00
◆ CR0
__IO uint8_t CMP_Type::CR0
CMP Control Register 0, offset: 0x0
◆ CR1 [1/2]
__IO uint8_t CMP_Type::CR1
CMP Control Register 1, offset: 0x1
◆ CR1 [2/2]
__IO uint32_t CSI_Type::CR1
CSI Control Register 1, offset: 0x0
◆ CR18
__IO uint32_t CSI_Type::CR18
CSI Control Register 18, offset: 0x48
◆ CR19
__IO uint32_t CSI_Type::CR19
CSI Control Register 19, offset: 0x4C
◆ CR2 [1/2]
__IO uint32_t CSI_Type::CR2
CSI Control Register 2, offset: 0x4
◆ CR2 [2/2]
__IO uint32_t DAC_Type::CR2
DAC Status and Control Register 2, offset: 0x14
◆ CR20
__IO uint32_t CSI_Type::CR20
CSI Control Register 20, offset: 0x50
◆ CR3
__IO uint32_t CSI_Type::CR3
CSI Control Register 3, offset: 0x8
◆ CRC_STAT
__IO uint32_t LCDIF_Type::CRC_STAT
CRC Status Register, offset: 0x1A0
◆ CRCR
__I uint32_t CAN_Type::CRCR
CRC Register, offset: 0x44
CRC register, offset: 0x44
◆ CRNR_LS
__I uint32_t CAAM_Type::CRNR_LS
CHA Revision Number Register, least-significant half, offset: 0xFA4
◆ CRNR_LS_DC01
__I uint32_t CAAM_Type::CRNR_LS_DC01
CHA Revision Number Register, least-significant half, offset: 0x80FA4
◆ CRNR_LS_JR [1/3]
__I uint32_t CAAM_Type::CRNR_LS_JR
CHA Revision Number Register, least-significant half, array offset: 0x10FA4, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::CRNR_LS_JR
◆  [3/3]
◆ CRNR_LS_RTIC
__I uint32_t CAAM_Type::CRNR_LS_RTIC
CHA Revision Number Register, least-significant half, offset: 0x60FA4
◆ CRNR_MS
__I uint32_t CAAM_Type::CRNR_MS
CHA Revision Number Register, most-significant half, offset: 0xFA0
◆ CRNR_MS_DC01
__I uint32_t CAAM_Type::CRNR_MS_DC01
CHA Revision Number Register, most-significant half, offset: 0x80FA0
◆  [1/3]
__I uint32_t { ... } ::CRNR_MS_JR
CHA Revision Number Register, most-significant half, array offset: 0x10FA0, array step: 0x10000
◆ CRNR_MS_JR [2/3]
__I uint32_t CAAM_Type::CRNR_MS_JR
◆  [3/3]
◆ CRNR_MS_RTIC
__I uint32_t CAAM_Type::CRNR_MS_RTIC
CHA Revision Number Register, most-significant half, offset: 0x60FA0
◆ CS [1/19]
__IO uint32_t CAN_Type::CS
Message Buffer 0 CS Register..Message Buffer 63 CS Register, array offset: 0x80, array step: 0x10
Message Buffer 0 CS Register..Message Buffer 20 CS Register, array offset: 0x80, array step: 0x18
Message Buffer 0 CS Register..Message Buffer 20 CS Register, array offset: 0x280, array step: 0x18
Message Buffer 0 CS Register..Message Buffer 11 CS Register, array offset: 0x80, array step: 0x28
Message Buffer 0 CS Register..Message Buffer 11 CS Register, array offset: 0x280, array step: 0x28
Message Buffer 0 CS Register..Message Buffer 6 CS Register, array offset: 0x80, array step: 0x48
Message Buffer 0 CS Register..Message Buffer 6 CS Register, array offset: 0x280, array step: 0x48
◆  [2/19]
__IO uint32_t { ... } ::CS
◆ CS [3/19]
__IO uint32_t RTWDOG_Type::CS
Watchdog Control and Status Register, offset: 0x0
◆  [4/19]
◆  [5/19]
◆  [6/19]
◆  [7/19]
◆  [8/19]
◆  [9/19]
◆  [10/19]
◆  [11/19]
◆  [12/19]
◆  [13/19]
◆  [14/19]
◆  [15/19]
◆  [16/19]
◆  [17/19]
◆  [18/19]
◆  [19/19]
◆ CS1CDR
__IO uint32_t CCM_Type::CS1CDR
CCM Clock Divider Register, offset: 0x28
◆ CS2CDR
__IO uint32_t CCM_Type::CS2CDR
CCM Clock Divider Register, offset: 0x2C
◆ CSC1_COEF0
__IO uint32_t PXP_Type::CSC1_COEF0
Color Space Conversion Coefficient Register 0, offset: 0x1A0
◆ CSC1_COEF1
__IO uint32_t PXP_Type::CSC1_COEF1
Color Space Conversion Coefficient Register 1, offset: 0x1B0
◆ CSC1_COEF2
__IO uint32_t PXP_Type::CSC1_COEF2
Color Space Conversion Coefficient Register 2, offset: 0x1C0
◆  [1/3]
__IO uint32_t { ... } ::CSC_COEF0
Color Space Conversion Coefficient Register 0, array offset: 0x218, array step: 0x40, this item is not available for all array instances
◆ CSC_COEF0 [2/3]
__IO uint32_t LCDIFV2_Type::CSC_COEF0
◆  [3/3]
◆ CSC_COEF1 [1/3]
__IO uint32_t LCDIFV2_Type::CSC_COEF1
Color Space Conversion Coefficient Register 1, array offset: 0x21C, array step: 0x40, this item is not available for all array instances
◆  [2/3]
__IO uint32_t { ... } ::CSC_COEF1
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CSC_COEF2
Color Space Conversion Coefficient Register 2, array offset: 0x220, array step: 0x40, this item is not available for all array instances
◆ CSC_COEF2 [2/3]
__IO uint32_t LCDIFV2_Type::CSC_COEF2
◆  [3/3]
◆ CSCDR1
__IO uint32_t CCM_Type::CSCDR1
CCM Serial Clock Divider Register 1, offset: 0x24
◆ CSCDR2
__IO uint32_t CCM_Type::CSCDR2
CCM Serial Clock Divider Register 2, offset: 0x38
◆ CSCDR3
__IO uint32_t CCM_Type::CSCDR3
CCM Serial Clock Divider Register 3, offset: 0x3C
◆ CSCMR1
__IO uint32_t CCM_Type::CSCMR1
CCM Serial Clock Multiplexer Register 1, offset: 0x1C
◆ CSCMR2
__IO uint32_t CCM_Type::CSCMR2
CCM Serial Clock Multiplexer Register 2, offset: 0x20
◆ CSCTRL [1/4]
__IO uint16_t TMR_Type::CSCTRL
Timer Channel Comparator Status and Control Register, array offset: 0x14, array step: 0x20
◆  [2/4]
__IO uint16_t { ... } ::CSCTRL
◆  [3/4]
◆  [4/4]
◆ CSL
__IO uint32_t CSU_Type::CSL[32]
Config security level register, array offset: 0x0, array step: 0x4
◆ CSR [1/5]
__I uint32_t CCM_Type::CSR
CCM Status Register, offset: 0x8
◆  [2/5]
__IO uint16_t { ... } ::CSR
TCD Control and Status, array offset: 0x101C, array step: 0x20
◆ CSR [3/5]
__IO uint16_t DMA_Type::CSR
◆  [4/5]
◆  [5/5]
◆ CSTA
__I uint32_t CAAM_Type::CSTA
CAAM Status Register, offset: 0xFD4
◆ CSTA_DC01
__I uint32_t CAAM_Type::CSTA_DC01
CAAM Status Register, offset: 0x80FD4
◆  [1/3]
__I uint32_t { ... } ::CSTA_JR
CAAM Status Register, array offset: 0x10FD4, array step: 0x10000
◆ CSTA_JR [2/3]
__I uint32_t CAAM_Type::CSTA_JR
◆  [3/3]
◆ CSTA_RTIC
__I uint32_t CAAM_Type::CSTA_RTIC
CAAM Status Register, offset: 0x60FD4
◆ CTPR_LS
__I uint32_t CAAM_Type::CTPR_LS
Compile Time Parameters Register, least-significant half, offset: 0xFAC
◆ CTPR_LS_DC01
__I uint32_t CAAM_Type::CTPR_LS_DC01
Compile Time Parameters Register, least-significant half, offset: 0x80FAC
◆  [1/3]
__I uint32_t { ... } ::CTPR_LS_JR
Compile Time Parameters Register, least-significant half, array offset: 0x10FAC, array step: 0x10000
◆ CTPR_LS_JR [2/3]
__I uint32_t CAAM_Type::CTPR_LS_JR
◆  [3/3]
◆ CTPR_LS_RTIC
__I uint32_t CAAM_Type::CTPR_LS_RTIC
Compile Time Parameters Register, least-significant half, offset: 0x60FAC
◆ CTPR_MS
__I uint32_t CAAM_Type::CTPR_MS
Compile Time Parameters Register, most-significant half, offset: 0xFA8
◆ CTPR_MS_DC01
__I uint32_t CAAM_Type::CTPR_MS_DC01
Compile Time Parameters Register, most-significant half, offset: 0x80FA8
◆  [1/3]
__I uint32_t { ... } ::CTPR_MS_JR
Compile Time Parameters Register, most-significant half, array offset: 0x10FA8, array step: 0x10000
◆ CTPR_MS_JR [2/3]
__I uint32_t CAAM_Type::CTPR_MS_JR
◆  [3/3]
◆ CTPR_MS_RTIC
__I uint32_t CAAM_Type::CTPR_MS_RTIC
Compile Time Parameters Register, most-significant half, offset: 0x60FA8
◆ CTR [1/3]
__IO uint32_t OTFAD_Type::CTR[2]
AES Counter Word, array offset: 0xD10, array step: index*0x40, index2*0x4
◆  [2/3]
__IO uint32_t { ... } ::CTR[2]
◆  [3/3]
◆ CTR_NONCE0_W0
__O uint32_t BEE_Type::CTR_NONCE0_W0
NONCE00 Register, offset: 0x20
◆ CTR_NONCE0_W1
__O uint32_t BEE_Type::CTR_NONCE0_W1
NONCE01 Register, offset: 0x24
◆ CTR_NONCE0_W2
__O uint32_t BEE_Type::CTR_NONCE0_W2
NONCE02 Register, offset: 0x28
◆ CTR_NONCE0_W3
__O uint32_t BEE_Type::CTR_NONCE0_W3
NONCE03 Register, offset: 0x2C
◆ CTR_NONCE1_W0
__O uint32_t BEE_Type::CTR_NONCE1_W0
NONCE10 Register, offset: 0x30
◆ CTR_NONCE1_W1
__O uint32_t BEE_Type::CTR_NONCE1_W1
NONCE11 Register, offset: 0x34
◆ CTR_NONCE1_W2
__O uint32_t BEE_Type::CTR_NONCE1_W2
NONCE12 Register, offset: 0x38
◆ CTR_NONCE1_W3
__O uint32_t BEE_Type::CTR_NONCE1_W3
NONCE13 Register, offset: 0x3C
◆ CTRL [1/25]
__IO uint32_t ADC_ETC_Type::CTRL
ADC_ETC Global Control Register, offset: 0x0
◆ CTRL [2/25]
__IO uint32_t BEE_Type::CTRL
◆ CTRL [3/25]
__IO uint32_t DCP_Type::CTRL
DCP control register 0, offset: 0x0
◆ CTRL [4/25]
__IO uint16_t ENC_Type::CTRL
◆ CTRL [5/25]
__IO uint8_t EWM_Type::CTRL
◆ CTRL [6/25]
__IO uint32_t FLEXIO_Type::CTRL
FlexIO Control Register, offset: 0x8
◆ CTRL [7/25]
__IO uint32_t LCDIF_Type::CTRL
LCDIF General Control Register, offset: 0x0
◆ CTRL [8/25]
__IO uint32_t LPUART_Type::CTRL
LPUART Control Register, offset: 0x18
◆ CTRL [9/25]
__IO uint32_t OCOTP_Type::CTRL
OTP Controller Control and Status Register, offset: 0x0
◆ CTRL [10/25]
__IO uint16_t PWM_Type::CTRL
Control Register, array offset: 0x6, array step: 0x60
◆  [11/25]
__IO uint16_t { ... } ::CTRL
◆ CTRL [12/25]
__IO uint32_t PXP_Type::CTRL
◆  [13/25]
Timer Channel Control Register, array offset: 0xC, array step: 0x20
◆ CTRL [14/25]
__IO uint16_t TMR_Type::CTRL
◆ CTRL [15/25]
__IO uint32_t USBPHY_Type::CTRL
USB PHY General Control Register, offset: 0x30
◆ CTRL [16/25]
__IO uint32_t ADC_Type::CTRL
LPADC Control Register, offset: 0x10
◆ CTRL [17/25]
__IO uint32_t EMVSIM_Type::CTRL
◆ CTRL [18/25]
__IO uint32_t LCDIFV2_Type::CTRL
LCDIFv2 display control Register, offset: 0x0
◆ CTRL [19/25]
__IO uint32_t PUF_Type::CTRL
PUF Control Register, offset: 0x0
◆  [20/25]
◆ CTRL [21/25]
__IO uint32_t SRAM_Type::CTRL
Control Register, offset: 0x3000
◆ CTRL [22/25]
__IO uint32_t SSARC_LP_Type::CTRL
Control Register, offset: 0x200
◆  [23/25]
◆  [24/25]
◆  [25/25]
◆ CTRL0 [1/3]
__IO uint16_t XBARA_Type::CTRL0
Crossbar A Control Register 0, offset: 0x84
Crossbar A Control Register 0, offset: 0xB0
◆ CTRL0 [2/3]
__IO uint32_t DCDC_Type::CTRL0
DCDC Control Register 0, offset: 0x0
◆ CTRL0 [3/3]
__IO uint32_t TMPSNS_Type::CTRL0
Temperature Sensor Control Register 0, offset: 0x0
◆ CTRL0_CLR
__IO uint32_t TMPSNS_Type::CTRL0_CLR
Temperature Sensor Control Register 0, offset: 0x8
◆ CTRL0_SET
__IO uint32_t TMPSNS_Type::CTRL0_SET
Temperature Sensor Control Register 0, offset: 0x4
◆ CTRL0_TOG
__IO uint32_t TMPSNS_Type::CTRL0_TOG
Temperature Sensor Control Register 0, offset: 0xC
◆ CTRL1 [1/6]
__IO uint32_t CAN_Type::CTRL1
Control 1 Register, offset: 0x4
Control 1 register, offset: 0x4
◆ CTRL1 [2/6]
__IO uint32_t LCDIF_Type::CTRL1
LCDIF General Control1 Register, offset: 0x10
◆ CTRL1 [3/6]
__IO uint16_t XBARA_Type::CTRL1
Crossbar A Control Register 1, offset: 0x86
Crossbar A Control Register 1, offset: 0xB2
◆ CTRL1 [4/6]
__IO uint32_t DCDC_Type::CTRL1
DCDC Control Register 1, offset: 0x4
◆ CTRL1 [5/6]
__IO uint32_t TMPSNS_Type::CTRL1
Temperature Sensor Control Register 1, offset: 0x10
◆ CTRL1 [6/6]
__IO uint32_t USBNC_Type::CTRL1
USB OTG Control 1 Register, offset: 0x0
◆ CTRL1_CLR [1/2]
__IO uint32_t LCDIF_Type::CTRL1_CLR
LCDIF General Control1 Register, offset: 0x18
◆ CTRL1_CLR [2/2]
__IO uint32_t TMPSNS_Type::CTRL1_CLR
Temperature Sensor Control Register 1, offset: 0x18
◆ CTRL1_SET [1/2]
__IO uint32_t LCDIF_Type::CTRL1_SET
LCDIF General Control1 Register, offset: 0x14
◆ CTRL1_SET [2/2]
__IO uint32_t TMPSNS_Type::CTRL1_SET
Temperature Sensor Control Register 1, offset: 0x14
◆ CTRL1_TOG [1/2]
__IO uint32_t LCDIF_Type::CTRL1_TOG
LCDIF General Control1 Register, offset: 0x1C
◆ CTRL1_TOG [2/2]
__IO uint32_t TMPSNS_Type::CTRL1_TOG
Temperature Sensor Control Register 1, offset: 0x1C
◆ CTRL2 [1/8]
__IO uint32_t CAN_Type::CTRL2
Control 2 Register, offset: 0x34
Control 2 register, offset: 0x34
◆ CTRL2 [2/8]
__IO uint16_t ENC_Type::CTRL2
Control 2 Register, offset: 0x1E
◆ CTRL2 [3/8]
__IO uint32_t LCDIF_Type::CTRL2
LCDIF General Control2 Register, offset: 0x20
◆ CTRL2 [4/8]
__IO uint16_t PWM_Type::CTRL2
Control 2 Register, array offset: 0x4, array step: 0x60
◆  [5/8]
__IO uint16_t { ... } ::CTRL2
◆  [6/8]
◆ CTRL2 [7/8]
__IO uint32_t USBNC_Type::CTRL2
USB OTG Control 2 Register, offset: 0x4
◆  [8/8]
◆ CTRL2_CLR
__IO uint32_t LCDIF_Type::CTRL2_CLR
LCDIF General Control2 Register, offset: 0x28
◆ CTRL2_SET
__IO uint32_t LCDIF_Type::CTRL2_SET
LCDIF General Control2 Register, offset: 0x24
◆ CTRL2_TOG
__IO uint32_t LCDIF_Type::CTRL2_TOG
LCDIF General Control2 Register, offset: 0x2C
◆ CTRL3
__IO uint16_t ENC_Type::CTRL3
Control 3 Register, offset: 0x32
◆ CTRL_1
__IO uint32_t PDM_Type::CTRL_1
PDM Control register 1, offset: 0x0
◆ CTRL_2
__IO uint32_t PDM_Type::CTRL_2
PDM Control register 2, offset: 0x4
◆ CTRL_CLR [1/6]
__IO uint32_t DCP_Type::CTRL_CLR
DCP control register 0, offset: 0x8
◆ CTRL_CLR [2/6]
__IO uint32_t LCDIF_Type::CTRL_CLR
LCDIF General Control Register, offset: 0x8
◆ CTRL_CLR [3/6]
__IO uint32_t OCOTP_Type::CTRL_CLR
OTP Controller Control and Status Register, offset: 0x8
◆ CTRL_CLR [4/6]
__IO uint32_t PXP_Type::CTRL_CLR
◆ CTRL_CLR [5/6]
__IO uint32_t USBPHY_Type::CTRL_CLR
USB PHY General Control Register, offset: 0x38
◆ CTRL_CLR [6/6]
__IO uint32_t LCDIFV2_Type::CTRL_CLR
LCDIFv2 display control Register, offset: 0x8
◆ CTRL_DISPLAY
__IO uint32_t SRC_Type::CTRL_DISPLAY
Slice Control Register, offset: 0x224
◆ CTRL_M4CORE
__IO uint32_t SRC_Type::CTRL_M4CORE
Slice Control Register, offset: 0x284
◆ CTRL_M4DEBUG
__IO uint32_t SRC_Type::CTRL_M4DEBUG
Slice Control Register, offset: 0x2C4
◆ CTRL_M7CORE
__IO uint32_t SRC_Type::CTRL_M7CORE
Slice Control Register, offset: 0x2A4
◆ CTRL_M7DEBUG
__IO uint32_t SRC_Type::CTRL_M7DEBUG
Slice Control Register, offset: 0x2E4
◆ CTRL_MEGA
__IO uint32_t SRC_Type::CTRL_MEGA
Slice Control Register, offset: 0x204
◆ CTRL_SET [1/6]
__IO uint32_t DCP_Type::CTRL_SET
DCP control register 0, offset: 0x4
◆ CTRL_SET [2/6]
__IO uint32_t LCDIF_Type::CTRL_SET
LCDIF General Control Register, offset: 0x4
◆ CTRL_SET [3/6]
__IO uint32_t OCOTP_Type::CTRL_SET
OTP Controller Control and Status Register, offset: 0x4
◆ CTRL_SET [4/6]
__IO uint32_t PXP_Type::CTRL_SET
◆ CTRL_SET [5/6]
__IO uint32_t USBPHY_Type::CTRL_SET
USB PHY General Control Register, offset: 0x34
◆ CTRL_SET [6/6]
__IO uint32_t LCDIFV2_Type::CTRL_SET
LCDIFv2 display control Register, offset: 0x4
◆ CTRL_TOG [1/6]
__IO uint32_t DCP_Type::CTRL_TOG
DCP control register 0, offset: 0xC
◆ CTRL_TOG [2/6]
__IO uint32_t LCDIF_Type::CTRL_TOG
LCDIF General Control Register, offset: 0xC
◆ CTRL_TOG [3/6]
__IO uint32_t OCOTP_Type::CTRL_TOG
OTP Controller Control and Status Register, offset: 0xC
◆ CTRL_TOG [4/6]
__IO uint32_t PXP_Type::CTRL_TOG
◆ CTRL_TOG [5/6]
__IO uint32_t USBPHY_Type::CTRL_TOG
USB PHY General Control Register, offset: 0x3C
◆ CTRL_TOG [6/6]
__IO uint32_t LCDIFV2_Type::CTRL_TOG
LCDIFv2 display control Register, offset: 0xC
◆ CTRL_USBPHY1
__IO uint32_t SRC_Type::CTRL_USBPHY1
Slice Control Register, offset: 0x304
◆ CTRL_USBPHY2
__IO uint32_t SRC_Type::CTRL_USBPHY2
Slice Control Register, offset: 0x324
◆ CTRL_WAKEUP
__IO uint32_t SRC_Type::CTRL_WAKEUP
Slice Control Register, offset: 0x244
◆ CTRLDESCL1 [1/3]
__IO uint32_t LCDIFV2_Type::CTRLDESCL1
Control Descriptor Layer 1 Register, array offset: 0x200, array step: 0x40
◆  [2/3]
__IO uint32_t { ... } ::CTRLDESCL1
◆  [3/3]
◆ CTRLDESCL2 [1/3]
__IO uint32_t LCDIFV2_Type::CTRLDESCL2
Control Descriptor Layer 2 Register, array offset: 0x204, array step: 0x40
◆  [2/3]
__IO uint32_t { ... } ::CTRLDESCL2
◆  [3/3]
◆ CTRLDESCL3 [1/3]
__IO uint32_t LCDIFV2_Type::CTRLDESCL3
Control Descriptor Layer 3 Register, array offset: 0x208, array step: 0x40
◆  [2/3]
__IO uint32_t { ... } ::CTRLDESCL3
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CTRLDESCL4
Control Descriptor Layer 4 Register, array offset: 0x20C, array step: 0x40
◆ CTRLDESCL4 [2/3]
__IO uint32_t LCDIFV2_Type::CTRLDESCL4
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CTRLDESCL5
Control Descriptor Layer 5 Register, array offset: 0x210, array step: 0x40
◆ CTRLDESCL5 [2/3]
__IO uint32_t LCDIFV2_Type::CTRLDESCL5
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::CTRLDESCL6
Control Descriptor Layer 6 Register, array offset: 0x214, array step: 0x40
◆ CTRLDESCL6 [2/3]
__IO uint32_t LCDIFV2_Type::CTRLDESCL6
◆  [3/3]
◆ CUR_BUF
__IO uint32_t LCDIF_Type::CUR_BUF
LCD Interface Current Buffer Address Register, offset: 0x40
◆ CV
__IO uint32_t ADC_Type::CV
Compare value register, offset: 0x50
Compare Value Register, array offset: 0x200, array step: 0x4
◆ CVAL [1/4]
__I uint32_t PIT_Type::CVAL
Current Timer Value Register, array offset: 0x104, array step: 0x10
◆  [2/4]
__I uint32_t { ... } ::CVAL
◆  [3/4]
◆  [4/4]
◆ CVAL0 [1/4]
__I uint16_t PWM_Type::CVAL0
Capture Value 0 Register, array offset: 0x40, array step: 0x60
◆  [2/4]
__I uint16_t { ... } ::CVAL0
◆  [3/4]
◆  [4/4]
◆  [1/4]
__I uint16_t { ... } ::CVAL0CYC
Capture Value 0 Cycle Register, array offset: 0x42, array step: 0x60
◆ CVAL0CYC [2/4]
__I uint16_t PWM_Type::CVAL0CYC
◆  [3/4]
◆  [4/4]
◆  [1/4]
__I uint16_t { ... } ::CVAL1
Capture Value 1 Register, array offset: 0x44, array step: 0x60
◆ CVAL1 [2/4]
__I uint16_t PWM_Type::CVAL1
◆  [3/4]
◆  [4/4]
◆ CVAL1CYC [1/4]
__I uint16_t PWM_Type::CVAL1CYC
Capture Value 1 Cycle Register, array offset: 0x46, array step: 0x60
◆  [2/4]
__I uint16_t { ... } ::CVAL1CYC
◆  [3/4]
◆  [4/4]
◆ CVAL2 [1/4]
__I uint16_t PWM_Type::CVAL2
Capture Value 2 Register, array offset: 0x48, array step: 0x60
◆  [2/4]
__I uint16_t { ... } ::CVAL2
◆  [3/4]
◆  [4/4]
◆ CVAL2CYC [1/4]
__I uint16_t PWM_Type::CVAL2CYC
Capture Value 2 Cycle Register, array offset: 0x4A, array step: 0x60
◆  [2/4]
__I uint16_t { ... } ::CVAL2CYC
◆  [3/4]
◆  [4/4]
◆ CVAL3 [1/4]
__I uint16_t PWM_Type::CVAL3
Capture Value 3 Register, array offset: 0x4C, array step: 0x60
◆  [2/4]
__I uint16_t { ... } ::CVAL3
◆  [3/4]
◆  [4/4]
◆ CVAL3CYC [1/4]
__I uint16_t PWM_Type::CVAL3CYC
Capture Value 3 Cycle Register, array offset: 0x4E, array step: 0x60
◆  [2/4]
__I uint16_t { ... } ::CVAL3CYC
◆  [3/4]
◆  [4/4]
◆ CVAL4 [1/4]
__I uint16_t PWM_Type::CVAL4
Capture Value 4 Register, array offset: 0x50, array step: 0x60
◆  [2/4]
__I uint16_t { ... } ::CVAL4
◆  [3/4]
◆  [4/4]
◆  [1/4]
__I uint16_t { ... } ::CVAL4CYC
Capture Value 4 Cycle Register, array offset: 0x52, array step: 0x60
◆ CVAL4CYC [2/4]
__I uint16_t PWM_Type::CVAL4CYC
◆  [3/4]
◆  [4/4]
◆ CVAL5 [1/4]
__I uint16_t PWM_Type::CVAL5
Capture Value 5 Register, array offset: 0x54, array step: 0x60
◆  [2/4]
__I uint16_t { ... } ::CVAL5
◆  [3/4]
◆  [4/4]
◆ CVAL5CYC [1/4]
__I uint16_t PWM_Type::CVAL5CYC
Capture Value 5 Cycle Register, array offset: 0x56, array step: 0x60
◆  [2/4]
__I uint16_t { ... } ::CVAL5CYC
◆  [3/4]
◆  [4/4]
◆ CWT_VAL
__IO uint32_t EMVSIM_Type::CWT_VAL
Character Wait Time Value Register, offset: 0x38
◆ D0TCM_ECC_MULTI_ERROR_ADDR
__I uint32_t FLEXRAM_Type::D0TCM_ECC_MULTI_ERROR_ADDR
D0TCM multi-bit ECC Error Address Register, offset: 0x6C
◆ D0TCM_ECC_MULTI_ERROR_DATA
__I uint32_t FLEXRAM_Type::D0TCM_ECC_MULTI_ERROR_DATA
D0TCM multi-bit ECC Error Data Register, offset: 0x70
◆ D0TCM_ECC_MULTI_ERROR_INFO
__I uint32_t FLEXRAM_Type::D0TCM_ECC_MULTI_ERROR_INFO
D0TCM multi-bit ECC Error Information Register, offset: 0x68
◆ D0TCM_ECC_SINGLE_ERROR_ADDR
__I uint32_t FLEXRAM_Type::D0TCM_ECC_SINGLE_ERROR_ADDR
D0TCM single-bit ECC Error Address Register, offset: 0x60
◆ D0TCM_ECC_SINGLE_ERROR_DATA
__I uint32_t FLEXRAM_Type::D0TCM_ECC_SINGLE_ERROR_DATA
D0TCM single-bit ECC Error Data Register, offset: 0x64
◆ D0TCM_ECC_SINGLE_ERROR_INFO
__I uint32_t FLEXRAM_Type::D0TCM_ECC_SINGLE_ERROR_INFO
D0TCM single-bit ECC Error Information Register, offset: 0x5C
◆ D1TCM_ECC_MULTI_ERROR_ADDR
__I uint32_t FLEXRAM_Type::D1TCM_ECC_MULTI_ERROR_ADDR
D1TCM multi-bit ECC Error Address Register, offset: 0x84
◆ D1TCM_ECC_MULTI_ERROR_DATA
__I uint32_t FLEXRAM_Type::D1TCM_ECC_MULTI_ERROR_DATA
D1TCM multi-bit ECC Error Data Register, offset: 0x88
◆ D1TCM_ECC_MULTI_ERROR_INFO
__I uint32_t FLEXRAM_Type::D1TCM_ECC_MULTI_ERROR_INFO
D1TCM multi-bit ECC Error Information Register, offset: 0x80
◆ D1TCM_ECC_SINGLE_ERROR_ADDR
__I uint32_t FLEXRAM_Type::D1TCM_ECC_SINGLE_ERROR_ADDR
D1TCM single-bit ECC Error Address Register, offset: 0x78
◆ D1TCM_ECC_SINGLE_ERROR_DATA
__I uint32_t FLEXRAM_Type::D1TCM_ECC_SINGLE_ERROR_DATA
D1TCM single-bit ECC Error Data Register, offset: 0x7C
◆ D1TCM_ECC_SINGLE_ERROR_INFO
__I uint32_t FLEXRAM_Type::D1TCM_ECC_SINGLE_ERROR_INFO
D1TCM single-bit ECC Error Information Register, offset: 0x74
◆ DACCR
__IO uint8_t CMP_Type::DACCR
DAC Control Register, offset: 0x4
◆ DADDR [1/4]
__IO uint32_t DMA_Type::DADDR
TCD Destination Address, array offset: 0x1010, array step: 0x20
◆  [2/4]
__IO uint32_t { ... } ::DADDR
◆  [3/4]
◆  [4/4]
◆ DAR
__IO uint32_t CAAM_Type::DAR
DECO Availability Register, offset: 0x120
◆ DATA [1/3]
__IO uint32_t LPUART_Type::DATA
LPUART Data Register, offset: 0x1C
◆ DATA [2/3]
__IO uint32_t OCOTP_Type::DATA
OTP Controller Write Data Register, offset: 0x20
◆ DATA [3/3]
__O uint32_t DAC_Type::DATA
DAC Data Register, offset: 0x8
◆ DATA_BUFF_ACC_PORT
__IO uint32_t USDHC_Type::DATA_BUFF_ACC_PORT
Data Buffer Access Port, offset: 0x20
◆ DATACH
__I uint32_t PDM_Type::DATACH
PDM Output Result Register, array offset: 0x24, array step: 0x4
◆ DBG1
__I uint32_t CAN_Type::DBG1
Debug 1 register, offset: 0x58
◆ DBG2
__I uint32_t CAN_Type::DBG2
Debug 2 register, offset: 0x5C
◆ DBGDATA
__I uint32_t DCP_Type::DBGDATA
DCP debug data register, offset: 0x410
◆ DBGSELECT
__IO uint32_t DCP_Type::DBGSELECT
DCP debug select register, offset: 0x400
◆ DBICR0
__IO uint32_t SEMC_Type::DBICR0
DBI-B control register 0, offset: 0x80
DBI-B Control Register 0, offset: 0x80
◆ DBICR1
__IO uint32_t SEMC_Type::DBICR1
DBI-B control register 1, offset: 0x84
DBI-B Control Register 1, offset: 0x84
◆ DBICR2
__IO uint32_t SEMC_Type::DBICR2
DBI-B Control Register 2, offset: 0x88
◆ DC_CTRL
__IO uint32_t PDM_Type::DC_CTRL
PDM DC Remover Control register, offset: 0x64
◆ DCCPARAMS
__I uint32_t USB_Type::DCCPARAMS
Device Controller Capability Parameters, offset: 0x124
◆ DCCR
__IO uint32_t SEMC_Type::DCCR
Delay Chain Control Register, offset: 0x150
◆ DCHPRI0
__IO uint8_t DMA_Type::DCHPRI0
Channel Priority, offset: 0x103
◆ DCHPRI1
__IO uint8_t DMA_Type::DCHPRI1
Channel Priority, offset: 0x102
◆ DCHPRI10
__IO uint8_t DMA_Type::DCHPRI10
Channel Priority, offset: 0x109
◆ DCHPRI11
__IO uint8_t DMA_Type::DCHPRI11
Channel Priority, offset: 0x108
◆ DCHPRI12
__IO uint8_t DMA_Type::DCHPRI12
Channel Priority, offset: 0x10F
◆ DCHPRI13
__IO uint8_t DMA_Type::DCHPRI13
Channel Priority, offset: 0x10E
◆ DCHPRI14
__IO uint8_t DMA_Type::DCHPRI14
Channel Priority, offset: 0x10D
◆ DCHPRI15
__IO uint8_t DMA_Type::DCHPRI15
Channel Priority, offset: 0x10C
◆ DCHPRI16
__IO uint8_t DMA_Type::DCHPRI16
Channel Priority, offset: 0x113
◆ DCHPRI17
__IO uint8_t DMA_Type::DCHPRI17
Channel Priority, offset: 0x112
◆ DCHPRI18
__IO uint8_t DMA_Type::DCHPRI18
Channel Priority, offset: 0x111
◆ DCHPRI19
__IO uint8_t DMA_Type::DCHPRI19
Channel Priority, offset: 0x110
◆ DCHPRI2
__IO uint8_t DMA_Type::DCHPRI2
Channel Priority, offset: 0x101
◆ DCHPRI20
__IO uint8_t DMA_Type::DCHPRI20
Channel Priority, offset: 0x117
◆ DCHPRI21
__IO uint8_t DMA_Type::DCHPRI21
Channel Priority, offset: 0x116
◆ DCHPRI22
__IO uint8_t DMA_Type::DCHPRI22
Channel Priority, offset: 0x115
◆ DCHPRI23
__IO uint8_t DMA_Type::DCHPRI23
Channel Priority, offset: 0x114
◆ DCHPRI24
__IO uint8_t DMA_Type::DCHPRI24
Channel Priority, offset: 0x11B
◆ DCHPRI25
__IO uint8_t DMA_Type::DCHPRI25
Channel Priority, offset: 0x11A
◆ DCHPRI26
__IO uint8_t DMA_Type::DCHPRI26
Channel Priority, offset: 0x119
◆ DCHPRI27
__IO uint8_t DMA_Type::DCHPRI27
Channel Priority, offset: 0x118
◆ DCHPRI28
__IO uint8_t DMA_Type::DCHPRI28
Channel Priority, offset: 0x11F
◆ DCHPRI29
__IO uint8_t DMA_Type::DCHPRI29
Channel Priority, offset: 0x11E
◆ DCHPRI3
__IO uint8_t DMA_Type::DCHPRI3
Channel Priority, offset: 0x100
◆ DCHPRI30
__IO uint8_t DMA_Type::DCHPRI30
Channel Priority, offset: 0x11D
◆ DCHPRI31
__IO uint8_t DMA_Type::DCHPRI31
Channel Priority, offset: 0x11C
◆ DCHPRI4
__IO uint8_t DMA_Type::DCHPRI4
Channel Priority, offset: 0x107
◆ DCHPRI5
__IO uint8_t DMA_Type::DCHPRI5
Channel Priority, offset: 0x106
◆ DCHPRI6
__IO uint8_t DMA_Type::DCHPRI6
Channel Priority, offset: 0x105
◆ DCHPRI7
__IO uint8_t DMA_Type::DCHPRI7
Channel Priority, offset: 0x104
◆ DCHPRI8
__IO uint8_t DMA_Type::DCHPRI8
Channel Priority, offset: 0x10B
◆ DCHPRI9
__IO uint8_t DMA_Type::DCHPRI9
Channel Priority, offset: 0x10A
◆ DCICC
__IO uint32_t DCIC_Type::DCICC
DCIC Control Register, offset: 0x0
◆ DCICIC
__IO uint32_t DCIC_Type::DCICIC
DCIC Interrupt Control Register, offset: 0x4
◆ DCICRC [1/3]
__IO uint32_t DCIC_Type::DCICRC
DCIC ROI Config Register, array offset: 0x10, array step: 0x10
◆  [2/3]
__IO uint32_t { ... } ::DCICRC
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::DCICRCS
DCIC ROI Calculated Signature Register, array offset: 0x1C, array step: 0x10
◆ DCICRCS [2/3]
__I uint32_t DCIC_Type::DCICRCS
◆  [3/3]
◆ DCICRRS [1/3]
__IO uint32_t DCIC_Type::DCICRRS
DCIC ROI Reference Signature Register, array offset: 0x18, array step: 0x10
◆  [2/3]
__IO uint32_t { ... } ::DCICRRS
◆  [3/3]
◆ DCICRS [1/3]
__IO uint32_t DCIC_Type::DCICRS
DCIC ROI Size Register, array offset: 0x14, array step: 0x10
◆  [2/3]
__IO uint32_t { ... } ::DCICRS
◆  [3/3]
◆ DCICS
__IO uint32_t DCIC_Type::DCICS
DCIC Status Register, offset: 0x8
◆ DCIVERSION
__I uint16_t USB_Type::DCIVERSION
Device Controller Interface Version, offset: 0x120
◆ DDAR [1/3]
__I uint64_t CAAM_Type::DDAR
DECO0 Descriptor Address Register, array offset: 0x80808, array step: 0xE3C
◆  [2/3]
__I uint64_t { ... } ::DDAR
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::DDDR
DECO0 Debug DECO Register, array offset: 0x80E04, array step: 0xE3C
◆ DDDR [2/3]
__I uint32_t CAAM_Type::DDDR
◆  [3/3]
◆ DDDR_LS [1/3]
__I uint32_t CAAM_Type::DDDR_LS
DECO0 Debug DID, least-significant half, array offset: 0x80E1C, array step: 0xE3C
◆  [2/3]
__I uint32_t { ... } ::DDDR_LS
◆  [3/3]
◆ DDDR_MS [1/3]
__I uint32_t CAAM_Type::DDDR_MS
DECO0 Debug DID, most-significant half, array offset: 0x80E18, array step: 0xE3C
◆  [2/3]
__I uint32_t { ... } ::DDDR_MS
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::DDESB[64]
DECO0 Descriptor Buffer Word 0..DECO0 Descriptor Buffer Word 63, array offset: 0x80A00, array step: index*0xE3C, index2*0x4
◆ DDESB [2/3]
__IO uint32_t CAAM_Type::DDESB[64]
◆  [3/3]
◆  [1/3]
__I uint64_t { ... } ::DDJP
DECO0 Debug Job Pointer, array offset: 0x80E08, array step: 0xE3C
◆ DDJP [2/3]
__I uint64_t CAAM_Type::DDJP
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::DDJR
DECO0 Debug Job Register, array offset: 0x80E00, array step: 0xE3C
◆ DDJR [2/3]
__I uint32_t CAAM_Type::DDJR
◆  [3/3]
◆ DE
__IO uint32_t ADC_Type::DE
DMA Enable Register, offset: 0x1C
◆ DEBUG0_STATUS
__I uint32_t USBPHY_Type::DEBUG0_STATUS
UTMI Debug Status Register 0, offset: 0x60
◆ DEBUG1
__IO uint32_t USBPHY_Type::DEBUG1
UTMI Debug Status Register 1, offset: 0x70
◆ DEBUG1_CLR
__IO uint32_t USBPHY_Type::DEBUG1_CLR
UTMI Debug Status Register 1, offset: 0x78
◆ DEBUG1_SET
__IO uint32_t USBPHY_Type::DEBUG1_SET
UTMI Debug Status Register 1, offset: 0x74
◆ DEBUG1_TOG
__IO uint32_t USBPHY_Type::DEBUG1_TOG
UTMI Debug Status Register 1, offset: 0x7C
◆ DEBUG_CLR
__IO uint32_t USBPHY_Type::DEBUG_CLR
USB PHY Debug Register, offset: 0x58
◆ DEBUG_MODE
__IO uint32_t TSC_Type::DEBUG_MODE
Debug Mode Register, offset: 0x70
◆ DEBUG_MODE2
__IO uint32_t TSC_Type::DEBUG_MODE2
Debug Mode Register 2, offset: 0x80
◆ DEBUG_SET
__IO uint32_t USBPHY_Type::DEBUG_SET
USB PHY Debug Register, offset: 0x54
◆ DEBUG_TOG
__IO uint32_t USBPHY_Type::DEBUG_TOG
USB PHY Debug Register, offset: 0x5C
◆ DEBUGCTL
__IO uint32_t CAAM_Type::DEBUGCTL
Debug Control Register, offset: 0x58
◆ DEBUGr
__IO uint32_t USBPHY_Type::DEBUGr
USB PHY Debug Register, offset: 0x50, 'r' suffix has been added to avoid clash with DEBUG symbolic constant
◆ DECODID_LS [1/3]
__IO uint32_t CAAM_Type::DECODID_LS
DECO0 DID Register - least significant half, array offset: 0xA4, array step: 0x8
◆  [2/3]
__IO uint32_t { ... } ::DECODID_LS
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::DECODID_MS
DECO0 DID Register - most significant half, array offset: 0xA0, array step: 0x8
◆ DECODID_MS [2/3]
__IO uint32_t CAAM_Type::DECODID_MS
◆  [3/3]
◆ DECORR
__IO uint32_t CAAM_Type::DECORR
DECO Request Register, offset: 0x9C
◆ DECORSR
__IO uint32_t CAAM_Type::DECORSR
DECO Request Source Register, offset: 0x94
◆ DER
__IO uint32_t LPSPI_Type::DER
DMA Enable, offset: 0x1C
◆  [1/3]
__IO uint32_t { ... } ::DESC_ADDR_DOWN
Descriptor Address Down 0 Register..Descriptor Address Down 15 Register, array offset: 0xC, array step: 0x20
◆ DESC_ADDR_DOWN [2/3]
__IO uint32_t SSARC_LP_Type::DESC_ADDR_DOWN
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::DESC_ADDR_UP
Descriptor Address Up 0 Register..Descriptor Address Up 15 Register, array offset: 0x8, array step: 0x20
◆ DESC_ADDR_UP [2/3]
__IO uint32_t SSARC_LP_Type::DESC_ADDR_UP
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::DESC_CTRL0
Descriptor Control0 0 Register..Descriptor Control0 15 Register, array offset: 0x0, array step: 0x20
◆ DESC_CTRL0 [2/3]
__IO uint32_t SSARC_LP_Type::DESC_CTRL0
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::DESC_CTRL1
Descriptor Control1 0 Register..Descriptor Control1 15 Register, array offset: 0x4, array step: 0x20
◆ DESC_CTRL1 [2/3]
__IO uint32_t SSARC_LP_Type::DESC_CTRL1
◆  [3/3]
◆  [1/4]
__IO uint32_t { ... } ::DEVICEADDR
Device Address, offset: 0x154
◆ DEVICEADDR [2/4]
__IO uint32_t USB_Type::DEVICEADDR
◆  [3/4]
◆  [4/4]
◆  [1/3]
__IO uint32_t { ... } ::DGTR_0
DECO0 Gather Table Register 0 Word 0, array offset: 0x80880, array step: index*0xE3C, index2*0x10
◆ DGTR_0 [2/3]
__IO uint32_t CAAM_Type::DGTR_0
◆  [3/3]
◆ DGTR_1 [1/3]
__IO uint32_t CAAM_Type::DGTR_1
DECO0 Gather Table Register 0 Word 1, array offset: 0x80884, array step: index*0xE3C, index2*0x10
◆  [2/3]
__IO uint32_t { ... } ::DGTR_1
◆  [3/3]
◆ DGTR_2 [1/3]
__IO uint32_t CAAM_Type::DGTR_2
DECO0 Gather Table Register 0 Word 2, array offset: 0x80888, array step: index*0xE3C, index2*0x10
◆  [2/3]
__IO uint32_t { ... } ::DGTR_2
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::DGTR_3
DECO0 Gather Table Register 0 Word 3, array offset: 0x8088C, array step: index*0xE3C, index2*0x10
◆ DGTR_3 [2/3]
__IO uint32_t CAAM_Type::DGTR_3
◆  [3/3]
◆ DIGPROG
__I uint32_t USB_ANALOG_Type::DIGPROG
Chip Silicon Version, offset: 0x260
◆ DIRECT [1/5]
__IO uint32_t CCM_Type::DIRECT
Clock source direct control, array offset: 0x5000, array step: 0x20
LPCG direct control, array offset: 0x6000, array step: 0x20
◆  [2/5]
__IO uint32_t { ... } ::DIRECT
◆  [3/5]
◆  [4/5]
◆  [5/5]
◆  [1/4]
__IO uint16_t { ... } ::DISMAP[1]
Fault Disable Mapping Register 0, array offset: 0x2C, array step: index*0x60, index2*0x2
◆  [2/4]
◆  [3/4]
__IO uint16_t { ... } ::DISMAP[2]
Fault Disable Mapping Register 0..Fault Disable Mapping Register 1, array offset: 0x2C, array step: index*0x60, index2*0x2
◆ DISMAP [4/4]
__IO uint16_t PWM_Type::DISMAP[1]
◆ DISP_PARA
__IO uint32_t LCDIFV2_Type::DISP_PARA
Display Parameter Register, offset: 0x10
◆ DISP_SIZE
__IO uint32_t LCDIFV2_Type::DISP_SIZE
Display Size Register, offset: 0x14
◆ DIVISOR
__IO uint32_t EMVSIM_Type::DIVISOR
Baud Rate Divisor Register, offset: 0xC
◆ DJQCR_LS [1/3]
__I uint32_t CAAM_Type::DJQCR_LS
DECO0 Job Queue Control Register, least-significant half, array offset: 0x80804, array step: 0xE3C
◆  [2/3]
__I uint32_t { ... } ::DJQCR_LS
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::DJQCR_MS
DECO0 Job Queue Control Register, most-significant half, array offset: 0x80800, array step: 0xE3C
◆ DJQCR_MS [2/3]
__IO uint32_t CAAM_Type::DJQCR_MS
◆  [3/3]
◆  [1/4]
__IO int32_t { ... } ::DLAST_SGA
TCD Last Destination Address Adjustment/Scatter Gather Address, array offset: 0x1018, array step: 0x20
◆ DLAST_SGA [2/4]
__IO int32_t DMA_Type::DLAST_SGA
◆  [3/4]
◆  [4/4]
◆ DLL_CTRL
__IO uint32_t USDHC_Type::DLL_CTRL
DLL (Delay Line) Control, offset: 0x60
◆ DLL_STATUS
__I uint32_t USDHC_Type::DLL_STATUS
DLL Status, offset: 0x64
◆ DLLCR [1/2]
__IO uint32_t FLEXSPI_Type::DLLCR
DLL Control Register 0, array offset: 0xC0, array step: 0x4
◆ DLLCR [2/2]
__IO uint32_t SEMC_Type::DLLCR
DLL Control Register, offset: 0x34
◆  [1/4]
__IO uint16_t { ... } ::DMA
Timer Channel DMA Enable Register, array offset: 0x18, array step: 0x20
◆ DMA [2/4]
__IO uint16_t TMR_Type::DMA
◆  [3/4]
◆  [4/4]
◆ DMA0_AID_ENB
__I uint32_t CAAM_Type::DMA0_AID_ENB
DMA0 AXI ID Enable Register, offset: 0x250
◆ DMA0_ARD_LAT
__IO uint32_t CAAM_Type::DMA0_ARD_LAT
DMA0 Read Timing Check Latency Register, offset: 0x26C
◆ DMA0_ARD_TC
__IO uint64_t CAAM_Type::DMA0_ARD_TC
DMA0 AXI Read Timing Check Register, offset: 0x260
◆ DMA0_AWR_LAT
__IO uint32_t CAAM_Type::DMA0_AWR_LAT
DMA0 Write Timing Check Latency Register, offset: 0x27C
◆ DMA0_AWR_TC
__IO uint64_t CAAM_Type::DMA0_AWR_TC
DMA0 AXI Write Timing Check Register, offset: 0x270
◆  [1/3]
__I uint32_t { ... } ::DMA_AIDL_MAP_LS
DMA0_AIDL_MAP_LS, array offset: 0x244, array step: 0x10
◆ DMA_AIDL_MAP_LS [2/3]
__I uint32_t CAAM_Type::DMA_AIDL_MAP_LS
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::DMA_AIDL_MAP_MS
DMA0_AIDL_MAP_MS, array offset: 0x240, array step: 0x10
◆ DMA_AIDL_MAP_MS [2/3]
__I uint32_t CAAM_Type::DMA_AIDL_MAP_MS
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::DMA_AIDM_MAP_LS
DMA0_AIDM_MAP_LS, array offset: 0x24C, array step: 0x10
◆ DMA_AIDM_MAP_LS [2/3]
__I uint32_t CAAM_Type::DMA_AIDM_MAP_LS
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::DMA_AIDM_MAP_MS
DMA0_AIDM_MAP_MS, array offset: 0x248, array step: 0x10
◆ DMA_AIDM_MAP_MS [2/3]
__I uint32_t CAAM_Type::DMA_AIDM_MAP_MS
◆  [3/3]
◆ DMA_CTRL
__IO uint32_t ADC_ETC_Type::DMA_CTRL
ETC DMA control Register, offset: 0xC
◆ DMA_STA
__I uint32_t CAAM_Type::DMA_STA
DMA Status Register, offset: 0x50C
◆ DMA_X_AID_11_8_MAP
__I uint32_t CAAM_Type::DMA_X_AID_11_8_MAP
DMA_X_AID_11_8_MAP, offset: 0x51C
◆ DMA_X_AID_15_0_EN
__I uint32_t CAAM_Type::DMA_X_AID_15_0_EN
DMA_X AXI ID Map Enable Register, offset: 0x524
◆ DMA_X_AID_15_12_MAP
__I uint32_t CAAM_Type::DMA_X_AID_15_12_MAP
DMA_X_AID_15_12_MAP, offset: 0x518
