RTEMS 5.2
core_cm7.h
1/**************************************************************************/
7/* Copyright (c) 2009 - 2015 ARM LIMITED
8
9 All rights reserved.
10 Redistribution and use in source and binary forms, with or without
11 modification, are permitted provided that the following conditions are met:
12 - Redistributions of source code must retain the above copyright
13 notice, this list of conditions and the following disclaimer.
14 - Redistributions in binary form must reproduce the above copyright
15 notice, this list of conditions and the following disclaimer in the
16 documentation and/or other materials provided with the distribution.
17 - Neither the name of ARM nor the names of its contributors may be used
18 to endorse or promote products derived from this software without
19 specific prior written permission.
20 *
21 THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
25 LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 POSSIBILITY OF SUCH DAMAGE.
32 ---------------------------------------------------------------------------*/
33
34
35#if defined ( __ICCARM__ )
36 #pragma system_include /* treat file as system include file for MISRA check */
37#elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
38 #pragma clang system_header /* treat file as system include file */
39#endif
40
41#ifndef __CORE_CM7_H_GENERIC
42#define __CORE_CM7_H_GENERIC
43
44#include <stdint.h>
45
46#ifdef __cplusplus
47 extern "C" {
48#endif
49
65/*******************************************************************************
66 * CMSIS definitions
67 ******************************************************************************/
73/* CMSIS CM7 definitions */
74#define __CM7_CMSIS_VERSION_MAIN (0x04U)
75#define __CM7_CMSIS_VERSION_SUB (0x1EU)
76#define __CM7_CMSIS_VERSION ((__CM7_CMSIS_VERSION_MAIN << 16U) | \
77 __CM7_CMSIS_VERSION_SUB )
79#define __CORTEX_M (0x07U)
82#if defined ( __CC_ARM )
83 #define __ASM __asm
84 #define __INLINE __inline
85 #define __STATIC_INLINE static __inline
86
87#elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
88 #define __ASM __asm
89 #define __INLINE __inline
90 #define __STATIC_INLINE static __inline
91
92#elif defined ( __GNUC__ )
93 #define __ASM __asm
94 #define __INLINE inline
95 #define __STATIC_INLINE static inline
96
97#elif defined ( __ICCARM__ )
98 #define __ASM __asm
99 #define __INLINE inline
100 #define __STATIC_INLINE static inline
101
102#elif defined ( __TMS470__ )
103 #define __ASM __asm
104 #define __STATIC_INLINE static inline
105
106#elif defined ( __TASKING__ )
107 #define __ASM __asm
108 #define __INLINE inline
109 #define __STATIC_INLINE static inline
110
111#elif defined ( __CSMC__ )
112 #define __packed
113 #define __ASM _asm
114 #define __INLINE inline
115 #define __STATIC_INLINE static inline
116
117#else
118 #error Unknown compiler
119#endif
120
124#if defined ( __CC_ARM )
125 #if defined __TARGET_FPU_VFP
126 #if (__FPU_PRESENT == 1U)
127 #define __FPU_USED 1U
128 #else
129 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
130 #define __FPU_USED 0U
131 #endif
132 #else
133 #define __FPU_USED 0U
134 #endif
135
136#elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
137 #if defined __ARM_PCS_VFP
138 #if (__FPU_PRESENT == 1)
139 #define __FPU_USED 1U
140 #else
141 #warning "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
142 #define __FPU_USED 0U
143 #endif
144 #else
145 #define __FPU_USED 0U
146 #endif
147
148#elif defined ( __GNUC__ )
149 #if defined (__VFP_FP__) && !defined(__SOFTFP__)
150 #if (__FPU_PRESENT == 1U)
151 #define __FPU_USED 1U
152 #else
153 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
154 #define __FPU_USED 0U
155 #endif
156 #else
157 #define __FPU_USED 0U
158 #endif
159
160#elif defined ( __ICCARM__ )
161 #if defined __ARMVFP__
162 #if (__FPU_PRESENT == 1U)
163 #define __FPU_USED 1U
164 #else
165 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
166 #define __FPU_USED 0U
167 #endif
168 #else
169 #define __FPU_USED 0U
170 #endif
171
172#elif defined ( __TMS470__ )
173 #if defined __TI_VFP_SUPPORT__
174 #if (__FPU_PRESENT == 1U)
175 #define __FPU_USED 1U
176 #else
177 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
178 #define __FPU_USED 0U
179 #endif
180 #else
181 #define __FPU_USED 0U
182 #endif
183
184#elif defined ( __TASKING__ )
185 #if defined __FPU_VFP__
186 #if (__FPU_PRESENT == 1U)
187 #define __FPU_USED 1U
188 #else
189 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
190 #define __FPU_USED 0U
191 #endif
192 #else
193 #define __FPU_USED 0U
194 #endif
195
196#elif defined ( __CSMC__ )
197 #if ( __CSMC__ & 0x400U)
198 #if (__FPU_PRESENT == 1U)
199 #define __FPU_USED 1U
200 #else
201 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
202 #define __FPU_USED 0U
203 #endif
204 #else
205 #define __FPU_USED 0U
206 #endif
207
208#endif
209
210#include "core_cmInstr.h" /* Core Instruction Access */
211#include "core_cmFunc.h" /* Core Function Access */
212#include "core_cmSimd.h" /* Compiler specific SIMD Intrinsics */
213
214#ifdef __cplusplus
215}
216#endif
217
218#endif /* __CORE_CM7_H_GENERIC */
219
220#ifndef __CMSIS_GENERIC
221
222#ifndef __CORE_CM7_H_DEPENDANT
223#define __CORE_CM7_H_DEPENDANT
224
225#ifdef __cplusplus
226 extern "C" {
227#endif
228
229/* check device defines and use defaults */
230#if defined __CHECK_DEVICE_DEFINES
231 #ifndef __CM7_REV
232 #define __CM7_REV 0x0000U
233 #warning "__CM7_REV not defined in device header file; using default!"
234 #endif
235
236 #ifndef __FPU_PRESENT
237 #define __FPU_PRESENT 0U
238 #warning "__FPU_PRESENT not defined in device header file; using default!"
239 #endif
240
241 #ifndef __MPU_PRESENT
242 #define __MPU_PRESENT 0U
243 #warning "__MPU_PRESENT not defined in device header file; using default!"
244 #endif
245
246 #ifndef __ICACHE_PRESENT
247 #define __ICACHE_PRESENT 0U
248 #warning "__ICACHE_PRESENT not defined in device header file; using default!"
249 #endif
250
251 #ifndef __DCACHE_PRESENT
252 #define __DCACHE_PRESENT 0U
253 #warning "__DCACHE_PRESENT not defined in device header file; using default!"
254 #endif
255
256 #ifndef __DTCM_PRESENT
257 #define __DTCM_PRESENT 0U
258 #warning "__DTCM_PRESENT not defined in device header file; using default!"
259 #endif
260
261 #ifndef __NVIC_PRIO_BITS
262 #define __NVIC_PRIO_BITS 3U
263 #warning "__NVIC_PRIO_BITS not defined in device header file; using default!"
264 #endif
265
266 #ifndef __Vendor_SysTickConfig
267 #define __Vendor_SysTickConfig 0U
268 #warning "__Vendor_SysTickConfig not defined in device header file; using default!"
269 #endif
270#endif
271
272/* IO definitions (access restrictions to peripheral registers) */
281#ifdef __cplusplus
282 #define __I volatile
283#else
284 #define __I volatile const
285#endif
286#define __O volatile
287#define __IO volatile
289/* following defines should be used for structure members */
290#define __IM volatile const
291#define __OM volatile
292#define __IOM volatile
298/*******************************************************************************
299 * Register Abstraction
300 Core Register contain:
301 - Core Register
302 - Core NVIC Register
303 - Core SCB Register
304 - Core SysTick Register
305 - Core Debug Register
306 - Core MPU Register
307 - Core FPU Register
308 ******************************************************************************/
325typedef union
326{
327 struct
328 {
329 uint32_t _reserved0:16;
330 uint32_t GE:4;
331 uint32_t _reserved1:7;
332 uint32_t Q:1;
333 uint32_t V:1;
334 uint32_t C:1;
335 uint32_t Z:1;
336 uint32_t N:1;
337 } b;
338 uint32_t w;
339} APSR_Type;
340
341/* APSR Register Definitions */
342#define APSR_N_Pos 31U
343#define APSR_N_Msk (1UL << APSR_N_Pos)
345#define APSR_Z_Pos 30U
346#define APSR_Z_Msk (1UL << APSR_Z_Pos)
348#define APSR_C_Pos 29U
349#define APSR_C_Msk (1UL << APSR_C_Pos)
351#define APSR_V_Pos 28U
352#define APSR_V_Msk (1UL << APSR_V_Pos)
354#define APSR_Q_Pos 27U
355#define APSR_Q_Msk (1UL << APSR_Q_Pos)
357#define APSR_GE_Pos 16U
358#define APSR_GE_Msk (0xFUL << APSR_GE_Pos)
364typedef union
365{
366 struct
367 {
368 uint32_t ISR:9;
369 uint32_t _reserved0:23;
370 } b;
371 uint32_t w;
372} IPSR_Type;
373
374/* IPSR Register Definitions */
375#define IPSR_ISR_Pos 0U
376#define IPSR_ISR_Msk (0x1FFUL /*<< IPSR_ISR_Pos*/)
382typedef union
383{
384 struct
385 {
386 uint32_t ISR:9;
387 uint32_t _reserved0:7;
388 uint32_t GE:4;
389 uint32_t _reserved1:4;
390 uint32_t T:1;
391 uint32_t IT:2;
392 uint32_t Q:1;
393 uint32_t V:1;
394 uint32_t C:1;
395 uint32_t Z:1;
396 uint32_t N:1;
397 } b;
398 uint32_t w;
399} xPSR_Type;
400
401/* xPSR Register Definitions */
