21 #if !defined (_RTEMS_RFS_DIR_H_)    22 #define _RTEMS_RFS_DIR_H_    35 #define RTEMS_RFS_DIR_ENTRY_INO  (0)     37 #define RTEMS_RFS_DIR_ENTRY_HASH (4)     42 #define RTEMS_RFS_DIR_ENTRY_LEN  (8)     48 #define RTEMS_RFS_DIR_ENTRY_SIZE (4 + 4 + 2)    53 #define RTEMS_RFS_DIR_ENTRY_EMPTY (0xffff)    62 #define rtems_rfs_dir_entry_hash(_e) \    63   rtems_rfs_read_u32 (_e + RTEMS_RFS_DIR_ENTRY_HASH)    72 #define rtems_rfs_dir_set_entry_hash(_e, _h) \    73   rtems_rfs_write_u32 (_e + RTEMS_RFS_DIR_ENTRY_HASH, _h)    82 #define rtems_rfs_dir_entry_ino(_e) \    83   rtems_rfs_read_u32 (_e + RTEMS_RFS_DIR_ENTRY_INO)    92 #define rtems_rfs_dir_set_entry_ino(_e, _i) \    93   rtems_rfs_write_u32 (_e + RTEMS_RFS_DIR_ENTRY_INO, _i)   102 #define rtems_rfs_dir_entry_length(_e) \   103   rtems_rfs_read_u16 (_e + RTEMS_RFS_DIR_ENTRY_LEN)   111 #define rtems_rfs_dir_set_entry_length(_e, _l) \   112   rtems_rfs_write_u16 (_e + RTEMS_RFS_DIR_ENTRY_LEN, _l)   193                         struct dirent*          dirent,
Definition: rtems-rfs-file-system.h:123
uint32_t rtems_rfs_ino
Definition: rtems-rfs-inode.h:78
int rtems_rfs_dir_del_entry(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir, rtems_rfs_ino ino, uint32_t offset)
Definition: rtems-rfs-dir.c:372
Definition: rtems-rfs-inode.h:181
RTEMS File System Information Node.
int rtems_rfs_dir_empty(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir)
Definition: rtems-rfs-dir.c:649
int rtems_rfs_dir_add_entry(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir, const char *name, size_t length, rtems_rfs_ino ino)
Definition: rtems-rfs-dir.c:225
LibIO Internal Interface.
int rtems_rfs_dir_read(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir, rtems_rfs_pos_rel offset, struct dirent *dirent, size_t *length)
Definition: rtems-rfs-dir.c:526
int64_t rtems_rfs_pos_rel
Definition: rtems-rfs-file-system.h:95
int rtems_rfs_dir_lookup_ino(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *inode, const char *name, int length, rtems_rfs_ino *ino, uint32_t *offset)
Definition: rtems-rfs-dir.c:50