◆ DMA_X_AID_3_0_MAP
__I uint32_t CAAM_Type::DMA_X_AID_3_0_MAP
DMA_X_AID_3_0_MAP, offset: 0x514
◆ DMA_X_AID_7_4_MAP
__I uint32_t CAAM_Type::DMA_X_AID_7_4_MAP
DMA_X_AID_7_4_MAP, offset: 0x510
◆ DMA_X_ARTC_CTL
__IO uint32_t CAAM_Type::DMA_X_ARTC_CTL
DMA_X AXI Read Timing Check Control Register, offset: 0x530
◆ DMA_X_ARTC_LAT
__IO uint32_t CAAM_Type::DMA_X_ARTC_LAT
DMA_X Read Timing Check Latency Register, offset: 0x53C
◆ DMA_X_ARTC_LC
__IO uint32_t CAAM_Type::DMA_X_ARTC_LC
DMA_X AXI Read Timing Check Late Count Register, offset: 0x534
◆ DMA_X_ARTC_SC
__IO uint32_t CAAM_Type::DMA_X_ARTC_SC
DMA_X AXI Read Timing Check Sample Count Register, offset: 0x538
◆ DMA_X_AWTC_CTL
__IO uint32_t CAAM_Type::DMA_X_AWTC_CTL
DMA_X AXI Write Timing Check Control Register, offset: 0x540
◆ DMA_X_AWTC_LAT
__IO uint32_t CAAM_Type::DMA_X_AWTC_LAT
DMA_X Write Timing Check Latency Register, offset: 0x54C
◆ DMA_X_AWTC_LC
__IO uint32_t CAAM_Type::DMA_X_AWTC_LC
DMA_X AXI Write Timing Check Late Count Register, offset: 0x544
◆ DMA_X_AWTC_SC
__IO uint32_t CAAM_Type::DMA_X_AWTC_SC
DMA_X AXI Write Timing Check Sample Count Register, offset: 0x548
◆ DMACFG
__IO uint32_t ENET_Type::DMACFG
DMA Class Based Configuration, array offset: 0x1D8, array step: 0x4
◆ DMAEN [1/4]
__IO uint16_t PWM_Type::DMAEN
DMA Enable Register, array offset: 0x28, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::DMAEN
◆  [3/4]
◆  [4/4]
◆ DMASA_FB1
__IO uint32_t CSI_Type::DMASA_FB1
CSI DMA Start Address Register - for Frame Buffer1, offset: 0x28
◆ DMASA_FB2
__IO uint32_t CSI_Type::DMASA_FB2
CSI DMA Transfer Size Register - for Frame Buffer2, offset: 0x2C
◆ DMASA_STATFIFO
__IO uint32_t CSI_Type::DMASA_STATFIFO
CSI DMA Start Address Register - for STATFIFO, offset: 0x20
◆ DMATS_STATFIFO
__IO uint32_t CSI_Type::DMATS_STATFIFO
CSI DMA Transfer Size Register - for STATFIFO, offset: 0x24
◆ DMR0
__IO uint32_t LPSPI_Type::DMR0
Data Match Register 0, offset: 0x30
Data Match 0, offset: 0x30
◆ DMR1
__IO uint32_t LPSPI_Type::DMR1
Data Match Register 1, offset: 0x34
Data Match 1, offset: 0x34
◆  [1/3]
__IO uint32_t { ... } ::DMTH_LS
DECO0 Math Register 0_LS..DECO0 Math Register 3_LS, array offset: 0x80844, array step: index*0xE3C, index2*0x8
◆ DMTH_LS [2/3]
__IO uint32_t CAAM_Type::DMTH_LS
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::DMTH_MS
DECO0 Math Register 0_MS..DECO0 Math Register 3_MS, array offset: 0x80840, array step: index*0xE3C, index2*0x8
◆ DMTH_MS [2/3]
__IO uint32_t CAAM_Type::DMTH_MS
◆  [3/3]
◆ DODIDSR [1/3]
__I uint32_t CAAM_Type::DODIDSR
DECO0 Output DID Status Register, array offset: 0x80824, array step: 0xE3C
◆  [2/3]
__I uint32_t { ... } ::DODIDSR
◆  [3/3]
◆  [1/4]
__IO uint16_t { ... } ::DOFF
TCD Signed Destination Address Offset, array offset: 0x1014, array step: 0x20
◆ DOFF [2/4]
__IO uint16_t DMA_Type::DOFF
◆  [3/4]
◆  [4/4]
◆ DOMAIN_DISPLAY
__IO uint32_t SRC_Type::DOMAIN_DISPLAY
Slice Domain Config Register, offset: 0x22C
◆ DOMAIN_M4CORE
__IO uint32_t SRC_Type::DOMAIN_M4CORE
Slice Domain Config Register, offset: 0x28C
◆ DOMAIN_M4DEBUG
__IO uint32_t SRC_Type::DOMAIN_M4DEBUG
Slice Domain Config Register, offset: 0x2CC
◆ DOMAIN_M7CORE
__IO uint32_t SRC_Type::DOMAIN_M7CORE
Slice Domain Config Register, offset: 0x2AC
◆ DOMAIN_M7DEBUG
__IO uint32_t SRC_Type::DOMAIN_M7DEBUG
Slice Domain Config Register, offset: 0x2EC
◆ DOMAIN_MEGA
__IO uint32_t SRC_Type::DOMAIN_MEGA
Slice Domain Config Register, offset: 0x20C
◆ DOMAIN_USBPHY1
__IO uint32_t SRC_Type::DOMAIN_USBPHY1
Slice Domain Config Register, offset: 0x30C
◆ DOMAIN_USBPHY2
__IO uint32_t SRC_Type::DOMAIN_USBPHY2
Slice Domain Config Register, offset: 0x32C
◆ DOMAIN_WAKEUP
__IO uint32_t SRC_Type::DOMAIN_WAKEUP
Slice Domain Config Register, offset: 0x24C
◆ DOMAINr [1/5]
__IO uint32_t CCM_Type::DOMAINr
Clock source domain control, array offset: 0x5004, array step: 0x20, 'r' suffix has been added to avoid clash with DOMAIN symbol in math.h
LPCG domain control, array offset: 0x6004, array step: 0x20, 'r' suffix has been added to avoid clash with DOMAIN symbol in math.h
◆  [2/5]
__IO uint32_t { ... } ::DOMAINr
◆  [3/5]
◆  [4/5]
◆  [5/5]
◆ DONE0_1_IRQ
__IO uint32_t ADC_ETC_Type::DONE0_1_IRQ
ETC DONE0 and DONE1 IRQ State Register, offset: 0x4
◆ DONE2_3_ERR_IRQ
__IO uint32_t ADC_ETC_Type::DONE2_3_ERR_IRQ
ETC DONE_2 and DONE_ERR IRQ State Register, offset: 0x8
ETC DONE_2, DONE_3 and DONE_ERR IRQ State Register, offset: 0x8
◆ DOPSTA_LS [1/3]
__I uint32_t CAAM_Type::DOPSTA_LS
DECO0 Operation Status Register, least-significant half, array offset: 0x80814, array step: 0xE3C
◆  [2/3]
__I uint32_t { ... } ::DOPSTA_LS
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::DOPSTA_MS
DECO0 Operation Status Register, most-significant half, array offset: 0x80810, array step: 0xE3C
◆ DOPSTA_MS [2/3]
__I uint32_t CAAM_Type::DOPSTA_MS
◆  [3/3]
◆ DPAMS
__O uint32_t IEE_Type::DPAMS
AES Mask Generation Seed, offset: 0xC
◆ DPDIDSR [1/3]
__I uint32_t CAAM_Type::DPDIDSR
DECO0 Primary DID Status Register, array offset: 0x80820, array step: 0xE3C
◆  [2/3]
__I uint32_t { ... } ::DPDIDSR
◆  [3/3]
◆ DPOVRD [1/3]
__IO uint32_t CAAM_Type::DPOVRD
Protocol Override Register, array offset: 0x80E30, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::DPOVRD
◆  [3/3]
◆ DR
__IO uint32_t GPIO_Type::DR
GPIO data register, offset: 0x0
◆ DR_CLEAR
__O uint32_t GPIO_Type::DR_CLEAR
GPIO data register CLEAR, offset: 0x88
◆ DR_SET
__O uint32_t GPIO_Type::DR_SET
GPIO data register SET, offset: 0x84
◆ DR_TOGGLE
__O uint32_t GPIO_Type::DR_TOGGLE
GPIO data register TOGGLE, offset: 0x8C
◆ DRR
__O uint32_t CAAM_Type::DRR
DECO Reset Register, offset: 0x124
◆ DS_ADDR
__IO uint32_t USDHC_Type::DS_ADDR
DMA System Address, offset: 0x0
◆  [1/3]
__I uint64_t { ... } ::DSDP
DECO0 Debug Shared Pointer, array offset: 0x80E10, array step: 0xE3C
◆ DSDP [2/3]
__I uint64_t CAAM_Type::DSDP
◆  [3/3]
◆ DSTR_0 [1/3]
__IO uint32_t CAAM_Type::DSTR_0
DECO0 Scatter Table Register 0 Word 0, array offset: 0x80900, array step: index*0xE3C, index2*0x10
◆  [2/3]
__IO uint32_t { ... } ::DSTR_0
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::DSTR_1
DECO0 Scatter Table Register 0 Word 1, array offset: 0x80904, array step: index*0xE3C, index2*0x10
◆ DSTR_1 [2/3]
__IO uint32_t CAAM_Type::DSTR_1
◆  [3/3]
◆ DSTR_2 [1/3]
__IO uint32_t CAAM_Type::DSTR_2
DECO0 Scatter Table Register 0 Word 2, array offset: 0x80908, array step: index*0xE3C, index2*0x10
◆  [2/3]
__IO uint32_t { ... } ::DSTR_2
◆  [3/3]
◆ DSTR_3 [1/3]
__IO uint32_t CAAM_Type::DSTR_3
DECO0 Scatter Table Register 0 Word 3, array offset: 0x8090C, array step: index*0xE3C, index2*0x10
◆  [2/3]
__IO uint32_t { ... } ::DSTR_3
◆  [3/3]
◆ DTCM_MAGIC_ADDR
__IO uint32_t FLEXRAM_Type::DTCM_MAGIC_ADDR
DTCM Magic Address Register, offset: 0x8
◆  [1/4]
__IO uint16_t { ... } ::DTCNT0
Deadtime Count Register 0, array offset: 0x30, array step: 0x60
◆ DTCNT0 [2/4]
__IO uint16_t PWM_Type::DTCNT0
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint16_t { ... } ::DTCNT1
Deadtime Count Register 1, array offset: 0x32, array step: 0x60
◆ DTCNT1 [2/4]
__IO uint16_t PWM_Type::DTCNT1
◆  [3/4]
◆  [4/4]
◆ DTSRCSEL
__IO uint16_t PWM_Type::DTSRCSEL
PWM Source Select Register, offset: 0x186
◆ EARS
__IO uint32_t DMA_Type::EARS
Enable Asynchronous Request in Stop, offset: 0x44
◆ ECC_BASE_ADDR0
__IO uint32_t XECC_Type::ECC_BASE_ADDR0
ECC Region 0 Base Address, offset: 0x3C
◆ ECC_BASE_ADDR1
__IO uint32_t XECC_Type::ECC_BASE_ADDR1
ECC Region 1 Base Address, offset: 0x44
◆ ECC_BASE_ADDR2
__IO uint32_t XECC_Type::ECC_BASE_ADDR2
ECC Region 2 Base Address, offset: 0x4C
◆ ECC_BASE_ADDR3
__IO uint32_t XECC_Type::ECC_BASE_ADDR3
ECC Region 3 Base Address, offset: 0x54
◆ ECC_CTRL
__IO uint32_t XECC_Type::ECC_CTRL
ECC Control Register, offset: 0x0
◆ ECC_END_ADDR0
__IO uint32_t XECC_Type::ECC_END_ADDR0
ECC Region 0 End Address, offset: 0x40
◆ ECC_END_ADDR1
__IO uint32_t XECC_Type::ECC_END_ADDR1
ECC Region 1 End Address, offset: 0x48
◆ ECC_END_ADDR2
__IO uint32_t XECC_Type::ECC_END_ADDR2
ECC Region 2 End Address, offset: 0x50
◆ ECC_END_ADDR3
__IO uint32_t XECC_Type::ECC_END_ADDR3
ECC Region 3 End Address, offset: 0x58
◆ ECR [1/2]
__IO uint32_t CAN_Type::ECR
Error Counter Register, offset: 0x1C
Error Counter, offset: 0x1C
◆ ECR [2/2]
__IO uint32_t ENET_Type::ECR
Ethernet Control Register, offset: 0x24
◆ EDGE_SEL
__IO uint32_t GPIO_Type::EDGE_SEL
GPIO edge select register, offset: 0x1C
◆ EEI
__IO uint32_t DMA_Type::EEI
Enable Error Interrupt, offset: 0x14
◆ EIMR
__IO uint32_t ENET_Type::EIMR
Interrupt Mask Register, offset: 0x8
◆ EIR
__IO uint32_t ENET_Type::EIR
Interrupt Event Register, offset: 0x4
◆ ENABLE_MULT_PKTS
__IO uint32_t DSI_HOST_DPI_INTFC_Type::ENABLE_MULT_PKTS
ENABLE_MULT_PKTS, offset: 0x28
◆  [1/4]
__IO uint16_t { ... } ::ENBL
Timer Channel Enable Register, array offset: 0x1E, array step: 0x20, this item is not available for all array instances
◆ ENBL [2/4]
__IO uint16_t TMR_Type::ENBL
◆  [3/4]
◆  [4/4]
◆ ENDPTCOMPLETE
__IO uint32_t USB_Type::ENDPTCOMPLETE
Endpoint Complete, offset: 0x1BC
◆ ENDPTCTRL
__IO uint32_t USB_Type::ENDPTCTRL
Endpoint Control 1..Endpoint Control 7, array offset: 0x1C4, array step: 0x4
◆ ENDPTCTRL0
__IO uint32_t USB_Type::ENDPTCTRL0
Endpoint Control0, offset: 0x1C0
◆ ENDPTFLUSH
__IO uint32_t USB_Type::ENDPTFLUSH
Endpoint Flush, offset: 0x1B4
◆ ENDPTLISTADDR [1/4]
__IO uint32_t USB_Type::ENDPTLISTADDR
Endpoint List Address, offset: 0x158
◆  [2/4]
__IO uint32_t { ... } ::ENDPTLISTADDR
◆  [3/4]
◆  [4/4]
◆ ENDPTNAK
__IO uint32_t USB_Type::ENDPTNAK
Endpoint NAK, offset: 0x178
◆ ENDPTNAKEN
__IO uint32_t USB_Type::ENDPTNAKEN
Endpoint NAK Enable, offset: 0x17C
◆ ENDPTPRIME
__IO uint32_t USB_Type::ENDPTPRIME
Endpoint Prime, offset: 0x1B0
◆ ENDPTSETUPSTAT
__IO uint32_t USB_Type::ENDPTSETUPSTAT
Endpoint Setup Status, offset: 0x1AC
◆ ENDPTSTAT
__I uint32_t USB_Type::ENDPTSTAT
Endpoint Status, offset: 0x1B8
◆ ENT
__I uint32_t TRNG_Type::ENT[16]
Entropy Read Register, array offset: 0x40, array step: 0x4
◆ ERQ
__IO uint32_t DMA_Type::ERQ
Enable Request, offset: 0xC
◆ ERR
__IO uint32_t DMA_Type::ERR
Error, offset: 0x2C
◆ ERR_DATA_INJ
__IO uint32_t XECC_Type::ERR_DATA_INJ
Error Injection On Write Data, offset: 0x10
◆ ERR_DATA_INJ_HIGH0
__IO uint32_t MECC_Type::ERR_DATA_INJ_HIGH0
Error Injection On HIGH 32 bits Of OCRAM Bank0 Write Data, offset: 0x10
◆ ERR_DATA_INJ_HIGH1
__IO uint32_t MECC_Type::ERR_DATA_INJ_HIGH1
Error Injection On HIGH 32 bits Of OCRAM Bank1 Write Data, offset: 0x1C
◆ ERR_DATA_INJ_HIGH2
__IO uint32_t MECC_Type::ERR_DATA_INJ_HIGH2
Error Injection On HIGH 32 bits Of OCRAM Bank2 Write Data, offset: 0x28
◆ ERR_DATA_INJ_HIGH3
__IO uint32_t MECC_Type::ERR_DATA_INJ_HIGH3
Error Injection On HIGH 32 bits Of OCRAM Bank3 Write Data, offset: 0x34
◆ ERR_DATA_INJ_LOW0
__IO uint32_t MECC_Type::ERR_DATA_INJ_LOW0
Error Injection On LOW 32 bits Of OCRAM Bank0 Write Data, offset: 0xC
◆ ERR_DATA_INJ_LOW1
__IO uint32_t MECC_Type::ERR_DATA_INJ_LOW1
Error Injection On LOW 32 bits Of OCRAM Bank1 Write Data, offset: 0x18
◆ ERR_DATA_INJ_LOW2
__IO uint32_t MECC_Type::ERR_DATA_INJ_LOW2
Error Injection On LOW 32 bits Of OCRAM Bank2 Write Data, offset: 0x24
◆ ERR_DATA_INJ_LOW3
__IO uint32_t MECC_Type::ERR_DATA_INJ_LOW3
Error Injection On LOW 32 bits Of OCRAM Bank3 Write Data, offset: 0x30
◆ ERR_ECC_INJ
__IO uint32_t XECC_Type::ERR_ECC_INJ
Error Injection On ECC Code of Write Data, offset: 0x14
◆ ERR_ECC_INJ0
__IO uint32_t MECC_Type::ERR_ECC_INJ0
Error Injection On 8 bits ECC code Of OCRAM Bank0 Write Data, offset: 0x14
◆ ERR_ECC_INJ1
__IO uint32_t MECC_Type::ERR_ECC_INJ1
Error Injection On 8 bits ECC code Of OCRAM Bank1 Write Data, offset: 0x20
◆ ERR_ECC_INJ2
__IO uint32_t MECC_Type::ERR_ECC_INJ2
Error Injection On 8 bits ECC code Of OCRAM Bank2 Write Data, offset: 0x2C
◆ ERR_ECC_INJ3
__IO uint32_t MECC_Type::ERR_ECC_INJ3
Error Injection On 8 bits ECC code Of OCRAM Bank3 Write Data, offset: 0x38
◆ ERR_SIG_EN [1/2]
__IO uint32_t MECC_Type::ERR_SIG_EN
Error Interrupt Enable Register, offset: 0x8
◆ ERR_SIG_EN [2/2]
__IO uint32_t XECC_Type::ERR_SIG_EN
Error Interrupt Enable Register, offset: 0xC
◆ ERR_STAT_EN [1/2]
__IO uint32_t MECC_Type::ERR_STAT_EN
Error Interrupt Status Enable Register, offset: 0x4
◆ ERR_STAT_EN [2/2]
__IO uint32_t XECC_Type::ERR_STAT_EN
Error Interrupt Status Enable Register, offset: 0x8
◆ ERR_STATUS [1/2]
__IO uint32_t MECC_Type::ERR_STATUS
Error Interrupt Status Register, offset: 0x0
◆ ERR_STATUS [2/2]
__IO uint32_t XECC_Type::ERR_STATUS
Error Interrupt Status Register, offset: 0x4
◆ ERRIAR
__IO uint32_t CAN_Type::ERRIAR
Error Injection Address register, offset: 0xAE4
◆ ERRIDPR
__IO uint32_t CAN_Type::ERRIDPR
Error Injection Data Pattern register, offset: 0xAE8
◆ ERRIPPR
__IO uint32_t CAN_Type::ERRIPPR
Error Injection Parity Pattern register, offset: 0xAEC
◆ ERRSR
__IO uint32_t CAN_Type::ERRSR
Error Status register, offset: 0xAFC
◆ ES
__I uint32_t DMA_Type::ES
Error Status, offset: 0x4
◆ ESR1
__IO uint32_t CAN_Type::ESR1
Error and Status 1 Register, offset: 0x20
Error and Status 1 register, offset: 0x20
◆ ESR2
__I uint32_t CAN_Type::ESR2
Error and Status 2 Register, offset: 0x38
Error and Status 2 register, offset: 0x38
◆ FADID
__I uint32_t CAAM_Type::FADID
Fault Address DID Register, offset: 0xFC8
◆ FADID_DC01
__I uint32_t CAAM_Type::FADID_DC01
Fault Address DID Register, offset: 0x80FC8
◆  [1/3]
__I uint32_t { ... } ::FADID_JR
Fault Address DID Register, array offset: 0x10FC8, array step: 0x10000
◆ FADID_JR [2/3]
__I uint32_t CAAM_Type::FADID_JR
◆  [3/3]
◆ FADID_RTIC
__I uint32_t CAAM_Type::FADID_RTIC
Fault Address DID Register, offset: 0x60FC8
◆ FADR [1/2]
__I uint32_t CAAM_Type::FADR
Fault Address Detail Register, offset: 0xFCC
◆ FADR [2/2]
__I uint32_t MCM_Type::FADR
Fault address register, offset: 0x20
◆ FADR_DC01
__I uint32_t CAAM_Type::FADR_DC01
Fault Address Detail Register, offset: 0x80FCC
◆  [1/3]
__I uint32_t { ... } ::FADR_JR
Fault Address Detail Register, array offset: 0x10FCC, array step: 0x10000
◆ FADR_JR [2/3]
__I uint32_t CAAM_Type::FADR_JR
◆  [3/3]
◆ FADR_RTIC
__I uint32_t CAAM_Type::FADR_RTIC
Fault Address Detail Register, offset: 0x60FCC
◆ FAR
__I uint64_t CAAM_Type::FAR
Fault Address Register, offset: 0xFC0
◆ FAR_DC01
__I uint64_t CAAM_Type::FAR_DC01
Fault Address Register, offset: 0x80FC0
◆  [1/3]
__I uint64_t { ... } ::FAR_JR
Fault Address Register, array offset: 0x10FC0, array step: 0x10000
◆ FAR_JR [2/3]
__I uint64_t CAAM_Type::FAR_JR
◆  [3/3]
◆ FAR_RTIC
__I uint64_t CAAM_Type::FAR_RTIC
Fault Address Register, offset: 0x60FC0
◆ FATR
__I uint32_t MCM_Type::FATR
Fault attributes register, offset: 0x24
◆ FBUF_PARA
__IO uint32_t CSI_Type::FBUF_PARA
CSI Frame Buffer Parameter Register, offset: 0x30
◆ FCR
__IO uint32_t LPSPI_Type::FCR
The FIFO Control register contains the RXWATER and TXWATER control fields., offset: 0x58
FIFO Control, offset: 0x58
◆ FCTRL [1/2]
__IO uint16_t PWM_Type::FCTRL
Fault Control Register, offset: 0x18C
◆ FCTRL [2/2]
__IO uint32_t ADC_Type::FCTRL
LPADC FIFO Control Register, offset: 0x30
◆ FCTRL2
__IO uint16_t PWM_Type::FCTRL2
Fault Control 2 Register, offset: 0x194
◆ FDCBT
__IO uint32_t CAN_Type::FDCBT
CAN FD Bit Timing register, offset: 0xC04
◆ FDCRC
__I uint32_t CAN_Type::FDCRC
CAN FD CRC register, offset: 0xC08
◆ FDCTRL
__IO uint32_t CAN_Type::FDCTRL
CAN FD Control register, offset: 0xC00
◆ FDR
__I uint32_t MCM_Type::FDR
Fault data register, offset: 0x28
◆ FFILT
__IO uint16_t PWM_Type::FFILT
Fault Filter Register, offset: 0x190
◆ FIFO
__IO uint32_t LPUART_Type::FIFO
LPUART FIFO Register, offset: 0x28
◆ FIFO_CTRL
__IO uint32_t PDM_Type::FIFO_CTRL
PDM FIFO Control register, offset: 0x10
◆ FIFO_STAT
__IO uint32_t PDM_Type::FIFO_STAT
PDM FIFO Status register, offset: 0x14
◆ FILT [1/5]
__IO uint16_t ENC_Type::FILT
Input Filter Register, offset: 0x2
◆  [2/5]
__IO uint16_t { ... } ::FILT
Timer Channel Input Filter Register, array offset: 0x16, array step: 0x20
◆ FILT [3/5]
__IO uint16_t TMR_Type::FILT
◆  [4/5]
◆  [5/5]
◆ FLAGS
__IO uint32_t CDOG_Type::FLAGS
Flags, offset: 0x18
◆ FLEXRAM_CTRL
__IO uint32_t FLEXRAM_Type::FLEXRAM_CTRL
FlexRAM feature Control register, offset: 0x108
◆ FLOW_CONTROL
__IO uint32_t TSC_Type::FLOW_CONTROL
Flow Control, offset: 0x20
◆ FLSHCR0
__IO uint32_t FLEXSPI_Type::FLSHCR0
Flash Control Register 0, array offset: 0x60, array step: 0x4
◆ FLSHCR1
__IO uint32_t FLEXSPI_Type::FLSHCR1
Flash Control Register 1, array offset: 0x70, array step: 0x4
◆ FLSHCR2
__IO uint32_t FLEXSPI_Type::FLSHCR2
Flash Control Register 2, array offset: 0x80, array step: 0x4
◆ FLSHCR4
__IO uint32_t FLEXSPI_Type::FLSHCR4
Flash Control Register 4, offset: 0x94
◆ FORCE_EVENT
__O uint32_t USDHC_Type::FORCE_EVENT
Force Event, offset: 0x50
◆ FPR
__IO uint8_t CMP_Type::FPR
CMP Filter Period Register, offset: 0x2
◆  [1/4]
__IO uint16_t { ... } ::FRACVAL1
Fractional Value Register 1, array offset: 0xC, array step: 0x60
◆ FRACVAL1 [2/4]
__IO uint16_t PWM_Type::FRACVAL1
◆  [3/4]
◆  [4/4]
◆ FRACVAL2 [1/4]
__IO uint16_t PWM_Type::FRACVAL2
Fractional Value Register 2, array offset: 0x10, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::FRACVAL2
◆  [3/4]
◆  [4/4]
◆ FRACVAL3 [1/4]
__IO uint16_t PWM_Type::FRACVAL3
Fractional Value Register 3, array offset: 0x14, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::FRACVAL3
◆  [3/4]
◆  [4/4]
◆ FRACVAL4 [1/4]
__IO uint16_t PWM_Type::FRACVAL4
Fractional Value Register 4, array offset: 0x18, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::FRACVAL4
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint16_t { ... } ::FRACVAL5
Fractional Value Register 5, array offset: 0x1C, array step: 0x60
◆ FRACVAL5 [2/4]
__IO uint16_t PWM_Type::FRACVAL5
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint16_t { ... } ::FRCTRL
Fractional Control Register, array offset: 0x20, array step: 0x60
◆ FRCTRL [2/4]
__IO uint16_t PWM_Type::FRCTRL
◆  [3/4]
◆  [4/4]
◆ FREQUENCY_CURRENT [1/3]
__I uint32_t CCM_OBS_Type::FREQUENCY_CURRENT
Current frequency detected, array offset: 0x40, array step: 0x80
◆  [2/3]
__I uint32_t { ... } ::FREQUENCY_CURRENT
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::FREQUENCY_MAX
Maximum frequency detected, array offset: 0x48, array step: 0x80
◆ FREQUENCY_MAX [2/3]
__I uint32_t CCM_OBS_Type::FREQUENCY_MAX
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::FREQUENCY_MIN
Minimum frequency detected, array offset: 0x44, array step: 0x80
◆ FREQUENCY_MIN [2/3]
__I uint32_t CCM_OBS_Type::FREQUENCY_MIN
◆  [3/3]
◆ FRINDEX
__IO uint32_t USB_Type::FRINDEX
USB Frame Index, offset: 0x14C
◆ FRQCNT [1/2]
__I uint32_t TRNG_Type::FRQCNT
Frequency Count Register, offset: 0x1C
◆  [2/2]
__I uint32_t { ... } ::FRQCNT
◆ FRQMAX [1/2]
__IO uint32_t TRNG_Type::FRQMAX
Frequency Count Maximum Limit Register, offset: 0x1C
◆  [2/2]
__IO uint32_t { ... } ::FRQMAX
◆ FRQMIN
__IO uint32_t TRNG_Type::FRQMIN
Frequency Count Minimum Limit Register, offset: 0x18
◆ FSR
__I uint32_t LPSPI_Type::FSR
FIFO Status Register, offset: 0x5C
FIFO Status, offset: 0x5C
◆ FSTS
__IO uint16_t PWM_Type::FSTS
Fault Status Register, offset: 0x18E
◆ FTRL
__IO uint32_t ENET_Type::FTRL
Frame Truncation Length, offset: 0x1B0
◆ FTST
__IO uint16_t PWM_Type::FTST
Fault Test Register, offset: 0x192
◆  [1/3]
__I uint32_t { ... } ::FUSE
Value of fuse word 0..Value of fuse word 143, array offset: 0x800, array step: 0x10
◆ FUSE [2/3]
__I uint32_t OCOTP_Type::FUSE
◆  [3/3]
◆ GALR
__IO uint32_t ENET_Type::GALR
Descriptor Group Lower Address Register, offset: 0x124
◆ GATE [1/2]
__IO uint8_t SEMA4_Type::GATE
Semaphores Gate n Register, array offset: 0x0, array step: 0x1
◆ GATE [2/2]
__IO uint8_t RDC_SEMAPHORE_Type::GATE
Gate Register, array offset: 0x0, array step: 0x1
◆ GAUR
__IO uint32_t ENET_Type::GAUR
Descriptor Group Upper Address Register, offset: 0x120
◆ GC
__IO uint32_t ADC_Type::GC
General control register, offset: 0x48
◆ GCFG
__IO uint32_t IEE_Type::GCFG
IEE Global Configuration, offset: 0x0
◆ GDIR
__IO uint32_t GPIO_Type::GDIR
GPIO direction register, offset: 0x4
◆ GFWR [1/2]
__IO uint32_t CAN_Type::GFWR
Glitch Filter Width Registers, offset: 0x9E0
◆ GFWR [2/2]
__IO uint32_t CAN_WRAPPER_Type::GFWR
Glitch Filter Width Register, offset: 0x9E0
◆ GLOBAL
__IO uint32_t LPUART_Type::GLOBAL
LPUART Global Register, offset: 0x8
◆ GP1
__IO uint32_t OCOTP_Type::GP1
Value of OTP Bank4 Word6 (General Purpose Customer Defined Info), offset: 0x660
◆ GP2
__IO uint32_t OCOTP_Type::GP2
Value of OTP Bank4 Word7 (General Purpose Customer Defined Info), offset: 0x670
◆ GP3
__IO uint32_t OCOTP_Type::GP3
Value of OTP Bank4 Word4 (MAC Address), offset: 0x640
◆ GPCNT0_VAL
__IO uint32_t EMVSIM_Type::GPCNT0_VAL
General Purpose Counter 0 Timeout Value Register, offset: 0x44
◆ GPCNT1_VAL
__IO uint32_t EMVSIM_Type::GPCNT1_VAL
General Purpose Counter 1 Timeout Value, offset: 0x48
◆ GPR [1/2]
__IO uint32_t SRC_Type::GPR
SRC General Purpose Register 1..SRC General Purpose Register 10, array offset: 0x20, array step: 0x4
SRC General Purpose Register, array offset: 0x14, array step: 0x4
◆ GPR [2/2]
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR
GPR0 General Purpose Register, array offset: 0x0, array step: 0x4
◆ GPR0 [1/4]
__IO uint32_t IOMUXC_GPR_Type::GPR0
GPR0 General Purpose Register, offset: 0x0
◆ GPR0 [2/4]
uint32_t IOMUXC_SNVS_GPR_Type::GPR0
◆ GPR0 [3/4]
◆ GPR0 [4/4]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR0
◆ GPR1 [1/3]
__IO uint32_t IOMUXC_GPR_Type::GPR1
GPR1 General Purpose Register, offset: 0x4
◆ GPR1 [2/3]
uint32_t IOMUXC_SNVS_GPR_Type::GPR1
◆ GPR1 [3/3]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR1
◆ GPR10 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR10
GPR10 General Purpose Register, offset: 0x28
◆ GPR10 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR10
◆ GPR11 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR11
GPR11 General Purpose Register, offset: 0x2C
◆ GPR11 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR11
◆ GPR12 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR12
GPR12 General Purpose Register, offset: 0x30
◆ GPR12 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR12
◆ GPR13 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR13
GPR13 General Purpose Register, offset: 0x34
◆ GPR13 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR13
◆ GPR14 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR14
GPR14 General Purpose Register, offset: 0x38
◆ GPR14 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR14
◆ GPR15 [1/3]
__IO uint32_t IOMUXC_GPR_Type::GPR15
GPR15 General Purpose Register, offset: 0x3C
◆ GPR15 [2/3]
◆ GPR15 [3/3]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR15
◆ GPR16 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR16
GPR16 General Purpose Register, offset: 0x40
◆ GPR16 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR16
◆ GPR17 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR17
GPR17 General Purpose Register, offset: 0x44
◆ GPR17 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR17
◆ GPR18 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR18
GPR18 General Purpose Register, offset: 0x48
◆ GPR18 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR18
◆ GPR19 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR19
GPR19 General Purpose Register, offset: 0x4C
◆ GPR19 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR19
◆ GPR2 [1/3]
__IO uint32_t IOMUXC_GPR_Type::GPR2
GPR2 General Purpose Register, offset: 0x8
◆ GPR2 [2/3]
uint32_t IOMUXC_SNVS_GPR_Type::GPR2
◆ GPR2 [3/3]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR2
◆ GPR20 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR20
GPR20 General Purpose Register, offset: 0x50
◆ GPR20 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR20
◆ GPR21 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR21
GPR21 General Purpose Register, offset: 0x54
◆ GPR21 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR21
◆ GPR22 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR22
GPR22 General Purpose Register, offset: 0x58
◆ GPR22 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR22
◆ GPR23 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR23
GPR23 General Purpose Register, offset: 0x5C
◆ GPR23 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR23
◆ GPR24 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR24
GPR24 General Purpose Register, offset: 0x60
◆ GPR24 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR24
◆ GPR25 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR25
GPR25 General Purpose Register, offset: 0x64
◆ GPR25 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR25
◆ GPR26 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR26
GPR26 General Purpose Register, offset: 0x68
◆ GPR26 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR26
◆ GPR27
__IO uint32_t IOMUXC_GPR_Type::GPR27
GPR27 General Purpose Register, offset: 0x6C
◆ GPR28
__IO uint32_t IOMUXC_GPR_Type::GPR28
GPR28 General Purpose Register, offset: 0x70
◆ GPR29
__IO uint32_t IOMUXC_GPR_Type::GPR29
GPR29 General Purpose Register, offset: 0x74
◆ GPR3 [1/3]
__IO uint32_t IOMUXC_GPR_Type::GPR3
GPR3 General Purpose Register, offset: 0xC
◆ GPR3 [2/3]
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR3
◆ GPR3 [3/3]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR3
◆ GPR30
__IO uint32_t IOMUXC_GPR_Type::GPR30
GPR30 General Purpose Register, offset: 0x78
◆ GPR31
__IO uint32_t IOMUXC_GPR_Type::GPR31
GPR31 General Purpose Register, offset: 0x7C
◆ GPR32 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR32
GPR32 General Purpose Register, offset: 0x80
◆ GPR32 [2/2]
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR32
◆ GPR33 [1/3]
__IO uint32_t IOMUXC_GPR_Type::GPR33
GPR33 General Purpose Register, offset: 0x84
◆ GPR33 [2/3]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR33
◆ GPR33 [3/3]
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR33
◆ GPR34 [1/3]
__IO uint32_t IOMUXC_GPR_Type::GPR34
GPR34 General Purpose Register, offset: 0x88
◆ GPR34 [2/3]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR34
◆ GPR34 [3/3]
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR34
◆ GPR35 [1/3]
__IO uint32_t IOMUXC_GPR_Type::GPR35
GPR35 General Purpose Register, offset: 0x8C
◆ GPR35 [2/3]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR35
◆ GPR35 [3/3]
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR35
◆ GPR36 [1/3]
__IO uint32_t IOMUXC_GPR_Type::GPR36
GPR36 General Purpose Register, offset: 0x90
◆ GPR36 [2/3]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR36
◆ GPR36 [3/3]
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR36
◆ GPR37 [1/3]
__IO uint32_t IOMUXC_GPR_Type::GPR37
GPR37 General Purpose Register, offset: 0x94
◆ GPR37 [2/3]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR37
◆ GPR37 [3/3]
__IO uint32_t IOMUXC_SNVS_GPR_Type::GPR37
◆ GPR38 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR38
GPR38 General Purpose Register, offset: 0x98
◆ GPR38 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR38
◆ GPR39 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR39
GPR39 General Purpose Register, offset: 0x9C
◆ GPR39 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR39
◆ GPR4 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR4
GPR4 General Purpose Register, offset: 0x10
◆ GPR4 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR4
◆ GPR40 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR40
GPR40 General Purpose Register, offset: 0xA0
◆ GPR40 [2/2]
__I uint32_t IOMUXC_LPSR_GPR_Type::GPR40
◆ GPR41 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR41
GPR41 General Purpose Register, offset: 0xA4
◆ GPR41 [2/2]
__I uint32_t IOMUXC_LPSR_GPR_Type::GPR41
◆ GPR42
__IO uint32_t IOMUXC_GPR_Type::GPR42
GPR42 General Purpose Register, offset: 0xA8
◆ GPR43
__IO uint32_t IOMUXC_GPR_Type::GPR43
GPR43 General Purpose Register, offset: 0xAC
◆ GPR44
__IO uint32_t IOMUXC_GPR_Type::GPR44
GPR44 General Purpose Register, offset: 0xB0
◆ GPR45
__IO uint32_t IOMUXC_GPR_Type::GPR45
GPR45 General Purpose Register, offset: 0xB4
◆ GPR46
__IO uint32_t IOMUXC_GPR_Type::GPR46
GPR46 General Purpose Register, offset: 0xB8
◆ GPR47
__IO uint32_t IOMUXC_GPR_Type::GPR47
GPR47 General Purpose Register, offset: 0xBC
◆ GPR48
__IO uint32_t IOMUXC_GPR_Type::GPR48
GPR48 General Purpose Register, offset: 0xC0
◆ GPR49
__IO uint32_t IOMUXC_GPR_Type::GPR49
GPR49 General Purpose Register, offset: 0xC4
◆ GPR5 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR5
GPR5 General Purpose Register, offset: 0x14
◆ GPR5 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR5
◆ GPR50
__IO uint32_t IOMUXC_GPR_Type::GPR50
GPR50 General Purpose Register, offset: 0xC8
◆ GPR51
__IO uint32_t IOMUXC_GPR_Type::GPR51
GPR51 General Purpose Register, offset: 0xCC
◆ GPR52
__IO uint32_t IOMUXC_GPR_Type::GPR52
GPR52 General Purpose Register, offset: 0xD0
◆ GPR53
__IO uint32_t IOMUXC_GPR_Type::GPR53
GPR53 General Purpose Register, offset: 0xD4
◆ GPR54
__IO uint32_t IOMUXC_GPR_Type::GPR54
GPR54 General Purpose Register, offset: 0xD8
◆ GPR55
__IO uint32_t IOMUXC_GPR_Type::GPR55
GPR55 General Purpose Register, offset: 0xDC
◆ GPR59
__IO uint32_t IOMUXC_GPR_Type::GPR59
GPR59 General Purpose Register, offset: 0xEC
◆ GPR6 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR6
GPR6 General Purpose Register, offset: 0x18
◆ GPR6 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR6
◆ GPR62
__IO uint32_t IOMUXC_GPR_Type::GPR62
GPR62 General Purpose Register, offset: 0xF8
◆ GPR63
__I uint32_t IOMUXC_GPR_Type::GPR63
GPR63 General Purpose Register, offset: 0xFC
◆ GPR64
__IO uint32_t IOMUXC_GPR_Type::GPR64
GPR64 General Purpose Register, offset: 0x100
◆ GPR65
__IO uint32_t IOMUXC_GPR_Type::GPR65
GPR65 General Purpose Register, offset: 0x104
◆ GPR66
__IO uint32_t IOMUXC_GPR_Type::GPR66
GPR66 General Purpose Register, offset: 0x108
◆ GPR67
__IO uint32_t IOMUXC_GPR_Type::GPR67
GPR67 General Purpose Register, offset: 0x10C
◆ GPR68
__IO uint32_t IOMUXC_GPR_Type::GPR68
GPR68 General Purpose Register, offset: 0x110
◆ GPR69
__IO uint32_t IOMUXC_GPR_Type::GPR69
GPR69 General Purpose Register, offset: 0x114
◆ GPR7 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR7
GPR7 General Purpose Register, offset: 0x1C
◆ GPR7 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR7
◆ GPR70
__IO uint32_t IOMUXC_GPR_Type::GPR70
GPR70 General Purpose Register, offset: 0x118
◆ GPR71
__IO uint32_t IOMUXC_GPR_Type::GPR71
GPR71 General Purpose Register, offset: 0x11C
◆ GPR72
__IO uint32_t IOMUXC_GPR_Type::GPR72
GPR72 General Purpose Register, offset: 0x120
◆ GPR73
__IO uint32_t IOMUXC_GPR_Type::GPR73
GPR73 General Purpose Register, offset: 0x124
◆ GPR74
__IO uint32_t IOMUXC_GPR_Type::GPR74
GPR74 General Purpose Register, offset: 0x128
◆ GPR75
__I uint32_t IOMUXC_GPR_Type::GPR75
GPR75 General Purpose Register, offset: 0x12C
◆ GPR76
__I uint32_t IOMUXC_GPR_Type::GPR76
GPR76 General Purpose Register, offset: 0x130
◆ GPR8 [1/2]
__IO uint32_t IOMUXC_GPR_Type::GPR8
GPR8 General Purpose Register, offset: 0x20
◆ GPR8 [2/2]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR8
◆ GPR9 [1/3]
__IO uint32_t IOMUXC_GPR_Type::GPR9
GPR9 General Purpose Register, offset: 0x24
◆ GPR9 [2/3]
◆ GPR9 [3/3]
__IO uint32_t IOMUXC_LPSR_GPR_Type::GPR9
◆ GPR_PRIVATE1
__IO uint32_t CCM_Type::GPR_PRIVATE1
General Purpose Register, offset: 0x4C20
◆ GPR_PRIVATE1_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE1_AUTHEN
GPR access control, offset: 0x4C30
◆ GPR_PRIVATE1_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE1_AUTHEN_CLR
GPR access control, offset: 0x4C38
◆ GPR_PRIVATE1_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE1_AUTHEN_SET
GPR access control, offset: 0x4C34
◆ GPR_PRIVATE1_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE1_AUTHEN_TOG
GPR access control, offset: 0x4C3C
◆ GPR_PRIVATE1_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE1_CLR
General Purpose Register, offset: 0x4C28
◆ GPR_PRIVATE1_SET
__IO uint32_t CCM_Type::GPR_PRIVATE1_SET
General Purpose Register, offset: 0x4C24
◆ GPR_PRIVATE1_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE1_TOG
General Purpose Register, offset: 0x4C2C
◆ GPR_PRIVATE2
__IO uint32_t CCM_Type::GPR_PRIVATE2
General Purpose Register, offset: 0x4C40
◆ GPR_PRIVATE2_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE2_AUTHEN
GPR access control, offset: 0x4C50
◆ GPR_PRIVATE2_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE2_AUTHEN_CLR
GPR access control, offset: 0x4C58
◆ GPR_PRIVATE2_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE2_AUTHEN_SET
GPR access control, offset: 0x4C54
◆ GPR_PRIVATE2_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE2_AUTHEN_TOG
GPR access control, offset: 0x4C5C
◆ GPR_PRIVATE2_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE2_CLR
General Purpose Register, offset: 0x4C48
◆ GPR_PRIVATE2_SET
__IO uint32_t CCM_Type::GPR_PRIVATE2_SET
General Purpose Register, offset: 0x4C44
◆ GPR_PRIVATE2_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE2_TOG
General Purpose Register, offset: 0x4C4C
◆ GPR_PRIVATE3
__IO uint32_t CCM_Type::GPR_PRIVATE3
General Purpose Register, offset: 0x4C60
◆ GPR_PRIVATE3_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE3_AUTHEN
GPR access control, offset: 0x4C70
◆ GPR_PRIVATE3_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE3_AUTHEN_CLR
GPR access control, offset: 0x4C78
◆ GPR_PRIVATE3_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE3_AUTHEN_SET
GPR access control, offset: 0x4C74
◆ GPR_PRIVATE3_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE3_AUTHEN_TOG
GPR access control, offset: 0x4C7C
◆ GPR_PRIVATE3_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE3_CLR
General Purpose Register, offset: 0x4C68
