17 #ifndef _RTEMS_POSIX_CONDIMPL_H    18 #define _RTEMS_POSIX_CONDIMPL_H    33   pthread_mutex_t *
mutex;
    36 #define POSIX_CONDITION_VARIABLES_CLOCK_MONOTONIC 0x1UL    38 #define POSIX_CONDITION_VARIABLES_FLAGS_MASK 0x1UL    40 #define POSIX_CONDITION_VARIABLES_MAGIC 0x18dfb1feUL    46 #define POSIX_CONDITION_VARIABLES_NO_MUTEX NULL    48 #define POSIX_CONDITION_VARIABLES_TQ_OPERATIONS &_Thread_queue_Operations_FIFO    50 #define POSIX_CONDITION_VARIABLE_OF_THREAD_QUEUE_QUEUE( queue ) \    52     queue, POSIX_Condition_variables_Control, Queue.Queue )    68   const pthread_condattr_t          *the_attr
    76   flags = (uintptr_t) the_cond ^ POSIX_CONDITION_VARIABLES_MAGIC;
    77   flags &= ~POSIX_CONDITION_VARIABLES_FLAGS_MASK;
    79   if ( the_attr->clock == CLOCK_MONOTONIC ) {
    80     flags |= POSIX_CONDITION_VARIABLES_CLOCK_MONOTONIC;
    83   the_cond->flags = flags;
    90   the_cond->flags = ~the_cond->flags;
    97   if ( ( flags & POSIX_CONDITION_VARIABLES_CLOCK_MONOTONIC ) != 0 ) {
    98     return CLOCK_MONOTONIC;
   101   return CLOCK_REALTIME;
   112   _Thread_queue_Context_ISR_disable( queue_context, level );
   114   executing = _Thread_Executing;
   115   _Thread_queue_Queue_acquire_critical(
   116     &the_cond->Queue.Queue,
   117     &executing->Potpourri_stats,
   130     &the_cond->Queue.Queue,
   142   pthread_cond_t            *cond,
   153   pthread_cond_t            *cond,
   154   pthread_mutex_t           *
mutex,
   155   const struct timespec     *abstime
   158 bool _POSIX_Condition_variables_Auto_initialization(
   162 #define POSIX_CONDITION_VARIABLES_VALIDATE_OBJECT( the_cond, flags ) \   164     if ( ( the_cond ) == NULL ) { \   167     flags = ( the_cond )->flags; \   169       ( ( (uintptr_t) ( the_cond ) ^ POSIX_CONDITION_VARIABLES_MAGIC ) \   170           & ~POSIX_CONDITION_VARIABLES_FLAGS_MASK ) \   171         != ( flags & ~POSIX_CONDITION_VARIABLES_FLAGS_MASK ) \   173       if ( !_POSIX_Condition_variables_Auto_initialization( the_cond ) ) { \ #define POSIX_CONDITION_VARIABLES_NO_MUTEX
Definition: condimpl.h:46
Thread queue context for the thread queue methods.
Definition: threadq.h:198
POSIX Threads Private Support.
const pthread_condattr_t _POSIX_Condition_variables_Default_attributes
Definition: conddefaultattributes.c:29
int _POSIX_Condition_variables_Wait_support(pthread_cond_t *cond, pthread_mutex_t *mutex, const struct timespec *abstime)
POSIX condition variables wait support.
Definition: condwaitsupp.c:94
Thread queue with a layout compatible to struct _Thread_queue_Queue defined in Newlib <sys/lock....
Definition: threadqimpl.h:54
int _POSIX_Condition_variables_Signal_support(pthread_cond_t *cond, bool is_broadcast)
Implements wake up version of the "signal" operation.
Definition: condsignalsupp.c:31
uint32_t ISR_Level
Definition: isrlevel.h:41
Thread_queue_Lock_context Lock_context
The lock context for the thread queue acquire and release operations.
Definition: threadq.h:203
Constants and Structures Associated with the Manipulation of Objects.
RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_initialize(Thread_queue_Queue *queue, const char *name)
Initializes the thread queue queue with the given name.
Definition: threadqimpl.h:547
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_ISR_level(Thread_queue_Context *queue_context, ISR_Level level)
Sets the thread queue context ISR level.
Definition: threadqimpl.h:411
Definition: condimpl.h:30
ISR_lock_Context Lock_context
Definition: threadq.h:130
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_release(Thread_queue_Queue *queue, ISR_lock_Context *lock_context)
Releases the thread queue queue and enables interrupts.
Definition: threadqimpl.h:625
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
