18 #ifndef _RTEMS_POSIX_MUTEXIMPL_H    19 #define _RTEMS_POSIX_MUTEXIMPL_H    39 #define POSIX_MUTEX_PROTOCOL_MASK 0x3UL    41 #define POSIX_MUTEX_RECURSIVE 0x4UL    43 #define POSIX_MUTEX_FLAGS_MASK 0x7UL    45 #define POSIX_MUTEX_MAGIC 0x961c13b8UL    47 #define POSIX_MUTEX_NO_PROTOCOL_TQ_OPERATIONS &_Thread_queue_Operations_FIFO    49 #define POSIX_MUTEX_PRIORITY_INHERIT_TQ_OPERATIONS \    50   &_Thread_queue_Operations_priority_inherit    52 #define POSIX_MUTEX_PRIORITY_CEILING_TQ_OPERATIONS \    53   &_Thread_queue_Operations_priority    61   POSIX_MUTEX_NO_PROTOCOL,
    62   POSIX_MUTEX_PRIORITY_INHERIT,
    63   POSIX_MUTEX_PRIORITY_CEILING
    80   _Thread_queue_Context_ISR_disable( queue_context, level );
    82   executing = _Thread_Executing;
    83   _Thread_queue_Queue_acquire_critical(
    84     &the_mutex->Recursive.Mutex.Queue.Queue,
    85     &executing->Potpourri_stats,
    98     &the_mutex->Recursive.Mutex.Queue.Queue,
   107   return flags & POSIX_MUTEX_PROTOCOL_MASK;
   114   return ( flags & POSIX_MUTEX_RECURSIVE ) != 0;
   121   return the_mutex->Recursive.Mutex.Queue.Queue.
owner;
   128   return _POSIX_Mutex_Get_owner( the_mutex ) !=
NULL;
   131 Status_Control _POSIX_Mutex_Seize_slow(
   135   const struct timespec         *abstime,
   144   the_mutex->Recursive.Mutex.Queue.Queue.
owner = owner;
   152   return _POSIX_Mutex_Get_owner( the_mutex ) == the_thread;
   155 static Status_Control _POSIX_Mutex_Lock_nested(
   161   if ( _POSIX_Mutex_Is_recursive( flags ) ) {
   162     ++the_mutex->Recursive.nest_level;
   163     return STATUS_SUCCESSFUL;
   165     return STATUS_NESTING_NOT_ALLOWED;
   174   const struct timespec         *abstime,
   180   owner = _POSIX_Mutex_Get_owner( the_mutex );
   182   if ( owner ==
NULL ) {
   183     _POSIX_Mutex_Set_owner( the_mutex, executing );
   185     _POSIX_Mutex_Release( the_mutex, queue_context );
   186     return STATUS_SUCCESSFUL;
   189   if ( owner == executing ) {
   190     Status_Control status;
   192     status = _POSIX_Mutex_Lock_nested( the_mutex, flags );
   193     _POSIX_Mutex_Release( the_mutex, queue_context );
   197   return _POSIX_Mutex_Seize_slow(
   213   unsigned int        nest_level;
   216   if ( !_POSIX_Mutex_Is_owner( the_mutex, executing ) ) {
   217     _POSIX_Mutex_Release( the_mutex, queue_context );
   218     return STATUS_NOT_OWNER;
   221   nest_level = the_mutex->Recursive.nest_level;
   223   if ( nest_level > 0 ) {
   224     the_mutex->Recursive.nest_level = nest_level - 1;
   225     _POSIX_Mutex_Release( the_mutex, queue_context );
   226     return STATUS_SUCCESSFUL;
   230   _POSIX_Mutex_Set_owner( the_mutex,
NULL );
   232   heads = the_mutex->Recursive.Mutex.Queue.Queue.
heads;
   234   if ( heads ==
NULL ) {
   235     _POSIX_Mutex_Release( the_mutex, queue_context );
   236     return STATUS_SUCCESSFUL;
   240     &the_mutex->Recursive.Mutex.Queue.Queue,
   246   return STATUS_SUCCESSFUL;
   253 #if defined(RTEMS_SMP)   254   return the_mutex->scheduler;
   268   owner = _POSIX_Mutex_Get_owner( the_mutex );
   270   if ( owner !=
NULL ) {
   274       &the_mutex->Priority_ceiling,
   281     the_mutex->Priority_ceiling.
priority = priority_ceiling;
   289   return the_mutex->Priority_ceiling.
priority;
   308       < the_mutex->Priority_ceiling.
