RTEMS 6.1
sh.h
1
10/*
11 * Authors: Ralf Corsepius (corsepiu@faw.uni-ulm.de) and
12 * Bernd Becker (becker@faw.uni-ulm.de)
13 *
14 * COPYRIGHT (c) 1997-1998, FAW Ulm, Germany
15 *
16 * This program is distributed in the hope that it will be useful,
17 * but WITHOUT ANY WARRANTY; without even the implied warranty of
18 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE
19 *
20 *
21 * COPYRIGHT (c) 1998-2001.
22 * On-Line Applications Research Corporation (OAR).
23 *
24 * The license and distribution terms for this file may be
25 * found in the file LICENSE in this distribution or at
26 * http://www.rtems.org/license/LICENSE.
27 */
28
29#ifndef _RTEMS_SCORE_SH_H
30#define _RTEMS_SCORE_SH_H
31
32#ifdef __cplusplus
33extern "C" {
34#endif
35
36/*
37 * This file contains the information required to build
38 * RTEMS for a particular member of the "SH" family.
39 *
40 * It does this by setting variables to indicate which implementation
41 * dependent features are present in a particular member of the family.
42 */
43
44/*
45 * Figure out all CPU Model Feature Flags based upon compiler
46 * predefines.
47 */
48
49#if defined(__SH2E__) || defined(__SH3E__)
50
51/* FIXME: SH-DSP context not currently supported */
52#define SH_HAS_FPU 0
53
54#elif defined(__SH4__) || defined(__SH4_SINGLE_ONLY__)
55
56/*
57 * Define this if you want to use XD-registers.
58 * Then this registers will be saved/restored on context switch.
59 * ! They will not be saved/restored on interrupts!
60 */
61#define SH4_USE_X_REGISTERS 0
62
63#if defined(__LITTLE_ENDIAN__)
64#define SH_HAS_FPU 1
65#else
66/* FIXME: Context_Control_fp does not support big endian */
67#warning FPU not supported
68#define SH_HAS_FPU 0
69#endif
70
71#elif defined(__sh1__) || defined(__sh2__) || defined(__sh3__)
72#define SH_HAS_FPU 0
73#else
74#warning Cannot detect FPU support, assuming no FPU
75#define SH_HAS_FPU 0
76#endif
77
78/* this should not be here */
79#ifndef CPU_MODEL_NAME
80#define CPU_MODEL_NAME "SH-Multilib"
81#endif
82
83/*
84 * If the following macro is set to 0 there will be no software irq stack
85 */
86
87#ifndef SH_HAS_SEPARATE_STACKS
88#define SH_HAS_SEPARATE_STACKS 1
89#endif
90
91/*
92 * Define the name of the CPU family.
93 */
94
95#define CPU_NAME "Hitachi SH"
96
97#ifndef ASM
98
99#if defined(__sh1__) || defined(__sh2__)
100
101/*
102 * Mask for disabling interrupts
103 */
104#define SH_IRQDIS_VALUE 0xf0
105
106#define sh_disable_interrupts( _level ) \
107 __asm__ volatile ( \
108 "stc sr,%0\n\t" \
109 "ldc %1,sr\n\t"\
110 : "=&r" (_level ) \
111 : "r" (SH_IRQDIS_VALUE) );
112
113#define sh_enable_interrupts( _level ) \
114 __asm__ volatile( "ldc %0,sr\n\t" \
115 "nop\n\t" \
116 :: "r" (_level) );
117
118/*
119 * This temporarily restores the interrupt to _level before immediately
120 * disabling them again. This is used to divide long RTEMS critical
121 * sections into two or more parts. The parameter _level is not
122 * modified.
123 */
124
125#define sh_flash_interrupts( _level ) \
126 __asm__ volatile( \
127 "ldc %1,sr\n\t" \
128 "nop\n\t" \
129 "ldc %0,sr\n\t" \
130 "nop\n\t" \
131 : : "r" (SH_IRQDIS_VALUE), "r" (_level) );
132
133#else
134
135#define SH_IRQDIS_MASK 0xf0
136
137#define sh_disable_interrupts( _level ) \
138 __asm__ volatile ( \
139 "stc sr,%0\n\t" \
140 "mov %0,r5\n\t" \
141 "or %1,r5\n\t" \
142 "ldc r5,sr\n\t"\
143 : "=&r" (_level ) \
144 : "r" (SH_IRQDIS_MASK) \
145 : "r5" );
146
147#define sh_enable_interrupts( _level ) \
148 __asm__ volatile( "ldc %0,sr\n\t" \
149 "nop\n\t" \
150 :: "r" (_level) );
151
152/*
153 * This temporarily restores the interrupt to _level before immediately
154 * disabling them again. This is used to divide long RTEMS critical
155 * sections into two or more parts. The parameter _level is not
156 * modified.