◆ GPR_PRIVATE3_SET
__IO uint32_t CCM_Type::GPR_PRIVATE3_SET
General Purpose Register, offset: 0x4C64
◆ GPR_PRIVATE3_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE3_TOG
General Purpose Register, offset: 0x4C6C
◆ GPR_PRIVATE4
__IO uint32_t CCM_Type::GPR_PRIVATE4
General Purpose Register, offset: 0x4C80
◆ GPR_PRIVATE4_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE4_AUTHEN
GPR access control, offset: 0x4C90
◆ GPR_PRIVATE4_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE4_AUTHEN_CLR
GPR access control, offset: 0x4C98
◆ GPR_PRIVATE4_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE4_AUTHEN_SET
GPR access control, offset: 0x4C94
◆ GPR_PRIVATE4_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE4_AUTHEN_TOG
GPR access control, offset: 0x4C9C
◆ GPR_PRIVATE4_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE4_CLR
General Purpose Register, offset: 0x4C88
◆ GPR_PRIVATE4_SET
__IO uint32_t CCM_Type::GPR_PRIVATE4_SET
General Purpose Register, offset: 0x4C84
◆ GPR_PRIVATE4_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE4_TOG
General Purpose Register, offset: 0x4C8C
◆ GPR_PRIVATE5
__IO uint32_t CCM_Type::GPR_PRIVATE5
General Purpose Register, offset: 0x4CA0
◆ GPR_PRIVATE5_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE5_AUTHEN
GPR access control, offset: 0x4CB0
◆ GPR_PRIVATE5_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE5_AUTHEN_CLR
GPR access control, offset: 0x4CB8
◆ GPR_PRIVATE5_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE5_AUTHEN_SET
GPR access control, offset: 0x4CB4
◆ GPR_PRIVATE5_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE5_AUTHEN_TOG
GPR access control, offset: 0x4CBC
◆ GPR_PRIVATE5_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE5_CLR
General Purpose Register, offset: 0x4CA8
◆ GPR_PRIVATE5_SET
__IO uint32_t CCM_Type::GPR_PRIVATE5_SET
General Purpose Register, offset: 0x4CA4
◆ GPR_PRIVATE5_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE5_TOG
General Purpose Register, offset: 0x4CAC
◆ GPR_PRIVATE6
__IO uint32_t CCM_Type::GPR_PRIVATE6
General Purpose Register, offset: 0x4CC0
◆ GPR_PRIVATE6_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE6_AUTHEN
GPR access control, offset: 0x4CD0
◆ GPR_PRIVATE6_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE6_AUTHEN_CLR
GPR access control, offset: 0x4CD8
◆ GPR_PRIVATE6_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE6_AUTHEN_SET
GPR access control, offset: 0x4CD4
◆ GPR_PRIVATE6_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE6_AUTHEN_TOG
GPR access control, offset: 0x4CDC
◆ GPR_PRIVATE6_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE6_CLR
General Purpose Register, offset: 0x4CC8
◆ GPR_PRIVATE6_SET
__IO uint32_t CCM_Type::GPR_PRIVATE6_SET
General Purpose Register, offset: 0x4CC4
◆ GPR_PRIVATE6_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE6_TOG
General Purpose Register, offset: 0x4CCC
◆ GPR_PRIVATE7
__IO uint32_t CCM_Type::GPR_PRIVATE7
General Purpose Register, offset: 0x4CE0
◆ GPR_PRIVATE7_AUTHEN
__IO uint32_t CCM_Type::GPR_PRIVATE7_AUTHEN
GPR access control, offset: 0x4CF0
◆ GPR_PRIVATE7_AUTHEN_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE7_AUTHEN_CLR
GPR access control, offset: 0x4CF8
◆ GPR_PRIVATE7_AUTHEN_SET
__IO uint32_t CCM_Type::GPR_PRIVATE7_AUTHEN_SET
GPR access control, offset: 0x4CF4
◆ GPR_PRIVATE7_AUTHEN_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE7_AUTHEN_TOG
GPR access control, offset: 0x4CFC
◆ GPR_PRIVATE7_CLR
__IO uint32_t CCM_Type::GPR_PRIVATE7_CLR
General Purpose Register, offset: 0x4CE8
◆ GPR_PRIVATE7_SET
__IO uint32_t CCM_Type::GPR_PRIVATE7_SET
General Purpose Register, offset: 0x4CE4
◆ GPR_PRIVATE7_TOG
__IO uint32_t CCM_Type::GPR_PRIVATE7_TOG
General Purpose Register, offset: 0x4CEC
◆ GPR_SHARED [1/3]
__IO uint32_t CCM_Type::GPR_SHARED
General Purpose Register, array offset: 0x4800, array step: 0x20
◆  [2/3]
__IO uint32_t { ... } ::GPR_SHARED
◆  [3/3]
◆ GPTIMER0CTRL
__IO uint32_t USB_Type::GPTIMER0CTRL
General Purpose Timer #0 Controller, offset: 0x84
◆ GPTIMER0LD
__IO uint32_t USB_Type::GPTIMER0LD
General Purpose Timer #0 Load, offset: 0x80
◆ GPTIMER1CTRL
__IO uint32_t USB_Type::GPTIMER1CTRL
General Purpose Timer #1 Controller, offset: 0x8C
◆ GPTIMER1LD
__IO uint32_t USB_Type::GPTIMER1LD
General Purpose Timer #1 Load, offset: 0x88
◆ GS
__IO uint32_t ADC_Type::GS
General status register, offset: 0x4C
◆ HADDREND
__IO uint32_t FLEXSPI_Type::HADDREND
HADDR REMAP END ADDR, offset: 0x424
◆ HADDROFFSET
__IO uint32_t FLEXSPI_Type::HADDROFFSET
HADDR REMAP OFFSET, offset: 0x428
◆ HADDRSTART
__IO uint32_t FLEXSPI_Type::HADDRSTART
HADDR REMAP START ADDR, offset: 0x420
◆ HBP
__IO uint32_t DSI_HOST_DPI_INTFC_Type::HBP
HBP, offset: 0x20
◆ HC
__IO uint32_t ADC_Type::HC[8]
Control register for hardware triggers, array offset: 0x0, array step: 0x4
◆ HCCPARAMS
__I uint32_t USB_Type::HCCPARAMS
Host Controller Capability Parameters, offset: 0x108
◆ HCIVERSION
__I uint16_t USB_Type::HCIVERSION
Host Controller Interface Version, offset: 0x102
◆ HCSPARAMS
__I uint32_t USB_Type::HCSPARAMS
Host Controller Structural Parameters, offset: 0x104
◆ HFP
__IO uint32_t DSI_HOST_DPI_INTFC_Type::HFP
HFP, offset: 0x1C
◆ HMSTRCR
__IO uint32_t FLEXSPI_Type::HMSTRCR
AHB Master ID 0 Control Register..AHB Master ID 7 Control Register, array offset: 0x400, array step: 0x4
◆  [1/4]
__IO uint16_t { ... } ::HOLD
Timer Channel Hold Register, array offset: 0x8, array step: 0x20
◆ HOLD [2/4]
__IO uint16_t TMR_Type::HOLD
◆  [3/4]
◆  [4/4]
◆ HOST_CTRL_CAP
__IO uint32_t USDHC_Type::HOST_CTRL_CAP
Host Controller Capabilities, offset: 0x40
◆ HP0
__IO uint32_t CSU_Type::HP0
HP0 register, offset: 0x200
◆ HP_TIMEOUT
__IO uint32_t SSARC_LP_Type::HP_TIMEOUT
HP Timeout Register, offset: 0x20C
◆ HPCOMR
__IO uint32_t SNVS_Type::HPCOMR
SNVS_HP Command Register, offset: 0x4
◆ HPCONTROL0
__IO uint32_t CSU_Type::HPCONTROL0
HPCONTROL0 register, offset: 0x358
◆ HPCR
__IO uint32_t SNVS_Type::HPCR
SNVS_HP Control Register, offset: 0x8
◆ HPHACIVR
__IO uint32_t SNVS_Type::HPHACIVR
SNVS_HP High Assurance Counter IV Register, offset: 0x1C
◆ HPHACR
__I uint32_t SNVS_Type::HPHACR
SNVS_HP High Assurance Counter Register, offset: 0x20
◆ HPLR
__IO uint32_t SNVS_Type::HPLR
SNVS_HP Lock Register, offset: 0x0
◆ HPRTCLR
__IO uint32_t SNVS_Type::HPRTCLR
SNVS_HP Real Time Counter LSB Register, offset: 0x28
◆ HPRTCMR
__IO uint32_t SNVS_Type::HPRTCMR
SNVS_HP Real Time Counter MSB Register, offset: 0x24
◆ HPSICR
__IO uint32_t SNVS_Type::HPSICR
SNVS_HP Security Interrupt Control Register, offset: 0xC
◆ HPSR
__IO uint32_t SNVS_Type::HPSR
SNVS_HP Status Register, offset: 0x14
◆ HPSVCR
__IO uint32_t SNVS_Type::HPSVCR
SNVS_HP Security Violation Control Register, offset: 0x10
◆ HPSVSR
__IO uint32_t SNVS_Type::HPSVSR
SNVS_HP Security Violation Status Register, offset: 0x18
◆ HPTALR
__IO uint32_t SNVS_Type::HPTALR
SNVS_HP Time Alarm LSB Register, offset: 0x30
◆ HPTAMR
__IO uint32_t SNVS_Type::HPTAMR
SNVS_HP Time Alarm MSB Register, offset: 0x2C
◆ HPVIDR1
__I uint32_t SNVS_Type::HPVIDR1
SNVS_HP Version ID Register 1, offset: 0xBF8
◆ HPVIDR2
__I uint32_t SNVS_Type::HPVIDR2
SNVS_HP Version ID Register 2, offset: 0xBFC
◆ HRS
__I uint32_t DMA_Type::HRS
Hardware Request Status, offset: 0x34
◆ HS
__I uint32_t ADC_Type::HS
Status register for HW triggers, offset: 0x20
◆ HSA
__IO uint32_t DSI_HOST_DPI_INTFC_Type::HSA
HSA, offset: 0x24
◆ HSIC_CTRL
__IO uint32_t USBNC_Type::HSIC_CTRL
USB Host HSIC Control Register, offset: 0x10
◆ HSYN_PARA
__IO uint32_t LCDIFV2_Type::HSYN_PARA
Horizontal Sync Parameter Register, offset: 0x18
◆ HSYNC_POLARITY
__IO uint32_t DSI_HOST_DPI_INTFC_Type::HSYNC_POLARITY
HSYNC_POLARITY, offset: 0x14
◆ HT_JD_ADDR [1/3]
__I uint64_t CAAM_Type::HT_JD_ADDR
Holding Tank 0 Job Descriptor Address, array offset: 0xC00, array step: 0x20
◆  [2/3]
__I uint64_t { ... } ::HT_JD_ADDR
◆  [3/3]
◆ HT_JQ_CTRL_LS [1/3]
__I uint32_t CAAM_Type::HT_JQ_CTRL_LS
Holding Tank 0 Job Queue Control, least-significant half, array offset: 0xC14, array step: 0x20
◆  [2/3]
__I uint32_t { ... } ::HT_JQ_CTRL_LS
◆  [3/3]
◆ HT_JQ_CTRL_MS [1/3]
__I uint32_t CAAM_Type::HT_JQ_CTRL_MS
Holding Tank 0 Job Queue Control, most-significant half, array offset: 0xC10, array step: 0x20
◆  [2/3]
__I uint32_t { ... } ::HT_JQ_CTRL_MS
◆  [3/3]
◆ HT_SD_ADDR [1/3]
__I uint64_t CAAM_Type::HT_SD_ADDR
Holding Tank 0 Shared Descriptor Address, array offset: 0xC08, array step: 0x20
◆  [2/3]
__I uint64_t { ... } ::HT_SD_ADDR
◆  [3/3]
◆ HT_STATUS [1/3]
__I uint32_t CAAM_Type::HT_STATUS
Holding Tank Status, array offset: 0xC1C, array step: 0x20
◆  [2/3]
__I uint32_t { ... } ::HT_STATUS
◆  [3/3]
◆ HW_GROUP_PENDING
__I uint32_t SSARC_LP_Type::HW_GROUP_PENDING
Hardware Request Pending Register, offset: 0x21C
◆ HWDEVICE
__I uint32_t USB_Type::HWDEVICE
Device Hardware Parameters, offset: 0xC
◆ HWGENERAL
__I uint32_t USB_Type::HWGENERAL
Hardware General, offset: 0x4
◆ HWHOST
__I uint32_t USB_Type::HWHOST
Host Hardware Parameters, offset: 0x8
◆ HWRXBUF
__I uint32_t USB_Type::HWRXBUF
RX Buffer Hardware Parameters, offset: 0x14
◆ HWTXBUF
__I uint32_t USB_Type::HWTXBUF
TX Buffer Hardware Parameters, offset: 0x10
◆ IALR
__IO uint32_t ENET_Type::IALR
Descriptor Individual Lower Address Register, offset: 0x11C
◆ IAUR
__IO uint32_t ENET_Type::IAUR
Descriptor Individual Upper Address Register, offset: 0x118
◆ ICR
__I uint32_t GPT_Type::ICR
GPT Input Capture Register 1..GPT Input Capture Register 2, array offset: 0x1C, array step: 0x4
GPT Input Capture Register, array offset: 0x1C, array step: 0x4
◆ ICR1
__IO uint32_t GPIO_Type::ICR1
GPIO interrupt configuration register1, offset: 0xC
◆ ICR2
__IO uint32_t GPIO_Type::ICR2
GPIO interrupt configuration register2, offset: 0x10
◆  [1/19]
__IO uint32_t { ... } ::ID
Message Buffer 0 ID Register..Message Buffer 63 ID Register, array offset: 0x84, array step: 0x10
◆ ID [2/19]
__IO uint32_t CAN_Type::ID
Message Buffer 0 ID Register..Message Buffer 20 ID Register, array offset: 0x84, array step: 0x18
Message Buffer 0 ID Register..Message Buffer 20 ID Register, array offset: 0x284, array step: 0x18
Message Buffer 0 ID Register..Message Buffer 11 ID Register, array offset: 0x84, array step: 0x28
Message Buffer 0 ID Register..Message Buffer 11 ID Register, array offset: 0x284, array step: 0x28
Message Buffer 0 ID Register..Message Buffer 6 ID Register, array offset: 0x84, array step: 0x48
Message Buffer 0 ID Register..Message Buffer 6 ID Register, array offset: 0x284, array step: 0x48
◆ ID [3/19]
__I uint32_t USB_Type::ID
Identification register, offset: 0x0
◆  [4/19]
◆  [5/19]
◆  [6/19]
◆  [7/19]
◆  [8/19]
◆  [9/19]
◆  [10/19]
◆  [11/19]
◆  [12/19]
◆  [13/19]
◆  [14/19]
◆  [15/19]
◆  [16/19]
◆  [17/19]
◆  [18/19]
◆  [19/19]
◆ IDXBLK
__IO uint32_t PUF_Type::IDXBLK
PUF Index Block Key Output, offset: 0x20C
◆ IDXBLK_DP
__IO uint32_t PUF_Type::IDXBLK_DP
PUF Index Block Key Output, offset: 0x210
◆ IDXBLK_SHIFT
__I uint32_t PUF_Type::IDXBLK_SHIFT
PUF Key Manager Shift Status, offset: 0x258
◆ IDXBLK_STATUS
__I uint32_t PUF_Type::IDXBLK_STATUS
PUF Index Block Setting Status Register, offset: 0x254
◆ IE
__IO uint32_t ADC_Type::IE
Interrupt Enable Register, offset: 0x18
◆ IEE_KEY_CTRL
__IO uint32_t KEY_MANAGER_Type::IEE_KEY_CTRL
CSR IEE Key Control, offset: 0x20
◆ IEEE_R_ALIGN
__I uint32_t ENET_Type::IEEE_R_ALIGN
Frames Received with Alignment Error Statistic Register, offset: 0x2D4
◆ IEEE_R_CRC
__I uint32_t ENET_Type::IEEE_R_CRC
Frames Received with CRC Error Statistic Register, offset: 0x2D0
◆ IEEE_R_DROP
__I uint32_t ENET_Type::IEEE_R_DROP
Frames not Counted Correctly Statistic Register, offset: 0x2C8
◆ IEEE_R_FDXFC
__I uint32_t ENET_Type::IEEE_R_FDXFC
Flow Control Pause Frames Received Statistic Register, offset: 0x2DC
◆ IEEE_R_FRAME_OK
__I uint32_t ENET_Type::IEEE_R_FRAME_OK
Frames Received OK Statistic Register, offset: 0x2CC
◆ IEEE_R_MACERR
__I uint32_t ENET_Type::IEEE_R_MACERR
Receive FIFO Overflow Count Statistic Register, offset: 0x2D8
◆ IEEE_R_OCTETS_OK
__I uint32_t ENET_Type::IEEE_R_OCTETS_OK
Octet Count for Frames Received without Error Statistic Register, offset: 0x2E0
◆ IEEE_T_1COL
__I uint32_t ENET_Type::IEEE_T_1COL
Frames Transmitted with Single Collision Statistic Register, offset: 0x250
◆ IEEE_T_CSERR
__I uint32_t ENET_Type::IEEE_T_CSERR
Frames Transmitted with Carrier Sense Error Statistic Register, offset: 0x268
◆ IEEE_T_DEF
__I uint32_t ENET_Type::IEEE_T_DEF
Frames Transmitted after Deferral Delay Statistic Register, offset: 0x258
◆ IEEE_T_DROP
uint32_t ENET_Type::IEEE_T_DROP
Reserved Statistic Register, offset: 0x248
◆ IEEE_T_EXCOL
__I uint32_t ENET_Type::IEEE_T_EXCOL
Frames Transmitted with Excessive Collisions Statistic Register, offset: 0x260
◆ IEEE_T_FDXFC
__I uint32_t ENET_Type::IEEE_T_FDXFC
Flow Control Pause Frames Transmitted Statistic Register, offset: 0x270
◆ IEEE_T_FRAME_OK
__I uint32_t ENET_Type::IEEE_T_FRAME_OK
Frames Transmitted OK Statistic Register, offset: 0x24C
◆ IEEE_T_LCOL
__I uint32_t ENET_Type::IEEE_T_LCOL
Frames Transmitted with Late Collision Statistic Register, offset: 0x25C
◆ IEEE_T_MACERR
__I uint32_t ENET_Type::IEEE_T_MACERR
Frames Transmitted with Tx FIFO Underrun Statistic Register, offset: 0x264
◆ IEEE_T_MCOL
__I uint32_t ENET_Type::IEEE_T_MCOL
Frames Transmitted with Multiple Collisions Statistic Register, offset: 0x254
◆ IEEE_T_OCTETS_OK
__I uint32_t ENET_Type::IEEE_T_OCTETS_OK
Octet Count for Frames Transmitted w/o Error Statistic Register, offset: 0x274
◆ IEEE_T_SQE
__I uint32_t ENET_Type::IEEE_T_SQE
Reserved Statistic Register, offset: 0x26C
◆ IER
__IO uint32_t LPSPI_Type::IER
Interrupt Enable, offset: 0x18
◆ IFLAG1
__IO uint32_t CAN_Type::IFLAG1
Interrupt Flags 1 Register, offset: 0x30
Interrupt Flags 1 register, offset: 0x30
◆ IFLAG2
__IO uint32_t CAN_Type::IFLAG2
Interrupt Flags 2 Register, offset: 0x2C
Interrupt Flags 2 register, offset: 0x2C
◆ IFSTAT
__IO uint32_t PUF_Type::IFSTAT
PUF Interface Status Register, offset: 0xDC
◆ IMAG_PARA
__IO uint32_t CSI_Type::IMAG_PARA
CSI Image Parameter Register, offset: 0x34
◆ IMASK1
__IO uint32_t CAN_Type::IMASK1
Interrupt Masks 1 Register, offset: 0x28
Interrupt Masks 1 register, offset: 0x28
◆ IMASK2
__IO uint32_t CAN_Type::IMASK2
Interrupt Masks 2 Register, offset: 0x24
Interrupt Masks 2 register, offset: 0x24
◆ IMR [1/3]
__I uint16_t ENC_Type::IMR
Input Monitor Register, offset: 0x1A
◆ IMR [2/3]
__IO uint32_t GPC_Type::IMR[4]
IRQ masking register 1..IRQ masking register 4, array offset: 0x8, array step: 0x4
◆ IMR [3/3]
__IO uint32_t GPIO_Type::IMR
GPIO interrupt mask register, offset: 0x14
◆ IMR5
__IO uint32_t GPC_Type::IMR5
IRQ masking register 5, offset: 0x34
◆  [1/4]
__IO uint16_t { ... } ::INIT
Initial Count Register, array offset: 0x2, array step: 0x60
◆ INIT [2/4]
__IO uint16_t PWM_Type::INIT
◆  [3/4]
◆  [4/4]
◆ INSTRUCTION_TIMER
__IO uint32_t CDOG_Type::INSTRUCTION_TIMER
Instruction Timer, offset: 0x8
◆ INT
__IO uint32_t DMA_Type::INT
Interrupt Request, offset: 0x24
◆ INT_CTRL
__IO uint32_t TRNG_Type::INT_CTRL
Interrupt Control Register, offset: 0xA4
◆ INT_EN
__IO uint32_t TSC_Type::INT_EN
Interrupt Enable, offset: 0x40
◆  [1/3]
__IO uint32_t { ... } ::INT_ENABLE
Interrupt Enable Register for domain 0..Interrupt Enable Register for domain 1, array offset: 0x24, array step: 0x10
◆ INT_ENABLE [2/3]
__IO uint32_t LCDIFV2_Type::INT_ENABLE
◆  [3/3]
◆ INT_MASK [1/2]
__IO uint32_t TRNG_Type::INT_MASK
Mask Register, offset: 0xA8
◆ INT_MASK [2/2]
__IO uint32_t EMVSIM_Type::INT_MASK
Interrupt Mask Register, offset: 0x14
◆ INT_SIG_EN [1/2]
__IO uint32_t FLEXRAM_Type::INT_SIG_EN
◆ INT_SIG_EN [2/2]
__IO uint32_t TSC_Type::INT_SIG_EN
Interrupt Signal Enable, offset: 0x50
◆ INT_SIGNAL_EN
__IO uint32_t USDHC_Type::INT_SIGNAL_EN
Interrupt Signal Enable, offset: 0x38
◆ INT_STAT_EN
__IO uint32_t FLEXRAM_Type::INT_STAT_EN
Interrupt Status Enable Register, offset: 0x14
◆ INT_STATUS [1/8]
__IO uint32_t FLEXRAM_Type::INT_STATUS
Interrupt Status Register, offset: 0x10
◆ INT_STATUS [2/8]
__I uint32_t TRNG_Type::INT_STATUS
Interrupt Status Register, offset: 0xAC
◆ INT_STATUS [3/8]
__IO uint32_t TSC_Type::INT_STATUS
Intterrupt Status, offset: 0x60
◆ INT_STATUS [4/8]
__IO uint32_t USDHC_Type::INT_STATUS
Interrupt Status, offset: 0x30
◆  [5/8]
__IO uint32_t { ... } ::INT_STATUS
Interrupt Status Register for domain 0..Interrupt Status Register for domain 1, array offset: 0x20, array step: 0x10
◆ INT_STATUS [6/8]
__IO uint32_t LCDIFV2_Type::INT_STATUS
◆ INT_STATUS [7/8]
__IO uint32_t SSARC_LP_Type::INT_STATUS
Interrupt Status Register, offset: 0x204
◆  [8/8]
◆ INT_STATUS_EN
__IO uint32_t USDHC_Type::INT_STATUS_EN
Interrupt Status Enable, offset: 0x34
◆ INTCTRL
__IO uint32_t RDC_Type::INTCTRL
Interrupt and Control, offset: 0x28
◆ INTEN [1/7]
__IO uint32_t FLEXSPI_Type::INTEN
Interrupt Enable Register, offset: 0x10
◆ INTEN [2/7]
__IO uint16_t PWM_Type::INTEN
Interrupt Enable Register, array offset: 0x26, array step: 0x60
◆  [3/7]
__IO uint16_t { ... } ::INTEN
◆ INTEN [4/7]
__IO uint32_t SEMC_Type::INTEN
Interrupt Enable Register, offset: 0x38
◆ INTEN [5/7]
__IO uint32_t PUF_Type::INTEN
PUF Interrupt Enable, offset: 0x100
◆  [6/7]
◆  [7/7]
◆ INTERFACE_COLOR_CODING
__IO uint32_t DSI_HOST_DPI_INTFC_Type::INTERFACE_COLOR_CODING
INTERFACE_COLOR_CODING, offset: 0x8
◆ INTR [1/2]
__IO uint32_t FLEXSPI_Type::INTR
Interrupt Register, offset: 0x14
◆ INTR [2/2]
__IO uint32_t SEMC_Type::INTR
Interrupt Enable Register, offset: 0x3C
Interrupt Register, offset: 0x3C
◆ INTSTAT [1/2]
__IO uint32_t PUF_Type::INTSTAT
PUF Interrupt Status, offset: 0x104
◆ INTSTAT [2/2]
__IO uint32_t RDC_Type::INTSTAT
Interrupt Status, offset: 0x2C
◆ IOCR
__IO uint32_t SEMC_Type::IOCR
IO Mux Control Register, offset: 0x4
IO MUX Control Register, offset: 0x4
◆ IPCMD [1/2]
__IO uint32_t FLEXSPI_Type::IPCMD
IP Command Register, offset: 0xB0
◆ IPCMD [2/2]
__IO uint32_t SEMC_Type::IPCMD
IP Command register, offset: 0x9C
IP Command Register, offset: 0x9C
◆ IPCR0 [1/2]
__IO uint32_t FLEXSPI_Type::IPCR0
IP Control Register 0, offset: 0xA0
◆ IPCR0 [2/2]
__IO uint32_t SEMC_Type::IPCR0
IP Command control register 0, offset: 0x90
IP Command Control Register 0, offset: 0x90
◆ IPCR1 [1/2]
__IO uint32_t FLEXSPI_Type::IPCR1
IP Control Register 1, offset: 0xA4
◆ IPCR1 [2/2]
__IO uint32_t SEMC_Type::IPCR1
IP Command control register 1, offset: 0x94
IP Command Control Register 1, offset: 0x94
◆ IPCR2
__IO uint32_t SEMC_Type::IPCR2
IP Command control register 2, offset: 0x98
IP Command Control Register 2, offset: 0x98
◆ IPRXDAT
__I uint32_t SEMC_Type::IPRXDAT
RX DATA register (for IP Command), offset: 0xB0
RX DATA Register, offset: 0xB0
◆ IPRXFCR
__IO uint32_t FLEXSPI_Type::IPRXFCR
IP RX FIFO Control Register, offset: 0xB8
◆ IPRXFSTS
__I uint32_t FLEXSPI_Type::IPRXFSTS
IP RX FIFO Status Register, offset: 0xF0
◆ IPSNSZEND0
__IO uint32_t FLEXSPI_Type::IPSNSZEND0
IPS nonsecure region End address of region 0, offset: 0x434
◆ IPSNSZEND1
__IO uint32_t FLEXSPI_Type::IPSNSZEND1
IPS nonsecure region End address of region 1, offset: 0x43C
◆ IPSNSZSTART0
__IO uint32_t FLEXSPI_Type::IPSNSZSTART0
IPS nonsecure region Start address of region 0, offset: 0x430
◆ IPSNSZSTART1
__IO uint32_t FLEXSPI_Type::IPSNSZSTART1
IPS nonsecure region Start address of region 1, offset: 0x438
◆ IPTXDAT
__IO uint32_t SEMC_Type::IPTXDAT
TX DATA register (for IP Command), offset: 0xA0
TX DATA Register, offset: 0xA0
◆ IPTXFCR
__IO uint32_t FLEXSPI_Type::IPTXFCR
IP TX FIFO Control Register, offset: 0xBC
◆ IPTXFSTS
__I uint32_t FLEXSPI_Type::IPTXFSTS
IP TX FIFO Status Register, offset: 0xF4
◆ IR
__IO uint32_t GPT_Type::IR
GPT Interrupt Register, offset: 0xC
◆  [1/3]
__IO uint64_t { ... } ::IRBAR_JR
Input Ring Base Address Register for Job Ring 0..Input Ring Base Address Register for Job Ring 3, array offset: 0x10000, array step: 0x10000
◆ IRBAR_JR [2/3]
__IO uint64_t CAAM_Type::IRBAR_JR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::IRJAR_JR
Input Ring Jobs Added Register for Job Ring0..Input Ring Jobs Added Register for Job Ring3, array offset: 0x1001C, array step: 0x10000
◆ IRJAR_JR [2/3]
__IO uint32_t CAAM_Type::IRJAR_JR
◆  [3/3]
◆ IRQ_MASK [1/2]
__IO uint32_t DSI_HOST_APB_PKT_IF_Type::IRQ_MASK
IRQ_MASK, offset: 0x28
◆ IRQ_MASK [2/2]
__IO uint32_t MIPI_CSI2RX_Type::IRQ_MASK
IRQ Mask Setting Register, offset: 0x110
◆ IRQ_MASK2
__IO uint32_t DSI_HOST_APB_PKT_IF_Type::IRQ_MASK2
IRQ_MASK2, offset: 0x2C
◆ IRQ_STATUS [1/2]
__I uint32_t DSI_HOST_APB_PKT_IF_Type::IRQ_STATUS
IRQ_STATUS, offset: 0x20
◆ IRQ_STATUS [2/2]
__I uint32_t MIPI_CSI2RX_Type::IRQ_STATUS
IRQ Status Register, offset: 0x10C
◆ IRQ_STATUS2
__I uint32_t DSI_HOST_APB_PKT_IF_Type::IRQ_STATUS2
IRQ_STATUS2, offset: 0x24
◆ IRRIR_JR [1/3]
__IO uint32_t CAAM_Type::IRRIR_JR
Input Ring Read Index Register for Job Ring 0..Input Ring Read Index Register for Job Ring 3, array offset: 0x1005C, array step: 0x10000
◆  [2/3]
__IO uint32_t { ... } ::IRRIR_JR
◆  [3/3]
◆ IRSAR_JR [1/3]
__IO uint32_t CAAM_Type::IRSAR_JR
Input Ring Slots Available Register for Job Ring 0..Input Ring Slots Available Register for Job Ring 3, array offset: 0x10014, array step: 0x10000
◆  [2/3]
__IO uint32_t { ... } ::IRSAR_JR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::IRSR_JR
Input Ring Size Register for Job Ring 0..Input Ring Size Register for Job Ring 3, array offset: 0x1000C, array step: 0x10000
◆ IRSR_JR [2/3]
__IO uint32_t CAAM_Type::IRSR_JR
◆  [3/3]
◆ ISCR [1/2]
__IO uint32_t CM7_MCM_Type::ISCR
Interrupt Status and Control Register, offset: 0x10
◆ ISCR [2/2]
__IO uint32_t MCM_Type::ISCR
◆ ISR [1/2]
__I uint32_t GPC_Type::ISR[4]
IRQ status resister 1..IRQ status resister 4, array offset: 0x18, array step: 0x4
◆ ISR [2/2]
__IO uint32_t GPIO_Type::ISR
GPIO interrupt status register, offset: 0x18
◆ ISR5
__I uint32_t GPC_Type::ISR5
IRQ status resister 5, offset: 0x38
◆ ITCM_ECC_MULTI_ERROR_ADDR
__I uint32_t FLEXRAM_Type::ITCM_ECC_MULTI_ERROR_ADDR
ITCM multi-bit ECC Error Address Register, offset: 0x50
◆ ITCM_ECC_MULTI_ERROR_DATA_LSB
__I uint32_t FLEXRAM_Type::ITCM_ECC_MULTI_ERROR_DATA_LSB
ITCM multi-bit ECC Error Data Register, offset: 0x54
◆ ITCM_ECC_MULTI_ERROR_DATA_MSB
__I uint32_t FLEXRAM_Type::ITCM_ECC_MULTI_ERROR_DATA_MSB
ITCM multi-bit ECC Error Data Register, offset: 0x58
◆ ITCM_ECC_MULTI_ERROR_INFO
__I uint32_t FLEXRAM_Type::ITCM_ECC_MULTI_ERROR_INFO
ITCM multi-bit ECC Error Information Register, offset: 0x4C
◆ ITCM_ECC_SINGLE_ERROR_ADDR
__I uint32_t FLEXRAM_Type::ITCM_ECC_SINGLE_ERROR_ADDR
ITCM single-bit ECC Error Address Register, offset: 0x40
◆ ITCM_ECC_SINGLE_ERROR_DATA_LSB
__I uint32_t FLEXRAM_Type::ITCM_ECC_SINGLE_ERROR_DATA_LSB
ITCM single-bit ECC Error Data Register, offset: 0x44
◆ ITCM_ECC_SINGLE_ERROR_DATA_MSB
__I uint32_t FLEXRAM_Type::ITCM_ECC_SINGLE_ERROR_DATA_MSB
ITCM single-bit ECC Error Data Register, offset: 0x48
◆ ITCM_ECC_SINGLE_ERROR_INFO
__I uint32_t FLEXRAM_Type::ITCM_ECC_SINGLE_ERROR_INFO
ITCM single-bit ECC Error Information Register, offset: 0x3C
◆ ITCM_MAGIC_ADDR
__IO uint32_t FLEXRAM_Type::ITCM_MAGIC_ADDR
ITCM Magic Address Register, offset: 0xC
◆ JDKEKR
__IO uint32_t CAAM_Type::JDKEKR
Job Descriptor Key Encryption Key Register, array offset: 0x400, array step: 0x4
◆ JQ_DEBUG_SEL
__IO uint32_t CAAM_Type::JQ_DEBUG_SEL
Job Queue Debug Select Register, offset: 0xC24
◆  [1/3]
__I uint64_t { ... } ::JRAAA[4]
Job Ring 0 Address-Array Address 0 Register..Job Ring 3 Address-Array Address 3 Register, array offset: 0x10800, array step: index*0x10000, index2*0x8
◆ JRAAA [2/3]
__I uint64_t CAAM_Type::JRAAA[4]
◆  [3/3]
◆ JRAAV [1/3]
__I uint32_t CAAM_Type::JRAAV
Job Ring 0 Address-Array Valid Register..Job Ring 3 Address-Array Valid Register, array offset: 0x10704, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::JRAAV
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::JRCFGR_JR_LS
Job Ring Configuration Register for Job Ring 0, least-significant half..Job Ring Configuration Register for Job Ring 3, least-significant half, array offset: 0x10054, array step: 0x10000
◆ JRCFGR_JR_LS [2/3]
__IO uint32_t CAAM_Type::JRCFGR_JR_LS
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::JRCFGR_JR_MS
Job Ring Configuration Register for Job Ring 0, most-significant half..Job Ring Configuration Register for Job Ring 3, most-significant half, array offset: 0x10050, array step: 0x10000
◆ JRCFGR_JR_MS [2/3]
__IO uint32_t CAAM_Type::JRCFGR_JR_MS
◆  [3/3]
◆  [1/3]
__O uint32_t { ... } ::JRCR_JR
Job Ring Command Register for Job Ring 0..Job Ring Command Register for Job Ring 3, array offset: 0x1006C, array step: 0x10000
◆ JRCR_JR [2/3]
__O uint32_t CAAM_Type::JRCR_JR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::JRDID_LS
Job Ring 0 DID Register - least significant half..Job Ring 3 DID Register - least significant half, array offset: 0x14, array step: 0x8
◆ JRDID_LS [2/3]
__IO uint32_t CAAM_Type::JRDID_LS
◆  [3/3]
◆ JRDID_MS [1/3]
__IO uint32_t CAAM_Type::JRDID_MS
Job Ring 0 DID Register - most significant half..Job Ring 3 DID Register - most significant half, array offset: 0x10, array step: 0x8
◆  [2/3]
__IO uint32_t { ... } ::JRDID_MS
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::JRINTR_JR
Job Ring Interrupt Status Register for Job Ring 0..Job Ring Interrupt Status Register for Job Ring 3, array offset: 0x1004C, array step: 0x10000
◆ JRINTR_JR [2/3]
__IO uint32_t CAAM_Type::JRINTR_JR
◆  [3/3]
◆ JRJDDA
__I uint64_t CAAM_Type::JRJDDA
Job Ring Job-Done Descriptor Address 0 Register, array offset: 0xE00, array step: 0x8
◆ JRJDJIF
__I uint32_t CAAM_Type::JRJDJIF
Job Ring Job-Done Job ID FIFO, offset: 0xDC4
◆ JRJDJIFBC
__I uint32_t CAAM_Type::JRJDJIFBC
Job Ring Job-Done Job ID FIFO BC, offset: 0xDC0
◆ JRJDS1
__I uint32_t CAAM_Type::JRJDS1
Job Ring Job-Done Source 1, offset: 0xDE4
◆ JRJIDU_LS
__I uint32_t CAAM_Type::JRJIDU_LS
Job Ring Job IDs in Use Register, least-significant half, offset: 0xDBC
◆  [1/3]
__IO uint32_t { ... } ::JRSMVBAR
Job Ring 0 Secure Memory Virtual Base Address Register..Job Ring 3 Secure Memory Virtual Base Address Register, array offset: 0x184, array step: 0x8
◆ JRSMVBAR [2/3]
__IO uint32_t CAAM_Type::JRSMVBAR
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::JRSTAR_JR
Job Ring Output Status Register for Job Ring 0..Job Ring Output Status Register for Job Ring 3, array offset: 0x10044, array step: 0x10000
◆ JRSTAR_JR [2/3]
__I uint32_t CAAM_Type::JRSTAR_JR
◆  [3/3]
◆ JRSTARTR
__IO uint32_t CAAM_Type::JRSTARTR
Job Ring Start Register, offset: 0x5C
◆ KDDR
__IO uint16_t KPP_Type::KDDR
Keypad Data Direction Register, offset: 0x4
◆ KEY [1/4]
__IO uint32_t DCP_Type::KEY
DCP key index, offset: 0x60
◆ KEY [2/4]
__IO uint32_t OTFAD_Type::KEY[4]
AES Key Word, array offset: 0xD00, array step: index*0x40, index2*0x4
◆  [3/4]
__IO uint32_t { ... } ::KEY[4]
◆  [4/4]
◆ KEYDATA
__IO uint32_t DCP_Type::KEYDATA
DCP key data, offset: 0x70
◆ KEYENABLE
__IO uint32_t PUF_Type::KEYENABLE
PUF Key Manager Enable, offset: 0x204
◆ KEYINDEX
__IO uint32_t PUF_Type::KEYINDEX
PUF Key Index Register, offset: 0x4
◆ KEYINPUT
__O uint32_t PUF_Type::KEYINPUT
PUF Key Input Register, offset: 0x40
◆ KEYLOCK
__IO uint32_t PUF_Type::KEYLOCK
PUF Key Manager Lock, offset: 0x200
◆ KEYMASK
__IO uint32_t PUF_Type::KEYMASK
PUF Key Block 0 Mask Enable..PUF Key Block 1 Mask Enable, array offset: 0x214, array step: 0x4
◆ KEYOUTINDEX
__I uint32_t PUF_Type::KEYOUTINDEX
PUF Key Output Index Register, offset: 0x60
◆ KEYOUTPUT
__I uint32_t PUF_Type::KEYOUTPUT
PUF Key Output Register, offset: 0x64
◆ KEYRESET
__IO uint32_t PUF_Type::KEYRESET
PUF Key Manager Reset, offset: 0x208
◆ KEYSIZE
__IO uint32_t PUF_Type::KEYSIZE
PUF Key Size Register, offset: 0x8
◆ KPCR
__IO uint16_t KPP_Type::KPCR
Keypad Control Register, offset: 0x0
◆ KPDR
__IO uint16_t KPP_Type::KPDR
Keypad Data Register, offset: 0x6
◆ KPSR
__IO uint16_t KPP_Type::KPSR
Keypad Status Register, offset: 0x2
◆ LASTEDGE
__I uint16_t ENC_Type::LASTEDGE
Last Edge Time Register, offset: 0x28
◆ LASTEDGEH
__I uint16_t ENC_Type::LASTEDGEH
Last Edge Time Hold Register, offset: 0x2A
◆ LCOMP
__IO uint16_t ENC_Type::LCOMP
Lower Position Compare Register, offset: 0x26
◆ LDO_LPSR_ANA_BYPASS_EN_SP
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_ANA_BYPASS_EN_SP
LDO_LPSR_ANA_BYPASS_EN_SP_REGISTER, offset: 0x640
◆ LDO_LPSR_ANA_ENABLE_SP
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_ANA_ENABLE_SP
LDO_LPSR_ANA_ENABLE_SP_REGISTER, offset: 0x610
◆ LDO_LPSR_ANA_LP_MODE_SP
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_ANA_LP_MODE_SP
LDO_LPSR_ANA_LP_MODE_SP_REGISTER, offset: 0x620
◆ LDO_LPSR_ANA_STBY_EN_SP
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_ANA_STBY_EN_SP
LDO_LPSR_ANA_STBY_EN_SP_REGISTER, offset: 0x650
◆ LDO_LPSR_ANA_TRACKING_EN_SP
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_ANA_TRACKING_EN_SP
LDO_LPSR_ANA_TRACKING_EN_SP_REGISTER, offset: 0x630
◆ LDO_LPSR_DIG_BYPASS_EN_SP
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_BYPASS_EN_SP
LDO_LPSR_DIG_BYPASS_EN_SP_REGISTER, offset: 0x6D0
◆ LDO_LPSR_DIG_ENABLE_SP
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_ENABLE_SP
LDO_LPSR_DIG_ENABLE_SP_REGISTER, offset: 0x660
◆ LDO_LPSR_DIG_LP_MODE_SP
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_LP_MODE_SP
LDO_LPSR_DIG_LP_MODE_SP_REGISTER, offset: 0x6B0
◆ LDO_LPSR_DIG_STBY_EN_SP
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_STBY_EN_SP
LDO_LPSR_DIG_STBY_EN_SP_REGISTER, offset: 0x6E0
◆ LDO_LPSR_DIG_TRACKING_EN_SP
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_TRACKING_EN_SP
LDO_LPSR_DIG_TRACKING_EN_SP_REGISTER, offset: 0x6C0
◆ LDO_LPSR_DIG_TRG_SP0
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_TRG_SP0
LDO_LPSR_DIG_TRG_SP0_REGISTER, offset: 0x670
◆ LDO_LPSR_DIG_TRG_SP1
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_TRG_SP1
LDO_LPSR_DIG_TRG_SP1_REGISTER, offset: 0x680
◆ LDO_LPSR_DIG_TRG_SP2
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_TRG_SP2
LDO_LPSR_DIG_TRG_SP2_REGISTER, offset: 0x690
◆ LDO_LPSR_DIG_TRG_SP3
__IO uint32_t ANADIG_PMU_Type::LDO_LPSR_DIG_TRG_SP3
LDO_LPSR_DIG_TRG_SP3_REGISTER, offset: 0x6A0
◆ LDO_PLL_ENABLE_SP
__IO uint32_t ANADIG_PMU_Type::LDO_PLL_ENABLE_SP
LDO_PLL_ENABLE_SP_REGISTER, offset: 0x600
◆ LDVAL [1/4]
__IO uint32_t PIT_Type::LDVAL
Timer Load Value Register, array offset: 0x100, array step: 0x10
◆  [2/4]
__IO uint32_t { ... } ::LDVAL
◆  [3/4]
◆  [4/4]
◆ LINIT
__IO uint16_t ENC_Type::LINIT
Lower Initialization Register, offset: 0x18
◆ LMDR
__IO uint32_t MCM_Type::LMDR[4]
Local Memory Descriptor Register, array offset: 0x400, array step: 0x4
◆ LMFAR
__I uint32_t MCM_Type::LMFAR
LMEM Fault Address Register, offset: 0x490
◆ LMFATR
__IO uint32_t MCM_Type::LMFATR
LMEM Fault Attribute Register, offset: 0x494
◆ LMFDHR
__I uint32_t MCM_Type::LMFDHR
LMEM Fault Data High Register, offset: 0x4A0
◆ LMFDLR
__I uint32_t MCM_Type::LMFDLR
LMEM Fault Data Low Register, offset: 0x4A4
◆ LMOD
__IO uint16_t ENC_Type::LMOD
Lower Modulus Register, offset: 0x22
◆ LMPECR
__IO uint32_t MCM_Type::LMPECR
LMEM Parity & ECC Control Register, offset: 0x480
◆ LMPEIR
__IO uint32_t MCM_Type::LMPEIR
LMEM Parity & ECC Interrupt Register, offset: 0x488
◆  [1/4]
__IO uint16_t { ... } ::LOAD
Timer Channel Load Register, array offset: 0x6, array step: 0x20
◆ LOAD [2/4]
__IO uint16_t TMR_Type::LOAD
◆  [3/4]
◆  [4/4]
◆ LOCK [1/2]
__IO uint32_t OCOTP_Type::LOCK
Value of OTP Bank0 Word0 (Lock controls), offset: 0x400
◆ LOCK [2/2]
__I uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::LOCK
LOCK, offset: 0x30
◆ LOCK_BYP
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::LOCK_BYP
LOCK_BYP, offset: 0x34
◆ LOCKED0
__I uint32_t OCOTP_Type::LOCKED0
OTP Controller Program Locked Status 0 Register, offset: 0x600
◆ LOCKED1
__I uint32_t OCOTP_Type::LOCKED1
OTP Controller Program Locked Status 1 Register, offset: 0x610
◆ LOCKED2
__I uint32_t OCOTP_Type::LOCKED2
OTP Controller Program Locked Status 2 Register, offset: 0x620
◆ LOCKED3
__I uint32_t OCOTP_Type::LOCKED3
OTP Controller Program Locked Status 3 Register, offset: 0x630
◆ LOCKED4
__I uint32_t OCOTP_Type::LOCKED4
OTP Controller Program Locked Status 4 Register, offset: 0x640
◆  [1/2]
__IO uint32_t { ... } ::LOOPBACK
USB Loopback Test Register, array offset: 0x1E0, array step: 0x60
◆ LOOPBACK [2/2]
__IO uint32_t USB_ANALOG_Type::LOOPBACK
◆  [1/2]
__IO uint32_t { ... } ::LOOPBACK_CLR
USB Loopback Test Register, array offset: 0x1E8, array step: 0x60
◆ LOOPBACK_CLR [2/2]
__IO uint32_t USB_ANALOG_Type::LOOPBACK_CLR
◆  [1/2]
__IO uint32_t { ... } ::LOOPBACK_SET
USB Loopback Test Register, array offset: 0x1E4, array step: 0x60
◆ LOOPBACK_SET [2/2]
__IO uint32_t USB_ANALOG_Type::LOOPBACK_SET
◆  [1/2]
__IO uint32_t { ... } ::LOOPBACK_TOG
USB Loopback Test Register, array offset: 0x1EC, array step: 0x60
◆ LOOPBACK_TOG [2/2]
__IO uint32_t USB_ANALOG_Type::LOOPBACK_TOG
◆ LOWPWR_CTRL
__IO uint32_t XTALOSC24M_Type::LOWPWR_CTRL
XTAL OSC (LP) Control Register, offset: 0x270
◆ LOWPWR_CTRL_CLR
__IO uint32_t XTALOSC24M_Type::LOWPWR_CTRL_CLR
XTAL OSC (LP) Control Register, offset: 0x278
◆ LOWPWR_CTRL_SET
__IO uint32_t XTALOSC24M_Type::LOWPWR_CTRL_SET
XTAL OSC (LP) Control Register, offset: 0x274
◆ LOWPWR_CTRL_TOG
__IO uint32_t XTALOSC24M_Type::LOWPWR_CTRL_TOG
XTAL OSC (LP) Control Register, offset: 0x27C
◆ LPATCLKR
__IO uint32_t SNVS_Type::LPATCLKR
SNVS_LP Active Tamper Clock Control Register, offset: 0xE4
◆ LPATCR
__O uint32_t SNVS_Type::LPATCR
SNVS_LP Active Tamper 1 Configuration Register..SNVS_LP Active Tamper 5 Configuration Register, array offset: 0xC0, array step: 0x4
◆ LPATCTLR
__IO uint32_t SNVS_Type::LPATCTLR
SNVS_LP Active Tamper Control Register, offset: 0xE0
◆ LPATRC1R
