RTEMS 5.2
Functions that manage interrupts and exceptions via the NVIC. More...
 FPU Functions
 Function that provides FPU type.
__STATIC_INLINE void NVIC_SetPriorityGrouping (uint32_t PriorityGroup)
 Set Priority Grouping. More...
__STATIC_INLINE uint32_t NVIC_GetPriorityGrouping (void)
 Get Priority Grouping. More...
__STATIC_INLINE void NVIC_EnableIRQ (IRQn_Type IRQn)
 Enable External Interrupt. More...
__STATIC_INLINE void NVIC_DisableIRQ (IRQn_Type IRQn)
 Disable External Interrupt. More...
__STATIC_INLINE uint32_t NVIC_GetPendingIRQ (IRQn_Type IRQn)
 Get Pending Interrupt. More...
__STATIC_INLINE void NVIC_SetPendingIRQ (IRQn_Type IRQn)
 Set Pending Interrupt. More...
__STATIC_INLINE void NVIC_ClearPendingIRQ (IRQn_Type IRQn)
 Clear Pending Interrupt. More...
__STATIC_INLINE uint32_t NVIC_GetActive (IRQn_Type IRQn)
 Get Active Interrupt. More...
__STATIC_INLINE void NVIC_SetPriority (IRQn_Type IRQn, uint32_t priority)
 Set Interrupt Priority. More...
__STATIC_INLINE uint32_t NVIC_GetPriority (IRQn_Type IRQn)
 Get Interrupt Priority. More...
__STATIC_INLINE uint32_t NVIC_EncodePriority (uint32_t PriorityGroup, uint32_t PreemptPriority, uint32_t SubPriority)
 Encode Priority. More...
__STATIC_INLINE void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGroup, uint32_t *const pPreemptPriority, uint32_t *const pSubPriority)
 Decode Priority. More...
__STATIC_INLINE void NVIC_SystemReset (void)
 System Reset. More...
◆ NVIC_ClearPendingIRQ()
__STATIC_INLINE void NVIC_ClearPendingIRQ ( IRQn_Type  IRQn)
Clears the pending bit of an external interrupt.
Parameters
[in]IRQnExternal interrupt number. Value cannot be negative.
◆ NVIC_DecodePriority()
__STATIC_INLINE void NVIC_DecodePriority ( uint32_t  Priority,
Decode Priority.
Decodes an interrupt priority value with a given priority group to preemptive priority value and subpriority value. In case of a conflict between priority grouping and available priority bits (__NVIC_PRIO_BITS) the smallest possible priority group is set.
Parameters
[in]PriorityPriority value, which can be retrieved with the function NVIC_GetPriority().
[in]PriorityGroupUsed priority group.
[out]pPreemptPriorityPreemptive priority value (starting from 0).
[out]pSubPrioritySubpriority value (starting from 0).
◆ NVIC_DisableIRQ()
__STATIC_INLINE void NVIC_DisableIRQ ( IRQn_Type  IRQn)
Disables a device-specific interrupt in the NVIC interrupt controller.
Parameters
◆ NVIC_EnableIRQ()
__STATIC_INLINE void NVIC_EnableIRQ ( IRQn_Type  IRQn)
Enables a device-specific interrupt in the NVIC interrupt controller.
Parameters
◆ NVIC_EncodePriority()
__STATIC_INLINE uint32_t NVIC_EncodePriority ( uint32_t  PriorityGroup,
Encode Priority.
Encodes the priority for an interrupt with the given priority group, preemptive priority value, and subpriority value. In case of a conflict between priority grouping and available priority bits (__NVIC_PRIO_BITS), the smallest possible priority group is set.
Parameters
[in]PreemptPriorityPreemptive priority value (starting from 0).
[in]SubPrioritySubpriority value (starting from 0).
Returns
Encoded priority. Value can be used in the function NVIC_SetPriority().
◆ NVIC_GetActive()
__STATIC_INLINE uint32_t NVIC_GetActive ( IRQn_Type  IRQn)
Reads the active register in NVIC and returns the active bit.
Parameters
[in]IRQnInterrupt number.
Returns
0 Interrupt status is not active.
1 Interrupt status is active.
◆ NVIC_GetPendingIRQ()
__STATIC_INLINE uint32_t NVIC_GetPendingIRQ ( IRQn_Type  IRQn)
Reads the pending register in the NVIC and returns the pending bit for the specified interrupt.
Parameters
Returns
0 Interrupt status is not pending.
1 Interrupt status is pending.
◆ NVIC_GetPriority()
__STATIC_INLINE uint32_t NVIC_GetPriority ( IRQn_Type  IRQn)
Reads the priority of an interrupt. The interrupt number can be positive to specify an external (device specific) interrupt, or negative to specify an internal (core) interrupt.
Parameters
Returns
Interrupt Priority. Value is aligned automatically to the implemented priority bits of the microcontroller.
◆ NVIC_GetPriorityGrouping()
__STATIC_INLINE uint32_t NVIC_GetPriorityGrouping ( void  )
Reads the priority grouping field from the NVIC Interrupt Controller.
Returns
Priority grouping field (SCB->AIRCR [10:8] PRIGROUP field).
◆ NVIC_SetPendingIRQ()
__STATIC_INLINE void NVIC_SetPendingIRQ ( IRQn_Type  IRQn)
Sets the pending bit of an external interrupt.
Parameters
[in]IRQnInterrupt number. Value cannot be negative.
◆ NVIC_SetPriority()
__STATIC_INLINE void NVIC_SetPriority ( IRQn_Type  IRQn,
uint32_t  priority
Sets the priority of an interrupt.
Note
The priority cannot be set for every core interrupt.
Parameters
[in]priorityPriority to set.
◆ NVIC_SetPriorityGrouping()
__STATIC_INLINE void NVIC_SetPriorityGrouping ( uint32_t  PriorityGroup)
Sets the priority grouping field using the required unlock sequence. The parameter PriorityGroup is assigned to the field SCB->AIRCR [10:8] PRIGROUP field. Only values from 0..7 are used. In case of a conflict between priority grouping and available priority bits (__NVIC_PRIO_BITS), the smallest possible priority group is set.
Parameters
[in]PriorityGroupPriority grouping field.
◆ NVIC_SystemReset()
__STATIC_INLINE void NVIC_SystemReset ( void  )
System Reset.
Initiates a system reset request to reset the MCU.
