RTEMS 6.1
Functions | Variables
cpu.c File Reference
SuperH CPU Support. More...
#include <rtems/score/cpuimpl.h>
#include <rtems/score/isr.h>
#include <rtems/score/sh_io.h>
#include <rtems/score/sh.h>
void _CPU_Initialize (void)
 CPU initialization.
uint32_t _CPU_ISR_Get_level (void)
 Returns the interrupt level of the executing thread.
void _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
 SPARC specific raw ISR installer.
void _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
 SPARC specific RTEMS ISR installer.
void _CPU_Context_Initialize (Context_Control *_the_context, void *_stack_base, uint32_t _size, uint32_t _isr, void(*_entry_point)(void), int _is_fp, void *_tls_base)
CPU_ISR_raw_handler vectab [256]
SuperH CPU Support.
This file contains information pertaining to the Hitachi SH processor.
◆ _CPU_ISR_install_raw_handler()
void _CPU_ISR_install_raw_handler ( uint32_t  vector,
CPU_ISR_raw_handler *  old_handler
This routine installs new_handler to be directly called from the trap table.
Parameters
[in]vectoris the vector number
[in]new_handleris the new ISR handler
[in]old_handlerwill contain the old ISR handler
