| Enumerator |
| kXBARA1_InputLogicLow | LOGIC_LOW output assigned to XBARA1_IN0 input.
| kXBARA1_InputLogicHigh | LOGIC_HIGH output assigned to XBARA1_IN1 input.
| kXBARA1_InputIomuxXbarIn02 | IOMUX_XBAR_IN02 output assigned to XBARA1_IN2 input.
| kXBARA1_InputIomuxXbarIn03 | IOMUX_XBAR_IN03 output assigned to XBARA1_IN3 input.
| kXBARA1_InputIomuxXbarInout04 | IOMUX_XBAR_INOUT04 output assigned to XBARA1_IN4 input.
| kXBARA1_InputIomuxXbarInout05 | IOMUX_XBAR_INOUT05 output assigned to XBARA1_IN5 input.
| kXBARA1_InputIomuxXbarInout06 | IOMUX_XBAR_INOUT06 output assigned to XBARA1_IN6 input.
| kXBARA1_InputIomuxXbarInout07 | IOMUX_XBAR_INOUT07 output assigned to XBARA1_IN7 input.
| kXBARA1_InputIomuxXbarInout08 | IOMUX_XBAR_INOUT08 output assigned to XBARA1_IN8 input.
| kXBARA1_InputIomuxXbarInout09 | IOMUX_XBAR_INOUT09 output assigned to XBARA1_IN9 input.
| kXBARA1_InputIomuxXbarInout10 | IOMUX_XBAR_INOUT10 output assigned to XBARA1_IN10 input.
| kXBARA1_InputIomuxXbarInout11 | IOMUX_XBAR_INOUT11 output assigned to XBARA1_IN11 input.
| kXBARA1_InputIomuxXbarInout12 | IOMUX_XBAR_INOUT12 output assigned to XBARA1_IN12 input.
| kXBARA1_InputIomuxXbarInout13 | IOMUX_XBAR_INOUT13 output assigned to XBARA1_IN13 input.
| kXBARA1_InputIomuxXbarInout14 | IOMUX_XBAR_INOUT14 output assigned to XBARA1_IN14 input.
| kXBARA1_InputIomuxXbarInout15 | IOMUX_XBAR_INOUT15 output assigned to XBARA1_IN15 input.
| kXBARA1_InputIomuxXbarInout16 | IOMUX_XBAR_INOUT16 output assigned to XBARA1_IN16 input.
| kXBARA1_InputIomuxXbarInout17 | IOMUX_XBAR_INOUT17 output assigned to XBARA1_IN17 input.
| kXBARA1_InputIomuxXbarInout18 | IOMUX_XBAR_INOUT18 output assigned to XBARA1_IN18 input.
| kXBARA1_InputIomuxXbarInout19 | IOMUX_XBAR_INOUT19 output assigned to XBARA1_IN19 input.
| kXBARA1_InputIomuxXbarIn20 | IOMUX_XBAR_IN20 output assigned to XBARA1_IN20 input.
| kXBARA1_InputIomuxXbarIn21 | IOMUX_XBAR_IN21 output assigned to XBARA1_IN21 input.
| kXBARA1_InputIomuxXbarIn22 | IOMUX_XBAR_IN22 output assigned to XBARA1_IN22 input.
| kXBARA1_InputIomuxXbarIn23 | IOMUX_XBAR_IN23 output assigned to XBARA1_IN23 input.
| kXBARA1_InputIomuxXbarIn24 | IOMUX_XBAR_IN24 output assigned to XBARA1_IN24 input.
| kXBARA1_InputIomuxXbarIn25 | IOMUX_XBAR_IN25 output assigned to XBARA1_IN25 input.
| kXBARA1_InputAcmp1Out | ACMP1_OUT output assigned to XBARA1_IN26 input.
| kXBARA1_InputAcmp2Out | ACMP2_OUT output assigned to XBARA1_IN27 input.
| kXBARA1_InputAcmp3Out | ACMP3_OUT output assigned to XBARA1_IN28 input.
| kXBARA1_InputAcmp4Out | ACMP4_OUT output assigned to XBARA1_IN29 input.
| kXBARA1_InputRESERVED30 | XBARA1_IN30 input is reserved.
| kXBARA1_InputRESERVED31 | XBARA1_IN31 input is reserved.
| kXBARA1_InputQtimer3Tmr0Output | QTIMER3_TMR0_OUTPUT output assigned to XBARA1_IN32 input.
| kXBARA1_InputQtimer3Tmr1Output | QTIMER3_TMR1_OUTPUT output assigned to XBARA1_IN33 input.
| kXBARA1_InputQtimer3Tmr2Output | QTIMER3_TMR2_OUTPUT output assigned to XBARA1_IN34 input.
| kXBARA1_InputQtimer3Tmr3Output | QTIMER3_TMR3_OUTPUT output assigned to XBARA1_IN35 input.
| kXBARA1_InputQtimer4Tmr0Output | QTIMER4_TMR0_OUTPUT output assigned to XBARA1_IN36 input.
| kXBARA1_InputQtimer4Tmr1Output | QTIMER4_TMR1_OUTPUT output assigned to XBARA1_IN37 input.
| kXBARA1_InputQtimer4Tmr2Output | QTIMER4_TMR2_OUTPUT output assigned to XBARA1_IN38 input.
| kXBARA1_InputQtimer4Tmr3Output | QTIMER4_TMR3_OUTPUT output assigned to XBARA1_IN39 input.
| kXBARA1_InputFlexpwm1Pwm1OutTrig01 | FLEXPWM1_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN40 input.
| kXBARA1_InputFlexpwm1Pwm2OutTrig01 | FLEXPWM1_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN41 input.
| kXBARA1_InputFlexpwm1Pwm3OutTrig01 | FLEXPWM1_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN42 input.
| kXBARA1_InputFlexpwm1Pwm4OutTrig01 | FLEXPWM1_PWM4_OUT_TRIG0_1 output assigned to XBARA1_IN43 input.
| kXBARA1_InputFlexpwm2Pwm1OutTrig01 | FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN44 input.
| kXBARA1_InputFlexpwm2Pwm2OutTrig01 | FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN45 input.
| kXBARA1_InputFlexpwm2Pwm3OutTrig01 | FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN46 input.
| kXBARA1_InputFlexpwm2Pwm4OutTrig01 | FLEXPWM2_PWM4_OUT_TRIG0_1 output assigned to XBARA1_IN47 input.
| kXBARA1_InputFlexpwm3Pwm1OutTrig01 | FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN48 input.
| kXBARA1_InputFlexpwm3Pwm2OutTrig01 | FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN49 input.
| kXBARA1_InputFlexpwm3Pwm3OutTrig01 | FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN50 input.
| kXBARA1_InputFlexpwm3Pwm4OutTrig01 | FLEXPWM3_PWM4_OUT_TRIG0_1 output assigned to XBARA1_IN51 input.
| kXBARA1_InputFlexpwm4Pwm1OutTrig01 | FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN52 input.
| kXBARA1_InputFlexpwm4Pwm2OutTrig01 | FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN53 input.
| kXBARA1_InputFlexpwm4Pwm3OutTrig01 | FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN54 input.
| kXBARA1_InputFlexpwm4Pwm4OutTrig01 | FLEXPWM4_PWM4_OUT_TRIG0_1 output assigned to XBARA1_IN55 input.
| kXBARA1_InputPitTrigger0 | PIT_TRIGGER0 output assigned to XBARA1_IN56 input.
| kXBARA1_InputPitTrigger1 | PIT_TRIGGER1 output assigned to XBARA1_IN57 input.
| kXBARA1_InputPitTrigger2 | PIT_TRIGGER2 output assigned to XBARA1_IN58 input.
| kXBARA1_InputPitTrigger3 | PIT_TRIGGER3 output assigned to XBARA1_IN59 input.
| kXBARA1_InputEnc1PosMatch | ENC1_POS_MATCH output assigned to XBARA1_IN60 input.