402#define xPSR_N_Pos 31U
403#define xPSR_N_Msk (1UL << xPSR_N_Pos)
405#define xPSR_Z_Pos 30U
406#define xPSR_Z_Msk (1UL << xPSR_Z_Pos)
408#define xPSR_C_Pos 29U
409#define xPSR_C_Msk (1UL << xPSR_C_Pos)
411#define xPSR_V_Pos 28U
412#define xPSR_V_Msk (1UL << xPSR_V_Pos)
414#define xPSR_Q_Pos 27U
415#define xPSR_Q_Msk (1UL << xPSR_Q_Pos)
417#define xPSR_IT_Pos 25U
418#define xPSR_IT_Msk (3UL << xPSR_IT_Pos)
420#define xPSR_T_Pos 24U
421#define xPSR_T_Msk (1UL << xPSR_T_Pos)
423#define xPSR_GE_Pos 16U
424#define xPSR_GE_Msk (0xFUL << xPSR_GE_Pos)
426#define xPSR_ISR_Pos 0U
427#define xPSR_ISR_Msk (0x1FFUL /*<< xPSR_ISR_Pos*/)
433typedef union
434{
435 struct
436 {
437 uint32_t nPRIV:1;
438 uint32_t SPSEL:1;
439 uint32_t FPCA:1;
440 uint32_t _reserved0:29;
441 } b;
442 uint32_t w;
444
445/* CONTROL Register Definitions */
446#define CONTROL_FPCA_Pos 2U
447#define CONTROL_FPCA_Msk (1UL << CONTROL_FPCA_Pos)
449#define CONTROL_SPSEL_Pos 1U
450#define CONTROL_SPSEL_Msk (1UL << CONTROL_SPSEL_Pos)
452#define CONTROL_nPRIV_Pos 0U
453#define CONTROL_nPRIV_Msk (1UL /*<< CONTROL_nPRIV_Pos*/)
468typedef struct
469{
470 __IOM uint32_t ISER[8U];
471 uint32_t RESERVED0[24U];
472 __IOM uint32_t ICER[8U];
473 uint32_t RSERVED1[24U];
474 __IOM uint32_t ISPR[8U];
475 uint32_t RESERVED2[24U];
476 __IOM uint32_t ICPR[8U];
477 uint32_t RESERVED3[24U];
478 __IOM uint32_t IABR[8U];
479 uint32_t RESERVED4[56U];
480 __IOM uint8_t IP[240U];
481 uint32_t RESERVED5[644U];
482 __OM uint32_t STIR;
483} NVIC_Type;
484
485/* Software Triggered Interrupt Register Definitions */
486#define NVIC_STIR_INTID_Pos 0U
487#define NVIC_STIR_INTID_Msk (0x1FFUL /*<< NVIC_STIR_INTID_Pos*/)
502typedef struct
503{
504 __IM uint32_t CPUID;
505 __IOM uint32_t ICSR;
506 __IOM uint32_t VTOR;
507 __IOM uint32_t AIRCR;
508 __IOM uint32_t SCR;
509 __IOM uint32_t CCR;
510 __IOM uint8_t SHPR[12U];
511 __IOM uint32_t SHCSR;
512 __IOM uint32_t CFSR;
513 __IOM uint32_t HFSR;
514 __IOM uint32_t DFSR;
515 __IOM uint32_t MMFAR;
516 __IOM uint32_t BFAR;
517 __IOM uint32_t AFSR;
518 __IM uint32_t ID_PFR[2U];
519 __IM uint32_t ID_DFR;
520 __IM uint32_t ID_AFR;
521 __IM uint32_t ID_MFR[4U];
522 __IM uint32_t ID_ISAR[5U];
523 uint32_t RESERVED0[1U];
524 __IM uint32_t CLIDR;
525 __IM uint32_t CTR;
526 __IM uint32_t CCSIDR;
527 __IOM uint32_t CSSELR;
528 __IOM uint32_t CPACR;
529 uint32_t RESERVED3[93U];
530 __OM uint32_t STIR;
531 uint32_t RESERVED4[15U];
532 __IM uint32_t MVFR0;
533 __IM uint32_t MVFR1;
534 __IM uint32_t MVFR2;
535 uint32_t RESERVED5[1U];
536 __OM uint32_t ICIALLU;
537 uint32_t RESERVED6[1U];
538 __OM uint32_t ICIMVAU;
539 __OM uint32_t DCIMVAC;
540 __OM uint32_t DCISW;
541 __OM uint32_t DCCMVAU;
542 __OM uint32_t DCCMVAC;
543 __OM uint32_t DCCSW;
544 __OM uint32_t DCCIMVAC;
545 __OM uint32_t DCCISW;
546 uint32_t RESERVED7[6U];
547 __IOM uint32_t ITCMCR;
548 __IOM uint32_t DTCMCR;
549 __IOM uint32_t AHBPCR;
550 __IOM uint32_t CACR;
551 __IOM uint32_t AHBSCR;
552 uint32_t RESERVED8[1U];
553 __IOM uint32_t ABFSR;
554} SCB_Type;
555
556/* SCB CPUID Register Definitions */
557#define SCB_CPUID_IMPLEMENTER_Pos 24U
558#define SCB_CPUID_IMPLEMENTER_Msk (0xFFUL << SCB_CPUID_IMPLEMENTER_Pos)
560#define SCB_CPUID_VARIANT_Pos 20U
561#define SCB_CPUID_VARIANT_Msk (0xFUL << SCB_CPUID_VARIANT_Pos)
563#define SCB_CPUID_ARCHITECTURE_Pos 16U
564#define SCB_CPUID_ARCHITECTURE_Msk (0xFUL << SCB_CPUID_ARCHITECTURE_Pos)
566#define SCB_CPUID_PARTNO_Pos 4U
567#define SCB_CPUID_PARTNO_Msk (0xFFFUL << SCB_CPUID_PARTNO_Pos)
569#define SCB_CPUID_REVISION_Pos 0U
570#define SCB_CPUID_REVISION_Msk (0xFUL /*<< SCB_CPUID_REVISION_Pos*/)
572/* SCB Interrupt Control State Register Definitions */
573#define SCB_ICSR_NMIPENDSET_Pos 31U
574#define SCB_ICSR_NMIPENDSET_Msk (1UL << SCB_ICSR_NMIPENDSET_Pos)
576#define SCB_ICSR_PENDSVSET_Pos 28U
577#define SCB_ICSR_PENDSVSET_Msk (1UL << SCB_ICSR_PENDSVSET_Pos)
579#define SCB_ICSR_PENDSVCLR_Pos 27U
580#define SCB_ICSR_PENDSVCLR_Msk (1UL << SCB_ICSR_PENDSVCLR_Pos)
582#define SCB_ICSR_PENDSTSET_Pos 26U
583#define SCB_ICSR_PENDSTSET_Msk (1UL << SCB_ICSR_PENDSTSET_Pos)
585#define SCB_ICSR_PENDSTCLR_Pos 25U
586#define SCB_ICSR_PENDSTCLR_Msk (1UL << SCB_ICSR_PENDSTCLR_Pos)
588#define SCB_ICSR_ISRPREEMPT_Pos 23U
589#define SCB_ICSR_ISRPREEMPT_Msk (1UL << SCB_ICSR_ISRPREEMPT_Pos)
591#define SCB_ICSR_ISRPENDING_Pos 22U
592#define SCB_ICSR_ISRPENDING_Msk (1UL << SCB_ICSR_ISRPENDING_Pos)
594#define SCB_ICSR_VECTPENDING_Pos 12U
595#define SCB_ICSR_VECTPENDING_Msk (0x1FFUL << SCB_ICSR_VECTPENDING_Pos)
597#define SCB_ICSR_RETTOBASE_Pos 11U
598#define SCB_ICSR_RETTOBASE_Msk (1UL << SCB_ICSR_RETTOBASE_Pos)
600#define SCB_ICSR_VECTACTIVE_Pos 0U
601#define SCB_ICSR_VECTACTIVE_Msk (0x1FFUL /*<< SCB_ICSR_VECTACTIVE_Pos*/)
603/* SCB Vector Table Offset Register Definitions */
604#define SCB_VTOR_TBLOFF_Pos 7U
605#define SCB_VTOR_TBLOFF_Msk (0x1FFFFFFUL << SCB_VTOR_TBLOFF_Pos)
607/* SCB Application Interrupt and Reset Control Register Definitions */
608#define SCB_AIRCR_VECTKEY_Pos 16U
609#define SCB_AIRCR_VECTKEY_Msk (0xFFFFUL << SCB_AIRCR_VECTKEY_Pos)
611#define SCB_AIRCR_VECTKEYSTAT_Pos 16U
612#define SCB_AIRCR_VECTKEYSTAT_Msk (0xFFFFUL << SCB_AIRCR_VECTKEYSTAT_Pos)
614#define SCB_AIRCR_ENDIANESS_Pos 15U
615#define SCB_AIRCR_ENDIANESS_Msk (1UL << SCB_AIRCR_ENDIANESS_Pos)
617#define SCB_AIRCR_PRIGROUP_Pos 8U
618#define SCB_AIRCR_PRIGROUP_Msk (7UL << SCB_AIRCR_PRIGROUP_Pos)
620#define SCB_AIRCR_SYSRESETREQ_Pos 2U
621#define SCB_AIRCR_SYSRESETREQ_Msk (1UL << SCB_AIRCR_SYSRESETREQ_Pos)
623#define SCB_AIRCR_VECTCLRACTIVE_Pos 1U
624#define SCB_AIRCR_VECTCLRACTIVE_Msk (1UL << SCB_AIRCR_VECTCLRACTIVE_Pos)
626#define SCB_AIRCR_VECTRESET_Pos 0U
627#define SCB_AIRCR_VECTRESET_Msk (1UL /*<< SCB_AIRCR_VECTRESET_Pos*/)
629/* SCB System Control Register Definitions */
630#define SCB_SCR_SEVONPEND_Pos 4U
631#define SCB_SCR_SEVONPEND_Msk (1UL << SCB_SCR_SEVONPEND_Pos)
633#define SCB_SCR_SLEEPDEEP_Pos 2U
634#define SCB_SCR_SLEEPDEEP_Msk (1UL << SCB_SCR_SLEEPDEEP_Pos)
636#define SCB_SCR_SLEEPONEXIT_Pos 1U
637#define SCB_SCR_SLEEPONEXIT_Msk (1UL << SCB_SCR_SLEEPONEXIT_Pos)
639/* SCB Configuration Control Register Definitions */
640#define SCB_CCR_BP_Pos 18U
641#define SCB_CCR_BP_Msk (1UL << SCB_CCR_BP_Pos)
643#define SCB_CCR_IC_Pos 17U
644#define SCB_CCR_IC_Msk (1UL << SCB_CCR_IC_Pos)
646#define SCB_CCR_DC_Pos 16U
647#define SCB_CCR_DC_Msk (1UL << SCB_CCR_DC_Pos)
649#define SCB_CCR_STKALIGN_Pos 9U
650#define SCB_CCR_STKALIGN_Msk (1UL << SCB_CCR_STKALIGN_Pos)
652#define SCB_CCR_BFHFNMIGN_Pos 8U
653#define SCB_CCR_BFHFNMIGN_Msk (1UL << SCB_CCR_BFHFNMIGN_Pos)
655#define SCB_CCR_DIV_0_TRP_Pos 4U
656#define SCB_CCR_DIV_0_TRP_Msk (1UL << SCB_CCR_DIV_0_TRP_Pos)
658#define SCB_CCR_UNALIGN_TRP_Pos 3U
659#define SCB_CCR_UNALIGN_TRP_Msk (1UL << SCB_CCR_UNALIGN_TRP_Pos)
661#define SCB_CCR_USERSETMPEND_Pos 1U
662#define SCB_CCR_USERSETMPEND_Msk (1UL << SCB_CCR_USERSETMPEND_Pos)
664#define SCB_CCR_NONBASETHRDENA_Pos 0U
665#define SCB_CCR_NONBASETHRDENA_Msk (1UL /*<< SCB_CCR_NONBASETHRDENA_Pos*/)
667/* SCB System Handler Control and State Register Definitions */
668#define SCB_SHCSR_USGFAULTENA_Pos 18U
669#define SCB_SHCSR_USGFAULTENA_Msk (1UL << SCB_SHCSR_USGFAULTENA_Pos)
671#define SCB_SHCSR_BUSFAULTENA_Pos 17U
672#define SCB_SHCSR_BUSFAULTENA_Msk (1UL << SCB_SHCSR_BUSFAULTENA_Pos)
674#define SCB_SHCSR_MEMFAULTENA_Pos 16U
675#define SCB_SHCSR_MEMFAULTENA_Msk (1UL << SCB_SHCSR_MEMFAULTENA_Pos)
677#define SCB_SHCSR_SVCALLPENDED_Pos 15U
678#define SCB_SHCSR_SVCALLPENDED_Msk (1UL << SCB_SHCSR_SVCALLPENDED_Pos)
680#define SCB_SHCSR_BUSFAULTPENDED_Pos 14U
681#define SCB_SHCSR_BUSFAULTPENDED_Msk (1UL << SCB_SHCSR_BUSFAULTPENDED_Pos)
683#define SCB_SHCSR_MEMFAULTPENDED_Pos 13U
684#define SCB_SHCSR_MEMFAULTPENDED_Msk (1UL << SCB_SHCSR_MEMFAULTPENDED_Pos)
686#define SCB_SHCSR_USGFAULTPENDED_Pos 12U
687#define SCB_SHCSR_USGFAULTPENDED_Msk (1UL << SCB_SHCSR_USGFAULTPENDED_Pos)
689#define SCB_SHCSR_SYSTICKACT_Pos 11U
690#define SCB_SHCSR_SYSTICKACT_Msk (1UL << SCB_SHCSR_SYSTICKACT_Pos)
692#define SCB_SHCSR_PENDSVACT_Pos 10U
693#define SCB_SHCSR_PENDSVACT_Msk (1UL << SCB_SHCSR_PENDSVACT_Pos)
695#define SCB_SHCSR_MONITORACT_Pos 8U
696#define SCB_SHCSR_MONITORACT_Msk (1UL << SCB_SHCSR_MONITORACT_Pos)
698#define SCB_SHCSR_SVCALLACT_Pos 7U
699#define SCB_SHCSR_SVCALLACT_Msk (1UL << SCB_SHCSR_SVCALLACT_Pos)
701#define SCB_SHCSR_USGFAULTACT_Pos 3U
702#define SCB_SHCSR_USGFAULTACT_Msk (1UL << SCB_SHCSR_USGFAULTACT_Pos)
704#define SCB_SHCSR_BUSFAULTACT_Pos 1U
705#define SCB_SHCSR_BUSFAULTACT_Msk (1UL << SCB_SHCSR_BUSFAULTACT_Pos)
707#define SCB_SHCSR_MEMFAULTACT_Pos 0U
708#define SCB_SHCSR_MEMFAULTACT_Msk (1UL /*<< SCB_SHCSR_MEMFAULTACT_Pos*/)
