RTEMS 5.2
Stack Overflow Check User Extension Set. More...
#include <rtems.h>#include <inttypes.h>#include <string.h>#include <stdlib.h>#include <rtems/bspIo.h>#include <rtems/printer.h>#include <rtems/stackchk.h>#include <rtems/sysinit.h>#include <rtems/score/address.h>#include <rtems/score/percpu.h>#include <rtems/score/smp.h>#include <rtems/score/threadimpl.h>Macros | |
| #define | CPU_STACK_CHECK_PATTERN_INITIALIZER |
| #define | BYTE_PATTERN 0xA5 |
| #define | U32_PATTERN 0xA5A5A5A5 |
| #define | SANITY_PATTERN_SIZE_BYTES sizeof(Stack_check_Sanity_pattern) |
| #define | SANITY_PATTERN_SIZE_WORDS RTEMS_ARRAY_SIZE(Stack_check_Sanity_pattern) |
| #define | Stack_check_Get_pattern(_the_stack) |
| #define | Stack_check_Calculate_used(_low, _size, _high_water) ((char *)(_high_water) - (char *)(_low)) |
| #define | Stack_check_Usable_stack_start(_the_stack) ((_the_stack)->area) |
| #define | Stack_check_Usable_stack_size(_the_stack) ((_the_stack)->size - SANITY_PATTERN_SIZE_BYTES) |
| bool | rtems_stack_checker_create_extension (Thread_Control *running RTEMS_UNUSED, Thread_Control *the_thread) |
| void | rtems_stack_checker_begin_extension (Thread_Control *executing) |
| void | rtems_stack_checker_switch_extension (Thread_Control *running, Thread_Control *heir) |
| Stack Checker Task Context Switch Extension. More... | |
| bool | rtems_stack_checker_is_blown (void) |
| Checks if current task is blown its stack. More... | |
| void | rtems_stack_checker_report_usage_with_plugin (const rtems_printer *printer) |
| Print the stack usage report using caller's routine. More... | |
| void | rtems_stack_checker_report_usage (void) |
| Print the stack usage report using printk. More... | |
| RTEMS_SYSINIT_ITEM (Stack_check_Prepare_interrupt_stacks, RTEMS_SYSINIT_ISR_STACK, RTEMS_SYSINIT_ORDER_MIDDLE) | |
NOTE: This extension set automatically determines at initialization time whether the stack for this CPU grows up or down and installs the correct extension routines for that direction.
| #define CPU_STACK_CHECK_PATTERN_INITIALIZER |
