22 #ifndef LIBBSP_ARM_LPC176X_H    23 #define LIBBSP_ARM_LPC176X_H    27 #define LPC176X_PLL_CON_PLLE BSP_BIT32( 0 )    28 #define LPC176X_PLL_CON_PLLC BSP_BIT32( 1 )    29 #define LPC176X_PLL_SEL_MSEL( val ) BSP_FLD32( val, 0, 14 )    30 #define LPC176X_PLL_SEL_MSEL_GET( reg ) BSP_FLD32GET( reg, 0, 14 )    31 #define LPC176X_PLL_SEL_MSEL_SET( reg, val ) BSP_FLD32SET( reg, val, 0, 14 )    32 #define LPC176X_PLL_SEL_PSEL( val ) BSP_FLD32( val, 16, 23 )    33 #define LPC176X_PLL_SEL_PSEL_GET( reg ) BSP_FLD32GET( reg, 16, 23 )    34 #define LPC176X_PLL_SEL_PSEL_SET( reg, val ) BSP_FLD32SET( reg, val, 16, 23 )    35 #define LPC176X_PLL_STAT_PLLE BSP_BIT32( 24 )    36 #define LPC176X_PLL_STAT_PLLC BSP_BIT32( 25 )    37 #define LPC176X_PLL_STAT_PLOCK BSP_BIT32( 26 )    61 #define LPC176X_SCB_BASE_ADDR 0x400FC000U    62 #define LPC176X_SCB_FLASHCFG_FLASHTIM( val ) BSP_FLD32( val, 12, 15 )    63 #define LPC176X_SCB_FLASHCFG_FLASHTIM_GET( reg ) BSP_FLD32GET( reg, 12, 15 )    64 #define LPC176X_SCB_FLASHCFG_FLASHTIM_SET( reg, val ) BSP_FLD32SET( reg, val, \    66 #define LPC176X_SCB_MEMMAP_MAP BSP_BIT32( 0 )    69 #define LPC176X_SCB_PCON_PM0 BSP_BIT32( 0 )    71 #define LPC176X_SCB_PCON_PM1 BSP_BIT32( 1 )    73 #define LPC176X_SCB_PCON_BODRPM BSP_BIT32( 2 )    75 #define LPC176X_SCB_PCON_BOGD BSP_BIT32( 3 )    77 #define LPC176X_SCB_PCON_BORD BSP_BIT32( 4 )    79 #define LPC176X_SCB_PCON_SMFLAG BSP_BIT32( 8 )    81 #define LPC176X_SCB_PCON_DSFLAG BSP_BIT32( 9 )    83 #define LPC176X_SCB_PCON_PDFLAG BSP_BIT32( 10 )    85 #define LPC176X_SCB_PCON_DPDFLAG BSP_BIT32( 11 )    89 #define LPC176X_SCB_PCONP_TIMER_0 BSP_BIT32( 1 )    91 #define LPC176X_SCB_PCONP_TIMER_1 BSP_BIT32( 2 )    93 #define LPC176X_SCB_PCONP_UART_0 BSP_BIT32( 3 )    95 #define LPC176X_SCB_PCONP_UART_1 BSP_BIT32( 4 )    98 #define LPC176X_SCB_PCONP_PWM_0 BSP_BIT32( 6 )   100 #define LPC176X_SCB_PCONP_I2C_0 BSP_BIT32( 7 )   102 #define LPC176X_SCB_PCONP_SPI BSP_BIT32( 8 )   104 #define LPC176X_SCB_PCONP_RTC BSP_BIT32( 9 )   106 #define LPC176X_SCB_PCONP_SSP_1 BSP_BIT32( 10 )   109 #define LPC176X_SCB_PCONP_ADC BSP_BIT32( 12 )   111 #define LPC176X_SCB_PCONP_CAN_1 BSP_BIT32( 13 )   113 #define LPC176X_SCB_PCONP_CAN_2 BSP_BIT32( 14 )   115 #define LPC176X_SCB_PCONP_GPIO BSP_BIT32( 15 )   117 #define LPC176X_SCB_PCONP_RIT BSP_BIT32( 16 )   119 #define LPC176X_SCB_PCONP_MCPWM BSP_BIT32( 17 )   121 #define LPC176X_SCB_PCONP_QEI BSP_BIT32( 18 )   123 #define LPC176X_SCB_PCONP_I2C_1 BSP_BIT32( 19 )   126 #define LPC176X_SCB_PCONP_SSP_0 BSP_BIT32( 21 )   128 #define LPC176X_SCB_PCONP_TIMER_2 BSP_BIT32( 22 )   130 #define LPC176X_SCB_PCONP_TIMER_3 BSP_BIT32( 23 )   132 #define LPC176X_SCB_PCONP_UART_2 BSP_BIT32( 24 )   134 #define LPC176X_SCB_PCONP_UART_3 BSP_BIT32( 25 )   136 #define LPC176X_SCB_PCONP_I2C_2 BSP_BIT32( 26 )   138 #define LPC176X_SCB_PCONP_I2S BSP_BIT32( 27 )   141 #define LPC176X_SCB_PCONP_GPDMA BSP_BIT32( 29 )   143 #define LPC176X_SCB_PCONP_ENET BSP_BIT32( 30 )   145 #define LPC176X_SCB_PCONP_USB BSP_BIT32( 31 )   146 #define LPC176X_SCB_CCLKSEL_CCLKDIV( val ) BSP_FLD32( val, 0, 7 )   147 #define LPC176X_SCB_CCLKSEL_CCLKDIV_GET( reg ) BSP_FLD32GET( reg, 0, 7 )   148 #define LPC176X_SCB_CCLKSEL_CCLKDIV_SET( reg, val ) BSP_FLD32SET( reg, \   152 #define LPC176X_SCB_CCLKSEL_CCLKSEL BSP_BIT32( 8 )   153 #define LPC176X_SCB_USBCLKSEL_USBDIV( val ) BSP_FLD32( val, 0, 4 )   154 #define LPC176X_SCB_USBCLKSEL_USBDIV_GET( reg ) BSP_FLD32GET( reg, 0, 4 )   155 #define LPC176X_SCB_USBCLKSEL_USBDIV_SET( reg, val ) BSP_FLD32SET( reg, \   159 #define LPC176X_SCB_USBCLKSEL_USBSEL( val ) BSP_FLD32( val, 8, 9 )   160 #define LPC176X_SCB_USBCLKSEL_USBSEL_GET( reg ) BSP_FLD32GET( reg, 8, 9 )   161 #define LPC176X_SCB_USBCLKSEL_USBSEL_SET( reg, val ) BSP_FLD32SET( reg, \   165 #define LPC176X_SCB_CLKSRCSEL_CLKSRC BSP_BIT32( 0 )   166 #define LPC176X_SCB_SCS_MCIPWR BSP_BIT32( 3 )   167 #define LPC176X_SCB_SCS_OSC_RANGE_SEL BSP_BIT32( 4 )   168 #define LPC176X_SCB_SCS_OSC_ENABLE BSP_BIT32( 5 )   169 #define LPC176X_SCB_SCS_OSC_STATUS BSP_BIT32( 6 )   170 #define LPC176X_SCB_PCLKSEL_PCLKDIV( val ) BSP_FLD32( val, 0, 4 )   171 #define LPC176X_SCB_PCLKSEL_PCLKDIV_GET( reg ) BSP_FLD32GET( reg, 0, 4 )   172 #define LPC176X_SCB_PCLKSEL_PCLKDIV_SET( reg, val ) BSP_FLD32SET( reg, \   176 #define LPC176X_SCB_PBOOST_BOOST BSP_BIT32( 0 )   177 #define LPC176X_SCB_CLKOUTCFG_CLKOUTSEL( val ) BSP_FLD32( val, 3, 0 )   178 #define LPC176X_SCB_CLKOUTCFG_CLKOUTSEL_GET( reg ) BSP_FLD32GET( reg, 3, 0 )   179 #define LPC176X_SCB_CLKOUTCFG_CLKOUTSEL_SET( reg, val ) BSP_FLD32SET( reg, \   181 #define LPC176X_SCB_CLKOUTCFG_CLKOUTDIV( val ) BSP_FLD32( val, 7, 4 )   182 #define LPC176X_SCB_CLKOUTCFG_CLKOUTDIV_GET( reg ) BSP_FLD32GET( reg, 7, 4 )   183 #define LPC176X_SCB_CLKOUTCFG_CLKOUTDIV_SET( reg, val ) BSP_FLD32SET( reg, \   185 #define LPC176X_SCB_CLKOUTCFG_CLKOUT_EN BSP_BIT32( 8 )   186 #define LPC176X_SCB_CLKOUTCFG_CLKOUT_ACT BSP_BIT32( 9 )   196   uint32_t reserved_04[ 15 ];
   201   uint32_t reserved_44[ 15 ];
   206   uint32_t reserved_90[ 4 ];
   211   uint32_t reserved_b0[ 4 ];
   220   uint32_t reserved_c8[ 15 ];
   235   uint32_t reserved_110[ 12 ];
   240   uint32_t reserved_144;
   249   uint32_t reserved_150[ 12 ];
   254   uint32_t reserved_184[ 7 ];
   259   uint32_t reserved_1a4;
   263   uint32_t pclksel[ 2 ];
   268   uint32_t reserved_1b4[ 5 ];
   276   uint32_t rstcon[ 2 ];
   277   uint32_t reserved_1d4[ 4 ];
   280 #define LPC176X_BASE 0x00u   281 #define LPC176X_SCB ( *(volatile lpc176x_scb *) ( LPC176X_SCB_BASE_ADDR ) )   284 #define LPC176X_FIO_BASE_ADDR 0x2009C000U   285 #define LPC176X_FIO ( (volatile lpc176x_fio *) LPC176X_FIO_BASE_ADDR )   287 #define FIO0DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) )   288 #define FIO0MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) )   289 #define FIO0PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) )   290 #define FIO0SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) )   291 #define FIO0CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) )   293 #define FIO1DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) )   294 #define FIO1MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) )   295 #define FIO1PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) )   296 #define FIO1SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) )   297 #define FIO1CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) )   299 #define FIO2DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) )   300 #define FIO2MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) )   301 #define FIO2PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) )   302 #define FIO2SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) )   303 #define FIO2CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) )   305 #define FIO3DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) )   306 #define FIO3MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) )   307 #define FIO3PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) )   308 #define FIO3SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) )   309 #define FIO3CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) )   311 #define FIO4DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) )   312 #define FIO4MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) )   313 #define FIO4PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) )   314 #define FIO4SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) )   315 #define FIO4CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) )   318 #define FIO0DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) )   319 #define FIO1DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) )   320 #define FIO2DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) )   321 #define FIO3DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) )   322 #define FIO4DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) )   324 #define FIO0DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x01U ) )   325 #define FIO1DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x21U ) )   326 #define FIO2DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x41U ) )   327 #define FIO3DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x61U ) )   328 #define FIO4DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x81U ) )   330 #define FIO0DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x02U ) )   331 #define FIO1DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x22U ) )   332 #define FIO2DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x42U ) )   333 #define FIO3DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x62U ) )   334 #define FIO4DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x82U ) )   336 #define FIO0DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x03U ) )   337 #define FIO1DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x23U ) )   338 #define FIO2DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x43U ) )   339 #define FIO3DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x63U ) )   340 #define FIO4DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x83U ) )   342 #define FIO0DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) )   343 #define FIO1DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) )   344 #define FIO2DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) )   345 #define FIO3DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) )   346 #define FIO4DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) )   348 #define FIO0DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x02U ) )   349 #define FIO1DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x22U ) )   350 #define FIO2DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x42U ) )   351 #define FIO3DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x62U ) )   352 #define FIO4DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x82U ) )   354 #define FIO0MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) )   355 #define FIO1MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) )   356 #define FIO2MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) )   357 #define FIO3MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) )   358 #define FIO4MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) )   360 #define FIO0MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x11U ) )   361 #define FIO1MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x21U ) )   362 #define FIO2MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x51U ) )   363 #define FIO3MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x71U ) )   364 #define FIO4MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x91U ) )   366 #define FIO0MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x12U ) )   367 #define FIO1MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x32U ) )   368 #define FIO2MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x52U ) )   369 #define FIO3MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x72U ) )   370 #define FIO4MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x92U ) )   372 #define FIO0MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x13U ) )   373 #define FIO1MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x33U ) )   374 #define FIO2MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x53U ) )   375 #define FIO3MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x73U ) )   376 #define FIO4MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x93U ) )   378 #define FIO0MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) )   379 #define FIO1MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) )   380 #define FIO2MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) )   381 #define FIO3MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) )   382 #define FIO4MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) )   384 #define FIO0MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x12U ) )   385 #define FIO1MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x32U ) )   386 #define FIO2MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x52U ) )   387 #define FIO3MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x72U ) )   388 #define FIO4MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x92U ) )   390 #define FIO0PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) )   391 #define FIO1PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) )   392 #define FIO2PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) )   393 #define FIO3PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) )   394 #define FIO4PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) )   396 #define FIO0PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x15U ) )   397 #define FIO1PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x25U ) )   398 #define FIO2PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x55U ) )   399 #define FIO3PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x75U ) )   400 #define FIO4PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x95U ) )   402 #define FIO0PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x16U ) )   403 #define FIO1PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x36U ) )   404 #define FIO2PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x56U ) )   405 #define FIO3PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x76U ) )   406 #define FIO4PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x96U ) )   408 #define FIO0PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x17U ) )   409 #define FIO1PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x37U ) )   410 #define FIO2PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x57U ) )   411 #define FIO3PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x77U ) )   412 #define FIO4PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x97U ) )   414 #define FIO0PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) )   415 #define FIO1PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) )   416 #define FIO2PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) )   417 #define FIO3PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) )   418 #define FIO4PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) )   420 #define FIO0PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x16U ) )   421 #define FIO1PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x36U ) )   422 #define FIO2PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x56U ) )   423 #define FIO3PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x76U ) )   424 #define FIO4PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x96U ) )   426 #define FIO0SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) )   427 #define FIO1SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) )   428 #define FIO2SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) )   429 #define FIO3SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) )   430 #define FIO4SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) )   432 #define FIO0SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x19U ) )   433 #define FIO1SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x29U ) )   434 #define FIO2SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x59U ) )   435 #define FIO3SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x79U ) )   436 #define FIO4SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x99U ) )   438 #define FIO0SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1AU ) )   439 #define FIO1SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3AU ) )   440 #define FIO2SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5AU ) )   441 #define FIO3SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7AU ) )   442 #define FIO4SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9AU ) )   444 #define FIO0SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1BU ) )   445 #define FIO1SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3BU ) )   446 #define FIO2SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5BU ) )   447 #define FIO3SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7BU ) )   448 #define FIO4SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9BU ) )   450 #define FIO0SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) )   451 #define FIO1SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) )   452 #define FIO2SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) )   453 #define FIO3SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) )   454 #define FIO4SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) )   456 #define FIO0SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1AU ) )   457 #define FIO1SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3AU ) )   458 #define FIO2SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5AU ) )   459 #define FIO3SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7AU ) )   460 #define FIO4SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x9AU ) )   462 #define FIO0CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) )   463 #define FIO1CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) )   464 #define FIO2CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) )   465 #define FIO3CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) )   466 #define FIO4CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) )   468 #define