#define  | LPC176X_PLL_CON_PLLE   BSP_BIT32( 0 ) |
#define  | LPC176X_PLL_CON_PLLC   BSP_BIT32( 1 ) |
#define  | LPC176X_PLL_SEL_MSEL(val)   BSP_FLD32( val, 0, 14 ) |
#define  | LPC176X_PLL_SEL_MSEL_GET(reg)   BSP_FLD32GET( reg, 0, 14 ) |
#define  | LPC176X_PLL_SEL_MSEL_SET(reg,  val)   BSP_FLD32SET( reg, val, 0, 14 ) |
#define  | LPC176X_PLL_SEL_PSEL(val)   BSP_FLD32( val, 16, 23 ) |
#define  | LPC176X_PLL_SEL_PSEL_GET(reg)   BSP_FLD32GET( reg, 16, 23 ) |
#define  | LPC176X_PLL_SEL_PSEL_SET(reg,  val)   BSP_FLD32SET( reg, val, 16, 23 ) |
#define  | LPC176X_PLL_STAT_PLLE   BSP_BIT32( 24 ) |
#define  | LPC176X_PLL_STAT_PLLC   BSP_BIT32( 25 ) |
#define  | LPC176X_PLL_STAT_PLOCK   BSP_BIT32( 26 ) |
#define  | LPC176X_SCB_BASE_ADDR   0x400FC000U |
#define  | LPC176X_SCB_FLASHCFG_FLASHTIM(val)   BSP_FLD32( val, 12, 15 ) |
#define  | LPC176X_SCB_FLASHCFG_FLASHTIM_GET(reg)   BSP_FLD32GET( reg, 12, 15 ) |
| #define  | LPC176X_SCB_FLASHCFG_FLASHTIM_SET(reg,  val) |
#define  | LPC176X_SCB_MEMMAP_MAP   BSP_BIT32( 0 ) |
#define  | LPC176X_SCB_PCON_PM0   BSP_BIT32( 0 ) |
#define  | LPC176X_SCB_PCON_PM1   BSP_BIT32( 1 ) |
#define  | LPC176X_SCB_PCON_BODRPM   BSP_BIT32( 2 ) |
#define  | LPC176X_SCB_PCON_BOGD   BSP_BIT32( 3 ) |
#define  | LPC176X_SCB_PCON_BORD   BSP_BIT32( 4 ) |
#define  | LPC176X_SCB_PCON_SMFLAG   BSP_BIT32( 8 ) |
#define  | LPC176X_SCB_PCON_DSFLAG   BSP_BIT32( 9 ) |
#define  | LPC176X_SCB_PCON_PDFLAG   BSP_BIT32( 10 ) |
#define  | LPC176X_SCB_PCON_DPDFLAG   BSP_BIT32( 11 ) |
#define  | LPC176X_SCB_PCONP_TIMER_0   BSP_BIT32( 1 ) |
#define  | LPC176X_SCB_PCONP_TIMER_1   BSP_BIT32( 2 ) |
#define  | LPC176X_SCB_PCONP_UART_0   BSP_BIT32( 3 ) |
#define  | LPC176X_SCB_PCONP_UART_1   BSP_BIT32( 4 ) |
#define  | LPC176X_SCB_PCONP_PWM_0   BSP_BIT32( 6 ) |
#define  | LPC176X_SCB_PCONP_I2C_0   BSP_BIT32( 7 ) |
#define  | LPC176X_SCB_PCONP_SPI   BSP_BIT32( 8 ) |
#define  | LPC176X_SCB_PCONP_RTC   BSP_BIT32( 9 ) |
#define  | LPC176X_SCB_PCONP_SSP_1   BSP_BIT32( 10 ) |
#define  | LPC176X_SCB_PCONP_ADC   BSP_BIT32( 12 ) |
#define  | LPC176X_SCB_PCONP_CAN_1   BSP_BIT32( 13 ) |
#define  | LPC176X_SCB_PCONP_CAN_2   BSP_BIT32( 14 ) |
#define  | LPC176X_SCB_PCONP_GPIO   BSP_BIT32( 15 ) |
#define  | LPC176X_SCB_PCONP_RIT   BSP_BIT32( 16 ) |
#define  | LPC176X_SCB_PCONP_MCPWM   BSP_BIT32( 17 ) |
#define  | LPC176X_SCB_PCONP_QEI   BSP_BIT32( 18 ) |
#define  | LPC176X_SCB_PCONP_I2C_1   BSP_BIT32( 19 ) |
#define  | LPC176X_SCB_PCONP_SSP_0   BSP_BIT32( 21 ) |
#define  | LPC176X_SCB_PCONP_TIMER_2   BSP_BIT32( 22 ) |
#define  | LPC176X_SCB_PCONP_TIMER_3   BSP_BIT32( 23 ) |
#define  | LPC176X_SCB_PCONP_UART_2   BSP_BIT32( 24 ) |
#define  | LPC176X_SCB_PCONP_UART_3   BSP_BIT32( 25 ) |
#define  | LPC176X_SCB_PCONP_I2C_2   BSP_BIT32( 26 ) |
#define  | LPC176X_SCB_PCONP_I2S   BSP_BIT32( 27 ) |
#define  | LPC176X_SCB_PCONP_GPDMA   BSP_BIT32( 29 ) |
#define  | LPC176X_SCB_PCONP_ENET   BSP_BIT32( 30 ) |
#define  | LPC176X_SCB_PCONP_USB   BSP_BIT32( 31 ) |
#define  | LPC176X_SCB_CCLKSEL_CCLKDIV(val)   BSP_FLD32( val, 0, 7 ) |
#define  | LPC176X_SCB_CCLKSEL_CCLKDIV_GET(reg)   BSP_FLD32GET( reg, 0, 7 ) |
| #define  | LPC176X_SCB_CCLKSEL_CCLKDIV_SET(reg,  val) |
#define  | LPC176X_SCB_CCLKSEL_CCLKSEL   BSP_BIT32( 8 ) |
#define  | LPC176X_SCB_USBCLKSEL_USBDIV(val)   BSP_FLD32( val, 0, 4 ) |
#define  | LPC176X_SCB_USBCLKSEL_USBDIV_GET(reg)   BSP_FLD32GET( reg, 0, 4 ) |
| #define  | LPC176X_SCB_USBCLKSEL_USBDIV_SET(reg,  val) |
#define  | LPC176X_SCB_USBCLKSEL_USBSEL(val)   BSP_FLD32( val, 8, 9 ) |
#define  | LPC176X_SCB_USBCLKSEL_USBSEL_GET(reg)   BSP_FLD32GET( reg, 8, 9 ) |
| #define  | LPC176X_SCB_USBCLKSEL_USBSEL_SET(reg,  val) |
#define  | LPC176X_SCB_CLKSRCSEL_CLKSRC   BSP_BIT32( 0 ) |
#define  | LPC176X_SCB_SCS_MCIPWR   BSP_BIT32( 3 ) |
#define  | LPC176X_SCB_SCS_OSC_RANGE_SEL   BSP_BIT32( 4 ) |
#define  | LPC176X_SCB_SCS_OSC_ENABLE   BSP_BIT32( 5 ) |
#define  | LPC176X_SCB_SCS_OSC_STATUS   BSP_BIT32( 6 ) |
#define  | LPC176X_SCB_PCLKSEL_PCLKDIV(val)   BSP_FLD32( val, 0, 4 ) |
#define  | LPC176X_SCB_PCLKSEL_PCLKDIV_GET(reg)   BSP_FLD32GET( reg, 0, 4 ) |
| #define  | LPC176X_SCB_PCLKSEL_PCLKDIV_SET(reg,  val) |
#define  | LPC176X_SCB_PBOOST_BOOST   BSP_BIT32( 0 ) |
#define  | LPC176X_SCB_CLKOUTCFG_CLKOUTSEL(val)   BSP_FLD32( val, 3, 0 ) |
#define  | LPC176X_SCB_CLKOUTCFG_CLKOUTSEL_GET(reg)   BSP_FLD32GET( reg, 3, 0 ) |
| #define  | LPC176X_SCB_CLKOUTCFG_CLKOUTSEL_SET(reg,  val) |
#define  | LPC176X_SCB_CLKOUTCFG_CLKOUTDIV(val)   BSP_FLD32( val, 7, 4 ) |
#define  | LPC176X_SCB_CLKOUTCFG_CLKOUTDIV_GET(reg)   BSP_FLD32GET( reg, 7, 4 ) |
| #define  | LPC176X_SCB_CLKOUTCFG_CLKOUTDIV_SET(reg,  val) |
#define  | LPC176X_SCB_CLKOUTCFG_CLKOUT_EN   BSP_BIT32( 8 ) |
#define  | LPC176X_SCB_CLKOUTCFG_CLKOUT_ACT   BSP_BIT32( 9 ) |
#define  | LPC176X_BASE   0x00u |
#define  | LPC176X_SCB   ( *(volatile lpc176x_scb *) ( LPC176X_SCB_BASE_ADDR ) ) |
#define  | LPC176X_FIO_BASE_ADDR   0x2009C000U |
#define  | LPC176X_FIO   ( (volatile lpc176x_fio *) LPC176X_FIO_BASE_ADDR ) |
#define  | FIO0DIR   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) ) |
#define  | FIO0MASK   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) ) |
#define  | FIO0PIN   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) ) |
#define  | FIO0SET   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) ) |
#define  | FIO0CLR   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) ) |
#define  | FIO1DIR   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) ) |
#define  | FIO1MASK   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) ) |
#define  | FIO1PIN   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) ) |
#define  | FIO1SET   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) ) |
#define  | FIO1CLR   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) ) |
#define  | FIO2DIR   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) ) |
#define  | FIO2MASK   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) ) |
#define  | FIO2PIN   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) ) |
#define  | FIO2SET   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) ) |
#define  | FIO2CLR   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) ) |
#define  | FIO3DIR   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) ) |
#define  | FIO3MASK   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) ) |
#define  | FIO3PIN   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) ) |
#define  | FIO3SET   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) ) |
#define  | FIO3CLR   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) ) |
#define  | FIO4DIR   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) ) |
#define  | FIO4MASK   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) ) |
#define  | FIO4PIN   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) ) |
#define  | FIO4SET   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) ) |
#define  | FIO4CLR   ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) ) |
#define  | FIO0DIR0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) ) |
#define  | FIO1DIR0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) ) |
#define  | FIO2DIR0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) ) |
#define  | FIO3DIR0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) ) |
#define  | FIO4DIR0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) ) |
#define  | FIO0DIR1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x01U ) ) |
#define  | FIO1DIR1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x21U ) ) |
#define  | FIO2DIR1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x41U ) ) |
#define  | FIO3DIR1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x61U ) ) |
#define  | FIO4DIR1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x81U ) ) |
#define  | FIO0DIR2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x02U ) ) |
#define  | FIO1DIR2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x22U ) ) |
#define  | FIO2DIR2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x42U ) ) |
#define  | FIO3DIR2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x62U ) ) |
#define  | FIO4DIR2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x82U ) ) |
#define  | FIO0DIR3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x03U ) ) |
#define  | FIO1DIR3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x23U ) ) |
#define  | FIO2DIR3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x43U ) ) |
