    RTEMS
    5.1
Type definitions for the Instrumentation Trace Macrocell (ITM) More...
| struct | ITM_Type |
| Structure type to access the Instrumentation Trace Macrocell Register (ITM).  More... | |
| #define | ITM_TPR_PRIVMASK_Pos 0U |
| #define | ITM_TPR_PRIVMASK_Msk (0xFUL /*<< ITM_TPR_PRIVMASK_Pos*/) |
| #define | ITM_TCR_BUSY_Pos 23U |
| #define | ITM_TCR_BUSY_Msk (1UL << ITM_TCR_BUSY_Pos) |
| #define | ITM_TCR_TraceBusID_Pos 16U |
| #define | ITM_TCR_TraceBusID_Msk (0x7FUL << ITM_TCR_TraceBusID_Pos) |
| #define | ITM_TCR_GTSFREQ_Pos 10U |
| #define | ITM_TCR_GTSFREQ_Msk (3UL << ITM_TCR_GTSFREQ_Pos) |
| #define | ITM_TCR_TSPrescale_Pos 8U |
| #define | ITM_TCR_TSPrescale_Msk (3UL << ITM_TCR_TSPrescale_Pos) |
| #define | ITM_TCR_SWOENA_Pos 4U |
| #define | ITM_TCR_SWOENA_Msk (1UL << ITM_TCR_SWOENA_Pos) |
| #define | ITM_TCR_DWTENA_Pos 3U |
| #define | ITM_TCR_DWTENA_Msk (1UL << ITM_TCR_DWTENA_Pos) |
| #define | ITM_TCR_SYNCENA_Pos 2U |
| #define | ITM_TCR_SYNCENA_Msk (1UL << ITM_TCR_SYNCENA_Pos) |
| #define | ITM_TCR_TSENA_Pos 1U |
| #define | ITM_TCR_TSENA_Msk (1UL << ITM_TCR_TSENA_Pos) |
| #define | ITM_TCR_ITMENA_Pos 0U |
| #define | ITM_TCR_ITMENA_Msk (1UL /*<< ITM_TCR_ITMENA_Pos*/) |
| #define | ITM_IWR_ATVALIDM_Pos 0U |
| #define | ITM_IWR_ATVALIDM_Msk (1UL /*<< ITM_IWR_ATVALIDM_Pos*/) |
| #define | ITM_IRR_ATREADYM_Pos 0U |
| #define | ITM_IRR_ATREADYM_Msk (1UL /*<< ITM_IRR_ATREADYM_Pos*/) |
| #define | ITM_IMCR_INTEGRATION_Pos 0U |
| #define | ITM_IMCR_INTEGRATION_Msk (1UL /*<< ITM_IMCR_INTEGRATION_Pos*/) |
| #define | ITM_LSR_ByteAcc_Pos 2U |
| #define | ITM_LSR_ByteAcc_Msk (1UL << ITM_LSR_ByteAcc_Pos) |
| #define | ITM_LSR_Access_Pos 1U |
| #define | ITM_LSR_Access_Msk (1UL << ITM_LSR_Access_Pos) |
| #define | ITM_LSR_Present_Pos 0U |
| #define | ITM_LSR_Present_Msk (1UL /*<< ITM_LSR_Present_Pos*/) |
| #define ITM_IMCR_INTEGRATION_Msk (1UL /*<< ITM_IMCR_INTEGRATION_Pos*/) |
ITM IMCR: INTEGRATION Mask
| #define ITM_IMCR_INTEGRATION_Pos 0U |
ITM IMCR: INTEGRATION Position
| #define ITM_IRR_ATREADYM_Msk (1UL /*<< ITM_IRR_ATREADYM_Pos*/) |
ITM IRR: ATREADYM Mask
| #define ITM_IRR_ATREADYM_Pos 0U |
ITM IRR: ATREADYM Position
| #define ITM_IWR_ATVALIDM_Msk (1UL /*<< ITM_IWR_ATVALIDM_Pos*/) |
ITM IWR: ATVALIDM Mask
| #define ITM_IWR_ATVALIDM_Pos 0U |
ITM IWR: ATVALIDM Position
| #define ITM_LSR_Access_Msk (1UL << ITM_LSR_Access_Pos) |
ITM LSR: Access Mask
| #define ITM_LSR_Access_Pos 1U |
ITM LSR: Access Position
| #define ITM_LSR_ByteAcc_Msk (1UL << ITM_LSR_ByteAcc_Pos) |
ITM LSR: ByteAcc Mask
| #define ITM_LSR_ByteAcc_Pos 2U |
ITM LSR: ByteAcc Position
| #define ITM_LSR_Present_Msk (1UL /*<< ITM_LSR_Present_Pos*/) |
ITM LSR: Present Mask
| #define ITM_LSR_Present_Pos 0U |
ITM LSR: Present Position
| #define ITM_TCR_BUSY_Msk (1UL << ITM_TCR_BUSY_Pos) |
ITM TCR: BUSY Mask
| #define ITM_TCR_BUSY_Pos 23U |
ITM TCR: BUSY Position
| #define ITM_TCR_DWTENA_Msk (1UL << ITM_TCR_DWTENA_Pos) |
ITM TCR: DWTENA Mask
| #define ITM_TCR_DWTENA_Pos 3U |
ITM TCR: DWTENA Position
| #define ITM_TCR_GTSFREQ_Msk (3UL << ITM_TCR_GTSFREQ_Pos) |
ITM TCR: Global timestamp frequency Mask
| #define ITM_TCR_GTSFREQ_Pos 10U |
ITM TCR: Global timestamp frequency Position
| #define ITM_TCR_ITMENA_Msk (1UL /*<< ITM_TCR_ITMENA_Pos*/) |
ITM TCR: ITM Enable bit Mask
| #define ITM_TCR_ITMENA_Pos 0U |
ITM TCR: ITM Enable bit Position
| #define ITM_TCR_SWOENA_Msk (1UL << ITM_TCR_SWOENA_Pos) |
ITM TCR: SWOENA Mask
| #define ITM_TCR_SWOENA_Pos 4U |
ITM TCR: SWOENA Position
| #define ITM_TCR_SYNCENA_Msk (1UL << ITM_TCR_SYNCENA_Pos) |
ITM TCR: SYNCENA Mask
| #define ITM_TCR_SYNCENA_Pos 2U |
ITM TCR: SYNCENA Position
| #define ITM_TCR_TraceBusID_Msk (0x7FUL << ITM_TCR_TraceBusID_Pos) |
ITM TCR: ATBID Mask
| #define ITM_TCR_TraceBusID_Pos 16U |
ITM TCR: ATBID Position
| #define ITM_TCR_TSENA_Msk (1UL << ITM_TCR_TSENA_Pos) |
ITM TCR: TSENA Mask
| #define ITM_TCR_TSENA_Pos 1U |
ITM TCR: TSENA Position
| #define ITM_TCR_TSPrescale_Msk (3UL << ITM_TCR_TSPrescale_Pos) |
ITM TCR: TSPrescale Mask
| #define ITM_TCR_TSPrescale_Pos 8U |
ITM TCR: TSPrescale Position
| #define ITM_TPR_PRIVMASK_Msk (0xFUL /*<< ITM_TPR_PRIVMASK_Pos*/) |
ITM TPR: PRIVMASK Mask
| #define ITM_TPR_PRIVMASK_Pos 0U |
ITM TPR: PRIVMASK Position
 1.8.15