__IO uint32_t SNVS_Type::LPATRC1R
SNVS_LP Active Tamper Routing Control 1 Register, offset: 0xE8
◆ LPATRC2R
__IO uint32_t SNVS_Type::LPATRC2R
SNVS_LP Active Tamper Routing Control 2 Register, offset: 0xEC
◆ LPCR
__IO uint32_t SNVS_Type::LPCR
SNVS_LP Control Register, offset: 0x38
◆ LPGPR
__IO uint32_t SNVS_Type::LPGPR
SNVS_LP General Purpose Registers 0 .. 7, array offset: 0x100, array step: 0x4
SNVS_LP General Purpose Registers 0 .. 3, array offset: 0x100, array step: 0x4
◆ LPGPR0_LEGACY_ALIAS
__IO uint32_t SNVS_Type::LPGPR0_LEGACY_ALIAS
SNVS_LP General Purpose Register 0 (legacy alias), offset: 0x68
◆ LPGPR_ALIAS
__IO uint32_t SNVS_Type::LPGPR_ALIAS
SNVS_LP General Purpose Registers 0 .. 3, array offset: 0x90, array step: 0x4
◆ LPLR
__IO uint32_t SNVS_Type::LPLR
SNVS_LP Lock Register, offset: 0x34
◆ LPLVDR
__IO uint32_t SNVS_Type::LPLVDR
SNVS_LP Digital Low-Voltage Detector Register, offset: 0x64
◆ LPMKCR
__IO uint32_t SNVS_Type::LPMKCR
SNVS_LP Master Key Control Register, offset: 0x3C
◆ LPOS
__IO uint16_t ENC_Type::LPOS
Lower Position Counter Register, offset: 0x10
◆ LPOSH
__I uint16_t ENC_Type::LPOSH
Lower Position Hold Register, offset: 0x14
◆ LPSECR
__IO uint32_t SNVS_Type::LPSECR
SNVS_LP Security Events Configuration Register, offset: 0x48
◆ LPSMCLR
__IO uint32_t SNVS_Type::LPSMCLR
SNVS_LP Secure Monotonic Counter LSB Register, offset: 0x60
◆ LPSMCMR
__IO uint32_t SNVS_Type::LPSMCMR
SNVS_LP Secure Monotonic Counter MSB Register, offset: 0x5C
◆ LPSR
__IO uint32_t SNVS_Type::LPSR
SNVS_LP Status Register, offset: 0x4C
◆ LPSR_1P8_LDO_OTP_TRIM_VALUE
__I uint32_t ANADIG_PMU_Type::LPSR_1P8_LDO_OTP_TRIM_VALUE
LPSR_1P8_LDO_OTP_TRIM_VALUE_REGISTER, offset: 0x7D0
◆ LPSRTCLR
__IO uint32_t SNVS_Type::LPSRTCLR
SNVS_LP Secure Real Time Counter LSB Register, offset: 0x54
◆ LPSRTCMR
__IO uint32_t SNVS_Type::LPSRTCMR
SNVS_LP Secure Real Time Counter MSB Register, offset: 0x50
◆ LPSVCR
__IO uint32_t SNVS_Type::LPSVCR
SNVS_LP Security Violation Control Register, offset: 0x40
◆ LPTAR
__IO uint32_t SNVS_Type::LPTAR
SNVS_LP Time Alarm Register, offset: 0x58
◆ LPTDC2R
__IO uint32_t SNVS_Type::LPTDC2R
SNVS_LP Tamper Detectors Config 2 Register, offset: 0xA0
◆ LPTDCR
__IO uint32_t SNVS_Type::LPTDCR
SNVS_LP Tamper Detect Configuration Register, offset: 0x48
◆ LPTDSR
__IO uint32_t SNVS_Type::LPTDSR
SNVS_LP Tamper Detectors Status Register, offset: 0xA4
◆ LPTGF1CR
__IO uint32_t SNVS_Type::LPTGF1CR
SNVS_LP Tamper Glitch Filter 1 Configuration Register, offset: 0xA8
◆ LPTGF2CR
__IO uint32_t SNVS_Type::LPTGF2CR
SNVS_LP Tamper Glitch Filter 2 Configuration Register, offset: 0xAC
◆ LPTGFCR
__IO uint32_t SNVS_Type::LPTGFCR
SNVS_LP Tamper Glitch Filters Configuration Register, offset: 0x44
◆ LPZMKR
__IO uint32_t SNVS_Type::LPZMKR
SNVS_LP Zeroizable Master Key Register, array offset: 0x6C, array step: 0x4
◆ LTMR64H
__I uint32_t PIT_Type::LTMR64H
PIT Upper Lifetime Timer Register, offset: 0xE0
◆ LTMR64L
__I uint32_t PIT_Type::LTMR64L
PIT Lower Lifetime Timer Register, offset: 0xE4
◆ LUT
__IO uint32_t FLEXSPI_Type::LUT
LUT 0..LUT 63, array offset: 0x200, array step: 0x4
◆ LUT0_ADDR
__IO uint32_t LCDIF_Type::LUT0_ADDR
Lookup Table 0 Index Register, offset: 0xB10
◆ LUT0_DATA
__IO uint32_t LCDIF_Type::LUT0_DATA
Lookup Table 0 Data Register, offset: 0xB20
◆ LUT1_ADDR
__IO uint32_t LCDIF_Type::LUT1_ADDR
Lookup Table 1 Index Register, offset: 0xB30
◆ LUT1_DATA
__IO uint32_t LCDIF_Type::LUT1_DATA
Lookup Table 1 Data Register, offset: 0xB40
◆ LUT_CTRL
__IO uint32_t LCDIF_Type::LUT_CTRL
Look Up Table Control Register, offset: 0xB00
◆ LUTCR
__IO uint32_t FLEXSPI_Type::LUTCR
LUT Control Register, offset: 0x1C
◆ LUTKEY
__IO uint32_t FLEXSPI_Type::LUTKEY
LUT Key Register, offset: 0x18
◆ M_PRG_HS_PREPARE
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::M_PRG_HS_PREPARE
M_PRG_HS_PREPARE, offset: 0x4
◆ M_PRG_HS_TRAIL
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::M_PRG_HS_TRAIL
M_PRG_HS_TRAIL, offset: 0x14
◆ M_PRG_HS_ZERO
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::M_PRG_HS_ZERO
M_PRG_HS_ZERO, offset: 0xC
◆ MAC0
__IO uint32_t OCOTP_Type::MAC0
Value of OTP Bank4 Word2 (MAC Address), offset: 0x620
◆ MAC1
__IO uint32_t OCOTP_Type::MAC1
Value of OTP Bank4 Word3 (MAC Address), offset: 0x630
◆ MASK
__IO uint16_t PWM_Type::MASK
Mask Register, offset: 0x182
◆ MASTER_KEY_CTRL
__IO uint32_t KEY_MANAGER_Type::MASTER_KEY_CTRL
CSR Master Key Control Register, offset: 0x0
◆ MATCH
__IO uint32_t LPUART_Type::MATCH
LPUART Match Address Register, offset: 0x20
◆ MC_PRG_HS_PREPARE
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::MC_PRG_HS_PREPARE
MC_PRG_HS_PREPARE, offset: 0x8
◆ MC_PRG_HS_TRAIL
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::MC_PRG_HS_TRAIL
MC_PRG_HS_TRAIL, offset: 0x18
◆ MC_PRG_HS_ZERO
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::MC_PRG_HS_ZERO
MC_PRG_HS_ZERO, offset: 0x10
◆ MCCR0
__IO uint32_t LPI2C_Type::MCCR0
Master Clock Configuration Register 0, offset: 0x48
Master Clock Configuration 0, offset: 0x48
◆ MCCR1
__IO uint32_t LPI2C_Type::MCCR1
Master Clock Configuration Register 1, offset: 0x50
Master Clock Configuration 1, offset: 0x50
◆ MCFGR
__IO uint32_t CAAM_Type::MCFGR
Master Configuration Register, offset: 0x4
◆ MCFGR0
__IO uint32_t LPI2C_Type::MCFGR0
Master Configuration Register 0, offset: 0x20
Master Configuration 0, offset: 0x20
◆ MCFGR1
__IO uint32_t LPI2C_Type::MCFGR1
Master Configuration Register 1, offset: 0x24
Master Configuration 1, offset: 0x24
◆ MCFGR2
__IO uint32_t LPI2C_Type::MCFGR2
Master Configuration Register 2, offset: 0x28
Master Configuration 2, offset: 0x28
◆ MCFGR3
__IO uint32_t LPI2C_Type::MCFGR3
Master Configuration Register 3, offset: 0x2C
Master Configuration 3, offset: 0x2C
◆ MCR [1/5]
__IO uint32_t CAN_Type::MCR
Module Configuration Register, offset: 0x0
Module Configuration register, offset: 0x0
◆ MCR [2/5]
__IO uint32_t LPI2C_Type::MCR
Master Control Register, offset: 0x10
Master Control, offset: 0x10
◆ MCR [3/5]
__IO uint32_t PIT_Type::MCR
PIT Module Control Register, offset: 0x0
◆ MCR [4/5]
__IO uint32_t SEMC_Type::MCR
◆ MCR [5/5]
__IO uint32_t XRDC2_Type::MCR
◆ MCR0
__IO uint32_t FLEXSPI_Type::MCR0
Module Control Register 0, offset: 0x0
◆ MCR1
__IO uint32_t FLEXSPI_Type::MCR1
Module Control Register 1, offset: 0x4
◆ MCR2
__IO uint32_t FLEXSPI_Type::MCR2
Module Control Register 2, offset: 0x8
◆ MCTL
__IO uint32_t TRNG_Type::MCTL
Miscellaneous Control Register, offset: 0x0
◆ MCTRL
__IO uint16_t PWM_Type::MCTRL
Master Control Register, offset: 0x188
◆ MCTRL2
__IO uint16_t PWM_Type::MCTRL2
Master Control 2 Register, offset: 0x18A
◆ MDA
__IO uint32_t RDC_Type::MDA
Master Domain Assignment, array offset: 0x200, array step: 0x4
◆  [1/3]
__IO uint32_t { ... } ::MDAC_MDA_W0
Master Domain Assignment, array offset: 0x2000, array step: index*0x100, index2*0x8
◆ MDAC_MDA_W0 [2/3]
__IO uint32_t XRDC2_Type::MDAC_MDA_W0
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::MDAC_MDA_W1
Master Domain Assignment, array offset: 0x2004, array step: index*0x100, index2*0x8
◆ MDAC_MDA_W1 [2/3]
__IO uint32_t XRDC2_Type::MDAC_MDA_W1
◆  [3/3]
◆ MDER
__IO uint32_t LPI2C_Type::MDER
Master DMA Enable Register, offset: 0x1C
Master DMA Enable, offset: 0x1C
◆ MDMR
__IO uint32_t LPI2C_Type::MDMR
Master Data Match Register, offset: 0x40
Master Data Match, offset: 0x40
◆ MEASEURE_VALUE
__I uint32_t TSC_Type::MEASEURE_VALUE
Measure Value, offset: 0x30
◆ MECR
__IO uint32_t CAN_Type::MECR
Memory Error Control register, offset: 0xAE0
◆ MEGA_CTRL
__IO uint32_t PGC_Type::MEGA_CTRL
PGC Mega Control Register, offset: 0x220
◆ MEGA_PDNSCR
__IO uint32_t PGC_Type::MEGA_PDNSCR
PGC Mega Pull Down Sequence Control Register, offset: 0x228
◆ MEGA_PUPSCR
__IO uint32_t PGC_Type::MEGA_PUPSCR
PGC Mega Power Up Sequence Control Register, offset: 0x224
◆ MEGA_SR
__IO uint32_t PGC_Type::MEGA_SR
PGC Mega Power Gating Controller Status Register, offset: 0x22C
◆ MEM0
__IO uint32_t OCOTP_Type::MEM0
Value of OTP Bank1 Word0 (Memory Related Info.), offset: 0x480
◆ MEM1
__IO uint32_t OCOTP_Type::MEM1
Value of OTP Bank1 Word1 (Memory Related Info.), offset: 0x490
◆ MEM2
__IO uint32_t OCOTP_Type::MEM2
Value of OTP Bank1 Word2 (Memory Related Info.), offset: 0x4A0
◆ MEM3
__IO uint32_t OCOTP_Type::MEM3
Value of OTP Bank1 Word3 (Memory Related Info.), offset: 0x4B0
◆ MEM4
__IO uint32_t OCOTP_Type::MEM4
Value of OTP Bank 1 Word 4 (Memory Related Info.), offset: 0x4C0
◆ MEMCFG
__I uint32_t MCM_Type::MEMCFG
Memory configuration, offset: 0x4
◆ MFCR
__IO uint32_t LPI2C_Type::MFCR
Master FIFO Control Register, offset: 0x58
Master FIFO Control, offset: 0x58
◆ MFSR
__I uint32_t LPI2C_Type::MFSR
Master FIFO Status Register, offset: 0x5C
Master FIFO Status, offset: 0x5C
◆ MIBC
__IO uint32_t ENET_Type::MIBC
MIB Control Register, offset: 0x64
◆ MIER
__IO uint32_t LPI2C_Type::MIER
Master Interrupt Enable Register, offset: 0x18
Master Interrupt Enable, offset: 0x18
◆ MIF_AUTHEN_CTRL
__IO uint32_t PGMC_MIF_Type::MIF_AUTHEN_CTRL
MIF Authentication Control, offset: 0x4
◆ MIF_MLPL_ARR_PDN
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_ARR_PDN
MIF MLPL control of array power down, offset: 0x60
◆ MIF_MLPL_HS
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_HS
MIF MLPL control of HS, offset: 0x40
◆ MIF_MLPL_IG
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_IG
MIF MLPL control of IG, offset: 0x20
◆ MIF_MLPL_INITN
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_INITN
MIF MLPL control of INITN, offset: 0x80
◆ MIF_MLPL_ISO
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_ISO
MIF MLPL control of isolation enable, offset: 0xB0
◆ MIF_MLPL_LS
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_LS
MIF MLPL control of LS, offset: 0x30
◆ MIF_MLPL_PER_PDN
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_PER_PDN
MIF MLPL control of peripheral power down, offset: 0x70
◆ MIF_MLPL_SLEEP
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_SLEEP
MIF MLPL control of SLEEP, offset: 0x10
◆ MIF_MLPL_STDBY
__IO uint32_t PGMC_MIF_Type::MIF_MLPL_STDBY
MIF MLPL control of STDBY, offset: 0x50
◆ MISC [1/2]
__IO uint32_t USB_ANALOG_Type::MISC
USB Misc Register, array offset: 0x1F0, array step: 0x60
◆  [2/2]
__IO uint32_t { ... } ::MISC
◆ MISC0 [1/3]
__IO uint32_t CCM_ANALOG_Type::MISC0
Miscellaneous Register 0, offset: 0x150
◆ MISC0 [2/3]
__IO uint32_t PMU_Type::MISC0
◆ MISC0 [3/3]
__IO uint32_t XTALOSC24M_Type::MISC0
◆ MISC0_CLR [1/3]
__IO uint32_t CCM_ANALOG_Type::MISC0_CLR
Miscellaneous Register 0, offset: 0x158
◆ MISC0_CLR [2/3]
__IO uint32_t PMU_Type::MISC0_CLR
◆ MISC0_CLR [3/3]
__IO uint32_t XTALOSC24M_Type::MISC0_CLR
◆ MISC0_SET [1/3]
__IO uint32_t CCM_ANALOG_Type::MISC0_SET
Miscellaneous Register 0, offset: 0x154
◆ MISC0_SET [2/3]
__IO uint32_t PMU_Type::MISC0_SET
◆ MISC0_SET [3/3]
__IO uint32_t XTALOSC24M_Type::MISC0_SET
◆ MISC0_TOG [1/3]
__IO uint32_t CCM_ANALOG_Type::MISC0_TOG
Miscellaneous Register 0, offset: 0x15C
◆ MISC0_TOG [2/3]
__IO uint32_t PMU_Type::MISC0_TOG
◆ MISC0_TOG [3/3]
__IO uint32_t XTALOSC24M_Type::MISC0_TOG
◆ MISC1 [1/2]
__IO uint32_t CCM_ANALOG_Type::MISC1
Miscellaneous Register 1, offset: 0x160
◆ MISC1 [2/2]
__IO uint32_t PMU_Type::MISC1
◆ MISC1_CLR [1/2]
__IO uint32_t CCM_ANALOG_Type::MISC1_CLR
Miscellaneous Register 1, offset: 0x168
◆ MISC1_CLR [2/2]
__IO uint32_t PMU_Type::MISC1_CLR
◆ MISC1_SET [1/2]
__IO uint32_t CCM_ANALOG_Type::MISC1_SET
Miscellaneous Register 1, offset: 0x164
◆ MISC1_SET [2/2]
__IO uint32_t PMU_Type::MISC1_SET
◆ MISC1_TOG [1/2]
__IO uint32_t CCM_ANALOG_Type::MISC1_TOG
Miscellaneous Register 1, offset: 0x16C
◆ MISC1_TOG [2/2]
__IO uint32_t PMU_Type::MISC1_TOG
◆ MISC2 [1/2]
__IO uint32_t CCM_ANALOG_Type::MISC2
Miscellaneous Register 2, offset: 0x170
◆ MISC2 [2/2]
__IO uint32_t PMU_Type::MISC2
Miscellaneous Control Register, offset: 0x170
◆ MISC2_CLR [1/2]
__IO uint32_t CCM_ANALOG_Type::MISC2_CLR
Miscellaneous Register 2, offset: 0x178
◆ MISC2_CLR [2/2]
__IO uint32_t PMU_Type::MISC2_CLR
Miscellaneous Control Register, offset: 0x178
◆ MISC2_SET [1/2]
__IO uint32_t CCM_ANALOG_Type::MISC2_SET
Miscellaneous Register 2, offset: 0x174
◆ MISC2_SET [2/2]
__IO uint32_t PMU_Type::MISC2_SET
Miscellaneous Control Register, offset: 0x174
◆ MISC2_TOG [1/2]
__IO uint32_t CCM_ANALOG_Type::MISC2_TOG
Miscellaneous Register 2, offset: 0x17C
◆ MISC2_TOG [2/2]
__IO uint32_t PMU_Type::MISC2_TOG
Miscellaneous Control Register, offset: 0x17C
◆ MISC_CLR [1/2]
__IO uint32_t USB_ANALOG_Type::MISC_CLR
USB Misc Register, array offset: 0x1F8, array step: 0x60
◆  [2/2]
__IO uint32_t { ... } ::MISC_CLR
◆ MISC_CONF0
__IO uint32_t OCOTP_Type::MISC_CONF0
Value of OTP Bank5 Word5 (Misc Conf), offset: 0x6D0
◆ MISC_CONF1
__IO uint32_t OCOTP_Type::MISC_CONF1
Value of OTP Bank5 Word6 (Misc Conf), offset: 0x6E0
◆ MISC_DIFPROG
__I uint32_t ANADIG_MISC_Type::MISC_DIFPROG
Chip Silicon Version Register, offset: 0x800
◆ MISC_SET [1/2]
__IO uint32_t USB_ANALOG_Type::MISC_SET
USB Misc Register, array offset: 0x1F4, array step: 0x60
◆  [2/2]
__IO uint32_t { ... } ::MISC_SET
◆  [1/2]
__IO uint32_t { ... } ::MISC_TOG
USB Misc Register, array offset: 0x1FC, array step: 0x60
◆ MISC_TOG [2/2]
__IO uint32_t USB_ANALOG_Type::MISC_TOG
◆ MISCCR4
__I uint32_t FLEXSPI_Type::MISCCR4
Misc Control Register 4, offset: 0xD0
◆ MISCCR5
__I uint32_t FLEXSPI_Type::MISCCR5
Misc Control Register 5, offset: 0xD4
◆ MISCCR6
__I uint32_t FLEXSPI_Type::MISCCR6
Misc Control Register 6, offset: 0xD8
◆ MISCCR7
__I uint32_t FLEXSPI_Type::MISCCR7
Misc Control Register 7, offset: 0xDC
◆ MIX_CTRL
__IO uint32_t USDHC_Type::MIX_CTRL
Mixer Control, offset: 0x48
◆ MMC_BOOT
__IO uint32_t USDHC_Type::MMC_BOOT
MMC Boot, offset: 0xC4
◆ MMFR
__IO uint32_t ENET_Type::MMFR
MII Management Frame Register, offset: 0x40
◆ MODIR
__IO uint32_t LPUART_Type::MODIR
LPUART Modem IrDA Register, offset: 0x24
◆ MPECC
__I uint32_t CAAM_Type::MPECC
Manufacturing Protection ECC Register, offset: 0x3F8
◆ MPMR
__IO uint8_t CAAM_Type::MPMR
Manufacturing Protection Message Register, array offset: 0x380, array step: 0x1
◆ MPPKR
__IO uint8_t CAAM_Type::MPPKR
Manufacturing Protection Private Key Register, array offset: 0x300, array step: 0x1
◆ MPR
__IO uint32_t AIPSTZ_Type::MPR
Master Priviledge Registers, offset: 0x0
◆ MPTESTR
__I uint8_t CAAM_Type::MPTESTR
Manufacturing Protection Test Register, array offset: 0x3C0, array step: 0x1
◆ MRBR
__IO uint32_t ENET_Type::MRBR
Maximum Receive Buffer Size Register - Ring 0, offset: 0x188
◆ MRBR1
__IO uint32_t ENET_Type::MRBR1
Maximum Receive Buffer Size Register - Ring 1, offset: 0x168
◆ MRBR2
__IO uint32_t ENET_Type::MRBR2
Maximum Receive Buffer Size Register - Ring 2, offset: 0x174
◆ MRC [1/3]
__IO uint32_t RDC_Type::MRC
Memory Region Control, array offset: 0x808, array step: 0x10
◆  [2/3]
__IO uint32_t { ... } ::MRC
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::MRC_MRGD_W0
Memory Region Descriptor, array offset: 0x8000, array step: index*0x400, index2*0x20
◆ MRC_MRGD_W0 [2/3]
__IO uint32_t XRDC2_Type::MRC_MRGD_W0
◆  [3/3]
◆ MRC_MRGD_W1 [1/3]
__IO uint32_t XRDC2_Type::MRC_MRGD_W1
Memory Region Descriptor, array offset: 0x8004, array step: index*0x400, index2*0x20
◆  [2/3]
__IO uint32_t { ... } ::MRC_MRGD_W1
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::MRC_MRGD_W2
Memory Region Descriptor, array offset: 0x8008, array step: index*0x400, index2*0x20
◆ MRC_MRGD_W2 [2/3]
__IO uint32_t XRDC2_Type::MRC_MRGD_W2
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::MRC_MRGD_W3
Memory Region Descriptor, array offset: 0x800C, array step: index*0x400, index2*0x20
◆ MRC_MRGD_W3 [2/3]
__IO uint32_t XRDC2_Type::MRC_MRGD_W3
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::MRC_MRGD_W5
Memory Region Descriptor, array offset: 0x8014, array step: index*0x400, index2*0x20
◆ MRC_MRGD_W5 [2/3]
__IO uint32_t XRDC2_Type::MRC_MRGD_W5
◆  [3/3]
◆ MRC_MRGD_W6 [1/3]
__IO uint32_t XRDC2_Type::MRC_MRGD_W6
Memory Region Descriptor, array offset: 0x8018, array step: index*0x400, index2*0x20
◆  [2/3]
__IO uint32_t { ... } ::MRC_MRGD_W6
◆  [3/3]
◆ MRDR
__I uint32_t LPI2C_Type::MRDR
Master Receive Data Register, offset: 0x70
Master Receive Data, offset: 0x70
◆ MREA [1/3]
__IO uint32_t RDC_Type::MREA
Memory Region End Address, array offset: 0x804, array step: 0x10
◆  [2/3]
__IO uint32_t { ... } ::MREA
◆  [3/3]
◆ MRSA [1/3]
__IO uint32_t RDC_Type::MRSA
Memory Region Start Address, array offset: 0x800, array step: 0x10
◆  [2/3]
__IO uint32_t { ... } ::MRSA
◆  [3/3]
◆ MRVS [1/3]
__IO uint32_t RDC_Type::MRVS
Memory Region Violation Status, array offset: 0x80C, array step: 0x10
◆  [2/3]
__IO uint32_t { ... } ::MRVS
◆  [3/3]
◆ MSC_MSAC_W0 [1/3]
__IO uint32_t XRDC2_Type::MSC_MSAC_W0
Memory Slot Access Control, array offset: 0x1000, array step: 0x8
◆  [2/3]
__IO uint32_t { ... } ::MSC_MSAC_W0
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::MSC_MSAC_W1
Memory Slot Access Control, array offset: 0x1004, array step: 0x8
◆ MSC_MSAC_W1 [2/3]
__IO uint32_t XRDC2_Type::MSC_MSAC_W1
◆  [3/3]
◆ MSCR
__IO uint32_t ENET_Type::MSCR
MII Speed Control Register, offset: 0x44
◆ MSR
__IO uint32_t LPI2C_Type::MSR
Master Status Register, offset: 0x14
Master Status, offset: 0x14
◆ MTDR
__O uint32_t LPI2C_Type::MTDR
Master Transmit Data Register, offset: 0x60
Master Transmit Data, offset: 0x60
◆ MULTI_ERR_ADDR
__I uint32_t XECC_Type::MULTI_ERR_ADDR
Multiple Error Address, offset: 0x2C
◆ MULTI_ERR_ADDR_ECC0
__I uint32_t MECC_Type::MULTI_ERR_ADDR_ECC0
Multiple Error Address And ECC code On OCRAM Bank0, offset: 0x8C
◆ MULTI_ERR_ADDR_ECC1
__I uint32_t MECC_Type::MULTI_ERR_ADDR_ECC1
Multiple Error Address And ECC code On OCRAM Bank1, offset: 0x98
◆ MULTI_ERR_ADDR_ECC2
__I uint32_t MECC_Type::MULTI_ERR_ADDR_ECC2
Multiple Error Address And ECC code On OCRAM Bank2, offset: 0xA4
◆ MULTI_ERR_ADDR_ECC3
__I uint32_t MECC_Type::MULTI_ERR_ADDR_ECC3
Multiple Error Address And ECC code On OCRAM Bank3, offset: 0xB0
◆ MULTI_ERR_BIT_FIELD
__I uint32_t XECC_Type::MULTI_ERR_BIT_FIELD
Multiple Error Bit Field, offset: 0x38
◆ MULTI_ERR_DATA
__I uint32_t XECC_Type::MULTI_ERR_DATA
Multiple Error Read Data, offset: 0x30
◆ MULTI_ERR_DATA_HIGH0
__I uint32_t MECC_Type::MULTI_ERR_DATA_HIGH0
HIGH 32 Bits Multiple Error Read Data On OCRAM Bank0, offset: 0x94
◆ MULTI_ERR_DATA_HIGH1
__I uint32_t MECC_Type::MULTI_ERR_DATA_HIGH1
HIGH 32 Bits Multiple Error Read Data On OCRAM Bank1, offset: 0xA0
◆ MULTI_ERR_DATA_HIGH2
__I uint32_t MECC_Type::MULTI_ERR_DATA_HIGH2
HIGH 32 Bits Multiple Error Read Data On OCRAM Bank2, offset: 0xAC
◆ MULTI_ERR_DATA_HIGH3
__I uint32_t MECC_Type::MULTI_ERR_DATA_HIGH3
HIGH 32 Bits Multiple Error Read Data On OCRAM Bank3, offset: 0xB8
◆ MULTI_ERR_DATA_LOW0
__I uint32_t MECC_Type::MULTI_ERR_DATA_LOW0
LOW 32 Bits Multiple Error Read Data On OCRAM Bank0, offset: 0x90
◆ MULTI_ERR_DATA_LOW1
__I uint32_t MECC_Type::MULTI_ERR_DATA_LOW1
LOW 32 Bits Multiple Error Read Data On OCRAM Bank1, offset: 0x9C
◆ MULTI_ERR_DATA_LOW2
__I uint32_t MECC_Type::MULTI_ERR_DATA_LOW2
LOW 32 Bits Multiple Error Read Data On OCRAM Bank2, offset: 0xA8
◆ MULTI_ERR_DATA_LOW3
__I uint32_t MECC_Type::MULTI_ERR_DATA_LOW3
LOW 32 Bits Multiple Error Read Data On OCRAM Bank3, offset: 0xB4
◆ MULTI_ERR_ECC
__I uint32_t XECC_Type::MULTI_ERR_ECC
Multiple Error ECC code, offset: 0x34
◆ MUXCR
__IO uint8_t CMP_Type::MUXCR
MUX Control Register, offset: 0x5
◆ NANDCR0
__IO uint32_t SEMC_Type::NANDCR0
NAND control register 0, offset: 0x50
NAND Control Register 0, offset: 0x50
◆ NANDCR1
__IO uint32_t SEMC_Type::NANDCR1
NAND control register 1, offset: 0x54
NAND Control Register 1, offset: 0x54
◆ NANDCR2
__IO uint32_t SEMC_Type::NANDCR2
NAND control register 2, offset: 0x58
NAND Control Register 2, offset: 0x58
◆ NANDCR3
__IO uint32_t SEMC_Type::NANDCR3
NAND control register 3, offset: 0x5C
NAND Control Register 3, offset: 0x5C
◆ NBYTES_MLNO [1/4]
__IO uint32_t DMA_Type::NBYTES_MLNO
TCD Minor Byte Count (Minor Loop Mapping Disabled), array offset: 0x1008, array step: 0x20
◆  [2/4]
__IO uint32_t { ... } ::NBYTES_MLNO
◆  [3/4]
◆  [4/4]
◆ NBYTES_MLOFFNO [1/4]
__IO uint32_t DMA_Type::NBYTES_MLOFFNO
TCD Signed Minor Loop Offset (Minor Loop Mapping Enabled and Offset Disabled), array offset: 0x1008, array step: 0x20
◆  [2/4]
__IO uint32_t { ... } ::NBYTES_MLOFFNO
◆  [3/4]
◆  [4/4]
◆ NBYTES_MLOFFYES [1/4]
__IO uint32_t DMA_Type::NBYTES_MLOFFYES
TCD Signed Minor Loop Offset (Minor Loop Mapping and Offset Enabled), array offset: 0x1008, array step: 0x20
◆  [2/4]
__IO uint32_t { ... } ::NBYTES_MLOFFYES
◆  [3/4]
◆  [4/4]
◆ NEXT
__IO uint32_t PXP_Type::NEXT
Next Frame Pointer, offset: 0x400
◆ NEXT_BUF
__IO uint32_t LCDIF_Type::NEXT_BUF
LCD Interface Next Buffer Address Register, offset: 0x50
◆ NORCR0
__IO uint32_t SEMC_Type::NORCR0
NOR control register 0, offset: 0x60
NOR Control Register 0, offset: 0x60
◆ NORCR1
__IO uint32_t SEMC_Type::NORCR1
NOR control register 1, offset: 0x64
NOR Control Register 1, offset: 0x64
◆ NORCR2
__IO uint32_t SEMC_Type::NORCR2
NOR control register 2, offset: 0x68
NOR Control Register 2, offset: 0x68
◆ NORCR3 [1/2]
__IO uint32_t SEMC_Type::NORCR3
NOR control register 3, offset: 0x6C
NOR Control Register 3, offset: 0x6C
◆ NORCR3 [2/2]
◆ OCR
__IO uint32_t GPT_Type::OCR
GPT Output Compare Register 1..GPT Output Compare Register 3, array offset: 0x10, array step: 0x4
GPT Output Compare Register, array offset: 0x10, array step: 0x4
◆ OCRAM_ECC_MULTI_ERROR_ADDR
__I uint32_t FLEXRAM_Type::OCRAM_ECC_MULTI_ERROR_ADDR
OCRAM multi-bit ECC Error Address Register, offset: 0x30
◆ OCRAM_ECC_MULTI_ERROR_DATA_LSB
__I uint32_t FLEXRAM_Type::OCRAM_ECC_MULTI_ERROR_DATA_LSB
OCRAM multi-bit ECC Error Data Register, offset: 0x34
◆ OCRAM_ECC_MULTI_ERROR_DATA_MSB
__I uint32_t FLEXRAM_Type::OCRAM_ECC_MULTI_ERROR_DATA_MSB
OCRAM multi-bit ECC Error Data Register, offset: 0x38
◆ OCRAM_ECC_MULTI_ERROR_INFO
__I uint32_t FLEXRAM_Type::OCRAM_ECC_MULTI_ERROR_INFO
OCRAM multi-bit ECC Error Information Register, offset: 0x2C
◆ OCRAM_ECC_SINGLE_ERROR_ADDR
__I uint32_t FLEXRAM_Type::OCRAM_ECC_SINGLE_ERROR_ADDR
OCRAM single-bit ECC Error Address Register, offset: 0x20
◆ OCRAM_ECC_SINGLE_ERROR_DATA_LSB
__I uint32_t FLEXRAM_Type::OCRAM_ECC_SINGLE_ERROR_DATA_LSB
OCRAM single-bit ECC Error Data Register, offset: 0x24
◆ OCRAM_ECC_SINGLE_ERROR_DATA_MSB
__I uint32_t FLEXRAM_Type::OCRAM_ECC_SINGLE_ERROR_DATA_MSB
OCRAM single-bit ECC Error Data Register, offset: 0x28
◆ OCRAM_ECC_SINGLE_ERROR_INFO
__I uint32_t FLEXRAM_Type::OCRAM_ECC_SINGLE_ERROR_INFO
OCRAM single-bit ECC Error Information Register, offset: 0x1C
◆ OCRAM_MAGIC_ADDR
__IO uint32_t FLEXRAM_Type::OCRAM_MAGIC_ADDR
OCRAM Magic Address Register, offset: 0x4
◆ OCRAM_PIPELINE_STATUS
__I uint32_t FLEXRAM_Type::OCRAM_PIPELINE_STATUS
OCRAM Pipeline Status register, offset: 0x10C
◆  [1/4]
__IO uint16_t { ... } ::OCTRL
Output Control Register, array offset: 0x22, array step: 0x60
◆ OCTRL [2/4]
__IO uint16_t PWM_Type::OCTRL
◆  [3/4]
◆  [4/4]
◆ OFS
__IO uint32_t ADC_Type::OFS
Offset correction value register, offset: 0x54
◆ OPACR
__IO uint32_t AIPSTZ_Type::OPACR
Off-Platform Peripheral Access Control Registers, offset: 0x40
◆ OPACR1
__IO uint32_t AIPSTZ_Type::OPACR1
Off-Platform Peripheral Access Control Registers, offset: 0x44
◆ OPACR2
__IO uint32_t AIPSTZ_Type::OPACR2
Off-Platform Peripheral Access Control Registers, offset: 0x48
◆ OPACR3
__IO uint32_t AIPSTZ_Type::OPACR3
Off-Platform Peripheral Access Control Registers, offset: 0x4C
◆ OPACR4
__IO uint32_t AIPSTZ_Type::OPACR4
Off-Platform Peripheral Access Control Registers, offset: 0x50
◆ OPD
__IO uint32_t ENET_Type::OPD
Opcode/Pause Duration Register, offset: 0xEC
◆  [1/3]
__IO uint64_t { ... } ::ORBAR_JR
Output Ring Base Address Register for Job Ring 0..Output Ring Base Address Register for Job Ring 3, array offset: 0x10020, array step: 0x10000
◆ ORBAR_JR [2/3]
__IO uint64_t CAAM_Type::ORBAR_JR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::ORJRR_JR
Output Ring Jobs Removed Register for Job Ring 0..Output Ring Jobs Removed Register for Job Ring 3, array offset: 0x10034, array step: 0x10000
◆ ORJRR_JR [2/3]
__IO uint32_t CAAM_Type::ORJRR_JR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::ORSFR_JR
Output Ring Slots Full Register for Job Ring 0..Output Ring Slots Full Register for Job Ring 3, array offset: 0x1003C, array step: 0x10000
◆ ORSFR_JR [2/3]
__IO uint32_t CAAM_Type::ORSFR_JR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::ORSR_JR
Output Ring Size Register for Job Ring 0..Output Ring Size Register for Job Ring 3, array offset: 0x1002C, array step: 0x10000
◆ ORSR_JR [2/3]
__IO uint32_t CAAM_Type::ORSR_JR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::ORWIR_JR
Output Ring Write Index Register for Job Ring 0..Output Ring Write Index Register for Job Ring 3, array offset: 0x10064, array step: 0x10000
◆ ORWIR_JR [2/3]
__IO uint32_t CAAM_Type::ORWIR_JR
◆  [3/3]
◆ OSC_16M_CTRL
__IO uint32_t ANADIG_OSC_Type::OSC_16M_CTRL
16MHz RCOSC Control Register, offset: 0xC0
◆ OSC_24M_CTRL
__IO uint32_t ANADIG_OSC_Type::OSC_24M_CTRL
24MHz OSC Control Register, offset: 0x20
◆ OSC_400M_CTRL0
__I uint32_t ANADIG_OSC_Type::OSC_400M_CTRL0
400MHz RCOSC Control0 Register, offset: 0x40
◆ OSC_400M_CTRL1
__IO uint32_t ANADIG_OSC_Type::OSC_400M_CTRL1
400MHz RCOSC Control1 Register, offset: 0x50
◆ OSC_400M_CTRL2
__IO uint32_t ANADIG_OSC_Type::OSC_400M_CTRL2
400MHz RCOSC Control2 Register, offset: 0x60
◆ OSC_48M_CTRL
__IO uint32_t ANADIG_OSC_Type::OSC_48M_CTRL
48MHz RCOSC Control Register, offset: 0x10
◆ OSC_CONFIG0
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG0
XTAL OSC Configuration 0 Register, offset: 0x2A0
◆ OSC_CONFIG0_CLR
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG0_CLR
XTAL OSC Configuration 0 Register, offset: 0x2A8
◆ OSC_CONFIG0_SET
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG0_SET
XTAL OSC Configuration 0 Register, offset: 0x2A4
◆ OSC_CONFIG0_TOG
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG0_TOG
XTAL OSC Configuration 0 Register, offset: 0x2AC
◆ OSC_CONFIG1
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG1
XTAL OSC Configuration 1 Register, offset: 0x2B0
◆ OSC_CONFIG1_CLR
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG1_CLR
XTAL OSC Configuration 1 Register, offset: 0x2B8
◆ OSC_CONFIG1_SET
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG1_SET
XTAL OSC Configuration 1 Register, offset: 0x2B4
◆ OSC_CONFIG1_TOG
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG1_TOG
XTAL OSC Configuration 1 Register, offset: 0x2BC
◆ OSC_CONFIG2
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG2
XTAL OSC Configuration 2 Register, offset: 0x2C0
◆ OSC_CONFIG2_CLR
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG2_CLR
XTAL OSC Configuration 2 Register, offset: 0x2C8
◆ OSC_CONFIG2_SET
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG2_SET
XTAL OSC Configuration 2 Register, offset: 0x2C4
◆ OSC_CONFIG2_TOG
__IO uint32_t XTALOSC24M_Type::OSC_CONFIG2_TOG
XTAL OSC Configuration 2 Register, offset: 0x2CC
◆ OTFAD1_KEY_CTRL
__IO uint32_t KEY_MANAGER_Type::OTFAD1_KEY_CTRL
CSR OTFAD-1 Key Control, offset: 0x10
◆ OTFAD2_KEY_CTRL
__IO uint32_t KEY_MANAGER_Type::OTFAD2_KEY_CTRL
CSR OTFAD-2 Key Control, offset: 0x18
◆ OTGSC
__IO uint32_t USB_Type::OTGSC
On-The-Go Status & control, offset: 0x1A4
◆ OUT_AS_LRC
__IO uint32_t PXP_Type::OUT_AS_LRC
Alpha Surface Lower Right Coordinate, offset: 0xA0
◆ OUT_AS_ULC
__IO uint32_t PXP_Type::OUT_AS_ULC
Alpha Surface Upper Left Coordinate, offset: 0x90
◆ OUT_BUF
__IO uint32_t PXP_Type::OUT_BUF
Output Frame Buffer Pointer, offset: 0x30
◆ OUT_BUF2
__IO uint32_t PXP_Type::OUT_BUF2
Output Frame Buffer Pointer #2, offset: 0x40
◆ OUT_CTRL
__IO uint32_t PXP_Type::OUT_CTRL
Output Buffer Control Register, offset: 0x20
◆ OUT_CTRL_CLR
__IO uint32_t PXP_Type::OUT_CTRL_CLR
Output Buffer Control Register, offset: 0x28
◆ OUT_CTRL_SET
__IO uint32_t PXP_Type::OUT_CTRL_SET
Output Buffer Control Register, offset: 0x24
◆ OUT_CTRL_TOG
__IO uint32_t PXP_Type::OUT_CTRL_TOG
Output Buffer Control Register, offset: 0x2C
◆ OUT_LRC
__IO uint32_t PXP_Type::OUT_LRC
Output Surface Lower Right Coordinate, offset: 0x60
◆ OUT_PITCH
__IO uint32_t PXP_Type::OUT_PITCH
Output Buffer Pitch, offset: 0x50
◆ OUT_PS_LRC
__IO uint32_t PXP_Type::OUT_PS_LRC
Processed Surface Lower Right Coordinate, offset: 0x80
◆ OUT_PS_ULC
__IO uint32_t PXP_Type::OUT_PS_ULC
Processed Surface Upper Left Coordinate, offset: 0x70
◆ OUT_STATUS
__IO uint32_t OCOTP_Type::OUT_STATUS
8K OTP Memory STATUS Register, offset: 0x90
◆ OUT_STATUS_CLR
__IO uint32_t OCOTP_Type::OUT_STATUS_CLR
8K OTP Memory STATUS Register, offset: 0x98
◆ OUT_STATUS_SET
__IO uint32_t OCOTP_Type::OUT_STATUS_SET
8K OTP Memory STATUS Register, offset: 0x94
◆ OUT_STATUS_TOG
__IO uint32_t OCOTP_Type::OUT_STATUS_TOG
8K OTP Memory STATUS Register, offset: 0x9C
◆ OUTEN
__IO uint16_t PWM_Type::OUTEN
Output Enable Register, offset: 0x180
◆ PAC_PDAC_W0 [1/3]
__IO uint32_t XRDC2_Type::PAC_PDAC_W0
Peripheral Domain Access Control, array offset: 0x4000, array step: index*0x800, index2*0x8
◆  [2/3]
__IO uint32_t { ... } ::PAC_PDAC_W0
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::PAC_PDAC_W1
Peripheral Domain Access Control, array offset: 0x4004, array step: index*0x800, index2*0x8
◆ PAC_PDAC_W1 [2/3]
__IO uint32_t XRDC2_Type::PAC_PDAC_W1
◆  [3/3]
◆ PACKET0
__I uint32_t DCP_Type::PACKET0
DCP work packet 0 status register, offset: 0x80
◆ PACKET1
__I uint32_t DCP_Type::PACKET1
DCP work packet 1 status register, offset: 0x90
◆ PACKET2
__I uint32_t DCP_Type::PACKET2
DCP work packet 2 status register, offset: 0xA0
◆ PACKET3
__I uint32_t DCP_Type::PACKET3
DCP work packet 3 status register, offset: 0xB0
◆ PACKET4
__I uint32_t DCP_Type::PACKET4
DCP work packet 4 status register, offset: 0xC0
◆ PACKET5
__I uint32_t DCP_Type::PACKET5
DCP work packet 5 status register, offset: 0xD0
◆ PACKET6
__I uint32_t DCP_Type::PACKET6
DCP work packet 6 status register, offset: 0xE0
◆ PAGE0_SDID
__IO uint32_t CAAM_Type::PAGE0_SDID
Page 0 SDID Register, offset: 0x8
◆ PAGETABLE
__IO uint32_t DCP_Type::PAGETABLE
DCP page table register, offset: 0x420
◆ PALR
__IO uint32_t ENET_Type::PALR
Physical Address Lower Register, offset: 0xE4
◆ PARAM [1/9]
__I uint32_t FLEXIO_Type::PARAM
Parameter Register, offset: 0x4
◆ PARAM [2/9]
__I uint32_t I2S_Type::PARAM
Parameter, offset: 0x4
◆ PARAM [3/9]
__I uint32_t LPI2C_Type::PARAM
◆ PARAM [4/9]
__I uint32_t LPSPI_Type::PARAM
◆ PARAM [5/9]
__I uint32_t LPUART_Type::PARAM
◆ PARAM [6/9]
__I uint32_t ADC_Type::PARAM
◆ PARAM [7/9]
__I uint32_t CMP_Type::PARAM
◆ PARAM [8/9]
__I uint32_t DAC_Type::PARAM
◆ PARAM [9/9]
__I uint32_t EMVSIM_Type::PARAM
◆ PAUR
__IO uint32_t ENET_Type::PAUR
Physical Address Upper Register, offset: 0xE8
◆ PAUSE
__IO uint32_t ADC_Type::PAUSE
LPADC Pause Register, offset: 0x24
◆ PBSL
__IO uint32_t CAAM_Type::PBSL
Peak Bandwidth Smoothing Limit Register, offset: 0x220
◆ PC_BLK_DEC
__IO uint32_t IEE_Type::PC_BLK_DEC
Performance Counter, Number of AES Block Decryptions, offset: 0x44
◆ PC_BLK_ENC
__IO uint32_t IEE_Type::PC_BLK_ENC
Performance Counter, Number of AES Block Encryptions, offset: 0x40
◆ PC_M_LT
__IO uint32_t IEE_Type::PC_M_LT
Performance Counter, AES Master Latency Threshold, offset: 0x24
◆ PC_M_MBR
__IO uint32_t IEE_Type::PC_M_MBR
Performance Counter, Number of AXI Master Merge Buffer Read Transactions, offset: 0x64
◆ PC_MR_TBC_L
__IO uint32_t IEE_Type::PC_MR_TBC_L
Performance Counter, Lower Master Read Transactions Byte Count, offset: 0x84
◆ PC_MR_TBC_U
__IO uint32_t IEE_Type::PC_MR_TBC_U
Performance Counter, Upper Master Read Transactions Byte Count, offset: 0x80
◆ PC_MR_TLAT_L
__IO uint32_t IEE_Type::PC_MR_TLAT_L
Performance Counter, Lower Master Read Latency Count, offset: 0xB4
◆ PC_MR_TLAT_U
__IO uint32_t IEE_Type::PC_MR_TLAT_U
Performance Counter, Upper Master Read Latency Count, offset: 0xB0
◆ PC_MR_TLGTT
__IO uint32_t IEE_Type::PC_MR_TLGTT
Performance Counter, Number of AXI Master Read Transactions with Latency Greater than the Threshold, offset: 0x98
◆ PC_MR_TRANS
__IO uint32_t IEE_Type::PC_MR_TRANS
Performance Counter, Number of AXI Master Read Transactions, offset: 0x58
◆ PC_MW_TBC_L
__IO uint32_t IEE_Type::PC_MW_TBC_L
Performance Counter, Lower Master Write Transactions Byte Count, offset: 0x8C
◆ PC_MW_TBC_U
__IO uint32_t IEE_Type::PC_MW_TBC_U
Performance Counter, Upper Master Write Transactions Byte Count, offset: 0x88
◆ PC_MW_TLAT_L
__IO uint32_t IEE_Type::PC_MW_TLAT_L
Performance Counter, Lower Master Write Latency Count, offset: 0xBC
◆ PC_MW_TLAT_U
__IO uint32_t IEE_Type::PC_MW_TLAT_U
Performance Counter, Upper Master Write Latency Count, offset: 0xB8
◆ PC_MW_TLGTT
__IO uint32_t IEE_Type::PC_MW_TLGTT
Performance Counter, Number of AXI Master Write Transactions with Latency Greater than the Threshold, offset: 0x9C
◆ PC_MW_TRANS
__IO uint32_t IEE_Type::PC_MW_TRANS
Performance Counter, Number of AXI Master Write Transactions, offset: 0x5C
◆ PC_S_LT
__IO uint32_t IEE_Type::PC_S_LT
Performance Counter, AES Slave Latency Threshold Value, offset: 0x20
◆ PC_SR_TBC_L
__IO uint32_t IEE_Type::PC_SR_TBC_L
Performance Counter, Lower Slave Read Transactions Byte Count, offset: 0x74
◆ PC_SR_TBC_U
__IO uint32_t IEE_Type::PC_SR_TBC_U
Performance Counter, Upper Slave Read Transactions Byte Count, offset: 0x70
◆ PC_SR_TLAT_L
__IO uint32_t IEE_Type::PC_SR_TLAT_L
Performance Counter, Lower Slave Read Latency Count, offset: 0xA4
◆ PC_SR_TLAT_U
__IO uint32_t IEE_Type::PC_SR_TLAT_U
Performance Counter, Upper Slave Read Latency Count, offset: 0xA0
◆ PC_SR_TLGTT
__IO uint32_t IEE_Type::PC_SR_TLGTT
Performance Counter, Number of AXI Slave Read Transactions with Latency Greater than the Threshold, offset: 0x90
◆ PC_SR_TNRT_L