priority   311     _POSIX_Mutex_Release( the_mutex, queue_context );
   312     return STATUS_MUTEX_CEILING_VIOLATED;
   315   _POSIX_Mutex_Set_owner( the_mutex, owner );
   319     &the_mutex->Priority_ceiling,
   325   _POSIX_Mutex_Release( the_mutex, queue_context );
   328   return STATUS_SUCCESSFUL;
   335   const struct timespec *abstime,
   341   owner = _POSIX_Mutex_Get_owner( the_mutex );
   343   if ( owner ==
NULL ) {
   344 #if defined(RTEMS_SMP)   347         != _POSIX_Mutex_Get_scheduler( the_mutex )
   349       _POSIX_Mutex_Release( the_mutex, queue_context );
   350       return STATUS_NOT_DEFINED;
   355     return _POSIX_Mutex_Ceiling_set_owner(
   362   if ( owner == executing ) {
   363     Status_Control status;
   365     status = _POSIX_Mutex_Lock_nested( the_mutex, flags );
   366     _POSIX_Mutex_Release( the_mutex, queue_context );
   370   return _POSIX_Mutex_Seize_slow(
   372     POSIX_MUTEX_PRIORITY_CEILING_TQ_OPERATIONS,
   385   unsigned int        nest_level;
   390   if ( !_POSIX_Mutex_Is_owner( the_mutex, executing ) ) {
   391     _POSIX_Mutex_Release( the_mutex, queue_context );
   392     return STATUS_NOT_OWNER;
   395   nest_level = the_mutex->Recursive.nest_level;
   397   if ( nest_level > 0 ) {
   398     the_mutex->Recursive.nest_level = nest_level - 1;
   399     _POSIX_Mutex_Release( the_mutex, queue_context );
   400     return STATUS_SUCCESSFUL;
   409     &the_mutex->Priority_ceiling,
   416   heads = the_mutex->Recursive.Mutex.Queue.Queue.
heads;
   418   if ( heads !=
NULL ) {
   422     operations = POSIX_MUTEX_PRIORITY_CEILING_TQ_OPERATIONS;
   423     new_owner = ( *operations->
first )( heads );
   424     _POSIX_Mutex_Set_owner( the_mutex, new_owner );
   428       &the_mutex->Priority_ceiling,
   432       &the_mutex->Recursive.Mutex.Queue.Queue,
   438     _POSIX_Mutex_Set_owner( the_mutex,
NULL );
   439     _POSIX_Mutex_Release( the_mutex, queue_context );
   444   return STATUS_SUCCESSFUL;
   447 #define POSIX_MUTEX_ABSTIME_TRY_LOCK ((uintptr_t) 1)   449 int _POSIX_Mutex_Lock_support(
   450   pthread_mutex_t              *
mutex,
   451   const struct timespec        *abstime,
   456   pthread_mutex_t *
mutex   464 #define POSIX_MUTEX_VALIDATE_OBJECT( the_mutex, flags ) \   466     if ( ( the_mutex ) == NULL ) { \   469     flags = ( the_mutex )->flags; \   471       ( ( (uintptr_t) ( the_mutex ) ^ POSIX_MUTEX_MAGIC ) \   472           & ~POSIX_MUTEX_FLAGS_MASK ) \   473         != ( flags & ~POSIX_MUTEX_FLAGS_MASK ) \   475       if ( !_POSIX_Mutex_Auto_initialization( the_mutex ) ) { \ Thread_Control * owner
The thread queue owner.
Definition: threadq.h:431
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_default_critical(Thread_Control *the_thread, ISR_lock_Context *lock_context)
Acquires the thread wait default lock inside a critical section (interrupts disabled).
Definition: threadimpl.h:1632
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_queue_Dispatch_disable(Thread_queue_Context *queue_context)
Disables dispatching in a critical section.
Definition: threadqimpl.h:429
POSIX_Mutex_Protocol
Supported POSIX mutex protocols.
Definition: muteximpl.h:60
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
Thread queue context for the thread queue methods.
Definition: threadq.h:198
The priority node to build up a priority aggregation.
Definition: priority.h:98
RTEMS_INLINE_ROUTINE void _Thread_Resource_count_decrement(Thread_Control *the_thread)
Decrements the thread's resource count.
Definition: threadimpl.h:1329
Definition: muteximpl.h:32
POSIX Threads Private Support.
Priority_Control priority
The priority value of this node.
Definition: priority.h:110
Thread_queue_First_operation first
Thread queue first operation.
