RTEMS 6.1
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_COUNT   (8U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_COUNT   (8U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_COUNT   (16U)
CM_AUTHEN_CTRL - CM Authentication Control
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_USER_MASK   (0x1U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_USER_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_USER(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_USER_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_USER_MASK)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_NONSECURE_MASK   (0x2U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_NONSECURE_SHIFT   (1U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_NONSECURE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_NONSECURE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_NONSECURE_MASK)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_SETTING_MASK   (0x10U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_SETTING_SHIFT   (4U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_SETTING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_SETTING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_SETTING_MASK)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_WHITE_LIST_MASK   (0xF00U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_WHITE_LIST_SHIFT   (8U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_WHITE_LIST(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_WHITE_LIST_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_WHITE_LIST_MASK)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_LIST_MASK   (0x1000U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_LIST_SHIFT   (12U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_LIST(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_LIST_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_LIST_MASK)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_CFG_MASK   (0x100000U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_CFG_SHIFT   (20U)
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_CFG(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_CFG_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_CFG_MASK)
CM_INT_CTRL - CM Interrupt Control
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_EN_MASK   (0x1U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_EN_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_EN(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_EN_MASK)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN_MASK   (0x2U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN_SHIFT   (1U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN_MASK)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_EN_MASK   (0x4U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_EN_SHIFT   (2U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_EN(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_EN_MASK)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_MASK   (0x10000U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_SHIFT   (16U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_MASK)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_MASK   (0x20000U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_SHIFT   (17U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_MASK)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_MASK   (0x40000U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_SHIFT   (18U)
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_MASK)
CM_MISC - Miscellaneous
#define GPC_CPU_MODE_CTRL_CM_MISC_NMI_STAT_MASK   (0x1U)
#define GPC_CPU_MODE_CTRL_CM_MISC_NMI_STAT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_MISC_NMI_STAT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MISC_NMI_STAT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MISC_NMI_STAT_MASK)
#define GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_EN_MASK   (0x2U)
#define GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_EN_SHIFT   (1U)
#define GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_EN(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_EN_MASK)
#define GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_STAT_MASK   (0x4U)
#define GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_STAT_SHIFT   (2U)
#define GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_STAT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_STAT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_STAT_MASK)
#define GPC_CPU_MODE_CTRL_CM_MISC_MASTER_CPU_MASK   (0x10U)
#define GPC_CPU_MODE_CTRL_CM_MISC_MASTER_CPU_SHIFT   (4U)
#define GPC_CPU_MODE_CTRL_CM_MISC_MASTER_CPU(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MISC_MASTER_CPU_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MISC_MASTER_CPU_MASK)
CM_MODE_CTRL - CPU mode control
#define GPC_CPU_MODE_CTRL_CM_MODE_CTRL_CPU_MODE_TARGET_MASK   (0x3U)
#define GPC_CPU_MODE_CTRL_CM_MODE_CTRL_CPU_MODE_TARGET_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_MODE_CTRL_CPU_MODE_TARGET(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MODE_CTRL_CPU_MODE_TARGET_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MODE_CTRL_CPU_MODE_TARGET_MASK)
#define GPC_CPU_MODE_CTRL_CM_MODE_CTRL_WFE_EN_MASK   (0x10U)
#define GPC_CPU_MODE_CTRL_CM_MODE_CTRL_WFE_EN_SHIFT   (4U)
#define GPC_CPU_MODE_CTRL_CM_MODE_CTRL_WFE_EN(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MODE_CTRL_WFE_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MODE_CTRL_WFE_EN_MASK)
CM_MODE_STAT - CM CPU mode Status
#define GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_CURRENT_MASK   (0x3U)
#define GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_CURRENT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_CURRENT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_CURRENT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_CURRENT_MASK)
#define GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_PREVIOUS_MASK   (0xCU)
#define GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_PREVIOUS_SHIFT   (2U)
#define GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_PREVIOUS(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_PREVIOUS_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_PREVIOUS_MASK)
CM_IRQ_WAKEUP_MASK - CM IRQ0~31 wakeup mask..CM IRQ224~255 wakeup mask