710/* SCB Configurable Fault Status Register Definitions */
711#define SCB_CFSR_USGFAULTSR_Pos 16U
712#define SCB_CFSR_USGFAULTSR_Msk (0xFFFFUL << SCB_CFSR_USGFAULTSR_Pos)
714#define SCB_CFSR_BUSFAULTSR_Pos 8U
715#define SCB_CFSR_BUSFAULTSR_Msk (0xFFUL << SCB_CFSR_BUSFAULTSR_Pos)
717#define SCB_CFSR_MEMFAULTSR_Pos 0U
718#define SCB_CFSR_MEMFAULTSR_Msk (0xFFUL /*<< SCB_CFSR_MEMFAULTSR_Pos*/)
720/* SCB Hard Fault Status Register Definitions */
721#define SCB_HFSR_DEBUGEVT_Pos 31U
722#define SCB_HFSR_DEBUGEVT_Msk (1UL << SCB_HFSR_DEBUGEVT_Pos)
724#define SCB_HFSR_FORCED_Pos 30U
725#define SCB_HFSR_FORCED_Msk (1UL << SCB_HFSR_FORCED_Pos)
727#define SCB_HFSR_VECTTBL_Pos 1U
728#define SCB_HFSR_VECTTBL_Msk (1UL << SCB_HFSR_VECTTBL_Pos)
730/* SCB Debug Fault Status Register Definitions */
731#define SCB_DFSR_EXTERNAL_Pos 4U
732#define SCB_DFSR_EXTERNAL_Msk (1UL << SCB_DFSR_EXTERNAL_Pos)
734#define SCB_DFSR_VCATCH_Pos 3U
735#define SCB_DFSR_VCATCH_Msk (1UL << SCB_DFSR_VCATCH_Pos)
737#define SCB_DFSR_DWTTRAP_Pos 2U
738#define SCB_DFSR_DWTTRAP_Msk (1UL << SCB_DFSR_DWTTRAP_Pos)
740#define SCB_DFSR_BKPT_Pos 1U
741#define SCB_DFSR_BKPT_Msk (1UL << SCB_DFSR_BKPT_Pos)
743#define SCB_DFSR_HALTED_Pos 0U
744#define SCB_DFSR_HALTED_Msk (1UL /*<< SCB_DFSR_HALTED_Pos*/)
746/* SCB Cache Level ID Register Definitions */
747#define SCB_CLIDR_LOUU_Pos 27U
748#define SCB_CLIDR_LOUU_Msk (7UL << SCB_CLIDR_LOUU_Pos)
750#define SCB_CLIDR_LOC_Pos 24U
751#define SCB_CLIDR_LOC_Msk (7UL << SCB_CLIDR_LOC_Pos)
753/* SCB Cache Type Register Definitions */
754#define SCB_CTR_FORMAT_Pos 29U
755#define SCB_CTR_FORMAT_Msk (7UL << SCB_CTR_FORMAT_Pos)
757#define SCB_CTR_CWG_Pos 24U
758#define SCB_CTR_CWG_Msk (0xFUL << SCB_CTR_CWG_Pos)
760#define SCB_CTR_ERG_Pos 20U
761#define SCB_CTR_ERG_Msk (0xFUL << SCB_CTR_ERG_Pos)
763#define SCB_CTR_DMINLINE_Pos 16U
764#define SCB_CTR_DMINLINE_Msk (0xFUL << SCB_CTR_DMINLINE_Pos)
766#define SCB_CTR_IMINLINE_Pos 0U
767#define SCB_CTR_IMINLINE_Msk (0xFUL /*<< SCB_CTR_IMINLINE_Pos*/)
769/* SCB Cache Size ID Register Definitions */
770#define SCB_CCSIDR_WT_Pos 31U
771#define SCB_CCSIDR_WT_Msk (1UL << SCB_CCSIDR_WT_Pos)
773#define SCB_CCSIDR_WB_Pos 30U
774#define SCB_CCSIDR_WB_Msk (1UL << SCB_CCSIDR_WB_Pos)
776#define SCB_CCSIDR_RA_Pos 29U
777#define SCB_CCSIDR_RA_Msk (1UL << SCB_CCSIDR_RA_Pos)
779#define SCB_CCSIDR_WA_Pos 28U
780#define SCB_CCSIDR_WA_Msk (1UL << SCB_CCSIDR_WA_Pos)
782#define SCB_CCSIDR_NUMSETS_Pos 13U
783#define SCB_CCSIDR_NUMSETS_Msk (0x7FFFUL << SCB_CCSIDR_NUMSETS_Pos)
785#define SCB_CCSIDR_ASSOCIATIVITY_Pos 3U
786#define SCB_CCSIDR_ASSOCIATIVITY_Msk (0x3FFUL << SCB_CCSIDR_ASSOCIATIVITY_Pos)
788#define SCB_CCSIDR_LINESIZE_Pos 0U
789#define SCB_CCSIDR_LINESIZE_Msk (7UL /*<< SCB_CCSIDR_LINESIZE_Pos*/)
791/* SCB Cache Size Selection Register Definitions */
792#define SCB_CSSELR_LEVEL_Pos 1U
793#define SCB_CSSELR_LEVEL_Msk (7UL << SCB_CSSELR_LEVEL_Pos)
795#define SCB_CSSELR_IND_Pos 0U
796#define SCB_CSSELR_IND_Msk (1UL /*<< SCB_CSSELR_IND_Pos*/)
798/* SCB Software Triggered Interrupt Register Definitions */
799#define SCB_STIR_INTID_Pos 0U
800#define SCB_STIR_INTID_Msk (0x1FFUL /*<< SCB_STIR_INTID_Pos*/)
802/* SCB D-Cache Invalidate by Set-way Register Definitions */
803#define SCB_DCISW_WAY_Pos 30U
804#define SCB_DCISW_WAY_Msk (3UL << SCB_DCISW_WAY_Pos)
806#define SCB_DCISW_SET_Pos 5U
807#define SCB_DCISW_SET_Msk (0x1FFUL << SCB_DCISW_SET_Pos)
809/* SCB D-Cache Clean by Set-way Register Definitions */
810#define SCB_DCCSW_WAY_Pos 30U
811#define SCB_DCCSW_WAY_Msk (3UL << SCB_DCCSW_WAY_Pos)
813#define SCB_DCCSW_SET_Pos 5U
814#define SCB_DCCSW_SET_Msk (0x1FFUL << SCB_DCCSW_SET_Pos)
816/* SCB D-Cache Clean and Invalidate by Set-way Register Definitions */
817#define SCB_DCCISW_WAY_Pos 30U
818#define SCB_DCCISW_WAY_Msk (3UL << SCB_DCCISW_WAY_Pos)
820#define SCB_DCCISW_SET_Pos 5U
821#define SCB_DCCISW_SET_Msk (0x1FFUL << SCB_DCCISW_SET_Pos)
823/* Instruction Tightly-Coupled Memory Control Register Definitions */
824#define SCB_ITCMCR_SZ_Pos 3U
825#define SCB_ITCMCR_SZ_Msk (0xFUL << SCB_ITCMCR_SZ_Pos)
827#define SCB_ITCMCR_RETEN_Pos 2U
828#define SCB_ITCMCR_RETEN_Msk (1UL << SCB_ITCMCR_RETEN_Pos)
830#define SCB_ITCMCR_RMW_Pos 1U
831#define SCB_ITCMCR_RMW_Msk (1UL << SCB_ITCMCR_RMW_Pos)
833#define SCB_ITCMCR_EN_Pos 0U
834#define SCB_ITCMCR_EN_Msk (1UL /*<< SCB_ITCMCR_EN_Pos*/)
836/* Data Tightly-Coupled Memory Control Register Definitions */
837#define SCB_DTCMCR_SZ_Pos 3U
838#define SCB_DTCMCR_SZ_Msk (0xFUL << SCB_DTCMCR_SZ_Pos)
840#define SCB_DTCMCR_RETEN_Pos 2U
841#define SCB_DTCMCR_RETEN_Msk (1UL << SCB_DTCMCR_RETEN_Pos)
843#define SCB_DTCMCR_RMW_Pos 1U
844#define SCB_DTCMCR_RMW_Msk (1UL << SCB_DTCMCR_RMW_Pos)
846#define SCB_DTCMCR_EN_Pos 0U
847#define SCB_DTCMCR_EN_Msk (1UL /*<< SCB_DTCMCR_EN_Pos*/)
849/* AHBP Control Register Definitions */
850#define SCB_AHBPCR_SZ_Pos 1U
851#define SCB_AHBPCR_SZ_Msk (7UL << SCB_AHBPCR_SZ_Pos)
853#define SCB_AHBPCR_EN_Pos 0U
854#define SCB_AHBPCR_EN_Msk (1UL /*<< SCB_AHBPCR_EN_Pos*/)
856/* L1 Cache Control Register Definitions */
857#define SCB_CACR_FORCEWT_Pos 2U
858#define SCB_CACR_FORCEWT_Msk (1UL << SCB_CACR_FORCEWT_Pos)
860#define SCB_CACR_ECCEN_Pos 1U
861#define SCB_CACR_ECCEN_Msk (1UL << SCB_CACR_ECCEN_Pos)
863#define SCB_CACR_SIWT_Pos 0U
864#define SCB_CACR_SIWT_Msk (1UL /*<< SCB_CACR_SIWT_Pos*/)
866/* AHBS Control Register Definitions */
867#define SCB_AHBSCR_INITCOUNT_Pos 11U
868#define SCB_AHBSCR_INITCOUNT_Msk (0x1FUL << SCB_AHBPCR_INITCOUNT_Pos)
870#define SCB_AHBSCR_TPRI_Pos 2U
871#define SCB_AHBSCR_TPRI_Msk (0x1FFUL << SCB_AHBPCR_TPRI_Pos)
873#define SCB_AHBSCR_CTL_Pos 0U
874#define SCB_AHBSCR_CTL_Msk (3UL /*<< SCB_AHBPCR_CTL_Pos*/)
876/* Auxiliary Bus Fault Status Register Definitions */
877#define SCB_ABFSR_AXIMTYPE_Pos 8U
878#define SCB_ABFSR_AXIMTYPE_Msk (3UL << SCB_ABFSR_AXIMTYPE_Pos)
880#define SCB_ABFSR_EPPB_Pos 4U
881#define SCB_ABFSR_EPPB_Msk (1UL << SCB_ABFSR_EPPB_Pos)
883#define SCB_ABFSR_AXIM_Pos 3U
884#define SCB_ABFSR_AXIM_Msk (1UL << SCB_ABFSR_AXIM_Pos)
886#define SCB_ABFSR_AHBP_Pos 2U
887#define SCB_ABFSR_AHBP_Msk (1UL << SCB_ABFSR_AHBP_Pos)
889#define SCB_ABFSR_DTCM_Pos 1U
890#define SCB_ABFSR_DTCM_Msk (1UL << SCB_ABFSR_DTCM_Pos)
892#define SCB_ABFSR_ITCM_Pos 0U
893#define SCB_ABFSR_ITCM_Msk (1UL /*<< SCB_ABFSR_ITCM_Pos*/)
908typedef struct
909{
910 uint32_t RESERVED0[1U];
911 __IM uint32_t ICTR;
912 __IOM uint32_t ACTLR;
914
915/* Interrupt Controller Type Register Definitions */
916#define SCnSCB_ICTR_INTLINESNUM_Pos 0U
917#define SCnSCB_ICTR_INTLINESNUM_Msk (0xFUL /*<< SCnSCB_ICTR_INTLINESNUM_Pos*/)
919/* Auxiliary Control Register Definitions */
920#define SCnSCB_ACTLR_DISITMATBFLUSH_Pos 12U
921#define SCnSCB_ACTLR_DISITMATBFLUSH_Msk (1UL << SCnSCB_ACTLR_DISITMATBFLUSH_Pos)
923#define SCnSCB_ACTLR_DISRAMODE_Pos 11U
924#define SCnSCB_ACTLR_DISRAMODE_Msk (1UL << SCnSCB_ACTLR_DISRAMODE_Pos)
926#define SCnSCB_ACTLR_FPEXCODIS_Pos 10U
927#define SCnSCB_ACTLR_FPEXCODIS_Msk (1UL << SCnSCB_ACTLR_FPEXCODIS_Pos)
929#define SCnSCB_ACTLR_DISFOLD_Pos 2U
930#define SCnSCB_ACTLR_DISFOLD_Msk (1UL << SCnSCB_ACTLR_DISFOLD_Pos)
932#define SCnSCB_ACTLR_DISMCYCINT_Pos 0U
933#define SCnSCB_ACTLR_DISMCYCINT_Msk (1UL /*<< SCnSCB_ACTLR_DISMCYCINT_Pos*/)
948typedef struct
949{
950 __IOM uint32_t CTRL;
951 __IOM uint32_t LOAD;
952 __IOM uint32_t VAL;
953 __IM uint32_t CALIB;
955
956/* SysTick Control / Status Register Definitions */
957#define SysTick_CTRL_COUNTFLAG_Pos 16U
958#define SysTick_CTRL_COUNTFLAG_Msk (1UL << SysTick_CTRL_COUNTFLAG_Pos)
960#define SysTick_CTRL_CLKSOURCE_Pos 2U
961#define SysTick_CTRL_CLKSOURCE_Msk (1UL << SysTick_CTRL_CLKSOURCE_Pos)
963#define SysTick_CTRL_TICKINT_Pos 1U
964#define SysTick_CTRL_TICKINT_Msk (1UL << SysTick_CTRL_TICKINT_Pos)
966#define SysTick_CTRL_ENABLE_Pos 0U
967#define SysTick_CTRL_ENABLE_Msk (1UL /*<< SysTick_CTRL_ENABLE_Pos*/)
969/* SysTick Reload Register Definitions */
970#define SysTick_LOAD_RELOAD_Pos 0U
971#define SysTick_LOAD_RELOAD_Msk (0xFFFFFFUL /*<< SysTick_LOAD_RELOAD_Pos*/)
973/* SysTick Current Register Definitions */
974#define SysTick_VAL_CURRENT_Pos 0U
975#define SysTick_VAL_CURRENT_Msk (0xFFFFFFUL /*<< SysTick_VAL_CURRENT_Pos*/)
977/* SysTick Calibration Register Definitions */
978#define SysTick_CALIB_NOREF_Pos 31U
979#define SysTick_CALIB_NOREF_Msk (1UL << SysTick_CALIB_NOREF_Pos)
981#define SysTick_CALIB_SKEW_Pos 30U
982#define SysTick_CALIB_SKEW_Msk (1UL << SysTick_CALIB_SKEW_Pos)
984#define SysTick_CALIB_TENMS_Pos 0U
985#define SysTick_CALIB_TENMS_Msk (0xFFFFFFUL /*<< SysTick_CALIB_TENMS_Pos*/)
1000typedef struct
1001{
1002 __OM union
1003 {
1004 __OM uint8_t u8;
