RTEMS  5.1
Structure type to access the Instrumentation Trace Macrocell Register (ITM). More...
#include <core_cm7.h>
union {
   __OM uint8_t   u8
   __OM uint16_t   u16
   __OM uint32_t   u32
} PORT [32U]
uint32_t RESERVED0 [864U]
__IOM uint32_t TER
uint32_t RESERVED1 [15U]
__IOM uint32_t TPR
uint32_t RESERVED2 [15U]
__IOM uint32_t TCR
uint32_t RESERVED3 [29U]
__OM uint32_t IWR
__IM uint32_t IRR
__IOM uint32_t IMCR
uint32_t RESERVED4 [43U]
__OM uint32_t LAR
__IM uint32_t LSR
uint32_t RESERVED5 [6U]
__IM uint32_t PID4
__IM uint32_t PID5
__IM uint32_t PID6
__IM uint32_t PID7
__IM uint32_t PID0
__IM uint32_t PID1
__IM uint32_t PID2
__IM uint32_t PID3
__IM uint32_t CID0
__IM uint32_t CID1
__IM uint32_t CID2
__IM uint32_t CID3
Field Documentation
◆ CID0
__IM uint32_t ITM_Type::CID0
Offset: 0xFF0 (R/ ) ITM Component Identification Register #0
◆ CID1
__IM uint32_t ITM_Type::CID1
Offset: 0xFF4 (R/ ) ITM Component Identification Register #1
◆ CID2
__IM uint32_t ITM_Type::CID2
Offset: 0xFF8 (R/ ) ITM Component Identification Register #2
◆ CID3
__IM uint32_t ITM_Type::CID3
Offset: 0xFFC (R/ ) ITM Component Identification Register #3
◆ IMCR
__IOM uint32_t ITM_Type::IMCR
Offset: 0xF00 (R/W) ITM Integration Mode Control Register
◆ IRR
__IM uint32_t ITM_Type::IRR
Offset: 0xEFC (R/ ) ITM Integration Read Register
◆ IWR
__OM uint32_t ITM_Type::IWR
Offset: 0xEF8 ( /W) ITM Integration Write Register
◆ LAR
__OM uint32_t ITM_Type::LAR
Offset: 0xFB0 ( /W) ITM Lock Access Register
◆ LSR
__IM uint32_t ITM_Type::LSR
Offset: 0xFB4 (R/ ) ITM Lock Status Register
◆ PID0
__IM uint32_t ITM_Type::PID0
Offset: 0xFE0 (R/ ) ITM Peripheral Identification Register #0
◆ PID1
__IM uint32_t ITM_Type::PID1
Offset: 0xFE4 (R/ ) ITM Peripheral Identification Register #1
◆ PID2
__IM uint32_t ITM_Type::PID2
Offset: 0xFE8 (R/ ) ITM Peripheral Identification Register #2
◆ PID3
__IM uint32_t ITM_Type::PID3
Offset: 0xFEC (R/ ) ITM Peripheral Identification Register #3
◆ PID4
__IM uint32_t ITM_Type::PID4
Offset: 0xFD0 (R/ ) ITM Peripheral Identification Register #4
◆ PID5
__IM uint32_t ITM_Type::PID5
Offset: 0xFD4 (R/ ) ITM Peripheral Identification Register #5
◆ PID6
__IM uint32_t ITM_Type::PID6
Offset: 0xFD8 (R/ ) ITM Peripheral Identification Register #6
◆ PID7
__IM uint32_t ITM_Type::PID7
Offset: 0xFDC (R/ ) ITM Peripheral Identification Register #7
◆ PORT
__OM { ... } ITM_Type::PORT[32U]
Offset: 0x000 ( /W) ITM Stimulus Port Registers
◆ TCR
__IOM uint32_t ITM_Type::TCR
Offset: 0xE80 (R/W) ITM Trace Control Register
◆ TER
__IOM uint32_t ITM_Type::TER
Offset: 0xE00 (R/W) ITM Trace Enable Register
◆ TPR
__IOM uint32_t ITM_Type::TPR
Offset: 0xE40 (R/W) ITM Trace Privilege Register
◆ u16
__OM uint16_t ITM_Type::u16
Offset: 0x000 ( /W) ITM Stimulus Port 16-bit
◆ u32
__OM uint32_t ITM_Type::u32
Offset: 0x000 ( /W) ITM Stimulus Port 32-bit
◆ u8
__OM uint8_t ITM_Type::u8
Offset: 0x000 ( /W) ITM Stimulus Port 8-bit
