RTEMS 6.1
PDM DMA transfer handle, users should not touch the content of the handle. More...
#include <fsl_pdm_sdma.h>
Data Fields | |
| sdma_handle_t * | dmaHandle |
| uint8_t | nbytes |
| uint8_t | fifoWidth |
| uint8_t | endChannel |
| uint8_t | channelNums |
| uint32_t | count |
| uint32_t | state |
| uint32_t | eventSource |
| pdm_sdma_callback_t | callback |
| void * | userData |
| sdma_buffer_descriptor_t | bdPool [PDM_XFER_QUEUE_SIZE] |
| pdm_transfer_t | pdmQueue [PDM_XFER_QUEUE_SIZE] |
| size_t | transferSize [PDM_XFER_QUEUE_SIZE] |
| volatile uint8_t | queueUser |
| volatile uint8_t | queueDriver |
| sdma_buffer_descriptor_t _pdm_sdma_handle::bdPool[PDM_XFER_QUEUE_SIZE] |
BD pool for SDMA transfer.
| pdm_sdma_callback_t _pdm_sdma_handle::callback |
Callback for users while transfer finish or error occurs
| uint8_t _pdm_sdma_handle::channelNums |
total channel numbers
| uint32_t _pdm_sdma_handle::count |
The transfer data count in a DMA request
| sdma_handle_t* _pdm_sdma_handle::dmaHandle |
DMA handler for PDM send
| uint8_t _pdm_sdma_handle::endChannel |
The last enabled channel
| uint32_t _pdm_sdma_handle::eventSource |
PDM event source number
| uint8_t _pdm_sdma_handle::fifoWidth |
fifo width
| uint8_t _pdm_sdma_handle::nbytes |
eDMA minor byte transfer count initially configured.
| pdm_transfer_t _pdm_sdma_handle::pdmQueue[PDM_XFER_QUEUE_SIZE] |
Transfer queue storing queued transfer.
| volatile uint8_t _pdm_sdma_handle::queueDriver |
Index for driver to get the transfer data and size
| volatile uint8_t _pdm_sdma_handle::queueUser |
Index for user to queue transfer.
| uint32_t _pdm_sdma_handle::state |
Internal state for PDM eDMA transfer
| size_t _pdm_sdma_handle::transferSize[PDM_XFER_QUEUE_SIZE] |
Data bytes need to transfer
| void* _pdm_sdma_handle::userData |
User callback parameter