1005 __OM uint16_t u16;
1006 __OM uint32_t u32;
1007 } PORT [32U];
1008 uint32_t RESERVED0[864U];
1009 __IOM uint32_t TER;
1010 uint32_t RESERVED1[15U];
1011 __IOM uint32_t TPR;
1012 uint32_t RESERVED2[15U];
1013 __IOM uint32_t TCR;
1014 uint32_t RESERVED3[29U];
1015 __OM uint32_t IWR;
1016 __IM uint32_t IRR;
1017 __IOM uint32_t IMCR;
1018 uint32_t RESERVED4[43U];
1019 __OM uint32_t LAR;
1020 __IM uint32_t LSR;
1021 uint32_t RESERVED5[6U];
1022 __IM uint32_t PID4;
1023 __IM uint32_t PID5;
1024 __IM uint32_t PID6;
1025 __IM uint32_t PID7;
1026 __IM uint32_t PID0;
1027 __IM uint32_t PID1;
1028 __IM uint32_t PID2;
1029 __IM uint32_t PID3;
1030 __IM uint32_t CID0;
1031 __IM uint32_t CID1;
1032 __IM uint32_t CID2;
1033 __IM uint32_t CID3;
1034} ITM_Type;
1035
1036/* ITM Trace Privilege Register Definitions */
1037#define ITM_TPR_PRIVMASK_Pos 0U
1038#define ITM_TPR_PRIVMASK_Msk (0xFUL /*<< ITM_TPR_PRIVMASK_Pos*/)
1040/* ITM Trace Control Register Definitions */
1041#define ITM_TCR_BUSY_Pos 23U
1042#define ITM_TCR_BUSY_Msk (1UL << ITM_TCR_BUSY_Pos)
1044#define ITM_TCR_TraceBusID_Pos 16U
1045#define ITM_TCR_TraceBusID_Msk (0x7FUL << ITM_TCR_TraceBusID_Pos)
1047#define ITM_TCR_GTSFREQ_Pos 10U
1048#define ITM_TCR_GTSFREQ_Msk (3UL << ITM_TCR_GTSFREQ_Pos)
1050#define ITM_TCR_TSPrescale_Pos 8U
1051#define ITM_TCR_TSPrescale_Msk (3UL << ITM_TCR_TSPrescale_Pos)
1053#define ITM_TCR_SWOENA_Pos 4U
1054#define ITM_TCR_SWOENA_Msk (1UL << ITM_TCR_SWOENA_Pos)
1056#define ITM_TCR_DWTENA_Pos 3U
1057#define ITM_TCR_DWTENA_Msk (1UL << ITM_TCR_DWTENA_Pos)
1059#define ITM_TCR_SYNCENA_Pos 2U
1060#define ITM_TCR_SYNCENA_Msk (1UL << ITM_TCR_SYNCENA_Pos)
1062#define ITM_TCR_TSENA_Pos 1U
1063#define ITM_TCR_TSENA_Msk (1UL << ITM_TCR_TSENA_Pos)
1065#define ITM_TCR_ITMENA_Pos 0U
1066#define ITM_TCR_ITMENA_Msk (1UL /*<< ITM_TCR_ITMENA_Pos*/)
1068/* ITM Integration Write Register Definitions */
1069#define ITM_IWR_ATVALIDM_Pos 0U
1070#define ITM_IWR_ATVALIDM_Msk (1UL /*<< ITM_IWR_ATVALIDM_Pos*/)
1072/* ITM Integration Read Register Definitions */
1073#define ITM_IRR_ATREADYM_Pos 0U
1074#define ITM_IRR_ATREADYM_Msk (1UL /*<< ITM_IRR_ATREADYM_Pos*/)
1076/* ITM Integration Mode Control Register Definitions */
1077#define ITM_IMCR_INTEGRATION_Pos 0U
1078#define ITM_IMCR_INTEGRATION_Msk (1UL /*<< ITM_IMCR_INTEGRATION_Pos*/)
1080/* ITM Lock Status Register Definitions */
1081#define ITM_LSR_ByteAcc_Pos 2U
1082#define ITM_LSR_ByteAcc_Msk (1UL << ITM_LSR_ByteAcc_Pos)
1084#define ITM_LSR_Access_Pos 1U
1085#define ITM_LSR_Access_Msk (1UL << ITM_LSR_Access_Pos)
1087#define ITM_LSR_Present_Pos 0U
1088#define ITM_LSR_Present_Msk (1UL /*<< ITM_LSR_Present_Pos*/) /* end of group CMSIS_ITM */
1091
1092
1103typedef struct
1104{
1105 __IOM uint32_t CTRL;
1106 __IOM uint32_t CYCCNT;
1107 __IOM uint32_t CPICNT;
1108 __IOM uint32_t EXCCNT;
1109 __IOM uint32_t SLEEPCNT;
1110 __IOM uint32_t LSUCNT;
1111 __IOM uint32_t FOLDCNT;
1112 __IM uint32_t PCSR;
1113 __IOM uint32_t COMP0;
1114 __IOM uint32_t MASK0;
1115 __IOM uint32_t FUNCTION0;
1116 uint32_t RESERVED0[1U];
1117 __IOM uint32_t COMP1;
1118 __IOM uint32_t MASK1;
1119 __IOM uint32_t FUNCTION1;
1120 uint32_t RESERVED1[1U];
1121 __IOM uint32_t COMP2;
1122 __IOM uint32_t MASK2;
1123 __IOM uint32_t FUNCTION2;
1124 uint32_t RESERVED2[1U];
1125 __IOM uint32_t COMP3;
1126 __IOM uint32_t MASK3;
1127 __IOM uint32_t FUNCTION3;
1128 uint32_t RESERVED3[981U];
1129 __OM uint32_t LAR;
1130 __IM uint32_t LSR;
1131} DWT_Type;
1132
1133/* DWT Control Register Definitions */
1134#define DWT_CTRL_NUMCOMP_Pos 28U
1135#define DWT_CTRL_NUMCOMP_Msk (0xFUL << DWT_CTRL_NUMCOMP_Pos)
1137#define DWT_CTRL_NOTRCPKT_Pos 27U
1138#define DWT_CTRL_NOTRCPKT_Msk (0x1UL << DWT_CTRL_NOTRCPKT_Pos)
1140#define DWT_CTRL_NOEXTTRIG_Pos 26U
1141#define DWT_CTRL_NOEXTTRIG_Msk (0x1UL << DWT_CTRL_NOEXTTRIG_Pos)
1143#define DWT_CTRL_NOCYCCNT_Pos 25U
1144#define DWT_CTRL_NOCYCCNT_Msk (0x1UL << DWT_CTRL_NOCYCCNT_Pos)
1146#define DWT_CTRL_NOPRFCNT_Pos 24U
1147#define DWT_CTRL_NOPRFCNT_Msk (0x1UL << DWT_CTRL_NOPRFCNT_Pos)
1149#define DWT_CTRL_CYCEVTENA_Pos 22U
1150#define DWT_CTRL_CYCEVTENA_Msk (0x1UL << DWT_CTRL_CYCEVTENA_Pos)
1152#define DWT_CTRL_FOLDEVTENA_Pos 21U
1153#define DWT_CTRL_FOLDEVTENA_Msk (0x1UL << DWT_CTRL_FOLDEVTENA_Pos)
1155#define DWT_CTRL_LSUEVTENA_Pos 20U
1156#define DWT_CTRL_LSUEVTENA_Msk (0x1UL << DWT_CTRL_LSUEVTENA_Pos)
1158#define DWT_CTRL_SLEEPEVTENA_Pos 19U
1159#define DWT_CTRL_SLEEPEVTENA_Msk (0x1UL << DWT_CTRL_SLEEPEVTENA_Pos)
1161#define DWT_CTRL_EXCEVTENA_Pos 18U
1162#define DWT_CTRL_EXCEVTENA_Msk (0x1UL << DWT_CTRL_EXCEVTENA_Pos)
1164#define DWT_CTRL_CPIEVTENA_Pos 17U
1165#define DWT_CTRL_CPIEVTENA_Msk (0x1UL << DWT_CTRL_CPIEVTENA_Pos)
1167#define DWT_CTRL_EXCTRCENA_Pos 16U
1168#define DWT_CTRL_EXCTRCENA_Msk (0x1UL << DWT_CTRL_EXCTRCENA_Pos)
1170#define DWT_CTRL_PCSAMPLENA_Pos 12U
1171#define DWT_CTRL_PCSAMPLENA_Msk (0x1UL << DWT_CTRL_PCSAMPLENA_Pos)
1173#define DWT_CTRL_SYNCTAP_Pos 10U
1174#define DWT_CTRL_SYNCTAP_Msk (0x3UL << DWT_CTRL_SYNCTAP_Pos)
1176#define DWT_CTRL_CYCTAP_Pos 9U
1177#define DWT_CTRL_CYCTAP_Msk (0x1UL << DWT_CTRL_CYCTAP_Pos)
1179#define DWT_CTRL_POSTINIT_Pos 5U
1180#define DWT_CTRL_POSTINIT_Msk (0xFUL << DWT_CTRL_POSTINIT_Pos)
1182#define DWT_CTRL_POSTPRESET_Pos 1U
1183#define DWT_CTRL_POSTPRESET_Msk (0xFUL << DWT_CTRL_POSTPRESET_Pos)
1185#define DWT_CTRL_CYCCNTENA_Pos 0U
1186#define DWT_CTRL_CYCCNTENA_Msk (0x1UL /*<< DWT_CTRL_CYCCNTENA_Pos*/)
1188/* DWT CPI Count Register Definitions */
1189#define DWT_CPICNT_CPICNT_Pos 0U
1190#define DWT_CPICNT_CPICNT_Msk (0xFFUL /*<< DWT_CPICNT_CPICNT_Pos*/)
1192/* DWT Exception Overhead Count Register Definitions */
1193#define DWT_EXCCNT_EXCCNT_Pos 0U
1194#define DWT_EXCCNT_EXCCNT_Msk (0xFFUL /*<< DWT_EXCCNT_EXCCNT_Pos*/)
1196/* DWT Sleep Count Register Definitions */
1197#define DWT_SLEEPCNT_SLEEPCNT_Pos 0U
1198#define DWT_SLEEPCNT_SLEEPCNT_Msk (0xFFUL /*<< DWT_SLEEPCNT_SLEEPCNT_Pos*/)
1200/* DWT LSU Count Register Definitions */
1201#define DWT_LSUCNT_LSUCNT_Pos 0U
1202#define DWT_LSUCNT_LSUCNT_Msk (0xFFUL /*<< DWT_LSUCNT_LSUCNT_Pos*/)
1204/* DWT Folded-instruction Count Register Definitions */
1205#define DWT_FOLDCNT_FOLDCNT_Pos 0U
1206#define DWT_FOLDCNT_FOLDCNT_Msk (0xFFUL /*<< DWT_FOLDCNT_FOLDCNT_Pos*/)
1208/* DWT Comparator Mask Register Definitions */
1209#define DWT_MASK_MASK_Pos 0U
1210#define DWT_MASK_MASK_Msk (0x1FUL /*<< DWT_MASK_MASK_Pos*/)
1212/* DWT Comparator Function Register Definitions */
1213#define DWT_FUNCTION_MATCHED_Pos 24U
1214#define DWT_FUNCTION_MATCHED_Msk (0x1UL << DWT_FUNCTION_MATCHED_Pos)
1216#define DWT_FUNCTION_DATAVADDR1_Pos 16U
1217#define DWT_FUNCTION_DATAVADDR1_Msk (0xFUL << DWT_FUNCTION_DATAVADDR1_Pos)
1219#define DWT_FUNCTION_DATAVADDR0_Pos 12U
1220#define DWT_FUNCTION_DATAVADDR0_Msk (0xFUL << DWT_FUNCTION_DATAVADDR0_Pos)
1222#define DWT_FUNCTION_DATAVSIZE_Pos 10U
1223#define DWT_FUNCTION_DATAVSIZE_Msk (0x3UL << DWT_FUNCTION_DATAVSIZE_Pos)
1225#define DWT_FUNCTION_LNK1ENA_Pos 9U
1226#define DWT_FUNCTION_LNK1ENA_Msk (0x1UL << DWT_FUNCTION_LNK1ENA_Pos)
1228#define DWT_FUNCTION_DATAVMATCH_Pos 8U
1229#define DWT_FUNCTION_DATAVMATCH_Msk (0x1UL << DWT_FUNCTION_DATAVMATCH_Pos)
1231#define DWT_FUNCTION_CYCMATCH_Pos 7U
1232#define DWT_FUNCTION_CYCMATCH_Msk (0x1UL << DWT_FUNCTION_CYCMATCH_Pos)
1234#define DWT_FUNCTION_EMITRANGE_Pos 5U
1235#define DWT_FUNCTION_EMITRANGE_Msk (0x1UL << DWT_FUNCTION_EMITRANGE_Pos)
1237#define DWT_FUNCTION_FUNCTION_Pos 0U
1238#define DWT_FUNCTION_FUNCTION_Msk (0xFUL /*<< DWT_FUNCTION_FUNCTION_Pos*/) /* end of group CMSIS_DWT */
1241
1242
1253typedef struct
1254{
1255 __IOM uint32_t SSPSR;
1256 __IOM uint32_t CSPSR;
1257 uint32_t RESERVED0[2U];
1258 __IOM uint32_t ACPR;
1259 uint32_t RESERVED1[55U];
1260 __IOM uint32_t SPPR;
1261 uint32_t RESERVED2[131U];
1262 __IM uint32_t FFSR;
1263 __IOM uint32_t FFCR;
1264 __IM uint32_t FSCR;
1265 uint32_t RESERVED3[759U];
1266 __IM uint32_t TRIGGER;
1267 __IM uint32_t FIFO0;
1268 __IM uint32_t ITATBCTR2;
1269 uint32_t RESERVED4[1U];
1270 __IM uint32_t ITATBCTR0;
1271 __IM uint32_t FIFO1;
1272 __IOM uint32_t ITCTRL;
1273 uint32_t RESERVED5[39U];
1274 __IOM uint32_t CLAIMSET;
1275 __IOM uint32_t CLAIMCLR;
1276 uint32_t RESERVED7[8U];
1277 __IM uint32_t DEVID;
1278 __IM uint32_t DEVTYPE;
1279} TPI_Type;
1280
1281/* TPI Asynchronous Clock Prescaler Register Definitions */
1282#define TPI_ACPR_PRESCALER_Pos 0U
1283#define TPI_ACPR_PRESCALER_Msk (0x1FFFUL /*<< TPI_ACPR_PRESCALER_Pos*/)
1285/* TPI Selected Pin Protocol Register Definitions */
1286#define TPI_SPPR_TXMODE_Pos 0U
1287#define TPI_SPPR_TXMODE_Msk (0x3UL /*<< TPI_SPPR_TXMODE_Pos*/)
1289/* TPI Formatter and Flush Status Register Definitions */