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_0_31_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_0_31_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_0_31(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_0_31_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_0_31_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_32_63_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_32_63_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_32_63(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_32_63_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_32_63_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_64_95_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_64_95_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_64_95(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_64_95_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_64_95_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_96_127_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_96_127_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_96_127(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_96_127_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_96_127_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_128_159_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_128_159_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_128_159(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_128_159_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_128_159_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_160_191_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_160_191_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_160_191(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_160_191_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_160_191_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_192_223_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_192_223_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_192_223(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_192_223_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_192_223_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_224_255_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_224_255_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_224_255(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_224_255_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_224_255_MASK)
CM_NON_IRQ_WAKEUP_MASK - CM non-irq wakeup mask
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_EVENT_WAKEUP_MASK_MASK   (0x1U)
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_EVENT_WAKEUP_MASK_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_EVENT_WAKEUP_MASK(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_EVENT_WAKEUP_MASK_SHIFT)) & GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_EVENT_WAKEUP_MASK_MASK)
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_DEBUG_WAKEUP_MASK_MASK   (0x2U)
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_DEBUG_WAKEUP_MASK_SHIFT   (1U)
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_DEBUG_WAKEUP_MASK(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_DEBUG_WAKEUP_MASK_SHIFT)) & GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_DEBUG_WAKEUP_MASK_MASK)
CM_IRQ_WAKEUP_STAT - CM IRQ0~31 wakeup status..CM IRQ224~255 wakeup status
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_MASK_224_255_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_MASK_224_255_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_MASK_224_255(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_MASK_224_255_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_MASK_224_255_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_0_31_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_0_31_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_0_31(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_0_31_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_0_31_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_32_63_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_32_63_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_32_63(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_32_63_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_32_63_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_64_95_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_64_95_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_64_95(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_64_95_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_64_95_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_96_127_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_96_127_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_96_127(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_96_127_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_96_127_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_128_159_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_128_159_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_128_159(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_128_159_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_128_159_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_160_191_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_160_191_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_160_191(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_160_191_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_160_191_MASK)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_192_223_MASK   (0xFFFFFFFFU)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_192_223_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_192_223(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_192_223_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_192_223_MASK)
CM_NON_IRQ_WAKEUP_STAT - CM non-irq wakeup status
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_EVENT_WAKEUP_STAT_MASK   (0x1U)
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_EVENT_WAKEUP_STAT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_EVENT_WAKEUP_STAT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_EVENT_WAKEUP_STAT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_EVENT_WAKEUP_STAT_MASK)
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_DEBUG_WAKEUP_STAT_MASK   (0x2U)
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_DEBUG_WAKEUP_STAT_SHIFT   (1U)
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_DEBUG_WAKEUP_STAT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_DEBUG_WAKEUP_STAT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_DEBUG_WAKEUP_STAT_MASK)
CM_SLEEP_SSAR_CTRL - CM sleep SSAR control
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_DISABLE_MASK)
CM_SLEEP_LPCG_CTRL - CM sleep LPCG control
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_DISABLE_MASK)
CM_SLEEP_PLL_CTRL - CM sleep PLL control
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_DISABLE_MASK)
CM_SLEEP_ISO_CTRL - CM sleep isolation control
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_DISABLE_MASK)
CM_SLEEP_RESET_CTRL - CM sleep reset control
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_DISABLE_MASK)
CM_SLEEP_POWER_CTRL - CM sleep power control
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_DISABLE_MASK)
CM_WAKEUP_POWER_CTRL - CM wakeup power control
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_DISABLE_MASK)
CM_WAKEUP_RESET_CTRL - CM wakeup reset control
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_DISABLE_MASK)
CM_WAKEUP_ISO_CTRL - CM wakeup isolation control
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_DISABLE_MASK)
CM_WAKEUP_PLL_CTRL - CM wakeup PLL control
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_DISABLE_MASK)
CM_WAKEUP_LPCG_CTRL - CM wakeup LPCG control
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_DISABLE_MASK)
CM_WAKEUP_SSAR_CTRL - CM wakeup SSAR control