#define  | FIO3DIR3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x63U ) ) |
#define  | FIO4DIR3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x83U ) ) |
#define  | FIO0DIRL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) ) |
#define  | FIO1DIRL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) ) |
#define  | FIO2DIRL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) ) |
#define  | FIO3DIRL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) ) |
#define  | FIO4DIRL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) ) |
#define  | FIO0DIRU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x02U ) ) |
#define  | FIO1DIRU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x22U ) ) |
#define  | FIO2DIRU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x42U ) ) |
#define  | FIO3DIRU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x62U ) ) |
#define  | FIO4DIRU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x82U ) ) |
#define  | FIO0MASK0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) ) |
#define  | FIO1MASK0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) ) |
#define  | FIO2MASK0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) ) |
#define  | FIO3MASK0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) ) |
#define  | FIO4MASK0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) ) |
#define  | FIO0MASK1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x11U ) ) |
#define  | FIO1MASK1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x21U ) ) |
#define  | FIO2MASK1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x51U ) ) |
#define  | FIO3MASK1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x71U ) ) |
#define  | FIO4MASK1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x91U ) ) |
#define  | FIO0MASK2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x12U ) ) |
#define  | FIO1MASK2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x32U ) ) |
#define  | FIO2MASK2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x52U ) ) |
#define  | FIO3MASK2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x72U ) ) |
#define  | FIO4MASK2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x92U ) ) |
#define  | FIO0MASK3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x13U ) ) |
#define  | FIO1MASK3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x33U ) ) |
#define  | FIO2MASK3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x53U ) ) |
#define  | FIO3MASK3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x73U ) ) |
#define  | FIO4MASK3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x93U ) ) |
#define  | FIO0MASKL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) ) |
#define  | FIO1MASKL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) ) |
#define  | FIO2MASKL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) ) |
#define  | FIO3MASKL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) ) |
#define  | FIO4MASKL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) ) |
#define  | FIO0MASKU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x12U ) ) |
#define  | FIO1MASKU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x32U ) ) |
#define  | FIO2MASKU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x52U ) ) |
#define  | FIO3MASKU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x72U ) ) |
#define  | FIO4MASKU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x92U ) ) |
#define  | FIO0PIN0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) ) |
#define  | FIO1PIN0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) ) |
#define  | FIO2PIN0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) ) |
#define  | FIO3PIN0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) ) |
#define  | FIO4PIN0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) ) |
#define  | FIO0PIN1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x15U ) ) |
#define  | FIO1PIN1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x25U ) ) |
#define  | FIO2PIN1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x55U ) ) |
#define  | FIO3PIN1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x75U ) ) |
#define  | FIO4PIN1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x95U ) ) |
#define  | FIO0PIN2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x16U ) ) |
#define  | FIO1PIN2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x36U ) ) |
#define  | FIO2PIN2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x56U ) ) |
#define  | FIO3PIN2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x76U ) ) |
#define  | FIO4PIN2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x96U ) ) |
#define  | FIO0PIN3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x17U ) ) |
#define  | FIO1PIN3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x37U ) ) |
#define  | FIO2PIN3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x57U ) ) |
#define  | FIO3PIN3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x77U ) ) |
#define  | FIO4PIN3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x97U ) ) |
#define  | FIO0PINL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) ) |
#define  | FIO1PINL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) ) |
#define  | FIO2PINL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) ) |
#define  | FIO3PINL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) ) |
#define  | FIO4PINL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) ) |
#define  | FIO0PINU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x16U ) ) |
#define  | FIO1PINU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x36U ) ) |
#define  | FIO2PINU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x56U ) ) |
#define  | FIO3PINU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x76U ) ) |
#define  | FIO4PINU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x96U ) ) |
#define  | FIO0SET0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) ) |
#define  | FIO1SET0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) ) |
#define  | FIO2SET0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) ) |
#define  | FIO3SET0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) ) |
#define  | FIO4SET0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) ) |
#define  | FIO0SET1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x19U ) ) |
#define  | FIO1SET1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x29U ) ) |
#define  | FIO2SET1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x59U ) ) |
#define  | FIO3SET1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x79U ) ) |
#define  | FIO4SET1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x99U ) ) |
#define  | FIO0SET2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1AU ) ) |
#define  | FIO1SET2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3AU ) ) |
#define  | FIO2SET2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5AU ) ) |
#define  | FIO3SET2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7AU ) ) |
#define  | FIO4SET2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9AU ) ) |
#define  | FIO0SET3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1BU ) ) |
#define  | FIO1SET3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3BU ) ) |
#define  | FIO2SET3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5BU ) ) |
#define  | FIO3SET3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7BU ) ) |
#define  | FIO4SET3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9BU ) ) |
#define  | FIO0SETL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) ) |
#define  | FIO1SETL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) ) |
#define  | FIO2SETL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) ) |
#define  | FIO3SETL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) ) |
#define  | FIO4SETL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) ) |
#define  | FIO0SETU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1AU ) ) |
#define  | FIO1SETU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3AU ) ) |
#define  | FIO2SETU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5AU ) ) |
#define  | FIO3SETU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7AU ) ) |
#define  | FIO4SETU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x9AU ) ) |
#define  | FIO0CLR0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) ) |
#define  | FIO1CLR0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) ) |