1290#define TPI_FFSR_FtNonStop_Pos 3U
1291#define TPI_FFSR_FtNonStop_Msk (0x1UL << TPI_FFSR_FtNonStop_Pos)
1293#define TPI_FFSR_TCPresent_Pos 2U
1294#define TPI_FFSR_TCPresent_Msk (0x1UL << TPI_FFSR_TCPresent_Pos)
1296#define TPI_FFSR_FtStopped_Pos 1U
1297#define TPI_FFSR_FtStopped_Msk (0x1UL << TPI_FFSR_FtStopped_Pos)
1299#define TPI_FFSR_FlInProg_Pos 0U
1300#define TPI_FFSR_FlInProg_Msk (0x1UL /*<< TPI_FFSR_FlInProg_Pos*/)
1302/* TPI Formatter and Flush Control Register Definitions */
1303#define TPI_FFCR_TrigIn_Pos 8U
1304#define TPI_FFCR_TrigIn_Msk (0x1UL << TPI_FFCR_TrigIn_Pos)
1306#define TPI_FFCR_EnFCont_Pos 1U
1307#define TPI_FFCR_EnFCont_Msk (0x1UL << TPI_FFCR_EnFCont_Pos)
1309/* TPI TRIGGER Register Definitions */
1310#define TPI_TRIGGER_TRIGGER_Pos 0U
1311#define TPI_TRIGGER_TRIGGER_Msk (0x1UL /*<< TPI_TRIGGER_TRIGGER_Pos*/)
1313/* TPI Integration ETM Data Register Definitions (FIFO0) */
1314#define TPI_FIFO0_ITM_ATVALID_Pos 29U
1315#define TPI_FIFO0_ITM_ATVALID_Msk (0x3UL << TPI_FIFO0_ITM_ATVALID_Pos)
1317#define TPI_FIFO0_ITM_bytecount_Pos 27U
1318#define TPI_FIFO0_ITM_bytecount_Msk (0x3UL << TPI_FIFO0_ITM_bytecount_Pos)
1320#define TPI_FIFO0_ETM_ATVALID_Pos 26U
1321#define TPI_FIFO0_ETM_ATVALID_Msk (0x3UL << TPI_FIFO0_ETM_ATVALID_Pos)
1323#define TPI_FIFO0_ETM_bytecount_Pos 24U
1324#define TPI_FIFO0_ETM_bytecount_Msk (0x3UL << TPI_FIFO0_ETM_bytecount_Pos)
1326#define TPI_FIFO0_ETM2_Pos 16U
1327#define TPI_FIFO0_ETM2_Msk (0xFFUL << TPI_FIFO0_ETM2_Pos)
1329#define TPI_FIFO0_ETM1_Pos 8U
1330#define TPI_FIFO0_ETM1_Msk (0xFFUL << TPI_FIFO0_ETM1_Pos)
1332#define TPI_FIFO0_ETM0_Pos 0U
1333#define TPI_FIFO0_ETM0_Msk (0xFFUL /*<< TPI_FIFO0_ETM0_Pos*/)
1335/* TPI ITATBCTR2 Register Definitions */
1336#define TPI_ITATBCTR2_ATREADY_Pos 0U
1337#define TPI_ITATBCTR2_ATREADY_Msk (0x1UL /*<< TPI_ITATBCTR2_ATREADY_Pos*/)
1339/* TPI Integration ITM Data Register Definitions (FIFO1) */
1340#define TPI_FIFO1_ITM_ATVALID_Pos 29U
1341#define TPI_FIFO1_ITM_ATVALID_Msk (0x3UL << TPI_FIFO1_ITM_ATVALID_Pos)
1343#define TPI_FIFO1_ITM_bytecount_Pos 27U
1344#define TPI_FIFO1_ITM_bytecount_Msk (0x3UL << TPI_FIFO1_ITM_bytecount_Pos)
1346#define TPI_FIFO1_ETM_ATVALID_Pos 26U
1347#define TPI_FIFO1_ETM_ATVALID_Msk (0x3UL << TPI_FIFO1_ETM_ATVALID_Pos)
1349#define TPI_FIFO1_ETM_bytecount_Pos 24U
1350#define TPI_FIFO1_ETM_bytecount_Msk (0x3UL << TPI_FIFO1_ETM_bytecount_Pos)
1352#define TPI_FIFO1_ITM2_Pos 16U
1353#define TPI_FIFO1_ITM2_Msk (0xFFUL << TPI_FIFO1_ITM2_Pos)
1355#define TPI_FIFO1_ITM1_Pos 8U
1356#define TPI_FIFO1_ITM1_Msk (0xFFUL << TPI_FIFO1_ITM1_Pos)
1358#define TPI_FIFO1_ITM0_Pos 0U
1359#define TPI_FIFO1_ITM0_Msk (0xFFUL /*<< TPI_FIFO1_ITM0_Pos*/)
1361/* TPI ITATBCTR0 Register Definitions */
1362#define TPI_ITATBCTR0_ATREADY_Pos 0U
1363#define TPI_ITATBCTR0_ATREADY_Msk (0x1UL /*<< TPI_ITATBCTR0_ATREADY_Pos*/)
1365/* TPI Integration Mode Control Register Definitions */
1366#define TPI_ITCTRL_Mode_Pos 0U
1367#define TPI_ITCTRL_Mode_Msk (0x1UL /*<< TPI_ITCTRL_Mode_Pos*/)
1369/* TPI DEVID Register Definitions */
1370#define TPI_DEVID_NRZVALID_Pos 11U
1371#define TPI_DEVID_NRZVALID_Msk (0x1UL << TPI_DEVID_NRZVALID_Pos)
1373#define TPI_DEVID_MANCVALID_Pos 10U
1374#define TPI_DEVID_MANCVALID_Msk (0x1UL << TPI_DEVID_MANCVALID_Pos)
1376#define TPI_DEVID_PTINVALID_Pos 9U
1377#define TPI_DEVID_PTINVALID_Msk (0x1UL << TPI_DEVID_PTINVALID_Pos)
1379#define TPI_DEVID_MinBufSz_Pos 6U
1380#define TPI_DEVID_MinBufSz_Msk (0x7UL << TPI_DEVID_MinBufSz_Pos)
1382#define TPI_DEVID_AsynClkIn_Pos 5U
1383#define TPI_DEVID_AsynClkIn_Msk (0x1UL << TPI_DEVID_AsynClkIn_Pos)
1385#define TPI_DEVID_NrTraceInput_Pos 0U
1386#define TPI_DEVID_NrTraceInput_Msk (0x1FUL /*<< TPI_DEVID_NrTraceInput_Pos*/)
1388/* TPI DEVTYPE Register Definitions */
1389#define TPI_DEVTYPE_MajorType_Pos 4U
1390#define TPI_DEVTYPE_MajorType_Msk (0xFUL << TPI_DEVTYPE_MajorType_Pos)
1392#define TPI_DEVTYPE_SubType_Pos 0U
1393#define TPI_DEVTYPE_SubType_Msk (0xFUL /*<< TPI_DEVTYPE_SubType_Pos*/) /* end of group CMSIS_TPI */
1396
1397
1398#if (__MPU_PRESENT == 1U)
1409typedef struct
1410{
1411 __IM uint32_t TYPE;
1412 __IOM uint32_t CTRL;
1413 __IOM uint32_t RNR;
1414 __IOM uint32_t RBAR;
1415 __IOM uint32_t RASR;
1416 __IOM uint32_t RBAR_A1;
1417 __IOM uint32_t RASR_A1;
1418 __IOM uint32_t RBAR_A2;
1419 __IOM uint32_t RASR_A2;
1420 __IOM uint32_t RBAR_A3;
1421 __IOM uint32_t RASR_A3;
1422} MPU_Type;
1423
1424/* MPU Type Register Definitions */
1425#define MPU_TYPE_IREGION_Pos 16U
1426#define MPU_TYPE_IREGION_Msk (0xFFUL << MPU_TYPE_IREGION_Pos)
1428#define MPU_TYPE_DREGION_Pos 8U
1429#define MPU_TYPE_DREGION_Msk (0xFFUL << MPU_TYPE_DREGION_Pos)
1431#define MPU_TYPE_SEPARATE_Pos 0U
1432#define MPU_TYPE_SEPARATE_Msk (1UL /*<< MPU_TYPE_SEPARATE_Pos*/)
1434/* MPU Control Register Definitions */
1435#define MPU_CTRL_PRIVDEFENA_Pos 2U
1436#define MPU_CTRL_PRIVDEFENA_Msk (1UL << MPU_CTRL_PRIVDEFENA_Pos)
1438#define MPU_CTRL_HFNMIENA_Pos 1U
1439#define MPU_CTRL_HFNMIENA_Msk (1UL << MPU_CTRL_HFNMIENA_Pos)
1441#define MPU_CTRL_ENABLE_Pos 0U
1442#define MPU_CTRL_ENABLE_Msk (1UL /*<< MPU_CTRL_ENABLE_Pos*/)
1444/* MPU Region Number Register Definitions */
1445#define MPU_RNR_REGION_Pos 0U
1446#define MPU_RNR_REGION_Msk (0xFFUL /*<< MPU_RNR_REGION_Pos*/)
1448/* MPU Region Base Address Register Definitions */
1449#define MPU_RBAR_ADDR_Pos 5U
1450#define MPU_RBAR_ADDR_Msk (0x7FFFFFFUL << MPU_RBAR_ADDR_Pos)
1452#define MPU_RBAR_VALID_Pos 4U
1453#define MPU_RBAR_VALID_Msk (1UL << MPU_RBAR_VALID_Pos)
1455#define MPU_RBAR_REGION_Pos 0U
1456#define MPU_RBAR_REGION_Msk (0xFUL /*<< MPU_RBAR_REGION_Pos*/)
1458/* MPU Region Attribute and Size Register Definitions */
1459#define MPU_RASR_ATTRS_Pos 16U
1460#define MPU_RASR_ATTRS_Msk (0xFFFFUL << MPU_RASR_ATTRS_Pos)
1462#define MPU_RASR_XN_Pos 28U
1463#define MPU_RASR_XN_Msk (1UL << MPU_RASR_XN_Pos)
1465#define MPU_RASR_AP_Pos 24U
1466#define MPU_RASR_AP_Msk (0x7UL << MPU_RASR_AP_Pos)
1468#define MPU_RASR_TEX_Pos 19U
1469#define MPU_RASR_TEX_Msk (0x7UL << MPU_RASR_TEX_Pos)
1471#define MPU_RASR_S_Pos 18U
1472#define MPU_RASR_S_Msk (1UL << MPU_RASR_S_Pos)
1474#define MPU_RASR_C_Pos 17U
1475#define MPU_RASR_C_Msk (1UL << MPU_RASR_C_Pos)
1477#define MPU_RASR_B_Pos 16U
1478#define MPU_RASR_B_Msk (1UL << MPU_RASR_B_Pos)
1480#define MPU_RASR_SRD_Pos 8U
1481#define MPU_RASR_SRD_Msk (0xFFUL << MPU_RASR_SRD_Pos)
1483#define MPU_RASR_SIZE_Pos 1U
1484#define MPU_RASR_SIZE_Msk (0x1FUL << MPU_RASR_SIZE_Pos)
1486#define MPU_RASR_ENABLE_Pos 0U
1487#define MPU_RASR_ENABLE_Msk (1UL /*<< MPU_RASR_ENABLE_Pos*/)
1490#endif
1491
1492
1493#if (__FPU_PRESENT == 1U)
1504typedef struct
1505{
1506 uint32_t RESERVED0[1U];
1507 __IOM uint32_t FPCCR;
1508 __IOM uint32_t FPCAR;
1509 __IOM uint32_t FPDSCR;
1510 __IM uint32_t MVFR0;
1511 __IM uint32_t MVFR1;
1512 __IM uint32_t MVFR2;
1513} FPU_Type;
1514
1515/* Floating-Point Context Control Register Definitions */
1516#define FPU_FPCCR_ASPEN_Pos 31U
1517#define FPU_FPCCR_ASPEN_Msk (1UL << FPU_FPCCR_ASPEN_Pos)
1519#define FPU_FPCCR_LSPEN_Pos 30U
1520#define FPU_FPCCR_LSPEN_Msk (1UL << FPU_FPCCR_LSPEN_Pos)
1522#define FPU_FPCCR_MONRDY_Pos 8U
1523#define FPU_FPCCR_MONRDY_Msk (1UL << FPU_FPCCR_MONRDY_Pos)
1525#define FPU_FPCCR_BFRDY_Pos 6U
1526#define FPU_FPCCR_BFRDY_Msk (1UL << FPU_FPCCR_BFRDY_Pos)
1528#define FPU_FPCCR_MMRDY_Pos 5U
1529#define FPU_FPCCR_MMRDY_Msk (1UL << FPU_FPCCR_MMRDY_Pos)
1531#define FPU_FPCCR_HFRDY_Pos 4U
1532#define FPU_FPCCR_HFRDY_Msk (1UL << FPU_FPCCR_HFRDY_Pos)
1534#define FPU_FPCCR_THREAD_Pos 3U
1535#define FPU_FPCCR_THREAD_Msk (1UL << FPU_FPCCR_THREAD_Pos)
1537#define FPU_FPCCR_USER_Pos 1U
1538#define FPU_FPCCR_USER_Msk (1UL << FPU_FPCCR_USER_Pos)
1540#define FPU_FPCCR_LSPACT_Pos 0U
1541#define FPU_FPCCR_LSPACT_Msk (1UL /*<< FPU_FPCCR_LSPACT_Pos*/)
1543/* Floating-Point Context Address Register Definitions */
1544#define FPU_FPCAR_ADDRESS_Pos 3U
1545#define FPU_FPCAR_ADDRESS_Msk (0x1FFFFFFFUL << FPU_FPCAR_ADDRESS_Pos)
1547/* Floating-Point Default Status Control Register Definitions */
1548#define FPU_FPDSCR_AHP_Pos 26U
1549#define FPU_FPDSCR_AHP_Msk (1UL << FPU_FPDSCR_AHP_Pos)
1551#define FPU_FPDSCR_DN_Pos 25U
1552#define FPU_FPDSCR_DN_Msk (1UL << FPU_FPDSCR_DN_Pos)
1554#define FPU_FPDSCR_FZ_Pos 24U
1555#define FPU_FPDSCR_FZ_Msk (1UL << FPU_FPDSCR_FZ_Pos)
1557#define FPU_FPDSCR_RMode_Pos 22U
1558#define FPU_FPDSCR_RMode_Msk (3UL << FPU_FPDSCR_RMode_Pos)
1560/* Media and FP Feature Register 0 Definitions */
1561#define FPU_MVFR0_FP_rounding_modes_Pos 28U
1562#define FPU_MVFR0_FP_rounding_modes_Msk (0xFUL << FPU_MVFR0_FP_rounding_modes_Pos)
1564#define FPU_MVFR0_Short_vectors_Pos 24U