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_STEP_CNT_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_STEP_CNT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_STEP_CNT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_STEP_CNT_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_CNT_MODE_MASK   (0x30000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_CNT_MODE_SHIFT   (28U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_CNT_MODE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_CNT_MODE_MASK)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_DISABLE_MASK   (0x80000000U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_DISABLE_SHIFT   (31U)
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_DISABLE(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_DISABLE_MASK)
CM_SP_CTRL - CM Setpoint Control
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_EN_MASK   (0x1U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_EN_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_EN(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_EN_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_MASK   (0x1EU)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_SHIFT   (1U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_EN_MASK   (0x20U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_EN_SHIFT   (5U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_EN(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_EN_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_MASK   (0x3C0U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_SHIFT   (6U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_EN_MASK   (0x400U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_EN_SHIFT   (10U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_EN(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_EN_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_MASK   (0x7800U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SHIFT   (11U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SEL_MASK   (0x8000U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SEL_SHIFT   (15U)
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SEL(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SEL_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SEL_MASK)
CM_SP_STAT - CM Setpoint Status
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_CURRENT_MASK   (0xFU)
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_CURRENT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_CURRENT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_CURRENT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_CURRENT_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_PREVIOUS_MASK   (0xF0U)
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_PREVIOUS_SHIFT   (4U)
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_PREVIOUS(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_PREVIOUS_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_PREVIOUS_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_TARGET_MASK   (0xF00U)
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_TARGET_SHIFT   (8U)
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_TARGET(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_TARGET_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_TARGET_MASK)
CM_RUN_MODE_MAPPING - CM Run Mode Setpoint Allowed
#define GPC_CPU_MODE_CTRL_CM_RUN_MODE_MAPPING_CPU_RUN_MODE_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_RUN_MODE_MAPPING_CPU_RUN_MODE_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_RUN_MODE_MAPPING_CPU_RUN_MODE_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_RUN_MODE_MAPPING_CPU_RUN_MODE_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_RUN_MODE_MAPPING_CPU_RUN_MODE_MAPPING_MASK)
CM_WAIT_MODE_MAPPING - CM Wait Mode Setpoint Allowed
#define GPC_CPU_MODE_CTRL_CM_WAIT_MODE_MAPPING_CPU_WAIT_MODE_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_WAIT_MODE_MAPPING_CPU_WAIT_MODE_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_WAIT_MODE_MAPPING_CPU_WAIT_MODE_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAIT_MODE_MAPPING_CPU_WAIT_MODE_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAIT_MODE_MAPPING_CPU_WAIT_MODE_MAPPING_MASK)
CM_STOP_MODE_MAPPING - CM Stop Mode Setpoint Allowed
#define GPC_CPU_MODE_CTRL_CM_STOP_MODE_MAPPING_CPU_STOP_MODE_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_STOP_MODE_MAPPING_CPU_STOP_MODE_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_STOP_MODE_MAPPING_CPU_STOP_MODE_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STOP_MODE_MAPPING_CPU_STOP_MODE_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STOP_MODE_MAPPING_CPU_STOP_MODE_MAPPING_MASK)
CM_SUSPEND_MODE_MAPPING - CM Suspend Mode Setpoint Allowed
#define GPC_CPU_MODE_CTRL_CM_SUSPEND_MODE_MAPPING_CPU_SUSPEND_MODE_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SUSPEND_MODE_MAPPING_CPU_SUSPEND_MODE_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SUSPEND_MODE_MAPPING_CPU_SUSPEND_MODE_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SUSPEND_MODE_MAPPING_CPU_SUSPEND_MODE_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SUSPEND_MODE_MAPPING_CPU_SUSPEND_MODE_MAPPING_MASK)
CM_SP_MAPPING - CM Setpoint 0 Mapping..CM Setpoint 15 Mapping
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP0_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP0_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP0_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP0_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP0_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP1_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP1_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP1_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP1_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP1_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP2_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP2_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP2_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP2_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP2_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP3_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP3_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP3_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP3_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP3_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP4_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP4_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP4_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP4_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP4_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP5_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP5_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP5_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP5_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP5_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP6_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP6_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP6_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP6_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP6_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP7_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP7_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP7_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP7_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP7_