#define  | FIO2CLR0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) ) |
#define  | FIO3CLR0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) ) |
#define  | FIO4CLR0   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) ) |
#define  | FIO0CLR1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1DU ) ) |
#define  | FIO1CLR1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x2DU ) ) |
#define  | FIO2CLR1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5DU ) ) |
#define  | FIO3CLR1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7DU ) ) |
#define  | FIO4CLR1   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9DU ) ) |
#define  | FIO0CLR2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1EU ) ) |
#define  | FIO1CLR2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3EU ) ) |
#define  | FIO2CLR2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5EU ) ) |
#define  | FIO3CLR2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7EU ) ) |
#define  | FIO4CLR2   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9EU ) ) |
#define  | FIO0CLR3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1FU ) ) |
#define  | FIO1CLR3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3FU ) ) |
#define  | FIO2CLR3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5FU ) ) |
#define  | FIO3CLR3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7FU ) ) |
#define  | FIO4CLR3   ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9FU ) ) |
#define  | FIO0CLRL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) ) |
#define  | FIO1CLRL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) ) |
#define  | FIO2CLRL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) ) |
#define  | FIO3CLRL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) ) |
#define  | FIO4CLRL   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) ) |
#define  | FIO0CLRU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1EU ) ) |
#define  | FIO1CLRU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3EU ) ) |
#define  | FIO2CLRU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5EU ) ) |
#define  | FIO3CLRU   ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7EU ) ) |
#define  | FIO4CLRU   ( *(volatile uint16_t *) ( FIO_BASE_ADDR + 0x9EU ) ) |
#define  | LPC176X_USB_CLOCK   48000000U |
#define  | LPC176X_MODULE_CLOCK_MASK   0x3U |
#define  | PINSEL_BASE_ADDR   0x4002C000U |
#define  | PINSEL0   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x00U ) ) |
#define  | PINSEL1   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x04U ) ) |
#define  | PINSEL2   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x08U ) ) |
#define  | PINSEL3   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x0CU ) ) |
#define  | PINSEL4   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x10U ) ) |
#define  | PINSEL5   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x14U ) ) |
#define  | PINSEL6   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x18U ) ) |
#define  | PINSEL7   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x1CU ) ) |
#define  | PINSEL8   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x20U ) ) |
#define  | PINSEL9   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x24U ) ) |
#define  | PINSEL10   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x28U ) ) |
#define  | PINSEL11   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x2CU ) ) |
#define  | PINMODE0   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x40U ) ) |
#define  | PINMODE1   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x44U ) ) |
#define  | PINMODE2   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x48U ) ) |
#define  | PINMODE3   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x4CU ) ) |
#define  | PINMODE4   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x50U ) ) |
#define  | PINMODE5   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x54U ) ) |
#define  | PINMODE6   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x58U ) ) |
#define  | PINMODE7   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x5CU ) ) |
#define  | PINMODE8   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x60U ) ) |
#define  | PINMODE9   ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x64U ) ) |
#define  | PWM0_BASE_ADDR   0x40014000 |
#define  | PWM0IR   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x00 ) ) |
#define  | PWM0TCR   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x04 ) ) |
#define  | PWM0TC   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x08 ) ) |
#define  | PWM0PR   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x0C ) ) |
#define  | PWM0PC   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x10 ) ) |
#define  | PWM0MCR   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x14 ) ) |
#define  | PWM0MR0   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x18 ) ) |
#define  | PWM0MR1   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x1C ) ) |
#define  | PWM0MR2   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x20 ) ) |
#define  | PWM0MR3   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x24 ) ) |
#define  | PWM0CCR   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x28 ) ) |
#define  | PWM0CR0   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x2C ) ) |
#define  | PWM0CR1   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x30 ) ) |
#define  | PWM0CR2   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x34 ) ) |
#define  | PWM0CR3   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x38 ) ) |
#define  | PWM0EMR   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x3C ) ) |
#define  | PWM0MR4   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x40 ) ) |
#define  | PWM0MR5   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x44 ) ) |
#define  | PWM0MR6   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x48 ) ) |
#define  | PWM0PCR   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x4C ) ) |
#define  | PWM0LER   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x50 ) ) |
#define  | PWM0CTCR   ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x70 ) ) |
#define  | PWM1_BASE_ADDR   0x40018000 |
#define  | PWM1IR   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x00 ) ) |
#define  | PWM1TCR   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x04 ) ) |
#define  | PWM1TC   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x08 ) ) |
#define  | PWM1PR   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x0C ) ) |
#define  | PWM1PC   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x10 ) ) |
#define  | PWM1MCR   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x14 ) ) |
#define  | PWM1MR0   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x18 ) ) |
#define  | PWM1MR1   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x1C ) ) |
#define  | PWM1MR2   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x20 ) ) |
#define  | PWM1MR3   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x24 ) ) |
#define  | PWM1CCR   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x28 ) ) |
#define  | PWM1CR0   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x2C ) ) |
#define  | PWM1CR1   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x30 ) ) |
#define  | PWM1CR2   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x34 ) ) |
#define  | PWM1CR3   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x38 ) ) |
#define  | PWM1EMR   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x3C ) ) |
#define  | PWM1MR4   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x40 ) ) |
#define  | PWM1MR5   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x44 ) ) |
#define  | PWM1MR6   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x48 ) ) |
#define  | PWM1PCR   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x4C ) ) |
#define  | PWM1LER   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x50 ) ) |
#define  | PWM1CTCR   ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x70 ) ) |
#define  | UART0_BASE_ADDR   0x4000C000 |
#define  | U0RBR   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) ) |
#define  | U0THR   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) ) |
#define  | U0DLL   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) ) |
#define  | U0DLM   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x04 ) ) |
