19 #ifndef _RTEMS_POSIX_TIMERIMPL_H    20 #define _RTEMS_POSIX_TIMERIMPL_H    31 #define POSIX_TIMER_STATE_FREE        0x01    34 #define POSIX_TIMER_STATE_CREATE_NEW  0x02    37 #define POSIX_TIMER_STATE_CREATE_RUN  0x03    40 #define POSIX_TIMER_STATE_CREATE_STOP 0x04    43 #define POSIX_TIMER_RELATIVE       0    50 #if (POSIX_TIMER_RELATIVE == TIMER_ABSTIME)    51 #error "POSIX_TIMER_RELATIVE == TIMER_ABSTIME" Inlined Routines in the Watchdog Handler.
Objects_Information _POSIX_Timer_Information
The POSIX Timer objects information.
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
#define _ISR_lock_ISR_enable(_context)
Restores the saved interrupt state of the ISR lock context.
Definition: isrlock.h:419
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Watchdog_Get_CPU(const Watchdog_Control *the_watchdog)
Gets the watchdog's cpu.
Definition: watchdogimpl.h:177
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition: objectallocate.c:42
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_release_critical(Per_CPU_Control *cpu, ISR_lock_Context *lock_context)
Releases the per cpu watchdog lock in a critical section.
Definition: watchdogimpl.h:575
Per CPU Core Structure.
Definition: percpu.h:347
RTEMS_INLINE_ROUTINE void _Objects_Free(Objects_Information *information, Objects_Control *the_object)
Frees an object.
Definition: objectimpl.h:930
RTEMS_INLINE_ROUTINE POSIX_Timer_Control * _POSIX_Timer_Allocate(void)
POSIX Timer Allocate.
Definition: timerimpl.h:60
POSIX Timers Internal Support.
RTEMS_INLINE_ROUTINE POSIX_Timer_Control * _POSIX_Timer_Get(timer_t id, ISR_lock_Context *lock_context)
POSIX Timer Get.
Definition: timerimpl.h:89
uint32_t Objects_Id
Definition: object.h:80
Objects_Control * _Objects_Get(Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information)
Maps the specified object identifier to the associated local object control block.
Definition: objectgetlocal.c:28
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
RTEMS_INLINE_ROUTINE void _POSIX_Timer_Free(POSIX_Timer_Control *the_timer)
POSIX Timer Free.
Definition: timerimpl.h:71
Inlined Routines in the Object Handler.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_acquire_critical(Per_CPU_Control *cpu, ISR_lock_Context *lock_context)
Acquires the per cpu watchdog lock in a critical section.
Definition: watchdogimpl.h:561
