RTEMS 5.2
cacheimpl.h
1/*
2 * Cache Manager
3 *
4 * Copyright (C) 2014, 2018 embedded brains GmbH
5 *
6 * COPYRIGHT (c) 1989-1999.
7 * On-Line Applications Research Corporation (OAR).
8 *
9 * The license and distribution terms for this file may be
10 * found in the file LICENSE in this distribution or at
11 * http://www.rtems.org/license/LICENSE.
12 */
13
14/*
15 * The functions in this file implement the API to the RTEMS Cache Manager.
16 * This file is intended to be included in a cache implemention source file
17 * provided by the architecture or BSP, e.g.
18 *
19 * - bsps/${RTEMS_CPU}/shared/cache/cache.c
20 * - bsps/${RTEMS_CPU}/${RTEMS_BSP_FAMILY}/start/cache.c
21 *
22 * In this file a couple of defines and inline functions may be provided and
23 * afterwards this file is included, e.g.
24 *
25 * #define CPU_DATA_CACHE_ALIGNMENT XYZ
26 * ...
27 * #include "../../../bsps/shared/cache/cacheimpl.h"
28 *
29 * The cache implementation source file shall define
30 *
31 * #define CPU_DATA_CACHE_ALIGNMENT <POSITIVE INTEGER>
32 *
33 * to enable the data cache support.
34 *
35 * The cache implementation source file shall define
36 *
37 * #define CPU_INSTRUCTION_CACHE_ALIGNMENT <POSITIVE INTEGER>
38 *
39 * to enable the instruction cache support.
40 *
41 * The cache implementation source file shall define
42 *
43 * #define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
44 *
45 * if it provides cache maintenance functions which operate on multiple lines.
46 * Otherwise a generic loop with single line operations will be used. It is
47 * strongly recommended to provide the implementation in terms of static inline
48 * functions for performance reasons.
49 *
50 * The cache implementation source file shall define
51 *
52 * #define CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS
53 *
54 * if it provides functions to get the data and instruction cache sizes by
55 * level.
56 *
57 * The cache implementation source file shall define
58 *
59 * #define CPU_CACHE_SUPPORT_PROVIDES_INSTRUCTION_SYNC_FUNCTION
60 *
61 * if special instructions must be used to synchronize the instruction caches
62 * after a code change.
63 *
64 * The cache implementation source file shall define
65 *
66 * #define CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA
67 *
68 * if an external implementation of rtems_cache_disable_data() is provided,
69 * e.g. as an implementation in assembly code.
70 *
71 * The cache implementation source file shall define
72 *
73 * #define CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING
74 *
75 * if the hardware provides no instruction cache snooping and the instruction
76 * cache invalidation needs software support.
77 *
78 * The functions below are implemented with inline routines found in the cache
79 * implementation source file for each architecture or BSP. In the event that
80 * not support for a specific function for a cache is provided, the API routine
81 * does nothing (but does exist).
82 */
83
84#include <rtems.h>
85
86#if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
87#include <rtems/score/smpimpl.h>
89#endif
90
91#if CPU_DATA_CACHE_ALIGNMENT > CPU_CACHE_LINE_BYTES
92#error "CPU_DATA_CACHE_ALIGNMENT is greater than CPU_CACHE_LINE_BYTES"
93#endif
94
95#if CPU_INSTRUCTION_CACHE_ALIGNMENT > CPU_CACHE_LINE_BYTES
96#error "CPU_INSTRUCTION_CACHE_ALIGNMENT is greater than CPU_CACHE_LINE_BYTES"
97#endif
98
99/*
100 * THESE FUNCTIONS ONLY HAVE BODIES IF WE HAVE A DATA CACHE
101 */
102
103/*
104 * This function is called to flush the data cache by performing cache
105 * copybacks. It must determine how many cache lines need to be copied
106 * back and then perform the copybacks.
107 */
108void
109rtems_cache_flush_multiple_data_lines( const void * d_addr, size_t n_bytes )
110{
111#if defined(CPU_DATA_CACHE_ALIGNMENT)
112#if defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
113 _CPU_cache_flush_data_range( d_addr, n_bytes );
114#else
115 const void * final_address;
116
117 /*
118 * Set d_addr to the beginning of the cache line; final_address indicates
119 * the last address_t which needs to be pushed. Increment d_addr and push
120 * the resulting line until final_address is passed.
