RTEMS  5.1
Functions | Variables
RTEMS File System Interface for RTEMS. More...
#include <sys/param.h>
#include <inttypes.h>
#include <rtems/rfs/rtems-rfs-file.h>
#include <rtems/rfs/rtems-rfs-dir.h>
#include <rtems/rfs/rtems-rfs-link.h>
#include "rtems-rfs-rtems.h"
int rtems_rfs_rtems_fstat (const rtems_filesystem_location_info_t *pathloc, struct stat *buf)
int rtems_rfs_rtems_rmnod (const rtems_filesystem_location_info_t *parent_pathloc, const rtems_filesystem_location_info_t *pathloc)
int rtems_rfs_rtems_fdatasync (rtems_libio_t *iop)
int rtems_rfs_rtems_initialise (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
void rtems_rfs_rtems_shutdown (rtems_filesystem_mount_table_entry_t *mt_entry)
const rtems_filesystem_file_handlers_r rtems_rfs_rtems_link_handlers
const rtems_filesystem_operations_table rtems_rfs_ops
◆ rtems_rfs_rtems_fdatasync()
int rtems_rfs_rtems_fdatasync ( rtems_libio_t *  iop)
The following routine does a sync on an inode node. Currently it flushes everything related to this device.
Parameters
iop
Returns
int
◆ rtems_rfs_rtems_fstat()
int rtems_rfs_rtems_fstat ( const rtems_filesystem_location_info_t *  pathloc,
struct stat *  buf
The following routine does a stat on a node.
◆ rtems_rfs_rtems_rmnod()
int rtems_rfs_rtems_rmnod ( const rtems_filesystem_location_info_t *  parent_pathloc,
Routine to remove a node from the RFS file system.
Parameters
parent_pathloc
pathloc
Returns
int
◆ rtems_rfs_rtems_shutdown()
void rtems_rfs_rtems_shutdown ( rtems_filesystem_mount_table_entry_t *  mt_entry)
Shutdown the file system.
Variable Documentation
◆ rtems_rfs_ops
Initial value:
.lock_h = rtems_rfs_rtems_lock_by_mt_entry,
.unlock_h = rtems_rfs_rtems_unlock_by_mt_entry,
.eval_path_h = rtems_rfs_rtems_eval_path,
.link_h = rtems_rfs_rtems_link,
.fchmod_h = rtems_rfs_rtems_fchmod,
.mknod_h = rtems_rfs_rtems_mknod,
.chown_h = rtems_rfs_rtems_chown,
.fsunmount_me_h = rtems_rfs_rtems_shutdown,
.utime_h = rtems_rfs_rtems_utime,
.symlink_h = rtems_rfs_rtems_symlink,
.readlink_h = rtems_rfs_rtems_readlink,
.rename_h = rtems_rfs_rtems_rename,
.statvfs_h = rtems_rfs_rtems_statvfs
bool rtems_filesystem_default_are_nodes_equal(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node access pointer of one location is equal to the node access pointer of the other loc...
Definition: default_are_nodes_equal.c:29
int rtems_rfs_rtems_rmnod(const rtems_filesystem_location_info_t *parent_pathloc, const rtems_filesystem_location_info_t *pathloc)
Definition: rtems-rfs-rtems.c:563
int rtems_filesystem_default_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_unmount.c:22
void rtems_rfs_rtems_shutdown(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: rtems-rfs-rtems.c:833
void rtems_filesystem_default_freenode(const rtems_filesystem_location_info_t *loc)
Definition: default_freenode.c:24
int rtems_filesystem_default_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_mount.c:22
int rtems_filesystem_default_clonenode(rtems_filesystem_location_info_t *loc)
Definition: default_clone.c:29
RFS file system operations table.
◆ rtems_rfs_rtems_link_handlers
Initial value:
int rtems_filesystem_default_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
Definition: default_open.c:24
int rtems_filesystem_default_fcntl(rtems_libio_t *iop, int cmd)
Definition: default_fcntl.c:22
int rtems_filesystem_default_mmap(rtems_libio_t *iop, void **addr, size_t len, int prot, off_t off)
Default MMAP handler.
Definition: default_mmap.c:23
int rtems_filesystem_default_kqfilter(rtems_libio_t *iop, struct knote *kn)
Default kernel event filter handler.
Definition: default_kqfilter.c:29
int rtems_filesystem_default_poll(rtems_libio_t *iop, int events)
Default poll handler.
Definition: default_poll.c:31
ssize_t rtems_filesystem_default_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the read handler for each IO vector entry.
Definition: default_readv.c:32
ssize_t rtems_filesystem_default_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the write handler for each IO vector entry.
Definition: default_writev.c:32
int rtems_filesystem_default_ftruncate(rtems_libio_t *iop, off_t length)
Definition: default_ftruncate.c:25
int rtems_filesystem_default_close(rtems_libio_t *iop)
Definition: default_close.c:18
int rtems_rfs_rtems_fstat(const rtems_filesystem_location_info_t *pathloc, struct stat *buf)
Definition: rtems-rfs-rtems.c:416
off_t rtems_filesystem_default_lseek(rtems_libio_t *iop, off_t offset, int whence)
Definition: default_lseek.c:24
ssize_t rtems_filesystem_default_read(rtems_libio_t *iop, void *buffer, size_t count)
Definition: default_read.c:20
ssize_t rtems_filesystem_default_write(rtems_libio_t *iop, const void *buffer, size_t count)
Definition: default_write.c:22
int rtems_filesystem_default_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
Definition: default_ioctl.c:24
int rtems_filesystem_default_fsync_or_fdatasync(rtems_libio_t *iop)
Definition: default_fsync.c:24
Handler table for RFS link nodes