| kXBARA1_InputEnc2PosMatch | ENC2_POS_MATCH output assigned to XBARA1_IN61 input.
| kXBARA1_InputEnc3PosMatch | ENC3_POS_MATCH output assigned to XBARA1_IN62 input.
| kXBARA1_InputEnc4PosMatch | ENC4_POS_MATCH output assigned to XBARA1_IN63 input.
| kXBARA1_InputDmaDone0 | DMA_DONE0 output assigned to XBARA1_IN64 input.
| kXBARA1_InputDmaDone1 | DMA_DONE1 output assigned to XBARA1_IN65 input.
| kXBARA1_InputDmaDone2 | DMA_DONE2 output assigned to XBARA1_IN66 input.
| kXBARA1_InputDmaDone3 | DMA_DONE3 output assigned to XBARA1_IN67 input.
| kXBARA1_InputDmaDone4 | DMA_DONE4 output assigned to XBARA1_IN68 input.
| kXBARA1_InputDmaDone5 | DMA_DONE5 output assigned to XBARA1_IN69 input.
| kXBARA1_InputDmaDone6 | DMA_DONE6 output assigned to XBARA1_IN70 input.
| kXBARA1_InputDmaDone7 | DMA_DONE7 output assigned to XBARA1_IN71 input.
| kXBARA1_InputAoi1Out0 | AOI1_OUT0 output assigned to XBARA1_IN72 input.
| kXBARA1_InputAoi1Out1 | AOI1_OUT1 output assigned to XBARA1_IN73 input.
| kXBARA1_InputAoi1Out2 | AOI1_OUT2 output assigned to XBARA1_IN74 input.
| kXBARA1_InputAoi1Out3 | AOI1_OUT3 output assigned to XBARA1_IN75 input.
| kXBARA1_InputAoi2Out0 | AOI2_OUT0 output assigned to XBARA1_IN76 input.
| kXBARA1_InputAoi2Out1 | AOI2_OUT1 output assigned to XBARA1_IN77 input.
| kXBARA1_InputAoi2Out2 | AOI2_OUT2 output assigned to XBARA1_IN78 input.
| kXBARA1_InputAoi2Out3 | AOI2_OUT3 output assigned to XBARA1_IN79 input.
| kXBARA1_InputAdcEtcXbar0Coco0 | ADC_ETC_XBAR0_COCO0 output assigned to XBARA1_IN80 input.
| kXBARA1_InputAdcEtcXbar0Coco1 | ADC_ETC_XBAR0_COCO1 output assigned to XBARA1_IN81 input.
| kXBARA1_InputAdcEtcXbar0Coco2 | ADC_ETC_XBAR0_COCO2 output assigned to XBARA1_IN82 input.
| kXBARA1_InputAdcEtcXbar0Coco3 | ADC_ETC_XBAR0_COCO3 output assigned to XBARA1_IN83 input.
| kXBARA1_InputAdcEtcXbar1Coco0 | ADC_ETC_XBAR1_COCO0 output assigned to XBARA1_IN84 input.
| kXBARA1_InputAdcEtcXbar1Coco1 | ADC_ETC_XBAR1_COCO1 output assigned to XBARA1_IN85 input.
| kXBARA1_InputAdcEtcXbar1Coco2 | ADC_ETC_XBAR1_COCO2 output assigned to XBARA1_IN86 input.
| kXBARA1_InputAdcEtcXbar1Coco3 | ADC_ETC_XBAR1_COCO3 output assigned to XBARA1_IN87 input.
| kXBARB2_InputLogicLow | LOGIC_LOW output assigned to XBARB2_IN0 input.
| kXBARB2_InputLogicHigh | LOGIC_HIGH output assigned to XBARB2_IN1 input.
| kXBARB2_InputRESERVED2 | XBARB2_IN2 input is reserved.
| kXBARB2_InputRESERVED3 | XBARB2_IN3 input is reserved.
| kXBARB2_InputRESERVED4 | XBARB2_IN4 input is reserved.
| kXBARB2_InputRESERVED5 | XBARB2_IN5 input is reserved.
| kXBARB2_InputAcmp1Out | ACMP1_OUT output assigned to XBARB2_IN6 input.
| kXBARB2_InputAcmp2Out | ACMP2_OUT output assigned to XBARB2_IN7 input.
| kXBARB2_InputAcmp3Out | ACMP3_OUT output assigned to XBARB2_IN8 input.
| kXBARB2_InputAcmp4Out | ACMP4_OUT output assigned to XBARB2_IN9 input.
| kXBARB2_InputRESERVED10 | XBARB2_IN10 input is reserved.
| kXBARB2_InputRESERVED11 | XBARB2_IN11 input is reserved.
| kXBARB2_InputQtimer3Tmr0Output | QTIMER3_TMR0_OUTPUT output assigned to XBARB2_IN12 input.
| kXBARB2_InputQtimer3Tmr1Output | QTIMER3_TMR1_OUTPUT output assigned to XBARB2_IN13 input.
| kXBARB2_InputQtimer3Tmr2Output | QTIMER3_TMR2_OUTPUT output assigned to XBARB2_IN14 input.
| kXBARB2_InputQtimer3Tmr3Output | QTIMER3_TMR3_OUTPUT output assigned to XBARB2_IN15 input.
| kXBARB2_InputQtimer4Tmr0Output | QTIMER4_TMR0_OUTPUT output assigned to XBARB2_IN16 input.
| kXBARB2_InputQtimer4Tmr1Output | QTIMER4_TMR1_OUTPUT output assigned to XBARB2_IN17 input.
| kXBARB2_InputQtimer4Tmr2Output | QTIMER4_TMR2_OUTPUT output assigned to XBARB2_IN18 input.
| kXBARB2_InputQtimer4Tmr3Output | QTIMER4_TMR3_OUTPUT output assigned to XBARB2_IN19 input.
| kXBARB2_InputFlexpwm1Pwm1OutTrig01 | FLEXPWM1_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN20 input.
| kXBARB2_InputFlexpwm1Pwm2OutTrig01 | FLEXPWM1_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN21 input.
| kXBARB2_InputFlexpwm1Pwm3OutTrig01 | FLEXPWM1_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN22 input.
| kXBARB2_InputFlexpwm1Pwm4OutTrig01 | FLEXPWM1_PWM4_OUT_TRIG0_1 output assigned to XBARB2_IN23 input.
| kXBARB2_InputFlexpwm2Pwm1OutTrig01 | FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN24 input.
| kXBARB2_InputFlexpwm2Pwm2OutTrig01 | FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN25 input.
| kXBARB2_InputFlexpwm2Pwm3OutTrig01 | FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN26 input.
| kXBARB2_InputFlexpwm2Pwm4OutTrig01 | FLEXPWM2_PWM4_OUT_TRIG0_1 output assigned to XBARB2_IN27 input.
| kXBARB2_InputFlexpwm3Pwm1OutTrig01 | FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN28 input.
| kXBARB2_InputFlexpwm3Pwm2OutTrig01 | FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN29 input.
| kXBARB2_InputFlexpwm3Pwm3OutTrig01 | FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN30 input.
| kXBARB2_InputFlexpwm3Pwm4OutTrig01 | FLEXPWM3_PWM4_OUT_TRIG0_1 output assigned to XBARB2_IN31 input.
| kXBARB2_InputFlexpwm4Pwm1OutTrig01 | FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN32 input.
| kXBARB2_InputFlexpwm4Pwm2OutTrig01 | FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN33 input.
| kXBARB2_InputFlexpwm4Pwm3OutTrig01 | FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN34 input.
| kXBARB2_InputFlexpwm4Pwm4OutTrig01 | FLEXPWM4_PWM4_OUT_TRIG0_1 output assigned to XBARB2_IN35 input.
| kXBARB2_InputPitTrigger0 | PIT_TRIGGER0 output assigned to XBARB2_IN36 input.