121 */
122
123 if( n_bytes == 0 )
124 /* Do nothing if number of bytes to flush is zero */
125 return;
126
127 final_address = (void *)((size_t)d_addr + n_bytes - 1);
128 d_addr = (void *)((size_t)d_addr & ~(CPU_DATA_CACHE_ALIGNMENT - 1));
129 while( d_addr <= final_address ) {
130 _CPU_cache_flush_1_data_line( d_addr );
131 d_addr = (void *)((size_t)d_addr + CPU_DATA_CACHE_ALIGNMENT);
132 }
133#endif
134#endif
135}
136
137/*
138 * This function is responsible for performing a data cache invalidate.
139 * It must determine how many cache lines need to be invalidated and then
140 * perform the invalidations.
141 */
142void
143rtems_cache_invalidate_multiple_data_lines( const void * d_addr, size_t n_bytes )
144{
145#if defined(CPU_DATA_CACHE_ALIGNMENT)
146#if defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
147 _CPU_cache_invalidate_data_range( d_addr, n_bytes );
148#else
149 const void * final_address;
150
151 /*
152 * Set d_addr to the beginning of the cache line; final_address indicates
153 * the last address_t which needs to be invalidated. Increment d_addr and
154 * invalidate the resulting line until final_address is passed.
155 */
156
157 if( n_bytes == 0 )
158 /* Do nothing if number of bytes to invalidate is zero */
159 return;
160
161 final_address = (void *)((size_t)d_addr + n_bytes - 1);
162 d_addr = (void *)((size_t)d_addr & ~(CPU_DATA_CACHE_ALIGNMENT - 1));
163 while( final_address >= d_addr ) {
164 _CPU_cache_invalidate_1_data_line( d_addr );
165 d_addr = (void *)((size_t)d_addr + CPU_DATA_CACHE_ALIGNMENT);
166 }
167#endif
168#endif
169}
170
171/*
172 * This function is responsible for performing a data cache flush.
173 * It flushes the entire cache.
174 */
175void
177{
178#if defined(CPU_DATA_CACHE_ALIGNMENT)
179 /*
180 * Call the CPU-specific routine
181 */
182 _CPU_cache_flush_entire_data();
183#endif
184}
185
186/*
187 * This function is responsible for performing a data cache
188 * invalidate. It invalidates the entire cache.
189 */
190void
192{
193#if defined(CPU_DATA_CACHE_ALIGNMENT)
194 /*
195 * Call the CPU-specific routine
196 */
197
198 _CPU_cache_invalidate_entire_data();
199#endif
200}
201
202/*
203 * This function returns the data cache granularity.
204 */
205size_t
207{
208#if defined(CPU_DATA_CACHE_ALIGNMENT)
210#else
211 return 0;
212#endif
213}
214
215size_t
217{
218#if defined(CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS)
219 return _CPU_cache_get_data_cache_size( level );
220#else
221 return 0;
222#endif
223}
224
225/*
226 * This function freezes the data cache; cache lines
227 * are not replaced.
