RTEMS 6.1
BASIC_SETTING - Basic Setting
#define TSC_BASIC_SETTING_AUTO_MEASURE_MASK   (0x1U)
#define TSC_BASIC_SETTING_AUTO_MEASURE_SHIFT   (0U)
#define TSC_BASIC_SETTING_AUTO_MEASURE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_AUTO_MEASURE_SHIFT)) & TSC_BASIC_SETTING_AUTO_MEASURE_MASK)
#define TSC_BASIC_SETTING_WIRE_4_5_MASK   (0x10U)
#define TSC_BASIC_SETTING_WIRE_4_5_SHIFT   (4U)
#define TSC_BASIC_SETTING_WIRE_4_5(x)   (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_WIRE_4_5_SHIFT)) & TSC_BASIC_SETTING_WIRE_4_5_MASK)
#define TSC_BASIC_SETTING_MEASURE_DELAY_TIME_MASK   (0xFFFFFF00U)
#define TSC_BASIC_SETTING_MEASURE_DELAY_TIME_SHIFT   (8U)
#define TSC_BASIC_SETTING_MEASURE_DELAY_TIME(x)   (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_MEASURE_DELAY_TIME_SHIFT)) & TSC_BASIC_SETTING_MEASURE_DELAY_TIME_MASK)
PRE_CHARGE_TIME - Pre-charge Time
#define TSC_PRE_CHARGE_TIME_PRE_CHARGE_TIME_MASK   (0xFFFFFFFFU)
#define TSC_PRE_CHARGE_TIME_PRE_CHARGE_TIME_SHIFT   (0U)
#define TSC_PRE_CHARGE_TIME_PRE_CHARGE_TIME(x)   (((uint32_t)(((uint32_t)(x)) << TSC_PRE_CHARGE_TIME_PRE_CHARGE_TIME_SHIFT)) & TSC_PRE_CHARGE_TIME_PRE_CHARGE_TIME_MASK)
FLOW_CONTROL - Flow Control
#define TSC_FLOW_CONTROL_SW_RST_MASK   (0x1U)
#define TSC_FLOW_CONTROL_SW_RST_SHIFT   (0U)
#define TSC_FLOW_CONTROL_SW_RST(x)   (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_SW_RST_SHIFT)) & TSC_FLOW_CONTROL_SW_RST_MASK)
#define TSC_FLOW_CONTROL_START_MEASURE_MASK   (0x10U)
#define TSC_FLOW_CONTROL_START_MEASURE_SHIFT   (4U)
#define TSC_FLOW_CONTROL_START_MEASURE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_START_MEASURE_SHIFT)) & TSC_FLOW_CONTROL_START_MEASURE_MASK)
#define TSC_FLOW_CONTROL_DROP_MEASURE_MASK   (0x100U)
#define TSC_FLOW_CONTROL_DROP_MEASURE_SHIFT   (8U)
#define TSC_FLOW_CONTROL_DROP_MEASURE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_DROP_MEASURE_SHIFT)) & TSC_FLOW_CONTROL_DROP_MEASURE_MASK)
#define TSC_FLOW_CONTROL_START_SENSE_MASK   (0x1000U)
#define TSC_FLOW_CONTROL_START_SENSE_SHIFT   (12U)
#define TSC_FLOW_CONTROL_START_SENSE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_START_SENSE_SHIFT)) & TSC_FLOW_CONTROL_START_SENSE_MASK)
#define TSC_FLOW_CONTROL_DISABLE_MASK   (0x10000U)
#define TSC_FLOW_CONTROL_DISABLE_SHIFT   (16U)
#define TSC_FLOW_CONTROL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_DISABLE_SHIFT)) & TSC_FLOW_CONTROL_DISABLE_MASK)
MEASEURE_VALUE - Measure Value
#define TSC_MEASEURE_VALUE_Y_VALUE_MASK   (0xFFFU)
#define TSC_MEASEURE_VALUE_Y_VALUE_SHIFT   (0U)
#define TSC_MEASEURE_VALUE_Y_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_MEASEURE_VALUE_Y_VALUE_SHIFT)) & TSC_MEASEURE_VALUE_Y_VALUE_MASK)
#define TSC_MEASEURE_VALUE_X_VALUE_MASK   (0xFFF0000U)
#define TSC_MEASEURE_VALUE_X_VALUE_SHIFT   (16U)
#define TSC_MEASEURE_VALUE_X_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_MEASEURE_VALUE_X_VALUE_SHIFT)) & TSC_MEASEURE_VALUE_X_VALUE_MASK)
INT_EN - Interrupt Enable
#define TSC_INT_EN_MEASURE_INT_EN_MASK   (0x1U)