#define  | U0IER   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x04 ) ) |
#define  | U0IIR   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x08 ) ) |
#define  | U0FCR   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x08 ) ) |
#define  | U0LCR   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x0C ) ) |
#define  | U0LSR   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x14 ) ) |
#define  | U0SCR   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x1C ) ) |
#define  | U0ACR   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x20 ) ) |
#define  | U0ICR   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x24 ) ) |
#define  | U0FDR   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x28 ) ) |
#define  | U0TER   ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x30 ) ) |
#define  | UART1_BASE_ADDR   0x40010000 |
#define  | U1RBR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) ) |
#define  | U1THR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) ) |
#define  | U1DLL   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) ) |
#define  | U1DLM   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x04 ) ) |
#define  | U1IER   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x04 ) ) |
#define  | U1IIR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x08 ) ) |
#define  | U1FCR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x08 ) ) |
#define  | U1LCR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x0C ) ) |
#define  | U1MCR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x10 ) ) |
#define  | U1LSR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x14 ) ) |
#define  | U1MSR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x18 ) ) |
#define  | U1SCR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x1C ) ) |
#define  | U1ACR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x20 ) ) |
#define  | U1FDR   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x28 ) ) |
#define  | U1TER   ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x30 ) ) |
#define  | UART2_BASE_ADDR   0x40098000 |
#define  | U2RBR   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) ) |
#define  | U2THR   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) ) |
#define  | U2DLL   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) ) |
#define  | U2DLM   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x04 ) ) |
#define  | U2IER   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x04 ) ) |
#define  | U2IIR   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x08 ) ) |
#define  | U2FCR   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x08 ) ) |
#define  | U2LCR   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x0C ) ) |
#define  | U2LSR   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x14 ) ) |
#define  | U2SCR   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x1C ) ) |
#define  | U2ACR   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x20 ) ) |
#define  | U2ICR   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x24 ) ) |
#define  | U2FDR   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x28 ) ) |
#define  | U2TER   ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x30 ) ) |
#define  | UART3_BASE_ADDR   0x4009C000 |
#define  | U3RBR   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) ) |
#define  | U3THR   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) ) |
#define  | U3DLL   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) ) |
#define  | U3DLM   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x04 ) ) |
#define  | U3IER   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x04 ) ) |
#define  | U3IIR   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x08 ) ) |
#define  | U3FCR   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x08 ) ) |
#define  | U3LCR   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x0C ) ) |
#define  | U3LSR   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x14 ) ) |
#define  | U3SCR   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x1C ) ) |
#define  | U3ACR   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x20 ) ) |
#define  | U3ICR   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x24 ) ) |
#define  | U3FDR   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x28 ) ) |
#define  | U3TER   ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x30 ) ) |
#define  | SPI0_BASE_ADDR   0xE0020000 |
#define  | S0SPCR   ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x00 ) ) |
#define  | S0SPSR   ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x04 ) ) |
#define  | S0SPDR   ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x08 ) ) |
#define  | S0SPCCR   ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x0C ) ) |
#define  | S0SPINT   ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x1C ) ) |
#define  | RTC_BASE_ADDR   0x40024000 |
#define  | RTC_ILR   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x00 ) ) |
#define  | RTC_CTC   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x04 ) ) |
#define  | RTC_CCR   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x08 ) ) |
#define  | RTC_CIIR   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x0C ) ) |
#define  | RTC_AMR   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x10 ) ) |
#define  | RTC_CTIME0   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x14 ) ) |
#define  | RTC_CTIME1   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x18 ) ) |
#define  | RTC_CTIME2   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x1C ) ) |
#define  | RTC_SEC   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x20 ) ) |
#define  | RTC_MIN   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x24 ) ) |
#define  | RTC_HOUR   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x28 ) ) |
#define  | RTC_DOM   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x2C ) ) |
#define  | RTC_DOW   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x30 ) ) |
#define  | RTC_DOY   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x34 ) ) |
#define  | RTC_MONTH   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x38 ) ) |
#define  | RTC_YEAR   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x3C ) ) |
#define  | RTC_CISS   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x40 ) ) |
#define  | RTC_ALSEC   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x60 ) ) |
#define  | RTC_ALMIN   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x64 ) ) |
#define  | RTC_ALHOUR   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x68 ) ) |
#define  | RTC_ALDOM   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x6C ) ) |
#define  | RTC_ALDOW   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x70 ) ) |
#define  | RTC_ALDOY   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x74 ) ) |
#define  | RTC_ALMON   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x78 ) ) |
#define  | RTC_ALYEAR   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x7C ) ) |
#define  | RTC_PREINT   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x80 ) ) |
#define  | RTC_PREFRAC   ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x84 ) ) |
#define  | AD0_BASE_ADDR   0x40034000 |
#define  | AD0CR   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x00 ) ) |
#define  | AD0GDR   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x04 ) ) |
#define  | AD0INTEN   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x0C ) ) |
#define  | AD0_DATA_START   ( (volatile uint32_t *) ( AD0_BASE_ADDR + 0x10 ) ) |
#define  | AD0DR0   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x10 ) ) |
#define  | AD0DR1   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x14 ) ) |
#define  | AD0DR2   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x18 ) ) |
#define  | AD0DR3   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x1C ) ) |
#define  | AD0DR4   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x20 ) ) |
#define  | AD0DR5   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x24 ) ) |
#define  | AD0DR6   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x28 ) ) |
#define  | AD0DR7   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x2C ) ) |
#define  | AD0STAT   ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x30 ) ) |
#define  | DAC_BASE_ADDR   0x4008C000 |
#define  | DACR   ( *(volatile uint32_t *) ( DAC_BASE_ADDR + 0x00 ) ) |
#define  | CAN_ACCEPT_BASE_ADDR   0x4003C000 |