1565#define FPU_MVFR0_Short_vectors_Msk (0xFUL << FPU_MVFR0_Short_vectors_Pos)
1567#define FPU_MVFR0_Square_root_Pos 20U
1568#define FPU_MVFR0_Square_root_Msk (0xFUL << FPU_MVFR0_Square_root_Pos)
1570#define FPU_MVFR0_Divide_Pos 16U
1571#define FPU_MVFR0_Divide_Msk (0xFUL << FPU_MVFR0_Divide_Pos)
1573#define FPU_MVFR0_FP_excep_trapping_Pos 12U
1574#define FPU_MVFR0_FP_excep_trapping_Msk (0xFUL << FPU_MVFR0_FP_excep_trapping_Pos)
1576#define FPU_MVFR0_Double_precision_Pos 8U
1577#define FPU_MVFR0_Double_precision_Msk (0xFUL << FPU_MVFR0_Double_precision_Pos)
1579#define FPU_MVFR0_Single_precision_Pos 4U
1580#define FPU_MVFR0_Single_precision_Msk (0xFUL << FPU_MVFR0_Single_precision_Pos)
1582#define FPU_MVFR0_A_SIMD_registers_Pos 0U
1583#define FPU_MVFR0_A_SIMD_registers_Msk (0xFUL /*<< FPU_MVFR0_A_SIMD_registers_Pos*/)
1585/* Media and FP Feature Register 1 Definitions */
1586#define FPU_MVFR1_FP_fused_MAC_Pos 28U
1587#define FPU_MVFR1_FP_fused_MAC_Msk (0xFUL << FPU_MVFR1_FP_fused_MAC_Pos)
1589#define FPU_MVFR1_FP_HPFP_Pos 24U
1590#define FPU_MVFR1_FP_HPFP_Msk (0xFUL << FPU_MVFR1_FP_HPFP_Pos)
1592#define FPU_MVFR1_D_NaN_mode_Pos 4U
1593#define FPU_MVFR1_D_NaN_mode_Msk (0xFUL << FPU_MVFR1_D_NaN_mode_Pos)
1595#define FPU_MVFR1_FtZ_mode_Pos 0U
1596#define FPU_MVFR1_FtZ_mode_Msk (0xFUL /*<< FPU_MVFR1_FtZ_mode_Pos*/)
1598/* Media and FP Feature Register 2 Definitions */
1599
1601#endif
1602
1603
1614typedef struct
1615{
1616 __IOM uint32_t DHCSR;
1617 __OM uint32_t DCRSR;
1618 __IOM uint32_t DCRDR;
1619 __IOM uint32_t DEMCR;
1621
1622/* Debug Halting Control and Status Register Definitions */
1623#define CoreDebug_DHCSR_DBGKEY_Pos 16U
1624#define CoreDebug_DHCSR_DBGKEY_Msk (0xFFFFUL << CoreDebug_DHCSR_DBGKEY_Pos)
1626#define CoreDebug_DHCSR_S_RESET_ST_Pos 25U
1627#define CoreDebug_DHCSR_S_RESET_ST_Msk (1UL << CoreDebug_DHCSR_S_RESET_ST_Pos)
1629#define CoreDebug_DHCSR_S_RETIRE_ST_Pos 24U
1630#define CoreDebug_DHCSR_S_RETIRE_ST_Msk (1UL << CoreDebug_DHCSR_S_RETIRE_ST_Pos)
1632#define CoreDebug_DHCSR_S_LOCKUP_Pos 19U
1633#define CoreDebug_DHCSR_S_LOCKUP_Msk (1UL << CoreDebug_DHCSR_S_LOCKUP_Pos)
1635#define CoreDebug_DHCSR_S_SLEEP_Pos 18U
1636#define CoreDebug_DHCSR_S_SLEEP_Msk (1UL << CoreDebug_DHCSR_S_SLEEP_Pos)
1638#define CoreDebug_DHCSR_S_HALT_Pos 17U
1639#define CoreDebug_DHCSR_S_HALT_Msk (1UL << CoreDebug_DHCSR_S_HALT_Pos)
1641#define CoreDebug_DHCSR_S_REGRDY_Pos 16U
1642#define CoreDebug_DHCSR_S_REGRDY_Msk (1UL << CoreDebug_DHCSR_S_REGRDY_Pos)
1644#define CoreDebug_DHCSR_C_SNAPSTALL_Pos 5U
1645#define CoreDebug_DHCSR_C_SNAPSTALL_Msk (1UL << CoreDebug_DHCSR_C_SNAPSTALL_Pos)
1647#define CoreDebug_DHCSR_C_MASKINTS_Pos 3U
1648#define CoreDebug_DHCSR_C_MASKINTS_Msk (1UL << CoreDebug_DHCSR_C_MASKINTS_Pos)
1650#define CoreDebug_DHCSR_C_STEP_Pos 2U
1651#define CoreDebug_DHCSR_C_STEP_Msk (1UL << CoreDebug_DHCSR_C_STEP_Pos)
1653#define CoreDebug_DHCSR_C_HALT_Pos 1U
1654#define CoreDebug_DHCSR_C_HALT_Msk (1UL << CoreDebug_DHCSR_C_HALT_Pos)
1656#define CoreDebug_DHCSR_C_DEBUGEN_Pos 0U
1657#define CoreDebug_DHCSR_C_DEBUGEN_Msk (1UL /*<< CoreDebug_DHCSR_C_DEBUGEN_Pos*/)
1659/* Debug Core Register Selector Register Definitions */
1660#define CoreDebug_DCRSR_REGWnR_Pos 16U
1661#define CoreDebug_DCRSR_REGWnR_Msk (1UL << CoreDebug_DCRSR_REGWnR_Pos)
1663#define CoreDebug_DCRSR_REGSEL_Pos 0U
1664#define CoreDebug_DCRSR_REGSEL_Msk (0x1FUL /*<< CoreDebug_DCRSR_REGSEL_Pos*/)
1666/* Debug Exception and Monitor Control Register Definitions */
1667#define CoreDebug_DEMCR_TRCENA_Pos 24U
1668#define CoreDebug_DEMCR_TRCENA_Msk (1UL << CoreDebug_DEMCR_TRCENA_Pos)
1670#define CoreDebug_DEMCR_MON_REQ_Pos 19U
1671#define CoreDebug_DEMCR_MON_REQ_Msk (1UL << CoreDebug_DEMCR_MON_REQ_Pos)
1673#define CoreDebug_DEMCR_MON_STEP_Pos 18U
1674#define CoreDebug_DEMCR_MON_STEP_Msk (1UL << CoreDebug_DEMCR_MON_STEP_Pos)
1676#define CoreDebug_DEMCR_MON_PEND_Pos 17U
1677#define CoreDebug_DEMCR_MON_PEND_Msk (1UL << CoreDebug_DEMCR_MON_PEND_Pos)
1679#define CoreDebug_DEMCR_MON_EN_Pos 16U
1680#define CoreDebug_DEMCR_MON_EN_Msk (1UL << CoreDebug_DEMCR_MON_EN_Pos)
1682#define CoreDebug_DEMCR_VC_HARDERR_Pos 10U
1683#define CoreDebug_DEMCR_VC_HARDERR_Msk (1UL << CoreDebug_DEMCR_VC_HARDERR_Pos)
1685#define CoreDebug_DEMCR_VC_INTERR_Pos 9U
1686#define CoreDebug_DEMCR_VC_INTERR_Msk (1UL << CoreDebug_DEMCR_VC_INTERR_Pos)
1688#define CoreDebug_DEMCR_VC_BUSERR_Pos 8U
1689#define CoreDebug_DEMCR_VC_BUSERR_Msk (1UL << CoreDebug_DEMCR_VC_BUSERR_Pos)
1691#define CoreDebug_DEMCR_VC_STATERR_Pos 7U
1692#define CoreDebug_DEMCR_VC_STATERR_Msk (1UL << CoreDebug_DEMCR_VC_STATERR_Pos)
1694#define CoreDebug_DEMCR_VC_CHKERR_Pos 6U
1695#define CoreDebug_DEMCR_VC_CHKERR_Msk (1UL << CoreDebug_DEMCR_VC_CHKERR_Pos)
1697#define CoreDebug_DEMCR_VC_NOCPERR_Pos 5U
1698#define CoreDebug_DEMCR_VC_NOCPERR_Msk (1UL << CoreDebug_DEMCR_VC_NOCPERR_Pos)
1700#define CoreDebug_DEMCR_VC_MMERR_Pos 4U
1701#define CoreDebug_DEMCR_VC_MMERR_Msk (1UL << CoreDebug_DEMCR_VC_MMERR_Pos)
1703#define CoreDebug_DEMCR_VC_CORERESET_Pos 0U
1704#define CoreDebug_DEMCR_VC_CORERESET_Msk (1UL /*<< CoreDebug_DEMCR_VC_CORERESET_Pos*/)
1722#define _VAL2FLD(field, value) ((value << field ## _Pos) & field ## _Msk)
1723
1730#define _FLD2VAL(field, value) ((value & field ## _Msk) >> field ## _Pos)
1731
1742/* Memory mapping of Cortex-M4 Hardware */
1743#define SCS_BASE (0xE000E000UL)
1744#define ITM_BASE (0xE0000000UL)
1745#define DWT_BASE (0xE0001000UL)
1746#define TPI_BASE (0xE0040000UL)
1747#define CoreDebug_BASE (0xE000EDF0UL)
1748#define SysTick_BASE (SCS_BASE + 0x0010UL)
1749#define NVIC_BASE (SCS_BASE + 0x0100UL)
1750#define SCB_BASE (SCS_BASE + 0x0D00UL)
1752#define SCnSCB ((SCnSCB_Type *) SCS_BASE )
1753#define SCB ((SCB_Type *) SCB_BASE )
1754#define SysTick ((SysTick_Type *) SysTick_BASE )
1755#define NVIC ((NVIC_Type *) NVIC_BASE )
1756#define ITM ((ITM_Type *) ITM_BASE )
1757#define DWT ((DWT_Type *) DWT_BASE )
1758#define TPI ((TPI_Type *) TPI_BASE )
1759#define CoreDebug ((CoreDebug_Type *) CoreDebug_BASE)
1761#if (__MPU_PRESENT == 1U)
1762 #define MPU_BASE (SCS_BASE + 0x0D90UL)
1763 #define MPU ((MPU_Type *) MPU_BASE )
1764#endif
1765
1766#if (__FPU_PRESENT == 1U)
1767 #define FPU_BASE (SCS_BASE + 0x0F30UL)
1768 #define FPU ((FPU_Type *) FPU_BASE )
1769#endif
1770
1775/*******************************************************************************
1776 * Hardware Abstraction Layer
1777 Core Function Interface contains:
1778 - Core NVIC Functions
1779 - Core SysTick Functions
1780 - Core Debug Functions
1781 - Core Register Access Functions
1782 ******************************************************************************/
1790/* ########################## NVIC functions #################################### */
1807__STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
1808{
1809 uint32_t reg_value;
1810 uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL); /* only values 0..7 are used */
1811
1812 reg_value = SCB->AIRCR; /* read old register configuration */
1813 reg_value &= ~((uint32_t)(SCB_AIRCR_VECTKEY_Msk | SCB_AIRCR_PRIGROUP_Msk)); /* clear bits to change */
1814 reg_value = (reg_value |
1815 ((uint32_t)0x5FAUL << SCB_AIRCR_VECTKEY_Pos) |
1816 (PriorityGroupTmp << 8U) ); /* Insert write key and priorty group */
1817 SCB->AIRCR = reg_value;
1818}
1819
1820
1826__STATIC_INLINE uint32_t NVIC_GetPriorityGrouping(void)
1827{
1828 return ((uint32_t)((SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) >> SCB_AIRCR_PRIGROUP_Pos));
1829}
1830
1831
1837__STATIC_INLINE void NVIC_EnableIRQ(IRQn_Type IRQn)
1838{
1839 NVIC->ISER[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
1840}
1841
1842
1848__STATIC_INLINE void NVIC_DisableIRQ(IRQn_Type IRQn)
1849{
1850 NVIC->ICER[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
1851}
1852
1853
1861__STATIC_INLINE uint32_t NVIC_GetPendingIRQ(IRQn_Type IRQn)
1862{
1863 return((uint32_t)(((NVIC->ISPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
1864}
1865
1866
1872__STATIC_INLINE void NVIC_SetPendingIRQ(IRQn_Type IRQn)
1873{
1874 NVIC->ISPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
1875}
1876
1877
1883__STATIC_INLINE void NVIC_ClearPendingIRQ(IRQn_Type IRQn)
1884{
1885 NVIC->ICPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
1886}
1887
1888
1896__STATIC_INLINE uint32_t NVIC_GetActive(IRQn_Type IRQn)
1897{
1898 return((uint32_t)(((NVIC->IABR[(((uint32_t)(int32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
1899}
1900
1901
1909__STATIC_INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
1910{
1911 if ((int32_t)(IRQn) < 0)
1912 {
1913 SCB->SHPR[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
1914 }
1915 else
1916 {
