RTEMS 5.2
ratemonimpl.h
1
9/* COPYRIGHT (c) 1989-2008.
10 * On-Line Applications Research Corporation (OAR).
11 * Copyright (c) 2016 embedded brains GmbH.
12 * COPYRIGHT (c) 2016 Kuan-Hsun Chen.
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef _RTEMS_RTEMS_RATEMONIMPL_H
20#define _RTEMS_RTEMS_RATEMONIMPL_H
21
27
28#include <string.h>
29
30#ifdef __cplusplus
31extern "C" {
32#endif
33
42#define RATE_MONOTONIC_INTEND_TO_BLOCK \
43 ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_INTEND_TO_BLOCK )
44
45#define RATE_MONOTONIC_BLOCKED \
46 ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_BLOCKED )
47
48#define RATE_MONOTONIC_READY_AGAIN \
49 ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_READY_AGAIN )
50
59{
60 return (Rate_monotonic_Control *)
62}
63
64RTEMS_INLINE_ROUTINE void _Rate_monotonic_Acquire_critical(
65 Rate_monotonic_Control *the_period,
66 ISR_lock_Context *lock_context
67)
68{
69 _ISR_lock_Acquire( &the_period->Lock, lock_context );
70}
71
72RTEMS_INLINE_ROUTINE void _Rate_monotonic_Release(
73 Rate_monotonic_Control *the_period,
74 ISR_lock_Context *lock_context
75)
76{
77 _ISR_lock_Release_and_ISR_enable( &the_period->Lock, lock_context );
78}
79
81 Objects_Id id,
82 ISR_lock_Context *lock_context
83)
84{
85 return (Rate_monotonic_Control *)
86 _Objects_Get( id, lock_context, &_Rate_monotonic_Information );
87}
88
89void _Rate_monotonic_Timeout( Watchdog_Control *watchdog );
90
107 const Rate_monotonic_Control *the_period,
108 Timestamp_Control *wall_since_last_period,
109 Timestamp_Control *cpu_since_last_period
110);
111
112void _Rate_monotonic_Restart(
113 Rate_monotonic_Control *the_period,
114 Thread_Control *owner,
115 ISR_lock_Context *lock_context
116);
117
118void _Rate_monotonic_Cancel(
119 Rate_monotonic_Control *the_period,
120 Thread_Control *owner,
121 ISR_lock_Context *lock_context
122);
123
124RTEMS_INLINE_ROUTINE void _Rate_monotonic_Reset_min_time(
125 Timestamp_Control *min_time
126)
127{
128 _Timestamp_Set( min_time, 0x7fffffff, 0x7fffffff );
129}
130
131RTEMS_INLINE_ROUTINE void _Rate_monotonic_Reset_statistics(
132 Rate_monotonic_Control *the_period
133)
134{
135 Rate_monotonic_Statistics *statistics;
136
137 statistics = &the_period->Statistics;
138 memset( statistics, 0, sizeof( *statistics ) );
139 _Rate_monotonic_Reset_min_time( &statistics->min_wall_time );
140 _Rate_monotonic_Reset_min_time( &statistics->min_cpu_time );
141}
142
145#ifdef __cplusplus
146}
147#endif
148
149#endif
150/* end of include file */
bool _Rate_monotonic_Get_status(const Rate_monotonic_Control *the_period, Timestamp_Control *wall_since_last_period, Timestamp_Control *cpu_since_last_period)
Definition: ratemonperiod.c:27
RTEMS_INLINE_ROUTINE Rate_monotonic_Control * _Rate_monotonic_Allocate(void)
Allocates a period control block from the inactive chain of free period control blocks.
Definition: ratemonimpl.h:58
Objects_Information _Rate_monotonic_Information
The Classic Rate Monotonic objects information.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
#define _ISR_lock_Acquire(_lock, _context)
Acquires an ISR lock inside an ISR disabled section.
Definition: isrlock.h:293
#define _ISR_lock_Release_and_ISR_enable(_lock, _context)
Releases an ISR lock.
Definition: isrlock.h:263
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition: objectallocate.c:42
uint32_t Objects_Id
Definition: object.h:80
Objects_Control * _Objects_Get(Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information)
Maps the specified object identifier to the associated local object control block.
Definition: objectgetlocal.c:28
RTEMS_INLINE_ROUTINE void _Timestamp_Set(Timestamp_Control *_time, time_t _seconds, long _nanoseconds)
Sets timestamp to specified seconds and nanoseconds.
Definition: timestampimpl.h:48
int64_t Timestamp_Control
Definition: timestamp.h:57
Inlined Routines in the Object Handler.
Classic Rate Monotonic Scheduler Data Structures.
Inlined Routines Associated with the Manipulation of the Scheduler.
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
The following structure defines the control block used to manage each period.
Definition: ratemondata.h:69
Rate_monotonic_Statistics Statistics
Definition: ratemondata.h:118
Definition: ratemondata.h:40
Timestamp_Control min_wall_time
Definition: ratemondata.h:54
Timestamp_Control min_cpu_time
Definition: ratemondata.h:47
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
Definition: thread.h:732
Inlined Routines from the Thread Handler.
Inlined Routines in the Watchdog Handler.