#define  | CAN_AFMR   ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x00 ) ) |
#define  | CAN_SFF_SA   ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x04 ) ) |
| #define  | CAN_SFF_GRP_SA |
#define  | CAN_EFF_SA   ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x0C ) ) |
| #define  | CAN_EFF_GRP_SA |
#define  | CAN_EOT   ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x14 ) ) |
| #define  | CAN_LUT_ERR_ADR |
#define  | CAN_LUT_ERR   ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x1C ) ) |
#define  | CAN_CENTRAL_BASE_ADDR   0x40040000 |
#define  | CAN_TX_SR   ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x00 ) ) |
#define  | CAN_RX_SR   ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x04 ) ) |
#define  | CAN_MSR   ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x08 ) ) |
#define  | CAN1_BASE_ADDR   0x40044000 |
#define  | CAN1MOD   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x00 ) ) |
#define  | CAN1CMR   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x04 ) ) |
#define  | CAN1GSR   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x08 ) ) |
#define  | CAN1ICR   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x0C ) ) |
#define  | CAN1IER   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x10 ) ) |
#define  | CAN1BTR   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x14 ) ) |
#define  | CAN1EWL   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x18 ) ) |
#define  | CAN1SR   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x1C ) ) |
#define  | CAN1RFS   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x20 ) ) |
#define  | CAN1RID   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x24 ) ) |
#define  | CAN1RDA   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x28 ) ) |
#define  | CAN1RDB   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x2C ) ) |
#define  | CAN1TFI1   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x30 ) ) |
#define  | CAN1TID1   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x34 ) ) |
#define  | CAN1TDA1   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x38 ) ) |
#define  | CAN1TDB1   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x3C ) ) |
#define  | CAN1TFI2   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x40 ) ) |
#define  | CAN1TID2   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x44 ) ) |
#define  | CAN1TDA2   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x48 ) ) |
#define  | CAN1TDB2   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x4C ) ) |
#define  | CAN1TFI3   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x50 ) ) |
#define  | CAN1TID3   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x54 ) ) |
#define  | CAN1TDA3   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x58 ) ) |
#define  | CAN1TDB3   ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x5C ) ) |
#define  | CAN2_BASE_ADDR   0x40048000 |
#define  | CAN2MOD   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x00 ) ) |
#define  | CAN2CMR   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x04 ) ) |
#define  | CAN2GSR   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x08 ) ) |
#define  | CAN2ICR   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x0C ) ) |
#define  | CAN2IER   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x10 ) ) |
#define  | CAN2BTR   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x14 ) ) |
#define  | CAN2EWL   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x18 ) ) |
#define  | CAN2SR   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x1C ) ) |
#define  | CAN2RFS   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x20 ) ) |
#define  | CAN2RID   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x24 ) ) |
#define  | CAN2RDA   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x28 ) ) |
#define  | CAN2RDB   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x2C ) ) |
#define  | CAN2TFI1   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x30 ) ) |
#define  | CAN2TID1   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x34 ) ) |
#define  | CAN2TDA1   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x38 ) ) |
#define  | CAN2TDB1   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x3C ) ) |
#define  | CAN2TFI2   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x40 ) ) |
#define  | CAN2TID2   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x44 ) ) |
#define  | CAN2TDA2   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x48 ) ) |
#define  | CAN2TDB2   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x4C ) ) |
#define  | CAN2TFI3   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x50 ) ) |
#define  | CAN2TID3   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x54 ) ) |
#define  | CAN2TDA3   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x58 ) ) |
#define  | CAN2TDB3   ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x5C ) ) |
#define  | MCI_BASE_ADDR   0x400c0000 |
#define  | MCI_POWER   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x00 ) ) |
#define  | MCI_CLOCK   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x04 ) ) |
#define  | MCI_ARGUMENT   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x08 ) ) |
#define  | MCI_COMMAND   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x0C ) ) |
#define  | MCI_RESP_CMD   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x10 ) ) |
#define  | MCI_RESP0   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x14 ) ) |
#define  | MCI_RESP1   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x18 ) ) |
#define  | MCI_RESP2   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x1C ) ) |
#define  | MCI_RESP3   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x20 ) ) |
#define  | MCI_DATA_TMR   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x24 ) ) |
#define  | MCI_DATA_LEN   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x28 ) ) |
#define  | MCI_DATA_CTRL   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x2C ) ) |
#define  | MCI_DATA_CNT   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x30 ) ) |
#define  | MCI_STATUS   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x34 ) ) |
#define  | MCI_CLEAR   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x38 ) ) |
#define  | MCI_MASK0   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x3C ) ) |
#define  | MCI_MASK1   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x40 ) ) |
#define  | MCI_FIFO_CNT   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x48 ) ) |
#define  | MCI_FIFO   ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x80 ) ) |
#define  | I2S_BASE_ADDR   0x400a8000 |
#define  | I2S_DAO   ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x00 ) ) |
#define  | I2S_DAI   ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x04 ) ) |
#define  | I2S_TX_FIFO   ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x08 ) ) |
#define  | I2S_RX_FIFO   ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x0C ) ) |
#define  | I2S_STATE   ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x10 ) ) |
#define  | I2S_DMA1   ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x14 ) ) |
#define  | I2S_DMA2   ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x18 ) ) |
#define  | I2S_IRQ   ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x1C ) ) |
#define  | I2S_TXRATE   ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x20 ) ) |
#define  | I2S_RXRATE   ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x24 ) ) |
#define  | DMA_BASE_ADDR   0x50004000 |
#define  | GPDMA_INT_STAT   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x000 ) ) |
#define  | GPDMA_INT_TCSTAT   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x004 ) ) |
#define  | GPDMA_INT_TCCLR   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x008 ) ) |
#define  | GPDMA_INT_ERR_STAT   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x00C ) ) |
#define  | GPDMA_INT_ERR_CLR   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x010 ) ) |
| #define  | GPDMA_RAW_INT_TCSTAT |
| #define  | GPDMA_RAW_INT_ERR_STAT |
#define  | GPDMA_ENABLED_CHNS   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x01C ) ) |
#define  | GPDMA_SOFT_BREQ   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x020 ) ) |
#define  | GPDMA_SOFT_SREQ   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x024 ) ) |
#define  | GPDMA_SOFT_LBREQ   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x028 ) ) |