1917 NVIC->IP[((uint32_t)(int32_t)IRQn)] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
1918 }
1919}
1920
1921
1931__STATIC_INLINE uint32_t NVIC_GetPriority(IRQn_Type IRQn)
1932{
1933
1934 if ((int32_t)(IRQn) < 0)
1935 {
1936 return(((uint32_t)SCB->SHPR[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] >> (8U - __NVIC_PRIO_BITS)));
1937 }
1938 else
1939 {
1940 return(((uint32_t)NVIC->IP[((uint32_t)(int32_t)IRQn)] >> (8U - __NVIC_PRIO_BITS)));
1941 }
1942}
1943
1944
1956__STATIC_INLINE uint32_t NVIC_EncodePriority (uint32_t PriorityGroup, uint32_t PreemptPriority, uint32_t SubPriority)
1957{
1958 uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL); /* only values 0..7 are used */
1959 uint32_t PreemptPriorityBits;
1960 uint32_t SubPriorityBits;
1961
1962 PreemptPriorityBits = ((7UL - PriorityGroupTmp) > (uint32_t)(__NVIC_PRIO_BITS)) ? (uint32_t)(__NVIC_PRIO_BITS) : (uint32_t)(7UL - PriorityGroupTmp);
1963 SubPriorityBits = ((PriorityGroupTmp + (uint32_t)(__NVIC_PRIO_BITS)) < (uint32_t)7UL) ? (uint32_t)0UL : (uint32_t)((PriorityGroupTmp - 7UL) + (uint32_t)(__NVIC_PRIO_BITS));
1964
1965 return (
1966 ((PreemptPriority & (uint32_t)((1UL << (PreemptPriorityBits)) - 1UL)) << SubPriorityBits) |
1967 ((SubPriority & (uint32_t)((1UL << (SubPriorityBits )) - 1UL)))
1968 );
1969}
1970
1971
1983__STATIC_INLINE void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGroup, uint32_t* const pPreemptPriority, uint32_t* const pSubPriority)
1984{
1985 uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL); /* only values 0..7 are used */
1986 uint32_t PreemptPriorityBits;
1987 uint32_t SubPriorityBits;
1988
1989 PreemptPriorityBits = ((7UL - PriorityGroupTmp) > (uint32_t)(__NVIC_PRIO_BITS)) ? (uint32_t)(__NVIC_PRIO_BITS) : (uint32_t)(7UL - PriorityGroupTmp);
1990 SubPriorityBits = ((PriorityGroupTmp + (uint32_t)(__NVIC_PRIO_BITS)) < (uint32_t)7UL) ? (uint32_t)0UL : (uint32_t)((PriorityGroupTmp - 7UL) + (uint32_t)(__NVIC_PRIO_BITS));
1991
1992 *pPreemptPriority = (Priority >> SubPriorityBits) & (uint32_t)((1UL << (PreemptPriorityBits)) - 1UL);
1993 *pSubPriority = (Priority ) & (uint32_t)((1UL << (SubPriorityBits )) - 1UL);
1994}
1995
1996
2001__STATIC_INLINE void NVIC_SystemReset(void)
2002{
2003 __DSB(); /* Ensure all outstanding memory accesses included
2004 buffered write are completed before reset */
2005 SCB->AIRCR = (uint32_t)((0x5FAUL << SCB_AIRCR_VECTKEY_Pos) |
2006 (SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) |
2007 SCB_AIRCR_SYSRESETREQ_Msk ); /* Keep priority group unchanged */
2008 __DSB(); /* Ensure completion of memory access */
2009
2010 for(;;) /* wait until reset */
2011 {
2012 __NOP();
2013 }
2014}
2015
2019/* ########################## FPU functions #################################### */
2035__STATIC_INLINE uint32_t SCB_GetFPUType(void)
2036{
2037 uint32_t mvfr0;
2038
2039 mvfr0 = SCB->MVFR0;
2040 if ((mvfr0 & 0x00000FF0UL) == 0x220UL)
2041 {
2042 return 2UL; /* Double + Single precision FPU */
2043 }
2044 else if ((mvfr0 & 0x00000FF0UL) == 0x020UL)
2045 {
2046 return 1UL; /* Single precision FPU */
2047 }
2048 else
2049 {
2050 return 0UL; /* No FPU */
2051 }
2052}
2053
2054
2059/* ########################## Cache functions #################################### */
2067/* Cache Size ID Register Macros */
2068#define CCSIDR_WAYS(x) (((x) & SCB_CCSIDR_ASSOCIATIVITY_Msk) >> SCB_CCSIDR_ASSOCIATIVITY_Pos)
2069#define CCSIDR_SETS(x) (((x) & SCB_CCSIDR_NUMSETS_Msk ) >> SCB_CCSIDR_NUMSETS_Pos )
2070
2071
2076__STATIC_INLINE void SCB_EnableICache (void)
2077{
2078 #if (__ICACHE_PRESENT == 1U)
2079 __DSB();
2080 __ISB();
2081 SCB->ICIALLU = 0UL; /* invalidate I-Cache */
2082 SCB->CCR |= (uint32_t)SCB_CCR_IC_Msk; /* enable I-Cache */
2083 __DSB();
2084 __ISB();
2085 #endif
2086}
2087
2088
2093__STATIC_INLINE void SCB_DisableICache (void)
2094{
2095 #if (__ICACHE_PRESENT == 1U)
2096 __DSB();
2097 __ISB();
2098 SCB->CCR &= ~(uint32_t)SCB_CCR_IC_Msk; /* disable I-Cache */
2099 SCB->ICIALLU = 0UL; /* invalidate I-Cache */
2100 __DSB();
2101 __ISB();
2102 #endif
2103}
2104
2105
2110__STATIC_INLINE void SCB_InvalidateICache (void)
2111{
2112 #if (__ICACHE_PRESENT == 1U)
2113 __DSB();
2114 __ISB();
2115 SCB->ICIALLU = 0UL;
2116 __DSB();
2117 __ISB();
2118 #endif
2119}
2120
2121
2126__STATIC_INLINE void SCB_EnableDCache (void)
2127{
2128 #if (__DCACHE_PRESENT == 1U)
2129 uint32_t ccsidr;
2130 uint32_t sets;
2131 uint32_t ways;
2132
2133 SCB->CSSELR = (0U << 1U) | 0U; /* Level 1 data cache */
2134 __DSB();
2135
2136 ccsidr = SCB->CCSIDR;
2137
2138 /* invalidate D-Cache */
2139 sets = (uint32_t)(CCSIDR_SETS(ccsidr));
2140 do {
2141 ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
2142 do {
2143 SCB->DCISW = (((sets << SCB_DCISW_SET_Pos) & SCB_DCISW_SET_Msk) |
2144 ((ways << SCB_DCISW_WAY_Pos) & SCB_DCISW_WAY_Msk) );
2145 #if defined ( __CC_ARM )
2146 __schedule_barrier();
2147 #endif
2148 } while (ways--);
2149 } while(sets--);
2150 __DSB();
2151
2152 SCB->CCR |= (uint32_t)SCB_CCR_DC_Msk; /* enable D-Cache */
2153
2154 __DSB();
2155 __ISB();
2156 #endif
2157}
2158
2159
2164__STATIC_INLINE void SCB_DisableDCache (void)
2165{
2166 #if (__DCACHE_PRESENT == 1U)
2167 uint32_t ccsidr;
2168 uint32_t sets;
2169 uint32_t ways;
2170
2171 SCB->CSSELR = (0U << 1U) | 0U; /* Level 1 data cache */
2172 __DSB();
2173
2174 ccsidr = SCB->CCSIDR;
2175
2176 SCB->CCR &= ~(uint32_t)SCB_CCR_DC_Msk; /* disable D-Cache */
2177
2178 /* clean & invalidate D-Cache */
2179 sets = (uint32_t)(CCSIDR_SETS(ccsidr));
2180 do {
2181 ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
2182 do {
2183 SCB->DCCISW = (((sets << SCB_DCCISW_SET_Pos) & SCB_DCCISW_SET_Msk) |
2184 ((ways << SCB_DCCISW_WAY_Pos) & SCB_DCCISW_WAY_Msk) );
2185 #if defined ( __CC_ARM )
2186 __schedule_barrier();
2187 #endif
2188 } while (ways--);
2189 } while(sets--);
2190
2191 __DSB();
2192 __ISB();
2193 #endif
2194}
2195
2196
2201__STATIC_INLINE void SCB_InvalidateDCache (void)
2202{
2203 #if (__DCACHE_PRESENT == 1U)
2204 uint32_t ccsidr;
2205 uint32_t sets;
2206 uint32_t ways;
2207
2208 SCB->CSSELR = (0U << 1U) | 0U; /* Level 1 data cache */
2209 __DSB();
2210
2211 ccsidr = SCB->CCSIDR;
2212
2213 /* invalidate D-Cache */
2214 sets = (uint32_t)(CCSIDR_SETS(ccsidr));
2215 do {
2216 ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
2217 do {
2218 SCB->DCISW = (((sets << SCB_DCISW_SET_Pos) & SCB_DCISW_SET_Msk) |
2219 ((ways << SCB_DCISW_WAY_Pos) & SCB_DCISW_WAY_Msk) );
2220 #if defined ( __CC_ARM )
2221 __schedule_barrier();
2222 #endif
2223 } while (ways--);
2224 } while(sets--);
2225
2226 __DSB();
2227 __ISB();
2228 #endif
2229}
2230
2231
2236__STATIC_INLINE void SCB_CleanDCache (void)
2237{
2238 #if (__DCACHE_PRESENT == 1U)
2239 uint32_t ccsidr;
2240 uint32_t sets;
2241 uint32_t ways;
2242
2243 SCB->CSSELR = (0U << 1U) | 0U; /* Level 1 data cache */
2244 __DSB();
2245
2246 ccsidr = SCB->CCSIDR;
2247
2248 /* clean D-Cache */
2249 sets = (uint32_t)(CCSIDR_SETS(ccsidr));
2250 do {
2251 ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
2252 do {
2253 SCB->DCCSW = (((sets << SCB_DCCSW_SET_Pos) & SCB_DCCSW_SET_Msk) |
2254 ((ways << SCB_DCCSW_WAY_Pos) & SCB_DCCSW_WAY_Msk) );
2255 #if defined ( __CC_ARM )
2256 __schedule_barrier();
2257 #endif
2258 } while (ways--);
2259 } while(sets--);
2260
2261 __DSB();
2262 __ISB();
2263 #endif
2264}
2265
2266
2271__STATIC_INLINE void SCB_CleanInvalidateDCache (void)
2272{
2273 #if (__DCACHE_PRESENT == 1U)
2274 uint32_t ccsidr;
2275 uint32_t sets;
2276 uint32_t ways;
2277
2278 SCB->CSSELR = (0U << 1U) | 0U; /* Level 1 data cache */
2279 __DSB();
2280
2281 ccsidr = SCB->CCSIDR;
2282
2283 /* clean & invalidate D-Cache */
2284 sets = (uint32_t)(CCSIDR_SETS(ccsidr));
2285 do {
2286 ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
2287 do {
2288 SCB->DCCISW = (((sets << SCB_DCCISW_SET_Pos) & SCB_DCCISW_SET_Msk) |
2289 ((ways << SCB_DCCISW_WAY_Pos) & SCB_DCCISW_WAY_Msk) );
2290 #if defined ( __CC_ARM )
2291 __schedule_barrier();
2292 #endif
2293 } while (ways--);
2294 } while(sets--);
2295
2296 __DSB();
2297 __ISB();
2298 #endif
2299}
2300
2301
2308__STATIC_INLINE void SCB_InvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize)
2309{
2310 #if (__DCACHE_PRESENT == 1U)
2311 int32_t op_size = dsize;
2312 uint32_t op_addr = (uint32_t)addr;
2313 int32_t linesize = 32U; /* in Cortex-M7 size of cache line is fixed to 8 words (32 bytes) */
2314
2315 __DSB();
2316
2317 while (op_size > 0) {
2318 SCB->DCIMVAC = op_addr;
2319 op_addr += linesize;
2320 op_size -= linesize;
2321 }
2322
2323 __DSB();
2324 __ISB();
2325 #endif
2326}
2327
2328
2335__STATIC_INLINE void SCB_CleanDCache_by_Addr (uint32_t *addr, int32_t dsize)
2336{