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP8_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP8_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP8_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP8_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP8_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP9_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP9_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP9_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP9_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP9_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP10_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP10_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP10_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP10_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP10_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP11_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP11_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP11_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP11_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP11_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP12_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP12_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP12_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP12_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP12_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP13_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP13_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP13_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP13_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP13_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP14_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP14_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP14_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP14_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP14_MAPPING_MASK)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP15_MAPPING_MASK   (0xFFFFU)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP15_MAPPING_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP15_MAPPING(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP15_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP15_MAPPING_MASK)
CM_STBY_CTRL - CM standby control
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAIT_MASK   (0x1U)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAIT_SHIFT   (0U)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAIT(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAIT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAIT_MASK)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_STOP_MASK   (0x2U)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_STOP_SHIFT   (1U)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_STOP(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_STOP_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_STOP_MASK)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SUSPEND_MASK   (0x4U)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SUSPEND_SHIFT   (2U)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SUSPEND(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SUSPEND_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SUSPEND_MASK)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SLEEP_BUSY_MASK   (0x10000U)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SLEEP_BUSY_SHIFT   (16U)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SLEEP_BUSY(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SLEEP_BUSY_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SLEEP_BUSY_MASK)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAKEUP_BUSY_MASK   (0x20000U)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAKEUP_BUSY_SHIFT   (17U)
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAKEUP_BUSY(x)   (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAKEUP_BUSY_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAKEUP_BUSY_MASK)
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_CFG [1/2]
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_CFG (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_CFG_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_CFG_MASK)
LOCK_CFG - Configuration lock
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_CFG [2/2]
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_LIST [1/2]
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_LIST (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_LIST_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_LIST_MASK)
LOCK_LIST - White list lock
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_LIST [2/2]
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_SETTING [1/2]
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_SETTING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_SETTING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_SETTING_MASK)
LOCK_SETTING - Lock NONSECURE and USER
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_LOCK_SETTING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_NONSECURE [1/2]
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_NONSECURE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_NONSECURE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_NONSECURE_MASK)
NONSECURE - Allow non-secure mode access 0b0..Allow only secure mode to access CPU mode control registers 0b1..Allow both secure and non-secure mode to access CPU mode control registers
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_NONSECURE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_USER [1/2]
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_USER (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_USER_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_USER_MASK)
USER - Allow user mode access 0b0..Allow only privilege mode to access CPU mode control registers 0b1..Allow both privilege and user mode to access CPU mode control registers
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_USER [2/2]
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_WHITE_LIST [1/2]
#define GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_WHITE_LIST (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_WHITE_LIST_SHIFT)) & GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_WHITE_LIST_MASK)
WHITE_LIST - Domain ID white list
◆ GPC_CPU_MODE_CTRL_CM_AUTHEN_CTRL_WHITE_LIST [2/2]
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT [1/2]
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_MASK)
SP_REQ_NOT_ALLOWED_SLEEP_INT - sp_req_not_allowed_for_sleep interrupt status and clear register
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_EN [1/2]
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_EN_MASK)
SP_REQ_NOT_ALLOWED_SLEEP_INT_EN - sp_req_not_allowed_for_sleep interrupt enable 0b0..Interrupt disable 0b1..Interrupt enable
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_EN [2/2]
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT [1/2]
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_MASK)
SP_REQ_NOT_ALLOWED_SOFT_INT - sp_req_not_allowed_for_soft interrupt status and clear register
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_EN [1/2]
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_EN_MASK)