FIO0CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1DU ) )   469 #define FIO1CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x2DU ) )   470 #define FIO2CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5DU ) )   471 #define FIO3CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7DU ) )   472 #define FIO4CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9DU ) )   474 #define FIO0CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1EU ) )   475 #define FIO1CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3EU ) )   476 #define FIO2CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5EU ) )   477 #define FIO3CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7EU ) )   478 #define FIO4CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9EU ) )   480 #define FIO0CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1FU ) )   481 #define FIO1CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3FU ) )   482 #define FIO2CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5FU ) )   483 #define FIO3CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7FU ) )   484 #define FIO4CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9FU ) )   486 #define FIO0CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) )   487 #define FIO1CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) )   488 #define FIO2CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) )   489 #define FIO3CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) )   490 #define FIO4CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) )   492 #define FIO0CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1EU ) )   493 #define FIO1CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3EU ) )   494 #define FIO2CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5EU ) )   495 #define FIO3CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7EU ) )   496 #define FIO4CLRU ( *(volatile uint16_t *) ( FIO_BASE_ADDR + 0x9EU ) )   498 #define LPC176X_USB_CLOCK 48000000U   499 #define LPC176X_MODULE_CLOCK_MASK 0x3U   502 #define PINSEL_BASE_ADDR 0x4002C000U   504 #define PINSEL0 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x00U ) )   505 #define PINSEL1 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x04U ) )   506 #define PINSEL2 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x08U ) )   507 #define PINSEL3 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x0CU ) )   508 #define PINSEL4 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x10U ) )   509 #define PINSEL5 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x14U ) )   510 #define PINSEL6 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x18U ) )   511 #define PINSEL7 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x1CU ) )   512 #define PINSEL8 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x20U ) )   513 #define PINSEL9 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x24U ) )   514 #define PINSEL10 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x28U ) )   515 #define PINSEL11 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x2CU ) )   517 #define PINMODE0 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x40U ) )   518 #define PINMODE1 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x44U ) )   519 #define PINMODE2 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x48U ) )   520 #define PINMODE3 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x4CU ) )   521 #define PINMODE4 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x50U ) )   522 #define PINMODE5 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x54U ) )   523 #define PINMODE6 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x58U ) )   524 #define PINMODE7 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x5CU ) )   525 #define PINMODE8 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x60U ) )   526 #define PINMODE9 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x64U ) )   529 #define PWM0_BASE_ADDR 0x40014000   531 #define PWM0IR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x00 ) )   532 #define PWM0TCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x04 ) )   533 #define PWM0TC ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x08 ) )   534 #define PWM0PR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x0C ) )   535 #define PWM0PC ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x10 ) )   536 #define PWM0MCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x14 ) )   537 #define PWM0MR0 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x18 ) )   538 #define PWM0MR1 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x1C ) )   539 #define PWM0MR2 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x20 ) )   540 #define PWM0MR3 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x24 ) )   541 #define PWM0CCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x28 ) )   542 #define PWM0CR0 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x2C ) )   543 #define PWM0CR1 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x30 ) )   544 #define PWM0CR2 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x34 ) )   545 #define PWM0CR3 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x38 ) )   546 #define PWM0EMR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x3C ) )   547 #define PWM0MR4 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x40 ) )   548 #define PWM0MR5 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x44 ) )   549 #define PWM0MR6 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x48 ) )   550 #define PWM0PCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x4C ) )   551 #define PWM0LER ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x50 ) )   552 #define PWM0CTCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x70 ) )   554 #define PWM1_BASE_ADDR 0x40018000   556 #define PWM1IR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x00 ) )   557 #define PWM1TCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x04 ) )   558 #define PWM1TC ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x08 ) )   559 #define PWM1PR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x0C ) )   560 #define PWM1PC ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x10 ) )   561 #define PWM1MCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x14 ) )   562 #define PWM1MR0 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x18 ) )   563 #define PWM1MR1 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x1C ) )   564 #define PWM1MR2 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x20 ) )   565 #define PWM1MR3 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x24 ) )   566 #define PWM1CCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x28 ) )   567 #define PWM1CR0 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x2C ) )   568 #define PWM1CR1 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x30 ) )   569 #define PWM1CR2 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x34 ) )   570 #define PWM1CR3 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x38 ) )   571 #define PWM1EMR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x3C ) )   572 #define PWM1MR4 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x40 ) )   573 #define PWM1MR5 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x44 ) )   574 #define PWM1MR6 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x48 ) )   575 #define PWM1PCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x4C ) )   576 #define PWM1LER ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x50 ) )   577 #define PWM1CTCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x70 ) )   580 #define UART0_BASE_ADDR 0x4000C000   582 #define U0RBR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) )   583 #define U0THR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) )   584 #define U0DLL ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) )   585 #define U0DLM ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x04 ) )   586 #define U0IER ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x04 ) )   587 #define U0IIR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x08 ) )   588 #define U0FCR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x08 ) )   589 #define U0LCR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x0C ) )   590 #define U0LSR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x14 ) )   591 #define U0SCR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x1C ) )   592 #define U0ACR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x20 ) )   593 #define U0ICR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x24 ) )   594 #define U0FDR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x28 ) )   595 #define U0TER ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x30 ) )   598 #define UART1_BASE_ADDR 0x40010000   600 #define U1RBR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) )   601 #define U1THR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) )   602 #define U1DLL ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) )   603 #define U1DLM ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x04 ) )   604 #define U1IER ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x04 ) )   605 #define U1IIR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x08 ) )   606 #define U1FCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x08 ) )   607 #define U1LCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x0C ) )   608 #define U1MCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x10 ) )   609 #define U1LSR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x14 ) )   610 #define U1MSR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x18 ) )   611 #define U1SCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x1C ) )   612 #define U1ACR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x20 ) )   613 #define U1FDR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x28 ) )   614 #define U1TER ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x30 ) )   617 #define UART2_BASE_ADDR 0x40098000   619 #define U2RBR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) )   620 #define U2THR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) )   621 #define U2DLL ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) )   622 #define U2DLM ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x04 ) )   623 #define U2IER ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x04 ) )   624 #define U2IIR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x08 ) )   625 #define U2FCR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x08 ) )   626 #define U2LCR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x0C ) )   627 #define U2LSR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x14 ) )   628 #define U2SCR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x1C ) )   629 #define U2ACR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x20 ) )   630 #define U2ICR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x24 ) )   631 #define U2FDR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x28 ) )   632 #define U2TER ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x30 ) )   635 #define UART3_BASE_ADDR 0x4009C000   637 #define U3RBR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) )   638 #define U3THR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) )   639 #define U3DLL ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) )   640 #define U3DLM ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x04 ) )   641 #define U3IER ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x04 ) )   642 #define U3IIR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x08 ) )   643 #define U3FCR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x08 ) )   644 #define U3LCR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x0C ) )   645 #define U3LSR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x14 ) )   646 #define U3SCR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x1C ) )   647 #define U3ACR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x20 ) )   648 #define U3ICR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x24 ) )   649 #define U3FDR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x28 ) )   650 #define U3TER ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x30 ) )   653 #define SPI0_BASE_ADDR 0xE0020000   654 #define S0SPCR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x00 ) )   655 #define S0SPSR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x04 ) )   656 #define S0SPDR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x08 ) )   657 #define S0SPCCR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x0C ) )   658 #define S0SPINT ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x1C ) )   661 #define RTC_BASE_ADDR 0x40024000   663 #define RTC_ILR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x00 ) )   664 #define RTC_CTC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x04 ) )   665 #define RTC_CCR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x08 ) )   666 #define RTC_CIIR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x0C ) )   667 #define RTC_AMR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x10 ) )   668 #define RTC_CTIME0 ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x14 ) )   669 #define RTC_CTIME1 ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x18 ) )   670 #define RTC_CTIME2 ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x1C ) )   671 #define RTC_SEC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x20 ) )   672 #define RTC_MIN ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x24 ) )   673 #define RTC_HOUR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x28 ) )   674 #define RTC_DOM ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x2C ) )   675 #define RTC_DOW ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x30 ) )   676 #define RTC_DOY ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x34 ) )   677 #define RTC_MONTH ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x38 ) )   678 #define RTC_YEAR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x3C ) )   679 #define RTC_CISS ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x40 ) )   680 #define RTC_ALSEC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x60 ) )   681 #define RTC_ALMIN ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x64 ) )   682 #define RTC_ALHOUR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x68 ) )   683 #define RTC_ALDOM ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x6C ) )   684 #define RTC_ALDOW ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x70 ) )   685 #define RTC_ALDOY ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x74 ) )   686 #define RTC_ALMON ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x78 ) )   687 #define RTC_ALYEAR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x7C ) )   688 #define RTC_PREINT ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x80 ) )   689 #define RTC_PREFRAC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x84 ) )   692 #define AD0_BASE_ADDR 0x40034000   694 #define AD0CR ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x00 ) )   695 #define AD0GDR ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x04 ) )   696 #define AD0INTEN ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x0C ) )   697 #define AD0_DATA_START ( (volatile uint32_t *) ( AD0_BASE_ADDR + 0x10 ) )   698 #define AD0DR0 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x10 ) )   699 #define AD0DR1 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x14 ) )   700 #define AD0DR2 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x18 ) )   701 #define AD0DR3 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x1C ) )   702 #define AD0DR4 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x20 ) )   703 #define AD0DR5 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x24 ) )   704 #define AD0DR6 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x28 ) )   705 #define AD0DR7 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x2C ) )   706 #define AD0STAT ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x30 ) )   709 #define DAC_BASE_ADDR 0x4008C000   711 #define DACR ( *(volatile uint32_t *) ( DAC_BASE_ADDR + 0x00 ) )   714 #define CAN_ACCEPT_BASE_ADDR 0x4003C000   716 #define CAN_AFMR ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x00 ) )   717 #define CAN_SFF_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x04 ) )   718 #define CAN_SFF_GRP_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + \   720 #define CAN_EFF_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x0C ) )   721 #define CAN_EFF_GRP_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + \   723 #define CAN_EOT ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x14 ) )   724 #define CAN_LUT_ERR_ADR ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + \   726 #define CAN_LUT_ERR ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x1C ) )   728 #define CAN_CENTRAL_BASE_ADDR 0x40040000   730 #define CAN_TX_SR ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x00 ) )   731 #define CAN_RX_SR ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x04 ) )   732 #define CAN_MSR ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x08 ) )   734 #define CAN1_BASE_ADDR 0x40044000   736 #define CAN1MOD ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x00 ) )   737 #define CAN1CMR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x04 ) )   738 #define