#define TSC_INT_EN_MEASURE_INT_EN_SHIFT   (0U)
#define TSC_INT_EN_MEASURE_INT_EN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_MEASURE_INT_EN_SHIFT)) & TSC_INT_EN_MEASURE_INT_EN_MASK)
#define TSC_INT_EN_DETECT_INT_EN_MASK   (0x10U)
#define TSC_INT_EN_DETECT_INT_EN_SHIFT   (4U)
#define TSC_INT_EN_DETECT_INT_EN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_DETECT_INT_EN_SHIFT)) & TSC_INT_EN_DETECT_INT_EN_MASK)
#define TSC_INT_EN_IDLE_SW_INT_EN_MASK   (0x1000U)
#define TSC_INT_EN_IDLE_SW_INT_EN_SHIFT   (12U)
#define TSC_INT_EN_IDLE_SW_INT_EN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_IDLE_SW_INT_EN_SHIFT)) & TSC_INT_EN_IDLE_SW_INT_EN_MASK)
INT_SIG_EN - Interrupt Signal Enable
#define TSC_INT_SIG_EN_MEASURE_SIG_EN_MASK   (0x1U)
#define TSC_INT_SIG_EN_MEASURE_SIG_EN_SHIFT   (0U)
#define TSC_INT_SIG_EN_MEASURE_SIG_EN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_MEASURE_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_MEASURE_SIG_EN_MASK)
#define TSC_INT_SIG_EN_DETECT_SIG_EN_MASK   (0x10U)
#define TSC_INT_SIG_EN_DETECT_SIG_EN_SHIFT   (4U)
#define TSC_INT_SIG_EN_DETECT_SIG_EN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_DETECT_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_DETECT_SIG_EN_MASK)
#define TSC_INT_SIG_EN_VALID_SIG_EN_MASK   (0x100U)
#define TSC_INT_SIG_EN_VALID_SIG_EN_SHIFT   (8U)
#define TSC_INT_SIG_EN_VALID_SIG_EN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_VALID_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_VALID_SIG_EN_MASK)
#define TSC_INT_SIG_EN_IDLE_SW_SIG_EN_MASK   (0x1000U)
#define TSC_INT_SIG_EN_IDLE_SW_SIG_EN_SHIFT   (12U)
#define TSC_INT_SIG_EN_IDLE_SW_SIG_EN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_IDLE_SW_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_IDLE_SW_SIG_EN_MASK)
INT_STATUS - Intterrupt Status
#define TSC_INT_STATUS_MEASURE_MASK   (0x1U)
#define TSC_INT_STATUS_MEASURE_SHIFT   (0U)
#define TSC_INT_STATUS_MEASURE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_MEASURE_SHIFT)) & TSC_INT_STATUS_MEASURE_MASK)
#define TSC_INT_STATUS_DETECT_MASK   (0x10U)
#define TSC_INT_STATUS_DETECT_SHIFT   (4U)
#define TSC_INT_STATUS_DETECT(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_DETECT_SHIFT)) & TSC_INT_STATUS_DETECT_MASK)
#define TSC_INT_STATUS_VALID_MASK   (0x100U)
#define TSC_INT_STATUS_VALID_SHIFT   (8U)
#define TSC_INT_STATUS_VALID(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_VALID_SHIFT)) & TSC_INT_STATUS_VALID_MASK)
#define TSC_INT_STATUS_IDLE_SW_MASK   (0x1000U)
#define TSC_INT_STATUS_IDLE_SW_SHIFT   (12U)
#define TSC_INT_STATUS_IDLE_SW(x)   (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_IDLE_SW_SHIFT)) & TSC_INT_STATUS_IDLE_SW_MASK)
DEBUG_MODE - Debug Mode Register
#define TSC_DEBUG_MODE_ADC_CONV_VALUE_MASK   (0xFFFU)
#define TSC_DEBUG_MODE_ADC_CONV_VALUE_SHIFT   (0U)
#define TSC_DEBUG_MODE_ADC_CONV_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_CONV_VALUE_SHIFT)) & TSC_DEBUG_MODE_ADC_CONV_VALUE_MASK)