Definition: threadq.h:545
Structures for the implementation of mutexes.
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire(Thread_Control *the_thread, Thread_queue_Context *queue_context)
Acquires the thread wait default lock and disables interrupts.
Definition: threadimpl.h:1842
Thread queue operations.
Definition: threadq.h:517
Thread_queue_Heads * heads
Lock to protect this thread queue.
Definition: threadq.h:426
Thread queue heads.
Definition: threadq.h:360
RTEMS_INLINE_ROUTINE void _Thread_Resource_count_increment(Thread_Control *the_thread)
Increments the thread's resource count.
Definition: threadimpl.h:1313
Per CPU Core Structure.
Definition: percpu.h:347
RTEMS_INLINE_ROUTINE void _Thread_Wait_release(Thread_Control *the_thread, Thread_queue_Context *queue_context)
Releases the thread wait lock and restores the previous interrupt status.
Definition: threadimpl.h:1903
uint32_t ISR_Level
Definition: isrlevel.h:41
void(* Thread_queue_Enqueue_callout)(Thread_queue_Queue *queue, Thread_Control *the_thread, struct Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
Thread queue enqueue callout.
Definition: threadq.h:72
Thread_queue_Lock_context Lock_context
The lock context for the thread queue acquire and release operations.
Definition: threadq.h:203
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_ISR_level(Thread_queue_Context *queue_context, ISR_Level level)
Sets the thread queue context ISR level.
Definition: threadqimpl.h:411
void _Thread_queue_Surrender(Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations)
Surrenders the thread queue previously owned by the thread to the first enqueued thread.
Definition: threadqenqueue.c:660
const Scheduler_Control _Scheduler_Table[]
Registered schedulers.
void _Thread_Priority_update(Thread_queue_Context *queue_context)
Updates the priority of all threads in the set.
Definition: threadchangepriority.c:339
void _Thread_Dispatch_enable(Per_CPU_Control *cpu_self)
Enables thread dispatching.
Definition: threaddispatch.c:362
RTEMS_INLINE_ROUTINE void _Thread_Wait_release_default_critical(Thread_Control *the_thread, ISR_lock_Context *lock_context)
Releases the thread wait default lock inside a critical section (interrupts disabled).
Definition: threadimpl.h:1692
const pthread_mutexattr_t _POSIX_Mutex_Default_attributes
Definition: mutexinit.c:58
Definition: muteximpl.h:42
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_clear_priority_updates(Thread_queue_Context *queue_context)
Clears the priority update count of the thread queue context.
Definition: threadqimpl.h:338
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_initialize(Thread_queue_Context *queue_context)
Initializes a thread queue context.
Definition: threadqimpl.h:152
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Thread_Scheduler_get_home(const Thread_Control *the_thread)
Gets the home scheduler of the thread.
Definition: threadimpl.h:1393
Scheduler control.
Definition: scheduler.h:269
Scheduler node for per-thread data.
Definition: schedulernode.h:79
Inlined Routines from the Thread Handler.
void _Thread_Priority_remove(Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Removes the specified thread priority node from the corresponding thread priority aggregation.
Definition: threadchangepriority.c:292
struct Scheduler_Node::@3980 Wait
Thread wait support block.
RTEMS_INLINE_ROUTINE Priority_Control _Priority_Get_priority(const Priority_Aggregation *aggregation)
Gets the priority aggregation's priority.
Definition: priorityimpl.h:270
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
ISR_lock_Context Lock_context
Definition: threadq.h:130
void _Thread_Priority_add(Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Adds the specified thread priority node to the corresponding thread priority aggregation.
Definition: threadchangepriority.c:277
RTEMS_INLINE_ROUTINE void _Thread_Priority_change(Thread_Control *the_thread, Priority_Node *priority_node, Priority_Control new_priority, bool prepend_it, Thread_queue_Context *queue_context)
Changes the thread priority value of the specified thread priority node in the corresponding thread p...
Definition: threadimpl.h:696
void _Thread_queue_Extract_critical(Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context)
Extracts the thread from the thread queue and unblocks it.
Definition: threadqenqueue.c:600
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_release(Thread_queue_Queue *queue, ISR_lock_Context *lock_context)
Releases the thread queue queue and enables interrupts.
Definition: threadqimpl.h:625
RTEMS_INLINE_ROUTINE Scheduler_Node * _Thread_Scheduler_get_home_node(const Thread_Control *the_thread)
Gets the scheduler's home node.
Definition: threadimpl.h:1412
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