228 */
229void
231{
232#if defined(CPU_DATA_CACHE_ALIGNMENT)
233 _CPU_cache_freeze_data();
234#endif
235}
236
238{
239#if defined(CPU_DATA_CACHE_ALIGNMENT)
240 _CPU_cache_unfreeze_data();
241#endif
242}
243
244void
246{
247#if defined(CPU_DATA_CACHE_ALIGNMENT)
248 _CPU_cache_enable_data();
249#endif
250}
251
252#if !defined(CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA)
253void
255{
256#if defined(CPU_DATA_CACHE_ALIGNMENT)
257 _CPU_cache_disable_data();
258#endif
259}
260#endif
261
262/*
263 * THESE FUNCTIONS ONLY HAVE BODIES IF WE HAVE AN INSTRUCTION CACHE
264 */
265
266#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT) \
267 && defined(RTEMS_SMP) \
268 && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
269
270typedef struct {
271 const void *addr;
272 size_t size;
273} smp_cache_area;
274
275static void smp_cache_inst_inv(void *arg)
276{
277 smp_cache_area *area = arg;
278
279 _CPU_cache_invalidate_instruction_range(area->addr, area->size);
280}
281
282static void smp_cache_inst_inv_all(void *arg)
283{
284 _CPU_cache_invalidate_entire_instruction();
285}
286
287static void smp_cache_broadcast( SMP_Action_handler handler, void *arg )
288{
289 uint32_t isr_level;
290 Per_CPU_Control *cpu_self;
291
292 isr_level = _ISR_Get_level();
293
294 if ( isr_level == 0 ) {
295 cpu_self = _Thread_Dispatch_disable();
296 } else {
297 cpu_self = _Per_CPU_Get();
298 }
299
300 _SMP_Broadcast_action( handler, arg );
301
302 if ( isr_level == 0 ) {
303 _Thread_Dispatch_enable( cpu_self );
304 }
305}
306
307#endif
308
309/*
310 * This function is responsible for performing an instruction cache
311 * invalidate. It must determine how many cache lines need to be invalidated
312 * and then perform the invalidations.
313 */
314#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT) \
315 && !defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
316static void
317_CPU_cache_invalidate_instruction_range(
318 const void * i_addr,
319 size_t n_bytes
320)
321{
322 const void * final_address;
323
324 /*
325 * Set i_addr to the beginning of the cache line; final_address indicates
326 * the last address_t which needs to be invalidated. Increment i_addr and
327 * invalidate the resulting line until final_address is passed.
328 */
329
330 if( n_bytes == 0 )
331 /* Do nothing if number of bytes to invalidate is zero */
332 return;
333
334 final_address = (void *)((size_t)i_addr + n_bytes - 1);
335 i_addr = (void *)((size_t)i_addr & ~(CPU_INSTRUCTION_CACHE_ALIGNMENT - 1));
336 while( final_address >= i_addr ) {
337 _CPU_cache_invalidate_1_instruction_line( i_addr );
338 i_addr = (void *)((size_t)i_addr + CPU_INSTRUCTION_CACHE_ALIGNMENT);
339 }
340}
341#endif
342
343void
345 const void * i_addr,
346 size_t n_bytes
347)
348{
349#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
350#if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
351 smp_cache_area area = { i_addr, n_bytes };
352
353 smp_cache_broadcast( smp_cache_inst_inv, &area );
354#else
355 _CPU_cache_invalidate_instruction_range( i_addr, n_bytes );
356#endif
357#endif
358}
359
360/*
361 * This function is responsible for performing an instruction cache
362 * invalidate. It invalidates the entire cache.
363 */
364void
366{
367#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
368#if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
369 smp_cache_broadcast( smp_cache_inst_inv_all, NULL );
370#else
371 _CPU_cache_invalidate_entire_instruction();
372#endif
373#endif
374}
375
376/*
377 * This function returns the instruction cache granularity.
378 */
379size_t
381{
382#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
383 return CPU_INSTRUCTION_CACHE_ALIGNMENT;
384#else
385 return 0;
386#endif
387}
388
389size_t
391{
392#if defined(CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS)
393 return _CPU_cache_get_instruction_cache_size( level );
394#else
395 return 0;
396#endif
397}
398
399/*
400 * This function freezes the instruction cache; cache lines
401 * are not replaced.