#define TSC_DEBUG_MODE_ADC_COCO_MASK   (0x1000U)
#define TSC_DEBUG_MODE_ADC_COCO_SHIFT   (12U)
#define TSC_DEBUG_MODE_ADC_COCO(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_MASK)
#define TSC_DEBUG_MODE_EXT_HWTS_MASK   (0x1F0000U)
#define TSC_DEBUG_MODE_EXT_HWTS_SHIFT   (16U)
#define TSC_DEBUG_MODE_EXT_HWTS(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_EXT_HWTS_SHIFT)) & TSC_DEBUG_MODE_EXT_HWTS_MASK)
#define TSC_DEBUG_MODE_TRIGGER_MASK   (0x1000000U)
#define TSC_DEBUG_MODE_TRIGGER_SHIFT   (24U)
#define TSC_DEBUG_MODE_TRIGGER(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_TRIGGER_SHIFT)) & TSC_DEBUG_MODE_TRIGGER_MASK)
#define TSC_DEBUG_MODE_ADC_COCO_CLEAR_MASK   (0x2000000U)
#define TSC_DEBUG_MODE_ADC_COCO_CLEAR_SHIFT   (25U)
#define TSC_DEBUG_MODE_ADC_COCO_CLEAR(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_CLEAR_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_CLEAR_MASK)
#define TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_MASK   (0x4000000U)
#define TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_SHIFT   (26U)
#define TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_MASK)
#define TSC_DEBUG_MODE_DEBUG_EN_MASK   (0x10000000U)
#define TSC_DEBUG_MODE_DEBUG_EN_SHIFT   (28U)
#define TSC_DEBUG_MODE_DEBUG_EN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_DEBUG_EN_SHIFT)) & TSC_DEBUG_MODE_DEBUG_EN_MASK)
DEBUG_MODE2 - Debug Mode Register 2
#define TSC_DEBUG_MODE2_XPUL_PULL_DOWN_MASK   (0x1U)
#define TSC_DEBUG_MODE2_XPUL_PULL_DOWN_SHIFT   (0U)
#define TSC_DEBUG_MODE2_XPUL_PULL_DOWN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_XPUL_PULL_DOWN_MASK)
#define TSC_DEBUG_MODE2_XPUL_PULL_UP_MASK   (0x2U)
#define TSC_DEBUG_MODE2_XPUL_PULL_UP_SHIFT   (1U)
#define TSC_DEBUG_MODE2_XPUL_PULL_UP(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XPUL_PULL_UP_MASK)
#define TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_MASK   (0x4U)
#define TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_SHIFT   (2U)
#define TSC_DEBUG_MODE2_XPUL_200K_PULL_UP(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_MASK)
#define TSC_DEBUG_MODE2_XNUR_PULL_DOWN_MASK   (0x8U)
#define TSC_DEBUG_MODE2_XNUR_PULL_DOWN_SHIFT   (3U)
#define TSC_DEBUG_MODE2_XNUR_PULL_DOWN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_XNUR_PULL_DOWN_MASK)
#define TSC_DEBUG_MODE2_XNUR_PULL_UP_MASK   (0x10U)
#define TSC_DEBUG_MODE2_XNUR_PULL_UP_SHIFT   (4U)
#define TSC_DEBUG_MODE2_XNUR_PULL_UP(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XNUR_PULL_UP_MASK)
#define TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_MASK   (0x20U)
#define TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_SHIFT   (5U)
#define TSC_DEBUG_MODE2_XNUR_200K_PULL_UP(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_MASK)
#define TSC_DEBUG_MODE2_YPLL_PULL_DOWN_MASK   (0x40U)
#define TSC_DEBUG_MODE2_YPLL_PULL_DOWN_SHIFT   (6U)
#define TSC_DEBUG_MODE2_YPLL_PULL_DOWN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_YPLL_PULL_DOWN_MASK)