__IO uint32_t IEE_Type::PC_SR_TNRT_L
Performance Counter, Lower Slave Read Total Non-Responding Time, offset: 0xC4
◆ PC_SR_TNRT_U
__IO uint32_t IEE_Type::PC_SR_TNRT_U
Performance Counter, Upper Slave Read Total Non-Responding Time, offset: 0xC0
◆ PC_SR_TRANS
__IO uint32_t IEE_Type::PC_SR_TRANS
Performance Counter, Number of AXI Slave Read Transactions, offset: 0x50
◆ PC_SW_TBC_L
__IO uint32_t IEE_Type::PC_SW_TBC_L
Performance Counter, Lower Slave Write Transactions Byte Count, offset: 0x7C
◆ PC_SW_TBC_U
__IO uint32_t IEE_Type::PC_SW_TBC_U
Performance Counter, Upper Slave Write Transactions Byte Count, offset: 0x78
◆ PC_SW_TLAT_L
__IO uint32_t IEE_Type::PC_SW_TLAT_L
Performance Counter, Lower Slave Write Latency Count, offset: 0xAC
◆ PC_SW_TLAT_U
__IO uint32_t IEE_Type::PC_SW_TLAT_U
Performance Counter, Upper Slave Write Latency Count, offset: 0xA8
◆ PC_SW_TLGTT
__IO uint32_t IEE_Type::PC_SW_TLGTT
Performance Counter, Number of AXI Slave Write Transactions with Latency Greater than the Threshold, offset: 0x94
◆ PC_SW_TNRT_L
__IO uint32_t IEE_Type::PC_SW_TNRT_L
Performance Counter, Lower Slave Write Total Non-Responding Time, offset: 0xCC
◆ PC_SW_TNRT_U
__IO uint32_t IEE_Type::PC_SW_TNRT_U
Performance Counter, Upper Slave Write Total Non-Responding Time, offset: 0xC8
◆ PC_SW_TRANS
__IO uint32_t IEE_Type::PC_SW_TRANS
Performance Counter, Number of AXI Slave Write Transactions, offset: 0x54
◆ PCCCR
__IO uint32_t LMEM_Type::PCCCR
PC bus Cache control register, offset: 0x0
◆ PCCCVR
__IO uint32_t LMEM_Type::PCCCVR
PC bus Cache read/write value register, offset: 0xC
◆ PCCLCR
__IO uint32_t LMEM_Type::PCCLCR
PC bus Cache line control register, offset: 0x4
◆ PCCSAR
__IO uint32_t LMEM_Type::PCCSAR
PC bus Cache search address register, offset: 0x8
◆ PCSR
__IO uint32_t EMVSIM_Type::PCSR
Port Control and Status Register, offset: 0x28
◆ PCT
__I uint16_t MCM_Type::PCT
Processor core type, offset: 0x2
◆ PD_PLL
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::PD_PLL
PD_PLL, offset: 0x1C
◆ PD_TX
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::PD_TX
PD_TX, offset: 0x0
◆ PDAP
__IO uint32_t RDC_Type::PDAP
Peripheral Domain Access Permissions, array offset: 0x400, array step: 0x4
◆ PDI_PARA
__IO uint32_t LCDIFV2_Type::PDI_PARA
Parallel Data Interface Parameter Register, offset: 0x40
◆ PDN
__IO uint32_t OCOTP_Type::PDN
OTP Controller PDN Register, offset: 0x10
◆ PENDING_STAT
__I uint32_t MECC_Type::PENDING_STAT
Pending Status, offset: 0x104
◆ PERIODICLISTBASE [1/4]
__IO uint32_t USB_Type::PERIODICLISTBASE
Frame List Base Address, offset: 0x154
◆  [2/4]
__IO uint32_t { ... } ::PERIODICLISTBASE
◆  [3/4]
◆  [4/4]
◆ PERSISTENT
__IO uint32_t CDOG_Type::PERSISTENT
Persistent Data Storage, offset: 0x1C
◆ PFD_480
__IO uint32_t CCM_ANALOG_Type::PFD_480
480MHz Clock (PLL3) Phase Fractional Divider Control Register, offset: 0xF0
◆ PFD_480_CLR
__IO uint32_t CCM_ANALOG_Type::PFD_480_CLR
480MHz Clock (PLL3) Phase Fractional Divider Control Register, offset: 0xF8
◆ PFD_480_SET
__IO uint32_t CCM_ANALOG_Type::PFD_480_SET
480MHz Clock (PLL3) Phase Fractional Divider Control Register, offset: 0xF4
◆ PFD_480_TOG
__IO uint32_t CCM_ANALOG_Type::PFD_480_TOG
480MHz Clock (PLL3) Phase Fractional Divider Control Register, offset: 0xFC
◆ PFD_528
__IO uint32_t CCM_ANALOG_Type::PFD_528
528MHz Clock (PLL2) Phase Fractional Divider Control Register, offset: 0x100
◆ PFD_528_CLR
__IO uint32_t CCM_ANALOG_Type::PFD_528_CLR
528MHz Clock (PLL2) Phase Fractional Divider Control Register, offset: 0x108
◆ PFD_528_SET
__IO uint32_t CCM_ANALOG_Type::PFD_528_SET
528MHz Clock (PLL2) Phase Fractional Divider Control Register, offset: 0x104
◆ PFD_528_TOG
__IO uint32_t CCM_ANALOG_Type::PFD_528_TOG
528MHz Clock (PLL2) Phase Fractional Divider Control Register, offset: 0x10C
◆  [1/4]
__IO uint32_t { ... } ::PIGEON_0
Panel Interface Signal Generator Register, array offset: 0x800, array step: 0x40
◆ PIGEON_0 [2/4]
__IO uint32_t LCDIF_Type::PIGEON_0
◆  [3/4]
◆  [4/4]
◆ PIGEON_1 [1/4]
__IO uint32_t LCDIF_Type::PIGEON_1
Panel Interface Signal Generator Register, array offset: 0x810, array step: 0x40
◆  [2/4]
__IO uint32_t { ... } ::PIGEON_1
◆  [3/4]
◆  [4/4]
◆ PIGEON_2 [1/4]
__IO uint32_t LCDIF_Type::PIGEON_2
Panel Interface Signal Generator Register, array offset: 0x820, array step: 0x40
◆  [2/4]
__IO uint32_t { ... } ::PIGEON_2
◆  [3/4]
◆  [4/4]
◆ PIGEONCTRL0
__IO uint32_t LCDIF_Type::PIGEONCTRL0
LCDIF Pigeon Mode Control0 Register, offset: 0x380
◆ PIGEONCTRL0_CLR
__IO uint32_t LCDIF_Type::PIGEONCTRL0_CLR
LCDIF Pigeon Mode Control0 Register, offset: 0x388
◆ PIGEONCTRL0_SET
__IO uint32_t LCDIF_Type::PIGEONCTRL0_SET
LCDIF Pigeon Mode Control0 Register, offset: 0x384
◆ PIGEONCTRL0_TOG
__IO uint32_t LCDIF_Type::PIGEONCTRL0_TOG
LCDIF Pigeon Mode Control0 Register, offset: 0x38C
◆ PIGEONCTRL1
__IO uint32_t LCDIF_Type::PIGEONCTRL1
LCDIF Pigeon Mode Control1 Register, offset: 0x390
◆ PIGEONCTRL1_CLR
__IO uint32_t LCDIF_Type::PIGEONCTRL1_CLR
LCDIF Pigeon Mode Control1 Register, offset: 0x398
◆ PIGEONCTRL1_SET
__IO uint32_t LCDIF_Type::PIGEONCTRL1_SET
LCDIF Pigeon Mode Control1 Register, offset: 0x394
◆ PIGEONCTRL1_TOG
__IO uint32_t LCDIF_Type::PIGEONCTRL1_TOG
LCDIF Pigeon Mode Control1 Register, offset: 0x39C
◆ PIGEONCTRL2
__IO uint32_t LCDIF_Type::PIGEONCTRL2
LCDIF Pigeon Mode Control2 Register, offset: 0x3A0
◆ PIGEONCTRL2_CLR
__IO uint32_t LCDIF_Type::PIGEONCTRL2_CLR
LCDIF Pigeon Mode Control2 Register, offset: 0x3A8
◆ PIGEONCTRL2_SET
__IO uint32_t LCDIF_Type::PIGEONCTRL2_SET
LCDIF Pigeon Mode Control2 Register, offset: 0x3A4
◆ PIGEONCTRL2_TOG
__IO uint32_t LCDIF_Type::PIGEONCTRL2_TOG
LCDIF Pigeon Mode Control2 Register, offset: 0x3AC
◆ PIN
__I uint32_t FLEXIO_Type::PIN
Pin State Register, offset: 0xC
◆ PINCFG
__IO uint32_t LPUART_Type::PINCFG
LPUART Pin Configuration Register, offset: 0xC
◆ PIPE_ECC_EN
__IO uint32_t MECC_Type::PIPE_ECC_EN
OCRAM Pipeline And ECC Enable, offset: 0x100
◆ PIXEL_FIFO_SEND_LEVEL
__IO uint32_t DSI_HOST_DPI_INTFC_Type::PIXEL_FIFO_SEND_LEVEL
PIXEL_FIFO_SEND_LEVEL, offset: 0x4
◆ PIXEL_FORMAT
__IO uint32_t DSI_HOST_DPI_INTFC_Type::PIXEL_FORMAT
PIXEL_FORMAT, offset: 0xC
◆ PIXEL_PAYLOAD_SIZE
__IO uint32_t DSI_HOST_DPI_INTFC_Type::PIXEL_PAYLOAD_SIZE
PEXEL_PAYLOAD_SIZE, offset: 0x0
◆ PKRCNT10
__I uint32_t TRNG_Type::PKRCNT10
Statistical Check Poker Count 1 and 0 Register, offset: 0x80
◆ PKRCNT32
__I uint32_t TRNG_Type::PKRCNT32
Statistical Check Poker Count 3 and 2 Register, offset: 0x84
◆ PKRCNT54
__I uint32_t TRNG_Type::PKRCNT54
Statistical Check Poker Count 5 and 4 Register, offset: 0x88
◆ PKRCNT76
__I uint32_t TRNG_Type::PKRCNT76
Statistical Check Poker Count 7 and 6 Register, offset: 0x8C
◆ PKRCNT98
__I uint32_t TRNG_Type::PKRCNT98
Statistical Check Poker Count 9 and 8 Register, offset: 0x90
◆ PKRCNTBA
__I uint32_t TRNG_Type::PKRCNTBA
Statistical Check Poker Count B and A Register, offset: 0x94
◆ PKRCNTDC
__I uint32_t TRNG_Type::PKRCNTDC
Statistical Check Poker Count D and C Register, offset: 0x98
◆ PKRCNTFE
__I uint32_t TRNG_Type::PKRCNTFE
Statistical Check Poker Count F and E Register, offset: 0x9C
◆  [1/2]
__IO uint32_t { ... } ::PKRMAX
Poker Maximum Limit Register, offset: 0xC
◆ PKRMAX [2/2]
__IO uint32_t TRNG_Type::PKRMAX
◆ PKRRNG
__IO uint32_t TRNG_Type::PKRRNG
Poker Range Register, offset: 0x8
◆  [1/2]
__I uint32_t { ... } ::PKRSQ
Poker Square Calculation Result Register, offset: 0xC
◆ PKRSQ [2/2]
__I uint32_t TRNG_Type::PKRSQ
◆ PKT_CONTROL
__IO uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_CONTROL
PKT_CONTROL, offset: 0x4
◆ PKT_FIFO_RD_LEVEL
__I uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_FIFO_RD_LEVEL
PKT_FIFO_RD_LEVEL, offset: 0x14
◆ PKT_FIFO_WR_LEVEL
__I uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_FIFO_WR_LEVEL
PKT_FIFO_WR_LEVEL, offset: 0x10
◆ PKT_RX_PAYLOAD
__I uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_RX_PAYLOAD
PKT_RX_PAYLOAD, offset: 0x18
◆ PKT_RX_PKT_HEADER
__I uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_RX_PKT_HEADER
PKT_RX_PKT_HEADER, offset: 0x1C
◆ PKT_STATUS
__I uint32_t DSI_HOST_APB_PKT_IF_Type::PKT_STATUS
PKT_STATUS, offset: 0xC
◆ PLAMC
__I uint16_t MCM_Type::PLAMC
Crossbar Switch (AXBS) Master Configuration, offset: 0xA
◆ PLASC
__I uint16_t MCM_Type::PLASC
Crossbar Switch (AXBS) Slave Configuration, offset: 0x8
◆ PLL_ARM
__IO uint32_t CCM_ANALOG_Type::PLL_ARM
Analog ARM PLL control Register, offset: 0x0
◆ PLL_ARM_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_ARM_CLR
Analog ARM PLL control Register, offset: 0x8
◆ PLL_ARM_SET
__IO uint32_t CCM_ANALOG_Type::PLL_ARM_SET
Analog ARM PLL control Register, offset: 0x4
◆ PLL_ARM_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_ARM_TOG
Analog ARM PLL control Register, offset: 0xC
◆ PLL_AUDIO
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO
Analog Audio PLL control Register, offset: 0x70
◆ PLL_AUDIO_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO_CLR
Analog Audio PLL control Register, offset: 0x78
◆ PLL_AUDIO_CTRL
__IO uint32_t ANADIG_PLL_Type::PLL_AUDIO_CTRL
PLL_AUDIO_CTRL_REGISTER, offset: 0x300
◆ PLL_AUDIO_DENOM
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO_DENOM
Denominator of Audio PLL Fractional Loop Divider Register, offset: 0x90
◆ PLL_AUDIO_DENOMINATOR
__IO uint32_t ANADIG_PLL_Type::PLL_AUDIO_DENOMINATOR
PLL_AUDIO_DENOMINATOR_REGISTER, offset: 0x320
◆ PLL_AUDIO_DIV_SELECT
__IO uint32_t ANADIG_PLL_Type::PLL_AUDIO_DIV_SELECT
PLL_AUDIO_DIV_SELECT_REGISTER, offset: 0x340
◆ PLL_AUDIO_NUM
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO_NUM
Numerator of Audio PLL Fractional Loop Divider Register, offset: 0x80
◆ PLL_AUDIO_NUMERATOR
__IO uint32_t ANADIG_PLL_Type::PLL_AUDIO_NUMERATOR
PLL_AUDIO_NUMERATOR_REGISTER, offset: 0x330
◆ PLL_AUDIO_SET
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO_SET
Analog Audio PLL control Register, offset: 0x74
◆ PLL_AUDIO_SS
__IO uint32_t ANADIG_PLL_Type::PLL_AUDIO_SS
PLL_AUDIO_SS_REGISTER, offset: 0x310
◆ PLL_AUDIO_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_AUDIO_TOG
Analog Audio PLL control Register, offset: 0x7C
◆ PLL_ENET
__IO uint32_t CCM_ANALOG_Type::PLL_ENET
Analog ENET PLL Control Register, offset: 0xE0
◆ PLL_ENET_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_ENET_CLR
Analog ENET PLL Control Register, offset: 0xE8
◆ PLL_ENET_SET
__IO uint32_t CCM_ANALOG_Type::PLL_ENET_SET
Analog ENET PLL Control Register, offset: 0xE4
◆ PLL_ENET_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_ENET_TOG
Analog ENET PLL Control Register, offset: 0xEC
◆ PLL_LDO_STBY_EN_SP
__IO uint32_t ANADIG_PMU_Type::PLL_LDO_STBY_EN_SP
PLL_LDO_STBY_EN_SP_REGISTER, offset: 0x740
◆ PLL_SIC
__IO uint32_t USBPHY_Type::PLL_SIC
USB PHY PLL Control/Status Register, offset: 0xA0
◆ PLL_SIC_CLR
__IO uint32_t USBPHY_Type::PLL_SIC_CLR
USB PHY PLL Control/Status Register, offset: 0xA8
◆ PLL_SIC_SET
__IO uint32_t USBPHY_Type::PLL_SIC_SET
USB PHY PLL Control/Status Register, offset: 0xA4
◆ PLL_SIC_TOG
__IO uint32_t USBPHY_Type::PLL_SIC_TOG
USB PHY PLL Control/Status Register, offset: 0xAC
◆ PLL_SYS
__IO uint32_t CCM_ANALOG_Type::PLL_SYS
Analog System PLL Control Register, offset: 0x30
◆ PLL_SYS_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_CLR
Analog System PLL Control Register, offset: 0x38
◆ PLL_SYS_DENOM
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_DENOM
Denominator of 528MHz System PLL Fractional Loop Divider Register, offset: 0x60
◆ PLL_SYS_NUM
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_NUM
Numerator of 528MHz System PLL Fractional Loop Divider Register, offset: 0x50
◆ PLL_SYS_SET
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_SET
Analog System PLL Control Register, offset: 0x34
◆ PLL_SYS_SS
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_SS
528MHz System PLL Spread Spectrum Register, offset: 0x40
◆ PLL_SYS_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_SYS_TOG
Analog System PLL Control Register, offset: 0x3C
◆ PLL_USB1
__IO uint32_t CCM_ANALOG_Type::PLL_USB1
Analog USB1 480MHz PLL Control Register, offset: 0x10
◆ PLL_USB1_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_USB1_CLR
Analog USB1 480MHz PLL Control Register, offset: 0x18
◆ PLL_USB1_SET
__IO uint32_t CCM_ANALOG_Type::PLL_USB1_SET
Analog USB1 480MHz PLL Control Register, offset: 0x14
◆ PLL_USB1_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_USB1_TOG
Analog USB1 480MHz PLL Control Register, offset: 0x1C
◆ PLL_USB2
__IO uint32_t CCM_ANALOG_Type::PLL_USB2
Analog USB2 480MHz PLL Control Register, offset: 0x20
◆ PLL_USB2_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_USB2_CLR
Analog USB2 480MHz PLL Control Register, offset: 0x28
◆ PLL_USB2_SET
__IO uint32_t CCM_ANALOG_Type::PLL_USB2_SET
Analog USB2 480MHz PLL Control Register, offset: 0x24
◆ PLL_USB2_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_USB2_TOG
Analog USB2 480MHz PLL Control Register, offset: 0x2C
◆ PLL_VIDEO
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO
Analog Video PLL control Register, offset: 0xA0
◆ PLL_VIDEO_CLR
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO_CLR
Analog Video PLL control Register, offset: 0xA8
◆ PLL_VIDEO_CTRL
__IO uint32_t ANADIG_PLL_Type::PLL_VIDEO_CTRL
PLL_VIDEO_CTRL_REGISTER, offset: 0x350
◆ PLL_VIDEO_DENOM
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO_DENOM
Denominator of Video PLL Fractional Loop Divider Register, offset: 0xC0
◆ PLL_VIDEO_DENOMINATOR
__IO uint32_t ANADIG_PLL_Type::PLL_VIDEO_DENOMINATOR
PLL_VIDEO_DENOMINATOR_REGISTER, offset: 0x370
◆ PLL_VIDEO_DIV_SELECT
__IO uint32_t ANADIG_PLL_Type::PLL_VIDEO_DIV_SELECT
PLL_VIDEO_DIV_SELECT_REGISTER, offset: 0x390
◆ PLL_VIDEO_NUM
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO_NUM
Numerator of Video PLL Fractional Loop Divider Register, offset: 0xB0
◆ PLL_VIDEO_NUMERATOR
__IO uint32_t ANADIG_PLL_Type::PLL_VIDEO_NUMERATOR
PLL_VIDEO_NUMERATOR_REGISTER, offset: 0x380
◆ PLL_VIDEO_SET
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO_SET
Analog Video PLL control Register, offset: 0xA4
◆ PLL_VIDEO_SS
__IO uint32_t ANADIG_PLL_Type::PLL_VIDEO_SS
PLL_VIDEO_SS_REGISTER, offset: 0x360
◆ PLL_VIDEO_TOG
__IO uint32_t CCM_ANALOG_Type::PLL_VIDEO_TOG
Analog Video PLL control Register, offset: 0xAC
◆ PLREV
__I uint16_t MCM_Type::PLREV
SoC-defined platform revision, offset: 0x0
◆ PMU_BIAS_CTRL
__IO uint32_t ANADIG_PMU_Type::PMU_BIAS_CTRL
PMU_BIAS_CTRL_REGISTER, offset: 0x550
◆ PMU_BIAS_CTRL2
__IO uint32_t ANADIG_PMU_Type::PMU_BIAS_CTRL2
PMU_BIAS_CTRL2_REGISTER, offset: 0x560
◆ PMU_LDO_LPSR_ANA
__IO uint32_t ANADIG_LDO_SNVS_Type::PMU_LDO_LPSR_ANA
PMU_LDO_LPSR_ANA_REGISTER, offset: 0x510
◆ PMU_LDO_LPSR_DIG
__IO uint32_t ANADIG_LDO_SNVS_Type::PMU_LDO_LPSR_DIG
PMU_LDO_LPSR_DIG_REGISTER, offset: 0x530
◆ PMU_LDO_LPSR_DIG_2
__IO uint32_t ANADIG_LDO_SNVS_Type::PMU_LDO_LPSR_DIG_2
PMU_LDO_LPSR_DIG_2_REGISTER, offset: 0x520
◆ PMU_LDO_PLL
__IO uint32_t ANADIG_PMU_Type::PMU_LDO_PLL
PMU_LDO_PLL_REGISTER, offset: 0x500
◆ PMU_LDO_SNVS_DIG
__IO uint32_t ANADIG_LDO_SNVS_DIG_Type::PMU_LDO_SNVS_DIG
PMU_LDO_SNVS_DIG_REGISTER, offset: 0x540
◆ PMU_POWER_DETECT_CTRL
__IO uint32_t ANADIG_PMU_Type::PMU_POWER_DETECT_CTRL
PMU_POWER_DETECT_CTRL_REGISTER, offset: 0x580
◆ PMU_REF_CTRL
__IO uint32_t ANADIG_PMU_Type::PMU_REF_CTRL
PMU_REF_CTRL_REGISTER, offset: 0x570
◆ PORTER_DUFF_CTRL
__IO uint32_t PXP_Type::PORTER_DUFF_CTRL
PXP Alpha Engine A Control Register., offset: 0x440
◆ PORTSC1
__IO uint32_t USB_Type::PORTSC1
Port Status & Control, offset: 0x184
◆ POSD
__IO uint16_t ENC_Type::POSD
Position Difference Counter Register, offset: 0x6
◆ POSDH
__I uint16_t ENC_Type::POSDH
Position Difference Hold Register, offset: 0x8
◆ POSDPER
__I uint16_t ENC_Type::POSDPER
Position Difference Period Counter Register, offset: 0x2C
◆ POSDPERBFR
__I uint16_t ENC_Type::POSDPERBFR
Position Difference Period Buffer Register, offset: 0x2E
◆ POSDPERH
__I uint16_t ENC_Type::POSDPERH
Position Difference Period Hold Register, offset: 0x30
◆ POWER
__IO uint32_t PXP_Type::POWER
PXP Power Control Register, offset: 0x320
◆ PPC_AUTHEN_CTRL
__IO uint32_t PGMC_PPC_Type::PPC_AUTHEN_CTRL
PPC Authentication Control, offset: 0x4
◆ PPC_MODE
__IO uint32_t PGMC_PPC_Type::PPC_MODE
PPC Mode, offset: 0x10
◆ PPC_STBY_CM_CTRL
__IO uint32_t PGMC_PPC_Type::PPC_STBY_CM_CTRL
PPC standby CPU mode control, offset: 0x14
◆ PPC_STBY_SP_CTRL
__IO uint32_t PGMC_PPC_Type::PPC_STBY_SP_CTRL
PPC standby Setpoint control, offset: 0x18
◆ PPI_ERRCONTROL
__I uint32_t MIPI_CSI2RX_Type::PPI_ERRCONTROL
ErrControl Status Register, offset: 0x128
◆ PPI_ERRESC
__I uint32_t MIPI_CSI2RX_Type::PPI_ERRESC
ErrEsc Status Register, offset: 0x120
◆ PPI_ERRSOT_HS
__I uint32_t MIPI_CSI2RX_Type::PPI_ERRSOT_HS
ERRSot HS Status Register, offset: 0x118
◆ PPI_ERRSOTSYNC_HS
__I uint32_t MIPI_CSI2RX_Type::PPI_ERRSOTSYNC_HS
ErrSotSync HS Status Register, offset: 0x11C
◆ PPI_ERRSYNCESC
__I uint32_t MIPI_CSI2RX_Type::PPI_ERRSYNCESC
ErrSyncEsc Status Register, offset: 0x124
◆ PR
__IO uint32_t GPT_Type::PR
GPT Prescaler Register, offset: 0x4
◆ PRE_CHARGE_TIME
__IO uint32_t TSC_Type::PRE_CHARGE_TIME
Pre-charge Time, offset: 0x10
◆ PRES_STATE
__I uint32_t USDHC_Type::PRES_STATE
Present State, offset: 0x24
◆ PROT_CTRL
__IO uint32_t USDHC_Type::PROT_CTRL
Protocol Control, offset: 0x28
◆ PS_BACKGROUND
__IO uint32_t PXP_Type::PS_BACKGROUND
PS Background Color, offset: 0x100
◆ PS_BUF
__IO uint32_t PXP_Type::PS_BUF
PS Input Buffer Address, offset: 0xC0
◆ PS_CLRKEYHIGH
__IO uint32_t PXP_Type::PS_CLRKEYHIGH
PS Color Key High, offset: 0x140
◆ PS_CLRKEYLOW
__IO uint32_t PXP_Type::PS_CLRKEYLOW
PS Color Key Low, offset: 0x130
◆ PS_CTRL
__IO uint32_t PXP_Type::PS_CTRL
Processed Surface (PS) Control Register, offset: 0xB0
◆ PS_CTRL_CLR
__IO uint32_t PXP_Type::PS_CTRL_CLR
Processed Surface (PS) Control Register, offset: 0xB8
◆ PS_CTRL_SET
__IO uint32_t PXP_Type::PS_CTRL_SET
Processed Surface (PS) Control Register, offset: 0xB4
◆ PS_CTRL_TOG
__IO uint32_t PXP_Type::PS_CTRL_TOG
Processed Surface (PS) Control Register, offset: 0xBC
◆ PS_OFFSET
__IO uint32_t PXP_Type::PS_OFFSET
PS Scale Offset Register, offset: 0x120
◆ PS_PITCH
__IO uint32_t PXP_Type::PS_PITCH
Processed Surface Pitch, offset: 0xF0
◆ PS_SCALE
__IO uint32_t PXP_Type::PS_SCALE
PS Scale Factor Register, offset: 0x110
◆ PS_UBUF
__IO uint32_t PXP_Type::PS_UBUF
PS U/Cb or 2 Plane UV Input Buffer Address, offset: 0xD0
◆ PS_VBUF
__IO uint32_t PXP_Type::PS_VBUF
PS V/Cr Input Buffer Address, offset: 0xE0
◆ PSCCR
__IO uint32_t LMEM_Type::PSCCR
PS bus Cache control register, offset: 0x800
◆ PSCCVR
__IO uint32_t LMEM_Type::PSCCVR
PS bus Cache read/write value register, offset: 0x80C
◆ PSCLCR
__IO uint32_t LMEM_Type::PSCLCR
PS bus Cache line control register, offset: 0x804
◆ PSCSAR
__IO uint32_t LMEM_Type::PSCSAR
PS bus Cache search address register, offset: 0x808
◆ PSR
__I uint32_t GPIO_Type::PSR
GPIO pad status register, offset: 0x8
◆ PTR
__I uint32_t DAC_Type::PTR
DAC FIFO Pointer Register, offset: 0x10
◆ PUF_KEY_CTRL
__IO uint32_t KEY_MANAGER_Type::PUF_KEY_CTRL
CSR PUF Key Control, offset: 0x30
◆ PWD
__IO uint32_t USBPHY_Type::PWD
USB PHY Power-Down Register, offset: 0x0
◆ PWD_CLR
__IO uint32_t USBPHY_Type::PWD_CLR
USB PHY Power-Down Register, offset: 0x8
◆ PWD_SET
__IO uint32_t USBPHY_Type::PWD_SET
USB PHY Power-Down Register, offset: 0x4
◆ PWD_TOG
__IO uint32_t USBPHY_Type::PWD_TOG
USB PHY Power-Down Register, offset: 0xC
◆ PWRCTRL
__IO uint32_t PUF_Type::PWRCTRL
PUF Power Control Of RAM, offset: 0x108
◆ PX_SDID_JR [1/3]
__I uint32_t CAAM_Type::PX_SDID_JR
Partition 0 SDID register..Partition 15 SDID register, array offset: 0x10A00, array step: index*0x10000, index2*0x10
◆  [2/3]
__I uint32_t { ... } ::PX_SDID_JR
◆  [3/3]
◆ PX_SDID_PG0 [1/3]
__I uint32_t CAAM_Type::PX_SDID_PG0
Partition 0 SDID register..Partition 15 SDID register, array offset: 0xA00, array step: 0x10
◆  [2/3]
__I uint32_t { ... } ::PX_SDID_PG0
◆  [3/3]
◆ PX_SMAG1_JR [1/3]
__IO uint32_t CAAM_Type::PX_SMAG1_JR
Secure Memory Access Group Registers, array offset: 0x10A0C, array step: index*0x10000, index2*0x10
◆  [2/3]
__IO uint32_t { ... } ::PX_SMAG1_JR
◆  [3/3]
◆ PX_SMAG1_PG0 [1/3]
__IO uint32_t CAAM_Type::PX_SMAG1_PG0
Secure Memory Access Group Registers, array offset: 0xA0C, array step: 0x10
◆  [2/3]
__IO uint32_t { ... } ::PX_SMAG1_PG0
◆  [3/3]
◆ PX_SMAG2_JR [1/3]
__IO uint32_t CAAM_Type::PX_SMAG2_JR
Secure Memory Access Group Registers, array offset: 0x10A08, array step: index*0x10000, index2*0x10
◆  [2/3]
__IO uint32_t { ... } ::PX_SMAG2_JR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::PX_SMAG2_PG0
Secure Memory Access Group Registers, array offset: 0xA08, array step: 0x10
◆ PX_SMAG2_PG0 [2/3]
__IO uint32_t CAAM_Type::PX_SMAG2_PG0
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::PX_SMAPR_JR
Secure Memory Access Permissions register, array offset: 0x10A04, array step: index*0x10000, index2*0x10
◆ PX_SMAPR_JR [2/3]
__IO uint32_t CAAM_Type::PX_SMAPR_JR
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::PX_SMAPR_PG0
Secure Memory Access Permissions register, array offset: 0xA04, array step: 0x10
◆ PX_SMAPR_PG0 [2/3]
__IO uint32_t CAAM_Type::PX_SMAPR_PG0
◆  [3/3]
◆ QOS
__IO uint32_t ENET_Type::QOS
QOS Scheme, offset: 0x1F0
◆ R
__I uint32_t ADC_Type::R[8]
Data result register for HW triggers, array offset: 0x24, array step: 0x4
◆ RACC
__IO uint32_t ENET_Type::RACC
Receive Accelerator Function Configuration, offset: 0x1C4
◆ RAEM
__IO uint32_t ENET_Type::RAEM
Receive FIFO Almost Empty Threshold, offset: 0x198
◆ RAFL
__IO uint32_t ENET_Type::RAFL
Receive FIFO Almost Full Threshold, offset: 0x19C
◆ RANGE0
__IO uint32_t TMPSNS_Type::RANGE0
Temperature Sensor Range Register 0, offset: 0x20
◆ RANGE0_CLR
__IO uint32_t TMPSNS_Type::RANGE0_CLR
Temperature Sensor Range Register 0, offset: 0x28
◆ RANGE0_SET
__IO uint32_t TMPSNS_Type::RANGE0_SET
Temperature Sensor Range Register 0, offset: 0x24
◆ RANGE0_TOG
__IO uint32_t TMPSNS_Type::RANGE0_TOG
Temperature Sensor Range Register 0, offset: 0x2C
◆ RANGE1
__IO uint32_t TMPSNS_Type::RANGE1
Temperature Sensor Range Register 1, offset: 0x30
◆ RANGE1_CLR
__IO uint32_t TMPSNS_Type::RANGE1_CLR
Temperature Sensor Range Register 1, offset: 0x38
◆ RANGE1_SET
__IO uint32_t TMPSNS_Type::RANGE1_SET
Temperature Sensor Range Register 1, offset: 0x34
◆ RANGE1_TOG
__IO uint32_t TMPSNS_Type::RANGE1_TOG
Temperature Sensor Range Register 1, offset: 0x3C
◆ RANGE_CTRL
__IO uint32_t PDM_Type::RANGE_CTRL
PDM Range Control register, offset: 0x74
◆ RANGE_STAT
__IO uint32_t PDM_Type::RANGE_STAT
PDM Range Status register, offset: 0x7C
◆ RBB_LPSR_CONFIGURE
__IO uint32_t ANADIG_PMU_Type::RBB_LPSR_CONFIGURE
RBB_LPSR_CONFIGURE_REGISTER, offset: 0x790
◆ RBB_LPSR_ENABLE_SP
__IO uint32_t ANADIG_PMU_Type::RBB_LPSR_ENABLE_SP
RBB_LPSR_ENABLE_SP_REGISTER, offset: 0x720
◆ RBB_LPSR_STBY_EN_SP
__IO uint32_t ANADIG_PMU_Type::RBB_LPSR_STBY_EN_SP
RBB_LPSR_STBY_EN_SP_REGISTER, offset: 0x770
◆ RBB_SOC_CONFIGURE
__IO uint32_t ANADIG_PMU_Type::RBB_SOC_CONFIGURE
RBB_SOC_CONFIGURE_REGISTER, offset: 0x7A0
◆ RBB_SOC_ENABLE_SP
__IO uint32_t ANADIG_PMU_Type::RBB_SOC_ENABLE_SP
RBB_SOC_ENABLE_SP_REGISTER, offset: 0x710
◆ RBB_SOC_STBY_EN_SP
__IO uint32_t ANADIG_PMU_Type::RBB_SOC_STBY_EN_SP
RBB_SOC_STBY_EN_SP_REGISTER, offset: 0x760
◆ RCMD
__IO uint32_t CAAM_Type::RCMD
RTIC Command Register, offset: 0x6000C
◆ RCMR
__IO uint32_t ENET_Type::RCMR
Receive Classification Match Register for Class n, array offset: 0x1C8, array step: 0x4
◆ RCR
__IO uint32_t ENET_Type::RCR
Receive Control Register, offset: 0x84
◆ RCR1
__IO uint32_t I2S_Type::RCR1
SAI Receive Configuration 1 Register, offset: 0x8C
Receive Configuration 1, offset: 0x8C
◆ RCR2
__IO uint32_t I2S_Type::RCR2
SAI Receive Configuration 2 Register, offset: 0x90
Receive Configuration 2, offset: 0x90
◆ RCR3
__IO uint32_t I2S_Type::RCR3
SAI Receive Configuration 3 Register, offset: 0x94
Receive Configuration 3, offset: 0x94
◆ RCR4
__IO uint32_t I2S_Type::RCR4
SAI Receive Configuration 4 Register, offset: 0x98
Receive Configuration 4, offset: 0x98
◆ RCR5
__IO uint32_t I2S_Type::RCR5
SAI Receive Configuration 5 Register, offset: 0x9C
Receive Configuration 5, offset: 0x9C
◆ RCSR
__IO uint32_t I2S_Type::RCSR
SAI Receive Control Register, offset: 0x88
Receive Control, offset: 0x88
◆ RCTL
__IO uint32_t CAAM_Type::RCTL
RTIC Control Register, offset: 0x60014
◆ RDAR
__IO uint32_t ENET_Type::RDAR
Receive Descriptor Active Register - Ring 0, offset: 0x10
◆ RDAR1
__IO uint32_t ENET_Type::RDAR1
Receive Descriptor Active Register - Ring 1, offset: 0x1E0
◆ RDAR2
__IO uint32_t ENET_Type::RDAR2
Receive Descriptor Active Register - Ring 2, offset: 0x1E8
◆ RDHBUF
__O uint32_t CAAM_Type::RDHBUF
RNG DRNG Hash Buffer Register, offset: 0x6E8
◆ RDHCNTL
__IO uint32_t CAAM_Type::RDHCNTL
RNG DRNG Hash Control Register, offset: 0x6E0
◆ RDHDIG
__I uint32_t CAAM_Type::RDHDIG
RNG DRNG Hash Digest Register, offset: 0x6E4
◆ RDINT0
__I uint32_t CAAM_Type::RDINT0
RNG DRNG State Handle 0 Reseed Interval Register, offset: 0x6D0
◆ RDINT1
__I uint32_t CAAM_Type::RDINT1
RNG DRNG State Handle 1 Reseed Interval Register, offset: 0x6D4
◆ RDR [1/2]
__I uint32_t I2S_Type::RDR
SAI Receive Data Register, array offset: 0xA0, array step: 0x4
Receive Data, array offset: 0xA0, array step: 0x4
◆ RDR [2/2]
__I uint32_t LPSPI_Type::RDR
Receive Data Register, offset: 0x74
Receive Data, offset: 0x74
◆ RDSR
__IO uint32_t ENET_Type::RDSR
Receive Descriptor Ring 0 Start Register, offset: 0x180
◆ RDSR1
__IO uint32_t ENET_Type::RDSR1
Receive Descriptor Ring 1 Start Register, offset: 0x160
◆ RDSR2
__IO uint32_t ENET_Type::RDSR2
Receive Descriptor Ring 2 Start Register, offset: 0x16C
◆ RDSTA
__I uint32_t CAAM_Type::RDSTA
RNG DRNG Status Register, offset: 0x6C0
◆ READ_CTRL
__IO uint32_t OCOTP_Type::READ_CTRL
OTP Controller Write Data Register, offset: 0x30
OTP Controller Read Control Register, offset: 0x30
◆ READ_FUSE_DATA [1/3]
__IO uint32_t OCOTP_Type::READ_FUSE_DATA
OTP Controller Read Data Register, offset: 0x40
OTP Controller Read Data 0 Register..OTP Controller Read Data 3 Register, array offset: 0x100, array step: 0x10
◆  [2/3]
__IO uint32_t { ... } ::READ_FUSE_DATA
◆  [3/3]
◆ REFTOP_OTP_TRIM_VALUE
__I uint32_t ANADIG_PMU_Type::REFTOP_OTP_TRIM_VALUE
REFTOP_OTP_TRIM_VALUE_REGISTER, offset: 0x7B0
◆ REG0
__IO uint32_t DCDC_Type::REG0
DCDC Register 0, offset: 0x0
DCDC Register 0, offset: 0x8
◆ REG1
__IO uint32_t DCDC_Type::REG1
DCDC Register 1, offset: 0x4
DCDC Register 1, offset: 0xC
◆ REG10
__IO uint32_t DCDC_Type::REG10
DCDC Register 10, offset: 0x34
◆ REG11
__IO uint32_t DCDC_Type::REG11
DCDC Register 11, offset: 0x38
◆ REG12
__IO uint32_t DCDC_Type::REG12
DCDC Register 12, offset: 0x3C
◆ REG13
__IO uint32_t DCDC_Type::REG13
DCDC Register 13, offset: 0x40
◆ REG14
__IO uint32_t DCDC_Type::REG14
DCDC Register 14, offset: 0x44
◆ REG15
__IO uint32_t DCDC_Type::REG15
DCDC Register 15, offset: 0x48
◆ REG16
__IO uint32_t DCDC_Type::REG16
DCDC Register 16, offset: 0x4C
◆ REG17
__IO uint32_t DCDC_Type::REG17
DCDC Register 17, offset: 0x50
◆ REG18
__IO uint32_t DCDC_Type::REG18
DCDC Register 18, offset: 0x54
◆ REG19
__IO uint32_t DCDC_Type::REG19
DCDC Register 19, offset: 0x58
◆ REG2
__IO uint32_t DCDC_Type::REG2
DCDC Register 2, offset: 0x8
DCDC Register 2, offset: 0x10
◆ REG20
__IO uint32_t DCDC_Type::REG20
DCDC Register 20, offset: 0x5C
◆ REG21
__IO uint32_t DCDC_Type::REG21
DCDC Register 21, offset: 0x60
◆ REG22
__IO uint32_t DCDC_Type::REG22
DCDC Register 22, offset: 0x64
◆ REG23
__IO uint32_t DCDC_Type::REG23
DCDC Register 23, offset: 0x68
◆ REG24
__IO uint32_t DCDC_Type::REG24
DCDC Register 24, offset: 0x6C
◆ REG3
__IO uint32_t DCDC_Type::REG3
DCDC Register 3, offset: 0xC
DCDC Register 3, offset: 0x14
◆ REG4
__IO uint32_t DCDC_Type::REG4
DCDC Register 4, offset: 0x18
◆ REG5
__IO uint32_t DCDC_Type::REG5
DCDC Register 5, offset: 0x1C
◆ REG6
__IO uint32_t DCDC_Type::REG6
DCDC Register 6, offset: 0x20
◆ REG7
__IO uint32_t DCDC_Type::REG7
DCDC Register 7, offset: 0x24
◆ REG7P
__IO uint32_t DCDC_Type::REG7P
DCDC Register 7 plus, offset: 0x28
◆ REG8
__IO uint32_t DCDC_Type::REG8
DCDC Register 8, offset: 0x2C
◆ REG9
__IO uint32_t DCDC_Type::REG9
DCDC Register 9, offset: 0x30
◆ REG_1P1
__IO uint32_t PMU_Type::REG_1P1
Regulator 1P1 Register, offset: 0x110
◆ REG_1P1_CLR
__IO uint32_t PMU_Type::REG_1P1_CLR
Regulator 1P1 Register, offset: 0x118
◆ REG_1P1_SET
__IO uint32_t PMU_Type::REG_1P1_SET
Regulator 1P1 Register, offset: 0x114
◆ REG_1P1_TOG
__IO uint32_t PMU_Type::REG_1P1_TOG
Regulator 1P1 Register, offset: 0x11C
◆ REG_2P5
__IO uint32_t PMU_Type::REG_2P5
Regulator 2P5 Register, offset: 0x130
◆ REG_2P5_CLR
__IO uint32_t PMU_Type::REG_2P5_CLR
Regulator 2P5 Register, offset: 0x138
◆ REG_2P5_SET
__IO uint32_t PMU_Type::REG_2P5_SET
Regulator 2P5 Register, offset: 0x134
◆ REG_2P5_TOG
__IO uint32_t PMU_Type::REG_2P5_TOG
Regulator 2P5 Register, offset: 0x13C
◆ REG_3P0
__IO uint32_t PMU_Type::REG_3P0
Regulator 3P0 Register, offset: 0x120
◆ REG_3P0_CLR
__IO uint32_t PMU_Type::REG_3P0_CLR
Regulator 3P0 Register, offset: 0x128
◆ REG_3P0_SET
__IO uint32_t PMU_Type::REG_3P0_SET
Regulator 3P0 Register, offset: 0x124
◆ REG_3P0_TOG
__IO uint32_t PMU_Type::REG_3P0_TOG
Regulator 3P0 Register, offset: 0x12C
◆ REG_CORE
__IO uint32_t PMU_Type::REG_CORE
Digital Regulator Core Register, offset: 0x140
◆ REG_CORE_CLR
__IO uint32_t PMU_Type::REG_CORE_CLR
Digital Regulator Core Register, offset: 0x148
◆ REG_CORE_SET
__IO uint32_t PMU_Type::REG_CORE_SET
Digital Regulator Core Register, offset: 0x144
◆ REG_CORE_TOG
__IO uint32_t PMU_Type::REG_CORE_TOG
Digital Regulator Core Register, offset: 0x14C
◆ REGATTR [1/3]
__IO uint32_t IEE_Type::REGATTR
IEE Region 0 Attribute Register...IEE Region 7 Attribute Register., array offset: 0x100, array step: 0x100
◆  [2/3]
__IO uint32_t { ... } ::REGATTR
◆  [3/3]
◆ REGION0_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION0_BOT_ADDR
Start address of IEE region (n), offset: 0x4
◆ REGION0_RDC_D0
__IO uint32_t IEE_APC_Type::REGION0_RDC_D0
Region control of core domain 0 for region (n), offset: 0x8
◆ REGION0_RDC_D1
__IO uint32_t IEE_APC_Type::REGION0_RDC_D1
Region control of core domain 1 for region (n), offset: 0xC
◆ REGION0_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION0_TOP_ADDR
End address of IEE region (n), offset: 0x0
◆ REGION1_BOT
__IO uint32_t BEE_Type::REGION1_BOT
Region1 Bottom Address Register, offset: 0x44
◆ REGION1_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION1_BOT_ADDR
Start address of IEE region (n), offset: 0x14
◆ REGION1_RDC_D0
__IO uint32_t IEE_APC_Type::REGION1_RDC_D0
Region control of core domain 0 for region (n), offset: 0x18
◆ REGION1_RDC_D1
__IO uint32_t IEE_APC_Type::REGION1_RDC_D1
Region control of core domain 1 for region (n), offset: 0x1C
◆ REGION1_TOP
__IO uint32_t BEE_Type::REGION1_TOP
Region1 Top Address Register, offset: 0x40
◆ REGION1_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION1_TOP_ADDR
End address of IEE region (n), offset: 0x10
◆ REGION2_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION2_BOT_ADDR
Start address of IEE region (n), offset: 0x24
◆ REGION2_RDC_D0
__IO uint32_t IEE_APC_Type::REGION2_RDC_D0
Region control of core domain 0 for region (n), offset: 0x28
◆ REGION2_RDC_D1
__IO uint32_t IEE_APC_Type::REGION2_RDC_D1
Region control of core domain 1 for region (n), offset: 0x2C
◆ REGION2_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION2_TOP_ADDR
End address of IEE region (n), offset: 0x20
◆ REGION3_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION3_BOT_ADDR
Start address of IEE region (n), offset: 0x34
◆ REGION3_RDC_D0
__IO uint32_t IEE_APC_Type::REGION3_RDC_D0
Region control of core domain 0 for region (n), offset: 0x38
◆ REGION3_RDC_D1
__IO uint32_t IEE_APC_Type::REGION3_RDC_D1
Region control of core domain 1 for region (n), offset: 0x3C
◆ REGION3_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION3_TOP_ADDR
End address of IEE region (n), offset: 0x30
◆ REGION4_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION4_BOT_ADDR
Start address of IEE region (n), offset: 0x44
◆ REGION4_RDC_D0
__IO uint32_t IEE_APC_Type::REGION4_RDC_D0
Region control of core domain 0 for region (n), offset: 0x48
◆ REGION4_RDC_D1
__IO uint32_t IEE_APC_Type::REGION4_RDC_D1
Region control of core domain 1 for region (n), offset: 0x4C
◆ REGION4_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION4_TOP_ADDR
End address of IEE region (n), offset: 0x40
◆ REGION5_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION5_BOT_ADDR
Start address of IEE region (n), offset: 0x54
◆ REGION5_RDC_D0
__IO uint32_t IEE_APC_Type::REGION5_RDC_D0
Region control of core domain 0 for region (n), offset: 0x58
◆ REGION5_RDC_D1
__IO uint32_t IEE_APC_Type::REGION5_RDC_D1
Region control of core domain 1 for region (n), offset: 0x5C
◆ REGION5_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION5_TOP_ADDR
End address of IEE region (n), offset: 0x50
◆ REGION6_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION6_BOT_ADDR
Start address of IEE region (n), offset: 0x64
◆ REGION6_RDC_D0
__IO uint32_t IEE_APC_Type::REGION6_RDC_D0
Region control of core domain 0 for region (n), offset: 0x68
◆ REGION6_RDC_D1
__IO uint32_t IEE_APC_Type::REGION6_RDC_D1
Region control of core domain 1 for region (n), offset: 0x6C
◆ REGION6_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION6_TOP_ADDR
End address of IEE region (n), offset: 0x60
◆ REGION7_BOT_ADDR
__IO uint32_t IEE_APC_Type::REGION7_BOT_ADDR
Start address of IEE region (n), offset: 0x74
◆ REGION7_RDC_D0
__IO uint32_t IEE_APC_Type::REGION7_RDC_D0
Region control of core domain 0 for region (n), offset: 0x78
◆ REGION7_RDC_D1