#define  | GPDMA_SOFT_LSREQ   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x02C ) ) |
#define  | GPDMA_CONFIG   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x030 ) ) |
#define  | GPDMA_SYNC   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x034 ) ) |
#define  | GPDMA_CH0_BASE_ADDR   ( DMA_BASE_ADDR + 0x100 ) |
#define  | GPDMA_CH0_SRC   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x100 ) ) |
#define  | GPDMA_CH0_DEST   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x104 ) ) |
#define  | GPDMA_CH0_LLI   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x108 ) ) |
#define  | GPDMA_CH0_CTRL   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x10C ) ) |
#define  | GPDMA_CH0_CFG   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x110 ) ) |
#define  | GPDMA_CH1_BASE_ADDR   ( DMA_BASE_ADDR + 0x120 ) |
#define  | GPDMA_CH1_SRC   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x120 ) ) |
#define  | GPDMA_CH1_DEST   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x124 ) ) |
#define  | GPDMA_CH1_LLI   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x128 ) ) |
#define  | GPDMA_CH1_CTRL   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x12C ) ) |
#define  | GPDMA_CH1_CFG   ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x130 ) ) |
#define  | USB_INT_BASE_ADDR   0x400fc1c0 |
#define  | USB_BASE_ADDR   0x2008c200 |
#define  | USB_INT_STAT   ( *(volatile uint32_t *) ( USB_INT_BASE_ADDR + 0x00 ) ) |
#define  | DEV_INT_STAT   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x00 ) ) |
#define  | DEV_INT_EN   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x04 ) ) |
#define  | DEV_INT_CLR   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x08 ) ) |
#define  | DEV_INT_SET   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x0C ) ) |
#define  | DEV_INT_PRIO   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x2C ) ) |
#define  | EP_INT_STAT   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x30 ) ) |
#define  | EP_INT_EN   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x34 ) ) |
#define  | EP_INT_CLR   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x38 ) ) |
#define  | EP_INT_SET   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x3C ) ) |
#define  | EP_INT_PRIO   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x40 ) ) |
#define  | REALIZE_EP   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x44 ) ) |
#define  | EP_INDEX   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x48 ) ) |
#define  | MAXPACKET_SIZE   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x4C ) ) |
#define  | CMD_CODE   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x10 ) ) |
#define  | CMD_DATA   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x14 ) ) |
#define  | RX_DATA   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x18 ) ) |
#define  | TX_DATA   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x1C ) ) |
#define  | RX_PLENGTH   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x20 ) ) |
#define  | TX_PLENGTH   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x24 ) ) |
#define  | USB_CTRL   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x28 ) ) |
#define  | DMA_REQ_STAT   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x50 ) ) |
#define  | DMA_REQ_CLR   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x54 ) ) |
#define  | DMA_REQ_SET   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x58 ) ) |
#define  | UDCA_HEAD   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x80 ) ) |
#define  | EP_DMA_STAT   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x84 ) ) |
#define  | EP_DMA_EN   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x88 ) ) |
#define  | EP_DMA_DIS   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x8C ) ) |
#define  | DMA_INT_STAT   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x90 ) ) |
#define  | DMA_INT_EN   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x94 ) ) |
#define  | EOT_INT_STAT   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA0 ) ) |
#define  | EOT_INT_CLR   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA4 ) ) |
#define  | EOT_INT_SET   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA8 ) ) |
#define  | NDD_REQ_INT_STAT   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xAC ) ) |
#define  | NDD_REQ_INT_CLR   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB0 ) ) |
#define  | NDD_REQ_INT_SET   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB4 ) ) |
#define  | SYS_ERR_INT_STAT   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB8 ) ) |
#define  | SYS_ERR_INT_CLR   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xBC ) ) |
#define  | SYS_ERR_INT_SET   ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xC0 ) ) |
#define  | USBHC_BASE_ADDR   0x2008c000 |
#define  | HC_REVISION   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x00 ) ) |
#define  | HC_CONTROL   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x04 ) ) |
#define  | HC_CMD_STAT   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x08 ) ) |
#define  | HC_INT_STAT   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x0C ) ) |
#define  | HC_INT_EN   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x10 ) ) |
#define  | HC_INT_DIS   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x14 ) ) |
#define  | HC_HCCA   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x18 ) ) |
#define  | HC_PERIOD_CUR_ED   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x1C ) ) |
#define  | HC_CTRL_HEAD_ED   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x20 ) ) |
#define  | HC_CTRL_CUR_ED   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x24 ) ) |
#define  | HC_BULK_HEAD_ED   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x28 ) ) |
#define  | HC_BULK_CUR_ED   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x2C ) ) |
#define  | HC_DONE_HEAD   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x30 ) ) |
#define  | HC_FM_INTERVAL   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x34 ) ) |
#define  | HC_FM_REMAINING   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x38 ) ) |
#define  | HC_FM_NUMBER   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x3C ) ) |
#define  | HC_PERIOD_START   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x40 ) ) |
#define  | HC_LS_THRHLD   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x44 ) ) |
#define  | HC_RH_DESCA   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x48 ) ) |
#define  | HC_RH_DESCB   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x4C ) ) |
#define  | HC_RH_STAT   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x50 ) ) |
#define  | HC_RH_PORT_STAT1   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x54 ) ) |
#define  | HC_RH_PORT_STAT2   ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x58 ) ) |
#define  | USBOTG_BASE_ADDR   0x2008c100 |
#define  | OTG_INT_STAT   ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x00 ) ) |
#define  | OTG_INT_EN   ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x04 ) ) |
#define  | OTG_INT_SET   ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x08 ) ) |
#define  | OTG_INT_CLR   ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x0C ) ) |
#define  | OTG_STAT_CTRL   ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x10 ) ) |
#define  | OTG_TIMER   ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x14 ) ) |
#define  | USBOTG_I2C_BASE_ADDR   0x2008c300 |
#define  | OTG_I2C_RX   ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x00 ) ) |
#define  | OTG_I2C_TX   ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x00 ) ) |
#define  | OTG_I2C_STS   ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x04 ) ) |
#define  | OTG_I2C_CTL   ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x08 ) ) |
| #define  | OTG_I2C_CLKHI |
| #define  | OTG_I2C_CLKLO |
#define  | USBOTG_CLK_BASE_ADDR   0x2008CFF0U |
| #define  | OTG_CLK_CTRL |
| #define  | OTG_CLK_STAT |
#define  | GET_FIELD(val,  mask,  shift)   ( ( ( val ) & ( mask ) ) >> ( shift ) ) |
#define  | SET_FIELD(val,  field,  mask,  shift)   ( ( ( val ) & ~( mask ) ) | ( ( ( field ) << ( shift ) ) & ( mask ) ) ) |
#define  | CLKSRCSEL_CLKSRC_MASK   0x00000003U |
#define  | GET_CLKSRCSEL_CLKSRC(reg)   GET_FIELD( reg, CLKSRCSEL_CLKSRC_MASK, 0 ) |