#define TSC_DEBUG_MODE2_YPLL_PULL_UP_MASK   (0x80U)
#define TSC_DEBUG_MODE2_YPLL_PULL_UP_SHIFT   (7U)
#define TSC_DEBUG_MODE2_YPLL_PULL_UP(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YPLL_PULL_UP_MASK)
#define TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_MASK   (0x100U)
#define TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_SHIFT   (8U)
#define TSC_DEBUG_MODE2_YPLL_200K_PULL_UP(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_MASK)
#define TSC_DEBUG_MODE2_YNLR_PULL_DOWN_MASK   (0x200U)
#define TSC_DEBUG_MODE2_YNLR_PULL_DOWN_SHIFT   (9U)
#define TSC_DEBUG_MODE2_YNLR_PULL_DOWN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_YNLR_PULL_DOWN_MASK)
#define TSC_DEBUG_MODE2_YNLR_PULL_UP_MASK   (0x400U)
#define TSC_DEBUG_MODE2_YNLR_PULL_UP_SHIFT   (10U)
#define TSC_DEBUG_MODE2_YNLR_PULL_UP(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YNLR_PULL_UP_MASK)
#define TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_MASK   (0x800U)
#define TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_SHIFT   (11U)
#define TSC_DEBUG_MODE2_YNLR_200K_PULL_UP(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_MASK)
#define TSC_DEBUG_MODE2_WIPER_PULL_DOWN_MASK   (0x1000U)
#define TSC_DEBUG_MODE2_WIPER_PULL_DOWN_SHIFT   (12U)
#define TSC_DEBUG_MODE2_WIPER_PULL_DOWN(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_WIPER_PULL_DOWN_MASK)
#define TSC_DEBUG_MODE2_WIPER_PULL_UP_MASK   (0x2000U)
#define TSC_DEBUG_MODE2_WIPER_PULL_UP_SHIFT   (13U)
#define TSC_DEBUG_MODE2_WIPER_PULL_UP(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_WIPER_PULL_UP_MASK)
#define TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_MASK   (0x4000U)
#define TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_SHIFT   (14U)
#define TSC_DEBUG_MODE2_WIPER_200K_PULL_UP(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_MASK)
#define TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_MASK   (0x10000U)
#define TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_SHIFT   (16U)
#define TSC_DEBUG_MODE2_DETECT_FOUR_WIRE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_MASK)
#define TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_MASK   (0x20000U)
#define TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_SHIFT   (17U)
#define TSC_DEBUG_MODE2_DETECT_FIVE_WIRE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_MASK)
#define TSC_DEBUG_MODE2_STATE_MACHINE_MASK   (0x700000U)
#define TSC_DEBUG_MODE2_STATE_MACHINE_SHIFT   (20U)
#define TSC_DEBUG_MODE2_STATE_MACHINE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_STATE_MACHINE_SHIFT)) & TSC_DEBUG_MODE2_STATE_MACHINE_MASK)
#define TSC_DEBUG_MODE2_INTERMEDIATE_MASK   (0x800000U)
#define TSC_DEBUG_MODE2_INTERMEDIATE_SHIFT   (23U)
#define TSC_DEBUG_MODE2_INTERMEDIATE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_INTERMEDIATE_SHIFT)) & TSC_DEBUG_MODE2_INTERMEDIATE_MASK)
#define TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_MASK   (0x1000000U)