__IO uint32_t IEE_APC_Type::REGION7_RDC_D1
Region control of core domain 1 for region (n), offset: 0x7C
◆ REGION7_TOP_ADDR
__IO uint32_t IEE_APC_Type::REGION7_TOP_ADDR
End address of IEE region (n), offset: 0x70
◆  [1/3]
__O uint32_t { ... } ::REGKEY1[8]
IEE Region 0 Key 1 Register..IEE Region 7 Key 1 Register, array offset: 0x140, array step: index*0x100, index2*0x4
◆ REGKEY1 [2/3]
__O uint32_t IEE_Type::REGKEY1[8]
◆  [3/3]
◆  [1/3]
__O uint32_t { ... } ::REGKEY2[8]
IEE Region 0 Key 2 Register..IEE Region 7 Key 2 Register, array offset: 0x180, array step: index*0x100, index2*0x4
◆ REGKEY2 [2/3]
__O uint32_t IEE_Type::REGKEY2[8]
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::REGPO
IEE Region 0 Page Offset Register..IEE Region 7 Page Offset Register, array offset: 0x108, array step: 0x100
◆ REGPO [2/3]
__IO uint32_t IEE_Type::REGPO
◆  [3/3]
◆ REIE
__IO uint32_t CAAM_Type::REIE
Recoverable Error Interrupt Enable, offset: 0xB04
◆ REIF
__I uint32_t CAAM_Type::REIF
Recoverable Error Interrupt Force, offset: 0xB08
◆ REIH
__IO uint32_t CAAM_Type::REIH
Recoverable Error Interrupt Halt, offset: 0xB0C
◆ REIR0JR [1/3]
__I uint32_t CAAM_Type::REIR0JR
Recoverable Error Interrupt Record 0 for Job Ring 0..Recoverable Error Interrupt Record 0 for Job Ring 3, array offset: 0x10E00, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::REIR0JR
◆  [3/3]
◆ REIR0RTIC
__I uint32_t CAAM_Type::REIR0RTIC
Recoverable Error Interrupt Record 0 for RTIC, offset: 0x60E00
◆ REIR2JR [1/3]
__I uint64_t CAAM_Type::REIR2JR
Recoverable Error Interrupt Record 2 for Job Ring 0..Recoverable Error Interrupt Record 2 for Job Ring 3, array offset: 0x10E08, array step: 0x10000
◆  [2/3]
__I uint64_t { ... } ::REIR2JR
◆  [3/3]
◆ REIR2RTIC
__I uint64_t CAAM_Type::REIR2RTIC
Recoverable Error Interrupt Record 2 for RTIC, offset: 0x60E08
◆  [1/3]
__I uint32_t { ... } ::REIR4JR
Recoverable Error Interrupt Record 4 for Job Ring 0..Recoverable Error Interrupt Record 4 for Job Ring 3, array offset: 0x10E10, array step: 0x10000
◆ REIR4JR [2/3]
__I uint32_t CAAM_Type::REIR4JR
◆  [3/3]
◆ REIR4RTIC
__I uint32_t CAAM_Type::REIR4RTIC
Recoverable Error Interrupt Record 4 for RTIC, offset: 0x60E10
◆ REIR5JR [1/3]
__I uint32_t CAAM_Type::REIR5JR
Recoverable Error Interrupt Record 5 for Job Ring 0..Recoverable Error Interrupt Record 5 for Job Ring 3, array offset: 0x10E14, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::REIR5JR
◆  [3/3]
◆ REIR5RTIC
__I uint32_t CAAM_Type::REIR5RTIC
Recoverable Error Interrupt Record 5 for RTIC, offset: 0x60E14
◆ REIS
__IO uint32_t CAAM_Type::REIS
Recoverable Error Interrupt Status, offset: 0xB00
◆ RELOAD
__IO uint32_t CDOG_Type::RELOAD
Instruction Timer reload, offset: 0x4
◆ REND
__IO uint32_t CAAM_Type::REND
RTIC Endian Register, offset: 0x60034
◆ RERRAR
__I uint32_t CAN_Type::RERRAR
Error Report Address register, offset: 0xAF0
◆ RERRDR
__I uint32_t CAN_Type::RERRDR
Error Report Data register, offset: 0xAF4
◆ RERRSYNR
__I uint32_t CAN_Type::RERRSYNR
Error Report Syndrome register, offset: 0xAF8
◆ RESFIFO
__I uint32_t ADC_Type::RESFIFO
LPADC Data Result FIFO Register, offset: 0x300
◆ RESTART
__O uint32_t CDOG_Type::RESTART
RESTART Command, offset: 0x28
◆ REV
__IO uint16_t ENC_Type::REV
Revolution Counter Register, offset: 0xA
◆ REVH
__I uint16_t ENC_Type::REVH
Revolution Hold Register, offset: 0xC
◆ RFDR
__I uint32_t FLEXSPI_Type::RFDR
IP RX FIFO Data Register 0..IP RX FIFO Data Register 31, array offset: 0x100, array step: 0x4
◆ RFIFO
__I uint32_t CSI_Type::RFIFO
CSI RX FIFO Register, offset: 0x10
◆ RFR
__I uint32_t I2S_Type::RFR
SAI Receive FIFO Register, array offset: 0xC0, array step: 0x4
Receive FIFO, array offset: 0xC0, array step: 0x4
◆ RGB_ADJUST
__IO uint32_t LCDIF_Type::RGB_ADJUST
RGB Color Range Adjust, offset: 0x2A0
◆ RGB_ADJUST_CLR
__IO uint32_t LCDIF_Type::RGB_ADJUST_CLR
RGB Color Range Adjust, offset: 0x2A8
◆ RGB_ADJUST_SET
__IO uint32_t LCDIF_Type::RGB_ADJUST_SET
RGB Color Range Adjust, offset: 0x2A4
◆ RGB_ADJUST_TOG
__IO uint32_t LCDIF_Type::RGB_ADJUST_TOG
RGB Color Range Adjust, offset: 0x2AC
◆  [1/3]
__IO uint32_t { ... } ::RGD_W0
AES Region Descriptor Word0, array offset: 0xD18, array step: 0x40
◆ RGD_W0 [2/3]
__IO uint32_t OTFAD_Type::RGD_W0
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::RGD_W1
AES Region Descriptor Word1, array offset: 0xD1C, array step: 0x40
◆ RGD_W1 [2/3]
__IO uint32_t OTFAD_Type::RGD_W1
◆  [3/3]
◆  [1/3]
__IO uint64_t { ... } ::RMA
RTIC Memory Block A Address 0 Register..RTIC Memory Block D Address 1 Register, array offset: 0x60100, array step: index*0x20, index2*0x10
◆ RMA [2/3]
__IO uint64_t CAAM_Type::RMA
◆  [3/3]
◆ RMD
__IO uint32_t CAAM_Type::RMD
RTIC Memory Block A Big Endian Hash Result Word 0..RTIC Memory Block D Little Endian Hash Result Word 31, array offset: 0x60200, array step: index*0x100, index2*0x80, index3*0x4
◆  [1/3]
__IO uint32_t { ... } ::RML
RTIC Memory Block A Length 0 Register..RTIC Memory Block D Length 1 Register, array offset: 0x6010C, array step: index*0x20, index2*0x10
◆ RML [2/3]
__IO uint32_t CAAM_Type::RML
◆  [3/3]
◆ RMON_R_BC_PKT
__I uint32_t ENET_Type::RMON_R_BC_PKT
Rx Broadcast Packets Statistic Register, offset: 0x288
◆ RMON_R_CRC_ALIGN
__I uint32_t ENET_Type::RMON_R_CRC_ALIGN
Rx Packets with CRC/Align Error Statistic Register, offset: 0x290
◆ RMON_R_FRAG
__I uint32_t ENET_Type::RMON_R_FRAG
Rx Packets Less Than 64 Bytes and Bad CRC Statistic Register, offset: 0x29C
◆ RMON_R_JAB
__I uint32_t ENET_Type::RMON_R_JAB
Rx Packets Greater Than MAX_FL Bytes and Bad CRC Statistic Register, offset: 0x2A0
◆ RMON_R_MC_PKT
__I uint32_t ENET_Type::RMON_R_MC_PKT
Rx Multicast Packets Statistic Register, offset: 0x28C
◆ RMON_R_OCTETS
__I uint32_t ENET_Type::RMON_R_OCTETS
Rx Octets Statistic Register, offset: 0x2C4
◆ RMON_R_OVERSIZE
__I uint32_t ENET_Type::RMON_R_OVERSIZE
Rx Packets Greater Than MAX_FL and Good CRC Statistic Register, offset: 0x298
◆ RMON_R_P1024TO2047
__I uint32_t ENET_Type::RMON_R_P1024TO2047
Rx 1024- to 2047-Byte Packets Statistic Register, offset: 0x2BC
◆ RMON_R_P128TO255
__I uint32_t ENET_Type::RMON_R_P128TO255
Rx 128- to 255-Byte Packets Statistic Register, offset: 0x2B0
◆ RMON_R_P256TO511
__I uint32_t ENET_Type::RMON_R_P256TO511
Rx 256- to 511-Byte Packets Statistic Register, offset: 0x2B4
◆ RMON_R_P512TO1023
__I uint32_t ENET_Type::RMON_R_P512TO1023
Rx 512- to 1023-Byte Packets Statistic Register, offset: 0x2B8
◆ RMON_R_P64
__I uint32_t ENET_Type::RMON_R_P64
Rx 64-Byte Packets Statistic Register, offset: 0x2A8
◆ RMON_R_P65TO127
__I uint32_t ENET_Type::RMON_R_P65TO127
Rx 65- to 127-Byte Packets Statistic Register, offset: 0x2AC
◆ RMON_R_P_GTE2048
__I uint32_t ENET_Type::RMON_R_P_GTE2048
Rx Packets Greater than 2048 Bytes Statistic Register, offset: 0x2C0
◆ RMON_R_PACKETS
__I uint32_t ENET_Type::RMON_R_PACKETS
Rx Packet Count Statistic Register, offset: 0x284
◆ RMON_R_UNDERSIZE
__I uint32_t ENET_Type::RMON_R_UNDERSIZE
Rx Packets with Less Than 64 Bytes and Good CRC Statistic Register, offset: 0x294
◆ RMON_T_BC_PKT
__I uint32_t ENET_Type::RMON_T_BC_PKT
Tx Broadcast Packets Statistic Register, offset: 0x208
◆ RMON_T_COL
__I uint32_t ENET_Type::RMON_T_COL
Tx Collision Count Statistic Register, offset: 0x224
◆ RMON_T_CRC_ALIGN
__I uint32_t ENET_Type::RMON_T_CRC_ALIGN
Tx Packets with CRC/Align Error Statistic Register, offset: 0x210
◆ RMON_T_FRAG
__I uint32_t ENET_Type::RMON_T_FRAG
Tx Packets Less Than 64 Bytes and Bad CRC Statistic Register, offset: 0x21C
◆ RMON_T_JAB
__I uint32_t ENET_Type::RMON_T_JAB
Tx Packets Greater Than MAX_FL bytes and Bad CRC Statistic Register, offset: 0x220
◆ RMON_T_MC_PKT
__I uint32_t ENET_Type::RMON_T_MC_PKT
Tx Multicast Packets Statistic Register, offset: 0x20C
◆ RMON_T_OCTETS
__I uint32_t ENET_Type::RMON_T_OCTETS
Tx Octets Statistic Register, offset: 0x244
◆ RMON_T_OVERSIZE
__I uint32_t ENET_Type::RMON_T_OVERSIZE
Tx Packets GT MAX_FL bytes and Good CRC Statistic Register, offset: 0x218
◆ RMON_T_P1024TO2047
__I uint32_t ENET_Type::RMON_T_P1024TO2047
Tx 1024- to 2047-byte Packets Statistic Register, offset: 0x23C
◆ RMON_T_P128TO255
__I uint32_t ENET_Type::RMON_T_P128TO255
Tx 128- to 255-byte Packets Statistic Register, offset: 0x230
◆ RMON_T_P256TO511
__I uint32_t ENET_Type::RMON_T_P256TO511
Tx 256- to 511-byte Packets Statistic Register, offset: 0x234
◆ RMON_T_P512TO1023
__I uint32_t ENET_Type::RMON_T_P512TO1023
Tx 512- to 1023-byte Packets Statistic Register, offset: 0x238
◆ RMON_T_P64
__I uint32_t ENET_Type::RMON_T_P64
Tx 64-Byte Packets Statistic Register, offset: 0x228
◆ RMON_T_P65TO127
__I uint32_t ENET_Type::RMON_T_P65TO127
Tx 65- to 127-byte Packets Statistic Register, offset: 0x22C
◆ RMON_T_P_GTE2048
__I uint32_t ENET_Type::RMON_T_P_GTE2048
Tx Packets Greater Than 2048 Bytes Statistic Register, offset: 0x240
◆ RMON_T_PACKETS
__I uint32_t ENET_Type::RMON_T_PACKETS
Tx Packet Count Statistic Register, offset: 0x204
◆ RMON_T_UNDERSIZE
__I uint32_t ENET_Type::RMON_T_UNDERSIZE
Tx Packets Less Than Bytes and Good CRC Statistic Register, offset: 0x214
◆ RMR
__IO uint32_t I2S_Type::RMR
SAI Receive Mask Register, offset: 0xE0
Receive Mask, offset: 0xE0
◆ ROMPATCHA
__IO uint32_t ROMC_Type::ROMPATCHA[16]
ROMC Address Registers, array offset: 0x100, array step: 0x4
◆ ROMPATCHCNTL
__IO uint32_t ROMC_Type::ROMPATCHCNTL
ROMC Control Register, offset: 0xF4
◆ ROMPATCHD
__IO uint32_t ROMC_Type::ROMPATCHD[8]
ROMC Data Registers, array offset: 0xD4, array step: 0x4
◆ ROMPATCHENH
uint32_t ROMC_Type::ROMPATCHENH
ROMC Enable Register High, offset: 0xF8
◆ ROMPATCHENL
__IO uint32_t ROMC_Type::ROMPATCHENL
ROMC Enable Register Low, offset: 0xFC
◆ ROMPATCHSR
__IO uint32_t ROMC_Type::ROMPATCHSR
ROMC Status Register, offset: 0x208
◆ RR
__I uint32_t MU_Type::RR
Processor B Receive Register 0..Processor B Receive Register 3, array offset: 0x10, array step: 0x4
Processor A Receive Register 0..Processor A Receive Register 3, array offset: 0x10, array step: 0x4
◆ RSEM
__IO uint32_t ENET_Type::RSEM
Receive FIFO Section Empty Threshold, offset: 0x194
◆ RSFL
__IO uint32_t ENET_Type::RSFL
Receive FIFO Section Full Threshold, offset: 0x190
◆ RSR
__I uint32_t LPSPI_Type::RSR
Receive Status Register, offset: 0x70
Receive Status, offset: 0x70
◆ RSTA
__I uint32_t CAAM_Type::RSTA
RTIC Status Register, offset: 0x60004
◆ RSTGT
__IO uint16_t SEMA4_Type::RSTGT
Semaphores (Secure) Reset Gate n, offset: 0x100
◆  [1/3]
__IO uint16_t { ... } ::RSTGT_R
Reset Gate Read, offset: 0x42
◆ RSTGT_R [2/3]
__IO uint16_t RDC_SEMAPHORE_Type::RSTGT_R
◆  [3/3]
◆  [1/3]
__IO uint16_t { ... } ::RSTGT_W
Reset Gate Write, offset: 0x42
◆ RSTGT_W [2/3]
__IO uint16_t RDC_SEMAPHORE_Type::RSTGT_W
◆  [3/3]
◆ RSTNTF
__IO uint16_t SEMA4_Type::RSTNTF
Semaphores (Secure) Reset IRQ Notification, offset: 0x104
◆ RTENT
__I uint32_t CAAM_Type::RTENT
RNG TRNG Entropy Read Register, array offset: 0x640, array step: 0x4
◆ RTFRQCNT [1/3]
__I uint32_t CAAM_Type::RTFRQCNT
RNG TRNG Frequency Count Register, offset: 0x61C
◆  [2/3]
__I uint32_t { ... } ::RTFRQCNT
◆  [3/3]
◆ RTFRQMAX [1/3]
__IO uint32_t CAAM_Type::RTFRQMAX
RNG TRNG Frequency Count Maximum Limit Register, offset: 0x61C
◆  [2/3]
__IO uint32_t { ... } ::RTFRQMAX
◆  [3/3]
◆ RTFRQMIN
__IO uint32_t CAAM_Type::RTFRQMIN
RNG TRNG Frequency Count Minimum Limit Register, offset: 0x618
◆ RTHR
__IO uint32_t CAAM_Type::RTHR
RTIC Throttle Register, offset: 0x6001C
◆ RTIC_DID [1/3]
__IO uint32_t CAAM_Type::RTIC_DID
RTIC DID Register for Block A..RTIC DID Register for Block D, array offset: 0x64, array step: 0x8
◆  [2/3]
__IO uint32_t { ... } ::RTIC_DID
◆  [3/3]
◆ RTIC_OWN
__IO uint32_t CAAM_Type::RTIC_OWN
RTIC OWN Register, offset: 0x60
◆ RTMCTL
__IO uint32_t CAAM_Type::RTMCTL
RNG TRNG Miscellaneous Control Register, offset: 0x600
◆ RTPKRCNT10
__I uint32_t CAAM_Type::RTPKRCNT10
RNG TRNG Statistical Check Poker Count 1 and 0 Register, offset: 0x680
◆ RTPKRCNT32
__I uint32_t CAAM_Type::RTPKRCNT32
RNG TRNG Statistical Check Poker Count 3 and 2 Register, offset: 0x684
◆ RTPKRCNT54
__I uint32_t CAAM_Type::RTPKRCNT54
RNG TRNG Statistical Check Poker Count 5 and 4 Register, offset: 0x688
◆ RTPKRCNT76
__I uint32_t CAAM_Type::RTPKRCNT76
RNG TRNG Statistical Check Poker Count 7 and 6 Register, offset: 0x68C
◆ RTPKRCNT98
__I uint32_t CAAM_Type::RTPKRCNT98
RNG TRNG Statistical Check Poker Count 9 and 8 Register, offset: 0x690
◆ RTPKRCNTBA
__I uint32_t CAAM_Type::RTPKRCNTBA
RNG TRNG Statistical Check Poker Count B and A Register, offset: 0x694
◆ RTPKRCNTDC
__I uint32_t CAAM_Type::RTPKRCNTDC
RNG TRNG Statistical Check Poker Count D and C Register, offset: 0x698
◆ RTPKRCNTFE
__I uint32_t CAAM_Type::RTPKRCNTFE
RNG TRNG Statistical Check Poker Count F and E Register, offset: 0x69C
◆ RTPKRMAX [1/3]
__IO uint32_t CAAM_Type::RTPKRMAX
RNG TRNG Poker Maximum Limit Register, offset: 0x60C
◆  [2/3]
__IO uint32_t { ... } ::RTPKRMAX
◆  [3/3]
◆ RTPKRRNG
__IO uint32_t CAAM_Type::RTPKRRNG
RNG TRNG Poker Range Register, offset: 0x608
◆ RTPKRSQ [1/3]
__I uint32_t CAAM_Type::RTPKRSQ
RNG TRNG Poker Square Calculation Result Register, offset: 0x60C
◆  [2/3]
__I uint32_t { ... } ::RTPKRSQ
◆  [3/3]
◆ RTSBLIM [1/3]
__IO uint32_t CAAM_Type::RTSBLIM
RNG TRNG Sparse Bit Limit Register, offset: 0x614
◆  [2/3]
__IO uint32_t { ... } ::RTSBLIM
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::RTSCMC
RNG TRNG Statistical Check Monobit Count Register, offset: 0x620
◆ RTSCMC [2/3]
__I uint32_t CAAM_Type::RTSCMC
◆  [3/3]
◆ RTSCMISC
__IO uint32_t CAAM_Type::RTSCMISC
RNG TRNG Statistical Check Miscellaneous Register, offset: 0x604
◆  [1/3]
__IO uint32_t { ... } ::RTSCML
RNG TRNG Statistical Check Monobit Limit Register, offset: 0x620
◆ RTSCML [2/3]
__IO uint32_t CAAM_Type::RTSCML
◆  [3/3]
◆  [1/3]
__I uint32_t { ... } ::RTSCR1C
RNG TRNG Statistical Check Run Length 1 Count Register, offset: 0x624
◆ RTSCR1C [2/3]
__I uint32_t CAAM_Type::RTSCR1C
◆  [3/3]
◆ RTSCR1L [1/3]
__IO uint32_t CAAM_Type::RTSCR1L
RNG TRNG Statistical Check Run Length 1 Limit Register, offset: 0x624
◆  [2/3]
__IO uint32_t { ... } ::RTSCR1L
◆  [3/3]
◆ RTSCR2C [1/3]
__I uint32_t CAAM_Type::RTSCR2C
RNG TRNG Statistical Check Run Length 2 Count Register, offset: 0x628
◆  [2/3]
__I uint32_t { ... } ::RTSCR2C
◆  [3/3]
◆ RTSCR2L [1/3]
__IO uint32_t CAAM_Type::RTSCR2L
RNG TRNG Statistical Check Run Length 2 Limit Register, offset: 0x628
◆  [2/3]
__IO uint32_t { ... } ::RTSCR2L
◆  [3/3]
◆ RTSCR3C [1/3]
__I uint32_t CAAM_Type::RTSCR3C
RNG TRNG Statistical Check Run Length 3 Count Register, offset: 0x62C
◆  [2/3]
__I uint32_t { ... } ::RTSCR3C
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::RTSCR3L
RNG TRNG Statistical Check Run Length 3 Limit Register, offset: 0x62C
◆ RTSCR3L [2/3]
__IO uint32_t CAAM_Type::RTSCR3L
◆  [3/3]
◆ RTSCR4C [1/3]
__I uint32_t CAAM_Type::RTSCR4C
RNG TRNG Statistical Check Run Length 4 Count Register, offset: 0x630
◆  [2/3]
__I uint32_t { ... } ::RTSCR4C
◆  [3/3]
◆ RTSCR4L [1/3]
__IO uint32_t CAAM_Type::RTSCR4L
RNG TRNG Statistical Check Run Length 4 Limit Register, offset: 0x630
◆  [2/3]
__IO uint32_t { ... } ::RTSCR4L
◆  [3/3]
◆ RTSCR5C [1/3]
__I uint32_t CAAM_Type::RTSCR5C
RNG TRNG Statistical Check Run Length 5 Count Register, offset: 0x634
◆  [2/3]
__I uint32_t { ... } ::RTSCR5C
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::RTSCR5L
RNG TRNG Statistical Check Run Length 5 Limit Register, offset: 0x634
◆ RTSCR5L [2/3]
__IO uint32_t CAAM_Type::RTSCR5L
◆  [3/3]
◆ RTSCR6PC [1/3]
__I uint32_t CAAM_Type::RTSCR6PC
RNG TRNG Statistical Check Run Length 6+ Count Register, offset: 0x638
◆  [2/3]
__I uint32_t { ... } ::RTSCR6PC
◆  [3/3]
◆ RTSCR6PL [1/3]
__IO uint32_t CAAM_Type::RTSCR6PL
RNG TRNG Statistical Check Run Length 6+ Limit Register, offset: 0x638
◆  [2/3]
__IO uint32_t { ... } ::RTSCR6PL
◆  [3/3]
◆ RTSDCTL
__IO uint32_t CAAM_Type::RTSDCTL
RNG TRNG Seed Control Register, offset: 0x610
◆ RTSTATUS
__I uint32_t CAAM_Type::RTSTATUS
RNG TRNG Status Register, offset: 0x63C
◆ RTTOTSAM [1/3]
__I uint32_t CAAM_Type::RTTOTSAM
RNG TRNG Total Samples Register, offset: 0x614
◆  [2/3]
__I uint32_t { ... } ::RTTOTSAM
◆  [3/3]
◆ RVID
__I uint32_t CAAM_Type::RVID
RTIC Version ID Register, offset: 0xFE0
◆ RVID_DC01
__I uint32_t CAAM_Type::RVID_DC01
RTIC Version ID Register, offset: 0x80FE0
◆  [1/3]
__I uint32_t { ... } ::RVID_JR
RTIC Version ID Register, array offset: 0x10FE0, array step: 0x10000
◆ RVID_JR [2/3]
__I uint32_t CAAM_Type::RVID_JR
◆  [3/3]
◆ RVID_RTIC
__I uint32_t CAAM_Type::RVID_RTIC
RTIC Version ID Register, offset: 0x60FE0
◆ RW [1/66]
__IO uint32_t AUDIO_PLL_Type::RW
Fractional PLL Control Register, offset: 0x0
Fractional PLL Spread Spectrum Control Register, offset: 0x10
Fractional PLL Numerator Control Register, offset: 0x20
Fractional PLL Denominator Control Register, offset: 0x30
◆  [2/66]
__IO uint32_t { ... } ::RW
◆  [3/66]
◆  [4/66]
◆  [5/66]
◆  [6/66]
◆ RW [7/66]
__IO uint32_t ETHERNET_PLL_Type::RW
◆  [8/66]
◆  [9/66]
◆  [10/66]
◆ RW [11/66]
__IO uint32_t OSC_RC_400M_Type::RW
Control Register 0, offset: 0x0
Control Register 1, offset: 0x10
Control Register 2, offset: 0x20
Control Register 3, offset: 0x30
◆  [12/66]
◆  [13/66]
◆  [14/66]
◆  [15/66]
◆  [16/66]
__I uint32_t { ... } ::RW
Status Register 0, offset: 0x50
◆ RW [17/66]
__I uint32_t OSC_RC_400M_Type::RW
Status Register 1, offset: 0x60
Status Register 2, offset: 0x70
◆  [18/66]
◆  [19/66]
◆  [20/66]
Analog Control Register CTRL0, offset: 0x0
◆ RW [21/66]
__IO uint32_t PHY_LDO_Type::RW
◆ RW [22/66]
__I uint32_t PHY_LDO_Type::RW
Analog Status Register STAT0, offset: 0x50
◆  [23/66]
◆ RW [24/66]
__IO uint32_t VIDEO_MUX_Type::RW
Video mux Control Register, offset: 0x0
Pixel Link Master(PLM) Control Register, offset: 0x20
YUV420 Control Register, offset: 0x30
Data Disable Register, offset: 0x50
MIPI DSI Control Register, offset: 0x70
◆  [25/66]
◆  [26/66]
◆  [27/66]
◆  [28/66]
◆  [29/66]
◆ RW [30/66]
__IO uint32_t VIDEO_PLL_Type::RW
◆  [31/66]
◆  [32/66]
◆  [33/66]
◆  [34/66]
◆  [35/66]
◆ RW [36/66]
__IO uint32_t VMBANDGAP_Type::RW
◆  [37/66]
◆ RW [38/66]
__I uint32_t VMBANDGAP_Type::RW
◆  [39/66]
◆  [40/66]
◆  [41/66]
◆  [42/66]
◆  [43/66]
◆  [44/66]
◆  [45/66]
◆  [46/66]
◆  [47/66]
◆  [48/66]
◆  [49/66]
◆  [50/66]
◆  [51/66]
◆  [52/66]
◆  [53/66]
◆  [54/66]
◆  [55/66]
◆  [56/66]
◆  [57/66]
◆  [58/66]
◆  [59/66]
◆  [60/66]
◆  [61/66]
◆  [62/66]
◆  [63/66]
◆  [64/66]
◆  [65/66]
◆  [66/66]
◆ RWDOG
__IO uint64_t CAAM_Type::RWDOG
RTIC Watchdog Timer, offset: 0x60028
◆ RX
__IO uint32_t USBPHY_Type::RX
USB PHY Receiver Control Register, offset: 0x20
◆ RX14MASK
__IO uint32_t CAN_Type::RX14MASK
Rx Buffer 14 Mask Register, offset: 0x14
Rx 14 Mask register, offset: 0x14
◆ RX15MASK
__IO uint32_t CAN_Type::RX15MASK
Rx Buffer 15 Mask Register, offset: 0x18
Rx 15 Mask register, offset: 0x18
◆ RX_BUF
__I uint32_t EMVSIM_Type::RX_BUF
Receive Data Read Buffer, offset: 0x2C
◆ RX_CLR
__IO uint32_t USBPHY_Type::RX_CLR
USB PHY Receiver Control Register, offset: 0x28
◆ RX_ERROR_STATUS
__I uint32_t DSI_HOST_Type::RX_ERROR_STATUS
RX_ERROR_STATUS, offset: 0x30
◆ RX_SET
__IO uint32_t USBPHY_Type::RX_SET
USB PHY Receiver Control Register, offset: 0x24
◆ RX_STATUS
__IO uint32_t EMVSIM_Type::RX_STATUS
Receive Status Register, offset: 0x20
◆ RX_THD
__IO uint32_t EMVSIM_Type::RX_THD
Receiver Threshold Register, offset: 0x18
◆ RX_TOG
__IO uint32_t USBPHY_Type::RX_TOG
USB PHY Receiver Control Register, offset: 0x2C
◆ RXCDRP
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::RXCDRP
RXCDRP, offset: 0x44
◆ RXCNT
__IO uint32_t CSI_Type::RXCNT
CSI RX Count Register, offset: 0x14
◆ RXFGMASK
__IO uint32_t CAN_Type::RXFGMASK
Rx FIFO Global Mask Register, offset: 0x48
Rx FIFO Global Mask register, offset: 0x48
◆ RXFIR
__I uint32_t CAN_Type::RXFIR
Rx FIFO Information Register, offset: 0x4C
Rx FIFO Information register, offset: 0x4C
◆ RXIC
__IO uint32_t ENET_Type::RXIC
Receive Interrupt Coalescing Register, array offset: 0x100, array step: 0x4
◆ RXIMR
__IO uint32_t CAN_Type::RXIMR
Rx Individual Mask Registers, array offset: 0x880, array step: 0x4
Rx Individual Mask registers, array offset: 0x880, array step: 0x4
◆ RXLPRP
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::RXLPRP
RXLPRP, offset: 0x40
◆ RXMGMASK
__IO uint32_t CAN_Type::RXMGMASK
Rx Mailboxes Global Mask Register, offset: 0x10
Rx Mailboxes Global Mask register, offset: 0x10
◆ SA
__IO uint32_t CSU_Type::SA
Secure access register, offset: 0x218
◆ SADDR [1/4]
__IO uint32_t DMA_Type::SADDR
TCD Source Address, array offset: 0x1000, array step: 0x20
◆  [2/4]
__IO uint32_t { ... } ::SADDR
◆  [3/4]
◆  [4/4]
◆ SAMR
__IO uint32_t LPI2C_Type::SAMR
Slave Address Match Register, offset: 0x140
Slave Address Match, offset: 0x140
◆ SASR
__I uint32_t LPI2C_Type::SASR
Slave Address Status Register, offset: 0x150
Slave Address Status, offset: 0x150
◆  [1/2]
__IO uint32_t { ... } ::SBLIM
Sparse Bit Limit Register, offset: 0x14
◆ SBLIM [2/2]
__IO uint32_t TRNG_Type::SBLIM
◆ SBMR1
__I uint32_t SRC_Type::SBMR1
SRC Boot Mode Register 1, offset: 0x4
SRC Boot Mode Register 1, offset: 0x8
◆ SBMR2
__I uint32_t SRC_Type::SBMR2
SRC Boot Mode Register 2, offset: 0x1C
SRC Boot Mode Register 2, offset: 0xC
◆ SBUSCFG
__IO uint32_t USB_Type::SBUSCFG
System Bus Config, offset: 0x90
◆ SCFGR
__IO uint32_t CAAM_Type::SCFGR
Security Configuration Register, offset: 0xC
◆ SCFGR1
__IO uint32_t LPI2C_Type::SCFGR1
Slave Configuration Register 1, offset: 0x124
Slave Configuration 1, offset: 0x124
◆ SCFGR2
__IO uint32_t LPI2C_Type::SCFGR2
Slave Configuration Register 2, offset: 0x128
Slave Configuration 2, offset: 0x128
◆ SCMC [1/2]
__I uint32_t TRNG_Type::SCMC
Statistical Check Monobit Count Register, offset: 0x20
◆  [2/2]
__I uint32_t { ... } ::SCMC
◆ SCMISC
__IO uint32_t TRNG_Type::SCMISC
Statistical Check Miscellaneous Register, offset: 0x4
◆ SCML [1/2]
__IO uint32_t TRNG_Type::SCML
Statistical Check Monobit Limit Register, offset: 0x20
◆  [2/2]
__IO uint32_t { ... } ::SCML
◆ SCR [1/4]
__IO uint8_t CMP_Type::SCR
CMP Status and Control Register, offset: 0x3
◆ SCR [2/4]
__IO uint32_t LPI2C_Type::SCR
Slave Control Register, offset: 0x110
Slave Control, offset: 0x110
◆ SCR [3/4]
__IO uint32_t SPDIF_Type::SCR
SPDIF Configuration Register, offset: 0x0
◆ SCR [4/4]
__IO uint32_t SRC_Type::SCR
SRC Control Register, offset: 0x0
◆ SCR1C [1/2]
__I uint32_t TRNG_Type::SCR1C
Statistical Check Run Length 1 Count Register, offset: 0x24
◆  [2/2]
__I uint32_t { ... } ::SCR1C
◆ SCR1L [1/2]
__IO uint32_t TRNG_Type::SCR1L
Statistical Check Run Length 1 Limit Register, offset: 0x24
◆  [2/2]
__IO uint32_t { ... } ::SCR1L
◆ SCR2C [1/2]
__I uint32_t TRNG_Type::SCR2C
Statistical Check Run Length 2 Count Register, offset: 0x28
◆  [2/2]
__I uint32_t { ... } ::SCR2C
◆ SCR2L [1/2]
__IO uint32_t TRNG_Type::SCR2L
Statistical Check Run Length 2 Limit Register, offset: 0x28
◆  [2/2]
__IO uint32_t { ... } ::SCR2L
◆  [1/2]
__I uint32_t { ... } ::SCR3C
Statistical Check Run Length 3 Count Register, offset: 0x2C
◆ SCR3C [2/2]
__I uint32_t TRNG_Type::SCR3C
◆  [1/2]
__IO uint32_t { ... } ::SCR3L
Statistical Check Run Length 3 Limit Register, offset: 0x2C
◆ SCR3L [2/2]
__IO uint32_t TRNG_Type::SCR3L
◆ SCR4C [1/2]
__I uint32_t TRNG_Type::SCR4C
Statistical Check Run Length 4 Count Register, offset: 0x30
◆  [2/2]
__I uint32_t { ... } ::SCR4C
◆ SCR4L [1/2]
__IO uint32_t TRNG_Type::SCR4L
Statistical Check Run Length 4 Limit Register, offset: 0x30
◆  [2/2]
__IO uint32_t { ... } ::SCR4L
◆  [1/2]
__I uint32_t { ... } ::SCR5C
Statistical Check Run Length 5 Count Register, offset: 0x34
◆ SCR5C [2/2]
__I uint32_t TRNG_Type::SCR5C
◆  [1/2]
__IO uint32_t { ... } ::SCR5L
Statistical Check Run Length 5 Limit Register, offset: 0x34
◆ SCR5L [2/2]
__IO uint32_t TRNG_Type::SCR5L
◆ SCR6PC [1/2]
__I uint32_t TRNG_Type::SCR6PC
Statistical Check Run Length 6+ Count Register, offset: 0x38
◆  [2/2]
__I uint32_t { ... } ::SCR6PC
◆ SCR6PL [1/2]
__IO uint32_t TRNG_Type::SCR6PL
Statistical Check Run Length 6+ Limit Register, offset: 0x38
◆  [2/2]
__IO uint32_t { ... } ::SCR6PL
◆ SCS
__IO uint32_t OCOTP_Type::SCS
Software Controllable Signals Register, offset: 0x60
◆ SCS_CLR
__IO uint32_t OCOTP_Type::SCS_CLR
Software Controllable Signals Register, offset: 0x68
◆ SCS_SET
__IO uint32_t OCOTP_Type::SCS_SET
Software Controllable Signals Register, offset: 0x64
◆ SCS_TOG
__IO uint32_t OCOTP_Type::SCS_TOG
Software Controllable Signals Register, offset: 0x6C
◆  [1/4]
__IO uint16_t { ... } ::SCTRL
Timer Channel Status and Control Register, array offset: 0xE, array step: 0x20
◆ SCTRL [2/4]
__IO uint16_t TMR_Type::SCTRL
◆  [3/4]
◆  [4/4]
◆ SDCTL
__IO uint32_t TRNG_Type::SDCTL
Seed Control Register, offset: 0x10
◆ SDER
__IO uint32_t LPI2C_Type::SDER
Slave DMA Enable Register, offset: 0x11C
Slave DMA Enable, offset: 0x11C
◆ SDRAMCR0
__IO uint32_t SEMC_Type::SDRAMCR0
SDRAM control register 0, offset: 0x40
SDRAM Control Register 0, offset: 0x40
◆ SDRAMCR1
__IO uint32_t SEMC_Type::SDRAMCR1
SDRAM control register 1, offset: 0x44
SDRAM Control Register 1, offset: 0x44
◆ SDRAMCR2
__IO uint32_t SEMC_Type::SDRAMCR2
SDRAM control register 2, offset: 0x48
SDRAM Control Register 2, offset: 0x48
◆ SDRAMCR3
__IO uint32_t SEMC_Type::SDRAMCR3
SDRAM control register 3, offset: 0x4C
SDRAM Control Register 3, offset: 0x4C
◆ SEC_CFG
__IO uint32_t TRNG_Type::SEC_CFG
Security Configuration Register, offset: 0xA0
◆ SECURE_COUNTER
__O uint32_t CDOG_Type::SECURE_COUNTER
Secure Counter, offset: 0xC
◆ SEEI
__O uint8_t DMA_Type::SEEI
Set Enable Error Interrupt, offset: 0x19
◆ SEL0 [1/2]
__IO uint16_t XBARA_Type::SEL0
Crossbar A Select Register 0, offset: 0x0
◆ SEL0 [2/2]
__IO uint16_t XBARB_Type::SEL0
Crossbar B Select Register 0, offset: 0x0
◆ SEL1 [1/2]
__IO uint16_t XBARA_Type::SEL1
Crossbar A Select Register 1, offset: 0x2
◆ SEL1 [2/2]
__IO uint16_t XBARB_Type::SEL1
Crossbar B Select Register 1, offset: 0x2
◆ SEL10
__IO uint16_t XBARA_Type::SEL10
Crossbar A Select Register 10, offset: 0x14
◆ SEL11
__IO uint16_t XBARA_Type::SEL11
Crossbar A Select Register 11, offset: 0x16
◆ SEL12
__IO uint16_t XBARA_Type::SEL12
Crossbar A Select Register 12, offset: 0x18
◆ SEL13
__IO uint16_t XBARA_Type::SEL13
Crossbar A Select Register 13, offset: 0x1A
◆ SEL14
__IO uint16_t XBARA_Type::SEL14
Crossbar A Select Register 14, offset: 0x1C
◆ SEL15
__IO uint16_t XBARA_Type::SEL15
Crossbar A Select Register 15, offset: 0x1E
◆ SEL16
__IO uint16_t XBARA_Type::SEL16
Crossbar A Select Register 16, offset: 0x20
◆ SEL17
__IO uint16_t XBARA_Type::SEL17
Crossbar A Select Register 17, offset: 0x22
◆ SEL18
__IO uint16_t XBARA_Type::SEL18
Crossbar A Select Register 18, offset: 0x24
◆ SEL19
__IO uint16_t XBARA_Type::SEL19
Crossbar A Select Register 19, offset: 0x26
◆ SEL2 [1/2]
__IO uint16_t XBARA_Type::SEL2
Crossbar A Select Register 2, offset: 0x4
◆ SEL2 [2/2]
__IO uint16_t XBARB_Type::SEL2
Crossbar B Select Register 2, offset: 0x4
◆ SEL20
__IO uint16_t XBARA_Type::SEL20
Crossbar A Select Register 20, offset: 0x28
◆ SEL21
__IO uint16_t XBARA_Type::SEL21
Crossbar A Select Register 21, offset: 0x2A
◆ SEL22
__IO uint16_t XBARA_Type::SEL22
Crossbar A Select Register 22, offset: 0x2C
◆ SEL23
__IO uint16_t XBARA_Type::SEL23
Crossbar A Select Register 23, offset: 0x2E
◆ SEL24
__IO uint16_t XBARA_Type::SEL24
Crossbar A Select Register 24, offset: 0x30
◆ SEL25
__IO uint16_t XBARA_Type::SEL25
Crossbar A Select Register 25, offset: 0x32
◆ SEL26
__IO uint16_t XBARA_Type::SEL26
Crossbar A Select Register 26, offset: 0x34
◆ SEL27
__IO uint16_t XBARA_Type::SEL27
Crossbar A Select Register 27, offset: 0x36
◆ SEL28
__IO uint16_t XBARA_Type::SEL28
Crossbar A Select Register 28, offset: 0x38
◆ SEL29
__IO uint16_t XBARA_Type::SEL29
Crossbar A Select Register 29, offset: 0x3A
◆ SEL3 [1/2]
__IO uint16_t XBARA_Type::SEL3
Crossbar A Select Register 3, offset: 0x6
◆ SEL3 [2/2]
__IO uint16_t XBARB_Type::SEL3
Crossbar B Select Register 3, offset: 0x6
◆ SEL30
__IO uint16_t XBARA_Type::SEL30
Crossbar A Select Register 30, offset: 0x3C
◆ SEL31
__IO uint16_t XBARA_Type::SEL31
Crossbar A Select Register 31, offset: 0x3E
◆ SEL32
__IO uint16_t XBARA_Type::SEL32
Crossbar A Select Register 32, offset: 0x40
◆ SEL33
__IO uint16_t XBARA_Type::SEL33
Crossbar A Select Register 33, offset: 0x42
◆ SEL34
__IO uint16_t XBARA_Type::SEL34
Crossbar A Select Register 34, offset: 0x44
◆ SEL35
__IO uint16_t XBARA_Type::SEL35
Crossbar A Select Register 35, offset: 0x46
◆ SEL36
__IO uint16_t XBARA_Type::SEL36
Crossbar A Select Register 36, offset: 0x48
◆ SEL37
__IO uint16_t XBARA_Type::SEL37
Crossbar A Select Register 37, offset: 0x4A
◆ SEL38
__IO uint16_t XBARA_Type::SEL38
Crossbar A Select Register 38, offset: 0x4C
◆ SEL39
__IO uint16_t XBARA_Type::SEL39
Crossbar A Select Register 39, offset: 0x4E
◆ SEL4 [1/2]
__IO uint16_t XBARA_Type::SEL4
Crossbar A Select Register 4, offset: 0x8
◆ SEL4 [2/2]
__IO uint16_t XBARB_Type::SEL4
Crossbar B Select Register 4, offset: 0x8
◆ SEL40
__IO uint16_t XBARA_Type::SEL40
Crossbar A Select Register 40, offset: 0x50
◆ SEL41
__IO uint16_t XBARA_Type::SEL41
Crossbar A Select Register 41, offset: 0x52
◆ SEL42
__IO uint16_t XBARA_Type::SEL42
Crossbar A Select Register 42, offset: 0x54
◆ SEL43
__IO uint16_t XBARA_Type::SEL43
Crossbar A Select Register 43, offset: 0x56
◆ SEL44
__IO uint16_t XBARA_Type::SEL44
Crossbar A Select Register 44, offset: 0x58
◆ SEL45
__IO uint16_t XBARA_Type::SEL45
Crossbar A Select Register 45, offset: 0x5A
◆ SEL46
__IO uint16_t XBARA_Type::SEL46
Crossbar A Select Register 46, offset: 0x5C
◆ SEL47
__IO uint16_t XBARA_Type::SEL47
Crossbar A Select Register 47, offset: 0x5E
◆ SEL48
__IO uint16_t XBARA_Type::SEL48
Crossbar A Select Register 48, offset: 0x60
◆ SEL49
__IO uint16_t XBARA_Type::SEL49
Crossbar A Select Register 49, offset: 0x62
◆ SEL5 [1/2]
__IO uint16_t XBARA_Type::SEL5
Crossbar A Select Register 5, offset: 0xA
◆ SEL5 [2/2]
__IO uint16_t XBARB_Type::SEL5
Crossbar B Select Register 5, offset: 0xA
◆ SEL50
__IO uint16_t XBARA_Type::SEL50
Crossbar A Select Register 50, offset: 0x64
◆ SEL51
__IO uint16_t XBARA_Type::SEL51
Crossbar A Select Register 51, offset: 0x66
◆ SEL52
__IO uint16_t XBARA_Type::SEL52
Crossbar A Select Register 52, offset: 0x68
◆ SEL53
__IO uint16_t XBARA_Type::SEL53
Crossbar A Select Register 53, offset: 0x6A
◆ SEL54
__IO uint16_t XBARA_Type::SEL54
Crossbar A Select Register 54, offset: 0x6C
◆ SEL55
__IO uint16_t XBARA_Type::SEL55
Crossbar A Select Register 55, offset: 0x6E
◆ SEL56
__IO uint16_t XBARA_Type::SEL56
Crossbar A Select Register 56, offset: 0x70
◆ SEL57
__IO uint16_t XBARA_Type::SEL57
Crossbar A Select Register 57, offset: 0x72
◆ SEL58
__IO uint16_t XBARA_Type::SEL58
Crossbar A Select Register 58, offset: 0x74
◆ SEL59
__IO uint16_t XBARA_Type::SEL59
Crossbar A Select Register 59, offset: 0x76
◆ SEL6 [1/2]
__IO uint16_t XBARA_Type::SEL6
Crossbar A Select Register 6, offset: 0xC
◆ SEL6 [2/2]
__IO uint16_t XBARB_Type::SEL6
Crossbar B Select Register 6, offset: 0xC
◆ SEL60
__IO uint16_t XBARA_Type::SEL60
Crossbar A Select Register 60, offset: 0x78
◆ SEL61
__IO uint16_t XBARA_Type::SEL61
Crossbar A Select Register 61, offset: 0x7A
◆ SEL62
__IO uint16_t XBARA_Type::SEL62
Crossbar A Select Register 62, offset: 0x7C
◆ SEL63
__IO uint16_t XBARA_Type::SEL63
Crossbar A Select Register 63, offset: 0x7E
◆ SEL64
__IO uint16_t XBARA_Type::SEL64
Crossbar A Select Register 64, offset: 0x80
◆ SEL65
__IO uint16_t XBARA_Type::SEL65
Crossbar A Select Register 65, offset: 0x82
◆ SEL66
__IO uint16_t XBARA_Type::SEL66
Crossbar A Select Register 66, offset: 0x84
◆ SEL67
__IO uint16_t XBARA_Type::SEL67
Crossbar A Select Register 67, offset: 0x86
◆ SEL68
__IO uint16_t XBARA_Type::SEL68
Crossbar A Select Register 68, offset: 0x88
◆ SEL69
__IO uint16_t XBARA_Type::SEL69
Crossbar A Select Register 69, offset: 0x8A
◆ SEL7 [1/2]
__IO uint16_t XBARA_Type::SEL7
Crossbar A Select Register 7, offset: 0xE
◆ SEL7 [2/2]
__IO uint16_t XBARB_Type::SEL7
Crossbar B Select Register 7, offset: 0xE
◆ SEL70
__IO uint16_t XBARA_Type::SEL70
Crossbar A Select Register 70, offset: 0x8C
◆ SEL71
__IO uint16_t XBARA_Type::SEL71
Crossbar A Select Register 71, offset: 0x8E
◆ SEL72
__IO uint16_t XBARA_Type::SEL72
Crossbar A Select Register 72, offset: 0x90
◆ SEL73
__IO uint16_t XBARA_Type::SEL73
Crossbar A Select Register 73, offset: 0x92
◆ SEL74
__IO uint16_t XBARA_Type::SEL74
Crossbar A Select Register 74, offset: 0x94
◆ SEL75
__IO uint16_t XBARA_Type::SEL75
Crossbar A Select Register 75, offset: 0x96
◆ SEL76
__IO uint16_t XBARA_Type::SEL76
Crossbar A Select Register 76, offset: 0x98
◆ SEL77
__IO uint16_t XBARA_Type::SEL77
Crossbar A Select Register 77, offset: 0x9A
◆ SEL78
__IO uint16_t XBARA_Type::SEL78
Crossbar A Select Register 78, offset: 0x9C
◆ SEL79
__IO uint16_t XBARA_Type::SEL79
Crossbar A Select Register 79, offset: 0x9E
◆ SEL8
__IO uint16_t XBARA_Type::SEL8
Crossbar A Select Register 8, offset: 0x10
◆ SEL80
__IO uint16_t XBARA_Type::SEL80
Crossbar A Select Register 80, offset: 0xA0
◆ SEL81
__IO uint16_t XBARA_Type::SEL81
Crossbar A Select Register 81, offset: 0xA2
◆ SEL82
__IO uint16_t XBARA_Type::SEL82
Crossbar A Select Register 82, offset: 0xA4
◆ SEL83
__IO uint16_t XBARA_Type::SEL83
Crossbar A Select Register 83, offset: 0xA6
◆ SEL84
__IO uint16_t XBARA_Type::SEL84
Crossbar A Select Register 84, offset: 0xA8
◆ SEL85
__IO uint16_t XBARA_Type::SEL85
Crossbar A Select Register 85, offset: 0xAA
◆ SEL86
__IO uint16_t XBARA_Type::SEL86
Crossbar A Select Register 86, offset: 0xAC
◆ SEL87
__IO uint16_t XBARA_Type::SEL87
Crossbar A Select Register 87, offset: 0xAE
◆ SEL9
__IO uint16_t XBARA_Type::SEL9
Crossbar A Select Register 9, offset: 0x12
◆ SELECT_INPUT [1/2]
