RTEMS  5.1
Data Structures | Macros | Enumerations | Functions | Variables
muteximpl.h File Reference
Private Inlined Routines for POSIX Mutex's. More...
#include <pthread.h>
#include <rtems/score/muteximpl.h>
struct  POSIX_Mutex_Control
#define POSIX_MUTEX_PROTOCOL_MASK   0x3UL
#define POSIX_MUTEX_RECURSIVE   0x4UL
#define POSIX_MUTEX_FLAGS_MASK   0x7UL
#define POSIX_MUTEX_MAGIC   0x961c13b8UL
#define POSIX_MUTEX_NO_PROTOCOL_TQ_OPERATIONS   &_Thread_queue_Operations_FIFO
#define POSIX_MUTEX_PRIORITY_INHERIT_TQ_OPERATIONS   &_Thread_queue_Operations_priority_inherit
#define POSIX_MUTEX_PRIORITY_CEILING_TQ_OPERATIONS   &_Thread_queue_Operations_priority
#define POSIX_MUTEX_ABSTIME_TRY_LOCK   ((uintptr_t) 1)
#define POSIX_MUTEX_VALIDATE_OBJECT(the_mutex, flags)
enum  POSIX_Mutex_Protocol { POSIX_MUTEX_NO_PROTOCOL, POSIX_MUTEX_PRIORITY_INHERIT, POSIX_MUTEX_PRIORITY_CEILING }
 Supported POSIX mutex protocols. More...
RTEMS_INLINE_ROUTINE Thread_Control * _POSIX_Mutex_Acquire (POSIX_Mutex_Control *the_mutex, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE void _POSIX_Mutex_Release (POSIX_Mutex_Control *the_mutex, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE POSIX_Mutex_Protocol _POSIX_Mutex_Get_protocol (unsigned long flags)
RTEMS_INLINE_ROUTINE bool _POSIX_Mutex_Is_recursive (unsigned long flags)
RTEMS_INLINE_ROUTINE Thread_Control * _POSIX_Mutex_Get_owner (const POSIX_Mutex_Control *the_mutex)
RTEMS_INLINE_ROUTINE bool _POSIX_Mutex_Is_locked (const POSIX_Mutex_Control *the_mutex)
Status_Control _POSIX_Mutex_Seize_slow (POSIX_Mutex_Control *the_mutex, const Thread_queue_Operations *operations, Thread_Control *executing, const struct timespec *abstime, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE void _POSIX_Mutex_Set_owner (POSIX_Mutex_Control *the_mutex, Thread_Control *owner)
RTEMS_INLINE_ROUTINE bool _POSIX_Mutex_Is_owner (const POSIX_Mutex_Control *the_mutex, const Thread_Control *the_thread)
RTEMS_INLINE_ROUTINE Status_Control _POSIX_Mutex_Seize (POSIX_Mutex_Control *the_mutex, unsigned long flags, const Thread_queue_Operations *operations, Thread_Control *executing, const struct timespec *abstime, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE Status_Control _POSIX_Mutex_Surrender (POSIX_Mutex_Control *the_mutex, const Thread_queue_Operations *operations, Thread_Control *executing, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE const Scheduler_Control * _POSIX_Mutex_Get_scheduler (const POSIX_Mutex_Control *the_mutex)
RTEMS_INLINE_ROUTINE void _POSIX_Mutex_Set_priority (POSIX_Mutex_Control *the_mutex, Priority_Control priority_ceiling, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE Priority_Control _POSIX_Mutex_Get_priority (const POSIX_Mutex_Control *the_mutex)
RTEMS_INLINE_ROUTINE Status_Control _POSIX_Mutex_Ceiling_set_owner (POSIX_Mutex_Control *the_mutex, Thread_Control *owner, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE Status_Control _POSIX_Mutex_Ceiling_seize (POSIX_Mutex_Control *the_mutex, unsigned long flags, Thread_Control *executing, const struct timespec *abstime, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE Status_Control _POSIX_Mutex_Ceiling_surrender (POSIX_Mutex_Control *the_mutex, Thread_Control *executing, Thread_queue_Context *queue_context)
int _POSIX_Mutex_Lock_support (pthread_mutex_t *mutex, const struct timespec *abstime, Thread_queue_Enqueue_callout enqueue_callout)
bool _POSIX_Mutex_Auto_initialization (POSIX_Mutex_Control *the_mutex)
const pthread_mutexattr_t _POSIX_Mutex_Default_attributes
This include file contains the static inline implementation of the private inlined routines for POSIX mutex's.
◆ POSIX_MUTEX_VALIDATE_OBJECT
#define POSIX_MUTEX_VALIDATE_OBJECT (   the_mutex,
  flags
Value:
do { \
if ( ( the_mutex ) == NULL ) { \
return EINVAL; \
flags = ( the_mutex )->flags; \
if ( \
( ( (uintptr_t) ( the_mutex ) ^ POSIX_MUTEX_MAGIC ) \
& ~POSIX_MUTEX_FLAGS_MASK ) \
!= ( flags & ~POSIX_MUTEX_FLAGS_MASK ) \
if ( !_POSIX_Mutex_Auto_initialization( the_mutex ) ) { \
return EINVAL; \
} while ( 0 )
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
◆ POSIX_Mutex_Protocol
Must be in synchronization with POSIX_Mutex_Control::protocol.
Variable Documentation
◆ _POSIX_Mutex_Default_attributes
The default mutex attributes structure.