#define TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_SHIFT   (24U)
#define TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_MASK)
#define TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_MASK   (0x10000000U)
#define TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_SHIFT   (28U)
#define TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_MASK)
#define TSC_DEBUG_MODE2_DE_GLITCH_MASK   (0x60000000U)
#define TSC_DEBUG_MODE2_DE_GLITCH_SHIFT   (29U)
#define TSC_DEBUG_MODE2_DE_GLITCH(x)   (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DE_GLITCH_SHIFT)) & TSC_DEBUG_MODE2_DE_GLITCH_MASK)
◆ TSC_BASIC_SETTING_AUTO_MEASURE
#define TSC_BASIC_SETTING_AUTO_MEASURE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_AUTO_MEASURE_SHIFT)) & TSC_BASIC_SETTING_AUTO_MEASURE_MASK)
AUTO_MEASURE - Auto Measure 0b0..Disable Auto Measure 0b1..Auto Measure
◆ TSC_BASIC_SETTING_MEASURE_DELAY_TIME
#define TSC_BASIC_SETTING_MEASURE_DELAY_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_MEASURE_DELAY_TIME_SHIFT)) & TSC_BASIC_SETTING_MEASURE_DELAY_TIME_MASK)
MEASURE_DELAY_TIME - Measure Delay Time
◆ TSC_BASIC_SETTING_WIRE_4_5
#define TSC_BASIC_SETTING_WIRE_4_5 (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_WIRE_4_5_SHIFT)) & TSC_BASIC_SETTING_WIRE_4_5_MASK)
WIRE_4_5 - 4/5 Wire detection 0b0..4-Wire Detection Mode 0b1..5-Wire Detection Mode
◆ TSC_DEBUG_MODE2_DE_GLITCH
#define TSC_DEBUG_MODE2_DE_GLITCH (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DE_GLITCH_SHIFT)) & TSC_DEBUG_MODE2_DE_GLITCH_MASK)
DE_GLITCH 0b00..Normal function: 0x1fff ipg clock cycles; Low power mode: 0x9 low power clock cycles 0b01..Normal function: 0xfff ipg clock cycles; Low power mode: :0x7 low power clock cycles 0b10..Normal function: 0x7ff ipg clock cycles; Low power mode:0x5 low power clock cycles 0b11..Normal function: 0x3 ipg clock cycles; Low power mode:0x3 low power clock cycles
◆ TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE
#define TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_MASK)
DETECT_ENABLE_FIVE_WIRE - Detect Enable Five Wire 0b0..Do not read five wire detect value, read default value from analogue 0b1..Read five wire detect status from analogue
◆ TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE
#define TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_MASK)
DETECT_ENABLE_FOUR_WIRE - Detect Enable Four Wire 0b0..Do not read four wire detect value, read default value from analogue 0b1..Read four wire detect status from analogue
◆ TSC_DEBUG_MODE2_DETECT_FIVE_WIRE
#define TSC_DEBUG_MODE2_DETECT_FIVE_WIRE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_MASK)
DETECT_FIVE_WIRE - Detect Five Wire 0b0..No detect signal 0b1..Yes, there is a detect on the touch screen.
◆ TSC_DEBUG_MODE2_DETECT_FOUR_WIRE
#define TSC_DEBUG_MODE2_DETECT_FOUR_WIRE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_MASK)
DETECT_FOUR_WIRE - Detect Four Wire 0b0..No detect signal 0b1..Yes, there is a detect on the touch screen.