__IO uint32_t IOMUXC_Type::SELECT_INPUT
ANATOP_USB_OTG1_ID_SELECT_INPUT DAISY Register..XBAR_INOUT23_SELECT_INPUT DAISY Register, array offset: 0x3F4, array step: 0x4
FLEXCAN1_RX_SELECT_INPUT DAISY Register..XBAR1_IN_SELECT_INPUT_35 DAISY Register, array offset: 0x498, array step: 0x4
◆ SELECT_INPUT [2/2]
__IO uint32_t IOMUXC_LPSR_Type::SELECT_INPUT
CAN3_IPP_IND_CANRX_SELECT_INPUT DAISY Register..SAI4_IPP_IND_SAI_TXSYNC_SELECT_INPUT DAISY Register, array offset: 0x80, array step: 0x4
◆ SEND_PACKET
__IO uint32_t DSI_HOST_APB_PKT_IF_Type::SEND_PACKET
SEND_PACKET, offset: 0x8
◆ SERQ
__O uint8_t DMA_Type::SERQ
Set Enable Request, offset: 0x1B
◆ SERV
__O uint8_t EWM_Type::SERV
Service Register, offset: 0x1
◆  [1/69]
__IO uint32_t { ... } ::SET
Fractional PLL Control Register, offset: 0x4
◆ SET [2/69]
__IO uint32_t AUDIO_PLL_Type::SET
Fractional PLL Spread Spectrum Control Register, offset: 0x14
Fractional PLL Numerator Control Register, offset: 0x24
Fractional PLL Denominator Control Register, offset: 0x34
◆  [3/69]
◆  [4/69]
◆  [5/69]
◆ SET [6/69]
__IO uint32_t CCM_Type::SET
General Purpose Register, array offset: 0x4804, array step: 0x20
◆  [7/69]
◆ SET [8/69]
__IO uint32_t ETHERNET_PLL_Type::SET
◆  [9/69]
◆  [10/69]
◆  [11/69]
◆  [12/69]
◆  [13/69]
◆ SET [14/69]
__IO uint32_t OSC_RC_400M_Type::SET
Control Register 1, offset: 0x14
Control Register 2, offset: 0x24
Control Register 3, offset: 0x34
◆  [15/69]
◆  [16/69]
◆  [17/69]
◆  [18/69]
__I uint32_t { ... } ::SET
Status Register 0, offset: 0x54
◆ SET [19/69]
__I uint32_t OSC_RC_400M_Type::SET
Status Register 1, offset: 0x64
Status Register 2, offset: 0x74
◆  [20/69]
◆  [21/69]
◆  [22/69]
Analog Control Register CTRL0, offset: 0x4
◆ SET [23/69]
__IO uint32_t PHY_LDO_Type::SET
◆  [24/69]
Analog Status Register STAT0, offset: 0x54
◆ SET [25/69]
__I uint32_t PHY_LDO_Type::SET
◆  [26/69]
Video mux Control Register, offset: 0x4
◆ SET [27/69]
__IO uint32_t VIDEO_MUX_Type::SET
Pixel Link Master(PLM) Control Register, offset: 0x24
YUV420 Control Register, offset: 0x34
Data Disable Register, offset: 0x54
MIPI DSI Control Register, offset: 0x74
◆  [28/69]
◆  [29/69]
◆  [30/69]
◆  [31/69]
◆ SET [32/69]
__IO uint32_t VIDEO_PLL_Type::SET
◆  [33/69]
◆  [34/69]
◆  [35/69]
◆  [36/69]
◆  [37/69]
◆ SET [38/69]
__IO uint32_t VMBANDGAP_Type::SET
◆  [39/69]
◆ SET [40/69]
__I uint32_t VMBANDGAP_Type::SET
◆  [41/69]
◆  [42/69]
◆  [43/69]
◆  [44/69]
◆  [45/69]
◆  [46/69]
◆  [47/69]
◆  [48/69]
◆  [49/69]
◆  [50/69]
◆  [51/69]
◆  [52/69]
◆  [53/69]
◆  [54/69]
◆  [55/69]
◆  [56/69]
◆  [57/69]
◆  [58/69]
◆  [59/69]
◆  [60/69]
◆  [61/69]
◆  [62/69]
◆  [63/69]
◆  [64/69]
◆  [65/69]
◆  [66/69]
◆  [67/69]
◆  [68/69]
◆  [69/69]
◆ SETPOINT [1/9]
__IO uint32_t CCM_Type::SETPOINT
Setpoint setting, array offset: 0x40, array step: index*0x80, index2*0x4
Setpoint setting, array offset: 0x4040, array step: index*0x80, index2*0x4
Clock source Setpoint setting, array offset: 0x5008, array step: 0x20
LPCG Setpoint setting, array offset: 0x6008, array step: 0x20
◆  [2/9]
__IO uint32_t { ... } ::SETPOINT[16]
◆  [3/9]
◆  [4/9]
◆  [5/9]
◆  [6/9]
◆  [7/9]
◆  [8/9]
◆  [9/9]
◆ SETPOINT_DISPLAY
__IO uint32_t SRC_Type::SETPOINT_DISPLAY
Slice Setpoint Config Register, offset: 0x228
◆ SETPOINT_M4CORE
__IO uint32_t SRC_Type::SETPOINT_M4CORE
Slice Setpoint Config Register, offset: 0x288
◆ SETPOINT_M4DEBUG
__IO uint32_t SRC_Type::SETPOINT_M4DEBUG
Slice Setpoint Config Register, offset: 0x2C8
◆ SETPOINT_M7CORE
__IO uint32_t SRC_Type::SETPOINT_M7CORE
Slice Setpoint Config Register, offset: 0x2A8
◆ SETPOINT_M7DEBUG
__IO uint32_t SRC_Type::SETPOINT_M7DEBUG
Slice Setpoint Config Register, offset: 0x2E8
◆ SETPOINT_MEGA
__IO uint32_t SRC_Type::SETPOINT_MEGA
Slice Setpoint Config Register, offset: 0x208
◆ SETPOINT_USBPHY1
__IO uint32_t SRC_Type::SETPOINT_USBPHY1
Slice Setpoint Config Register, offset: 0x308
◆ SETPOINT_USBPHY2
__IO uint32_t SRC_Type::SETPOINT_USBPHY2
Slice Setpoint Config Register, offset: 0x328
◆ SETPOINT_WAKEUP
__IO uint32_t SRC_Type::SETPOINT_WAKEUP
Slice Setpoint Config Register, offset: 0x248
◆ SHIFTBUF
__IO uint32_t FLEXIO_Type::SHIFTBUF
Shifter Buffer N Register, array offset: 0x200, array step: 0x4
◆ SHIFTBUFBBS
__IO uint32_t FLEXIO_Type::SHIFTBUFBBS
Shifter Buffer N Bit Byte Swapped Register, array offset: 0x380, array step: 0x4
◆ SHIFTBUFBIS
__IO uint32_t FLEXIO_Type::SHIFTBUFBIS
Shifter Buffer N Bit Swapped Register, array offset: 0x280, array step: 0x4
◆ SHIFTBUFBYS
__IO uint32_t FLEXIO_Type::SHIFTBUFBYS
Shifter Buffer N Byte Swapped Register, array offset: 0x300, array step: 0x4
◆ SHIFTBUFEOS
__IO uint32_t FLEXIO_Type::SHIFTBUFEOS
Shifter Buffer N Even Odd Swapped Register, array offset: 0x880, array step: 0x4
◆ SHIFTBUFHWS
__IO uint32_t FLEXIO_Type::SHIFTBUFHWS
Shifter Buffer N Half Word Swapped Register, array offset: 0x700, array step: 0x4
◆ SHIFTBUFNBS
__IO uint32_t FLEXIO_Type::SHIFTBUFNBS
Shifter Buffer N Nibble Byte Swapped Register, array offset: 0x680, array step: 0x4
◆ SHIFTBUFNIS
__IO uint32_t FLEXIO_Type::SHIFTBUFNIS
Shifter Buffer N Nibble Swapped Register, array offset: 0x780, array step: 0x4
◆ SHIFTBUFOES
__IO uint32_t FLEXIO_Type::SHIFTBUFOES
Shifter Buffer N Odd Even Swapped Register, array offset: 0x800, array step: 0x4
◆ SHIFTCFG
__IO uint32_t FLEXIO_Type::SHIFTCFG
Shifter Configuration N Register, array offset: 0x100, array step: 0x4
◆ SHIFTCTL
__IO uint32_t FLEXIO_Type::SHIFTCTL
Shifter Control N Register, array offset: 0x80, array step: 0x4
◆ SHIFTEIEN
__IO uint32_t FLEXIO_Type::SHIFTEIEN
Shifter Error Interrupt Enable, offset: 0x24
◆ SHIFTERR
__IO uint32_t FLEXIO_Type::SHIFTERR
Shifter Error Register, offset: 0x14
◆ SHIFTSDEN
__IO uint32_t FLEXIO_Type::SHIFTSDEN
Shifter Status DMA Enable, offset: 0x30
◆ SHIFTSIEN
__IO uint32_t FLEXIO_Type::SHIFTSIEN
Shifter Status Interrupt Enable, offset: 0x20
◆ SHIFTSTAT
__IO uint32_t FLEXIO_Type::SHIFTSTAT
Shifter Status Register, offset: 0x10
◆ SHIFTSTATE
__IO uint32_t FLEXIO_Type::SHIFTSTATE
Shifter State Register, offset: 0x40
◆ SIC [1/4]
__O uint32_t SPDIF_Type::SIC
InterruptClear Register, offset: 0x10
◆  [2/4]
__O uint32_t { ... } ::SIC
◆  [3/4]
◆  [4/4]
◆ SIE
__IO uint32_t SPDIF_Type::SIE
InterruptEn Register, offset: 0xC
◆ SIER
__IO uint32_t LPI2C_Type::SIER
Slave Interrupt Enable Register, offset: 0x118
Slave Interrupt Enable, offset: 0x118
◆ SIGNAL_OVERRIDE
__IO uint32_t USBHSDCD_Type::SIGNAL_OVERRIDE
Signal Override Register, offset: 0xC
◆ SIL [1/3]
__IO uint32_t CAAM_Type::SIL
Sequence Input Length Register, array offset: 0x80E28, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::SIL
◆  [3/3]
◆ SINGLE_ERR_ADDR
__I uint32_t XECC_Type::SINGLE_ERR_ADDR
Single Error Address, offset: 0x18
◆ SINGLE_ERR_ADDR_ECC0
__I uint32_t MECC_Type::SINGLE_ERR_ADDR_ECC0
Single Error Address And ECC code On OCRAM Bank0, offset: 0x3C
◆ SINGLE_ERR_ADDR_ECC1
__I uint32_t MECC_Type::SINGLE_ERR_ADDR_ECC1
Single Error Address And ECC code On OCRAM Bank1, offset: 0x50
◆ SINGLE_ERR_ADDR_ECC2
__I uint32_t MECC_Type::SINGLE_ERR_ADDR_ECC2
Single Error Address And ECC code On OCRAM Bank2, offset: 0x64
◆ SINGLE_ERR_ADDR_ECC3
__I uint32_t MECC_Type::SINGLE_ERR_ADDR_ECC3
Single Error Address And ECC code On OCRAM Bank3, offset: 0x78
◆ SINGLE_ERR_BIT_FIELD
__I uint32_t XECC_Type::SINGLE_ERR_BIT_FIELD
Single Error Bit Field, offset: 0x28
◆ SINGLE_ERR_DATA
__I uint32_t XECC_Type::SINGLE_ERR_DATA
Single Error Read Data, offset: 0x1C
◆ SINGLE_ERR_DATA_HIGH0
__I uint32_t MECC_Type::SINGLE_ERR_DATA_HIGH0
HIGH 32 Bits Single Error Read Data On OCRAM Bank0, offset: 0x44
◆ SINGLE_ERR_DATA_HIGH1
__I uint32_t MECC_Type::SINGLE_ERR_DATA_HIGH1
HIGH 32 Bits Single Error Read Data On OCRAM Bank1, offset: 0x58
◆ SINGLE_ERR_DATA_HIGH2
__I uint32_t MECC_Type::SINGLE_ERR_DATA_HIGH2
HIGH 32 Bits Single Error Read Data On OCRAM Bank2, offset: 0x6C
◆ SINGLE_ERR_DATA_HIGH3
__I uint32_t MECC_Type::SINGLE_ERR_DATA_HIGH3
HIGH 32 Bits Single Error Read Data On OCRAM Bank3, offset: 0x80
◆ SINGLE_ERR_DATA_LOW0
__I uint32_t MECC_Type::SINGLE_ERR_DATA_LOW0
LOW 32 Bits Single Error Read Data On OCRAM Bank0, offset: 0x40
◆ SINGLE_ERR_DATA_LOW1
__I uint32_t MECC_Type::SINGLE_ERR_DATA_LOW1
LOW 32 Bits Single Error Read Data On OCRAM Bank1, offset: 0x54
◆ SINGLE_ERR_DATA_LOW2
__I uint32_t MECC_Type::SINGLE_ERR_DATA_LOW2
LOW 32 Bits Single Error Read Data On OCRAM Bank2, offset: 0x68
◆ SINGLE_ERR_DATA_LOW3
__I uint32_t MECC_Type::SINGLE_ERR_DATA_LOW3
LOW 32 Bits Single Error Read Data On OCRAM Bank3, offset: 0x7C
◆ SINGLE_ERR_ECC
__I uint32_t XECC_Type::SINGLE_ERR_ECC
Single Error ECC Code, offset: 0x20
◆ SINGLE_ERR_POS
__I uint32_t XECC_Type::SINGLE_ERR_POS
Single Error Bit Position, offset: 0x24
◆ SINGLE_ERR_POS_HIGH0
__I uint32_t MECC_Type::SINGLE_ERR_POS_HIGH0
HIGH Single Error Bit Position On OCRAM Bank0, offset: 0x4C
◆ SINGLE_ERR_POS_HIGH1
__I uint32_t MECC_Type::SINGLE_ERR_POS_HIGH1
HIGH Single Error Bit Position On OCRAM Bank1, offset: 0x60
◆ SINGLE_ERR_POS_HIGH2
__I uint32_t MECC_Type::SINGLE_ERR_POS_HIGH2
HIGH Single Error Bit Position On OCRAM Bank2, offset: 0x74
◆ SINGLE_ERR_POS_HIGH3
__I uint32_t MECC_Type::SINGLE_ERR_POS_HIGH3
HIGH Single Error Bit Position On OCRAM Bank3, offset: 0x88
◆ SINGLE_ERR_POS_LOW0
__I uint32_t MECC_Type::SINGLE_ERR_POS_LOW0
LOW Single Error Bit Position On OCRAM Bank0, offset: 0x48
◆ SINGLE_ERR_POS_LOW1
__I uint32_t MECC_Type::SINGLE_ERR_POS_LOW1
LOW Single Error Bit Position On OCRAM Bank1, offset: 0x5C
◆ SINGLE_ERR_POS_LOW2
__I uint32_t MECC_Type::SINGLE_ERR_POS_LOW2
LOW Single Error Bit Position On OCRAM Bank2, offset: 0x70
◆ SINGLE_ERR_POS_LOW3
__I uint32_t MECC_Type::SINGLE_ERR_POS_LOW3
LOW Single Error Bit Position On OCRAM Bank3, offset: 0x84
◆  [1/4]
__I uint32_t { ... } ::SIS
InterruptStat Register, offset: 0x10
◆ SIS [2/4]
__I uint32_t SPDIF_Type::SIS
◆  [3/4]
◆  [4/4]
◆ SJC_RESP0
__IO uint32_t OCOTP_Type::SJC_RESP0
Value of OTP Bank4 Word0 (Secure JTAG Response Field), offset: 0x600
◆ SJC_RESP1
__IO uint32_t OCOTP_Type::SJC_RESP1
Value of OTP Bank4 Word1 (Secure JTAG Response Field), offset: 0x610
◆ SKNR
__IO uint64_t CAAM_Type::SKNR
Secure Key Nonce Register, offset: 0x4E0
◆ SLAST [1/4]
__IO int32_t DMA_Type::SLAST
TCD Last Source Address Adjustment, array offset: 0x100C, array step: 0x20
◆  [2/4]
__IO int32_t { ... } ::SLAST
◆  [3/4]
◆  [4/4]
◆ SLOT0_CTRL
__IO uint32_t KEY_MANAGER_Type::SLOT0_CTRL
Slot 0 Control, offset: 0x400
◆ SLOT1_CTRL
__IO uint32_t KEY_MANAGER_Type::SLOT1_CTRL
Slot1 Control, offset: 0x404
◆ SLOT2_CTRL
__IO uint32_t KEY_MANAGER_Type::SLOT2_CTRL
Slot2 Control, offset: 0x408
◆ SLOT3_CTRL
__IO uint32_t KEY_MANAGER_Type::SLOT3_CTRL
Slot3 Control, offset: 0x40C
◆ SLOT4_CTRL
__IO uint32_t KEY_MANAGER_Type::SLOT4_CTRL
Slot 4 Control, offset: 0x410
◆  [1/3]
__IO uint32_t { ... } ::SLOT_CTRL
Slot Control Register, array offset: 0x0, array step: 0x10
◆ SLOT_CTRL [2/3]
__IO uint32_t IPS_DOMAIN_Type::SLOT_CTRL
◆  [3/3]
◆  [1/3]
__O uint32_t { ... } ::SMCR_JR
Secure Memory Command Register, array offset: 0x10BE4, array step: 0x10000
◆ SMCR_JR [2/3]
__O uint32_t CAAM_Type::SMCR_JR
◆  [3/3]
◆ SMCR_PG0
__O uint32_t CAAM_Type::SMCR_PG0
Secure Memory Command Register, offset: 0xBE4
◆  [1/3]
__I uint32_t { ... } ::SMCSR_JR
Secure Memory Command Status Register, array offset: 0x10BEC, array step: 0x10000
◆ SMCSR_JR [2/3]
__I uint32_t CAAM_Type::SMCSR_JR
◆  [3/3]
◆ SMCSR_PG0
__I uint32_t CAAM_Type::SMCSR_PG0
Secure Memory Command Status Register, offset: 0xBEC
◆ SMPO
__I uint32_t CAAM_Type::SMPO
Secure Memory Partition Owners Register, offset: 0xFBC
◆  [1/3]
__I uint32_t { ... } ::SMPO_JR
Secure Memory Partition Owners Register, array offset: 0x10FBC, array step: 0x10000
◆ SMPO_JR [2/3]
__I uint32_t CAAM_Type::SMPO_JR
◆  [3/3]
◆ SMSTA
__I uint32_t CAAM_Type::SMSTA
Secure Memory Status Register, offset: 0xFB4
◆ SMSTA_DC01
__I uint32_t CAAM_Type::SMSTA_DC01
Secure Memory Status Register, offset: 0x80FB4
◆ SMSTA_JR [1/3]
__I uint32_t CAAM_Type::SMSTA_JR
Secure Memory Status Register, array offset: 0x10FB4, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::SMSTA_JR
◆  [3/3]
◆ SMSTA_RTIC
__I uint32_t CAAM_Type::SMSTA_RTIC
Secure Memory Status Register, offset: 0x60FB4
◆ SMVID_LS
__I uint32_t CAAM_Type::SMVID_LS
Secure Memory Version ID Register, least-significant half, offset: 0xFDC
◆ SMVID_LS_DC01
__I uint32_t CAAM_Type::SMVID_LS_DC01
Secure Memory Version ID Register, least-significant half, offset: 0x80FDC
◆ SMVID_LS_JR [1/3]
__I uint32_t CAAM_Type::SMVID_LS_JR
Secure Memory Version ID Register, least-significant half, array offset: 0x10FDC, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::SMVID_LS_JR
◆  [3/3]
◆ SMVID_LS_RTIC
__I uint32_t CAAM_Type::SMVID_LS_RTIC
Secure Memory Version ID Register, least-significant half, offset: 0x60FDC
◆ SMVID_MS
__I uint32_t CAAM_Type::SMVID_MS
Secure Memory Version ID Register, most-significant half, offset: 0xFD8
◆ SMVID_MS_DC01
__I uint32_t CAAM_Type::SMVID_MS_DC01
Secure Memory Version ID Register, most-significant half, offset: 0x80FD8
◆ SMVID_MS_JR [1/3]
__I uint32_t CAAM_Type::SMVID_MS_JR
Secure Memory Version ID Register, most-significant half, array offset: 0x10FD8, array step: 0x10000
◆  [2/3]
__I uint32_t { ... } ::SMVID_MS_JR
◆  [3/3]
◆ SMVID_MS_RTIC
__I uint32_t CAAM_Type::SMVID_MS_RTIC
Secure Memory Version ID Register, most-significant half, offset: 0x60FD8
◆ SMWPJRR
__IO uint32_t CAAM_Type::SMWPJRR
Secure Memory Write Protect Job Ring Register, array offset: 0xBD0, array step: 0x4
◆  [1/4]
__IO uint16_t { ... } ::SOFF
TCD Signed Source Address Offset, array offset: 0x1004, array step: 0x20
◆ SOFF [2/4]
__IO uint16_t DMA_Type::SOFF
◆  [3/4]
◆  [4/4]
◆  [1/3]
__IO uint32_t { ... } ::SOL
Sequence Output Length Register, array offset: 0x80E20, array step: 0xE3C
◆ SOL [2/3]
__IO uint32_t CAAM_Type::SOL
◆  [3/3]
◆ SP_AUTHEN_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_AUTHEN_CTRL
SP Authentication Control, offset: 0x4
◆ SP_BG_PLDO_OFF_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_BG_PLDO_OFF_CTRL
SP bandgap and PLL_LDO off control, offset: 0x190
◆ SP_BG_PLDO_ON_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_BG_PLDO_ON_CTRL
SP bandgap and PLL_LDO on control, offset: 0x220
◆ SP_BIAS_OFF_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_BIAS_OFF_CTRL
SP bias off control, offset: 0x180
◆ SP_BIAS_ON_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_BIAS_ON_CTRL
SP bias on control, offset: 0x230
◆ SP_CPU_REQ
__I uint32_t GPC_SET_POINT_CTRL_Type::SP_CPU_REQ
CPU SP Request, offset: 0x10
◆ SP_DCDC_DOWN_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_DCDC_DOWN_CTRL
SP DCDC down control, offset: 0x1B0
◆ SP_DCDC_UP_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_DCDC_UP_CTRL
SP DCDC up control, offset: 0x200
◆ SP_GROUP_DOWN_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_GROUP_DOWN_CTRL
SP group down control, offset: 0x120
◆ SP_GROUP_UP_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_GROUP_UP_CTRL
SP group up control, offset: 0x290
◆ SP_INT_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_INT_CTRL
SP Interrupt Control, offset: 0x8
◆ SP_ISO_OFF_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_ISO_OFF_CTRL
SP ISO off control, offset: 0x260
◆ SP_ISO_ON_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_ISO_ON_CTRL
SP ISO on control, offset: 0x150
◆ SP_LDO_POST_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_LDO_POST_CTRL
SP LDO post control, offset: 0x210
◆ SP_LDO_PRE_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_LDO_PRE_CTRL
SP LDO pre control, offset: 0x1A0
◆ SP_LPCG_OFF_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_LPCG_OFF_CTRL
SP LPCG off control, offset: 0x110
◆ SP_LPCG_ON_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_LPCG_ON_CTRL
SP LPCG on control, offset: 0x2A0
◆ SP_PLL_OFF_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_PLL_OFF_CTRL
SP PLL off control, offset: 0x140
◆ SP_PLL_ON_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_PLL_ON_CTRL
SP PLL on control, offset: 0x270
◆ SP_POWER_OFF_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_POWER_OFF_CTRL
SP power off control, offset: 0x170
◆ SP_POWER_ON_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_POWER_ON_CTRL
SP power on control, offset: 0x240
◆ SP_PRIORITY_0_7
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_PRIORITY_0_7
SP0~7 Priority, offset: 0x40
◆ SP_PRIORITY_8_15
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_PRIORITY_8_15
SP8~15 Priority, offset: 0x44
◆ SP_RESET_EARLY_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_RESET_EARLY_CTRL
SP reset early control, offset: 0x160
◆ SP_RESET_LATE_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_RESET_LATE_CTRL
SP reset late control, offset: 0x250
◆ SP_ROOT_DOWN_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_ROOT_DOWN_CTRL
SP root down control, offset: 0x130
◆ SP_ROOT_UP_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_ROOT_UP_CTRL
SP root up control, offset: 0x280
◆ SP_ROSC_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_ROSC_CTRL
SP ROSC Control, offset: 0x1C
◆ SP_SSAR_RESTORE_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_SSAR_RESTORE_CTRL
SP SSAR restore control, offset: 0x2B0
◆ SP_SSAR_SAVE_CTRL
__IO uint32_t GPC_SET_POINT_CTRL_Type::SP_SSAR_SAVE_CTRL
SP SSAR save control, offset: 0x100
◆ SP_SYS_STAT
__I uint32_t GPC_SET_POINT_CTRL_Type::SP_SYS_STAT
SP System Status, offset: 0x14
◆ SR [1/6]
__IO uint32_t CSI_Type::SR
CSI Status Register, offset: 0x18
◆ SR [2/6]
__IO uint32_t GPT_Type::SR
GPT Status Register, offset: 0x8
◆ SR [3/6]
__IO uint32_t LPSPI_Type::SR
Status Register, offset: 0x14
◆ SR [4/6]
__IO uint32_t MU_Type::SR
Processor B Status Register, offset: 0x20
Processor A Status Register, offset: 0x20
◆ SR [5/6]
__IO uint32_t OTFAD_Type::SR
Status Register, offset: 0xC04
◆ SR [6/6]
__I uint32_t XRDC2_Type::SR
Status Register, offset: 0x4
◆  [1/3]
__IO uint32_t { ... } ::SRAM0
Description Address Register, array offset: 0x0, array step: 0x10
◆ SRAM0 [2/3]
__IO uint32_t SSARC_HP_Type::SRAM0
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::SRAM1
Description Data Register, array offset: 0x4, array step: 0x10
◆ SRAM1 [2/3]
__IO uint32_t SSARC_HP_Type::SRAM1
◆  [3/3]
◆  [1/3]
__IO uint32_t { ... } ::SRAM2
Description Control Register, array offset: 0x8, array step: 0x10
◆ SRAM2 [2/3]
__IO uint32_t SSARC_HP_Type::SRAM2
◆  [3/3]
◆ SRAMCR0
__IO uint32_t SEMC_Type::SRAMCR0
SRAM control register 0, offset: 0x70
SRAM Control Register 0, offset: 0x70
◆ SRAMCR1
__IO uint32_t SEMC_Type::SRAMCR1
SRAM control register 1, offset: 0x74
SRAM Control Register 1, offset: 0x74
◆ SRAMCR2
__IO uint32_t SEMC_Type::SRAMCR2
SRAM control register 2, offset: 0x78
SRAM Control Register 2, offset: 0x78
◆ SRAMCR3
uint32_t SEMC_Type::SRAMCR3
SRAM control register 3, offset: 0x7C
SRAM Control Register 3, offset: 0x7C
◆ SRAMCR4
__IO uint32_t SEMC_Type::SRAMCR4
SRAM Control Register 4, offset: 0x120
◆ SRAMCR5
__IO uint32_t SEMC_Type::SRAMCR5
SRAM Control Register 5, offset: 0x124
◆ SRAMCR6
__IO uint32_t SEMC_Type::SRAMCR6
SRAM Control Register 6, offset: 0x128
◆ SRCD
__IO uint32_t SPDIF_Type::SRCD
CDText Control Register, offset: 0x4
◆ SRCSH
__I uint32_t SPDIF_Type::SRCSH
SPDIFRxCChannel_h Register, offset: 0x1C
◆ SRCSL
__I uint32_t SPDIF_Type::SRCSL
SPDIFRxCChannel_l Register, offset: 0x20
◆ SRDR
__I uint32_t LPI2C_Type::SRDR
Slave Receive Data Register, offset: 0x170
Slave Receive Data, offset: 0x170
◆ SRFM
__I uint32_t SPDIF_Type::SRFM
FreqMeas Register, offset: 0x44
◆ SRK0
__IO uint32_t OCOTP_Type::SRK0
Shadow Register for OTP Bank3 Word0 (SRK Hash), offset: 0x580
◆ SRK1
__IO uint32_t OCOTP_Type::SRK1
Shadow Register for OTP Bank3 Word1 (SRK Hash), offset: 0x590
◆ SRK2
__IO uint32_t OCOTP_Type::SRK2
Shadow Register for OTP Bank3 Word2 (SRK Hash), offset: 0x5A0
◆ SRK3
__IO uint32_t OCOTP_Type::SRK3
Shadow Register for OTP Bank3 Word3 (SRK Hash), offset: 0x5B0
◆ SRK4
__IO uint32_t OCOTP_Type::SRK4
Shadow Register for OTP Bank3 Word4 (SRK Hash), offset: 0x5C0
◆ SRK5
__IO uint32_t OCOTP_Type::SRK5
Shadow Register for OTP Bank3 Word5 (SRK Hash), offset: 0x5D0
◆ SRK6
__IO uint32_t OCOTP_Type::SRK6
Shadow Register for OTP Bank3 Word6 (SRK Hash), offset: 0x5E0
◆ SRK7
__IO uint32_t OCOTP_Type::SRK7
Shadow Register for OTP Bank3 Word7 (SRK Hash), offset: 0x5F0
◆ SRK_REVOKE
__IO uint32_t OCOTP_Type::SRK_REVOKE
Value of OTP Bank5 Word7 (SRK Revoke), offset: 0x6F0
◆ SRL
__I uint32_t SPDIF_Type::SRL
SPDIFRxLeft Register, offset: 0x14
◆ SRMR
__IO uint32_t SRC_Type::SRMR
SRC Reset Mode Register, offset: 0x4
◆ SRPC
__IO uint32_t SPDIF_Type::SRPC
PhaseConfig Register, offset: 0x8
◆ SRQ
__I uint32_t SPDIF_Type::SRQ
QchannelRx Register, offset: 0x28
◆ SRR
__I uint32_t SPDIF_Type::SRR
SPDIFRxRight Register, offset: 0x18
◆ SRSR
__IO uint32_t SRC_Type::SRSR
SRC Reset Status Register, offset: 0x8
SRC Reset Status Register, offset: 0x10
◆ SRU
__I uint32_t SPDIF_Type::SRU
UchannelRx Register, offset: 0x24
◆ SSR
__IO uint32_t LPI2C_Type::SSR
Slave Status Register, offset: 0x114
Slave Status, offset: 0x114
◆ SSRT
__O uint8_t DMA_Type::SSRT
Set START Bit, offset: 0x1D
◆ STA
__I uint32_t IEE_Type::STA
IEE Status, offset: 0x4
◆ STAR
__IO uint32_t LPI2C_Type::STAR
Slave Transmit ACK Register, offset: 0x154
Slave Transmit ACK, offset: 0x154
◆ START
__O uint32_t CDOG_Type::START
START Command, offset: 0x20
◆ STAT [1/8]
__IO uint32_t DCP_Type::STAT
DCP status register, offset: 0x10
◆ STAT [2/8]
__I uint32_t LCDIF_Type::STAT
LCD Interface Status Register, offset: 0x1B0
◆ STAT [3/8]
__IO uint32_t LPUART_Type::STAT
LPUART Status Register, offset: 0x14
◆ STAT [4/8]
__IO uint32_t PXP_Type::STAT
◆ STAT [5/8]
__IO uint32_t ADC_Type::STAT
LPADC Status Register, offset: 0x14
◆ STAT [6/8]
__IO uint32_t PDM_Type::STAT
PDM Status register, offset: 0x8
◆ STAT [7/8]
__I uint32_t PUF_Type::STAT
PUF Status Register, offset: 0x20
◆ STAT [8/8]
__IO uint32_t RDC_Type::STAT
Status, offset: 0x24
◆ STAT_CLR [1/2]
__IO uint32_t DCP_Type::STAT_CLR
DCP status register, offset: 0x18
◆ STAT_CLR [2/2]
__IO uint32_t PXP_Type::STAT_CLR
◆ STAT_DISPLAY
__IO uint32_t SRC_Type::STAT_DISPLAY
Slice Status Register, offset: 0x230
◆ STAT_M4CORE
__IO uint32_t SRC_Type::STAT_M4CORE
Slice Status Register, offset: 0x290
◆ STAT_M4DEBUG
__IO uint32_t SRC_Type::STAT_M4DEBUG
Slice Status Register, offset: 0x2D0
◆ STAT_M7CORE
__IO uint32_t SRC_Type::STAT_M7CORE
Slice Status Register, offset: 0x2B0
◆ STAT_M7DEBUG
__IO uint32_t SRC_Type::STAT_M7DEBUG
Slice Status Register, offset: 0x2F0
◆ STAT_MEGA
__IO uint32_t SRC_Type::STAT_MEGA
Slice Status Register, offset: 0x210
◆ STAT_SET [1/2]
__IO uint32_t DCP_Type::STAT_SET
DCP status register, offset: 0x14
◆ STAT_SET [2/2]
__IO uint32_t PXP_Type::STAT_SET
◆ STAT_TOG [1/2]
__IO uint32_t DCP_Type::STAT_TOG
DCP status register, offset: 0x1C
◆ STAT_TOG [2/2]
__IO uint32_t PXP_Type::STAT_TOG
Status Register, offset: 0x1C
◆ STAT_USBPHY1
__IO uint32_t SRC_Type::STAT_USBPHY1
Slice Status Register, offset: 0x310
◆ STAT_USBPHY2
__IO uint32_t SRC_Type::STAT_USBPHY2
Slice Status Register, offset: 0x330
◆ STAT_WAKEUP
__IO uint32_t SRC_Type::STAT_WAKEUP
Slice Status Register, offset: 0x250
◆ STATFIFO
__I uint32_t CSI_Type::STATFIFO
CSI Statistic FIFO Register, offset: 0xC
◆ STATUS [1/5]
__IO uint32_t BEE_Type::STATUS
◆ STATUS [2/5]
__I uint32_t TRNG_Type::STATUS
Status Register, offset: 0x3C
◆ STATUS [3/5]
__IO uint32_t USBPHY_Type::STATUS
USB PHY Status Register, offset: 0x40
◆ STATUS [4/5]
__I uint32_t CDOG_Type::STATUS
Status 1, offset: 0x10
◆ STATUS [5/5]
__I uint32_t USBHSDCD_Type::STATUS
◆ STATUS0 [1/14]
__I uint32_t CCM_Type::STATUS0
Clock root working status, array offset: 0x20, array step: 0x80
Clock source working status, array offset: 0x5010, array step: 0x20
LPCG working status, array offset: 0x6010, array step: 0x20
◆  [2/14]
__I uint32_t { ... } ::STATUS0
◆  [3/14]
__IO uint32_t { ... } ::STATUS0
Clock group working status, array offset: 0x4020, array step: 0x80
◆ STATUS0 [4/14]
__IO uint32_t CCM_Type::STATUS0
◆  [5/14]
◆  [6/14]
◆  [7/14]
Observe status, array offset: 0x20, array step: 0x80
◆ STATUS0 [8/14]
__I uint32_t CCM_OBS_Type::STATUS0
◆ STATUS0 [9/14]
__IO uint32_t TMPSNS_Type::STATUS0
Temperature Sensor Status Register 0, offset: 0x50
◆  [10/14]
◆  [11/14]
◆  [12/14]
◆  [13/14]
◆  [14/14]
◆  [1/9]
__I uint32_t { ... } ::STATUS1
Clock root low power status, array offset: 0x24, array step: 0x80
◆ STATUS1 [2/9]
__I uint32_t CCM_Type::STATUS1
Clock group low power/extend status, array offset: 0x4024, array step: 0x80
Clock source low power status, array offset: 0x5014, array step: 0x20
LPCG low power status, array offset: 0x6014, array step: 0x20
◆  [3/9]
◆  [4/9]
◆  [5/9]
◆  [6/9]
◆  [7/9]
◆  [8/9]
◆  [9/9]
◆ STATUS2
__I uint32_t CDOG_Type::STATUS2
Status 2, offset: 0x14
◆ STBY_AUTHEN_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_AUTHEN_CTRL
Standby Authentication Control, offset: 0x4
◆ STBY_BANDGAP_IN_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_BANDGAP_IN_CTRL
STBY bandgap_in control, offset: 0x128
◆ STBY_BANDGAP_OUT_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_BANDGAP_OUT_CTRL
STBY bandgap out control, offset: 0x230
◆ STBY_BIAS_IN_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_BIAS_IN_CTRL
STBY bias_in control, offset: 0x110
◆ STBY_BIAS_OUT_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_BIAS_OUT_CTRL
STBY bias out control, offset: 0x240
◆ STBY_DCDC_IN_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_DCDC_IN_CTRL
STBY dcdc_in control, offset: 0x140
◆ STBY_DCDC_OUT_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_DCDC_OUT_CTRL
STBY DCDC out control, offset: 0x210
◆ STBY_LDO_IN_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_LDO_IN_CTRL
STBY ldo_in control, offset: 0x130
◆ STBY_LDO_OUT_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_LDO_OUT_CTRL
STBY LDO out control, offset: 0x220
◆ STBY_LPCG_IN_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_LPCG_IN_CTRL
STBY lpcg_in control, offset: 0xF0
◆ STBY_LPCG_OUT_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_LPCG_OUT_CTRL
STBY LPCG out control, offset: 0x260
◆ STBY_MISC
__IO uint32_t GPC_STBY_CTRL_Type::STBY_MISC
STBY Misc, offset: 0xC
◆ STBY_PLDO_IN_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PLDO_IN_CTRL
STBY pldo_in control, offset: 0x120
◆ STBY_PLDO_OUT_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PLDO_OUT_CTRL
STBY pldo out control, offset: 0x238
◆ STBY_PLL_IN_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PLL_IN_CTRL
STBY pll_in control, offset: 0x100
◆ STBY_PLL_OUT_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PLL_OUT_CTRL
STBY PLL out control, offset: 0x250
◆ STBY_PMIC_IN_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PMIC_IN_CTRL
STBY PMIC in control, offset: 0x150
◆ STBY_PMIC_OUT_CTRL
__IO uint32_t GPC_STBY_CTRL_Type::STBY_PMIC_OUT_CTRL
STBY PMIC out control, offset: 0x200
◆ STC
__IO uint32_t SPDIF_Type::STC
SPDIFTxClk Register, offset: 0x50
◆ STCSCH
__IO uint32_t SPDIF_Type::STCSCH
SPDIFTxCChannelCons_h Register, offset: 0x34
◆ STCSCL
__IO uint32_t SPDIF_Type::STCSCL
SPDIFTxCChannelCons_l Register, offset: 0x38
◆ STDR
__O uint32_t LPI2C_Type::STDR
Slave Transmit Data Register, offset: 0x160
Slave Transmit Data, offset: 0x160
◆ STL
__O uint32_t SPDIF_Type::STL
SPDIFTxLeft Register, offset: 0x2C
◆ STOP
__O uint32_t CDOG_Type::STOP
STOP Command, offset: 0x24
◆ STR
__O uint32_t SPDIF_Type::STR
SPDIFTxRight Register, offset: 0x30
◆ STROBE_DLL_CTRL
__IO uint32_t USDHC_Type::STROBE_DLL_CTRL
Strobe DLL control, offset: 0x70
◆ STROBE_DLL_STATUS
__I uint32_t USDHC_Type::STROBE_DLL_STATUS
Strobe DLL status, offset: 0x74
◆ STS [1/4]
__IO uint16_t PWM_Type::STS
Status Register, array offset: 0x24, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::STS
◆  [3/4]
◆  [4/4]
◆ STS0 [1/2]
__I uint32_t FLEXSPI_Type::STS0
Status Register 0, offset: 0xE0
◆ STS0 [2/2]
__I uint32_t SEMC_Type::STS0
Status register 0, offset: 0xC0
Status Register 0, offset: 0xC0
◆ STS1 [1/2]
__I uint32_t FLEXSPI_Type::STS1
Status Register 1, offset: 0xE4
◆ STS1 [2/2]
uint32_t SEMC_Type::STS1
Status register 1, offset: 0xC4
Status Register 1, offset: 0xC4
◆ STS10
uint32_t SEMC_Type::STS10
Status register 10, offset: 0xE8
Status Register 10, offset: 0xE8
◆ STS11
uint32_t SEMC_Type::STS11
Status register 11, offset: 0xEC
Status Register 11, offset: 0xEC
◆ STS12
__I uint32_t SEMC_Type::STS12
Status register 12, offset: 0xF0
Status Register 12, offset: 0xF0
◆ STS13 [1/2]
__I uint32_t SEMC_Type::STS13
Status register 13, offset: 0xF4
Status Register 13, offset: 0xF4
◆ STS13 [2/2]
◆ STS14
uint32_t SEMC_Type::STS14
Status register 14, offset: 0xF8
Status Register 14, offset: 0xF8
◆ STS15
uint32_t SEMC_Type::STS15
Status register 15, offset: 0xFC
Status Register 15, offset: 0xFC
◆ STS2 [1/2]
__I uint32_t FLEXSPI_Type::STS2
Status Register 2, offset: 0xE8
◆ STS2 [2/2]
__I uint32_t SEMC_Type::STS2
Status register 2, offset: 0xC8
Status Register 2, offset: 0xC8
◆ STS3
uint32_t SEMC_Type::STS3
Status register 3, offset: 0xCC
Status Register 3, offset: 0xCC
◆ STS4
uint32_t SEMC_Type::STS4
Status register 4, offset: 0xD0
Status Register 4, offset: 0xD0
◆ STS5
uint32_t SEMC_Type::STS5
Status register 5, offset: 0xD4
Status Register 5, offset: 0xD4
◆ STS6
uint32_t SEMC_Type::STS6
Status register 6, offset: 0xD8
Status Register 6, offset: 0xD8
◆ STS7
uint32_t SEMC_Type::STS7
Status register 7, offset: 0xDC
Status Register 7, offset: 0xDC
◆ STS8
uint32_t SEMC_Type::STS8
Status register 8, offset: 0xE0
Status Register 8, offset: 0xE0
◆ STS9
uint32_t SEMC_Type::STS9
Status register 9, offset: 0xE4
Status Register 9, offset: 0xE4
◆ SUB
__O uint32_t CDOG_Type::SUB
SUB Command, offset: 0x3C
◆ SUB1
__O uint32_t CDOG_Type::SUB1
SUB1 Command, offset: 0x40
◆ SUB16
__O uint32_t CDOG_Type::SUB16
SUB16 Command, offset: 0x44
◆ SUB256
__O uint32_t CDOG_Type::SUB256
SUB256 Command, offset: 0x48
◆ SW_GP1
__IO uint32_t OCOTP_Type::SW_GP1
Value of OTP Bank5 Word0 (SW GP1), offset: 0x680
◆ SW_GP20
__IO uint32_t OCOTP_Type::SW_GP20
Value of OTP Bank5 Word1 (SW GP2), offset: 0x690
◆ SW_GP21
__IO uint32_t OCOTP_Type::SW_GP21
Value of OTP Bank5 Word2 (SW GP2), offset: 0x6A0
◆ SW_GP22
__IO uint32_t OCOTP_Type::SW_GP22
Value of OTP Bank5 Word3 (SW GP2), offset: 0x6B0
◆ SW_GP23
__IO uint32_t OCOTP_Type::SW_GP23
Value of OTP Bank5 Word4 (SW GP2), offset: 0x6C0
◆ SW_GROUP_PENDING
__I uint32_t SSARC_LP_Type::SW_GROUP_PENDING
Software Request Pending Register, offset: 0x220
◆ SW_LOCK
__IO uint32_t OCOTP_Type::SW_LOCK
SW_LOCK Register, offset: 0x140
◆ SW_MUX_CTL_PAD [1/2]
__IO uint32_t IOMUXC_Type::SW_MUX_CTL_PAD
SW_MUX_CTL_PAD_GPIO_EMC_00 SW MUX Control Register..SW_MUX_CTL_PAD_GPIO_SD_B1_11 SW MUX Control Register, array offset: 0x14, array step: 0x4
SW_MUX_CTL_PAD_GPIO_EMC_B1_00 SW MUX Control Register..SW_MUX_CTL_PAD_GPIO_DISP_B2_15 SW MUX Control Register, array offset: 0x10, array step: 0x4
◆ SW_MUX_CTL_PAD [2/2]
__IO uint32_t IOMUXC_LPSR_Type::SW_MUX_CTL_PAD
SW_MUX_CTL_PAD_GPIO_LPSR_00 SW MUX Control Register..SW_MUX_CTL_PAD_GPIO_LPSR_15 SW MUX Control Register, array offset: 0x0, array step: 0x4
◆ SW_MUX_CTL_PAD_GPIO_SNVS_00_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_00_DIG
SW_MUX_CTL_PAD_GPIO_SNVS_00_DIG SW MUX Control Register, offset: 0xC
◆ SW_MUX_CTL_PAD_GPIO_SNVS_01_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_01_DIG
SW_MUX_CTL_PAD_GPIO_SNVS_01_DIG SW MUX Control Register, offset: 0x10
◆ SW_MUX_CTL_PAD_GPIO_SNVS_02_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_02_DIG
SW_MUX_CTL_PAD_GPIO_SNVS_02_DIG SW MUX Control Register, offset: 0x14
◆ SW_MUX_CTL_PAD_GPIO_SNVS_03_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_03_DIG
SW_MUX_CTL_PAD_GPIO_SNVS_03_DIG SW MUX Control Register, offset: 0x18
◆ SW_MUX_CTL_PAD_GPIO_SNVS_04_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_04_DIG
SW_MUX_CTL_PAD_GPIO_SNVS_04_DIG SW MUX Control Register, offset: 0x1C
◆ SW_MUX_CTL_PAD_GPIO_SNVS_05_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_05_DIG
SW_MUX_CTL_PAD_GPIO_SNVS_05_DIG SW MUX Control Register, offset: 0x20
◆ SW_MUX_CTL_PAD_GPIO_SNVS_06_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_06_DIG
SW_MUX_CTL_PAD_GPIO_SNVS_06_DIG SW MUX Control Register, offset: 0x24
◆ SW_MUX_CTL_PAD_GPIO_SNVS_07_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_07_DIG
SW_MUX_CTL_PAD_GPIO_SNVS_07_DIG SW MUX Control Register, offset: 0x28
◆ SW_MUX_CTL_PAD_GPIO_SNVS_08_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_08_DIG
SW_MUX_CTL_PAD_GPIO_SNVS_08_DIG SW MUX Control Register, offset: 0x2C
◆ SW_MUX_CTL_PAD_GPIO_SNVS_09_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_GPIO_SNVS_09_DIG
SW_MUX_CTL_PAD_GPIO_SNVS_09_DIG SW MUX Control Register, offset: 0x30
◆ SW_MUX_CTL_PAD_PMIC_ON_REQ
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_PMIC_ON_REQ
SW_MUX_CTL_PAD_PMIC_ON_REQ SW MUX Control Register, offset: 0x4
◆ SW_MUX_CTL_PAD_PMIC_ON_REQ_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_PMIC_ON_REQ_DIG
SW_MUX_CTL_PAD_PMIC_ON_REQ_DIG SW MUX Control Register, offset: 0x4
◆ SW_MUX_CTL_PAD_PMIC_STBY_REQ
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_PMIC_STBY_REQ
SW_MUX_CTL_PAD_PMIC_STBY_REQ SW MUX Control Register, offset: 0x8
◆ SW_MUX_CTL_PAD_PMIC_STBY_REQ_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_PMIC_STBY_REQ_DIG
SW_MUX_CTL_PAD_PMIC_STBY_REQ_DIG SW MUX Control Register, offset: 0x8
◆ SW_MUX_CTL_PAD_WAKEUP
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_WAKEUP
SW_MUX_CTL_PAD_WAKEUP SW MUX Control Register, offset: 0x0
◆ SW_MUX_CTL_PAD_WAKEUP_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_MUX_CTL_PAD_WAKEUP_DIG