CAN1GSR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x08 ) )   739 #define CAN1ICR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x0C ) )   740 #define CAN1IER ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x10 ) )   741 #define CAN1BTR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x14 ) )   742 #define CAN1EWL ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x18 ) )   743 #define CAN1SR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x1C ) )   744 #define CAN1RFS ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x20 ) )   745 #define CAN1RID ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x24 ) )   746 #define CAN1RDA ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x28 ) )   747 #define CAN1RDB ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x2C ) )   749 #define CAN1TFI1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x30 ) )   750 #define CAN1TID1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x34 ) )   751 #define CAN1TDA1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x38 ) )   752 #define CAN1TDB1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x3C ) )   753 #define CAN1TFI2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x40 ) )   754 #define CAN1TID2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x44 ) )   755 #define CAN1TDA2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x48 ) )   756 #define CAN1TDB2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x4C ) )   757 #define CAN1TFI3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x50 ) )   758 #define CAN1TID3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x54 ) )   759 #define CAN1TDA3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x58 ) )   760 #define CAN1TDB3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x5C ) )   762 #define CAN2_BASE_ADDR 0x40048000   764 #define CAN2MOD ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x00 ) )   765 #define CAN2CMR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x04 ) )   766 #define CAN2GSR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x08 ) )   767 #define CAN2ICR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x0C ) )   768 #define CAN2IER ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x10 ) )   769 #define CAN2BTR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x14 ) )   770 #define CAN2EWL ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x18 ) )   771 #define CAN2SR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x1C ) )   772 #define CAN2RFS ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x20 ) )   773 #define CAN2RID ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x24 ) )   774 #define CAN2RDA ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x28 ) )   775 #define CAN2RDB ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x2C ) )   777 #define CAN2TFI1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x30 ) )   778 #define CAN2TID1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x34 ) )   779 #define CAN2TDA1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x38 ) )   780 #define CAN2TDB1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x3C ) )   781 #define CAN2TFI2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x40 ) )   782 #define CAN2TID2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x44 ) )   783 #define CAN2TDA2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x48 ) )   784 #define CAN2TDB2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x4C ) )   785 #define CAN2TFI3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x50 ) )   786 #define CAN2TID3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x54 ) )   787 #define CAN2TDA3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x58 ) )   788 #define CAN2TDB3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x5C ) )   791 #define MCI_BASE_ADDR 0x400c0000   793 #define MCI_POWER ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x00 ) )   794 #define MCI_CLOCK ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x04 ) )   795 #define MCI_ARGUMENT ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x08 ) )   796 #define MCI_COMMAND ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x0C ) )   797 #define MCI_RESP_CMD ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x10 ) )   798 #define MCI_RESP0 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x14 ) )   799 #define MCI_RESP1 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x18 ) )   800 #define MCI_RESP2 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x1C ) )   801 #define MCI_RESP3 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x20 ) )   802 #define MCI_DATA_TMR ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x24 ) )   803 #define MCI_DATA_LEN ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x28 ) )   804 #define MCI_DATA_CTRL ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x2C ) )   805 #define MCI_DATA_CNT ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x30 ) )   806 #define MCI_STATUS ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x34 ) )   807 #define MCI_CLEAR ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x38 ) )   808 #define MCI_MASK0 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x3C ) )   809 #define MCI_MASK1 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x40 ) )   810 #define MCI_FIFO_CNT ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x48 ) )   811 #define MCI_FIFO ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x80 ) )   814 #define I2S_BASE_ADDR 0x400a8000   816 #define I2S_DAO ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x00 ) )   817 #define I2S_DAI ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x04 ) )   818 #define I2S_TX_FIFO ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x08 ) )   819 #define I2S_RX_FIFO ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x0C ) )   820 #define I2S_STATE ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x10 ) )   821 #define I2S_DMA1 ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x14 ) )   822 #define I2S_DMA2 ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x18 ) )   823 #define I2S_IRQ ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x1C ) )   824 #define I2S_TXRATE ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x20 ) )   825 #define I2S_RXRATE ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x24 ) )   828 #define DMA_BASE_ADDR 0x50004000   830 #define GPDMA_INT_STAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x000 ) )   831 #define GPDMA_INT_TCSTAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x004 ) )   832 #define GPDMA_INT_TCCLR ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x008 ) )   833 #define GPDMA_INT_ERR_STAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x00C ) )   834 #define GPDMA_INT_ERR_CLR ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x010 ) )   835 #define GPDMA_RAW_INT_TCSTAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + \   837 #define GPDMA_RAW_INT_ERR_STAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + \   839 #define GPDMA_ENABLED_CHNS ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x01C ) )   840 #define GPDMA_SOFT_BREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x020 ) )   841 #define GPDMA_SOFT_SREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x024 ) )   842 #define GPDMA_SOFT_LBREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x028 ) )   843 #define GPDMA_SOFT_LSREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x02C ) )   844 #define GPDMA_CONFIG ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x030 ) )   845 #define GPDMA_SYNC ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x034 ) )   848 #define GPDMA_CH0_BASE_ADDR ( DMA_BASE_ADDR + 0x100 )   849 #define GPDMA_CH0_SRC ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x100 ) )   850 #define GPDMA_CH0_DEST ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x104 ) )   851 #define GPDMA_CH0_LLI ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x108 ) )   852 #define GPDMA_CH0_CTRL ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x10C ) )   853 #define GPDMA_CH0_CFG ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x110 ) )   856 #define GPDMA_CH1_BASE_ADDR ( DMA_BASE_ADDR + 0x120 )   857 #define GPDMA_CH1_SRC ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x120 ) )   858 #define GPDMA_CH1_DEST ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x124 ) )   859 #define GPDMA_CH1_LLI ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x128 ) )   860 #define GPDMA_CH1_CTRL ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x12C ) )   861 #define GPDMA_CH1_CFG ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x130 ) )   864 #define USB_INT_BASE_ADDR 