RTEMS 6.1
SPARC_Minimum_stack_frame Struct Reference
#include <cpu.h>
uint32_t l0
uint32_t l1
uint32_t l2
uint32_t l3
uint32_t l4
uint32_t l5
uint32_t l6
uint32_t l7
uint32_t i0
uint32_t i1
uint32_t i2
uint32_t i3
uint32_t i4
uint32_t i5
uint32_t i6_fp
uint32_t i7
void * structure_return_address
uint32_t saved_arg0
uint32_t saved_arg1
uint32_t saved_arg2
uint32_t saved_arg3
uint32_t saved_arg4
uint32_t saved_arg5
uint32_t pad0
This structure represents the organization of the minimum stack frame for the SPARC. More framing information is required in certain situaions such as when there are a large number of out parameters or when the callee must save floating point registers.
Field Documentation
◆ i0
uint32_t SPARC_Minimum_stack_frame::i0
This is the offset of the l0 register.
◆ i1
uint32_t SPARC_Minimum_stack_frame::i1
This is the offset of the i1 register.
◆ i2
uint32_t SPARC_Minimum_stack_frame::i2
This is the offset of the i2 register.
◆ i3
uint32_t SPARC_Minimum_stack_frame::i3
This is the offset of the i3 register.
◆ i4
uint32_t SPARC_Minimum_stack_frame::i4
This is the offset of the i4 register.
◆ i5
uint32_t SPARC_Minimum_stack_frame::i5
This is the offset of the i5 register.
◆ i6_fp
uint32_t SPARC_Minimum_stack_frame::i6_fp
This is the offset of the i6 register.
◆ i7
uint32_t SPARC_Minimum_stack_frame::i7
This is the offset of the i7 register.
◆ l0
uint32_t SPARC_Minimum_stack_frame::l0
◆ l1
uint32_t SPARC_Minimum_stack_frame::l1
This is the offset of the l1 register.
◆ l2
uint32_t SPARC_Minimum_stack_frame::l2
This is the offset of the l2 register.
◆ l3
uint32_t SPARC_Minimum_stack_frame::l3
This is the offset of the l3 register.
◆ l4
uint32_t SPARC_Minimum_stack_frame::l4
This is the offset of the l4 register.
◆ l5
uint32_t SPARC_Minimum_stack_frame::l5
This is the offset of the l5 register.
◆ l6
uint32_t SPARC_Minimum_stack_frame::l6
This is the offset of the l6 register.
◆ l7
uint32_t SPARC_Minimum_stack_frame::l7
This is the offset of the l7 register.
◆ pad0
uint32_t SPARC_Minimum_stack_frame::pad0
This field pads the structure so ldd and std instructions can be used.
◆ saved_arg0
uint32_t SPARC_Minimum_stack_frame::saved_arg0
This is the offset of the register for saved argument 0.
◆ saved_arg1
uint32_t SPARC_Minimum_stack_frame::saved_arg1
This is the offset of the register for saved argument 1.
◆ saved_arg2
uint32_t SPARC_Minimum_stack_frame::saved_arg2
This is the offset of the register for saved argument 2.
◆ saved_arg3
uint32_t SPARC_Minimum_stack_frame::saved_arg3
This is the offset of the register for saved argument 3.
◆ saved_arg4
uint32_t SPARC_Minimum_stack_frame::saved_arg4
This is the offset of the register for saved argument 4.
◆ saved_arg5
uint32_t SPARC_Minimum_stack_frame::saved_arg5
This is the offset of the register for saved argument 5.
◆ structure_return_address
void* SPARC_Minimum_stack_frame::structure_return_address
This is the offset of the register used to return structures.
