RTEMS  5.1
condimpl.h File Reference
#include <pthread.h>
struct  POSIX_Condition_variables_Control
#define POSIX_CONDITION_VARIABLES_CLOCK_MONOTONIC   0x1UL
#define POSIX_CONDITION_VARIABLES_FLAGS_MASK   0x1UL
#define POSIX_CONDITION_VARIABLES_MAGIC   0x18dfb1feUL
#define POSIX_CONDITION_VARIABLES_NO_MUTEX   NULL
#define POSIX_CONDITION_VARIABLES_TQ_OPERATIONS   &_Thread_queue_Operations_FIFO
#define POSIX_CONDITION_VARIABLE_OF_THREAD_QUEUE_QUEUE(queue)
#define POSIX_CONDITION_VARIABLES_VALIDATE_OBJECT(the_cond, flags)
RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Initialize (POSIX_Condition_variables_Control *the_cond, const pthread_condattr_t *the_attr)
RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Destroy (POSIX_Condition_variables_Control *the_cond)
RTEMS_INLINE_ROUTINE clockid_t _POSIX_Condition_variables_Get_clock (unsigned long flags)
RTEMS_INLINE_ROUTINE Thread_Control * _POSIX_Condition_variables_Acquire (POSIX_Condition_variables_Control *the_cond, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Release (POSIX_Condition_variables_Control *the_cond, Thread_queue_Context *queue_context)
int _POSIX_Condition_variables_Signal_support (pthread_cond_t *cond, bool is_broadcast)
 Implements wake up version of the "signal" operation. More...
int _POSIX_Condition_variables_Wait_support (pthread_cond_t *cond, pthread_mutex_t *mutex, const struct timespec *abstime)
 POSIX condition variables wait support. More...
bool _POSIX_Condition_variables_Auto_initialization (POSIX_Condition_variables_Control *the_cond)
const pthread_condattr_t _POSIX_Condition_variables_Default_attributes
This include file contains the static inline implementation of the private inlined routines for POSIX condition variables.
◆ POSIX_CONDITION_VARIABLE_OF_THREAD_QUEUE_QUEUE
#define POSIX_CONDITION_VARIABLE_OF_THREAD_QUEUE_QUEUE (   queue)
Value:
queue, POSIX_Condition_variables_Control, Queue.Queue )
#define RTEMS_CONTAINER_OF(_m, _type, _member_name)
Returns a pointer to the container of a specified member pointer.
Definition: basedefs.h:430
Definition: condimpl.h:30
◆ POSIX_CONDITION_VARIABLES_NO_MUTEX
Constant to indicate condition variable does not currently have a mutex assigned to it.
◆ POSIX_CONDITION_VARIABLES_VALIDATE_OBJECT
#define POSIX_CONDITION_VARIABLES_VALIDATE_OBJECT (   the_cond,
  flags
Value:
do { \
if ( ( the_cond ) == NULL ) { \
return EINVAL; \
flags = ( the_cond )->flags; \
if ( \
( ( (uintptr_t) ( the_cond ) ^ POSIX_CONDITION_VARIABLES_MAGIC ) \
& ~POSIX_CONDITION_VARIABLES_FLAGS_MASK ) \
!= ( flags & ~POSIX_CONDITION_VARIABLES_FLAGS_MASK ) \
if ( !_POSIX_Condition_variables_Auto_initialization( the_cond ) ) { \
return EINVAL; \
} while ( 0 )
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
◆ _POSIX_Condition_variables_Signal_support()
int _POSIX_Condition_variables_Signal_support ( pthread_cond_t *  cond,
bool  is_broadcast
A support routine which implements guts of the broadcast and single task wake up version of the "signal" operation.
◆ _POSIX_Condition_variables_Wait_support()
int _POSIX_Condition_variables_Wait_support ( pthread_cond_t *  cond,
pthread_mutex_t *  mutex,
const struct timespec *  abstime
A support routine which implements guts of the blocking, non-blocking, and timed wait version of condition variable wait routines.
Variable Documentation
◆ _POSIX_Condition_variables_Default_attributes
The default condition variable attributes structure.