0x400fc1c0   865 #define USB_BASE_ADDR 0x2008c200   867 #define USB_INT_STAT ( *(volatile uint32_t *) ( USB_INT_BASE_ADDR + 0x00 ) )   870 #define DEV_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x00 ) )   871 #define DEV_INT_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x04 ) )   872 #define DEV_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x08 ) )   873 #define DEV_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x0C ) )   874 #define DEV_INT_PRIO ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x2C ) )   877 #define EP_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x30 ) )   878 #define EP_INT_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x34 ) )   879 #define EP_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x38 ) )   880 #define EP_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x3C ) )   881 #define EP_INT_PRIO ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x40 ) )   884 #define REALIZE_EP ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x44 ) )   885 #define EP_INDEX ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x48 ) )   886 #define MAXPACKET_SIZE ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x4C ) )   889 #define CMD_CODE ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x10 ) )   890 #define CMD_DATA ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x14 ) )   893 #define RX_DATA ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x18 ) )   894 #define TX_DATA ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x1C ) )   895 #define RX_PLENGTH ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x20 ) )   896 #define TX_PLENGTH ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x24 ) )   897 #define USB_CTRL ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x28 ) )   900 #define DMA_REQ_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x50 ) )   901 #define DMA_REQ_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x54 ) )   902 #define DMA_REQ_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x58 ) )   903 #define UDCA_HEAD ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x80 ) )   904 #define EP_DMA_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x84 ) )   905 #define EP_DMA_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x88 ) )   906 #define EP_DMA_DIS ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x8C ) )   907 #define DMA_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x90 ) )   908 #define DMA_INT_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x94 ) )   909 #define EOT_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA0 ) )   910 #define EOT_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA4 ) )   911 #define EOT_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA8 ) )   912 #define NDD_REQ_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xAC ) )   913 #define NDD_REQ_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB0 ) )   914 #define NDD_REQ_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB4 ) )   915 #define SYS_ERR_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB8 ) )   916 #define SYS_ERR_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xBC ) )   917 #define SYS_ERR_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xC0 ) )   920 #define USBHC_BASE_ADDR 0x2008c000   922 #define HC_REVISION ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x00 ) )   923 #define HC_CONTROL ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x04 ) )   924 #define HC_CMD_STAT ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x08 ) )   925 #define HC_INT_STAT ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x0C ) )   926 #define HC_INT_EN ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x10 ) )   927 #define HC_INT_DIS ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x14 ) )   928 #define HC_HCCA ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x18 ) )   929 #define HC_PERIOD_CUR_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x1C ) )   930 #define HC_CTRL_HEAD_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x20 ) )   931 #define HC_CTRL_CUR_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x24 ) )   932 #define HC_BULK_HEAD_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x28 ) )   933 #define HC_BULK_CUR_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x2C ) )   934 #define HC_DONE_HEAD ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x30 ) )   935 #define HC_FM_INTERVAL ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x34 ) )   936 #define HC_FM_REMAINING ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x38 ) )   937 #define HC_FM_NUMBER ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x3C ) )   938 #define HC_PERIOD_START ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x40 ) )   939 #define HC_LS_THRHLD ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x44 ) )   940 #define HC_RH_DESCA ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x48 ) )   941 #define HC_RH_DESCB ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x4C ) )   942 #define HC_RH_STAT ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x50 ) )   943 #define HC_RH_PORT_STAT1 ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x54 ) )   944 #define HC_RH_PORT_STAT2 ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x58 ) )   947 #define USBOTG_BASE_ADDR 0x2008c100   949 #define OTG_INT_STAT ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x00 ) )   950 #define OTG_INT_EN ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x04 ) )   951 #define OTG_INT_SET ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x08 ) )   952 #define OTG_INT_CLR ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x0C ) )   953 #define OTG_STAT_CTRL ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x10 ) )   954 #define OTG_TIMER ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x14 ) )   956 #define USBOTG_I2C_BASE_ADDR 0x2008c300   958 #define OTG_I2C_RX ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x00 ) )   959 #define OTG_I2C_TX ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x00 ) )   960 #define OTG_I2C_STS ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x04 ) )   961 #define OTG_I2C_CTL ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x08 ) )   962 #define OTG_I2C_CLKHI ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + \   964 #define OTG_I2C_CLKLO ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + \   967 #define USBOTG_CLK_BASE_ADDR 0x2008CFF0U   969 #define OTG_CLK_CTRL ( *(volatile uint32_t *) ( USBOTG_CLK_BASE_ADDR + \   971 #define OTG_CLK_STAT ( *(volatile uint32_t *) ( USBOTG_CLK_BASE_ADDR + \   975 #define GET_FIELD( val, mask, shift ) \   976   ( ( ( val ) & ( mask ) ) >> ( shift ) )   978 #define SET_FIELD( val, field, mask, shift ) \   979   ( ( ( val ) & ~( mask ) ) | ( ( ( field ) << ( shift ) ) & ( mask ) ) )   982 #define CLKSRCSEL_CLKSRC_MASK 0x00000003U   984 #define GET_CLKSRCSEL_CLKSRC( reg ) \   985   GET_FIELD( reg, CLKSRCSEL_CLKSRC_MASK, 0 )   987 #define SET_CLKSRCSEL_CLKSRC( reg, val ) \   988   SET_FIELD( reg, val, CLKSRCSEL_CLKSRC_MASK, 0 )   991 #define PLLCON_PLLE 0x00000001U   993 #define PLLCON_PLLC 0x00000002U   996 #define PLLCFG_MSEL_MASK 0x00007fffU   998 #define GET_PLLCFG_MSEL( reg ) \   999   GET_FIELD( reg, PLLCFG_MSEL_MASK, 0 )  1001 #define SET_PLLCFG_MSEL( reg, val ) \  1002   SET_FIELD( reg, val, PLLCFG_MSEL_MASK, 0 )  1004 #define PLLCFG_NSEL_MASK 0x00ff0000U  1006 #define GET_PLLCFG_NSEL( reg ) \  1007   GET_FIELD( reg, PLLCFG_NSEL_MASK, 16 )  1009 #define SET_PLLCFG_NSEL( reg, val ) \  1010   SET_FIELD( reg, val, PLLCFG_NSEL_MASK, 16 )  1013 #define PLLSTAT_MSEL_MASK 0x00007fffU  1015 #define GET_PLLSTAT_MSEL( reg ) \  1016   GET_FIELD( reg, PLLSTAT_MSEL_MASK, 0 )  1018 #define SET_PLLSTAT_MSEL( reg, val ) \  1019   SET_FIELD( reg, val, PLLSTAT_MSEL_MASK, 0 )  1021 #define PLLSTAT_NSEL_MASK 0x00ff0000U  1023 #define GET_PLLSTAT_NSEL( reg ) \  1024   GET_FIELD( reg, PLLSTAT_NSEL_MASK, 16 )  1026 #define SET_PLLSTAT_NSEL( reg, val ) \  1027   SET_FIELD( reg, val, PLLSTAT_NSEL_MASK, 16 )  1029 #define PLLSTAT_PLLE 0x01000000U  1031 #define PLLSTAT_PLLC 0x02000000U  1033 #define PLLSTAT_PLOCK 0x04000000U  1036 #define CCLKCFG_CCLKSEL_MASK 0x000000ffU  1038 #define GET_CCLKCFG_CCLKSEL( reg ) \  1039   GET_FIELD( reg, CCLKCFG_CCLKSEL_MASK, 0 )  1041 #define SET_CCLKCFG_CCLKSEL( reg, val ) \  1042   SET_FIELD( reg, val, CCLKCFG_CCLKSEL_MASK, 0 )  1045 #define MEMMAP_MAP_MASK 0x00000003U  1047 #define GET_MEMMAP_MAP( reg ) \  1048   GET_FIELD( reg, MEMMAP_MAP_MASK, 0 )  1050 #define SET_MEMMAP_MAP( reg, val ) \  1051   SET_FIELD( reg, val, MEMMAP_MAP_MASK, 0 )  1054 #define TIR_MR0 0x00000001U  1055 #define TIR_MR1 0x00000002U  