SW_MUX_CTL_PAD_WAKEUP_DIG SW MUX Control Register, offset: 0x0
◆ SW_PAD_CTL_PAD [1/2]
__IO uint32_t IOMUXC_Type::SW_PAD_CTL_PAD
SW_PAD_CTL_PAD_GPIO_EMC_00 SW PAD Control Register..SW_PAD_CTL_PAD_GPIO_SD_B1_11 SW PAD Control Register, array offset: 0x204, array step: 0x4
SW_PAD_CTL_PAD_GPIO_EMC_B1_00 SW PAD Control Register..SW_PAD_CTL_PAD_GPIO_DISP_B2_15 SW PAD Control Register, array offset: 0x254, array step: 0x4
◆ SW_PAD_CTL_PAD [2/2]
__IO uint32_t IOMUXC_LPSR_Type::SW_PAD_CTL_PAD
SW_PAD_CTL_PAD_GPIO_LPSR_00 SW PAD Control Register..SW_PAD_CTL_PAD_GPIO_LPSR_15 SW PAD Control Register, array offset: 0x40, array step: 0x4
◆ SW_PAD_CTL_PAD_GPIO_SNVS_00_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_00_DIG
SW_PAD_CTL_PAD_GPIO_SNVS_00_DIG SW PAD Control Register, offset: 0x4C
◆ SW_PAD_CTL_PAD_GPIO_SNVS_01_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_01_DIG
SW_PAD_CTL_PAD_GPIO_SNVS_01_DIG SW PAD Control Register, offset: 0x50
◆ SW_PAD_CTL_PAD_GPIO_SNVS_02_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_02_DIG
SW_PAD_CTL_PAD_GPIO_SNVS_02_DIG SW PAD Control Register, offset: 0x54
◆ SW_PAD_CTL_PAD_GPIO_SNVS_03_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_03_DIG
SW_PAD_CTL_PAD_GPIO_SNVS_03_DIG SW PAD Control Register, offset: 0x58
◆ SW_PAD_CTL_PAD_GPIO_SNVS_04_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_04_DIG
SW_PAD_CTL_PAD_GPIO_SNVS_04_DIG SW PAD Control Register, offset: 0x5C
◆ SW_PAD_CTL_PAD_GPIO_SNVS_05_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_05_DIG
SW_PAD_CTL_PAD_GPIO_SNVS_05_DIG SW PAD Control Register, offset: 0x60
◆ SW_PAD_CTL_PAD_GPIO_SNVS_06_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_06_DIG
SW_PAD_CTL_PAD_GPIO_SNVS_06_DIG SW PAD Control Register, offset: 0x64
◆ SW_PAD_CTL_PAD_GPIO_SNVS_07_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_07_DIG
SW_PAD_CTL_PAD_GPIO_SNVS_07_DIG SW PAD Control Register, offset: 0x68
◆ SW_PAD_CTL_PAD_GPIO_SNVS_08_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_08_DIG
SW_PAD_CTL_PAD_GPIO_SNVS_08_DIG SW PAD Control Register, offset: 0x6C
◆ SW_PAD_CTL_PAD_GPIO_SNVS_09_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_GPIO_SNVS_09_DIG
SW_PAD_CTL_PAD_GPIO_SNVS_09_DIG SW PAD Control Register, offset: 0x70
◆ SW_PAD_CTL_PAD_ONOFF
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_ONOFF
SW_PAD_CTL_PAD_ONOFF SW PAD Control Register, offset: 0x14
◆ SW_PAD_CTL_PAD_ONOFF_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_ONOFF_DIG
SW_PAD_CTL_PAD_ONOFF_DIG SW PAD Control Register, offset: 0x3C
◆ SW_PAD_CTL_PAD_PMIC_ON_REQ
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_PMIC_ON_REQ
SW_PAD_CTL_PAD_PMIC_ON_REQ SW PAD Control Register, offset: 0x1C
◆ SW_PAD_CTL_PAD_PMIC_ON_REQ_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_PMIC_ON_REQ_DIG
SW_PAD_CTL_PAD_PMIC_ON_REQ_DIG SW PAD Control Register, offset: 0x44
◆ SW_PAD_CTL_PAD_PMIC_STBY_REQ
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_PMIC_STBY_REQ
SW_PAD_CTL_PAD_PMIC_STBY_REQ SW PAD Control Register, offset: 0x20
◆ SW_PAD_CTL_PAD_PMIC_STBY_REQ_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_PMIC_STBY_REQ_DIG
SW_PAD_CTL_PAD_PMIC_STBY_REQ_DIG SW PAD Control Register, offset: 0x48
◆ SW_PAD_CTL_PAD_POR_B
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_POR_B
SW_PAD_CTL_PAD_POR_B SW PAD Control Register, offset: 0x10
◆ SW_PAD_CTL_PAD_POR_B_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_POR_B_DIG
SW_PAD_CTL_PAD_POR_B_DIG SW PAD Control Register, offset: 0x38
◆ SW_PAD_CTL_PAD_TEST_MODE
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_TEST_MODE
SW_PAD_CTL_PAD_TEST_MODE SW PAD Control Register, offset: 0xC
◆ SW_PAD_CTL_PAD_TEST_MODE_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_TEST_MODE_DIG
SW_PAD_CTL_PAD_TEST_MODE_DIG SW PAD Control Register, offset: 0x34
◆ SW_PAD_CTL_PAD_WAKEUP
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_WAKEUP
SW_PAD_CTL_PAD_WAKEUP SW PAD Control Register, offset: 0x18
◆ SW_PAD_CTL_PAD_WAKEUP_DIG
__IO uint32_t IOMUXC_SNVS_Type::SW_PAD_CTL_PAD_WAKEUP_DIG
SW_PAD_CTL_PAD_WAKEUP_DIG SW PAD Control Register, offset: 0x40
◆ SW_STICKY
__IO uint32_t OCOTP_Type::SW_STICKY
Sticky bit Register, offset: 0x50
◆ SWCOUT
__IO uint16_t PWM_Type::SWCOUT
Software Controlled Output Register, offset: 0x184
◆ SWTRIG
__O uint32_t ADC_Type::SWTRIG
Software Trigger Register, offset: 0x34
◆ SYS_CTRL
__IO uint32_t USDHC_Type::SYS_CTRL
System Control, offset: 0x2C
◆ SYS_PLL1_CTRL
__IO uint32_t ANADIG_PLL_Type::SYS_PLL1_CTRL
SYS_PLL1_CTRL_REGISTER, offset: 0x2C0
◆ SYS_PLL1_DENOMINATOR
__IO uint32_t ANADIG_PLL_Type::SYS_PLL1_DENOMINATOR
SYS_PLL1_DENOMINATOR_REGISTER, offset: 0x2D0
◆ SYS_PLL1_DIV_SELECT
__IO uint32_t ANADIG_PLL_Type::SYS_PLL1_DIV_SELECT
SYS_PLL1_DIV_SELECT_REGISTER, offset: 0x2F0
◆ SYS_PLL1_NUMERATOR
__IO uint32_t ANADIG_PLL_Type::SYS_PLL1_NUMERATOR
SYS_PLL1_NUMERATOR_REGISTER, offset: 0x2E0
◆ SYS_PLL1_SS
__IO uint32_t ANADIG_PLL_Type::SYS_PLL1_SS
SYS_PLL1_SS_REGISTER, offset: 0x2B0
◆ SYS_PLL2_CTRL
__IO uint32_t ANADIG_PLL_Type::SYS_PLL2_CTRL
SYS_PLL2_CTRL_REGISTER, offset: 0x240
◆ SYS_PLL2_MFD
__IO uint32_t ANADIG_PLL_Type::SYS_PLL2_MFD
SYS_PLL2_MFD_REGISTER, offset: 0x2A0
◆ SYS_PLL2_PFD
__IO uint32_t ANADIG_PLL_Type::SYS_PLL2_PFD
SYS_PLL2_PFD_REGISTER, offset: 0x270
◆ SYS_PLL2_SS
__IO uint32_t ANADIG_PLL_Type::SYS_PLL2_SS
SYS_PLL2_SS_REGISTER, offset: 0x260
◆ SYS_PLL2_UPDATE
__IO uint32_t ANADIG_PLL_Type::SYS_PLL2_UPDATE
SYS_PLL2_UPDATE_REGISTER, offset: 0x250
◆ SYS_PLL3_CTRL
__IO uint32_t ANADIG_PLL_Type::SYS_PLL3_CTRL
SYS_PLL3_CTRL_REGISTER, offset: 0x210
◆ SYS_PLL3_PFD
__IO uint32_t ANADIG_PLL_Type::SYS_PLL3_PFD
SYS_PLL3_PFD_REGISTER, offset: 0x230
◆ SYS_PLL3_UPDATE
__IO uint32_t ANADIG_PLL_Type::SYS_PLL3_UPDATE
SYS_PLL3_UPDATE_REGISTER, offset: 0x220
◆ TACC
__IO uint32_t ENET_Type::TACC
Transmit Accelerator Function Configuration, offset: 0x1C0
◆ TAEM
__IO uint32_t ENET_Type::TAEM
Transmit FIFO Almost Empty Threshold, offset: 0x1A4
◆ TAFL
__IO uint32_t ENET_Type::TAFL
Transmit FIFO Almost Full Threshold, offset: 0x1A8
◆  [1/4]
__IO uint32_t { ... } ::TCCR
Timer Compare Capture Register, array offset: 0x60C, array step: 0x8
◆ TCCR [2/4]
__IO uint32_t ENET_Type::TCCR
◆  [3/4]
◆  [4/4]
◆ TCM_CTRL
__IO uint32_t FLEXRAM_Type::TCM_CTRL
TCM CRTL Register, offset: 0x0
◆ TCR [1/2]
__IO uint32_t ENET_Type::TCR
Transmit Control Register, offset: 0xC4
◆ TCR [2/2]
__IO uint32_t LPSPI_Type::TCR
Transmit Command Register, offset: 0x60
Transmit Command, offset: 0x60
◆ TCR1
__IO uint32_t I2S_Type::TCR1
SAI Transmit Configuration 1 Register, offset: 0xC
Transmit Configuration 1, offset: 0xC
◆ TCR2
__IO uint32_t I2S_Type::TCR2
SAI Transmit Configuration 2 Register, offset: 0x10
Transmit Configuration 2, offset: 0x10
◆ TCR3
__IO uint32_t I2S_Type::TCR3
SAI Transmit Configuration 3 Register, offset: 0x14
Transmit Configuration 3, offset: 0x14
◆ TCR4
__IO uint32_t I2S_Type::TCR4
SAI Transmit Configuration 4 Register, offset: 0x18
Transmit Configuration 4, offset: 0x18
◆ TCR5
__IO uint32_t I2S_Type::TCR5
SAI Transmit Configuration 5 Register, offset: 0x1C
Transmit Configuration 5, offset: 0x1C
◆ TCSR [1/5]
__IO uint32_t ENET_Type::TCSR
Timer Control Status Register, array offset: 0x608, array step: 0x8
◆  [2/5]
__IO uint32_t { ... } ::TCSR
◆ TCSR [3/5]
__IO uint32_t I2S_Type::TCSR
SAI Transmit Control Register, offset: 0x8
Transmit Control, offset: 0x8
◆  [4/5]
◆  [5/5]
◆  [1/9]
__IO uint32_t { ... } ::TCTRL
Timer Control Register, array offset: 0x108, array step: 0x10
◆ TCTRL [2/9]
__IO uint32_t PIT_Type::TCTRL
◆ TCTRL [3/9]
__IO uint16_t PWM_Type::TCTRL
Output Trigger Control Register, array offset: 0x2A, array step: 0x60
◆  [4/9]
__IO uint16_t { ... } ::TCTRL
◆ TCTRL [5/9]
__IO uint32_t ADC_Type::TCTRL
Trigger Control Register, array offset: 0xC0, array step: 0x4
◆  [6/9]
◆  [7/9]
◆  [8/9]
◆  [9/9]
◆ TDAR
__IO uint32_t ENET_Type::TDAR
Transmit Descriptor Active Register - Ring 0, offset: 0x14
◆ TDAR1
__IO uint32_t ENET_Type::TDAR1
Transmit Descriptor Active Register - Ring 1, offset: 0x1E4
◆ TDAR2
__IO uint32_t ENET_Type::TDAR2
Transmit Descriptor Active Register - Ring 2, offset: 0x1EC
◆ TDKEKR
__IO uint32_t CAAM_Type::TDKEKR
Trusted Descriptor Key Encryption Key Register, array offset: 0x420, array step: 0x4
◆ TDR [1/2]
__O uint32_t I2S_Type::TDR
SAI Transmit Data Register, array offset: 0x20, array step: 0x4
Transmit Data, array offset: 0x20, array step: 0x4
◆ TDR [2/2]
__O uint32_t LPSPI_Type::TDR
Transmit Data Register, offset: 0x64
Transmit Data, offset: 0x64
◆ TDSKR
__IO uint32_t CAAM_Type::TDSKR
Trusted Descriptor Signing Key Register, array offset: 0x440, array step: 0x4
◆ TDSR
__IO uint32_t ENET_Type::TDSR
Transmit Buffer Descriptor Ring 0 Start Register, offset: 0x184
◆ TDSR1
__IO uint32_t ENET_Type::TDSR1
Transmit Buffer Descriptor Ring 1 Start Register, offset: 0x164
◆ TDSR2
__IO uint32_t ENET_Type::TDSR2
Transmit Buffer Descriptor Ring 2 Start Register, offset: 0x170
◆ TEMPSENSE0
__IO uint32_t TEMPMON_Type::TEMPSENSE0
Tempsensor Control Register 0, offset: 0x180
◆ TEMPSENSE0_CLR
__IO uint32_t TEMPMON_Type::TEMPSENSE0_CLR
Tempsensor Control Register 0, offset: 0x188
◆ TEMPSENSE0_SET
__IO uint32_t TEMPMON_Type::TEMPSENSE0_SET
Tempsensor Control Register 0, offset: 0x184
◆ TEMPSENSE0_TOG
__IO uint32_t TEMPMON_Type::TEMPSENSE0_TOG
Tempsensor Control Register 0, offset: 0x18C
◆ TEMPSENSE1
__IO uint32_t TEMPMON_Type::TEMPSENSE1
Tempsensor Control Register 1, offset: 0x190
◆ TEMPSENSE1_CLR
__IO uint32_t TEMPMON_Type::TEMPSENSE1_CLR
Tempsensor Control Register 1, offset: 0x198
◆ TEMPSENSE1_SET
__IO uint32_t TEMPMON_Type::TEMPSENSE1_SET
Tempsensor Control Register 1, offset: 0x194
◆ TEMPSENSE1_TOG
__IO uint32_t TEMPMON_Type::TEMPSENSE1_TOG
Tempsensor Control Register 1, offset: 0x19C
◆ TEMPSENSE2
__IO uint32_t TEMPMON_Type::TEMPSENSE2
Tempsensor Control Register 2, offset: 0x290
◆ TEMPSENSE2_CLR
__IO uint32_t TEMPMON_Type::TEMPSENSE2_CLR
Tempsensor Control Register 2, offset: 0x298
◆ TEMPSENSE2_SET
__IO uint32_t TEMPMON_Type::TEMPSENSE2_SET
Tempsensor Control Register 2, offset: 0x294
◆ TEMPSENSE2_TOG
__IO uint32_t TEMPMON_Type::TEMPSENSE2_TOG
Tempsensor Control Register 2, offset: 0x29C
◆ TEMPSENSOR
__IO uint32_t ANADIG_TEMPSENSOR_Type::TEMPSENSOR
Tempsensor Register, offset: 0x400
◆ TEMPSNS_OTP_TRIM_VALUE
__I uint32_t ANADIG_TEMPSENSOR_Type::TEMPSNS_OTP_TRIM_VALUE
TEMPSNS_OTP_TRIM_VALUE_REGISTER, offset: 0x430
◆ TFDR
__O uint32_t FLEXSPI_Type::TFDR
IP TX FIFO Data Register 0..IP TX FIFO Data Register 31, array offset: 0x180, array step: 0x4
◆ TFLG [1/4]
__IO uint32_t PIT_Type::TFLG
Timer Flag Register, array offset: 0x10C, array step: 0x10
◆  [2/4]
__IO uint32_t { ... } ::TFLG
◆  [3/4]
◆  [4/4]
◆ TFR
__I uint32_t I2S_Type::TFR
SAI Transmit FIFO Register, array offset: 0x40, array step: 0x4
Transmit FIFO, array offset: 0x40, array step: 0x4
◆ TFWR
__IO uint32_t ENET_Type::TFWR
Transmit FIFO Watermark Register, offset: 0x144
◆ TGSR
__IO uint32_t ENET_Type::TGSR
Timer Global Status Register, offset: 0x604
◆ THRES
__IO uint32_t LCDIF_Type::THRES
LCDIF Threshold Register, offset: 0x200
◆ TIMCFG
__IO uint32_t FLEXIO_Type::TIMCFG
Timer Configuration N Register, array offset: 0x480, array step: 0x4
◆ TIMCMP
__IO uint32_t FLEXIO_Type::TIMCMP
Timer Compare N Register, array offset: 0x500, array step: 0x4
◆ TIMCTL
__IO uint32_t FLEXIO_Type::TIMCTL
Timer Control N Register, array offset: 0x400, array step: 0x4
◆ TIMER
__IO uint32_t CAN_Type::TIMER
Free Running Timer Register, offset: 0x8
Free Running Timer, offset: 0x8
◆ TIMER0
__IO uint32_t USBHSDCD_Type::TIMER0
TIMER0 register, offset: 0x10
◆ TIMER1
__IO uint32_t USBHSDCD_Type::TIMER1
TIMER1 register, offset: 0x14
◆ TIMER2_BC11 [1/3]
__IO uint32_t USBHSDCD_Type::TIMER2_BC11
TIMER2_BC11 register, offset: 0x18
◆  [2/3]
__IO uint32_t { ... } ::TIMER2_BC11
◆  [3/3]
◆ TIMER2_BC12 [1/3]
__IO uint32_t USBHSDCD_Type::TIMER2_BC12
TIMER2_BC12 register, offset: 0x18
◆  [2/3]
__IO uint32_t { ... } ::TIMER2_BC12
◆  [3/3]
◆ TIMERSDEN
__IO uint32_t FLEXIO_Type::TIMERSDEN
Timer Status DMA Enable, offset: 0x38
◆ TIMIEN
__IO uint32_t FLEXIO_Type::TIMIEN
Timer Interrupt Enable Register, offset: 0x28
◆ TIMING
__IO uint32_t OCOTP_Type::TIMING
OTP Controller Timing Register, offset: 0x10
◆ TIMING2
__IO uint32_t OCOTP_Type::TIMING2
OTP Controller Timing Register 2, offset: 0x100
◆ TIMSTAT
__IO uint32_t FLEXIO_Type::TIMSTAT
Timer Status Register, offset: 0x18
◆ TIPG
__IO uint32_t ENET_Type::TIPG
Transmit Inter-Packet Gap, offset: 0x1AC
◆ TMR
__IO uint32_t I2S_Type::TMR
SAI Transmit Mask Register, offset: 0x60
Transmit Mask, offset: 0x60
◆ TOG [1/69]
__IO uint32_t AUDIO_PLL_Type::TOG
Fractional PLL Control Register, offset: 0xC
Fractional PLL Spread Spectrum Control Register, offset: 0x1C
Fractional PLL Numerator Control Register, offset: 0x2C
Fractional PLL Denominator Control Register, offset: 0x3C
◆  [2/69]
__IO uint32_t { ... } ::TOG
◆  [3/69]
◆  [4/69]
◆  [5/69]
◆  [6/69]
General Purpose Register, array offset: 0x480C, array step: 0x20
◆ TOG [7/69]
__IO uint32_t CCM_Type::TOG
◆  [8/69]
◆ TOG [9/69]
__IO uint32_t ETHERNET_PLL_Type::TOG
◆  [10/69]
◆  [11/69]
◆  [12/69]
◆ TOG [13/69]
__IO uint32_t OSC_RC_400M_Type::TOG
Control Register 0, offset: 0xC
Control Register 1, offset: 0x1C
Control Register 2, offset: 0x2C
Control Register 3, offset: 0x3C
◆  [14/69]
◆  [15/69]
◆  [16/69]
◆  [17/69]
◆ TOG [18/69]
__I uint32_t OSC_RC_400M_Type::TOG
Status Register 0, offset: 0x5C
Status Register 1, offset: 0x6C
Status Register 2, offset: 0x7C
◆  [19/69]
__I uint32_t { ... } ::TOG
◆  [20/69]
◆  [21/69]
◆  [22/69]
Analog Control Register CTRL0, offset: 0xC
◆ TOG [23/69]
__IO uint32_t PHY_LDO_Type::TOG
◆ TOG [24/69]
__I uint32_t PHY_LDO_Type::TOG
Analog Status Register STAT0, offset: 0x5C
◆  [25/69]
◆ TOG [26/69]
__IO uint32_t VIDEO_MUX_Type::TOG
Video mux Control Register, offset: 0xC
Pixel Link Master(PLM) Control Register, offset: 0x2C
YUV420 Control Register, offset: 0x3C
Data Disable Register, offset: 0x5C
MIPI DSI Control Register, offset: 0x7C
◆  [27/69]
◆  [28/69]
◆  [29/69]
◆  [30/69]
◆  [31/69]
◆ TOG [32/69]
__IO uint32_t VIDEO_PLL_Type::TOG
◆  [33/69]
◆  [34/69]
◆  [35/69]
◆  [36/69]
◆  [37/69]
◆ TOG [38/69]
__IO uint32_t VMBANDGAP_Type::TOG
◆ TOG [39/69]
__I uint32_t VMBANDGAP_Type::TOG
◆  [40/69]
◆  [41/69]
◆  [42/69]
◆  [43/69]
◆  [44/69]
◆  [45/69]
◆  [46/69]
◆  [47/69]
◆  [48/69]
◆  [49/69]
◆  [50/69]
◆  [51/69]
◆  [52/69]
◆  [53/69]
◆  [54/69]
◆  [55/69]
◆  [56/69]
◆  [57/69]
◆  [58/69]
◆  [59/69]
◆  [60/69]
◆  [61/69]
◆  [62/69]
◆  [63/69]
◆  [64/69]
◆  [65/69]
◆  [66/69]
◆  [67/69]
◆  [68/69]
◆  [69/69]
◆ TOTSAM [1/2]
__I uint32_t TRNG_Type::TOTSAM
Total Samples Register, offset: 0x14
◆  [2/2]
__I uint32_t { ... } ::TOTSAM
◆ TOVAL
__IO uint32_t RTWDOG_Type::TOVAL
Watchdog Timeout Value Register, offset: 0x8
◆ TR
__IO uint32_t MU_Type::TR
Processor B Transmit Register 0..Processor B Transmit Register 3, array offset: 0x0, array step: 0x4
Processor A Transmit Register 0..Processor A Transmit Register 3, array offset: 0x0, array step: 0x4
◆ TRANSFER_COUNT
__IO uint32_t LCDIF_Type::TRANSFER_COUNT
LCDIF Horizontal and Vertical Valid Data Count Register, offset: 0x30
◆  [1/4]
__IO uint32_t { ... } ::TRIGn_CHAIN_1_0
ETC_TRIG Chain 0/1 Register, array offset: 0x18, array step: 0x28
◆ TRIGn_CHAIN_1_0 [2/4]
__IO uint32_t ADC_ETC_Type::TRIGn_CHAIN_1_0
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint32_t { ... } ::TRIGn_CHAIN_3_2
ETC_TRIG Chain 2/3 Register, array offset: 0x1C, array step: 0x28
◆ TRIGn_CHAIN_3_2 [2/4]
__IO uint32_t ADC_ETC_Type::TRIGn_CHAIN_3_2
◆  [3/4]
◆  [4/4]
◆ TRIGn_CHAIN_5_4 [1/4]
__IO uint32_t ADC_ETC_Type::TRIGn_CHAIN_5_4
ETC_TRIG Chain 4/5 Register, array offset: 0x20, array step: 0x28
◆  [2/4]
__IO uint32_t { ... } ::TRIGn_CHAIN_5_4
◆  [3/4]
◆  [4/4]
◆ TRIGn_CHAIN_7_6 [1/4]
__IO uint32_t ADC_ETC_Type::TRIGn_CHAIN_7_6
ETC_TRIG Chain 6/7 Register, array offset: 0x24, array step: 0x28
◆  [2/4]
__IO uint32_t { ... } ::TRIGn_CHAIN_7_6
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint32_t { ... } ::TRIGn_COUNTER
ETC_TRIG Counter Register, array offset: 0x14, array step: 0x28
◆ TRIGn_COUNTER [2/4]
__IO uint32_t ADC_ETC_Type::TRIGn_COUNTER
◆  [3/4]
◆  [4/4]
◆ TRIGn_CTRL [1/4]
__IO uint32_t ADC_ETC_Type::TRIGn_CTRL
ETC_TRIG Control Register, array offset: 0x10, array step: 0x28
◆  [2/4]
__IO uint32_t { ... } ::TRIGn_CTRL
◆  [3/4]
◆  [4/4]
◆ TRIGn_RESULT_1_0 [1/4]
__I uint32_t ADC_ETC_Type::TRIGn_RESULT_1_0
ETC_TRIG Result Data 1/0 Register, array offset: 0x28, array step: 0x28
◆  [2/4]
__I uint32_t { ... } ::TRIGn_RESULT_1_0
◆  [3/4]
◆  [4/4]
◆ TRIGn_RESULT_3_2 [1/4]
__I uint32_t ADC_ETC_Type::TRIGn_RESULT_3_2
ETC_TRIG Result Data 3/2 Register, array offset: 0x2C, array step: 0x28
◆  [2/4]
__I uint32_t { ... } ::TRIGn_RESULT_3_2
◆  [3/4]
◆  [4/4]
◆ TRIGn_RESULT_5_4 [1/4]
__I uint32_t ADC_ETC_Type::TRIGn_RESULT_5_4
ETC_TRIG Result Data 5/4 Register, array offset: 0x30, array step: 0x28
◆  [2/4]
__I uint32_t { ... } ::TRIGn_RESULT_5_4
◆  [3/4]
◆  [4/4]
◆ TRIGn_RESULT_7_6 [1/4]
__I uint32_t ADC_ETC_Type::TRIGn_RESULT_7_6
ETC_TRIG Result Data 7/6 Register, array offset: 0x34, array step: 0x28
◆  [2/4]
__I uint32_t { ... } ::TRIGn_RESULT_7_6
◆  [3/4]
◆  [4/4]
◆ TRIM_OVERRIDE_EN
__IO uint32_t USBPHY_Type::TRIM_OVERRIDE_EN
USB PHY Trim Override Enable Register, offset: 0x130
◆ TRIM_OVERRIDE_EN_CLR
__IO uint32_t USBPHY_Type::TRIM_OVERRIDE_EN_CLR
USB PHY Trim Override Enable Register, offset: 0x138
◆ TRIM_OVERRIDE_EN_SET
__IO uint32_t USBPHY_Type::TRIM_OVERRIDE_EN_SET
USB PHY Trim Override Enable Register, offset: 0x134
◆ TRIM_OVERRIDE_EN_TOG
__IO uint32_t USBPHY_Type::TRIM_OVERRIDE_EN_TOG
USB PHY Trim Override Enable Register, offset: 0x13C
◆ TSEM
__IO uint32_t ENET_Type::TSEM
Transmit FIFO Section Empty Threshold, offset: 0x1A0
◆ TST [1/2]
__IO uint16_t ENC_Type::TST
Test Register, offset: 0x1C
◆ TST [2/2]
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::TST
TST, offset: 0x20
◆ TSTMD
__IO uint32_t IEE_Type::TSTMD
IEE Test Mode Register, offset: 0x8
◆ TUNING_CTRL
__IO uint32_t USDHC_Type::TUNING_CTRL
Tuning Control, offset: 0xCC
◆ TX
__IO uint32_t USBPHY_Type::TX
USB PHY Transmitter Control Register, offset: 0x10
◆ TX_BUF
__O uint32_t EMVSIM_Type::TX_BUF
Transmit Data Buffer, offset: 0x30
◆ TX_CLR
__IO uint32_t USBPHY_Type::TX_CLR
USB PHY Transmitter Control Register, offset: 0x18
◆ TX_GETU
__IO uint32_t EMVSIM_Type::TX_GETU
Transmitter Guard ETU Value Register, offset: 0x34
◆ TX_PAYLOAD
__IO uint32_t DSI_HOST_APB_PKT_IF_Type::TX_PAYLOAD
TX_PAYLOAD, offset: 0x0
◆ TX_RCAL
__IO uint32_t DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type::TX_RCAL
TX_RCAL, offset: 0x38
◆ TX_SET
__IO uint32_t USBPHY_Type::TX_SET
USB PHY Transmitter Control Register, offset: 0x14
◆ TX_STATUS
__IO uint32_t EMVSIM_Type::TX_STATUS
Transmitter Status Register, offset: 0x24
◆ TX_THD
__IO uint32_t EMVSIM_Type::TX_THD
Transmitter Threshold Register, offset: 0x1C
◆ TX_TOG
__IO uint32_t USBPHY_Type::TX_TOG
USB PHY Transmitter Control Register, offset: 0x1C
◆ TXFILLTUNING
__IO uint32_t USB_Type::TXFILLTUNING
TX FIFO Fill Tuning, offset: 0x164
◆ TXIC
__IO uint32_t ENET_Type::TXIC
Transmit Interrupt Coalescing Register, array offset: 0xF0, array step: 0x4
◆ UCOMP
__IO uint16_t ENC_Type::UCOMP
Upper Position Compare Register, offset: 0x24
◆ UINIT
__IO uint16_t ENC_Type::UINIT
Upper Initialization Register, offset: 0x16
◆ ULPS_STATUS
__I uint32_t MIPI_CSI2RX_Type::ULPS_STATUS
Ultra Low Power State (ULPS) Status Register, offset: 0x114
◆ UMOD
__IO uint16_t ENC_Type::UMOD
Upper Modulus Register, offset: 0x20
◆ UPOS
__IO uint16_t ENC_Type::UPOS
Upper Position Counter Register, offset: 0xE
◆ UPOSH
__I uint16_t ENC_Type::UPOSH
Upper Position Hold Register, offset: 0x12
◆ USB1_CHRG_DET_STAT
__I uint32_t USBPHY_Type::USB1_CHRG_DET_STAT
USB PHY Charger Detect Status Register, offset: 0xF0
◆ USB1_CHRG_DETECT
__IO uint32_t USBPHY_Type::USB1_CHRG_DETECT
USB PHY Charger Detect Control Register, offset: 0xE0
◆ USB1_CHRG_DETECT_CLR
__IO uint32_t USBPHY_Type::USB1_CHRG_DETECT_CLR
USB PHY Charger Detect Control Register, offset: 0xE8
◆ USB1_CHRG_DETECT_SET
__IO uint32_t USBPHY_Type::USB1_CHRG_DETECT_SET
USB PHY Charger Detect Control Register, offset: 0xE4
◆ USB1_CHRG_DETECT_TOG
__IO uint32_t USBPHY_Type::USB1_CHRG_DETECT_TOG
USB PHY Charger Detect Control Register, offset: 0xEC
◆ USB1_LOOPBACK
__IO uint32_t USBPHY_Type::USB1_LOOPBACK
USB PHY Loopback Control/Status Register, offset: 0x110
◆ USB1_LOOPBACK_CLR
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_CLR
USB PHY Loopback Control/Status Register, offset: 0x118
◆ USB1_LOOPBACK_HSFSCNT
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_HSFSCNT
USB PHY Loopback Packet Number Select Register, offset: 0x120
◆ USB1_LOOPBACK_HSFSCNT_CLR
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_HSFSCNT_CLR
USB PHY Loopback Packet Number Select Register, offset: 0x128
◆ USB1_LOOPBACK_HSFSCNT_SET
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_HSFSCNT_SET
USB PHY Loopback Packet Number Select Register, offset: 0x124
◆ USB1_LOOPBACK_HSFSCNT_TOG
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_HSFSCNT_TOG
USB PHY Loopback Packet Number Select Register, offset: 0x12C
◆ USB1_LOOPBACK_SET
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_SET
USB PHY Loopback Control/Status Register, offset: 0x114
◆ USB1_LOOPBACK_TOG
__IO uint32_t USBPHY_Type::USB1_LOOPBACK_TOG
USB PHY Loopback Control/Status Register, offset: 0x11C
◆ USB1_VBUS_DET_STAT
__I uint32_t USBPHY_Type::USB1_VBUS_DET_STAT
USB PHY VBUS Detector Status Register, offset: 0xD0
◆ USB1_VBUS_DETECT
__IO uint32_t USBPHY_Type::USB1_VBUS_DETECT
USB PHY VBUS Detect Control Register, offset: 0xC0
◆ USB1_VBUS_DETECT_CLR
__IO uint32_t USBPHY_Type::USB1_VBUS_DETECT_CLR
USB PHY VBUS Detect Control Register, offset: 0xC8
◆ USB1_VBUS_DETECT_SET
__IO uint32_t USBPHY_Type::USB1_VBUS_DETECT_SET
USB PHY VBUS Detect Control Register, offset: 0xC4
◆ USB1_VBUS_DETECT_TOG
__IO uint32_t USBPHY_Type::USB1_VBUS_DETECT_TOG
USB PHY VBUS Detect Control Register, offset: 0xCC
◆ USB_OTGn_CTRL
__IO uint32_t USBNC_Type::USB_OTGn_CTRL
USB OTG1 Control Register..USB OTG2 Control Register, offset: 0x800
◆ USB_OTGn_PHY_CTRL_0
__IO uint32_t USBNC_Type::USB_OTGn_PHY_CTRL_0
OTG1 UTMI PHY Control 0 Register..OTG2 UTMI PHY Control 0 Register, offset: 0x818
◆ USBCMD
__IO uint32_t USB_Type::USBCMD
USB Command Register, offset: 0x140
◆ USBINTR
__IO uint32_t USB_Type::USBINTR
Interrupt Enable Register, offset: 0x148
◆ USBMODE
__IO uint32_t USB_Type::USBMODE
USB Device Mode, offset: 0x1A8
◆ USBSTS
__IO uint32_t USB_Type::USBSTS
USB Status Register, offset: 0x144
◆ USE_NULL_PKT_BLLP
__IO uint32_t DSI_HOST_DPI_INTFC_Type::USE_NULL_PKT_BLLP
USE_NULL_PKT_BLLP, offset: 0x38
◆ UVSIL [1/3]
__IO uint32_t CAAM_Type::UVSIL
Variable Sequence Input Length Register; Upper 32 bits, array offset: 0x80E38, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::UVSIL
◆  [3/3]
◆ UVSOL [1/3]
__IO uint32_t CAAM_Type::UVSOL
Variable Sequence Output Length Register; Upper 32 bits, array offset: 0x80E34, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::UVSOL
◆  [3/3]
◆ VACTIVE
__IO uint32_t DSI_HOST_DPI_INTFC_Type::VACTIVE
VACTIVE, offset: 0x3C
◆ VAD0_CTRL_1
__IO uint32_t PDM_Type::VAD0_CTRL_1
Voice Activity Detector 0 Control register, offset: 0x90
◆ VAD0_CTRL_2
__IO uint32_t PDM_Type::VAD0_CTRL_2
Voice Activity Detector 0 Control register, offset: 0x94
◆ VAD0_NCONFIG
__IO uint32_t PDM_Type::VAD0_NCONFIG
Voice Activity Detector 0 Noise Configuration, offset: 0xA0
◆ VAD0_NDATA
__I uint32_t PDM_Type::VAD0_NDATA
Voice Activity Detector 0 Noise Data, offset: 0xA4
◆ VAD0_SCONFIG
__IO uint32_t PDM_Type::VAD0_SCONFIG
Voice Activity Detector 0 Signal Configuration, offset: 0x9C
◆ VAD0_STAT
__IO uint32_t PDM_Type::VAD0_STAT
Voice Activity Detector 0 Status register, offset: 0x98
◆ VAD0_ZCD
__IO uint32_t PDM_Type::VAD0_ZCD
Voice Activity Detector 0 Zero-Crossing Detector, offset: 0xA8
◆ VAL0 [1/4]
__IO uint16_t PWM_Type::VAL0
Value Register 0, array offset: 0xA, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::VAL0
◆  [3/4]
◆  [4/4]
◆ VAL1 [1/4]
__IO uint16_t PWM_Type::VAL1
Value Register 1, array offset: 0xE, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::VAL1
◆  [3/4]
◆  [4/4]
◆ VAL2 [1/4]
__IO uint16_t PWM_Type::VAL2
Value Register 2, array offset: 0x12, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::VAL2
◆  [3/4]
◆  [4/4]
◆ VAL3 [1/4]
__IO uint16_t PWM_Type::VAL3
Value Register 3, array offset: 0x16, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::VAL3
◆  [3/4]
◆  [4/4]
◆ VAL4 [1/4]
__IO uint16_t PWM_Type::VAL4
Value Register 4, array offset: 0x1A, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::VAL4
◆  [3/4]
◆  [4/4]
◆ VAL5 [1/4]
__IO uint16_t PWM_Type::VAL5
Value Register 5, array offset: 0x1E, array step: 0x60
◆  [2/4]
__IO uint16_t { ... } ::VAL5
◆  [3/4]
◆  [4/4]
◆ VBP
__IO uint32_t DSI_HOST_DPI_INTFC_Type::VBP
VBP, offset: 0x2C
◆  [1/2]
__IO uint32_t { ... } ::VBUS_DETECT
USB VBUS Detect Register, array offset: 0x1A0, array step: 0x60
◆ VBUS_DETECT [2/2]
__IO uint32_t USB_ANALOG_Type::VBUS_DETECT
◆  [1/2]
__IO uint32_t { ... } ::VBUS_DETECT_CLR
USB VBUS Detect Register, array offset: 0x1A8, array step: 0x60
◆ VBUS_DETECT_CLR [2/2]
__IO uint32_t USB_ANALOG_Type::VBUS_DETECT_CLR
◆  [1/2]
__IO uint32_t { ... } ::VBUS_DETECT_SET
USB VBUS Detect Register, array offset: 0x1A4, array step: 0x60
◆ VBUS_DETECT_SET [2/2]
__IO uint32_t USB_ANALOG_Type::VBUS_DETECT_SET
◆  [1/2]
__I uint32_t { ... } ::VBUS_DETECT_STAT
USB VBUS Detect Status Register, array offset: 0x1C0, array step: 0x60
◆ VBUS_DETECT_STAT [2/2]
__I uint32_t USB_ANALOG_Type::VBUS_DETECT_STAT
◆  [1/2]
__IO uint32_t { ... } ::VBUS_DETECT_TOG
USB VBUS Detect Register, array offset: 0x1AC, array step: 0x60
◆ VBUS_DETECT_TOG [2/2]
__IO uint32_t USB_ANALOG_Type::VBUS_DETECT_TOG
◆ VDCTRL0
__IO uint32_t LCDIF_Type::VDCTRL0
LCDIF VSYNC Mode and Dotclk Mode Control Register0, offset: 0x70
◆ VDCTRL0_CLR
__IO uint32_t LCDIF_Type::VDCTRL0_CLR
LCDIF VSYNC Mode and Dotclk Mode Control Register0, offset: 0x78
◆ VDCTRL0_SET
__IO uint32_t LCDIF_Type::VDCTRL0_SET
LCDIF VSYNC Mode and Dotclk Mode Control Register0, offset: 0x74
◆ VDCTRL0_TOG
__IO uint32_t LCDIF_Type::VDCTRL0_TOG
LCDIF VSYNC Mode and Dotclk Mode Control Register0, offset: 0x7C
◆ VDCTRL1
__IO uint32_t LCDIF_Type::VDCTRL1
LCDIF VSYNC Mode and Dotclk Mode Control Register1, offset: 0x80
◆ VDCTRL2
__IO uint32_t LCDIF_Type::VDCTRL2
LCDIF VSYNC Mode and Dotclk Mode Control Register2, offset: 0x90
◆ VDCTRL3
__IO uint32_t LCDIF_Type::VDCTRL3
LCDIF VSYNC Mode and Dotclk Mode Control Register3, offset: 0xA0
◆ VDCTRL4
__IO uint32_t LCDIF_Type::VDCTRL4
LCDIF VSYNC Mode and Dotclk Mode Control Register4, offset: 0xB0
◆ VDDLPSR_AI400M_CTRL
__IO uint32_t ANADIG_MISC_Type::VDDLPSR_AI400M_CTRL
VDDLPSR_AI400M_CTRL_REGISTER, offset: 0x920
◆ VDDLPSR_AI400M_RDATA
__I uint32_t ANADIG_MISC_Type::VDDLPSR_AI400M_RDATA
VDDLPSR_AI400M_RDATA_REGISTER, offset: 0x940
◆ VDDLPSR_AI400M_WDATA
__IO uint32_t ANADIG_MISC_Type::VDDLPSR_AI400M_WDATA
VDDLPSR_AI400M_WDATA_REGISTER, offset: 0x930
◆ VDDLPSR_AI_CTRL
__IO uint32_t ANADIG_MISC_Type::VDDLPSR_AI_CTRL
VDDSOC_AI_CTRL_REGISTER, offset: 0x8E0
◆ VDDLPSR_AI_RDATA_REFTOP
__I uint32_t ANADIG_MISC_Type::VDDLPSR_AI_RDATA_REFTOP
VDDLPSR_AI_RDATA_REFTOP_REGISTER, offset: 0x900
◆ VDDLPSR_AI_RDATA_TMPSNS
__I uint32_t ANADIG_MISC_Type::VDDLPSR_AI_RDATA_TMPSNS
VDDLPSR_AI_RDATA_TMPSNS_REGISTER, offset: 0x910
◆ VDDLPSR_AI_WDATA
__IO uint32_t ANADIG_MISC_Type::VDDLPSR_AI_WDATA
VDDLPSR_AI_WDATA_REGISTER, offset: 0x8F0
◆ VDDSOC2PLL_AI_CTRL_1G
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_CTRL_1G
VDDSOC2PLL_AI_CTRL_1G_REGISTER, offset: 0x850
◆ VDDSOC2PLL_AI_CTRL_AUDIO
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_CTRL_AUDIO
VDDSOC_AI_CTRL_AUDIO_REGISTER, offset: 0x880
◆ VDDSOC2PLL_AI_CTRL_VIDEO
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_CTRL_VIDEO
VDDSOC2PLL_AI_CTRL_VIDEO_REGISTER, offset: 0x8B0
◆ VDDSOC2PLL_AI_RDATA_1G
__I uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_RDATA_1G
VDDSOC2PLL_AI_RDATA_1G_REGISTER, offset: 0x870
◆ VDDSOC2PLL_AI_RDATA_AUDIO
__I uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_RDATA_AUDIO
VDDSOC2PLL_AI_RDATA_REGISTER, offset: 0x8A0
◆ VDDSOC2PLL_AI_RDATA_VIDEO
__I uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_RDATA_VIDEO
VDDSOC2PLL_AI_RDATA_VIDEO_REGISTER, offset: 0x8D0
◆ VDDSOC2PLL_AI_WDATA_1G
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_WDATA_1G
VDDSOC2PLL_AI_WDATA_1G_REGISTER, offset: 0x860
◆ VDDSOC2PLL_AI_WDATA_AUDIO
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_WDATA_AUDIO
VDDSOC_AI_WDATA_AUDIO_REGISTER, offset: 0x890
◆ VDDSOC2PLL_AI_WDATA_VIDEO
__IO uint32_t ANADIG_MISC_Type::VDDSOC2PLL_AI_WDATA_VIDEO
VDDSOC2PLL_AI_WDATA_VIDEO_REGISTER, offset: 0x8C0
◆ VDDSOC_AI_CTRL
__IO uint32_t ANADIG_MISC_Type::VDDSOC_AI_CTRL
VDDSOC_AI_CTRL_REGISTER, offset: 0x820
◆ VDDSOC_AI_RDATA
__I uint32_t ANADIG_MISC_Type::VDDSOC_AI_RDATA
VDDSOC_AI_RDATA_REGISTER, offset: 0x840
◆ VDDSOC_AI_WDATA
__IO uint32_t ANADIG_MISC_Type::VDDSOC_AI_WDATA
VDDSOC_AI_WDATA_REGISTER, offset: 0x830
◆ VEND_SPEC
__IO uint32_t USDHC_Type::VEND_SPEC
Vendor Specific Register, offset: 0xC0
◆ VEND_SPEC2
__IO uint32_t USDHC_Type::VEND_SPEC2
Vendor Specific 2 Register, offset: 0xC8
◆ VER_ID
__I uint32_t EMVSIM_Type::VER_ID
Version ID Register, offset: 0x0
◆ VERID [1/8]
__I uint32_t FLEXIO_Type::VERID
◆ VERID [2/8]
__I uint32_t I2S_Type::VERID
Version ID, offset: 0x0
◆ VERID [3/8]
__I uint32_t LPI2C_Type::VERID
◆ VERID [4/8]
__I uint32_t LPSPI_Type::VERID
◆ VERID [5/8]
__I uint32_t LPUART_Type::VERID
◆ VERID [6/8]
__I uint32_t ADC_Type::VERID
◆ VERID [7/8]
__I uint32_t CMP_Type::VERID
◆ VERID [8/8]
__I uint32_t DAC_Type::VERID
Version Identifier Register, offset: 0x0
◆ VERSION [1/4]
__I uint32_t DCP_Type::VERSION
DCP version register, offset: 0x430
◆ VERSION [2/4]
__I uint32_t OCOTP_Type::VERSION
OTP Controller Version Register, offset: 0x90
OTP Controller Version Register, offset: 0xB0
◆ VERSION [3/4]
__I uint32_t USBPHY_Type::VERSION
UTMI RTL Version, offset: 0x80
◆ VERSION [4/4]
__I uint32_t PUF_Type::VERSION
PUF Version Register, offset: 0xFC
◆ VFP
__IO uint32_t DSI_HOST_DPI_INTFC_Type::VFP
VFP, offset: 0x30
◆ VID1
__I uint32_t TRNG_Type::VID1
Version ID Register (MS), offset: 0xF0
◆ VID2
__I uint32_t TRNG_Type::VID2
Version ID Register (LS), offset: 0xF4
◆ VIDEO_MODE
__IO uint32_t DSI_HOST_DPI_INTFC_Type::VIDEO_MODE
VIDEO_MODE, offset: 0x18
◆ VIDR1
__I uint32_t IEE_Type::VIDR1
IEE Version ID Register 1, offset: 0xF0
◆ VIR
__I uint32_t RDC_Type::VIR
Version Information, offset: 0x0
◆ VSIL [1/3]
__IO uint32_t CAAM_Type::VSIL
Variable Sequence Input Length Register, array offset: 0x80E2C, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::VSIL
◆  [3/3]
◆ VSOL [1/3]
__IO uint32_t CAAM_Type::VSOL
Variable Sequence Output Length Register, array offset: 0x80E24, array step: 0xE3C
◆  [2/3]
__IO uint32_t { ... } ::VSOL
◆  [3/3]
◆ VSYN_PARA
__IO uint32_t LCDIFV2_Type::VSYN_PARA
Vertical Sync Parameter Register, offset: 0x1C
◆ VSYNC_POLARITY
__IO uint32_t DSI_HOST_DPI_INTFC_Type::VSYNC_POLARITY
VSYNC_POLARITY, offset: 0x10
◆ WATER
__IO uint32_t LPUART_Type::WATER
LPUART Watermark Register, offset: 0x2C
◆ WCR
__IO uint16_t WDOG_Type::WCR
Watchdog Control Register, offset: 0x0
◆ WICR
__IO uint16_t WDOG_Type::WICR
Watchdog Interrupt Control Register, offset: 0x6
◆ WIN
__IO uint32_t RTWDOG_Type::WIN
Watchdog Window Register, offset: 0xC
◆ WMCR
__IO uint16_t WDOG_Type::WMCR
Watchdog Miscellaneous Control Register, offset: 0x8
◆  [1/15]
__IO uint32_t { ... } ::WORD[16]
Message Buffer 0 WORD_64B Register..Message Buffer 6 WORD_64B Register, array offset: 0x88, array step: index*0x48, index2*0x4
◆  [2/15]
Message Buffer 0 WORD_64B Register..Message Buffer 6 WORD_64B Register, array offset: 0x288, array step: index*0x48, index2*0x4
◆  [3/15]
◆  [4/15]
◆  [5/15]
__IO uint32_t { ... } ::WORD[2]
Message Buffer 0 WORD_8B Register..Message Buffer 63 WORD_8B Register, array offset: 0x88, array step: index*0x10, index2*0x4
◆ WORD [6/15]
__IO uint32_t CAN_Type::WORD[16]
Message Buffer 0 WORD_16B Register..Message Buffer 20 WORD_16B Register, array offset: 0x88, array step: index*0x18, index2*0x4
Message Buffer 0 WORD_16B Register..Message Buffer 20 WORD_16B Register, array offset: 0x288, array step: index*0x18, index2*0x4
Message Buffer 0 WORD_32B Register..Message Buffer 11 WORD_32B Register, array offset: 0x88, array step: index*0x28, index2*0x4
Message Buffer 0 WORD_32B Register..Message Buffer 11 WORD_32B Register, array offset: 0x288, array step: index*0x28, index2*0x4
◆  [7/15]
◆  [8/15]
__IO uint32_t { ... } ::WORD[4]
◆  [9/15]
◆  [10/15]
◆  [11/15]
◆  [12/15]
__IO uint32_t { ... } ::WORD[8]
◆  [13/15]
◆  [14/15]
◆  [15/15]
◆  [1/4]
__IO uint32_t { ... } ::WORD0
Message Buffer 0 WORD0 Register..Message Buffer 63 WORD0 Register, array offset: 0x88, array step: 0x10
◆ WORD0 [2/4]
__IO uint32_t CAN_Type::WORD0
◆  [3/4]
◆  [4/4]
◆  [1/4]
__IO uint32_t { ... } ::WORD1
Message Buffer 0 WORD1 Register..Message Buffer 63 WORD1 Register, array offset: 0x8C, array step: 0x10
◆ WORD1 [2/4]
__IO uint32_t CAN_Type::WORD1
◆  [3/4]
◆  [4/4]
◆ WRSR
__I uint16_t WDOG_Type::WRSR
Watchdog Reset Status Register, offset: 0x4
◆ WSR
__IO uint16_t WDOG_Type::WSR
Watchdog Service Register, offset: 0x2
◆ WTMK_LVL
__IO uint32_t USDHC_Type::WTMK_LVL
Watermark Level, offset: 0x44
◆ WTR
__IO uint16_t ENC_Type::WTR
Watchdog Timeout Register, offset: 0x4