#define  | SET_CLKSRCSEL_CLKSRC(reg,  val)   SET_FIELD( reg, val, CLKSRCSEL_CLKSRC_MASK, 0 ) |
#define  | PLLCON_PLLE   0x00000001U |
#define  | PLLCON_PLLC   0x00000002U |
#define  | PLLCFG_MSEL_MASK   0x00007fffU |
#define  | GET_PLLCFG_MSEL(reg)   GET_FIELD( reg, PLLCFG_MSEL_MASK, 0 ) |
#define  | SET_PLLCFG_MSEL(reg,  val)   SET_FIELD( reg, val, PLLCFG_MSEL_MASK, 0 ) |
#define  | PLLCFG_NSEL_MASK   0x00ff0000U |
#define  | GET_PLLCFG_NSEL(reg)   GET_FIELD( reg, PLLCFG_NSEL_MASK, 16 ) |
#define  | SET_PLLCFG_NSEL(reg,  val)   SET_FIELD( reg, val, PLLCFG_NSEL_MASK, 16 ) |
#define  | PLLSTAT_MSEL_MASK   0x00007fffU |
#define  | GET_PLLSTAT_MSEL(reg)   GET_FIELD( reg, PLLSTAT_MSEL_MASK, 0 ) |
#define  | SET_PLLSTAT_MSEL(reg,  val)   SET_FIELD( reg, val, PLLSTAT_MSEL_MASK, 0 ) |
#define  | PLLSTAT_NSEL_MASK   0x00ff0000U |
#define  | GET_PLLSTAT_NSEL(reg)   GET_FIELD( reg, PLLSTAT_NSEL_MASK, 16 ) |
#define  | SET_PLLSTAT_NSEL(reg,  val)   SET_FIELD( reg, val, PLLSTAT_NSEL_MASK, 16 ) |
#define  | PLLSTAT_PLLE   0x01000000U |
#define  | PLLSTAT_PLLC   0x02000000U |
#define  | PLLSTAT_PLOCK   0x04000000U |
#define  | CCLKCFG_CCLKSEL_MASK   0x000000ffU |
#define  | GET_CCLKCFG_CCLKSEL(reg)   GET_FIELD( reg, CCLKCFG_CCLKSEL_MASK, 0 ) |
#define  | SET_CCLKCFG_CCLKSEL(reg,  val)   SET_FIELD( reg, val, CCLKCFG_CCLKSEL_MASK, 0 ) |
#define  | MEMMAP_MAP_MASK   0x00000003U |
#define  | GET_MEMMAP_MAP(reg)   GET_FIELD( reg, MEMMAP_MAP_MASK, 0 ) |
#define  | SET_MEMMAP_MAP(reg,  val)   SET_FIELD( reg, val, MEMMAP_MAP_MASK, 0 ) |
#define  | TIR_MR0   0x00000001U |
#define  | TIR_MR1   0x00000002U |
#define  | TIR_MR2   0x00000004U |
#define  | TIR_MR3   0x00000008U |
#define  | TIR_CR0   0x00000010U |
#define  | TIR_CR1   0x00000020U |
#define  | TIR_CR2   0x00000040U |
#define  | TIR_CR3   0x00000080U |
#define  | TCR_EN   0x00000001U |
#define  | TCR_RST   0x00000002U |
#define  | TMCR_MR0I   0x00000001U |
#define  | TMCR_MR0R   0x00000002U |
#define  | TMCR_MR0S   0x00000004U |
#define  | TMCR_MR1I   0x00000008U |
#define  | TMCR_MR1R   0x00000010U |
#define  | TMCR_MR1S   0x00000020U |
#define  | TMCR_MR2I   0x00000040U |
#define  | TMCR_MR2R   0x00000080U |
#define  | TMCR_MR2S   0x00000100U |
#define  | TMCR_MR3I   0x00000200U |
#define  | TMCR_MR3R   0x00000400U |
#define  | TMCR_MR3S   0x00000800U |
#define  | PCLKSEL0_PCLK_WDT_MASK   0x00000003U |
#define  | GET_PCLKSEL0_PCLK_WDT(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_WDT_MASK, 0 ) |
#define  | SET_PCLKSEL0_PCLK_WDT(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_WDT_MASK, 0 ) |
#define  | PCLKSEL0_PCLK_TIMER0_MASK   0x0000000cU |
#define  | GET_PCLKSEL0_PCLK_TIMER0(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_TIMER0_MASK, 2 ) |
#define  | SET_PCLKSEL0_PCLK_TIMER0(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_TIMER0_MASK, 2 ) |
#define  | PCLKSEL0_PCLK_TIMER1_MASK   0x00000030U |
#define  | GET_PCLKSEL0_PCLK_TIMER1(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_TIMER1_MASK, 4 ) |
#define  | SET_PCLKSEL0_PCLK_TIMER1(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_TIMER1_MASK, 4 ) |
#define  | PCLKSEL0_PCLK_UART0_MASK   0x000000c0U |
#define  | GET_PCLKSEL0_PCLK_UART0(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_UART0_MASK, 6 ) |
#define  | SET_PCLKSEL0_PCLK_UART0(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_UART0_MASK, 6 ) |
#define  | PCLKSEL0_PCLK_UART1_MASK   0x00000300U |
#define  | GET_PCLKSEL0_PCLK_UART1(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_UART1_MASK, 8 ) |
#define  | SET_PCLKSEL0_PCLK_UART1(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_UART1_MASK, 8 ) |
#define  | PCLKSEL0_PCLK_PWM0_MASK   0x00000c00U |
#define  | GET_PCLKSEL0_PCLK_PWM0(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_PWM0_MASK, 10 ) |
#define  | SET_PCLKSEL0_PCLK_PWM0(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_PWM0_MASK, 10 ) |
#define  | PCLKSEL0_PCLK_PWM1_MASK   0x00003000U |
#define  | GET_PCLKSEL0_PCLK_PWM1(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_PWM1_MASK, 12 ) |
#define  | SET_PCLKSEL0_PCLK_PWM1(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_PWM1_MASK, 12 ) |
#define  | PCLKSEL0_PCLK_I2C0_MASK   0x0000c000U |
#define  | GET_PCLKSEL0_PCLK_I2C0(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_I2C0_MASK, 14 ) |
#define  | SET_PCLKSEL0_PCLK_I2C0(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_I2C0_MASK, 14 ) |
#define  | PCLKSEL0_PCLK_SPI_MASK   0x00030000U |
#define  | GET_PCLKSEL0_PCLK_SPI(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_SPI_MASK, 16 ) |
#define  | SET_PCLKSEL0_PCLK_SPI(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_SPI_MASK, 16 ) |
#define  | PCLKSEL0_PCLK_RTC_MASK   0x000c0000U |
#define  | GET_PCLKSEL0_PCLK_RTC(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_RTC_MASK, 18 ) |
#define  | SET_PCLKSEL0_PCLK_RTC(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_RTC_MASK, 18 ) |
#define  | PCLKSEL0_PCLK_SSP1_MASK   0x00300000U |
#define  | GET_PCLKSEL0_PCLK_SSP1(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_SSP1_MASK, 20 ) |
#define  | SET_PCLKSEL0_PCLK_SSP1(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_SSP1_MASK, 20 ) |
#define  | PCLKSEL0_PCLK_DAC_MASK   0x00c00000U |
#define  | GET_PCLKSEL0_PCLK_DAC(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_DAC_MASK, 22 ) |
#define  | SET_PCLKSEL0_PCLK_DAC(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_DAC_MASK, 22 ) |
#define  | PCLKSEL0_PCLK_ADC_MASK   0x03000000U |
#define  | GET_PCLKSEL0_PCLK_ADC(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_ADC_MASK, 24 ) |
#define  | SET_PCLKSEL0_PCLK_ADC(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_ADC_MASK, 24 ) |
#define  | PCLKSEL0_PCLK_CAN1_MASK   0x0c000000U |
#define  | GET_PCLKSEL0_PCLK_CAN1(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_CAN1_MASK, 26 ) |
#define  | SET_PCLKSEL0_PCLK_CAN1(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_CAN1_MASK, 26 ) |
#define  | PCLKSEL0_PCLK_CAN2_MASK   0x30000000U |
#define  | GET_PCLKSEL0_PCLK_CAN2(reg)   GET_FIELD( reg, PCLKSEL0_PCLK_CAN2_MASK, 28 ) |
#define  | SET_PCLKSEL0_PCLK_CAN2(reg,  val)   SET_FIELD( reg, val, PCLKSEL0_PCLK_CAN2_MASK, 28 ) |
#define  | PCLKSEL1_PCLK_BAT_RAM_MASK   0x00000003U |
#define  | GET_PCLKSEL1_PCLK_BAT_RAM(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_BAT_RAM_MASK, 0 ) |
#define  | SET_PCLKSEL1_PCLK_BAT_RAM(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_BAT_RAM_MASK, 0 ) |
#define  | PCLKSEL1_PCLK_GPIO_MASK   0x0000000cU |
#define  | GET_PCLKSEL1_PCLK_GPIO(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_GPIO_MASK, 2 ) |
#define  | SET_PCLKSEL1_PCLK_GPIO(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_GPIO_MASK, 2 ) |
#define  | PCLKSEL1_PCLK_PCB_MASK   0x00000030U |
#define  | GET_PCLKSEL1_PCLK_PCB(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_PCB_MASK, 4 ) |
#define  | SET_PCLKSEL1_PCLK_PCB(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_PCB_MASK, 4 ) |
#define  | PCLKSEL1_PCLK_I2C1_MASK   0x000000c0U |
#define  | GET_PCLKSEL1_PCLK_I2C1(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_I2C1_MASK, 6 ) |
#define  | SET_PCLKSEL1_PCLK_I2C1(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_I2C1_MASK, 6 ) |
#define  | PCLKSEL1_PCLK_SSP0_MASK   0x00000c00U |
#define  | GET_PCLKSEL1_PCLK_SSP0(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_SSP0_MASK, 10 ) |
#define  | SET_PCLKSEL1_PCLK_SSP0(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_SSP0_MASK, 10 ) |
#define  | PCLKSEL1_PCLK_TIMER2_MASK   0x00003000U |
#define  | GET_PCLKSEL1_PCLK_TIMER2(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_TIMER2_MASK, 12 ) |
#define  | SET_PCLKSEL1_PCLK_TIMER2(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_TIMER2_MASK, 12 ) |
#define  | PCLKSEL1_PCLK_TIMER3_MASK   0x0000c000U |
#define  | GET_PCLKSEL1_PCLK_TIMER3(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_TIMER3_MASK, 14 ) |
#define  | SET_PCLKSEL1_PCLK_TIMER3(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_TIMER3_MASK, 14 ) |
#define  | PCLKSEL1_PCLK_UART2_MASK   0x00030000U |
#define  | GET_PCLKSEL1_PCLK_UART2(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_UART2_MASK, 16 ) |
#define  | SET_PCLKSEL1_PCLK_UART2(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_UART2_MASK, 16 ) |
#define  | PCLKSEL1_PCLK_UART3_MASK   0x000c0000U |
#define  | GET_PCLKSEL1_PCLK_UART3(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_UART3_MASK, 18 ) |