1056 #define TIR_MR2 0x00000004U  1057 #define TIR_MR3 0x00000008U  1058 #define TIR_CR0 0x00000010U  1059 #define TIR_CR1 0x00000020U  1060 #define TIR_CR2 0x00000040U  1061 #define TIR_CR3 0x00000080U  1064 #define TCR_EN 0x00000001U  1065 #define TCR_RST 0x00000002U  1068 #define TMCR_MR0I 0x00000001U  1069 #define TMCR_MR0R 0x00000002U  1070 #define TMCR_MR0S 0x00000004U  1071 #define TMCR_MR1I 0x00000008U  1072 #define TMCR_MR1R 0x00000010U  1073 #define TMCR_MR1S 0x00000020U  1074 #define TMCR_MR2I 0x00000040U  1075 #define TMCR_MR2R 0x00000080U  1076 #define TMCR_MR2S 0x00000100U  1077 #define TMCR_MR3I 0x00000200U  1078 #define TMCR_MR3R 0x00000400U  1079 #define TMCR_MR3S 0x00000800U  1082 #define PCLKSEL0_PCLK_WDT_MASK 0x00000003U  1084 #define GET_PCLKSEL0_PCLK_WDT( reg ) \  1085   GET_FIELD( reg, PCLKSEL0_PCLK_WDT_MASK, 0 )  1087 #define SET_PCLKSEL0_PCLK_WDT( reg, val ) \  1088   SET_FIELD( reg, val, PCLKSEL0_PCLK_WDT_MASK, 0 )  1090 #define PCLKSEL0_PCLK_TIMER0_MASK 0x0000000cU  1092 #define GET_PCLKSEL0_PCLK_TIMER0( reg ) \  1093   GET_FIELD( reg, PCLKSEL0_PCLK_TIMER0_MASK, 2 )  1095 #define SET_PCLKSEL0_PCLK_TIMER0( reg, val ) \  1096   SET_FIELD( reg, val, PCLKSEL0_PCLK_TIMER0_MASK, 2 )  1098 #define PCLKSEL0_PCLK_TIMER1_MASK 0x00000030U  1100 #define GET_PCLKSEL0_PCLK_TIMER1( reg ) \  1101   GET_FIELD( reg, PCLKSEL0_PCLK_TIMER1_MASK, 4 )  1103 #define SET_PCLKSEL0_PCLK_TIMER1( reg, val ) \  1104   SET_FIELD( reg, val, PCLKSEL0_PCLK_TIMER1_MASK, 4 )  1106 #define PCLKSEL0_PCLK_UART0_MASK 0x000000c0U  1108 #define GET_PCLKSEL0_PCLK_UART0( reg ) \  1109   GET_FIELD( reg, PCLKSEL0_PCLK_UART0_MASK, 6 )  1111 #define SET_PCLKSEL0_PCLK_UART0( reg, val ) \  1112   SET_FIELD( reg, val, PCLKSEL0_PCLK_UART0_MASK, 6 )  1114 #define PCLKSEL0_PCLK_UART1_MASK 0x00000300U  1116 #define GET_PCLKSEL0_PCLK_UART1( reg ) \  1117   GET_FIELD( reg, PCLKSEL0_PCLK_UART1_MASK, 8 )  1119 #define SET_PCLKSEL0_PCLK_UART1( reg, val ) \  1120   SET_FIELD( reg, val, PCLKSEL0_PCLK_UART1_MASK, 8 )  1122 #define PCLKSEL0_PCLK_PWM0_MASK 0x00000c00U  1124 #define GET_PCLKSEL0_PCLK_PWM0( reg ) \  1125   GET_FIELD( reg, PCLKSEL0_PCLK_PWM0_MASK, 10 )  1127 #define SET_PCLKSEL0_PCLK_PWM0( reg, val ) \  1128   SET_FIELD( reg, val, PCLKSEL0_PCLK_PWM0_MASK, 10 )  1130 #define PCLKSEL0_PCLK_PWM1_MASK 0x00003000U  1132 #define GET_PCLKSEL0_PCLK_PWM1( reg ) \  1133   GET_FIELD( reg, PCLKSEL0_PCLK_PWM1_MASK, 12 )  1135 #define SET_PCLKSEL0_PCLK_PWM1( reg, val ) \  1136   SET_FIELD( reg, val, PCLKSEL0_PCLK_PWM1_MASK, 12 )  1138 #define PCLKSEL0_PCLK_I2C0_MASK 0x0000c000U  1140 #define GET_PCLKSEL0_PCLK_I2C0( reg ) \  1141   GET_FIELD( reg, PCLKSEL0_PCLK_I2C0_MASK, 14 )  1143 #define SET_PCLKSEL0_PCLK_I2C0( reg, val ) \  1144   SET_FIELD( reg, val, PCLKSEL0_PCLK_I2C0_MASK, 14 )  1146 #define PCLKSEL0_PCLK_SPI_MASK 0x00030000U  1148 #define GET_PCLKSEL0_PCLK_SPI( reg ) \  1149   GET_FIELD( reg, PCLKSEL0_PCLK_SPI_MASK, 16 )  1151 #define SET_PCLKSEL0_PCLK_SPI( reg, val ) \  1152   SET_FIELD( reg, val, PCLKSEL0_PCLK_SPI_MASK, 16 )  1154 #define PCLKSEL0_PCLK_RTC_MASK 0x000c0000U  1156 #define GET_PCLKSEL0_PCLK_RTC( reg ) \  1157   GET_FIELD( reg, PCLKSEL0_PCLK_RTC_MASK, 18 )  1159 #define SET_PCLKSEL0_PCLK_RTC( reg, val ) \  1160   SET_FIELD( reg, val, PCLKSEL0_PCLK_RTC_MASK, 18 )  1162 #define PCLKSEL0_PCLK_SSP1_MASK 0x00300000U  1164 #define GET_PCLKSEL0_PCLK_SSP1( reg ) \  1165   GET_FIELD( reg, PCLKSEL0_PCLK_SSP1_MASK, 20 )  1167 #define SET_PCLKSEL0_PCLK_SSP1( reg, val ) \  1168   SET_FIELD( reg, val, PCLKSEL0_PCLK_SSP1_MASK, 20 )  1170 #define PCLKSEL0_PCLK_DAC_MASK 0x00c00000U  1172 #define GET_PCLKSEL0_PCLK_DAC( reg ) \  1173   GET_FIELD( reg, PCLKSEL0_PCLK_DAC_MASK, 22 )  1175 #define SET_PCLKSEL0_PCLK_DAC( reg, val ) \  1176   SET_FIELD( reg, val, PCLKSEL0_PCLK_DAC_MASK, 22 )  1178 #define PCLKSEL0_PCLK_ADC_MASK 0x03000000U  1180 #define GET_PCLKSEL0_PCLK_ADC( reg ) \  1181   GET_FIELD( reg, PCLKSEL0_PCLK_ADC_MASK, 24 )  1183 #define SET_PCLKSEL0_PCLK_ADC( reg, val ) \  1184   SET_FIELD( reg, val, PCLKSEL0_PCLK_ADC_MASK, 24 )  1186 #define PCLKSEL0_PCLK_CAN1_MASK 0x0c000000U  1188 #define GET_PCLKSEL0_PCLK_CAN1( reg ) \  1189   GET_FIELD( reg, PCLKSEL0_PCLK_CAN1_MASK, 26 )  1191 #define SET_PCLKSEL0_PCLK_CAN1( reg, val ) \  1192   SET_FIELD( reg, val, PCLKSEL0_PCLK_CAN1_MASK, 26 )  1194 #define PCLKSEL0_PCLK_CAN2_MASK 0x30000000U  1196 #define GET_PCLKSEL0_PCLK_CAN2( reg ) \  1197   GET_FIELD( reg, PCLKSEL0_PCLK_CAN2_MASK, 28 )  1199 #define SET_PCLKSEL0_PCLK_CAN2( reg, val ) \  1200   SET_FIELD( reg, val, PCLKSEL0_PCLK_CAN2_MASK, 28 )  1203 #define PCLKSEL1_PCLK_BAT_RAM_MASK 0x00000003U  1205 #define GET_PCLKSEL1_PCLK_BAT_RAM( reg ) \  1206   GET_FIELD( reg, PCLKSEL1_PCLK_BAT_RAM_MASK, 0 )  1208 #define SET_PCLKSEL1_PCLK_BAT_RAM( reg, val ) \  1209   SET_FIELD( reg, val, PCLKSEL1_PCLK_BAT_RAM_MASK, 0 )  1211 #define PCLKSEL1_PCLK_GPIO_MASK 0x0000000cU  1213 #define GET_PCLKSEL1_PCLK_GPIO( reg ) \  1214   GET_FIELD( reg, PCLKSEL1_PCLK_GPIO_MASK, 2 )  1216 #define SET_PCLKSEL1_PCLK_GPIO( reg, val ) \  1217   SET_FIELD( reg, val, PCLKSEL1_PCLK_GPIO_MASK, 2 )  1219 #define PCLKSEL1_PCLK_PCB_MASK 0x00000030U  1221 #define GET_PCLKSEL1_PCLK_PCB( reg ) \  1222   GET_FIELD( reg, PCLKSEL1_PCLK_PCB_MASK, 4 )  1224 #define SET_PCLKSEL1_PCLK_PCB( reg, val ) \  1225   SET_FIELD( reg, val, PCLKSEL1_PCLK_PCB_MASK, 4 )  1227 #define PCLKSEL1_PCLK_I2C1_MASK 0x000000c0U  1229 #define GET_PCLKSEL1_PCLK_I2C1( reg ) \  1230   GET_FIELD( reg, PCLKSEL1_PCLK_I2C1_MASK, 6 )  1232 #define SET_PCLKSEL1_PCLK_I2C1( reg, val ) \  1233   SET_FIELD( reg, val, PCLKSEL1_PCLK_I2C1_MASK, 6 )  1235 #define PCLKSEL1_PCLK_SSP0_MASK 0x00000c00U  1237 #define GET_PCLKSEL1_PCLK_SSP0( reg ) \  1238   GET_FIELD( reg, PCLKSEL1_PCLK_SSP0_MASK, 10 )  1240 #define SET_PCLKSEL1_PCLK_SSP0( reg, val ) \  1241   SET_FIELD( reg, val, PCLKSEL1_PCLK_SSP0_MASK, 10 )  1243 #define PCLKSEL1_PCLK_TIMER2_MASK 0x00003000U  1245 #define GET_PCLKSEL1_PCLK_TIMER2( reg ) \  1246   GET_FIELD( reg, PCLKSEL1_PCLK_TIMER2_MASK, 12 )  1248 #define SET_PCLKSEL1_PCLK_TIMER2( reg, val ) \  1249   SET_FIELD( reg, val, PCLKSEL1_PCLK_TIMER2_MASK, 12 )  1251 #define PCLKSEL1_PCLK_TIMER3_MASK 0x0000c000U  1253 #define GET_PCLKSEL1_PCLK_TIMER3( reg ) \  1254   GET_FIELD( reg, PCLKSEL1_PCLK_TIMER3_MASK, 14 )  1256 #define SET_PCLKSEL1_PCLK_TIMER3( reg, val ) \  1257   SET_FIELD( reg, val, PCLKSEL1_PCLK_TIMER3_MASK, 14 )  1259 #define PCLKSEL1_PCLK_UART2_MASK 0x00030000U  1261 #define GET_PCLKSEL1_PCLK_UART2( reg ) \  1262   GET_FIELD( reg, PCLKSEL1_PCLK_UART2_MASK, 16 )  1264 #define SET_PCLKSEL1_PCLK_UART2( reg, val ) \  1265   SET_FIELD( reg, val, PCLKSEL1_PCLK_UART2_MASK, 16 )  1267 #define PCLKSEL1_PCLK_UART3_MASK 0x000c0000U  1269 #define GET_PCLKSEL1_PCLK_UART3( reg ) \  1270   GET_FIELD( reg, PCLKSEL1_PCLK_UART3_MASK, 18 )  1272 #define SET_PCLKSEL1_PCLK_UART3( reg, val ) \  1273   SET_FIELD( reg, val, PCLKSEL1_PCLK_UART3_MASK, 18 )  1275 #define PCLKSEL1_PCLK_I2C2_MASK 0x00300000U  1277 #define GET_PCLKSEL1_PCLK_I2C2( reg ) \  1278   GET_FIELD( reg, PCLKSEL1_PCLK_I2C2_MASK, 20 )  1280 #define SET_PCLKSEL1_PCLK_I2C2( reg, val ) \  1281   SET_FIELD( reg, val, PCLKSEL1_PCLK_I2C2_MASK, 20 )  1283 #define PCLKSEL1_PCLK_I2S_MASK 0x00c00000U  1285 #define GET_PCLKSEL1_PCLK_I2S( reg ) \  1286   GET_FIELD( reg, PCLKSEL1_PCLK_I2S_MASK, 22 )  1288 #define SET_PCLKSEL1_PCLK_I2S( reg, val ) \  1289   SET_FIELD( reg, val, PCLKSEL1_PCLK_I2S_MASK, 22 )  1291 #define PCLKSEL1_PCLK_MCI_MASK 0x03000000U  1293 #define GET_PCLKSEL1_PCLK_MCI( reg ) \  1294   GET_FIELD( reg, PCLKSEL1_PCLK_MCI_MASK, 24 )  1296 #define SET_PCLKSEL1_PCLK_MCI( reg, val ) \  1297   SET_FIELD( reg, val, PCLKSEL1_PCLK_MCI_MASK, 24 )  1299 #define PCLKSEL1_PCLK_SYSCON_MASK 0x30000000U  1301 #define GET_PCLKSEL1_PCLK_SYSCON( reg ) \  1302   GET_FIELD( reg, PCLKSEL1_PCLK_SYSCON_MASK, 28 )  1304 #define SET_PCLKSEL1_PCLK_SYSCON( reg, val ) \  1305   SET_FIELD( reg, val, PCLKSEL1_PCLK_SYSCON_MASK, 28 )  1308 #define RTC_ILR_RTCCIF 0x00000001U  1309 #define RTC_ILR_RTCALF 0x00000002U  1310 #define RTC_ILR_RTSSF 0x00000004U  1313 #define RTC_CCR_CLKEN 0x00000001U  1314 #define RTC_CCR_CTCRST 0x00000002U  1315 #define RTC_CCR_CLKSRC 0x00000010U  1330 #define GPDMA_CH_NUMBER 2  1331 #define GPDMA_STATUS_CH_0 0x00000001U  1332 #define GPDMA_STATUS_CH_1 0x00000002U  1333 #define GPDMA_CH_BASE_ADDR( i ) \  1334   ( (volatile lpc176x_dma_channel *) \  1335     ( ( i ) ? GPDMA_CH1_BASE_ADDR : GPDMA_CH0_BASE_ADDR ) )  1338 #define GPDMA_CONFIG_EN 0x00000001U  1339 #define GPDMA_CONFIG_MODE 0x00000002U  1342 #define GPDMA_ENABLED_CHNS_CH0 0x00000001U  1343 #define GPDMA_ENABLED_CHNS_CH1 0x00000002U  1346 #define GPDMA_CH_CTRL_TSZ_MASK 0x00000fffU  