SP_REQ_NOT_ALLOWED_SOFT_INT_EN - sp_req_not_allowed_for_soft interrupt enable 0b0..Interrupt disable 0b1..Interrupt enable
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_EN [2/2]
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT [1/2]
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_MASK)
SP_REQ_NOT_ALLOWED_WAKEUP_INT - sp_req_not_allowed_for_wakeup interrupt status and clear register
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN [1/2]
#define GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN_MASK)
SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN - sp_req_not_allowed_for_wakeup interrupt enable 0b0..Interrupt disable 0b1..Interrupt enable
◆ GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_EN [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_0_31 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_0_31 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_0_31_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_0_31_MASK)
IRQ_WAKEUP_MASK_0_31 - "1" means the IRQ cannot wakeup CPU platform
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_0_31 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_128_159 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_128_159 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_128_159_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_128_159_MASK)
IRQ_WAKEUP_MASK_128_159 - "1" means the IRQ cannot wakeup CPU platform
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_128_159 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_160_191 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_160_191 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_160_191_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_160_191_MASK)
IRQ_WAKEUP_MASK_160_191 - "1" means the IRQ cannot wakeup CPU platform
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_160_191 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_192_223 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_192_223 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_192_223_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_192_223_MASK)
IRQ_WAKEUP_MASK_192_223 - "1" means the IRQ cannot wakeup CPU platform
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_192_223 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_224_255 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_224_255 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_224_255_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_224_255_MASK)
IRQ_WAKEUP_MASK_224_255 - "1" means the IRQ cannot wakeup CPU platform
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_224_255 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_32_63 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_32_63 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_32_63_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_32_63_MASK)
IRQ_WAKEUP_MASK_32_63 - "1" means the IRQ cannot wakeup CPU platform
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_32_63 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_64_95 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_64_95 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_64_95_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_64_95_MASK)
IRQ_WAKEUP_MASK_64_95 - "1" means the IRQ cannot wakeup CPU platform
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_64_95 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_96_127 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_96_127 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_96_127_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_96_127_MASK)
IRQ_WAKEUP_MASK_96_127 - "1" means the IRQ cannot wakeup CPU platform
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_MASK_IRQ_WAKEUP_MASK_96_127 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_MASK_224_255 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_MASK_224_255 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_MASK_224_255_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_MASK_224_255_MASK)
IRQ_WAKEUP_MASK_224_255 - IRQ status 0b00000000000000000000000000000000..None 0b00000000000000000000000000000001..Valid
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_MASK_224_255 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_0_31 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_0_31 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_0_31_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_0_31_MASK)
IRQ_WAKEUP_STAT_0_31 - IRQ status 0b00000000000000000000000000000000..None 0b00000000000000000000000000000001..Valid
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_0_31 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_128_159 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_128_159 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_128_159_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_128_159_MASK)
IRQ_WAKEUP_STAT_128_159 - IRQ status 0b00000000000000000000000000000000..None 0b00000000000000000000000000000001..Valid
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_128_159 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_160_191 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_160_191 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_160_191_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_160_191_MASK)
IRQ_WAKEUP_STAT_160_191 - IRQ status 0b00000000000000000000000000000000..None 0b00000000000000000000000000000001..Valid
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_160_191 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_192_223 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_192_223 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_192_223_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_192_223_MASK)
IRQ_WAKEUP_STAT_192_223 - IRQ status 0b00000000000000000000000000000000..None 0b00000000000000000000000000000001..Valid
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_192_223 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_32_63 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_32_63 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_32_63_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_32_63_MASK)
IRQ_WAKEUP_STAT_32_63 - IRQ status 0b00000000000000000000000000000000..None 0b00000000000000000000000000000001..Valid
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_32_63 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_64_95 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_64_95 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_64_95_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_64_95_MASK)
IRQ_WAKEUP_STAT_64_95 - IRQ status 0b00000000000000000000000000000000..None 0b00000000000000000000000000000001..Valid
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_64_95 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_96_127 [1/2]
#define GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_96_127 (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_96_127_SHIFT)) & GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_96_127_MASK)
IRQ_WAKEUP_STAT_96_127 - IRQ status 0b00000000000000000000000000000000..None 0b00000000000000000000000000000001..Valid