2337 #if (__DCACHE_PRESENT == 1)
2338 int32_t op_size = dsize;
2339 uint32_t op_addr = (uint32_t) addr;
2340 int32_t linesize = 32U; /* in Cortex-M7 size of cache line is fixed to 8 words (32 bytes) */
2341
2342 __DSB();
2343
2344 while (op_size > 0) {
2345 SCB->DCCMVAC = op_addr;
2346 op_addr += linesize;
2347 op_size -= linesize;
2348 }
2349
2350 __DSB();
2351 __ISB();
2352 #endif
2353}
2354
2355
2362__STATIC_INLINE void SCB_CleanInvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize)
2363{
2364 #if (__DCACHE_PRESENT == 1U)
2365 int32_t op_size = dsize;
2366 uint32_t op_addr = (uint32_t) addr;
2367 int32_t linesize = 32U; /* in Cortex-M7 size of cache line is fixed to 8 words (32 bytes) */
2368
2369 __DSB();
2370
2371 while (op_size > 0) {
2372 SCB->DCCIMVAC = op_addr;
2373 op_addr += linesize;
2374 op_size -= linesize;
2375 }
2376
2377 __DSB();
2378 __ISB();
2379 #endif
2380}
2381
2382
2387/* ################################## SysTick function ############################################ */
2395#if (__Vendor_SysTickConfig == 0U)
2396
2408__STATIC_INLINE uint32_t SysTick_Config(uint32_t ticks)
2409{
2410 if ((ticks - 1UL) > SysTick_LOAD_RELOAD_Msk)
2411 {
2412 return (1UL); /* Reload value impossible */
2413 }
2414
2415 SysTick->LOAD = (uint32_t)(ticks - 1UL); /* set reload register */
2416 NVIC_SetPriority (SysTick_IRQn, (1UL << __NVIC_PRIO_BITS) - 1UL); /* set Priority for Systick Interrupt */
2417 SysTick->VAL = 0UL; /* Load the SysTick Counter Value */
2420 SysTick_CTRL_ENABLE_Msk; /* Enable SysTick IRQ and SysTick Timer */
2421 return (0UL); /* Function successful */
2422}
2423
2424#endif
2425
2430/* ##################################### Debug In/Output function ########################################### */
2438extern volatile int32_t ITM_RxBuffer;
2439#define ITM_RXBUFFER_EMPTY 0x5AA55AA5U
2450__STATIC_INLINE uint32_t ITM_SendChar (uint32_t ch)
2451{
2452 if (((ITM->TCR & ITM_TCR_ITMENA_Msk) != 0UL) && /* ITM enabled */
2453 ((ITM->TER & 1UL ) != 0UL) ) /* ITM Port #0 enabled */
2454 {
2455 while (ITM->PORT[0U].u32 == 0UL)
2456 {
2457 __NOP();
2458 }
2459 ITM->PORT[0U].u8 = (uint8_t)ch;
2460 }
2461 return (ch);
2462}
2463
2464
2471__STATIC_INLINE int32_t ITM_ReceiveChar (void)
2472{
2473 int32_t ch = -1; /* no character available */
2474
2476 {
2477 ch = ITM_RxBuffer;
2478 ITM_RxBuffer = ITM_RXBUFFER_EMPTY; /* ready for next character */
2479 }
2480
2481 return (ch);
2482}
2483
2484
2491__STATIC_INLINE int32_t ITM_CheckChar (void)
2492{
2493
2495 {
2496 return (0); /* no character available */
2497 }
2498 else
2499 {
2500 return (1); /* character available */
2501 }
2502}
2503
2509#ifdef __cplusplus
2510}
2511#endif
2512
2513#endif /* __CORE_CM7_H_DEPENDANT */
2514
2515#endif /* __CMSIS_GENERIC */
CMSIS Cortex-M Core Function Access Header File.
CMSIS Cortex-M Core Instruction Access Header File.
CMSIS Cortex-M SIMD Header File.
__STATIC_INLINE void SCB_CleanInvalidateDCache(void)
Clean & Invalidate D-Cache.
Definition: core_cm7.h:2271
__STATIC_INLINE void SCB_InvalidateDCache_by_Addr(uint32_t *addr, int32_t dsize)
D-Cache Invalidate by address.
Definition: core_cm7.h:2308
__STATIC_INLINE void SCB_InvalidateICache(void)
Invalidate I-Cache.
Definition: core_cm7.h:2110
__STATIC_INLINE void SCB_CleanDCache(void)
Clean D-Cache.
Definition: core_cm7.h:2236
__STATIC_INLINE void SCB_CleanInvalidateDCache_by_Addr(uint32_t *addr, int32_t dsize)
D-Cache Clean and Invalidate by address.
Definition: core_cm7.h:2362
__STATIC_INLINE void SCB_EnableDCache(void)
Enable D-Cache.
Definition: core_cm7.h:2126
__STATIC_INLINE void SCB_DisableDCache(void)
Disable D-Cache.
Definition: core_cm7.h:2164
__STATIC_INLINE void SCB_CleanDCache_by_Addr(uint32_t *addr, int32_t dsize)
D-Cache Clean by address.
Definition: core_cm7.h:2335
__STATIC_INLINE void SCB_DisableICache(void)
Disable I-Cache.
Definition: core_cm7.h:2093
__STATIC_INLINE void SCB_InvalidateDCache(void)
Invalidate D-Cache.
Definition: core_cm7.h:2201
__STATIC_INLINE void SCB_EnableICache(void)
Enable I-Cache.
Definition: core_cm7.h:2076
get FPU type
Definition: core_cm7.h:2035
System Reset.
Definition: core_cm7.h:2001
Get Interrupt Priority.
Definition: core_cm7.h:1931
Set Interrupt Priority.
Definition: core_cm7.h:1909
Disable External Interrupt.
Definition: core_cm7.h:1848
Clear Pending Interrupt.
Definition: core_cm7.h:1883
Enable External Interrupt.
Definition: core_cm7.h:1837
__STATIC_INLINE void NVIC_DecodePriority(uint32_t Priority, uint32_t PriorityGroup, uint32_t *const pPreemptPriority, uint32_t *const pSubPriority)
Decode Priority.
Definition: core_cm7.h:1983
Get Priority Grouping.
Definition: core_cm7.h:1826
Set Pending Interrupt.
Definition: core_cm7.h:1872
Get Active Interrupt.
Definition: core_cm7.h:1896
Set Priority Grouping.
Definition: core_cm7.h:1807
__STATIC_INLINE uint32_t NVIC_EncodePriority(uint32_t PriorityGroup, uint32_t PreemptPriority, uint32_t SubPriority)
Encode Priority.
Definition: core_cm7.h:1956
Get Pending Interrupt.
Definition: core_cm7.h:1861
System Tick Configuration.
Definition: core_cm7.h:2408
Definition: core_cm7.h:1066
Definition: core_cm7.h:820
Definition: core_cm7.h:647
Definition: core_cm7.h:814
Definition: core_cm7.h:810
Definition: core_cm7.h:811
Definition: core_cm7.h:618
Definition: core_cm7.h:609
Definition: core_cm7.h:803
Definition: core_cm7.h:817
Definition: core_cm7.h:608
Definition: core_cm7.h:621
Definition: core_cm7.h:807
Definition: core_cm7.h:804
Definition: core_cm7.h:617
Definition: core_cm7.h:813
Definition: core_cm7.h:806
Definition: core_cm7.h:821
Definition: core_cm7.h:818
Definition: core_cm7.h:644
Definition: core_cm7.h:967
Definition: core_cm7.h:971
Definition: core_cm7.h:964
Definition: core_cm7.h:961
uint32_t w
Definition: core_cm7.h:398
uint32_t Z
Definition: core_cm7.h:395
uint32_t Q
Definition: core_cm7.h:332
uint32_t GE
Definition: core_cm7.h:388
uint32_t N
Definition: core_cm7.h:396
uint32_t IT
Definition: core_cm7.h:391
uint32_t nPRIV
Definition: core_cm7.h:437
uint32_t Z
Definition: core_cm7.h:335
uint32_t ISR
Definition: core_cm7.h:386
uint32_t C
Definition: core_cm7.h:394
uint32_t w
Definition: core_cm7.h:371
uint32_t w
Definition: core_cm7.h:442
uint32_t _reserved1
Definition: core_cm7.h:389
uint32_t N
Definition: core_cm7.h:336
uint32_t T
Definition: core_cm7.h:390
uint32_t V
Definition: core_cm7.h:333
uint32_t C
Definition: core_cm7.h:334
uint32_t SPSEL
Definition: core_cm7.h:438
Definition: core_cm7.h:2439
uint32_t ISR
Definition: core_cm7.h:368
__STATIC_INLINE int32_t ITM_ReceiveChar(void)
ITM Receive Character.
Definition: core_cm7.h:2471
uint32_t FPCA
Definition: core_cm7.h:439
uint32_t _reserved1
Definition: core_cm7.h:331
__STATIC_INLINE uint32_t ITM_SendChar(uint32_t ch)
ITM Send Character.
Definition: core_cm7.h:2450
uint32_t _reserved0
Definition: core_cm7.h:369
uint32_t GE
Definition: core_cm7.h:330
uint32_t Q
Definition: core_cm7.h:392
uint32_t w
Definition: core_cm7.h:338
__STATIC_INLINE int32_t ITM_CheckChar(void)
ITM Check Character.
Definition: core_cm7.h:2491
uint32_t V
Definition: core_cm7.h:393
uint32_t _reserved0
Definition: core_cm7.h:387
uint32_t _reserved0
Definition: core_cm7.h:440
uint32_t _reserved0
Definition: core_cm7.h:329
#define SCB
Definition: core_cm7.h:1753
#define ITM
Definition: core_cm7.h:1756
#define NVIC
Definition: core_cm7.h:1755
#define SysTick
Definition: core_cm7.h:1754
#define TCR
tx configuration reg
Definition: wd80x3.h:99
#define SCR
Scratch register.
Definition: uart.h:94
#define LSR
Line Status Register.
Definition: uart.h:92
Structure type to access the Core Debug Register (CoreDebug).
Definition: core_cm7.h:1615
Structure type to access the Data Watchpoint and Trace Register (DWT).
Definition: core_cm7.h:1104
Structure type to access the Instrumentation Trace Macrocell Register (ITM).
Definition: core_cm7.h:1001
Structure type to access the Nested Vectored Interrupt Controller (NVIC).
Definition: core_cm7.h:469
Structure type to access the System Control Block (SCB).
Definition: core_cm7.h:503
Structure type to access the System Control and ID Register not in the SCB.
Definition: core_cm7.h:909
Structure type to access the System Timer (SysTick).
Definition: core_cm7.h:949
Structure type to access the Trace Port Interface Register (TPI).
Definition: core_cm7.h:1254
Union type to access the Application Program Status Register (APSR).
Definition: core_cm7.h:326
Union type to access the Control Registers (CONTROL).
Definition: core_cm7.h:434
Union type to access the Interrupt Program Status Register (IPSR).
Definition: core_cm7.h:365
Union type to access the Special-Purpose Program Status Registers (xPSR).
Definition: core_cm7.h:383