◆ TSC_DEBUG_MODE2_INTERMEDIATE
#define TSC_DEBUG_MODE2_INTERMEDIATE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_INTERMEDIATE_SHIFT)) & TSC_DEBUG_MODE2_INTERMEDIATE_MASK)
INTERMEDIATE - Intermediate State 0b0..Not in intermedia 0b1..Intermedia
◆ TSC_DEBUG_MODE2_STATE_MACHINE
#define TSC_DEBUG_MODE2_STATE_MACHINE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_STATE_MACHINE_SHIFT)) & TSC_DEBUG_MODE2_STATE_MACHINE_MASK)
STATE_MACHINE - State Machine 0b000..Idle 0b001..Pre-charge 0b010..Detect 0b011..X-measure 0b100..Y-measure 0b101..Pre-charge 0b110..Detect
◆ TSC_DEBUG_MODE2_WIPER_200K_PULL_UP
#define TSC_DEBUG_MODE2_WIPER_200K_PULL_UP (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_MASK)
WIPER_200K_PULL_UP - Wiper Wire 200K Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_WIPER_PULL_DOWN
#define TSC_DEBUG_MODE2_WIPER_PULL_DOWN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_WIPER_PULL_DOWN_MASK)
WIPER_PULL_DOWN - Wiper Wire Pull Down Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_WIPER_PULL_UP
#define TSC_DEBUG_MODE2_WIPER_PULL_UP (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_WIPER_PULL_UP_MASK)
WIPER_PULL_UP - Wiper Wire Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_XNUR_200K_PULL_UP
#define TSC_DEBUG_MODE2_XNUR_200K_PULL_UP (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_MASK)
XNUR_200K_PULL_UP - XNUR Wire 200K Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_XNUR_PULL_DOWN
#define TSC_DEBUG_MODE2_XNUR_PULL_DOWN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_XNUR_PULL_DOWN_MASK)
XNUR_PULL_DOWN - XNUR Wire Pull Down Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_XNUR_PULL_UP
#define TSC_DEBUG_MODE2_XNUR_PULL_UP (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XNUR_PULL_UP_MASK)
XNUR_PULL_UP - XNUR Wire Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_XPUL_200K_PULL_UP
#define TSC_DEBUG_MODE2_XPUL_200K_PULL_UP (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_MASK)
XPUL_200K_PULL_UP - XPUL Wire 200K Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_XPUL_PULL_DOWN
#define TSC_DEBUG_MODE2_XPUL_PULL_DOWN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_XPUL_PULL_DOWN_MASK)
XPUL_PULL_DOWN - XPUL Wire Pull Down Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_XPUL_PULL_UP
#define TSC_DEBUG_MODE2_XPUL_PULL_UP (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XPUL_PULL_UP_MASK)
XPUL_PULL_UP - XPUL Wire Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_YNLR_200K_PULL_UP
#define TSC_DEBUG_MODE2_YNLR_200K_PULL_UP (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_MASK)
YNLR_200K_PULL_UP - YNLR Wire 200K Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_YNLR_PULL_DOWN
#define TSC_DEBUG_MODE2_YNLR_PULL_DOWN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_YNLR_PULL_DOWN_MASK)
YNLR_PULL_DOWN - YNLR Wire Pull Down Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_YNLR_PULL_UP
#define TSC_DEBUG_MODE2_YNLR_PULL_UP (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YNLR_PULL_UP_MASK)
YNLR_PULL_UP - YNLR Wire Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_YPLL_200K_PULL_UP
#define TSC_DEBUG_MODE2_YPLL_200K_PULL_UP (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_MASK)
YPLL_200K_PULL_UP - YPLL Wire 200K Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_YPLL_PULL_DOWN
