28 #ifndef LIBBSP_SPARC_LEON2_BSP_H    29 #define LIBBSP_SPARC_LEON2_BSP_H    59 #define BSP_IDLE_TASK_BODY bsp_idle_thread    64 struct rtems_bsdnet_ifconfig;
    65 extern int rtems_leon_open_eth_driver_attach(
    66   struct rtems_bsdnet_ifconfig *
config    68 extern int rtems_smc91111_driver_attach_leon2(
    69   struct rtems_bsdnet_ifconfig *
config    71 #define RTEMS_BSP_NETWORK_DRIVER_NAME "open_eth1"    72 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH \    73           rtems_leon_open_eth_driver_attach    74 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111 \    75           rtems_smc91111_driver_attach_leon2    80 #define GRETH_SUPPORTED    81 #define GRETH_MEM_LOAD(addr) leon_r32_no_cache((uintptr_t) addr)    87 extern int   CPU_SPARC_HAS_SNOOPING;
    99 extern int   PROM_START;
   101 extern int   PROM_SIZE;
   103 extern int   CLOCK_SPEED;
   110     rtems_isr_entry     handler,
   115 void BSP_fatal_exit(uint32_t error);
   117 void bsp_spurious_initialize(
void );
   120 typedef void (*bsp_shared_isr)(
void *arg);
   123 extern void BSP_shared_interrupt_init(
void);
   138 static __inline__
int BSP_shared_interrupt_register
   157 static __inline__
int BSP_shared_interrupt_unregister
   175 extern void BSP_shared_interrupt_clear(
int irq);
   184 extern void BSP_shared_interrupt_unmask(
int irq);
   193 extern void BSP_shared_interrupt_mask(
int irq);
   198 void rtems_bsp_delay(
int usecs);
   203 int cchip1_register(
void);
   206 #define BSP_PCI_BIG_ENDIAN   213 #define AMBAPPBUS_INFO_AVAIL             214 #define GPTIMER_INFO_AVAIL               215 #define GRETH_INFO_AVAIL                 217 void console_outbyte_polled(
int port,
unsigned char ch );
Definition: deflate.c:115
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
#define RTEMS_INTERRUPT_SHARED
Allows that this interrupt handler may share a common interrupt vector with other handler.
Definition: irq-extension.h:50
rtems_status_code rtems_interrupt_handler_remove(rtems_vector_number vector, rtems_interrupt_handler handler, void *arg)
Removes the interrupt handler routine handler with argument arg for the interrupt vector with number ...
Definition: irq.c:175
rtems_status_code rtems_interrupt_handler_install(rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg)
Installs the interrupt handler routine handler for the interrupt vector with number vector.
Definition: irq.c:127
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
int console_inbyte_nonblocking(int port)
Definition: console-io.c:84
Header file for the Interrupt Manager Extension.
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