◆ GPC_CPU_MODE_CTRL_CM_IRQ_WAKEUP_STAT_IRQ_WAKEUP_STAT_96_127 [2/2]
◆ GPC_CPU_MODE_CTRL_CM_MISC_MASTER_CPU [1/2]
#define GPC_CPU_MODE_CTRL_CM_MISC_MASTER_CPU (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MISC_MASTER_CPU_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MISC_MASTER_CPU_MASK)
MASTER_CPU - Master CPU
◆ GPC_CPU_MODE_CTRL_CM_MISC_MASTER_CPU [2/2]
◆ GPC_CPU_MODE_CTRL_CM_MISC_NMI_STAT [1/2]
#define GPC_CPU_MODE_CTRL_CM_MISC_NMI_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MISC_NMI_STAT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MISC_NMI_STAT_MASK)
NMI_STAT - Non-masked interrupt status 0b0..NMI is not asserting 0b1..NMI is asserting
◆ GPC_CPU_MODE_CTRL_CM_MISC_NMI_STAT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_EN [1/2]
#define GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_EN (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_EN_MASK)
SLEEP_HOLD_EN - Allow cpu_sleep_hold_req assert during CPU low power status 0b0..Disable cpu_sleep_hold_req 0b1..Allow cpu_sleep_hold_req assert during CPU low power status
◆ GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_EN [2/2]
◆ GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_STAT [1/2]
#define GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_STAT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_STAT_MASK)
SLEEP_HOLD_STAT - Status of cpu_sleep_hold_ack_b
◆ GPC_CPU_MODE_CTRL_CM_MISC_SLEEP_HOLD_STAT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_MODE_CTRL_CPU_MODE_TARGET [1/2]
#define GPC_CPU_MODE_CTRL_CM_MODE_CTRL_CPU_MODE_TARGET (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MODE_CTRL_CPU_MODE_TARGET_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MODE_CTRL_CPU_MODE_TARGET_MASK)
CPU_MODE_TARGET - The CPU mode the CPU platform should transit to on next sleep event 0b00..Stay in RUN mode 0b01..Transit to WAIT mode 0b10..Transit to STOP mode 0b11..Transit to SUSPEND mode
◆ GPC_CPU_MODE_CTRL_CM_MODE_CTRL_CPU_MODE_TARGET [2/2]
◆ GPC_CPU_MODE_CTRL_CM_MODE_CTRL_WFE_EN [1/2]
#define GPC_CPU_MODE_CTRL_CM_MODE_CTRL_WFE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MODE_CTRL_WFE_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MODE_CTRL_WFE_EN_MASK)
WFE_EN - WFE assertion can be sleep event 0b0..WFE assertion can not trigger low power 0b1..WFE assertion can trigger low power
◆ GPC_CPU_MODE_CTRL_CM_MODE_CTRL_WFE_EN [2/2]
◆ GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_CURRENT [1/2]
#define GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_CURRENT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_CURRENT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_CURRENT_MASK)
CPU_MODE_CURRENT - Current CPU mode 0b00..CPU is currently in RUN mode 0b01..CPU is currently in WAIT mode 0b10..CPU is currently in STOP mode 0b11..CPU is currently in SUSPEND mode
◆ GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_CURRENT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_PREVIOUS [1/2]
#define GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_PREVIOUS (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_PREVIOUS_SHIFT)) & GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_PREVIOUS_MASK)
CPU_MODE_PREVIOUS - Previous CPU mode 0b00..CPU was previously in RUN mode 0b01..CPU was previously in WAIT mode 0b10..CPU was previously in STOP mode 0b11..CPU was previously in SUSPEND mode
◆ GPC_CPU_MODE_CTRL_CM_MODE_STAT_CPU_MODE_PREVIOUS [2/2]
◆ GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_DEBUG_WAKEUP_MASK [1/2]
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_DEBUG_WAKEUP_MASK (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_DEBUG_WAKEUP_MASK_SHIFT)) & GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_DEBUG_WAKEUP_MASK_MASK)
DEBUG_WAKEUP_MASK - "1" means the debug_wakeup_request cannot wakeup CPU platform
◆ GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_DEBUG_WAKEUP_MASK [2/2]
◆ GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_EVENT_WAKEUP_MASK [1/2]
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_EVENT_WAKEUP_MASK (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_EVENT_WAKEUP_MASK_SHIFT)) & GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_EVENT_WAKEUP_MASK_MASK)
EVENT_WAKEUP_MASK - There are 256 interrupts and 1 event as a wakeup source for GPC. This field masks the 1 event wakeup source. 0b1..The event cannot wakeup CPU platform
◆ GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_MASK_EVENT_WAKEUP_MASK [2/2]
◆ GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_DEBUG_WAKEUP_STAT [1/2]
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_DEBUG_WAKEUP_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_DEBUG_WAKEUP_STAT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_DEBUG_WAKEUP_STAT_MASK)
DEBUG_WAKEUP_STAT - Debug wakeup status
◆ GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_DEBUG_WAKEUP_STAT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_EVENT_WAKEUP_STAT [1/2]
#define GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_EVENT_WAKEUP_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_EVENT_WAKEUP_STAT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_EVENT_WAKEUP_STAT_MASK)
EVENT_WAKEUP_STAT - Event wakeup status 0b1..Interrupt is asserting (pending)
◆ GPC_CPU_MODE_CTRL_CM_NON_IRQ_WAKEUP_STAT_EVENT_WAKEUP_STAT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_RUN_MODE_MAPPING_CPU_RUN_MODE_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_RUN_MODE_MAPPING_CPU_RUN_MODE_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_RUN_MODE_MAPPING_CPU_RUN_MODE_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_RUN_MODE_MAPPING_CPU_RUN_MODE_MAPPING_MASK)
CPU_RUN_MODE_MAPPING - Defines which Setpoint is allowed when CPU enters RUN mode. Each bit stands for 1 Setpoint, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_RUN_MODE_MAPPING_CPU_RUN_MODE_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_CNT_MODE_MASK)
CNT_MODE - Count mode 0b00..Counter disable mode: not use step counter, step completes once receiving step_done 0b01..Counter delay mode: delay after receiving step_done, delay cycle number is STEP_CNT 0b10..Ignore step_done response, the counter starts to count once step begins, when counter reaches STEP_CNT value, the step completes 0b11..Time out mode, the counter starts to count once step begins, the step completes when either step_done received or counting to STEP_CNT value
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_DISABLE_MASK)
DISABLE - Disable this step
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_STEP_CNT_MASK)
STEP_CNT - Step count, useage is depending on CNT_MODE
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_ISO_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_STEP_CNT_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_LPCG_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_STEP_CNT_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_PLL_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_STEP_CNT_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_POWER_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_STEP_CNT_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_RESET_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_STEP_CNT_MASK)
STEP_CNT - Step count, useage is depending on CNT_MODE.