| kXBARB2_InputPitTrigger1 | PIT_TRIGGER1 output assigned to XBARB2_IN37 input.
| kXBARB2_InputAdcEtcXbar0Coco0 | ADC_ETC_XBAR0_COCO0 output assigned to XBARB2_IN38 input.
| kXBARB2_InputAdcEtcXbar0Coco1 | ADC_ETC_XBAR0_COCO1 output assigned to XBARB2_IN39 input.
| kXBARB2_InputAdcEtcXbar0Coco2 | ADC_ETC_XBAR0_COCO2 output assigned to XBARB2_IN40 input.
| kXBARB2_InputAdcEtcXbar0Coco3 | ADC_ETC_XBAR0_COCO3 output assigned to XBARB2_IN41 input.
| kXBARB2_InputAdcEtcXbar1Coco0 | ADC_ETC_XBAR1_COCO0 output assigned to XBARB2_IN42 input.
| kXBARB2_InputAdcEtcXbar1Coco1 | ADC_ETC_XBAR1_COCO1 output assigned to XBARB2_IN43 input.
| kXBARB2_InputAdcEtcXbar1Coco2 | ADC_ETC_XBAR1_COCO2 output assigned to XBARB2_IN44 input.
| kXBARB2_InputAdcEtcXbar1Coco3 | ADC_ETC_XBAR1_COCO3 output assigned to XBARB2_IN45 input.
| kXBARB2_InputEnc1PosMatch | ENC1_POS_MATCH output assigned to XBARB2_IN46 input.
| kXBARB2_InputEnc2PosMatch | ENC2_POS_MATCH output assigned to XBARB2_IN47 input.
| kXBARB2_InputEnc3PosMatch | ENC3_POS_MATCH output assigned to XBARB2_IN48 input.
| kXBARB2_InputEnc4PosMatch | ENC4_POS_MATCH output assigned to XBARB2_IN49 input.
| kXBARB2_InputDmaDone0 | DMA_DONE0 output assigned to XBARB2_IN50 input.
| kXBARB2_InputDmaDone1 | DMA_DONE1 output assigned to XBARB2_IN51 input.
| kXBARB2_InputDmaDone2 | DMA_DONE2 output assigned to XBARB2_IN52 input.
| kXBARB2_InputDmaDone3 | DMA_DONE3 output assigned to XBARB2_IN53 input.
| kXBARB2_InputDmaDone4 | DMA_DONE4 output assigned to XBARB2_IN54 input.
| kXBARB2_InputDmaDone5 | DMA_DONE5 output assigned to XBARB2_IN55 input.
| kXBARB2_InputDmaDone6 | DMA_DONE6 output assigned to XBARB2_IN56 input.
| kXBARB2_InputDmaDone7 | DMA_DONE7 output assigned to XBARB2_IN57 input.
| kXBARB3_InputLogicLow | LOGIC_LOW output assigned to XBARB3_IN0 input.
| kXBARB3_InputLogicHigh | LOGIC_HIGH output assigned to XBARB3_IN1 input.
| kXBARB3_InputRESERVED2 | XBARB3_IN2 input is reserved.
| kXBARB3_InputRESERVED3 | XBARB3_IN3 input is reserved.
| kXBARB3_InputRESERVED4 | XBARB3_IN4 input is reserved.
| kXBARB3_InputRESERVED5 | XBARB3_IN5 input is reserved.
| kXBARB3_InputAcmp1Out | ACMP1_OUT output assigned to XBARB3_IN6 input.
| kXBARB3_InputAcmp2Out | ACMP2_OUT output assigned to XBARB3_IN7 input.
| kXBARB3_InputAcmp3Out | ACMP3_OUT output assigned to XBARB3_IN8 input.
| kXBARB3_InputAcmp4Out | ACMP4_OUT output assigned to XBARB3_IN9 input.
| kXBARB3_InputRESERVED10 | XBARB3_IN10 input is reserved.
| kXBARB3_InputRESERVED11 | XBARB3_IN11 input is reserved.
| kXBARB3_InputQtimer3Tmr0Output | QTIMER3_TMR0_OUTPUT output assigned to XBARB3_IN12 input.
| kXBARB3_InputQtimer3Tmr1Output | QTIMER3_TMR1_OUTPUT output assigned to XBARB3_IN13 input.
| kXBARB3_InputQtimer3Tmr2Output | QTIMER3_TMR2_OUTPUT output assigned to XBARB3_IN14 input.
| kXBARB3_InputQtimer3Tmr3Output | QTIMER3_TMR3_OUTPUT output assigned to XBARB3_IN15 input.
| kXBARB3_InputQtimer4Tmr0Output | QTIMER4_TMR0_OUTPUT output assigned to XBARB3_IN16 input.
| kXBARB3_InputQtimer4Tmr1Output | QTIMER4_TMR1_OUTPUT output assigned to XBARB3_IN17 input.
| kXBARB3_InputQtimer4Tmr2Output | QTIMER4_TMR2_OUTPUT output assigned to XBARB3_IN18 input.
| kXBARB3_InputQtimer4Tmr3Output | QTIMER4_TMR3_OUTPUT output assigned to XBARB3_IN19 input.
| kXBARB3_InputFlexpwm1Pwm1OutTrig01 | FLEXPWM1_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN20 input.
| kXBARB3_InputFlexpwm1Pwm2OutTrig01 | FLEXPWM1_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN21 input.
| kXBARB3_InputFlexpwm1Pwm3OutTrig01 | FLEXPWM1_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN22 input.
| kXBARB3_InputFlexpwm1Pwm4OutTrig01 | FLEXPWM1_PWM4_OUT_TRIG0_1 output assigned to XBARB3_IN23 input.
| kXBARB3_InputFlexpwm2Pwm1OutTrig01 | FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN24 input.
| kXBARB3_InputFlexpwm2Pwm2OutTrig01 | FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN25 input.
| kXBARB3_InputFlexpwm2Pwm3OutTrig01 | FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN26 input.
| kXBARB3_InputFlexpwm2Pwm4OutTrig01 | FLEXPWM2_PWM4_OUT_TRIG0_1 output assigned to XBARB3_IN27 input.
| kXBARB3_InputFlexpwm3Pwm1OutTrig01 | FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN28 input.
| kXBARB3_InputFlexpwm3Pwm2OutTrig01 | FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN29 input.
| kXBARB3_InputFlexpwm3Pwm3OutTrig01 | FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN30 input.
| kXBARB3_InputFlexpwm3Pwm4OutTrig01 | FLEXPWM3_PWM4_OUT_TRIG0_1 output assigned to XBARB3_IN31 input.
| kXBARB3_InputFlexpwm4Pwm1OutTrig01 | FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN32 input.
| kXBARB3_InputFlexpwm4Pwm2OutTrig01 | FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN33 input.
| kXBARB3_InputFlexpwm4Pwm3OutTrig01 | FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN34 input.
| kXBARB3_InputFlexpwm4Pwm4OutTrig01 | FLEXPWM4_PWM4_OUT_TRIG0_1 output assigned to XBARB3_IN35 input.
| kXBARB3_InputPitTrigger0 | PIT_TRIGGER0 output assigned to XBARB3_IN36 input.
| kXBARB3_InputPitTrigger1 | PIT_TRIGGER1 output assigned to XBARB3_IN37 input.
| kXBARB3_InputAdcEtcXbar0Coco0 | ADC_ETC_XBAR0_COCO0 output assigned to XBARB3_IN38 input.
| kXBARB3_InputAdcEtcXbar0Coco1 | ADC_ETC_XBAR0_COCO1 output assigned to XBARB3_IN39 input.
| kXBARB3_InputAdcEtcXbar0Coco2 | ADC_ETC_XBAR0_COCO2 output assigned to XBARB3_IN40 input.
| kXBARB3_InputAdcEtcXbar0Coco3 | ADC_ETC_XBAR0_COCO3 output assigned to XBARB3_IN41 input.
