RTEMS  5.1
Macros | Functions
timerimpl.h File Reference
Inlined Routines from the POSIX Timer Manager. More...
#include <rtems/posix/timer.h>
#define POSIX_TIMER_STATE_FREE   0x01
#define POSIX_TIMER_STATE_CREATE_NEW   0x02
#define POSIX_TIMER_STATE_CREATE_RUN   0x03
#define POSIX_TIMER_STATE_CREATE_STOP   0x04
#define POSIX_TIMER_RELATIVE   0
RTEMS_INLINE_ROUTINE POSIX_Timer_Control * _POSIX_Timer_Allocate (void)
 POSIX Timer Allocate. More...
RTEMS_INLINE_ROUTINE void _POSIX_Timer_Free (POSIX_Timer_Control *the_timer)
 POSIX Timer Free. More...
void _POSIX_Timer_TSR (Watchdog_Control *the_watchdog)
RTEMS_INLINE_ROUTINE POSIX_Timer_Control * _POSIX_Timer_Get (timer_t id, ISR_lock_Context *lock_context)
 POSIX Timer Get. More...
RTEMS_INLINE_ROUTINE Per_CPU_Control * _POSIX_Timer_Acquire_critical (POSIX_Timer_Control *ptimer, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _POSIX_Timer_Release (Per_CPU_Control *cpu, ISR_lock_Context *lock_context)
This file contains the static inline implementation of the inlined routines from the POSIX Timer Manager.
◆ POSIX_TIMER_RELATIVE
Indicates that the fire time is relative to the current one
◆ POSIX_TIMER_STATE_CREATE_NEW
Created timer but not running
◆ POSIX_TIMER_STATE_CREATE_RUN
Created timer and running
◆ POSIX_TIMER_STATE_CREATE_STOP
Created, ran and stopped timer
◆ POSIX_TIMER_STATE_FREE
Timer is free
◆ _POSIX_Timer_Allocate()
RTEMS_INLINE_ROUTINE POSIX_Timer_Control* _POSIX_Timer_Allocate ( void  )
This function allocates a timer control block from the inactive chain of free timer control blocks.
◆ _POSIX_Timer_Free()
RTEMS_INLINE_ROUTINE void _POSIX_Timer_Free ( POSIX_Timer_Control *  the_timer)
POSIX Timer Free.
This routine frees a timer control block to the inactive chain of free timer control blocks.
◆ _POSIX_Timer_Get()
RTEMS_INLINE_ROUTINE POSIX_Timer_Control* _POSIX_Timer_Get ( timer_t  id,
ISR_lock_Context *  lock_context
POSIX Timer Get.
This function maps timer IDs to timer control blocks. If ID corresponds to a local timer, then it returns the timer control pointer which maps to ID and location is set to OBJECTS_LOCAL. Otherwise, location is set to OBJECTS_ERROR and the returned value is undefined.