157 */
158
159#define sh_flash_interrupts( _level ) \
160 __asm__ volatile( \
161 "stc sr,r5\n\t" \
162 "ldc %1,sr\n\t" \
163 "nop\n\t" \
164 "or %0,r5\n\t" \
165 "ldc r5,sr\n\t" \
166 "nop\n\t" \
167 : : "r" (SH_IRQDIS_MASK), "r" (_level) : "r5");
168
169#endif
170
171#define sh_get_interrupt_level( _level ) \
172{ \
173 uint32_t _tmpsr ; \
174 \
175 __asm__ volatile( "stc sr, %0" : "=r" (_tmpsr) ); \
176 _level = (_tmpsr & 0xf0) >> 4 ; \
177}
178
179#define sh_set_interrupt_level( _newlevel ) \
180{ \
181 uint32_t _tmpsr; \
182 \
183 __asm__ volatile ( "stc sr, %0" : "=r" (_tmpsr) ); \
184 _tmpsr = ( _tmpsr & ~0xf0 ) | ((_newlevel) << 4) ; \
185 __asm__ volatile( "ldc %0,sr" :: "r" (_tmpsr) ); \
186}
187
188/*
189 * The following routine swaps the endian format of an unsigned int.
190 * It must be static because it is referenced indirectly.
191 */
192
193static inline uint32_t sh_swap_u32(
194 uint32_t value
195)
196{
197 uint32_t swapped;
198
199 __asm__ volatile (
200 "swap.b %1,%0; "
201 "swap.w %0,%0; "
202 "swap.b %0,%0"
203 : "=r" (swapped)
204 : "r" (value) );
205
206 return( swapped );
207}
208
209static inline uint16_t sh_swap_u16(
210 uint16_t value
211)
212{
213 uint16_t swapped ;
214
215 __asm__ volatile ( "swap.b %1,%0" : "=r" (swapped) : "r" (value) );
216
217 return( swapped );
218}
219
220#define CPU_swap_u32( value ) sh_swap_u32( value )
221#define CPU_swap_u16( value ) sh_swap_u16( value )
222
223extern unsigned int sh_set_irq_priority(
224 unsigned int irq,
225 unsigned int prio );
226
227#endif /* !ASM */
228
229/*
230 * Bits on SH-4 registers.
231 * See SH-4 Programming manual for more details.
232 *
233 * Added by Alexandra Kossovsky <sasha@oktet.ru>
234 */
235
236#if defined(__SH4__)
237#define SH4_SR_MD 0x40000000 /* Priveleged mode */
238#define SH4_SR_RB 0x20000000 /* General register bank specifier */
239#define SH4_SR_BL 0x10000000 /* Exeption/interrupt masking bit */
240#define SH4_SR_FD 0x00008000 /* FPU disable bit */
241#define SH4_SR_M 0x00000200 /* For signed division:
242 divisor (module) is negative */
243#define SH4_SR_Q 0x00000100 /* For signed division:
244 dividend (and quotient) is negative */
245#define SH4_SR_IMASK 0x000000f0 /* Interrupt mask level */
246#define SH4_SR_IMASK_S 4
247#define SH4_SR_S 0x00000002 /* Saturation for MAC instruction:
248 if set, data in MACH/L register
249 is restricted to 48/32 bits
250 for MAC.W/L instructions */
251#define SH4_SR_T 0x00000001 /* 1 if last condiyion was true */
252#define SH4_SR_RESERV 0x8fff7d0d /* Reserved bits, read/write as 0 */
253
254/* FPSCR -- FPU Status/Control Register */
255#define SH4_FPSCR_FR 0x00200000 /* FPU register bank specifier */
256#define SH4_FPSCR_SZ 0x00100000 /* FMOV 64-bit transfer mode */
257#define SH4_FPSCR_PR 0x00080000 /* Double-percision floating-point
258 operations flag */
259 /* SH4_FPSCR_SZ & SH4_FPSCR_PR != 1 */
260#define SH4_FPSCR_DN 0x00040000 /* Treat denormalized number as zero */
261#define SH4_FPSCR_CAUSE 0x0003f000 /* FPU exeption cause field */
262#define SH4_FPSCR_CAUSE_S 12
263#define SH4_FPSCR_ENABLE 0x00000f80 /* FPU exeption enable field */
264#define SH4_FPSCR_ENABLE_s 7
265#define SH4_FPSCR_FLAG 0x0000007d /* FPU exeption flag field */
266#define SH4_FPSCR_FLAG_S 2
267#define SH4_FPSCR_RM 0x00000001 /* Rounding mode:
268 1/0 -- round to zero/nearest */
269#define SH4_FPSCR_RESERV 0xffd00000 /* Reserved bits, read/write as 0 */
270
271#endif
272
273#ifdef __cplusplus
274}
275#endif
276
277#endif