| kXBARB3_InputAdcEtcXbar1Coco0 | ADC_ETC_XBAR1_COCO0 output assigned to XBARB3_IN42 input.
| kXBARB3_InputAdcEtcXbar1Coco1 | ADC_ETC_XBAR1_COCO1 output assigned to XBARB3_IN43 input.
| kXBARB3_InputAdcEtcXbar1Coco2 | ADC_ETC_XBAR1_COCO2 output assigned to XBARB3_IN44 input.
| kXBARB3_InputAdcEtcXbar1Coco3 | ADC_ETC_XBAR1_COCO3 output assigned to XBARB3_IN45 input.
| kXBARB3_InputEnc1PosMatch | ENC1_POS_MATCH output assigned to XBARB3_IN46 input.
| kXBARB3_InputEnc2PosMatch | ENC2_POS_MATCH output assigned to XBARB3_IN47 input.
| kXBARB3_InputEnc3PosMatch | ENC3_POS_MATCH output assigned to XBARB3_IN48 input.
| kXBARB3_InputEnc4PosMatch | ENC4_POS_MATCH output assigned to XBARB3_IN49 input.
| kXBARB3_InputDmaDone0 | DMA_DONE0 output assigned to XBARB3_IN50 input.
| kXBARB3_InputDmaDone1 | DMA_DONE1 output assigned to XBARB3_IN51 input.
| kXBARB3_InputDmaDone2 | DMA_DONE2 output assigned to XBARB3_IN52 input.
| kXBARB3_InputDmaDone3 | DMA_DONE3 output assigned to XBARB3_IN53 input.
| kXBARB3_InputDmaDone4 | DMA_DONE4 output assigned to XBARB3_IN54 input.
| kXBARB3_InputDmaDone5 | DMA_DONE5 output assigned to XBARB3_IN55 input.
| kXBARB3_InputDmaDone6 | DMA_DONE6 output assigned to XBARB3_IN56 input.
| kXBARB3_InputDmaDone7 | DMA_DONE7 output assigned to XBARB3_IN57 input.
| kXBARA1_InputRESERVED2 | XBARA1_IN2 input is reserved.
| kXBARA1_InputRESERVED3 | XBARA1_IN3 input is reserved.
| kXBARA1_InputIomuxXbarInout20 | IOMUX_XBAR_INOUT20 output assigned to XBARA1_IN20 input.
| kXBARA1_InputIomuxXbarInout21 | IOMUX_XBAR_INOUT21 output assigned to XBARA1_IN21 input.
| kXBARA1_InputIomuxXbarInout22 | IOMUX_XBAR_INOUT22 output assigned to XBARA1_IN22 input.
| kXBARA1_InputIomuxXbarInout23 | IOMUX_XBAR_INOUT23 output assigned to XBARA1_IN23 input.
| kXBARA1_InputIomuxXbarInout24 | IOMUX_XBAR_INOUT24 output assigned to XBARA1_IN24 input.
| kXBARA1_InputIomuxXbarInout25 | IOMUX_XBAR_INOUT25 output assigned to XBARA1_IN25 input.
| kXBARA1_InputIomuxXbarInout26 | IOMUX_XBAR_INOUT26 output assigned to XBARA1_IN26 input.
| kXBARA1_InputIomuxXbarInout27 | IOMUX_XBAR_INOUT27 output assigned to XBARA1_IN27 input.
| kXBARA1_InputIomuxXbarInout28 | IOMUX_XBAR_INOUT28 output assigned to XBARA1_IN28 input.
| kXBARA1_InputIomuxXbarInout29 | IOMUX_XBAR_INOUT29 output assigned to XBARA1_IN29 input.
| kXBARA1_InputIomuxXbarInout30 | IOMUX_XBAR_INOUT30 output assigned to XBARA1_IN30 input.
| kXBARA1_InputIomuxXbarInout31 | IOMUX_XBAR_INOUT31 output assigned to XBARA1_IN31 input.
| kXBARA1_InputIomuxXbarInout32 | IOMUX_XBAR_INOUT32 output assigned to XBARA1_IN32 input.
| kXBARA1_InputIomuxXbarInout33 | IOMUX_XBAR_INOUT33 output assigned to XBARA1_IN33 input.
| kXBARA1_InputIomuxXbarInout34 | IOMUX_XBAR_INOUT34 output assigned to XBARA1_IN34 input.
| kXBARA1_InputIomuxXbarInout35 | IOMUX_XBAR_INOUT35 output assigned to XBARA1_IN35 input.
| kXBARA1_InputIomuxXbarInout36 | IOMUX_XBAR_INOUT36 output assigned to XBARA1_IN36 input.
| kXBARA1_InputIomuxXbarInout37 | IOMUX_XBAR_INOUT37 output assigned to XBARA1_IN37 input.
| kXBARA1_InputIomuxXbarInout38 | IOMUX_XBAR_INOUT38 output assigned to XBARA1_IN38 input.
| kXBARA1_InputIomuxXbarInout39 | IOMUX_XBAR_INOUT39 output assigned to XBARA1_IN39 input.
| kXBARA1_InputIomuxXbarInout40 | IOMUX_XBAR_INOUT40 output assigned to XBARA1_IN40 input.
| kXBARA1_InputRESERVED41 | XBARA1_IN41 input is reserved.
| kXBARA1_InputAcmp1Out | ACMP1_OUT output assigned to XBARA1_IN42 input.
| kXBARA1_InputAcmp2Out | ACMP2_OUT output assigned to XBARA1_IN43 input.
| kXBARA1_InputAcmp3Out | ACMP3_OUT output assigned to XBARA1_IN44 input.
| kXBARA1_InputAcmp4Out | ACMP4_OUT output assigned to XBARA1_IN45 input.
| kXBARA1_InputRESERVED46 | XBARA1_IN46 input is reserved.
| kXBARA1_InputRESERVED47 | XBARA1_IN47 input is reserved.
| kXBARA1_InputRESERVED48 | XBARA1_IN48 input is reserved.
| kXBARA1_InputRESERVED49 | XBARA1_IN49 input is reserved.
| kXBARA1_InputQtimer1Timer0 | QTIMER1_TIMER0 output assigned to XBARA1_IN50 input.
| kXBARA1_InputQtimer1Timer1 | QTIMER1_TIMER1 output assigned to XBARA1_IN51 input.
| kXBARA1_InputQtimer1Timer2 | QTIMER1_TIMER2 output assigned to XBARA1_IN52 input.
| kXBARA1_InputQtimer1Timer3 | QTIMER1_TIMER3 output assigned to XBARA1_IN53 input.
| kXBARA1_InputQtimer2Timer0 | QTIMER2_TIMER0 output assigned to XBARA1_IN54 input.
| kXBARA1_InputQtimer2Timer1 | QTIMER2_TIMER1 output assigned to XBARA1_IN55 input.
| kXBARA1_InputQtimer2Timer2 | QTIMER2_TIMER2 output assigned to XBARA1_IN56 input.
| kXBARA1_InputQtimer2Timer3 | QTIMER2_TIMER3 output assigned to XBARA1_IN57 input.
| kXBARA1_InputQtimer3Timer0 | QTIMER3_TIMER0 output assigned to XBARA1_IN58 input.
| kXBARA1_InputQtimer3Timer1 | QTIMER3_TIMER1 output assigned to XBARA1_IN59 input.
| kXBARA1_InputQtimer3Timer2 | QTIMER3_TIMER2 output assigned to XBARA1_IN60 input.
| kXBARA1_InputQtimer3Timer3 | QTIMER3_TIMER3 output assigned to XBARA1_IN61 input.
| kXBARA1_InputQtimer4Timer0 | QTIMER4_TIMER0 output assigned to XBARA1_IN62 input.
| kXBARA1_InputQtimer4Timer1 | QTIMER4_TIMER1 output assigned to XBARA1_IN63 input.
| kXBARA1_InputQtimer4Timer2 | QTIMER4_TIMER2 output assigned to XBARA1_IN64 input.