◆ GPC_CPU_MODE_CTRL_CM_SLEEP_SSAR_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_MASK)
CPU_SP_RUN - The Setpoint that CPU want the system to transit to when CPU_SP_RUN_EN is set
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_EN [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_EN (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_EN_MASK)
CPU_SP_RUN_EN - Request a Setpoint transition when this bit is set
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_RUN_EN [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_MASK)
CPU_SP_SLEEP - The Setpoint that CPU want the system to transit to on next CPU platform sleep sequence
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_EN [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_EN (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_EN_MASK)
CPU_SP_SLEEP_EN - 1 means enable Setpoint transition on next CPU platform sleep sequence
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_SLEEP_EN [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_MASK)
CPU_SP_WAKEUP - The Setpoint that CPU want the system to transit to on next CPU platform wakeup sequence
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_EN [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_EN (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_EN_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_EN_MASK)
CPU_SP_WAKEUP_EN - 1 means enable Setpoint transition on next CPU platform wakeup sequence
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_EN [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SEL [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SEL_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SEL_MASK)
CPU_SP_WAKEUP_SEL - Select the Setpoint transiton on the next CPU platform wakeup sequence 0b0..Request SP transition to CPU_SP_WAKEUP 0b1..Request SP transition to the Setpoint when the sleep event happens, which is captured in CPU_SP_PREVIOUS
◆ GPC_CPU_MODE_CTRL_CM_SP_CTRL_CPU_SP_WAKEUP_SEL [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP0_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP0_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP0_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP0_MAPPING_MASK)
CPU_SP0_MAPPING - Defines when SP0 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP0_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP10_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP10_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP10_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP10_MAPPING_MASK)
CPU_SP10_MAPPING - Defines when SP10 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP10_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP11_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP11_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP11_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP11_MAPPING_MASK)
CPU_SP11_MAPPING - Defines when SP11 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP11_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP12_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP12_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP12_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP12_MAPPING_MASK)
CPU_SP12_MAPPING - Defines when SP12 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP12_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP13_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP13_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP13_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP13_MAPPING_MASK)
CPU_SP13_MAPPING - Defines when SP13 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP13_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP14_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP14_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP14_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP14_MAPPING_MASK)
CPU_SP14_MAPPING - Defines when SP14 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP14_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP15_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP15_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP15_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP15_MAPPING_MASK)
CPU_SP15_MAPPING - Defines when SP15 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP15_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP1_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP1_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP1_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP1_MAPPING_MASK)
CPU_SP1_MAPPING - Defines when SP1 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP1_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP2_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP2_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP2_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP2_MAPPING_MASK)
CPU_SP2_MAPPING - Defines when SP2 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP2_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP3_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP3_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP3_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP3_MAPPING_MASK)
CPU_SP3_MAPPING - Defines when SP3 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP3_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP4_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP4_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP4_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP4_MAPPING_MASK)
CPU_SP4_MAPPING - Defines when SP4 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP4_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP5_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP5_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP5_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP5_MAPPING_MASK)
CPU_SP5_MAPPING - Defines when SP5 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP5_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP6_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP6_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP6_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP6_MAPPING_MASK)
CPU_SP6_MAPPING - Defines when SP6 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP6_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP7_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP7_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP7_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP7_MAPPING_MASK)
CPU_SP7_MAPPING - Defines when SP7 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP7_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP8_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP8_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP8_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP8_MAPPING_MASK)
CPU_SP8_MAPPING - Defines when SP8 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP8_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP9_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP9_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP9_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP9_MAPPING_MASK)
CPU_SP9_MAPPING - Defines when SP9 is set as the CPU_SP_TARGET, which SP is allowed, locked by LOCK_CFG field
◆ GPC_CPU_MODE_CTRL_CM_SP_MAPPING_CPU_SP9_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_CURRENT [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_CURRENT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_CURRENT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_CURRENT_MASK)
CPU_SP_CURRENT - The current Setpoint of the system
◆ GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_CURRENT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_PREVIOUS [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_PREVIOUS (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_PREVIOUS_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_PREVIOUS_MASK)
CPU_SP_PREVIOUS - The previous Setpoint of the system
◆ GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_PREVIOUS [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_TARGET [1/2]
#define GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_TARGET (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_TARGET_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_TARGET_MASK)
CPU_SP_TARGET - The requested Setpoint from the CPU platform
◆ GPC_CPU_MODE_CTRL_CM_SP_STAT_CPU_SP_TARGET [2/2]
◆ GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SLEEP_BUSY [1/2]
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SLEEP_BUSY (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SLEEP_BUSY_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SLEEP_BUSY_MASK)
STBY_SLEEP_BUSY - Indicate the CPU is busy entering standby mode.
