This source file contains static assertions to ensure the consistency of interfaces used in C and assembler and it contains the SPARC-specific implementation of _CPU_Initialize(), _CPU_ISR_Get_level(), and _CPU_Context_Initialize().
More...
| SPARC_ASSERT_OFFSET (g5, G5) |
| SPARC_ASSERT_OFFSET (g7, G7) |
| RTEMS_STATIC_ASSERT (offsetof(Context_Control, l0_and_l1)==L0_OFFSET, Context_Control_offset_L0) |
| RTEMS_STATIC_ASSERT (offsetof(Context_Control, l0_and_l1)+4==L1_OFFSET, Context_Control_offset_L1) |
| SPARC_ASSERT_OFFSET (l2, L2) |
| SPARC_ASSERT_OFFSET (l3, L3) |
| SPARC_ASSERT_OFFSET (l4, L4) |
| SPARC_ASSERT_OFFSET (l5, L5) |
| SPARC_ASSERT_OFFSET (l6, L6) |
| SPARC_ASSERT_OFFSET (l7, L7) |
| SPARC_ASSERT_OFFSET (i0, I0) |
| SPARC_ASSERT_OFFSET (i1, I1) |
| SPARC_ASSERT_OFFSET (i2, I2) |
| SPARC_ASSERT_OFFSET (i3, I3) |
| SPARC_ASSERT_OFFSET (i4, I4) |
| SPARC_ASSERT_OFFSET (i5, I5) |
| SPARC_ASSERT_OFFSET (i6_fp, I6_FP) |
| SPARC_ASSERT_OFFSET (i7, I7) |
| SPARC_ASSERT_OFFSET (o6_sp, O6_SP) |
| SPARC_ASSERT_OFFSET (o7, O7) |
| SPARC_ASSERT_OFFSET (psr, PSR) |
| SPARC_ASSERT_OFFSET (isr_dispatch_disable, ISR_DISPATCH_DISABLE_STACK) |
| SPARC_ASSERT_ISF_OFFSET (psr, PSR) |
| SPARC_ASSERT_ISF_OFFSET (pc, PC) |
| SPARC_ASSERT_ISF_OFFSET (npc, NPC) |
| SPARC_ASSERT_ISF_OFFSET (g1, G1) |
| SPARC_ASSERT_ISF_OFFSET (g2, G2) |
| SPARC_ASSERT_ISF_OFFSET (g3, G3) |
| SPARC_ASSERT_ISF_OFFSET (g4, G4) |
| SPARC_ASSERT_ISF_OFFSET (g5, G5) |
| SPARC_ASSERT_ISF_OFFSET (g7, G7) |
| SPARC_ASSERT_ISF_OFFSET (i0, I0) |
| SPARC_ASSERT_ISF_OFFSET (i1, I1) |
| SPARC_ASSERT_ISF_OFFSET (i2, I2) |
| SPARC_ASSERT_ISF_OFFSET (i3, I3) |
| SPARC_ASSERT_ISF_OFFSET (i4, I4) |
| SPARC_ASSERT_ISF_OFFSET (i5, I5) |
| SPARC_ASSERT_ISF_OFFSET (i6_fp, I6_FP) |
| SPARC_ASSERT_ISF_OFFSET (i7, I7) |
| SPARC_ASSERT_ISF_OFFSET (y, Y) |
| SPARC_ASSERT_ISF_OFFSET (tpc, TPC) |
| SPARC_ASSERT_FP_OFFSET (f0_f1, F0_F1) |
| SPARC_ASSERT_FP_OFFSET (f2_f3, F2_F3) |
| SPARC_ASSERT_FP_OFFSET (f4_f5, F4_F5) |
| SPARC_ASSERT_FP_OFFSET (f6_f7, F6_F7) |
| SPARC_ASSERT_FP_OFFSET (f8_f9, F8_F9) |
| SPARC_ASSERT_FP_OFFSET (f10_f11, F10_F11) |
| SPARC_ASSERT_FP_OFFSET (f12_f13, F12_F13) |
| SPARC_ASSERT_FP_OFFSET (f14_f15, F14_F15) |
| SPARC_ASSERT_FP_OFFSET (f16_f17, F16_F17) |
| SPARC_ASSERT_FP_OFFSET (f18_f19, F18_F19) |
| SPARC_ASSERT_FP_OFFSET (f20_f21, F20_F21) |
| SPARC_ASSERT_FP_OFFSET (f22_f23, F22_F23) |
| SPARC_ASSERT_FP_OFFSET (f24_f25, F24_F25) |
| SPARC_ASSERT_FP_OFFSET (f26_f27, F26_F27) |
| SPARC_ASSERT_FP_OFFSET (f28_f29, F28_F29) |
| SPARC_ASSERT_FP_OFFSET (f30_f31, F30_F31) |
| SPARC_ASSERT_FP_OFFSET (fsr, FSR) |
| RTEMS_STATIC_ASSERT (sizeof(SPARC_Minimum_stack_frame)==SPARC_MINIMUM_STACK_FRAME_SIZE, SPARC_MINIMUM_STACK_FRAME_SIZE) |
| RTEMS_STATIC_ASSERT (sizeof(CPU_Interrupt_frame) % CPU_ALIGNMENT==0, CPU_Interrupt_frame_alignment) |
| SPARC_ASSERT_REGISTER_WINDOW_OFFSET (local[0], LOCAL(0)) |
| SPARC_ASSERT_REGISTER_WINDOW_OFFSET (local[1], LOCAL(1)) |
| SPARC_ASSERT_REGISTER_WINDOW_OFFSET (input[0], INPUT(0)) |
| SPARC_ASSERT_REGISTER_WINDOW_OFFSET (input[1], INPUT(1)) |
| RTEMS_STATIC_ASSERT (sizeof(SPARC_Register_window)==SPARC_REGISTER_WINDOW_SIZE, SPARC_REGISTER_WINDOW_SIZE) |
| SPARC_ASSERT_EXCEPTION_OFFSET (psr, PSR) |
| SPARC_ASSERT_EXCEPTION_OFFSET (pc, PC) |
| SPARC_ASSERT_EXCEPTION_OFFSET (npc, NPC) |
| SPARC_ASSERT_EXCEPTION_OFFSET (trap, TRAP) |
| SPARC_ASSERT_EXCEPTION_OFFSET (wim, WIM) |
| SPARC_ASSERT_EXCEPTION_OFFSET (y, Y) |
| SPARC_ASSERT_EXCEPTION_OFFSET (global[0], GLOBAL(0)) |
| SPARC_ASSERT_EXCEPTION_OFFSET (global[1], GLOBAL(1)) |
| SPARC_ASSERT_EXCEPTION_OFFSET (output[0], OUTPUT(0)) |
| SPARC_ASSERT_EXCEPTION_OFFSET (output[1], OUTPUT(1)) |
| RTEMS_STATIC_ASSERT (sizeof(CPU_Exception_frame)==SPARC_EXCEPTION_FRAME_SIZE, SPARC_EXCEPTION_FRAME_SIZE) |
| RTEMS_STATIC_ASSERT (sizeof(CPU_Exception_frame) % CPU_ALIGNMENT==0, CPU_Exception_frame_alignment) |
| void | _CPU_Initialize (void) |
| | CPU initialization.
| uint32_t | _CPU_ISR_Get_level (void) |
| | Returns the interrupt level of the executing thread.
| void | _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