| kXBARA1_InputQtimer4Timer3 | QTIMER4_TIMER3 output assigned to XBARA1_IN65 input.
| kXBARA1_InputRESERVED66 | XBARA1_IN66 input is reserved.
| kXBARA1_InputRESERVED67 | XBARA1_IN67 input is reserved.
| kXBARA1_InputRESERVED68 | XBARA1_IN68 input is reserved.
| kXBARA1_InputRESERVED69 | XBARA1_IN69 input is reserved.
| kXBARA1_InputRESERVED70 | XBARA1_IN70 input is reserved.
| kXBARA1_InputRESERVED71 | XBARA1_IN71 input is reserved.
| kXBARA1_InputRESERVED72 | XBARA1_IN72 input is reserved.
| kXBARA1_InputRESERVED73 | XBARA1_IN73 input is reserved.
| kXBARA1_InputFlexpwm1Pwm0OutTrig0 | FLEXPWM1_PWM0_OUT_TRIG0 output assigned to XBARA1_IN74 input.
| kXBARA1_InputFlexpwm1Pwm0OutTrig1 | FLEXPWM1_PWM0_OUT_TRIG1 output assigned to XBARA1_IN75 input.
| kXBARA1_InputFlexpwm1Pwm1OutTrig0 | FLEXPWM1_PWM1_OUT_TRIG0 output assigned to XBARA1_IN76 input.
| kXBARA1_InputFlexpwm1Pwm1OutTrig1 | FLEXPWM1_PWM1_OUT_TRIG1 output assigned to XBARA1_IN77 input.
| kXBARA1_InputFlexpwm1Pwm2OutTrig0 | FLEXPWM1_PWM2_OUT_TRIG0 output assigned to XBARA1_IN78 input.
| kXBARA1_InputFlexpwm1Pwm2OutTrig1 | FLEXPWM1_PWM2_OUT_TRIG1 output assigned to XBARA1_IN79 input.
| kXBARA1_InputFlexpwm1Pwm3OutTrig0 | FLEXPWM1_PWM3_OUT_TRIG0 output assigned to XBARA1_IN80 input.
| kXBARA1_InputFlexpwm1Pwm3OutTrig1 | FLEXPWM1_PWM3_OUT_TRIG1 output assigned to XBARA1_IN81 input.
| kXBARA1_InputFlexpwm2Pwm0OutTrig01 | FLEXPWM2_PWM0_OUT_TRIG0_1 output assigned to XBARA1_IN82 input.
| kXBARA1_InputFlexpwm2Pwm1OutTrig01 | FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN83 input.
| kXBARA1_InputFlexpwm2Pwm2OutTrig01 | FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN84 input.
| kXBARA1_InputFlexpwm2Pwm3OutTrig01 | FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN85 input.
| kXBARA1_InputFlexpwm3Pwm0OutTrig01 | FLEXPWM3_PWM0_OUT_TRIG0_1 output assigned to XBARA1_IN86 input.
| kXBARA1_InputFlexpwm3Pwm1OutTrig01 | FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN87 input.
| kXBARA1_InputFlexpwm3Pwm2OutTrig01 | FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN88 input.
| kXBARA1_InputFlexpwm3Pwm3OutTrig01 | FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN89 input.
| kXBARA1_InputFlexpwm4Pwm0OutTrig01 | FLEXPWM4_PWM0_OUT_TRIG0_1 output assigned to XBARA1_IN90 input.
| kXBARA1_InputFlexpwm4Pwm1OutTrig01 | FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARA1_IN91 input.
| kXBARA1_InputFlexpwm4Pwm2OutTrig01 | FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARA1_IN92 input.
| kXBARA1_InputFlexpwm4Pwm3OutTrig01 | FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARA1_IN93 input.
| kXBARA1_InputRESERVED94 | XBARA1_IN94 input is reserved.
| kXBARA1_InputRESERVED95 | XBARA1_IN95 input is reserved.
| kXBARA1_InputRESERVED96 | XBARA1_IN96 input is reserved.
| kXBARA1_InputRESERVED97 | XBARA1_IN97 input is reserved.
| kXBARA1_InputRESERVED98 | XBARA1_IN98 input is reserved.
| kXBARA1_InputRESERVED99 | XBARA1_IN99 input is reserved.
| kXBARA1_InputRESERVED100 | XBARA1_IN100 input is reserved.
| kXBARA1_InputRESERVED101 | XBARA1_IN101 input is reserved.
| kXBARA1_InputPit1Trigger0 | PIT1_TRIGGER0 output assigned to XBARA1_IN102 input.
| kXBARA1_InputPit1Trigger1 | PIT1_TRIGGER1 output assigned to XBARA1_IN103 input.
| kXBARA1_InputPit1Trigger2 | PIT1_TRIGGER2 output assigned to XBARA1_IN104 input.
| kXBARA1_InputPit1Trigger3 | PIT1_TRIGGER3 output assigned to XBARA1_IN105 input.
| kXBARA1_InputDec1PosMatch | DEC1_POS_MATCH output assigned to XBARA1_IN106 input.
| kXBARA1_InputDec2PosMatch | DEC2_POS_MATCH output assigned to XBARA1_IN107 input.
| kXBARA1_InputDec3PosMatch | DEC3_POS_MATCH output assigned to XBARA1_IN108 input.
| kXBARA1_InputDec4PosMatch | DEC4_POS_MATCH output assigned to XBARA1_IN109 input.
| kXBARA1_InputRESERVED110 | XBARA1_IN110 input is reserved.
| kXBARA1_InputRESERVED111 | XBARA1_IN111 input is reserved.
| kXBARA1_InputDmaDone0 | DMA_DONE0 output assigned to XBARA1_IN112 input.
| kXBARA1_InputDmaDone1 | DMA_DONE1 output assigned to XBARA1_IN113 input.
| kXBARA1_InputDmaDone2 | DMA_DONE2 output assigned to XBARA1_IN114 input.
| kXBARA1_InputDmaDone3 | DMA_DONE3 output assigned to XBARA1_IN115 input.
| kXBARA1_InputDmaDone4 | DMA_DONE4 output assigned to XBARA1_IN116 input.
| kXBARA1_InputDmaDone5 | DMA_DONE5 output assigned to XBARA1_IN117 input.
| kXBARA1_InputDmaDone6 | DMA_DONE6 output assigned to XBARA1_IN118 input.
| kXBARA1_InputDmaDone7 | DMA_DONE7 output assigned to XBARA1_IN119 input.
| kXBARA1_InputDmaLpsrDone0 | DMA_LPSR_DONE0 output assigned to XBARA1_IN120 input.
| kXBARA1_InputDmaLpsrDone1 | DMA_LPSR_DONE1 output assigned to XBARA1_IN121 input.
| kXBARA1_InputDmaLpsrDone2 | DMA_LPSR_DONE2 output assigned to XBARA1_IN122 input.
| kXBARA1_InputDmaLpsrDone3 | DMA_LPSR_DONE3 output assigned to XBARA1_IN123 input.
| kXBARA1_InputDmaLpsrDone4 | DMA_LPSR_DONE4 output assigned to XBARA1_IN124 input.
| kXBARA1_InputDmaLpsrDone5 | DMA_LPSR_DONE5 output assigned to XBARA1_IN125 input.
| kXBARA1_InputDmaLpsrDone6 | DMA_LPSR_DONE6 output assigned to XBARA1_IN126 input.
| kXBARA1_InputDmaLpsrDone7 | DMA_LPSR_DONE7 output assigned to XBARA1_IN127 input.
| kXBARA1_InputAoi1Out0 | AOI1_OUT0 output assigned to XBARA1_IN128 input.
| kXBARA1_InputAoi1Out1 | AOI1_OUT1 output assigned to XBARA1_IN129 input.
| kXBARA1_InputAoi1Out2 | AOI1_OUT2 output assigned to XBARA1_IN130 input.
