RTEMS 5.2
Files | |
| file | modesimpl.h |
| Classic Modes Implementation. | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Mask_changed (rtems_mode mode_set, rtems_mode masks) |
| Checks if any of the mode flags in mask are set in mode_set. More... | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Is_asr_disabled (rtems_mode mode_set) |
| Checks if mode_set says that Asynchronous Signal Processing is disabled. More... | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Is_preempt (rtems_mode mode_set) |
| Checks if mode_set indicates that preemption is enabled. More... | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Is_timeslice (rtems_mode mode_set) |
| Checks if mode_set indicates that timeslicing is enabled. More... | |
| RTEMS_INLINE_ROUTINE ISR_Level | _Modes_Get_interrupt_level (rtems_mode mode_set) |
| Gets the interrupt level portion of the mode_set. More... | |
| RTEMS_INLINE_ROUTINE void | _Modes_Set_interrupt_level (rtems_mode mode_set) |
| Sets the current interrupt level to that specified in the mode_set. More... | |
| RTEMS_INLINE_ROUTINE void | _Modes_Change (rtems_mode old_mode_set, rtems_mode new_mode_set, rtems_mode mask, rtems_mode *out_mode_set, rtems_mode *changed) |
| Changes the modes in old_mode_set indicated by mask to the requested values in new_mode_set. More... | |
| RTEMS_INLINE_ROUTINE void _Modes_Change | ( | rtems_mode | old_mode_set, |
| rtems_mode | new_mode_set, | ||
| rtems_mode | mask, | ||
| rtems_mode * | out_mode_set, | ||
| rtems_mode * | changed | ||
This routine changes the modes in old_mode_set indicated by mask to the requested values in new_mode_set. The resulting mode set is returned in out_mode_set and the modes that changed is returned in changed.
| RTEMS_INLINE_ROUTINE ISR_Level _Modes_Get_interrupt_level | ( | rtems_mode | mode_set | ) |
This function returns the interrupt level portion of the mode_set.
| RTEMS_INLINE_ROUTINE bool _Modes_Is_asr_disabled | ( | rtems_mode | mode_set | ) |
This function returns TRUE if mode_set indicates that Asynchronous Signal Processing is disabled, and FALSE otherwise.
| RTEMS_INLINE_ROUTINE bool _Modes_Is_preempt | ( | rtems_mode | mode_set | ) |
This function returns TRUE if mode_set indicates that preemption is enabled, and FALSE otherwise.
| RTEMS_INLINE_ROUTINE bool _Modes_Is_timeslice | ( | rtems_mode | mode_set | ) |
This function returns TRUE if mode_set indicates that timeslicing is enabled, and FALSE otherwise.
| RTEMS_INLINE_ROUTINE bool _Modes_Mask_changed | ( | rtems_mode | mode_set, |
| rtems_mode | masks | ||
This function returns TRUE if any of the mode flags in mask are set in mode_set, and FALSE otherwise.
| RTEMS_INLINE_ROUTINE void _Modes_Set_interrupt_level | ( | rtems_mode | mode_set | ) |
This routine sets the current interrupt level to that specified in the mode_set.