1348 #define GET_GPDMA_CH_CTRL_TSZ( reg ) \  1349   GET_FIELD( reg, GPDMA_CH_CTRL_TSZ_MASK, 0 )  1351 #define SET_GPDMA_CH_CTRL_TSZ( reg, val ) \  1352   SET_FIELD( reg, val, GPDMA_CH_CTRL_TSZ_MASK, 0 )  1354 #define GPDMA_CH_CTRL_TSZ_MAX 0x00000fffU  1356 #define GPDMA_CH_CTRL_SBSZ_MASK 0x00007000U  1358 #define GET_GPDMA_CH_CTRL_SBSZ( reg ) \  1359   GET_FIELD( reg, GPDMA_CH_CTRL_SBSZ_MASK, 12 )  1361 #define SET_GPDMA_CH_CTRL_SBSZ( reg, val ) \  1362   SET_FIELD( reg, val, GPDMA_CH_CTRL_SBSZ_MASK, 12 )  1364 #define GPDMA_CH_CTRL_DBSZ_MASK 0x00038000U  1366 #define GET_GPDMA_CH_CTRL_DBSZ( reg ) \  1367   GET_FIELD( reg, GPDMA_CH_CTRL_DBSZ_MASK, 15 )  1369 #define SET_GPDMA_CH_CTRL_DBSZ( reg, val ) \  1370   SET_FIELD( reg, val, GPDMA_CH_CTRL_DBSZ_MASK, 15 )  1372 #define GPDMA_CH_CTRL_BSZ_1 0x00000000U  1374 #define GPDMA_CH_CTRL_BSZ_4 0x00000001U  1376 #define GPDMA_CH_CTRL_BSZ_8 0x00000002U  1378 #define GPDMA_CH_CTRL_BSZ_16 0x00000003U  1380 #define GPDMA_CH_CTRL_BSZ_32 0x00000004U  1382 #define GPDMA_CH_CTRL_BSZ_64 0x00000005U  1384 #define GPDMA_CH_CTRL_BSZ_128 0x00000006U  1386 #define GPDMA_CH_CTRL_BSZ_256 0x00000007U  1388 #define GPDMA_CH_CTRL_SW_MASK 0x001c0000U  1390 #define GET_GPDMA_CH_CTRL_SW( reg ) \  1391   GET_FIELD( reg, GPDMA_CH_CTRL_SW_MASK, 18 )  1393 #define SET_GPDMA_CH_CTRL_SW( reg, val ) \  1394   SET_FIELD( reg, val, GPDMA_CH_CTRL_SW_MASK, 18 )  1396 #define GPDMA_CH_CTRL_DW_MASK 0x00e00000U  1398 #define GET_GPDMA_CH_CTRL_DW( reg ) \  1399   GET_FIELD( reg, GPDMA_CH_CTRL_DW_MASK, 21 )  1401 #define SET_GPDMA_CH_CTRL_DW( reg, val ) \  1402   SET_FIELD( reg, val, GPDMA_CH_CTRL_DW_MASK, 21 )  1404 #define GPDMA_CH_CTRL_W_8 0x00000000U  1406 #define GPDMA_CH_CTRL_W_16 0x00000001U  1408 #define GPDMA_CH_CTRL_W_32 0x00000002U  1410 #define GPDMA_CH_CTRL_SI 0x04000000U  1412 #define GPDMA_CH_CTRL_DI 0x08000000U  1414 #define GPDMA_CH_CTRL_PROT_MASK 0x70000000U  1416 #define GET_GPDMA_CH_CTRL_PROT( reg ) \  1417   GET_FIELD( reg, GPDMA_CH_CTRL_PROT_MASK, 28 )  1419 #define SET_GPDMA_CH_CTRL_PROT( reg, val ) \  1420   SET_FIELD( reg, val, GPDMA_CH_CTRL_PROT_MASK, 28 )  1422 #define GPDMA_CH_CTRL_ITC 0x80000000U  1425 #define GPDMA_CH_CFG_EN 0x00000001U  1427 #define GPDMA_CH_CFG_SRCPER_MASK 0x0000001eU  1429 #define GET_GPDMA_CH_CFG_SRCPER( reg ) \  1430   GET_FIELD( reg, GPDMA_CH_CFG_SRCPER_MASK, 1 )  1432 #define SET_GPDMA_CH_CFG_SRCPER( reg, val ) \  1433   SET_FIELD( reg, val, GPDMA_CH_CFG_SRCPER_MASK, 1 )  1435 #define GPDMA_CH_CFG_DESTPER_MASK 0x000003c0U  1437 #define GET_GPDMA_CH_CFG_DESTPER( reg ) \  1438   GET_FIELD( reg, GPDMA_CH_CFG_DESTPER_MASK, 6 )  1440 #define SET_GPDMA_CH_CFG_DESTPER( reg, val ) \  1441   SET_FIELD( reg, val, GPDMA_CH_CFG_DESTPER_MASK, 6 )  1443 #define GPDMA_CH_CFG_PER_SSP0_TX 0x00000000U  1445 #define GPDMA_CH_CFG_PER_SSP0_RX 0x00000001U  1447 #define GPDMA_CH_CFG_PER_SSP1_TX 0x00000002U  1449 #define GPDMA_CH_CFG_PER_SSP1_RX 0x00000003U  1451 #define GPDMA_CH_CFG_PER_SD_MMC 0x00000004U  1453 #define GPDMA_CH_CFG_PER_I2S_CH0 0x00000005U  1455 #define GPDMA_CH_CFG_PER_I2S_CH1 0x00000006U  1457 #define GPDMA_CH_CFG_FLOW_MASK 0x00003800U  1459 #define GET_GPDMA_CH_CFG_FLOW( reg ) \  1460   GET_FIELD( reg, GPDMA_CH_CFG_FLOW_MASK, 11 )  1462 #define SET_GPDMA_CH_CFG_FLOW( reg, val ) \  1463   SET_FIELD( reg, val, GPDMA_CH_CFG_FLOW_MASK, 11 )  1465 #define GPDMA_CH_CFG_FLOW_MEM_TO_MEM_DMA 0x00000000U  1467 #define GPDMA_CH_CFG_FLOW_MEM_TO_PER_DMA 0x00000001U  1469 #define GPDMA_CH_CFG_FLOW_PER_TO_MEM_DMA 0x00000002U  1471 #define GPDMA_CH_CFG_FLOW_PER_TO_PER_DMA 0x00000003U  1473 #define GPDMA_CH_CFG_FLOW_PER_TO_PER_DEST 0x00000004U  1475 #define GPDMA_CH_CFG_FLOW_MEM_TO_PER_PER 0x00000005U  1477 #define GPDMA_CH_CFG_FLOW_PER_TO_MEM_PER 0x00000006U  1479 #define GPDMA_CH_CFG_FLOW_PER_TO_PER_SRC 0x00000007U  1481 #define GPDMA_CH_CFG_IE 0x00004000U  1483 #define GPDMA_CH_CFG_ITC 0x00008000U  1485 #define GPDMA_CH_CFG_LOCK 0x00010000U  1487 #define GPDMA_CH_CFG_ACTIVE 0x00020000U  1489 #define GPDMA_CH_CFG_HALT 0x00040000U  1492 #define AHBCFG_SCHEDULER_UNIFORM 0x00000001U  1494 #define AHBCFG_BREAK_BURST_MASK 0x00000006U  1496 #define GET_AHBCFG_BREAK_BURST( reg ) \  1497   GET_FIELD( reg, AHBCFG_BREAK_BURST_MASK, 1 )  1499 #define SET_AHBCFG_BREAK_BURST( reg, val ) \  1500   SET_FIELD( reg, val, AHBCFG_BREAK_BURST_MASK, 1 )  1502 #define AHBCFG_QUANTUM_BUS_CYCLE 0x00000008U  1504 #define AHBCFG_QUANTUM_SIZE_MASK 0x000000f0U  1506 #define GET_AHBCFG_QUANTUM_SIZE( reg ) \  1507   GET_FIELD( reg, AHBCFG_QUANTUM_SIZE_MASK, 4 )  1509 #define SET_AHBCFG_QUANTUM_SIZE( reg, val ) \  1510   SET_FIELD( reg, val, AHBCFG_QUANTUM_SIZE_MASK, 4 )  1512 #define AHBCFG_DEFAULT_MASTER_MASK 0x00000700U  1514 #define GET_AHBCFG_DEFAULT_MASTER( reg ) \  1515   GET_FIELD( reg, AHBCFG_DEFAULT_MASTER_MASK, 8 )  1517 #define SET_AHBCFG_DEFAULT_MASTER( reg, val ) \  1518   SET_FIELD( reg, val, AHBCFG_DEFAULT_MASTER_MASK, 8 )  1520 #define AHBCFG_EP1_MASK 0x00007000U  1522 #define GET_AHBCFG_EP1( reg ) \  1523   GET_FIELD( reg, AHBCFG_EP1_MASK, 12 )  1525 #define SET_AHBCFG_EP1( reg, val ) \  1526   SET_FIELD( reg, val, AHBCFG_EP1_MASK, 12 )  1528 #define AHBCFG_EP2_MASK 0x00070000U  1530 #define GET_AHBCFG_EP2( reg ) \  1531   GET_FIELD( reg, AHBCFG_EP2_MASK, 16 )  1533 #define SET_AHBCFG_EP2( reg, val ) \  1534   SET_FIELD( reg, val, AHBCFG_EP2_MASK, 16 )  1536 #define AHBCFG_EP3_MASK 0x00700000U  1538 #define GET_AHBCFG_EP3( reg ) \  1539   GET_FIELD( reg, AHBCFG_EP3_MASK, 20 )  1541 #define SET_AHBCFG_EP3( reg, val ) \  1542   SET_FIELD( reg, val, AHBCFG_EP3_MASK, 20 )  1544 #define AHBCFG_EP4_MASK 0x07000000U  1546 #define GET_AHBCFG_EP4( reg ) \  1547   GET_FIELD( reg, AHBCFG_EP4_MASK, 24 )  1549 #define SET_AHBCFG_EP4( reg, val ) \  1550   SET_FIELD( reg, val, AHBCFG_EP4_MASK, 24 )  1552 #define AHBCFG_EP5_MASK 0x70000000U  1554 #define GET_AHBCFG_EP5( reg ) \  1555   GET_FIELD( reg, AHBCFG_EP5_MASK, 28 )  1557 #define SET_AHBCFG_EP5( reg, val ) \  1558   SET_FIELD( reg, val, AHBCFG_EP5_MASK, 28 )  1561 static volatile lpc_i2s *
const lpc176x_i2s = (
lpc_i2s *) I2S_BASE_ADDR;
  1564 #define ADC_CR_SEL( val ) BSP_FLD32( val, 0, 7 )  1565 #define ADC_CR_SEL_GET( val ) BSP_FLD32GET( val, 0, 7 )  1566 #define ADC_CR_SEL_SET( reg, val ) BSP_FLD32SET( reg, val, 0, 7 )  1567 #define ADC_CR_CLKDIV( val ) BSP_FLD32( val, 8, 15 )  1568 #define ADC_CR_CLKDIV_GET( reg ) BSP_FLD32GET( reg, 8, 15 )  1569 #define ADC_CR_CLKDIV_SET( reg, val ) BSP_FLD32SET( reg, val, 8, 15 )  1570 #define ADC_CR_BURST BSP_BIT32( 16 )  1571 #define ADC_CR_CLKS( val ) BSP_FLD32( val, 17, 19 )  1572 #define ADC_CR_PDN BSP_BIT32( 21 )  1573 #define ADC_CR_START( val ) BSP_FLD32( val, 24, 26 )  1574 #define ADC_CR_EDGE BSP_BIT32( 27 )  1576 #define ADC_DR_VALUE( reg ) BSP_FLD32GET( reg, 6, 15 )  1577 #define ADC_DR_OVERRUN BSP_BIT32( 30 )  1578 #define ADC_DR_DONE BSP_BIT32( 31 )  1581 #define DAC_STEPS 1024  1582 #define DAC_VALUE( val ) BSP_FLD32( val, 6, 15 )  1583 #define DAC_BIAS BSP_BIT32( 16 ) System Control Block representation.
Definition: lpc176x.h:191
Definition: lpc176x.h:1318
uint32_t extint
External Interrupt flag register.
Definition: lpc176x.h:239
uint32_t pboost
Peripheral boost.
Definition: lpc176x.h:267
uint32_t extmode
External Interrupt Mode register.
Definition: lpc176x.h:244
Phase-Locked Loop representation.
Definition: lpc176x.h:42
uint32_t rsid
Reset Source Identification Register.
Definition: lpc176x.h:253
I2S control block.
Definition: lpc-i2s.h:46
uint32_t cfg
PLL Configuration Register.
Definition: lpc176x.h:50
uint32_t con
PLL Control Register.
Definition: lpc176x.h:46
uint32_t stat
PLL Status Register.
Definition: lpc176x.h:54
uint32_t clkoutcfg
Clock Output Configuration Register.
Definition: lpc176x.h:272
uint32_t feed
PLL Feed Register.
Definition: lpc176x.h:58
lpc176x_pll pll_1
Phase-Locked Loop 1.
Definition: lpc176x.h:210
uint32_t cclksel
Selects the divide valuefor creating the CPU clock from the PPL0 output.
Definition: lpc176x.h:225
uint32_t extpolar
External Interrupt Polarity register.
Definition: lpc176x.h:248
Definition: lpc176x.h:1325
uint32_t flashcfg
Flash Accelerator Configuration Register.
Definition: lpc176x.h:195
lpc176x_pll pll_0
Phase-Locked Loop 0.
Definition: lpc176x.h:205
uint32_t pconp
Power Control for Peripherals register.
Definition: lpc176x.h:219
uint32_t memmap
Memopry Map Control.
Definition: lpc176x.h:200
uint32_t pcon
Power Mode Control register.
Definition: lpc176x.h:215
uint32_t scs
System Controls and Status Register.
Definition: lpc176x.h:258
uint32_t clksrcsel
Clock Source Select register.
Definition: lpc176x.h:234
uint32_t usbclksel
Selects the divide value for creating the USB clock from the PPL0 output.
Definition: lpc176x.h:230