| kXBARA1_InputAoi1Out3 | AOI1_OUT3 output assigned to XBARA1_IN131 input.
| kXBARA1_InputAoi2Out0 | AOI2_OUT0 output assigned to XBARA1_IN132 input.
| kXBARA1_InputAoi2Out1 | AOI2_OUT1 output assigned to XBARA1_IN133 input.
| kXBARA1_InputAoi2Out2 | AOI2_OUT2 output assigned to XBARA1_IN134 input.
| kXBARA1_InputAoi2Out3 | AOI2_OUT3 output assigned to XBARA1_IN135 input.
| kXBARA1_InputAdcEtc0Coco0 | ADC_ETC0_COCO0 output assigned to XBARA1_IN136 input.
| kXBARA1_InputAdcEtc0Coco1 | ADC_ETC0_COCO1 output assigned to XBARA1_IN137 input.
| kXBARA1_InputAdcEtc0Coco2 | ADC_ETC0_COCO2 output assigned to XBARA1_IN138 input.
| kXBARA1_InputAdcEtc0Coco3 | ADC_ETC0_COCO3 output assigned to XBARA1_IN139 input.
| kXBARA1_InputAdcEtc1Coco0 | ADC_ETC1_COCO0 output assigned to XBARA1_IN140 input.
| kXBARA1_InputAdcEtc1Coco1 | ADC_ETC1_COCO1 output assigned to XBARA1_IN141 input.
| kXBARA1_InputAdcEtc1Coco2 | ADC_ETC1_COCO2 output assigned to XBARA1_IN142 input.
| kXBARA1_InputAdcEtc1Coco3 | ADC_ETC1_COCO3 output assigned to XBARA1_IN143 input.
| kXBARB2_InputAcmp1Out | ACMP1_OUT output assigned to XBARB2_IN2 input.
| kXBARB2_InputAcmp2Out | ACMP2_OUT output assigned to XBARB2_IN3 input.
| kXBARB2_InputAcmp3Out | ACMP3_OUT output assigned to XBARB2_IN4 input.
| kXBARB2_InputAcmp4Out | ACMP4_OUT output assigned to XBARB2_IN5 input.
| kXBARB2_InputRESERVED6 | XBARB2_IN6 input is reserved.
| kXBARB2_InputRESERVED7 | XBARB2_IN7 input is reserved.
| kXBARB2_InputRESERVED8 | XBARB2_IN8 input is reserved.
| kXBARB2_InputRESERVED9 | XBARB2_IN9 input is reserved.
| kXBARB2_InputQtimer1Timer0 | QTIMER1_TIMER0 output assigned to XBARB2_IN10 input.
| kXBARB2_InputQtimer1Timer1 | QTIMER1_TIMER1 output assigned to XBARB2_IN11 input.
| kXBARB2_InputQtimer1Timer2 | QTIMER1_TIMER2 output assigned to XBARB2_IN12 input.
| kXBARB2_InputQtimer1Timer3 | QTIMER1_TIMER3 output assigned to XBARB2_IN13 input.
| kXBARB2_InputQtimer2Timer0 | QTIMER2_TIMER0 output assigned to XBARB2_IN14 input.
| kXBARB2_InputQtimer2Timer1 | QTIMER2_TIMER1 output assigned to XBARB2_IN15 input.
| kXBARB2_InputQtimer2Timer2 | QTIMER2_TIMER2 output assigned to XBARB2_IN16 input.
| kXBARB2_InputQtimer2Timer3 | QTIMER2_TIMER3 output assigned to XBARB2_IN17 input.
| kXBARB2_InputQtimer3Timer0 | QTIMER3_TIMER0 output assigned to XBARB2_IN18 input.
| kXBARB2_InputQtimer3Timer1 | QTIMER3_TIMER1 output assigned to XBARB2_IN19 input.
| kXBARB2_InputQtimer3Timer2 | QTIMER3_TIMER2 output assigned to XBARB2_IN20 input.
| kXBARB2_InputQtimer3Timer3 | QTIMER3_TIMER3 output assigned to XBARB2_IN21 input.
| kXBARB2_InputQtimer4Timer0 | QTIMER4_TIMER0 output assigned to XBARB2_IN22 input.
| kXBARB2_InputQtimer4Timer1 | QTIMER4_TIMER1 output assigned to XBARB2_IN23 input.
| kXBARB2_InputQtimer4Timer2 | QTIMER4_TIMER2 output assigned to XBARB2_IN24 input.
| kXBARB2_InputQtimer4Timer3 | QTIMER4_TIMER3 output assigned to XBARB2_IN25 input.
| kXBARB2_InputRESERVED26 | XBARB2_IN26 input is reserved.
| kXBARB2_InputRESERVED27 | XBARB2_IN27 input is reserved.
| kXBARB2_InputRESERVED28 | XBARB2_IN28 input is reserved.
| kXBARB2_InputRESERVED29 | XBARB2_IN29 input is reserved.
| kXBARB2_InputRESERVED30 | XBARB2_IN30 input is reserved.
| kXBARB2_InputRESERVED31 | XBARB2_IN31 input is reserved.
| kXBARB2_InputRESERVED32 | XBARB2_IN32 input is reserved.
| kXBARB2_InputRESERVED33 | XBARB2_IN33 input is reserved.
| kXBARB2_InputFlexpwm1Pwm0OutTrig01 | FLEXPWM1_PWM0_OUT_TRIG0_1 output assigned to XBARB2_IN34 input.
| kXBARB2_InputFlexpwm1Pwm1OutTrig01 | FLEXPWM1_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN35 input.
| kXBARB2_InputFlexpwm1Pwm2OutTrig01 | FLEXPWM1_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN36 input.
| kXBARB2_InputFlexpwm1Pwm3OutTrig01 | FLEXPWM1_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN37 input.
| kXBARB2_InputFlexpwm2Pwm0OutTrig01 | FLEXPWM2_PWM0_OUT_TRIG0_1 output assigned to XBARB2_IN38 input.
| kXBARB2_InputFlexpwm2Pwm1OutTrig01 | FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN39 input.
| kXBARB2_InputFlexpwm2Pwm2OutTrig01 | FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN40 input.
| kXBARB2_InputFlexpwm2Pwm3OutTrig01 | FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN41 input.
| kXBARB2_InputFlexpwm3Pwm0OutTrig01 | FLEXPWM3_PWM0_OUT_TRIG0_1 output assigned to XBARB2_IN42 input.
| kXBARB2_InputFlexpwm3Pwm1OutTrig01 | FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN43 input.
| kXBARB2_InputFlexpwm3Pwm2OutTrig01 | FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN44 input.
| kXBARB2_InputFlexpwm3Pwm3OutTrig01 | FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN45 input.
| kXBARB2_InputFlexpwm4Pwm0OutTrig01 | FLEXPWM4_PWM0_OUT_TRIG0_1 output assigned to XBARB2_IN46 input.
| kXBARB2_InputFlexpwm4Pwm1OutTrig01 | FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARB2_IN47 input.
| kXBARB2_InputFlexpwm4Pwm2OutTrig01 | FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARB2_IN48 input.
| kXBARB2_InputFlexpwm4Pwm3OutTrig01 | FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARB2_IN49 input.
| kXBARB2_InputRESERVED50 | XBARB2_IN50 input is reserved.
| kXBARB2_InputRESERVED51 | XBARB2_IN51 input is reserved.
| kXBARB2_InputRESERVED52 | XBARB2_IN52 input is reserved.
| kXBARB2_InputRESERVED53 | XBARB2_IN53 input is reserved.
| kXBARB2_InputRESERVED54 | XBARB2_IN54 input is reserved.
| kXBARB2_InputRESERVED55 | XBARB2_IN55 input is reserved.
| kXBARB2_InputRESERVED56 | XBARB2_IN56 input is reserved.
| kXBARB2_InputRESERVED57 | XBARB2_IN57 input is reserved.
