    RTEMS
    5.1
Go to the documentation of this file.   23 #ifndef LIBBSP_ARM_SHARED_LPC_I2S_H    24 #define LIBBSP_ARM_SHARED_LPC_I2S_H    64 #define I2S_DAIO_WORDWIDTH(val) BSP_FLD32(val, 0, 1)    65 #define I2S_DAIO_MONO BSP_BIT32(2)    66 #define I2S_DAIO_STOP BSP_BIT32(3)    67 #define I2S_DAIO_RESET BSP_BIT32(4)    68 #define I2S_DAIO_WS_SEL BSP_BIT32(5)    69 #define I2S_DAIO_WS_HALFPERIOD(val) BSP_FLD32(val, 6, 14)    70 #define I2S_DAIO_MUTE BSP_BIT32(15)    80 #define I2S_STATE_IRQ BSP_BIT32(0)    81 #define I2S_STATE_DMAREQ_0 BSP_BIT32(1)    82 #define I2S_STATE_DMAREQ_1 BSP_BIT32(2)    83 #define I2S_STATE_RX_LEVEL_GET(reg) BSP_FLD32GET(reg, 8, 11)    84 #define I2S_STATE_TX_LEVEL_GET(reg) BSP_FLD32GET(reg, 16, 19)    94 #define I2S_DMA_RX_ENABLE BSP_BIT32(0)    95 #define I2S_DMA_TX_ENABLE BSP_BIT32(1)    96 #define I2S_DMA_RX_DEPTH(val) BSP_FLD32(val, 8, 11)    97 #define I2S_DMA_TX_DEPTH(val) BSP_FLD32(val, 16, 19)   107 #define I2S_IRQ_RX BSP_BIT32(0)   108 #define I2S_IRQ_TX BSP_BIT32(1)   109 #define I2S_IRQ_RX_DEPTH(val) BSP_FLD32(val, 8, 11)   110 #define I2S_IRQ_TX_DEPTH(val) BSP_FLD32(val, 16, 19)   120 #define LPC24XX_I2S_RATE(val) BSP_FLD32(val, 0, 9)   121 #define LPC32XX_I2S_RATE_X_DIVIDER(val) BSP_FLD32(val, 0, 7)   122 #define LPC32XX_I2S_RATE_Y_DIVIDER(val) BSP_FLD32(val, 8, 15) I2S control block.
Definition: lpc-i2s.h:46
