    RTEMS
    5.1
System Control Block representation. More...
#include <lpc176x.h>
Data Fields | |
| uint32_t | flashcfg |
| Flash Accelerator Configuration Register.  | |
| uint32_t | reserved_04 [15] |
| uint32_t | memmap |
| Memopry Map Control.  | |
| uint32_t | reserved_44 [15] |
| lpc176x_pll | pll_0 |
| Phase-Locked Loop 0.  | |
| uint32_t | reserved_90 [4] |
| lpc176x_pll | pll_1 |
| Phase-Locked Loop 1.  | |
| uint32_t | reserved_b0 [4] |
| uint32_t | pcon |
| Power Mode Control register.  | |
| uint32_t | pconp |
| Power Control for Peripherals register.  | |
| uint32_t | reserved_c8 [15] |
| uint32_t | cclksel |
| Selects the divide valuefor creating the CPU clock from the PPL0 output.  | |
| uint32_t | usbclksel |
| Selects the divide value for creating the USB clock from the PPL0 output.  | |
| uint32_t | clksrcsel |
| Clock Source Select register.  | |
| uint32_t | reserved_110 [12] |
| uint32_t | extint |
| External Interrupt flag register.  | |
| uint32_t | reserved_144 |
| uint32_t | extmode |
| External Interrupt Mode register.  | |
| uint32_t | extpolar |
| External Interrupt Polarity register.  | |
| uint32_t | reserved_150 [12] |
| uint32_t | rsid |
| Reset Source Identification Register.  | |
| uint32_t | reserved_184 [7] |
| uint32_t | scs |
| System Controls and Status Register.  | |
| uint32_t | reserved_1a4 |
| uint32_t | pclksel [2] |
| Peripheral Clock Selection registers 0 and 1.  | |
| uint32_t | pboost |
| Peripheral boost.  | |
| uint32_t | reserved_1b4 [5] |
| uint32_t | clkoutcfg |
| Clock Output Configuration Register.  | |
| uint32_t | rstcon [2] |
| Reset Control bit 0 and 1.  | |
| uint32_t | reserved_1d4 [4] |
 1.8.15