| kXBARB2_InputPit1Trigger0 | PIT1_TRIGGER0 output assigned to XBARB2_IN58 input.
| kXBARB2_InputPit1Trigger1 | PIT1_TRIGGER1 output assigned to XBARB2_IN59 input.
| kXBARB2_InputAdcEtc0Coco0 | ADC_ETC0_COCO0 output assigned to XBARB2_IN60 input.
| kXBARB2_InputAdcEtc0Coco1 | ADC_ETC0_COCO1 output assigned to XBARB2_IN61 input.
| kXBARB2_InputAdcEtc0Coco2 | ADC_ETC0_COCO2 output assigned to XBARB2_IN62 input.
| kXBARB2_InputAdcEtc0Coco3 | ADC_ETC0_COCO3 output assigned to XBARB2_IN63 input.
| kXBARB2_InputAdcEtc1Coco0 | ADC_ETC1_COCO0 output assigned to XBARB2_IN64 input.
| kXBARB2_InputAdcEtc1Coco1 | ADC_ETC1_COCO1 output assigned to XBARB2_IN65 input.
| kXBARB2_InputAdcEtc1Coco2 | ADC_ETC1_COCO2 output assigned to XBARB2_IN66 input.
| kXBARB2_InputAdcEtc1Coco3 | ADC_ETC1_COCO3 output assigned to XBARB2_IN67 input.
| kXBARB2_InputRESERVED68 | XBARB2_IN68 input is reserved.
| kXBARB2_InputRESERVED69 | XBARB2_IN69 input is reserved.
| kXBARB2_InputRESERVED70 | XBARB2_IN70 input is reserved.
| kXBARB2_InputRESERVED71 | XBARB2_IN71 input is reserved.
| kXBARB2_InputRESERVED72 | XBARB2_IN72 input is reserved.
| kXBARB2_InputRESERVED73 | XBARB2_IN73 input is reserved.
| kXBARB2_InputRESERVED74 | XBARB2_IN74 input is reserved.
| kXBARB2_InputRESERVED75 | XBARB2_IN75 input is reserved.
| kXBARB2_InputDec1PosMatch | DEC1_POS_MATCH output assigned to XBARB2_IN76 input.
| kXBARB2_InputDec2PosMatch | DEC2_POS_MATCH output assigned to XBARB2_IN77 input.
| kXBARB2_InputDec3PosMatch | DEC3_POS_MATCH output assigned to XBARB2_IN78 input.
| kXBARB2_InputDec4PosMatch | DEC4_POS_MATCH output assigned to XBARB2_IN79 input.
| kXBARB2_InputRESERVED80 | XBARB2_IN80 input is reserved.
| kXBARB2_InputRESERVED81 | XBARB2_IN81 input is reserved.
| kXBARB2_InputDmaDone0 | DMA_DONE0 output assigned to XBARB2_IN82 input.
| kXBARB2_InputDmaDone1 | DMA_DONE1 output assigned to XBARB2_IN83 input.
| kXBARB2_InputDmaDone2 | DMA_DONE2 output assigned to XBARB2_IN84 input.
| kXBARB2_InputDmaDone3 | DMA_DONE3 output assigned to XBARB2_IN85 input.
| kXBARB2_InputDmaDone4 | DMA_DONE4 output assigned to XBARB2_IN86 input.
| kXBARB2_InputDmaDone5 | DMA_DONE5 output assigned to XBARB2_IN87 input.
| kXBARB2_InputDmaDone6 | DMA_DONE6 output assigned to XBARB2_IN88 input.
| kXBARB2_InputDmaDone7 | DMA_DONE7 output assigned to XBARB2_IN89 input.
| kXBARB2_InputDmaLpsrDone0 | DMA_LPSR_DONE0 output assigned to XBARB2_IN90 input.
| kXBARB2_InputDmaLpsrDone1 | DMA_LPSR_DONE1 output assigned to XBARB2_IN91 input.
| kXBARB2_InputDmaLpsrDone2 | DMA_LPSR_DONE2 output assigned to XBARB2_IN92 input.
| kXBARB2_InputDmaLpsrDone3 | DMA_LPSR_DONE3 output assigned to XBARB2_IN93 input.
| kXBARB2_InputDmaLpsrDone4 | DMA_LPSR_DONE4 output assigned to XBARB2_IN94 input.
| kXBARB2_InputDmaLpsrDone5 | DMA_LPSR_DONE5 output assigned to XBARB2_IN95 input.
| kXBARB2_InputDmaLpsrDone6 | DMA_LPSR_DONE6 output assigned to XBARB2_IN96 input.
| kXBARB2_InputDmaLpsrDone7 | DMA_LPSR_DONE7 output assigned to XBARB2_IN97 input.
| kXBARB3_InputAcmp1Out | ACMP1_OUT output assigned to XBARB3_IN2 input.
| kXBARB3_InputAcmp2Out | ACMP2_OUT output assigned to XBARB3_IN3 input.
| kXBARB3_InputAcmp3Out | ACMP3_OUT output assigned to XBARB3_IN4 input.
| kXBARB3_InputAcmp4Out | ACMP4_OUT output assigned to XBARB3_IN5 input.
| kXBARB3_InputRESERVED6 | XBARB3_IN6 input is reserved.
| kXBARB3_InputRESERVED7 | XBARB3_IN7 input is reserved.
| kXBARB3_InputRESERVED8 | XBARB3_IN8 input is reserved.
| kXBARB3_InputRESERVED9 | XBARB3_IN9 input is reserved.
| kXBARB3_InputQtimer1Timer0 | QTIMER1_TIMER0 output assigned to XBARB3_IN10 input.
| kXBARB3_InputQtimer1Timer1 | QTIMER1_TIMER1 output assigned to XBARB3_IN11 input.
| kXBARB3_InputQtimer1Timer2 | QTIMER1_TIMER2 output assigned to XBARB3_IN12 input.
| kXBARB3_InputQtimer1Timer3 | QTIMER1_TIMER3 output assigned to XBARB3_IN13 input.
| kXBARB3_InputQtimer2Timer0 | QTIMER2_TIMER0 output assigned to XBARB3_IN14 input.
| kXBARB3_InputQtimer2Timer1 | QTIMER2_TIMER1 output assigned to XBARB3_IN15 input.
| kXBARB3_InputQtimer2Timer2 | QTIMER2_TIMER2 output assigned to XBARB3_IN16 input.
| kXBARB3_InputQtimer2Timer3 | QTIMER2_TIMER3 output assigned to XBARB3_IN17 input.
| kXBARB3_InputQtimer3Timer0 | QTIMER3_TIMER0 output assigned to XBARB3_IN18 input.
| kXBARB3_InputQtimer3Timer1 | QTIMER3_TIMER1 output assigned to XBARB3_IN19 input.
| kXBARB3_InputQtimer3Timer2 | QTIMER3_TIMER2 output assigned to XBARB3_IN20 input.
| kXBARB3_InputQtimer3Timer3 | QTIMER3_TIMER3 output assigned to XBARB3_IN21 input.
| kXBARB3_InputQtimer4Timer0 | QTIMER4_TIMER0 output assigned to XBARB3_IN22 input.
| kXBARB3_InputQtimer4Timer1 | QTIMER4_TIMER1 output assigned to XBARB3_IN23 input.
| kXBARB3_InputQtimer4Timer2 | QTIMER4_TIMER2 output assigned to XBARB3_IN24 input.
| kXBARB3_InputQtimer4Timer3 | QTIMER4_TIMER3 output assigned to XBARB3_IN25 input.
| kXBARB3_InputRESERVED26 | XBARB3_IN26 input is reserved.
| kXBARB3_InputRESERVED27 | XBARB3_IN27 input is reserved.
| kXBARB3_InputRESERVED28 | XBARB3_IN28 input is reserved.
| kXBARB3_InputRESERVED29 | XBARB3_IN29 input is reserved.
| kXBARB3_InputRESERVED30 | XBARB3_IN30 input is reserved.
