RTEMS 6.1
This source file contains the Clock Driver for Cortex-A9 MPCore compatible devices. More...
#include <bsp.h>#include <bsp/fatal.h>#include <bsp/irq.h>#include <bsp/irq-generic.h>#include <bsp/arm-a9mpcore-regs.h>#include <bsp/arm-a9mpcore-clock.h>#include <rtems/timecounter.h>#include <rtems/score/smpimpl.h>#include "../../shared/dev/clock/clockimpl.h"Macros | |
| #define | A9MPCORE_GT ((volatile a9mpcore_gt *) BSP_ARM_A9MPCORE_GT_BASE) |
| #define | Clock_driver_support_at_tick(arg) a9mpcore_clock_at_tick(arg) |
| #define | Clock_driver_support_initialize_hardware() a9mpcore_clock_initialize() |
| #define | Clock_driver_support_install_isr(isr) a9mpcore_clock_handler_install(isr) |
| __attribute__ ((weak)) | |
| uint32_t | _CPU_Counter_frequency (void) |
| Gets the current CPU counter frequency in Hz. | |
| CPU_Counter_ticks | _CPU_Counter_read (void) |
| Gets the current CPU counter value. | |
| __attribute__ | ( | (weak) | ) |
External Trace Linker and TBG data. We provide weak versions to allow us to link and be present in an application that has not been trace linked.