402 */
403void
405{
406#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
407 _CPU_cache_freeze_instruction();
408#endif
409}
410
412{
413#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
414 _CPU_cache_unfreeze_instruction();
415#endif
416}
417
418void
420{
421#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
422 _CPU_cache_enable_instruction();
423#endif
424}
425
426void
428{
429#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
430 _CPU_cache_disable_instruction();
431#endif
432}
433
434/* Returns the maximal cache line size of all cache kinds in bytes. */
436{
437#if defined(CPU_MAXIMAL_CACHE_ALIGNMENT)
438 return CPU_MAXIMAL_CACHE_ALIGNMENT;
439#endif
440 size_t max_line_size = 0;
441#if defined(CPU_DATA_CACHE_ALIGNMENT)
442 {
443 size_t data_line_size = CPU_DATA_CACHE_ALIGNMENT;
444 if ( max_line_size < data_line_size )
445 max_line_size = data_line_size;
446 }
447#endif
448#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
449 {
450 size_t instruction_line_size = CPU_INSTRUCTION_CACHE_ALIGNMENT;
451 if ( max_line_size < instruction_line_size )
452 max_line_size = instruction_line_size;
453 }
454#endif
455 return max_line_size;
456}
457
458/*
459 * Purpose is to synchronize caches after code has been loaded
460 * or self modified. Actual implementation is simple only
461 * but it can and should be repaced by optimized version
462 * which does not need flush and invalidate all cache levels
463 * when code is changed.
464 */
466 const void *code_addr,
467 size_t n_bytes
468)
469{
470#if defined(CPU_CACHE_SUPPORT_PROVIDES_INSTRUCTION_SYNC_FUNCTION)
471 _CPU_cache_instruction_sync_after_code_change( code_addr, n_bytes );
472#else
473 rtems_cache_flush_multiple_data_lines( code_addr, n_bytes );
475#endif
476}
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
size_t rtems_cache_get_maximal_line_size(void)
Definition: cacheimpl.h:435
void rtems_cache_invalidate_entire_instruction(void)
Invalidates the entire instruction cache.
Definition: cacheimpl.h:365
void rtems_cache_invalidate_entire_data(void)
Definition: cacheimpl.h:191
void rtems_cache_invalidate_multiple_instruction_lines(const void *i_addr, size_t n_bytes)
Invalidates multiple instruction cache lines.
Definition: cacheimpl.h:344
void rtems_cache_unfreeze_instruction(void)
Definition: cacheimpl.h:411
size_t rtems_cache_get_data_cache_size(uint32_t level)
Returns the data cache size in bytes.
Definition: cacheimpl.h:216
void rtems_cache_enable_data(void)
Definition: cacheimpl.h:245
void rtems_cache_disable_instruction(void)
Definition: cacheimpl.h:427
void rtems_cache_instruction_sync_after_code_change(const void *code_addr, size_t n_bytes)
Ensure necessary synchronization required after code changes.
Definition: cacheimpl.h:465
void rtems_cache_disable_data(void)
Definition: cacheimpl.h:254
size_t rtems_cache_get_instruction_cache_size(uint32_t level)
Returns the instruction cache size in bytes.
Definition: cacheimpl.h:390
void rtems_cache_unfreeze_data(void)
Definition: cacheimpl.h:237
void rtems_cache_freeze_instruction(void)
Definition: cacheimpl.h:404
void rtems_cache_invalidate_multiple_data_lines(const void *d_addr, size_t n_bytes)
Invalidates multiple data cache lines.
Definition: cacheimpl.h:143
void rtems_cache_flush_multiple_data_lines(const void *d_addr, size_t n_bytes)
Flushes multiple data cache lines.
Definition: cacheimpl.h:109
void rtems_cache_flush_entire_data(void)
Flushes the entire data cache.
Definition: cacheimpl.h:176
size_t rtems_cache_get_instruction_line_size(void)
Returns the instruction cache line size in bytes.
Definition: cacheimpl.h:380
size_t rtems_cache_get_data_line_size(void)
Returns the data cache line size in bytes.
Definition: cacheimpl.h:206
void rtems_cache_freeze_data(void)
Definition: cacheimpl.h:230
void rtems_cache_enable_instruction(void)
Definition: cacheimpl.h:419
Cache definitions and functions.
Definition: cache-l2c-310.c:65
#define _ISR_Get_level()
Return current interrupt level.
Definition: isrlevel.h:128
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Dispatch_disable(void)
Disables thread dispatching.
Definition: threaddispatch.h:191
void _Thread_Dispatch_enable(Per_CPU_Control *cpu_self)
Enables thread dispatching.
Definition: threaddispatch.c:362
SuperCore SMP Implementation.
Per CPU Core Structure.
Definition: percpu.h:347
unsigned size
Definition: tte.h:1
Constants and Structures Related with Thread Dispatch.