◆ GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SLEEP_BUSY [2/2]
◆ GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_STOP [1/2]
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_STOP (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_STOP_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_STOP_MASK)
STBY_STOP - 0x1: Request the chip into standby mode when CPU entering STOP mode, locked by LOCK_CFG field.
◆ GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_STOP [2/2]
◆ GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SUSPEND [1/2]
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SUSPEND (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SUSPEND_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SUSPEND_MASK)
STBY_SUSPEND - 0x1: Request the chip into standby mode when CPU entering SUSPEND mode, locked by LOCK_CFG field.
◆ GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_SUSPEND [2/2]
◆ GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAIT [1/2]
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAIT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAIT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAIT_MASK)
STBY_WAIT - 0x1: Request the chip into standby mode when CPU entering WAIT mode, locked by LOCK_CFG field.
◆ GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAIT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAKEUP_BUSY [1/2]
#define GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAKEUP_BUSY (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAKEUP_BUSY_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAKEUP_BUSY_MASK)
STBY_WAKEUP_BUSY - Indicate the CPU is busy exiting standby mode.
◆ GPC_CPU_MODE_CTRL_CM_STBY_CTRL_STBY_WAKEUP_BUSY [2/2]
◆ GPC_CPU_MODE_CTRL_CM_STOP_MODE_MAPPING_CPU_STOP_MODE_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_STOP_MODE_MAPPING_CPU_STOP_MODE_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_STOP_MODE_MAPPING_CPU_STOP_MODE_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_STOP_MODE_MAPPING_CPU_STOP_MODE_MAPPING_MASK)
CPU_STOP_MODE_MAPPING - Defines which Setpoint is allowed when CPU enters STOP mode. Each bit stands for 1 Setpoint, locked by LOCK_CFG
◆ GPC_CPU_MODE_CTRL_CM_STOP_MODE_MAPPING_CPU_STOP_MODE_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_SUSPEND_MODE_MAPPING_CPU_SUSPEND_MODE_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_SUSPEND_MODE_MAPPING_CPU_SUSPEND_MODE_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_SUSPEND_MODE_MAPPING_CPU_SUSPEND_MODE_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_SUSPEND_MODE_MAPPING_CPU_SUSPEND_MODE_MAPPING_MASK)
CPU_SUSPEND_MODE_MAPPING - Defines which Setpoint is allowed when CPU enters SUSPEND mode. Each bit stands for 1 Setpoint, locked by LOCK_CFG
◆ GPC_CPU_MODE_CTRL_CM_SUSPEND_MODE_MAPPING_CPU_SUSPEND_MODE_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAIT_MODE_MAPPING_CPU_WAIT_MODE_MAPPING [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAIT_MODE_MAPPING_CPU_WAIT_MODE_MAPPING (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAIT_MODE_MAPPING_CPU_WAIT_MODE_MAPPING_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAIT_MODE_MAPPING_CPU_WAIT_MODE_MAPPING_MASK)
CPU_WAIT_MODE_MAPPING - Defines which Setpoint is allowed when CPU enters WAIT mode. Each bit stands for 1 Setpoint, locked by LOCK_CFG
◆ GPC_CPU_MODE_CTRL_CM_WAIT_MODE_MAPPING_CPU_WAIT_MODE_MAPPING [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_STEP_CNT_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_ISO_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_STEP_CNT_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_LPCG_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_STEP_CNT_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_PLL_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_STEP_CNT_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_POWER_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_STEP_CNT_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_RESET_CTRL_STEP_CNT [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_CNT_MODE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_CNT_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_CNT_MODE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_CNT_MODE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_CNT_MODE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_DISABLE [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_DISABLE (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_DISABLE_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_DISABLE_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_DISABLE [2/2]
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_STEP_CNT [1/2]
#define GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_STEP_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_STEP_CNT_SHIFT)) & GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_STEP_CNT_MASK)
◆ GPC_CPU_MODE_CTRL_CM_WAKEUP_SSAR_CTRL_STEP_CNT [2/2]
