RTEMS 6.1
arm-a9mpcore-clock.h
2
11/*
12 * Copyright (c) 2013 Chris Johns <chrisj@rtems.org>. All rights reserved.
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_SHARED_ARM_A9MPCORE_CLOCK_H
37#define LIBBSP_ARM_SHARED_ARM_A9MPCORE_CLOCK_H
38
39#include <rtems/counter.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
51/*
52 * Return the peripheral clock. For systems such as the zynq this
53 * is controlled by the PL logic generation and can vary. Provide this
54 * function in your application to override the BSP default.
55 */
56uint32_t a9mpcore_clock_periphclk(void);
57
60#ifdef __cplusplus
61}
62#endif /* __cplusplus */
63
64#endif /* LIBBSP_ARM_SHARED_ARM_A9MPCORE_CLOCK_H */
This header file defines the Free-Running Counter and Busy Wait Delay API.