#define  | SET_PCLKSEL1_PCLK_UART3(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_UART3_MASK, 18 ) |
#define  | PCLKSEL1_PCLK_I2C2_MASK   0x00300000U |
#define  | GET_PCLKSEL1_PCLK_I2C2(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_I2C2_MASK, 20 ) |
#define  | SET_PCLKSEL1_PCLK_I2C2(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_I2C2_MASK, 20 ) |
#define  | PCLKSEL1_PCLK_I2S_MASK   0x00c00000U |
#define  | GET_PCLKSEL1_PCLK_I2S(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_I2S_MASK, 22 ) |
#define  | SET_PCLKSEL1_PCLK_I2S(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_I2S_MASK, 22 ) |
#define  | PCLKSEL1_PCLK_MCI_MASK   0x03000000U |
#define  | GET_PCLKSEL1_PCLK_MCI(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_MCI_MASK, 24 ) |
#define  | SET_PCLKSEL1_PCLK_MCI(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_MCI_MASK, 24 ) |
#define  | PCLKSEL1_PCLK_SYSCON_MASK   0x30000000U |
#define  | GET_PCLKSEL1_PCLK_SYSCON(reg)   GET_FIELD( reg, PCLKSEL1_PCLK_SYSCON_MASK, 28 ) |
#define  | SET_PCLKSEL1_PCLK_SYSCON(reg,  val)   SET_FIELD( reg, val, PCLKSEL1_PCLK_SYSCON_MASK, 28 ) |
#define  | RTC_ILR_RTCCIF   0x00000001U |
#define  | RTC_ILR_RTCALF   0x00000002U |
#define  | RTC_ILR_RTSSF   0x00000004U |
#define  | RTC_CCR_CLKEN   0x00000001U |
#define  | RTC_CCR_CTCRST   0x00000002U |
#define  | RTC_CCR_CLKSRC   0x00000010U |
#define  | GPDMA_CH_NUMBER   2 |
#define  | GPDMA_STATUS_CH_0   0x00000001U |
#define  | GPDMA_STATUS_CH_1   0x00000002U |
| #define  | GPDMA_CH_BASE_ADDR(i) |
#define  | GPDMA_CONFIG_EN   0x00000001U |
#define  | GPDMA_CONFIG_MODE   0x00000002U |
#define  | GPDMA_ENABLED_CHNS_CH0   0x00000001U |
#define  | GPDMA_ENABLED_CHNS_CH1   0x00000002U |
#define  | GPDMA_CH_CTRL_TSZ_MASK   0x00000fffU |
#define  | GET_GPDMA_CH_CTRL_TSZ(reg)   GET_FIELD( reg, GPDMA_CH_CTRL_TSZ_MASK, 0 ) |
#define  | SET_GPDMA_CH_CTRL_TSZ(reg,  val)   SET_FIELD( reg, val, GPDMA_CH_CTRL_TSZ_MASK, 0 ) |
#define  | GPDMA_CH_CTRL_TSZ_MAX   0x00000fffU |
#define  | GPDMA_CH_CTRL_SBSZ_MASK   0x00007000U |
#define  | GET_GPDMA_CH_CTRL_SBSZ(reg)   GET_FIELD( reg, GPDMA_CH_CTRL_SBSZ_MASK, 12 ) |
#define  | SET_GPDMA_CH_CTRL_SBSZ(reg,  val)   SET_FIELD( reg, val, GPDMA_CH_CTRL_SBSZ_MASK, 12 ) |
#define  | GPDMA_CH_CTRL_DBSZ_MASK   0x00038000U |
#define  | GET_GPDMA_CH_CTRL_DBSZ(reg)   GET_FIELD( reg, GPDMA_CH_CTRL_DBSZ_MASK, 15 ) |
#define  | SET_GPDMA_CH_CTRL_DBSZ(reg,  val)   SET_FIELD( reg, val, GPDMA_CH_CTRL_DBSZ_MASK, 15 ) |
#define  | GPDMA_CH_CTRL_BSZ_1   0x00000000U |
#define  | GPDMA_CH_CTRL_BSZ_4   0x00000001U |
#define  | GPDMA_CH_CTRL_BSZ_8   0x00000002U |
#define  | GPDMA_CH_CTRL_BSZ_16   0x00000003U |
#define  | GPDMA_CH_CTRL_BSZ_32   0x00000004U |
#define  | GPDMA_CH_CTRL_BSZ_64   0x00000005U |
#define  | GPDMA_CH_CTRL_BSZ_128   0x00000006U |
#define  | GPDMA_CH_CTRL_BSZ_256   0x00000007U |
#define  | GPDMA_CH_CTRL_SW_MASK   0x001c0000U |
#define  | GET_GPDMA_CH_CTRL_SW(reg)   GET_FIELD( reg, GPDMA_CH_CTRL_SW_MASK, 18 ) |
#define  | SET_GPDMA_CH_CTRL_SW(reg,  val)   SET_FIELD( reg, val, GPDMA_CH_CTRL_SW_MASK, 18 ) |
#define  | GPDMA_CH_CTRL_DW_MASK   0x00e00000U |
#define  | GET_GPDMA_CH_CTRL_DW(reg)   GET_FIELD( reg, GPDMA_CH_CTRL_DW_MASK, 21 ) |
#define  | SET_GPDMA_CH_CTRL_DW(reg,  val)   SET_FIELD( reg, val, GPDMA_CH_CTRL_DW_MASK, 21 ) |
#define  | GPDMA_CH_CTRL_W_8   0x00000000U |
#define  | GPDMA_CH_CTRL_W_16   0x00000001U |
#define  | GPDMA_CH_CTRL_W_32   0x00000002U |
#define  | GPDMA_CH_CTRL_SI   0x04000000U |
#define  | GPDMA_CH_CTRL_DI   0x08000000U |
#define  | GPDMA_CH_CTRL_PROT_MASK   0x70000000U |
#define  | GET_GPDMA_CH_CTRL_PROT(reg)   GET_FIELD( reg, GPDMA_CH_CTRL_PROT_MASK, 28 ) |
#define  | SET_GPDMA_CH_CTRL_PROT(reg,  val)   SET_FIELD( reg, val, GPDMA_CH_CTRL_PROT_MASK, 28 ) |
#define  | GPDMA_CH_CTRL_ITC   0x80000000U |
#define  | GPDMA_CH_CFG_EN   0x00000001U |
#define  | GPDMA_CH_CFG_SRCPER_MASK   0x0000001eU |
#define  | GET_GPDMA_CH_CFG_SRCPER(reg)   GET_FIELD( reg, GPDMA_CH_CFG_SRCPER_MASK, 1 ) |
#define  | SET_GPDMA_CH_CFG_SRCPER(reg,  val)   SET_FIELD( reg, val, GPDMA_CH_CFG_SRCPER_MASK, 1 ) |
#define  | GPDMA_CH_CFG_DESTPER_MASK   0x000003c0U |
#define  | GET_GPDMA_CH_CFG_DESTPER(reg)   GET_FIELD( reg, GPDMA_CH_CFG_DESTPER_MASK, 6 ) |
#define  | SET_GPDMA_CH_CFG_DESTPER(reg,  val)   SET_FIELD( reg, val, GPDMA_CH_CFG_DESTPER_MASK, 6 ) |
#define  | GPDMA_CH_CFG_PER_SSP0_TX   0x00000000U |
#define  | GPDMA_CH_CFG_PER_SSP0_RX   0x00000001U |
#define  | GPDMA_CH_CFG_PER_SSP1_TX   0x00000002U |
#define  | GPDMA_CH_CFG_PER_SSP1_RX   0x00000003U |
#define  | GPDMA_CH_CFG_PER_SD_MMC   0x00000004U |
#define  | GPDMA_CH_CFG_PER_I2S_CH0   0x00000005U |
#define  | GPDMA_CH_CFG_PER_I2S_CH1   0x00000006U |
#define  | GPDMA_CH_CFG_FLOW_MASK   0x00003800U |
#define  | GET_GPDMA_CH_CFG_FLOW(reg)   GET_FIELD( reg, GPDMA_CH_CFG_FLOW_MASK, 11 ) |
#define  | SET_GPDMA_CH_CFG_FLOW(reg,  val)   SET_FIELD( reg, val, GPDMA_CH_CFG_FLOW_MASK, 11 ) |
#define  | GPDMA_CH_CFG_FLOW_MEM_TO_MEM_DMA   0x00000000U |
#define  | GPDMA_CH_CFG_FLOW_MEM_TO_PER_DMA   0x00000001U |
#define  | GPDMA_CH_CFG_FLOW_PER_TO_MEM_DMA   0x00000002U |
#define  | GPDMA_CH_CFG_FLOW_PER_TO_PER_DMA   0x00000003U |
#define  | GPDMA_CH_CFG_FLOW_PER_TO_PER_DEST   0x00000004U |
#define  | GPDMA_CH_CFG_FLOW_MEM_TO_PER_PER   0x00000005U |
#define  | GPDMA_CH_CFG_FLOW_PER_TO_MEM_PER   0x00000006U |
#define  | GPDMA_CH_CFG_FLOW_PER_TO_PER_SRC   0x00000007U |
#define  | GPDMA_CH_CFG_IE   0x00004000U |
#define  | GPDMA_CH_CFG_ITC   0x00008000U |
#define  | GPDMA_CH_CFG_LOCK   0x00010000U |
#define  | GPDMA_CH_CFG_ACTIVE   0x00020000U |
#define  | GPDMA_CH_CFG_HALT   0x00040000U |
#define  | AHBCFG_SCHEDULER_UNIFORM   0x00000001U |
#define  | AHBCFG_BREAK_BURST_MASK   0x00000006U |
#define  | GET_AHBCFG_BREAK_BURST(reg)   GET_FIELD( reg, AHBCFG_BREAK_BURST_MASK, 1 ) |
#define  | SET_AHBCFG_BREAK_BURST(reg,  val)   SET_FIELD( reg, val, AHBCFG_BREAK_BURST_MASK, 1 ) |
#define  | AHBCFG_QUANTUM_BUS_CYCLE   0x00000008U |
#define  | AHBCFG_QUANTUM_SIZE_MASK   0x000000f0U |
#define  | GET_AHBCFG_QUANTUM_SIZE(reg)   GET_FIELD( reg, AHBCFG_QUANTUM_SIZE_MASK, 4 ) |
#define  | SET_AHBCFG_QUANTUM_SIZE(reg,  val)   SET_FIELD( reg, val, AHBCFG_QUANTUM_SIZE_MASK, 4 ) |
#define  | AHBCFG_DEFAULT_MASTER_MASK   0x00000700U |
#define  | GET_AHBCFG_DEFAULT_MASTER(reg)   GET_FIELD( reg, AHBCFG_DEFAULT_MASTER_MASK, 8 ) |
#define  | SET_AHBCFG_DEFAULT_MASTER(reg,  val)   SET_FIELD( reg, val, AHBCFG_DEFAULT_MASTER_MASK, 8 ) |
#define  | AHBCFG_EP1_MASK   0x00007000U |
#define  | GET_AHBCFG_EP1(reg)   GET_FIELD( reg, AHBCFG_EP1_MASK, 12 ) |
#define  | SET_AHBCFG_EP1(reg,  val)   SET_FIELD( reg, val, AHBCFG_EP1_MASK, 12 ) |
#define  | AHBCFG_EP2_MASK   0x00070000U |
#define  | GET_AHBCFG_EP2(reg)   GET_FIELD( reg, AHBCFG_EP2_MASK, 16 ) |
#define  | SET_AHBCFG_EP2(reg,  val)   SET_FIELD( reg, val, AHBCFG_EP2_MASK, 16 ) |
#define  | AHBCFG_EP3_MASK   0x00700000U |
#define  | GET_AHBCFG_EP3(reg)   GET_FIELD( reg, AHBCFG_EP3_MASK, 20 ) |
#define  | SET_AHBCFG_EP3(reg,  val)   SET_FIELD( reg, val, AHBCFG_EP3_MASK, 20 ) |
#define  | AHBCFG_EP4_MASK   0x07000000U |
#define  | GET_AHBCFG_EP4(reg)   GET_FIELD( reg, AHBCFG_EP4_MASK, 24 ) |
#define  | SET_AHBCFG_EP4(reg,  val)   SET_FIELD( reg, val, AHBCFG_EP4_MASK, 24 ) |
#define  | AHBCFG_EP5_MASK   0x70000000U |
#define  | GET_AHBCFG_EP5(reg)   GET_FIELD( reg, AHBCFG_EP5_MASK, 28 ) |
#define  | SET_AHBCFG_EP5(reg,  val)   SET_FIELD( reg, val, AHBCFG_EP5_MASK, 28 ) |
#define  | ADC_CR_SEL(val)   BSP_FLD32( val, 0, 7 ) |
#define  | ADC_CR_SEL_GET(val)   BSP_FLD32GET( val, 0, 7 ) |
#define  | ADC_CR_SEL_SET(reg,  val)   BSP_FLD32SET( reg, val, 0, 7 ) |
#define  | ADC_CR_CLKDIV(val)   BSP_FLD32( val, 8, 15 ) |
#define  | ADC_CR_CLKDIV_GET(reg)   BSP_FLD32GET( reg, 8, 15 ) |
#define  | ADC_CR_CLKDIV_SET(reg,  val)   BSP_FLD32SET( reg, val, 8, 15 ) |
#define  | ADC_CR_BURST   BSP_BIT32( 16 ) |
#define  | ADC_CR_CLKS(val)   BSP_FLD32( val, 17, 19 ) |
#define  | ADC_CR_PDN   BSP_BIT32( 21 ) |
#define  | ADC_CR_START(val)   BSP_FLD32( val, 24, 26 ) |
#define  | ADC_CR_EDGE   BSP_BIT32( 27 ) |
#define  | ADC_DR_VALUE(reg)   BSP_FLD32GET( reg, 6, 15 ) |
#define  | ADC_DR_OVERRUN   BSP_BIT32( 30 ) |
#define  | ADC_DR_DONE   BSP_BIT32( 31 ) |
#define  | DAC_STEPS   1024 |
#define  | DAC_VALUE(val)   BSP_FLD32( val, 6, 15 ) |
#define  | DAC_BIAS   BSP_BIT32( 16 ) |