#define TSC_DEBUG_MODE2_YPLL_PULL_DOWN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_YPLL_PULL_DOWN_MASK)
YPLL_PULL_DOWN - YPLL Wire Pull Down Switch 0b0..Close the switch 0b1..Open up the switch
◆ TSC_DEBUG_MODE2_YPLL_PULL_UP
#define TSC_DEBUG_MODE2_YPLL_PULL_UP (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YPLL_PULL_UP_MASK)
YPLL_PULL_UP - YPLL Wire Pull Up Switch 0b0..Close the switch 0b1..Open the switch
◆ TSC_DEBUG_MODE_ADC_COCO
#define TSC_DEBUG_MODE_ADC_COCO (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_MASK)
ADC_COCO - ADC COCO Signal
◆ TSC_DEBUG_MODE_ADC_COCO_CLEAR
#define TSC_DEBUG_MODE_ADC_COCO_CLEAR (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_CLEAR_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_CLEAR_MASK)
ADC_COCO_CLEAR - ADC Coco Clear 0b0..No ADC COCO clear 0b1..Set ADC COCO clear
◆ TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE
#define TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_MASK)
ADC_COCO_CLEAR_DISABLE - ADC COCO Clear Disable 0b0..Allow TSC hardware generates ADC COCO clear 0b1..Prevent TSC from generate ADC COCO clear signal
◆ TSC_DEBUG_MODE_ADC_CONV_VALUE
#define TSC_DEBUG_MODE_ADC_CONV_VALUE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_CONV_VALUE_SHIFT)) & TSC_DEBUG_MODE_ADC_CONV_VALUE_MASK)
ADC_CONV_VALUE - ADC Conversion Value
◆ TSC_DEBUG_MODE_DEBUG_EN
#define TSC_DEBUG_MODE_DEBUG_EN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_DEBUG_EN_SHIFT)) & TSC_DEBUG_MODE_DEBUG_EN_MASK)
DEBUG_EN - Debug Enable 0b0..Enable debug mode 0b1..Disable debug mode
◆ TSC_DEBUG_MODE_EXT_HWTS
#define TSC_DEBUG_MODE_EXT_HWTS (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_EXT_HWTS_SHIFT)) & TSC_DEBUG_MODE_EXT_HWTS_MASK)
EXT_HWTS - Hardware Trigger Select Signal
◆ TSC_DEBUG_MODE_TRIGGER
#define TSC_DEBUG_MODE_TRIGGER (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_TRIGGER_SHIFT)) & TSC_DEBUG_MODE_TRIGGER_MASK)
TRIGGER - Trigger 0b0..No hardware trigger signal 0b1..Hardware trigger signal, the signal must last at least 1 ips clock period
◆ TSC_FLOW_CONTROL_DISABLE
#define TSC_FLOW_CONTROL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_DISABLE_SHIFT)) & TSC_FLOW_CONTROL_DISABLE_MASK)
DISABLE 0b0..Leave HW state machine control 0b1..SW set to idle status
◆ TSC_FLOW_CONTROL_DROP_MEASURE
#define TSC_FLOW_CONTROL_DROP_MEASURE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_DROP_MEASURE_SHIFT)) & TSC_FLOW_CONTROL_DROP_MEASURE_MASK)
DROP_MEASURE - Drop Measure 0b0..Do not drop measure for now 0b1..Drop the measure and controller return to idle status
◆ TSC_FLOW_CONTROL_START_MEASURE
#define TSC_FLOW_CONTROL_START_MEASURE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_START_MEASURE_SHIFT)) & TSC_FLOW_CONTROL_START_MEASURE_MASK)
START_MEASURE - Start Measure 0b0..Do not start measure for now 0b1..Start measure the X/Y coordinate value
◆ TSC_FLOW_CONTROL_START_SENSE
#define TSC_FLOW_CONTROL_START_SENSE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_START_SENSE_SHIFT)) & TSC_FLOW_CONTROL_START_SENSE_MASK)
START_SENSE - Start Sense 0b0..Stay at idle status 0b1..Start sense detection and (if auto_measure set to 1) measure after detect a touch
◆ TSC_FLOW_CONTROL_SW_RST
#define TSC_FLOW_CONTROL_SW_RST (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_SW_RST_SHIFT)) & TSC_FLOW_CONTROL_SW_RST_MASK)
SW_RST - Soft Reset
◆ TSC_INT_EN_DETECT_INT_EN