| kXBARB3_InputRESERVED31 | XBARB3_IN31 input is reserved.
| kXBARB3_InputRESERVED32 | XBARB3_IN32 input is reserved.
| kXBARB3_InputRESERVED33 | XBARB3_IN33 input is reserved.
| kXBARB3_InputFlexpwm1Pwm0OutTrig01 | FLEXPWM1_PWM0_OUT_TRIG0_1 output assigned to XBARB3_IN34 input.
| kXBARB3_InputFlexpwm1Pwm1OutTrig01 | FLEXPWM1_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN35 input.
| kXBARB3_InputFlexpwm1Pwm2OutTrig01 | FLEXPWM1_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN36 input.
| kXBARB3_InputFlexpwm1Pwm3OutTrig01 | FLEXPWM1_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN37 input.
| kXBARB3_InputFlexpwm2Pwm0OutTrig01 | FLEXPWM2_PWM0_OUT_TRIG0_1 output assigned to XBARB3_IN38 input.
| kXBARB3_InputFlexpwm2Pwm1OutTrig01 | FLEXPWM2_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN39 input.
| kXBARB3_InputFlexpwm2Pwm2OutTrig01 | FLEXPWM2_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN40 input.
| kXBARB3_InputFlexpwm2Pwm3OutTrig01 | FLEXPWM2_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN41 input.
| kXBARB3_InputFlexpwm3Pwm0OutTrig01 | FLEXPWM3_PWM0_OUT_TRIG0_1 output assigned to XBARB3_IN42 input.
| kXBARB3_InputFlexpwm3Pwm1OutTrig01 | FLEXPWM3_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN43 input.
| kXBARB3_InputFlexpwm3Pwm2OutTrig01 | FLEXPWM3_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN44 input.
| kXBARB3_InputFlexpwm3Pwm3OutTrig01 | FLEXPWM3_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN45 input.
| kXBARB3_InputFlexpwm4Pwm0OutTrig01 | FLEXPWM4_PWM0_OUT_TRIG0_1 output assigned to XBARB3_IN46 input.
| kXBARB3_InputFlexpwm4Pwm1OutTrig01 | FLEXPWM4_PWM1_OUT_TRIG0_1 output assigned to XBARB3_IN47 input.
| kXBARB3_InputFlexpwm4Pwm2OutTrig01 | FLEXPWM4_PWM2_OUT_TRIG0_1 output assigned to XBARB3_IN48 input.
| kXBARB3_InputFlexpwm4Pwm3OutTrig01 | FLEXPWM4_PWM3_OUT_TRIG0_1 output assigned to XBARB3_IN49 input.
| kXBARB3_InputRESERVED50 | XBARB3_IN50 input is reserved.
| kXBARB3_InputRESERVED51 | XBARB3_IN51 input is reserved.
| kXBARB3_InputRESERVED52 | XBARB3_IN52 input is reserved.
| kXBARB3_InputRESERVED53 | XBARB3_IN53 input is reserved.
| kXBARB3_InputRESERVED54 | XBARB3_IN54 input is reserved.
| kXBARB3_InputRESERVED55 | XBARB3_IN55 input is reserved.
| kXBARB3_InputRESERVED56 | XBARB3_IN56 input is reserved.
| kXBARB3_InputRESERVED57 | XBARB3_IN57 input is reserved.
| kXBARB3_InputPit1Trigger0 | PIT1_TRIGGER0 output assigned to XBARB3_IN58 input.
| kXBARB3_InputPit1Trigger1 | PIT1_TRIGGER1 output assigned to XBARB3_IN59 input.
| kXBARB3_InputAdcEtc0Coco0 | ADC_ETC0_COCO0 output assigned to XBARB3_IN60 input.
| kXBARB3_InputAdcEtc0Coco1 | ADC_ETC0_COCO1 output assigned to XBARB3_IN61 input.
| kXBARB3_InputAdcEtc0Coco2 | ADC_ETC0_COCO2 output assigned to XBARB3_IN62 input.
| kXBARB3_InputAdcEtc0Coco3 | ADC_ETC0_COCO3 output assigned to XBARB3_IN63 input.
| kXBARB3_InputAdcEtc1Coco0 | ADC_ETC1_COCO0 output assigned to XBARB3_IN64 input.
| kXBARB3_InputAdcEtc1Coco1 | ADC_ETC1_COCO1 output assigned to XBARB3_IN65 input.
| kXBARB3_InputAdcEtc1Coco2 | ADC_ETC1_COCO2 output assigned to XBARB3_IN66 input.
| kXBARB3_InputAdcEtc1Coco3 | ADC_ETC1_COCO3 output assigned to XBARB3_IN67 input.
| kXBARB3_InputRESERVED68 | XBARB3_IN68 input is reserved.
| kXBARB3_InputRESERVED69 | XBARB3_IN69 input is reserved.
| kXBARB3_InputRESERVED70 | XBARB3_IN70 input is reserved.
| kXBARB3_InputRESERVED71 | XBARB3_IN71 input is reserved.
| kXBARB3_InputRESERVED72 | XBARB3_IN72 input is reserved.
| kXBARB3_InputRESERVED73 | XBARB3_IN73 input is reserved.
| kXBARB3_InputRESERVED74 | XBARB3_IN74 input is reserved.
| kXBARB3_InputRESERVED75 | XBARB3_IN75 input is reserved.
| kXBARB3_InputDec1PosMatch | DEC1_POS_MATCH output assigned to XBARB3_IN76 input.
| kXBARB3_InputDec2PosMatch | DEC2_POS_MATCH output assigned to XBARB3_IN77 input.
| kXBARB3_InputDec3PosMatch | DEC3_POS_MATCH output assigned to XBARB3_IN78 input.
| kXBARB3_InputDec4PosMatch | DEC4_POS_MATCH output assigned to XBARB3_IN79 input.
| kXBARB3_InputRESERVED80 | XBARB3_IN80 input is reserved.
| kXBARB3_InputRESERVED81 | XBARB3_IN81 input is reserved.
| kXBARB3_InputDmaDone0 | DMA_DONE0 output assigned to XBARB3_IN82 input.
| kXBARB3_InputDmaDone1 | DMA_DONE1 output assigned to XBARB3_IN83 input.
| kXBARB3_InputDmaDone2 | DMA_DONE2 output assigned to XBARB3_IN84 input.
| kXBARB3_InputDmaDone3 | DMA_DONE3 output assigned to XBARB3_IN85 input.
| kXBARB3_InputDmaDone4 | DMA_DONE4 output assigned to XBARB3_IN86 input.
| kXBARB3_InputDmaDone5 | DMA_DONE5 output assigned to XBARB3_IN87 input.
| kXBARB3_InputDmaDone6 | DMA_DONE6 output assigned to XBARB3_IN88 input.
| kXBARB3_InputDmaDone7 | DMA_DONE7 output assigned to XBARB3_IN89 input.
| kXBARB3_InputDmaLpsrDone0 | DMA_LPSR_DONE0 output assigned to XBARB3_IN90 input.
| kXBARB3_InputDmaLpsrDone1 | DMA_LPSR_DONE1 output assigned to XBARB3_IN91 input.
| kXBARB3_InputDmaLpsrDone2 | DMA_LPSR_DONE2 output assigned to XBARB3_IN92 input.
| kXBARB3_InputDmaLpsrDone3 | DMA_LPSR_DONE3 output assigned to XBARB3_IN93 input.
| kXBARB3_InputDmaLpsrDone4 | DMA_LPSR_DONE4 output assigned to XBARB3_IN94 input.
| kXBARB3_InputDmaLpsrDone5 | DMA_LPSR_DONE5 output assigned to XBARB3_IN95 input.
| kXBARB3_InputDmaLpsrDone6 | DMA_LPSR_DONE6 output assigned to XBARB3_IN96 input.
| kXBARB3_InputDmaLpsrDone7 | DMA_LPSR_DONE7 output assigned to XBARB3_IN97 input.