#define TSC_INT_EN_DETECT_INT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_DETECT_INT_EN_SHIFT)) & TSC_INT_EN_DETECT_INT_EN_MASK)
DETECT_INT_EN - Detect Interrupt Enable 0b0..Disable detect interrupt 0b1..Enable detect interrupt
◆ TSC_INT_EN_IDLE_SW_INT_EN
#define TSC_INT_EN_IDLE_SW_INT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_IDLE_SW_INT_EN_SHIFT)) & TSC_INT_EN_IDLE_SW_INT_EN_MASK)
IDLE_SW_INT_EN - Idle Software Interrupt Enable 0b0..Disable idle software interrupt 0b1..Enable idle software interrupt
◆ TSC_INT_EN_MEASURE_INT_EN
#define TSC_INT_EN_MEASURE_INT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_MEASURE_INT_EN_SHIFT)) & TSC_INT_EN_MEASURE_INT_EN_MASK)
MEASURE_INT_EN - Measure Interrupt Enable 0b0..Disable measure interrupt 0b1..Enable measure interrupt
◆ TSC_INT_SIG_EN_DETECT_SIG_EN
#define TSC_INT_SIG_EN_DETECT_SIG_EN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_DETECT_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_DETECT_SIG_EN_MASK)
DETECT_SIG_EN - Detect Signal Enable 0b0..Disable detect signal 0b1..Enable detect signal
◆ TSC_INT_SIG_EN_IDLE_SW_SIG_EN
#define TSC_INT_SIG_EN_IDLE_SW_SIG_EN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_IDLE_SW_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_IDLE_SW_SIG_EN_MASK)
IDLE_SW_SIG_EN - Idle Software Signal Enable 0b0..Disable idle software signal 0b1..Enable idle software signal
◆ TSC_INT_SIG_EN_MEASURE_SIG_EN
#define TSC_INT_SIG_EN_MEASURE_SIG_EN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_MEASURE_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_MEASURE_SIG_EN_MASK)
MEASURE_SIG_EN - Measure Signal Enable
◆ TSC_INT_SIG_EN_VALID_SIG_EN
#define TSC_INT_SIG_EN_VALID_SIG_EN (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_VALID_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_VALID_SIG_EN_MASK)
VALID_SIG_EN - Valid Signal Enable 0b0..Disable valid signal 0b1..Enable valid signal
◆ TSC_INT_STATUS_DETECT
#define TSC_INT_STATUS_DETECT (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_DETECT_SHIFT)) & TSC_INT_STATUS_DETECT_MASK)
DETECT - Detect Signal 0b0..Does not exist a detect signal 0b1..Exist detect signal
◆ TSC_INT_STATUS_IDLE_SW
#define TSC_INT_STATUS_IDLE_SW (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_IDLE_SW_SHIFT)) & TSC_INT_STATUS_IDLE_SW_MASK)
IDLE_SW - Idle Software 0b0..Haven't return to idle status 0b1..Already return to idle status
◆ TSC_INT_STATUS_MEASURE
#define TSC_INT_STATUS_MEASURE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_MEASURE_SHIFT)) & TSC_INT_STATUS_MEASURE_MASK)
MEASURE - Measure Signal 0b0..Does not exist a measure signal 0b1..Exist a measure signal
◆ TSC_INT_STATUS_VALID
#define TSC_INT_STATUS_VALID (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_VALID_SHIFT)) & TSC_INT_STATUS_VALID_MASK)
VALID - Valid Signal 0b0..There is no touch detected after measurement, indicates that the measured value is not valid 0b1..There is touch detection after measurement, indicates that the measure is valid
◆ TSC_MEASEURE_VALUE_X_VALUE
#define TSC_MEASEURE_VALUE_X_VALUE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_MEASEURE_VALUE_X_VALUE_SHIFT)) & TSC_MEASEURE_VALUE_X_VALUE_MASK)
X_VALUE - X Value
◆ TSC_MEASEURE_VALUE_Y_VALUE
#define TSC_MEASEURE_VALUE_Y_VALUE (   x)    (((uint32_t)(((uint32_t)(x)) << TSC_MEASEURE_VALUE_Y_VALUE_SHIFT)) & TSC_MEASEURE_VALUE_Y_VALUE_MASK)
Y_VALUE - Y Value
